commit 685fd0b4ea3f0f1d5385610b0d5b57775a8d5842 upstream.
A small number of users of IRQF_TIMER are using it for the implied no
suspend behaviour on interrupts which are not timer interrupts.
Therefore add a new IRQF_NO_SUSPEND flag, rename IRQF_TIMER to
__IRQF_TIMER and redefine IRQF_TIMER in terms of these new flags.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: xen-devel@lists.xensource.com
Cc: linux-input@vger.kernel.org
Cc: linuxppc-dev@ozlabs.org
Cc: devicetree-discuss@lists.ozlabs.org
LKML-Reference: <1280398595-29708-1-git-send-email-ian.campbell@citrix.com>
commit 38117d1495e587fbb10d6e55733139a27893cef5 upstream.
commit 06c4648d46d1b757d6b9591a86810be79818b60c upstream.
Currently such notifications are only generated when the device comes up or the
address changes. However one use case for these notifications is to enable
faster network recovery after a virtual machine migration (by causing switches
to relearn their MAC tables). A migration appears to the network stack as a
temporary loss of carrier and therefore does not trigger either of the current
conditions. Rather than adding carrier up as a trigger (which can cause issues
when interfaces a flapping) simply add an interface which the driver can use
to explicitly trigger the notification.
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: netdev@vger.kernel.org
commit 93362a875fc69881ae69299efaf19a55a1f57db0 upstream.
The Logitech Harmony 700 series needs an extra delay during
initialization. This patch adds a USB quirk which enables such a delay
and adds the device to the quirks list.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
BIO_RW_* bits
commit aca27ba9618276dd2f777bcd5a1419589ccf1ca8 upstream.
Commit a82afdf (block: use the same failfast bits for bio and request)
moved BIO_RW_* bits around such that they match up with REQ_* bits.
Unfortunately, fs.h hard coded RW_MASK, RWA_MASK, READ, WRITE, READA
and SWRITE as 0, 1, 2 and 3, and expected them to match with BIO_RW_*
bits. READ/WRITE didn't change but BIO_RW_AHEAD was moved to bit 4
instead of bit 1, breaking RWA_MASK, READA and SWRITE.
This patch updates RWA_MASK, READA and SWRITE such that they match the
BIO_RW_* bits again. A follow up patch will update the definitions to
directly use BIO_RW_* bits so that this kind of breakage won't happen
again.
Neil also spotted missing RWA_MASK conversion.
Stable: The offending commit a82afdf was released with v2.6.32, so
this patch should be applied to all kernels since then but it must
_NOT_ be applied to kernels earlier than that.
Reported-and-bisected-by: Vladislav Bolkhovitin <vst@vlnb.net>
Root-caused-by: Neil Brown <neilb@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit ea2db495f92ad2cf3301623e60cb95b4062bc484 upstream.
Our offset handling becomes even a little more hackish now. For some reason I
do not understand all offsets as inrelative. It assumes base offset is 0x1000
but it will work for now as we make offsets relative anyway by removing base
0x1000. Should be cleaner however.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit d53cdbb94a52a920d5420ed64d986c3523a56743 upstream.
Attempting to read registers that don't exist on the SSB bus can cause
hangs on some boxes. At least some b43 devices are 'in the wild' that
don't have SPROMs at all. When the SSB bus support loads, it attempts
to read these (non-existant) SPROMs and causes hard hangs on the box --
no console output, etc.
This patch adds some intelligence to determine whether or not the SPROM
is present before attempting to read it. This avoids those hard hangs
on those devices with no SPROM attached to their SSB bus. The
SSB-attached devices (e.g. b43, et al.) won't work, but at least the box
will survive to test further patches. :-)
Cc: Michael Buesch <mb@bu3sch.de>
Turns out this isn't the best way to resolve this issue. The
individual patches will be applied instead.
commit 1297c05a8dfb568c689f057d51a65eebe5ddc86f upstream.
New evergreen and r7xx ids.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
commit 77a63f3d1e0a3e7ede8d10f569e8481b13ff47c5 upstream.
nfs_commit_inode() needs to be defined irrespectively of whether or not
we are supporting NFSv3 and NFSv4.
Allow the compiler to optimise away code in the NFSv2-only case by
converting it into an inlined stub function.
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit b608b283a962caaa280756bc8563016a71712acf upstream.
See https://bugzilla.kