commit 87f4d7c1d36f44b0822053b7e5dedc31fdd0ab99 upstream.
This patch updates the adjfreq callback description to include a note that the
delta in ppb is always relative to the base frequency, and not to the current
frequency of the hardware clock.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
CC: Richard Cochran <richard.cochran@gmail.com>
CC: John Stultz <john.stultz@linaro.org>
commit 95a7d76897c1e7243d4137037c66d15cbf2cce76 upstream.
As Mukesh explained it, the MMUEXT_TLB_FLUSH_ALL allows the
hypervisor to do a TLB flush on all active vCPUs. If instead
we were using the generic one (which ends up being xen_flush_tlb)
we end up making the MMUEXT_TLB_FLUSH_LOCAL hypercall. But
before we make that hypercall the kernel will IPI all of the
vCPUs (even those that were asleep from the hypervisor
perspective). The end result is that we needlessly wake them
up and do a TLB flush when we can just let the hypervisor
do it correctly.
This patch gives around 50% speed improvement when migrating
idle guest's from one host to another.
Oracle-bug: 14630170
Tested-by: Jingjie Jiang <jingjie.jiang@oracle.com>
Suggested-by: Mukesh Rathor <mukesh.rathor@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 9b395bc3be1cebf0144a127c7e67d56dbdac0930 upstream.
A number of places in the mesh code don't check that
the frame data is present and in the skb header when
trying to access. Add those checks and the necessary
pskb_may_pull() calls. This prevents accessing data
that doesn't actually exist.
To do this, export ieee80211_get_mesh_hdrlen() to be
able to use it in mac80211.
commit 115c9b81928360d769a76c632bae62d15206a94a upstream.
Implement a new netlink attribute type IFLA_EXT_MASK. The mask
is a 32 bit value that can be used to indicate to the kernel that
certain extended ifinfo values are requested by the user application.
At this time the only mask value defined is RTEXT_FILTER_VF to
indicate that the user wants the ifinfo dump to send information
about the VFs belonging to the interface.
This patch fixes a bug in which certain applications do not have
large enough buffers to accommodate the extra information returned
by the kernel with large numbers of SR-IOV virtual functions.
Those applications will not send the new netlink attribute with
the interface info dump request netlink messages so they will
not get unexpectedly large request buffers returned by the kernel.
Modifies the rtnl_calcit function to traverse the list of net
devices and compute the minimum buffer size that can hold the
info dumps of all matching devices based upon the filter passed
in via the new netlink attribute filter mask. If no filter
mask is sent then the buffer allocation defaults to NLMSG_GOODSIZE.
With this change it is possible to add yet to be defined netlink
attributes to the dump request which should make it fairly extensible
in the future.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
[bwh: Backported to 3.2: drop the change in do_setlink() that reverts
commit f18da14565819ba43b8321237e2426a2914cc2ef, which we never applied]
commit a0830dbd4e42b38aefdf3fb61ba5019a1a99ea85 upstream.
For more strict protection for wild disconnections, a refcount is
introduced to the card instance, and let it up/down when an object is
referred via snd_lookup_*() in the open ops.
The free-after-last-close check is also changed to check this refcount
instead of the empty list, too.
Reported-by: Matthieu CASTET <matthieu.castet@parrot.com>
commit a007c4c3e943ecc054a806c259d95420a188754b upstream.
I don't think there's a practical difference for the range of values
these interfaces should see, but it would be safer to be unambiguous.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 5b423f6a40a0327f9d40bc8b97ce9be266f74368 upstream.
Existing code assumes that del_timer returns true for alive conntrack
entries. However, this is not true if reliable events are enabled.
In that case, del_timer may return true for entries that were
just inserted in the dying list. Note that packets / ctnetlink may
hold references to conntrack entries that were just inserted to such
list.
This patch fixes the issue by adding an independent timer for
event delivery. This increases the size of the ecache extension.
Still we can revisit this later and use variable size extensions
to allocate this area on demand.
Tested-by: Oliver Smith <olipro@8.c.9.b.0.7.4.0.1.0.0.2.ip6.arpa>
Acked-by: David Miller <davem@davemloft.net>
[ Upstream commit 48cc32d38a52d0b68f91a171a8d00531edc6a46e ]
6a32e4f9dd9219261f8856f817e6655114cfec2f made the vlan code skip marking
vlan-tagged frames for not locally configured vlans as PACKET_OTHERHOST if
there was an rx_handler, as the rx_handler could cause the frame to be received
on a different (virtual) vlan-capable interface where that vlan might be
configured.
As rx_handlers do not necessarily return RX_HANDLER_ANOTHER, this could cause
frames for unknown vlans to be delivered to the protocol stack as if they had
been received untagged.
For example, if an ipv6 router advertisement that's tagged for a locally not
configured vlan is received on an interface with macvlan interfaces attached,
macvlan's rx_handler returns RX_HANDLER_PASS after delivering the frame to the
macvlan interfaces, which caused it to be passed to the protocol stack, leading
to ipv6 addresses for the announced prefix being configured even though those
are completely unusable on the underlying interface.
The fix moves marking as PACKET_OTHERHOST after the rx_handler so the
rx_handler, if there is one, sees the frame unchanged, but afterwards,
before the frame is delivered to the protocol stack, it gets marked whether
there is an rx_handler or not.
Signed-off-by: Florian Zumbiehl <florz@florz.de>
commit bf7a01bf7987b63b121d572b240c132ec44129c4 upstream.
The NAND_CHIPOPTIONS_MSK has limited utility and is causing real bugs. It
silently masks off at least one flag that might be set by the driver
(NAND_NO_SUBPAGE_WRITE). This breaks the GPMI NAND driver and possibly
others.
Really, as long as driver writers exercise a small amount of care with
NAND_* options, this mask is not necessary at all; it was only here to
prevent certain options from accidentally being set by the driver. But the
original thought turns out to be a bad idea occasionally. Thus, kill it.
Note, this patch fixes some major gpmi-nand breakage.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Tested-by: Huang Shijie <shijie8@gmail.com>
Cc: stable@vger.kernel.org
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
[Brian Norris: This is a backport for v3.2 stable.]
commit 5276e16bb6f35412583518d6f04651dd9dc114be upstream.
When using the xt_set.h header in userspace, one will get these gcc
reports:
ipset/ip_set.h:184:1: error: unknown type name "u16"
In file included from libxt_SET.c:21:0:
netfilter/xt_set.h:61:2: error: unknown type name "u32"
netfilter/xt_set.h:62:2: error: unknown type name "u32"
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
commit 9e33ce453f8ac8452649802bee1f410319408f4b upstream.
IPVS should not reset skb->nf_bridge in FORWARD hook
by calling nf_reset for NAT replies. It triggers oops in
br_nf_forward_finish.
[ 579.781508] BUG: unable to handle kernel NULL pointer dereference at 0000000000000004
[ 579.781669] IP: [<ffffffff817b1ca5>] br_nf_forward_finish+0x58/0x112
[ 579.781792] PGD 218f9067 PUD 0
[ 579.781865] Oops: 0000 [#1] SMP
[ 579.781945] CPU 0
[ 579.781983] Modules linked in:
[ 579.782047]
[ 579.782080]
[ 579.782114] Pid: 4644, comm: qemu Tainted: G W 3.5.0-rc5-00006-g95e69f9 #282 Hewlett-Packard /30E8
[ 579.782300] RIP: 0010:[<ffffffff817b1ca5>] [<ffffffff817b1ca5>] br_nf_forward_finish+0x58/0x112
[ 579.782455] RSP: 0018:ffff88007b003a98 EFLAGS: 00010287
[ 579.782541] RAX: 0000000000000008 RBX: ffff8800762ead00 RCX: 000000000001670a
[ 579.782653] RDX: 0000000000000000 RSI: 000000000000000a RDI: ffff8800762ead00
[ 579.782845] RBP: ffff88007b003ac8 R08: 0000000000016630 R09: ffff88007b003a90
[ 579.782957] R10: ffff88007b0038e8 R11: ffff88002da37540 R12: ffff88002da01a02
[ 579.783066] R13: ffff88002da01a80 R14: ffff88002d83c000 R15: ffff88002d82a000
[ 579.783177] FS: 0000000000000000(0000) GS:ffff88007b000000(0063) knlGS:00000000f62d1b70
[ 579.783306] CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b
[ 579.783395] CR2: 0000000000000004 CR3: 00000000218fe000 CR4: 00000000000027f0
[ 579.783505] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 579.783684] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 579.783795] Process qemu (pid: 4644, threadinfo ffff880021b20000, task ffff880021aba760)
[ 579.783919] Stack:
[ 579.783959] ffff88007693cedc ffff8800762ead00 ffff88002da01a02 ffff8800762ead00
[ 579.784110] ffff88002da01a02 ffff88002da01a80 ffff88007b003b18 ffffffff817b26c7
[ 579.784260] ffff880080000000 ffffffff81ef59f0 ffff8800762ead00 ffffffff81ef58b0
[ 579.784477] Call Trace:
[ 579.784523] <IRQ>
[ 579.784562]
[ 579.784603] [<ffffffff817b26c7>] br_nf_forward_ip+0x275/0x2c8
[ 579.784707] [<ffffffff81704b58>] nf_iterate+0x47/0x7d
[ 579.784797] [<ffffffff817ac32e>] ? br_dev_queue_push_xmit+0xae/0xae
[ 579.784906] [<ffffffff81704bfb>] nf_hook_slow+0x6d/0x102
[ 579.784995] [<ffffffff817ac32e>] ? br_dev_queue_push_xmit+0xae/0xae
[ 579.785175] [<ffffffff8187fa95>] ? _raw_write_unlock_bh+0x19/0x1b
[ 579.785179] [<ffffffff817ac417>] __br_forward+0x97/0xa2
[ 579.785179] [<ffffffff817ad366>] br_handle_frame_finish+0x1a6/0x257
[ 579.785179] [<ffffffff817b2386>] br_nf_pre_routing_finish+0x26d/0x2cb
[ 579.785179] [<ffffffff817b2cf0>] br_nf_pre_routing+0x55d/0x5c1
[ 579.785179] [<ffffffff81704b58>] nf_iterate+0x47/0x7d
[ 579.785179] [<ffffffff817ad1c0>] ? br_handle_local_finish+0x44/0x44
[ 579.785179] [<ffffffff81704bfb>] nf_hook_slow+0x6d/0x102
[ 579.785179] [<ffffffff81551525>] ? sky2_poll+0xb35/0xb54
[ 579.785179] [<ffffffff817ad62a>] br_handle_frame+0x213/0x229
[ 579.785179] [<ffffffff817ad417>] ? br_handle_frame_finish+0x257/0x257
[ 579.785179] [<ffffffff816e3b47>] __netif_receive_skb+0x2b4/0x3f1
[ 579.785179] [<ffffffff816e69fc>] process_backlog+0x99/0x1e2
[ 579.785179] [<ffffffff816e6800>] net_rx_action+0xdf/0x242
[ 579.785179] [<ffffffff8107e8a8>] __do_softirq+0xc1/0x1e0
[ 579.785179] [<ffffffff8135a5ba>] ? trace_hardirqs_off_thunk+0x3a/0x6c
[ 579.785179] [<ffffffff8188812c>] call_softirq+0x1c/0x30
The steps to reproduce as follow,
1. On Host1, setup brige br0(192.168.1.106)
2. Boot a kvm guest(192.168.1.105) on Host1 and start httpd
3. Start IPVS service on Host1
ipvsadm -A -t 192.168.1.106:80 -s rr
ipvsadm -a -t 192.168.1.106:80 -r 192.168.1.105:80 -m
4. Run apache benchmark on Host2(192.168.1.101)
ab -n 1000 http://192.168.1.106/
ip_vs_reply4
ip_vs_out
handle_response
ip_vs_notrack
nf_reset()
skb->nf_bridge = NULL;
Actually, IPVS wants in this case just to replace nfct
with untracked version. So replace the nf_reset(skb) call
in ip_vs_notrack() with a nf_conntrack_put(skb->nfct) call.
Signed-off-by: Lin Ming <mlin@ss.pku.edu.cn>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit b22d127a39ddd10d93deee3d96e643657ad53a49 upstream.
shared_policy_replace() use of sp_alloc() is unsafe. 1) sp_node cannot
be dereferenced if sp->lock is not held and 2) another thread can modify
sp_node between spin_unlock for allocating a new sp node and next
spin_lock. The bug was introduced before 2.6.12-rc2.
Kosaki's original patch for this problem was to allocate an sp node and
policy within shared_policy_replace and initialise it when the lock is
reacquired. I was not keen on this approach because it partially
duplicates sp_alloc(). As the paths were sp->lock is taken are not that
performance critical this patch converts sp->lock to sp->mutex so it can
sleep when calling sp_alloc().
[kosaki.motohiro@jp.fujitsu.com: Original patch]
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
Cc: Josh Boyer <jwboyer@gmail.com>
commit 26e8220adb0aec43b7acafa0f1431760eee28522 upstream.
Apparently the same card model has two IDs, so this patch
complements the commit 39aced68d664291db3324d0fcf0985ab5626aac2
adding the missing one.
Signed-off-by: Flavio Leitner <fbl@redhat.com>
[bwh: Backported to 3.2: adjust filename]
[ Upstream commit ecd7918745234e423dd87fcc0c077da557909720 ]
The current code fails to ensure that the netlink message actually
contains as many bytes as the header indicates. If a user creates a new
state or updates an existing one but does not supply the bytes for the
whole ESN replay window, the kernel copies random heap bytes into the
replay bitmap, the ones happen to follow the XFRMA_REPLAY_ESN_VAL
netlink attribute. This leads to following issues:
1. The replay window has random bits set confusing the replay handling
code later on.
2. A malicious user could use this flaw to leak up to ~3.5kB of heap
memory when she has access to the XFRM netlink interface (requires
CAP_NET_ADMIN).
Known users of the ESN replay window are strongSwan and Steffen's
iproute2 patch (<http://patchwork.ozlabs.org/patch/85962/>). The latter
uses the interface with a bitmap supplied while the former does not.
strongSwan is therefore prone to run into issue 1.
To fix both issues without breaking existing userland allow using the
XFRMA_REPLAY_ESN_VAL netlink attribute with either an empty bitmap or a
fully specified one. For the former case we initialize the in-kernel
bitmap with zero, for the latter we copy the user supplied bitmap. For
state updates the full bitmap must be supplied.
To prevent overflows in the bitmap length calculation the maximum size
of bmp_len is limited to 128 by this patch -- resulting in a maximum
replay window of 4096 packets. This should be sufficient for all real
life scenarios (RFC 4303 recommends a default replay window size of 64).
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Martin Willi <martin@revosec.ch>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Mathias Krause <minipli@googlemail.com>
[ Upstream commit 3b59df46a449ec9975146d71318c4777ad086744 ]
ESN for esp is defined in RFC 4303. This RFC assumes that the
sequence number counters are always up to date. However,
this is not true if an async crypto algorithm is employed.
If the sequence number counters are not up to date on sequence
number check, we may incorrectly update the upper 32 bit of
the sequence number. This leads to a DOS.
We workaround this by comparing the upper sequence number,
(used for authentication) with the upper sequence number
computed after the async processing. We drop the packet
if these numbers are different.
To do this, we introduce a recheck function that does this
check in the ESN case.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit d6d7c873529abd622897cad5e36f1fd7d82f5110 upstream.
Commit b6787242f327 ("HID: hidraw: add proper error handling to raw event
reporting") forgot to update the static inline version of
hidraw_report_event() for the case when CONFIG_HIDRAW is unset. Fix that
up.
commit b6787242f32700377d3da3b8d788ab3928bab849 upstream.
If kmemdup() in hidraw_report_event() fails, we are not propagating
this fact properly.
Let hidraw_report_event() and hid_report_raw_event() return an error
value to the caller.
Reported-by: Oliver Neukum <oneukum@suse.de>
commit cc110922da7e902b62d18641a370fec01a9fa794 upstream.
To make it clear that it may be called from contexts that may not have
any knowledge of L2CAP, we change the connection parameter, to receive
a hci_conn.
This also makes it clear that it is checking the security of the link.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 85f2a2ef1d0ab99523e0b947a2b723f5650ed6aa upstream.
When allocating memory fails, page is NULL. page_to_pfn() will
cause the kernel panicked if we don't use sparsemem vmemmap.
Link: http://lkml.kernel.org/r/505AB1FF.8020104@cn.fujitsu.com
Acked-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
commit b161dfa6937ae46d50adce8a7c6b12233e96e7bd upstream.
IBM reported a soft lockup after applying the fix for the rename_lock
deadlock. Commit c83ce989cb5f ("VFS: Fix the nfs sillyrename regression
in kernel 2.6.38") was found to be the culprit.
The nfs sillyrename fix used DCACHE_DISCONNECTED to indicate that the
dentry was killed. This flag can be set on non-killed dentries too,
which results in infinite retries when trying to traverse the dentry
tree.
This patch introduces a separate flag: DCACHE_DENTRY_KILLED, which is
only set in d_kill() and makes try_to_ascend() test only this flag.
IBM reported successful test results with this patch.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 05cf96398e1b6502f9e191291b715c7463c9d5dd upstream.
I found following definition in include/linux/memory.h, in my IA64
platform, SECTION_SIZE_BITS is equal to 32, and MIN_MEMORY_BLOCK_SIZE
will be 0.
#define MIN_MEMORY_BLOCK_SIZE (1 << SECTION_SIZE_BITS)
Because MIN_MEMORY_BLOCK_SIZE is int type and length of 32bits,
so MIN_MEMORY_BLOCK_SIZE(1 << 32) will will equal to 0.
Actually when SECTION_SIZE_BITS >= 31, MIN_MEMORY_BLOCK_SIZE will be wrong.
This will cause wrong system memory infomation in sysfs.
I think it should be:
#define MIN_MEMORY_BLOCK_SIZE (1UL << SECTION_SIZE_BITS)
And "echo offline > memory0/state" will cause following call trace:
kernel BUG at mm/memory_hotplug.c:885!
sh[6455]: bugcheck! 0 [1]
Pid: 6455, CPU 0, comm: sh
psr : 0000101008526030 ifs : 8000000000000fa4 ip : [<a0000001008c40f0>] Not tainted (3.6.0-rc1)
ip is at offline_pages+0x210/0xee0
Call Trace:
show_stack+0x80/0xa0
show_regs+0x640/0x920
die+0x190/0x2c0
die_if_kernel+0x50/0x80
ia64_bad_break+0x3d0/0x6e0
ia64_native_leave_kernel+0x0/0x270
alloc_pages_current+0x180/0x2a0
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit f39c1bfb5a03e2d255451bff05be0d7255298fa4 upstream.
Commit 43cedbf0e8dfb9c5610eb7985d5f21263e313802 (SUNRPC: Ensure that
we grab the XPRT_LOCK before calling xprt_alloc_slot) is causing
hangs in the case of NFS over UDP mounts.
Since neither the UDP or the RDMA transport mechanism use dynamic slot
allocation, we can skip grabbing the socket lock for those transports.
Add a new rpc_xprt_op to allow switching between the TCP and UDP/RDMA
case.
Note that the NFSv4.1 back channel assigns the slot directly
through rpc_run_bc_task, so we can ignore that case.
Reported-by: Dick Streefland <dick.streefland@altium.nl>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 60e233a56609fd963c59e99bd75c663d63fa91b6 upstream.
Fengguang Wu <fengguang.wu@intel.com> writes:
> After the __devinit* removal series, I can still get kernel panic in
> show_uevent(). So there are more sources of bug..
> Debug patch:
> @@ -343,8 +343,11 @@ static ssize_t show_uevent(struct device
> goto out;
> /* copy keys to file */
> - for (i = 0; i < env->envp_idx; i++)
> + dev_err(dev, "uevent %d env[%d]: %s/.../%s\n", env->buflen, env->envp_idx, top_kobj->name, dev->kobj.name);
> + for (i = 0; i < env->envp_idx; i++) {
> + printk(KERN_ERR "uevent %d env[%d]: %s\n", (int)count, i, env->envp[i]);
> count += sprintf(&buf[count], "%s\n", env->envp[i]);
> Oops message, the env[] is again not properly initilized:
> [ 44.068623] input input0: uevent 61 env[805306368]: input0/.../input0
> [ 44.069552] uevent 0 env[0]: (null)
This is a completely different CONFIG_HOTPLUG problem, only
demonstrating another reason why CONFIG_HOTPLUG should go away. I had a
hard time trying to disable it anyway ;-)
The problem this time is lots of code assuming that a call to
add_uevent_var() will guarantee that env->buflen > 0. This is not true
if CONFIG_HOTPLUG is unset. So things like this end up overwriting
env->envp_idx because the array index is -1:
if (add_uevent_var(env, "MODALIAS="))
return -ENOMEM;
len = input_print_modalias(&env->buf[env->buflen - 1],
sizeof(env->buf) - env->buflen,
dev, 0);
Don't know what the best action is, given that there seem to be a *lot*
of this around the kernel. This patch "fixes" the problem for me, but I
don't know if it can be considered an appropriate fix.
[ It is the correct fix for now, for 3.7 forcing CONFIG_HOTPLUG to
always be on is the longterm fix, but it's too late for 3.6 and older
kernels to resolve this that way - gregkh ]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit c3f52af3e03013db5237e339c817beaae5ec9e3a upstream.
When the NFS_COOKIEVERF helper macro was converted into a static
inline function in commit 99fadcd764 (nfs: convert NFS_*(inode)
helpers to static inline), we broke the initialisation of the
readdir cookies, since that depended on doing a memset with an
argument of 'sizeof(NFS_COOKIEVERF(inode))' which therefore
changed from sizeof(be32 cookieverf[2]) to sizeof(be32 *).
At this point, NFS_COOKIEVERF seems to be more of an obfuscation
than a helper, so the best thing would be to just get rid of it.
Also see: https://bugzilla.kernel.org/show_bug.cgi?id=46881
Reported-by: Andi Kleen <andi@firstfloor.org>
Reported-by: David Binderman <dcb314@hotmail.com>
commit a6fa941d94b411bbd2b6421ffbde6db3c93e65ab upstream.
Don't mess with file refcounts (or keep a reference to file, for
that matter) in perf_event. Use explicit refcount of its own
instead. Deal with the race between the final reference to event
going away and new children getting created for it by use of
atomic_long_inc_not_zero() in inherit_event(); just have the
latter free what it had allocated and return NULL, that works
out just fine (children of siblings of something doomed are
created as singletons, same as if the child of leader had been
created and immediately killed).
Link: http://lkml.kernel.org/r/20120820135925.GG23464@ZenIV.linux.org.uk
This is a -stable backport of cee58483cf56e0ba355fdd97ff5e8925329aa936
Andreas Bombe reported that the added ktime_t overflow checking added to
timespec_valid in commit 4e8b14526ca7 ("time: Improve sanity checking of
timekeeping inputs") was causing problems with X.org because it caused
timeouts larger then KTIME_T to be invalid.
Previously, these large timeouts would be clamped to KTIME_MAX and would
never expire, which is valid.
This patch splits the ktime_t overflow checking into a new
timespec_valid_strict function, and converts the timekeeping codes
internal checking to use this more strict function.
Reported-and-tested-by: Andreas Bombe <aeb@debian.org>
Cc: Zhouping Liu <zliu@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Linux Kernel <linux-kernel@vger.kernel.org>
This is a -stable backport of 4e8b14526ca7fb046a81c94002c1c43b6fdf0e9b
Unexpected behavior could occur if the time is set to a value large
enough to overflow a 64bit ktime_t (which is something larger then the
year 2262).
Also unexpected behavior could occur if large negative offsets are
injected via adjtimex.
So this patch improves the sanity check timekeeping inputs by
improving the timespec_valid() check, and then makes better use of
timespec_valid() to make sure we don't set the time to an invalid
negative value or one that overflows ktime_t.
Note: This does not protect from setting the time close to overflowing
ktime_t and then letting natural accumulation cause the overflow.
Reported-by: CAI Qian <caiqian@redhat.com>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Link: http://lkml.kernel.org/r/1344454580-17031-1-git-send-email-john.stultz@linaro.org
[ Upstream commit 5c879d2094946081af934739850c7260e8b25d3c ]
Commit c3def943c7117d42caaed3478731ea7c3c87190e have added support for
new pci ids of the 57840 board, while failing to change the obsolete value
in 'pci_ids.h'.
This patch does so, allowing the probe of such devices.
Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
[ Upstream commit e0e3cea46d31d23dc40df0a49a7a2c04fe8edfea ]
Pablo Neira Ayuso discovered that avahi and
potentially NetworkManager accept spoofed Netlink messages because of a
kernel bug. The kernel passes all-zero SCM_CREDENTIALS ancillary data
to the receiver if the sender did not provide such data, instead of not
including any such data at all or including the correct data from the
peer (as it is the case with AF_UNIX).
This bug was introduced in commit 16e572626961
(af_unix: dont send SCM_CREDENTIALS by default)
This patch forces passing credentials for netlink, as
before the regression.
Another fix would be to not add SCM_CREDENTIALS in
netlink messages if not provided by the sender, but it
might break some programs.
With help from Florian Weimer & Petr Matousek
This issue is designated as CVE-2012-3520
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
[ Upstream commit c0de08d04215031d68fa13af36f347a6cfa252ca ]
If a packet is emitted on one socket in one group of fanout sockets,
it is transmitted again. It is thus read again on one of the sockets
of the fanout group. This result in a loop for software which
generate packets when receiving one.
This retransmission is not the intended behavior: a fanout group
must behave like a single socket. The packet should not be
transmitted on a socket if it originates from a socket belonging
to the same fanout group.
This patch fixes the issue by changing the transmission check to
take fanout group info account.
Reported-by: Aleksandr Kotov <a1k@mail.ru>
Signed-off-by: Eric Leblond <eric@regit.org>
[ Upstream commit 1485348d2424e1131ea42efc033cbd9366462b01 ]
Cache the device gso_max_segs in sock::sk_gso_max_segs and use it to
limit the size of TSO skbs. This avoids the need to fall back to
software GSO for local TCP senders.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
[ Upstream commit 30b678d844af3305cda5953467005cebb5d7b687 ]
A peer (or local user) may cause TCP to use a nominal MSS of as little
as 88 (actual MSS of 76 with timestamps). Given that we have a
sufficiently prodigious local sender and the peer ACKs quickly enough,
it is nevertheless possible to grow the window for such a connection
to the point that we will try to send just under 64K at once. This
results in a single skb that expands to 861 segments.
In some drivers with TSO support, such an skb will require hundreds of
DMA descriptors; a substantial fraction of a TX ring or even more than
a full ring. The TX queue selected for the skb may stall and trigger
the TX watchdog repeatedly (since the problem skb will be retried
after the TX reset). This particularly affects sfc, for which the
issue is designated as CVE-2012-3412.
Therefore:
1. Add the field net_device::gso_max_segs holding the device-specific
limit.
2. In netif_skb_features(), if the number of segments is too high then
mask out GSO features to force fall back to software GSO.
commit 3550ccdb9d8d350e526b809bf3dd92b550a74fe1 upstream.
For several MoviNAND eMMC parts, there are known issues with secure
erase and secure trim. For these specific MoviNAND devices, we skip
these operations.
Specifically, there is a bug in the eMMC firmware that causes
unrecoverable corruption when the MMC is erased with MMC_CAP_ERASE
enabled.
References:
http://forum.xda-developers.com/showthread.php?t=1644364
https://plus.google.com/111398485184813224730/posts/21pTYfTsCkB#111398485184813224730/posts/21pTYfTsCkB
Signed-off-by: Ian Chen <ian.cy.chen@samsung.com>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
[bwh: Backported to 3.2: adjust context]
commit 7c4eaca4162d0b5ad4fb39f974d7ffd71b9daa09 upstream.
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com>
commit 58569aee5a1a5dcc25c34a0a2ed9a377874e6b05 upstream.
The mv643xx ethernet controller limits the packet size for the TX
checksum offloading. This patch sets this limits for Kirkwood and
Dove which have smaller limits that the default.
As a side note, this patch is an updated version of a patch sent some years
ago: http://lists.infradead.org/pipermail/linux-arm-kernel/2010-June/017320.html
which seems to have been lost.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
[bwh: Backported to 3.2: adjust for the extra two parameters of
orion_ge0{0,1}_init()]
commit 0bce9c46bf3b15f485d82d7e81dabed6ebcc24b1 upstream.
ARM recently moved to asm-generic/mutex-xchg.h for its mutex
implementation after the previous implementation was found to be missing
some crucial memory barriers. However, this has revealed some problems
running hackbench on SMP platforms due to the way in which the
MUTEX_SPIN_ON_OWNER code operates.
The symptoms are that a bunch of hackbench tasks are left waiting on an
unlocked mutex and therefore never get woken up to claim it. This boils
down to the following sequence of events:
Task A Task B Task C Lock value
0 1
1 lock() 0
2 lock() 0
3 spin(A) 0
4 unlock() 1
5 lock() 0
6 cmpxchg(1,0) 0
7 contended() -1
8 lock() 0
9 spin(C) 0
10 unlock() 1
11 cmpxchg(1,0) 0
12 unlock() 1
At this point, the lock is unlocked, but Task B is in an uninterruptible
sleep with nobody to wake it up.
This patch fixes the problem by ensuring we put the lock into the
contended state if we fail to acquire it on the fastpath, ensuring that
any blocked waiters are woken up when the mutex is released.
Cc: Chris Mason <chris.mason@fusionio.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Link: http://lkml.kernel.org/n/tip-6e9lrw2avczr0617fzl5vqb8@git.kernel.org
commit d81a5d1956731c453b85c141458d4ff5d6cc5366 upstream.
A lot of Broadcom Bluetooth devices provides vendor specific interface
class and we are getting flooded by patches adding new device support.
This change will help us enable support for any other Broadcom with vendor
specific device that arrives in the future.
Only the product id changes for those devices, so this macro would be
perfect for us:
{ USB_VENDOR_AND_INTERFACE_INFO(0x0a5c, 0xff, 0x01, 0x01) }
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Acked-by: Henrik Rydberg <rydberg@bitmath.se>
commit 4eef6cbfcc03b294d9d334368a851b35b496ce53 upstream.
The EETI touchscreen asserts its IRQ line as soon as it has data in its
internal buffers. The line is automatically deasserted once all data has
been read via I2C. Hence, the driver has to monitor the GPIO line and
cannot simply rely on the interrupt handler reception.
In the current implementation of the driver, irq_to_gpio() is used to
determine the GPIO number from the i2c_client's IRQ value.
As irq_to_gpio() is not available on all platforms, this patch changes
this and makes the driver ignore the passed in IRQ. Instead, a GPIO is
added to the platform_data struct and gpio_to_irq is used to derive the
IRQ from that GPIO. If this fails, bail out. The driver is only able to
work in environments where the touchscreen GPIO can be mapped to an
IRQ.
Without this patch, building raumfeld_defconfig results in:
drivers/input/touchscreen/eeti_ts.c: In function 'eeti_ts_irq_active':
drivers/input/touchscreen/eeti_ts.c:65:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration]
Signed-off-by: Daniel Mack <zonque@gmail.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Sven Neumann <s.neumann@raumfeld.com>
Cc: linux-input@vger.kernel.org
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
[bwh: Backported to 3.2: raumfeld_controller_i2c_board_info.irq was
initialised using gpio_to_irq(), but this doesn't seem to matter]
commit 59ee93a528b94ef4e81a08db252b0326feff171f upstream.
The irq_to_gpio function was removed from the pxa platform
in linux-3.2, and this driver has been broken since.
There is actually no in-tree user of this driver that adds
this platform device, but the driver can and does get enabled
on some platforms.
Without this patch, building ezx_defconfig results in:
drivers/mfd/ezx-pcap.c: In function 'pcap_isr_work':
drivers/mfd/ezx-pcap.c:205:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration]
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
commit d833352a4338dc31295ed832a30c9ccff5c7a183 upstream.
If a process creates a large hugetlbfs mapping that is eligible for page
table sharing and forks heavily with children some of whom fault and
others which destroy the mapping then it is possible for page tables to
get corrupted. Some teardowns of the mapping encounter a "bad pmd" and
output a message to the kernel log. The final teardown will trigger a
BUG_ON in mm/filemap.c.
This was reproduced in 3.4 but is known to have existed for a long time
and goes back at least as far as 2.6.37. It was probably was introduced
in 2.6.20 by [39dde65c: shared page table for hugetlb page]. The messages
look like this;
[ ..........] Lots of bad pmd messages followed by this
[ 127.164256] mm/memory.c:391: bad pmd ffff880412e04fe8(80000003de4000e7).
[ 127.164257] mm/memory.c:391: bad pmd ffff880412e04ff0(80000003de6000e7).
[ 127.164258] mm/memory.c:391: bad pmd ffff880412e04ff8(80000003de0000e7).
[ 127.186778] ------------[ cut here ]------------
[ 127.186781] kernel BUG at mm/filemap.c:134!
[ 127.186782] invalid opcode: 0000 [#1] SMP
[ 127.186783] CPU 7
[ 127.186784] Modules linked in: af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf ext3 jbd dm_mod coretemp crc32c_intel usb_storage ghash_clmulni_intel aesni_intel i2c_i801 r8169 mii uas sr_mod cdrom sg iTCO_wdt iTCO_vendor_support shpchp serio_raw cryptd aes_x86_64 e1000e pci_hotplug dcdbas aes_generic container microcode ext4 mbcache jbd2 crc16 sd_mod crc_t10dif i915 drm_kms_helper drm i2c_algo_bit ehci_hcd ahci libahci usbcore rtc_cmos usb_common button i2c_core intel_agp video intel_gtt fan processor thermal thermal_sys hwmon ata_generic pata_atiixp libata scsi_mod
[ 127.186801]
[ 127.186802] Pid: 9017, comm: hugetlbfs-test Not tainted 3.4.0-autobuild #53 Dell Inc. OptiPlex 990/06D7TR
[ 127.186804] RIP: 0010:[<ffffffff810ed6ce>] [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160
[ 127.186809] RSP: 0000:ffff8804144b5c08 EFLAGS: 00010002
[ 127.186810] RAX: 0000000000000001 RBX: ffffea000a5c9000 RCX: 00000000ffffffc0
[ 127.186811] RDX: 0000000000000000 RSI: 0000000000000009 RDI: ffff88042dfdad00
[ 127.186812] RBP: ffff8804144b5c18 R08: 0000000000000009 R09: 0000000000000003
[ 127.186813] R10: 0000000000000000 R11: 000000000000002d R12: ffff880412ff83d8
[ 127.186814] R13: ffff880412ff83d8 R14: 0000000000000000 R15: ffff880412ff83d8
[ 127.186815] FS: 00007fe18ed2c700(0000) GS:ffff88042dce0000(0000) knlGS:0000000000000000
[ 127.186816] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 127.186817] CR2: 00007fe340000503 CR3: 0000000417a14000 CR4: 00000000000407e0
[ 127.186818] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 127.186819] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 127.186820] Process hugetlbfs-test (pid: 9017, threadinfo ffff8804144b4000, task ffff880417f803c0)
[ 127.186821] Stack:
[ 127.186822] ffffea000a5c9000 0000000000000000 ffff8804144b5c48 ffffffff810ed83b
[ 127.186824] ffff8804144b5c48 000000000000138a 0000000000001387 ffff8804144b5c98
[ 127.186825] ffff8804144b5d48 ffffffff811bc925 ffff8804144b5cb8 0000000000000000
[ 127.186827] Call Trace:
[ 127.186829] [<ffffffff810ed83b>] delete_from_page_cache+0x3b/0x80
[ 127.186832] [<ffffffff811bc925>] truncate_hugepages+0x115/0x220
[ 127.186834] [<ffffffff811bca43>] hugetlbfs_evict_inode+0x13/0x30
[ 127.186837] [<ffffffff811655c7>] evict+0xa7/0x1b0
[ 127.186839] [<ffffffff811657a3>] iput_final+0xd3/0x1f0
[ 127.186840] [<ffffffff811658f9>] iput+0x39/0x50
[ 127.186842] [<ffffffff81162708>] d_kill+0xf8/0x130
[ 127.186843] [<ffffffff81162812>] dput+0xd2/0x1a0
[ 127.186845] [<ffffffff8114e2d0>] __fput+0x170/0x230
[ 127.186848] [<ffffffff81236e0e>] ? rb_erase+0xce/0x150
[ 127.186849] [<ffffffff8114e3ad>] fput+0x1d/0x30
[ 127.186851] [<ffffffff81117db7>] remove_vma+0x37/0x80
[ 127.186853] [<ffffffff81119182>] do_munmap+0x2d2/0x360
[ 127.186855] [<ffffffff811cc639>] sys_shmdt+0xc9/0x170
[ 127.186857] [<ffffffff81410a39>] system_call_fastpath+0x16/0x1b
[ 127.186858] Code: 0f 1f 44 00 00 48 8b 43 08 48 8b 00 48 8b 40 28 8b b0 40 03 00 00 85 f6 0f 88 df fe ff ff 48 89 df e8 e7 cb 05 00 e9 d2 fe ff ff <0f> 0b 55 83 e2 fd 48 89 e5 48 83 ec 30 48 89 5d d8 4c 89 65 e0
[ 127.186868] RIP [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160
[ 127.186870] RSP <ffff8804144b5c08>
[ 127.186871] ---[ end trace 7cbac5d1db69f426 ]---
The bug is a race and not always easy to reproduce. To reproduce it I was
doing the following on a single socket I7-based machine with 16G of RAM.
$ hugeadm --pool-pages-max DEFAULT:13G
$ echo $((18*1048576*1024)) > /proc/sys/kernel/shmmax
$ echo $((18*1048576*1024)) > /proc/sys/kernel/shmall
$ for i in `seq 1 9000`; do ./hugetlbfs-test; done
On my particular machine, it usually triggers within 10 minutes but
enabling debug options can change the timing such that it never hits.
Once the bug is triggered, the machine is in trouble and needs to be
rebooted. The machine will respond but processes accessing proc like "ps
aux" will hang due to the BUG_ON. shutdown will also hang and needs a
hard reset or a sysrq-b.
The basic problem is a race between page table sharing and teardown. For
the most part page table sharing depends on i_mmap_mutex. In some cases,
it is also taking the mm->page_table_lock for the PTE updates but with
shared page tables, it is the i_mmap_mutex that is more important.
Unfortunately it appears to be also insufficient. Consider the following
situation
Process A Process B
hugetlb_fault shmdt
LockWrite(mmap_sem)
do_munmap
unmap_region
unmap_vmas
unmap_single_vma
unmap_hugepage_range
Lock(i_mmap_mutex)
Lock(mm->page_table_lock)
huge_pmd_unshare/unmap tables <--- (1)
Unlock(mm->page_table_lock)
Unlock(i_mmap_mutex)
huge_pte_alloc ...
Lock(i_mmap_mutex) ...
vma_prio_walk, find svma, spte ...
Lock(mm->page_table_lock) ...
share spte ...
Unlock(mm->page_table_lock) ...
Unlock(i_mmap_mutex) ...
hugetlb_no_page <--- (2)
free_pgtables
unlink_file_vma
hugetlb_free_pgd_range
remove_vma_list
In this scenario, it is possible for Process A to share page tables with
Process B that is trying to tear them down. The i_mmap_mutex on its own
does not prevent Process A walking Process B's page tables. At (1) above,
the page tables are not shared yet so it unmaps the PMDs. Process A sets
up page table sharing and at (2) faults a new entry. Process B then trips
up on it in free_pgtables.
This patch fixes the problem by adding a new function
__unmap_hugepage_range_final that is only called when the VMA is about to
be destroyed. This function clears VM_MAYSHARE during
unmap_hugepage_range() under the i_mmap_mutex. This makes the VMA
ineligible for sharing and avoids the race. Superficially this looks like
it would then be vunerable to truncate and madvise issues but hugetlbfs
has its own truncate handlers so does not use unmap_mapping_range() and
does not support madvise(DONTNEED).
This should be treated as a -stable candidate if it is merged.
Test program is as follows. The test case was mostly written by Michal
Hocko with a few minor changes to reproduce this bug.
==== CUT HERE ====
static size_t huge_page_size = (2UL << 20);
static size_t nr_huge_page_A = 512;
static size_t nr_huge_page_B = 5632;
unsigned int get_random(unsigned int max)
struct timeval tv;
gettimeofday(&tv, NULL);
srandom(tv.tv_usec);
return random() % max;
static void play(void *addr, size_t size)
unsigned char *start = addr,
*end = start + size,
*a;
start += get_random(size/2);
/* we could itterate on huge pages but let's give it more time. */
for (a = start; a < end; a += 4096)
*a = 0;
int main(int argc, char **argv)
key_t key = IPC_PRIVATE;
size_t sizeA = nr_huge_page_A * huge_page_size;
size_t sizeB = nr_huge_page_B * huge_page_size;
int shmidA, shmidB;
void *addrA = NULL, *addrB = NULL;
int nr_children = 300, n = 0;
if ((shmidA = shmget(key, sizeA, IPC_CREAT|SHM_HUGETLB|0660)) == -1) {
perror("shmget:");
return 1;
if ((addrA = shmat(shmidA, addrA, SHM_R|SHM_W)) == (void *)-1UL) {
perror("shmat");
return 1;
if ((shmidB = shmget(key, sizeB, IPC_CREAT|SHM_HUGETLB|0660)) == -1) {
perror("shmget:");
return 1;
if ((addrB = shmat(shmidB, addrB, SHM_R|SHM_W)) == (void *)-1UL) {
perror("shmat");
return 1;
fork_child:
switch(fork()) {
case 0:
switch (n%3) {
case 0:
play(addrA, sizeA);
break;
case 1:
play(addrB, sizeB);
break;
case 2:
break;
break;
case -1:
perror("fork:");
break;
default:
if (++n < nr_children)
goto fork_child;
play(addrA, sizeA);
break;
shmdt(addrA);
shmdt(addrB);
do {
wait(NULL);
} while (--n > 0);
shmctl(shmidA, IPC_RMID, NULL);
shmctl(shmidB, IPC_RMID, NULL);
return 0;
[akpm@linux-foundation.org: name the declaration's args, fix CONFIG_HUGETLBFS=n build]
- Adjust context
- Drop the mmu_gather * parameters]
commit c2557a303ab6712bb6e09447df828c557c710ac9 upstream.
Create a new function, get_random_bytes_arch() which will use the
architecture-specific hardware random number generator if it is
present. Change get_random_bytes() to not use the HW RNG, even if it
is avaiable.
The reason for this is that the hw random number generator is fast (if
it is present), but it requires that we trust the hardware
manufacturer to have not put in a back door. (For example, an
increasing counter encrypted by an AES key known to the NSA.)
It's unlikely that Intel (for example) was paid off by the US
Government to do this, but it's impossible for them to prove otherwise
commit a2080a67abe9e314f9e9c2cc3a4a176e8a8f8793 upstream.
Add a new interface, add_device_randomness() for adding data to the
random pool that is likely to differ between two devices (or possibly
even per boot). This would be things like MAC addresses or serial
numbers, or the read-out of the RTC. This does *not* add any actual
entropy to the pool, but it initializes the pool to different values
for devices that might otherwise be identical and have very little
entropy available to them (particularly common in the embedded world).
[ Modified by tytso to mix in a timestamp, since there may be some
variability caused by the time needed to detect/configure the hardware
in question. ]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream.
We've been moving away from add_interrupt_randomness() for various
reasons: it's too expensive to do on every interrupt, and flooding the
CPU with interrupts could theoretically cause bogus floods of entropy
from a somewhat externally controllable source.
This solves both problems by limiting the actual randomness addition
to just once a second or after 64 interrupts, whicever comes first.
During that time, the interrupt cycle data is buffered up in a per-cpu
pool. Also, we make sure the the nonblocking pool used by urandom is
initialized before we start feeding the normal input pool. This
assures that /dev/urandom is returning unpredictable data as soon as
possible.
(Based on an original patch by Linus, but significantly modified by
tytso.)
Tested-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu>
Reported-by: Zakir Durumeric <zakir@umich.edu>
Reported-by: J. Alex Halderman <jhalderm@umich.edu>.
commit 8323f26ce3425460769605a6aece7a174edaa7d1 upstream
Stefan reported a crash on a kernel before a3e5d1091c1 ("sched:
Don't call task_group() too many times in set_task_rq()"), he
found the reason to be that the multiple task_group()
invocations in set_task_rq() returned different values.
Looking at all that I found a lack of serialization and plain
wrong comments.
The below tries to fix it using an extra pointer which is
updated under the appropriate scheduler locks. Its not pretty,
but I can't really see another way given how all the cgroup
stuff works.
Reported-and-tested-by: Stefan Bader <stefan.bader@canonical.com>
Link: http://lkml.kernel.org/r/1340364965.18025.71.camel@twins
(backported to previous file names and layout)
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
commit 34f6055c80285e4efb3f602a9119db75239744dc upstream.
There are a number of QUEUE_FLAG_DEAD tests. Add blk_queue_dead()
macro and use it.
This patch doesn't introduce any functional difference.
commit 6575820221f7a4dd6eadecf7bf83cdd154335eda upstream.
Currently, all workqueue cpu hotplug operations run off
CPU_PRI_WORKQUEUE which is higher than normal notifiers. This is to
ensure that workqueue is up and running while bringing up a CPU before
other notifiers try to use workqueue on the CPU.
Per-cpu workqueues are supposed to remain working and bound to the CPU
for normal CPU_DOWN_PREPARE notifiers. This holds mostly true even
with workqueue offlining running with higher priority because
workqueue CPU_DOWN_PREPARE only creates a bound trustee thread which
runs the per-cpu workqueue without concurrency management without
explicitly detaching the existing workers.
However, if the trustee needs to create new workers, it creates
unbound workers which may wander off to other CPUs while
CPU_DOWN_PREPARE notifiers are in progress. Furthermore, if the CPU
down is cancelled, the per-CPU workqueue may end up with workers which
aren't bound to the CPU.
While reliably reproducible with a convoluted artificial test-case
involving scheduling and flushing CPU burning work items from CPU down
notifiers, this isn't very likely to happen in the wild, and, even
when it happens, the effects are likely to be hidden by the following
successful CPU down.
Fix it by using different priorities for up and down notifiers - high
priority for up operations and low priority for down operations.
Workqueue cpu hotplug operations will soon go through further cleanup.
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
commit e2397c704429025bc6b331a970f699e52f34283e upstream.
Many SCSI commands are defined to return a CHECK CONDITION / ILLEGAL
REQUEST with ASC set to LOGICAL BLOCK ADDRESS OUT OF RANGE if the
initiator sends a command that accesses a too-big LBA. Add an enum
value and case entries so that target code can return this status.
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 5aaa0b7a2ed5b12692c9ffb5222182bd558d3146 upstream.
Follow up on commit 556061b00 ("sched/nohz: Fix rq->cpu_load[]
calculations") since while that fixed the busy case it regressed the
mostly idle case.
Add a callback from the nohz exit to also age the rq->cpu_load[]
array. This closes the hole where either there was no nohz load
balance pass during the nohz, or there was a 'significant' amount of
idle time between the last nohz balance and the nohz exit.
So we'll update unconditionally from the tick to not insert any
accidental 0 load periods while busy, and we try and catch up from
nohz idle balance and nohz exit. Both these are still prone to missing
a jiffy, but that has always been the case.
Cc: pjt@google.com
Cc: Venkatesh Pallipadi <venki@google.com>
Link: http://lkml.kernel.org/n/tip-kt0trz0apodbf84ucjfdbr1a@git.kernel.org
[bwh: Backported to 3.2: adjust filenames and context]
commit cc9a6c8776615f9c194ccf0b63a0aa5628235545 upstream.
Stable note: Not tracked in Bugzilla. [get|put]_mems_allowed() is extremely
expensive and severely impacted page allocator performance. This
is part of a series of patches that reduce page allocator overhead.
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when
changing cpuset's mems") wins a super prize for the largest number of
memory barriers entered into fast paths for one commit.
[get|put]_mems_allowed is incredibly heavy with pairs of full memory
barriers inserted into a number of hot paths. This was detected while
investigating at large page allocator slowdown introduced some time
after 2.6.32. The largest portion of this overhead was shown by
oprofile to be at an mfence introduced by this commit into the page
allocator hot path.
For extra style points, the commit introduced the use of yield() in an
implementation of what looks like a spinning mutex.
This patch replaces the full memory barriers on both read and write
sides with a sequence counter with just read barriers on the fast path
side. This is much cheaper on some architectures, including x86. The
main bulk of the patch is the retry logic if the nodemask changes in a
manner that can cause a false failure.
While updating the nodemask, a check is made to see if a false failure
is a risk. If it is, the sequence number gets bumped and parallel
allocators will briefly stall while the nodemask update takes place.
In a page fault test microbenchmark, oprofile samples from
__alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The
actual results were
3.3.0-rc3 3.3.0-rc3
rc3-vanilla nobarrier-v2r1
Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%)
Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%)
Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%)
Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%)
Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%)
Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%)
Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%)
Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%)
Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%)
Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%)
Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%)
Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%)
Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%)
Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%)
Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%)
MMTests Statistics: duration
Sys Time Running Test (seconds) 135.68 132.17
User+Sys Time Running Test (seconds) 164.2 160.13
Total Elapsed Time (seconds) 123.46 120.87
The overall improvement is small but the System CPU time is much
improved and roughly in correlation to what oprofile reported (these
performance figures are without profiling so skew is expected). The
actual number of page faults is noticeably improved.
For benchmarks like kernel builds, the overall benefit is marginal but
the system CPU time is slightly reduced.
To test the actual bug the commit fixed I opened two terminals. The
first ran within a cpuset and continually ran a small program that
faulted 100M of anonymous data. In a second window, the nodemask of the
cpuset was continually randomised in a loop.
Without the commit, the program would fail every so often (usually
within 10 seconds) and obviously with the commit everything worked fine.
With this patch applied, it also worked fine so the fix should be
functionally equivalent.
Cc: Miao Xie <miaox@cn.fujitsu.com>
Cc: Christoph Lameter <cl@linux.com>
[bwh: Forward-ported from 3.0 to 3.2: apply the upstream changes
to get_any_partial()]
commit a6bc32b899223a877f595ef9ddc1e89ead5072b8 upstream.
Stable note: Not tracked in Buzilla. This was part of a series that
reduced interactivity stalls experienced when THP was enabled.
These stalls were particularly noticable when copying data
to a USB stick but the experiences for users varied a lot.
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT
mode that avoids writing back pages to backing storage. Async compaction
maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT.
For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is
used.
This avoids sync compaction stalling for an excessive length of time,
particularly when copying files to a USB stick where there might be a
large number of dirty pages backed by a filesystem that does not support
->writepages.
[aarcange@redhat.com: This patch is heavily based on Andrea's work]
[akpm@linux-foundation.org: fix fs/nfs/write.c build]
[akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build]
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Andy Isaacson <adi@hexapodia.org>
Cc: Nai Xia <nai.xia@gmail.com>
Cc: Johannes Weiner <jweiner@redhat.com>
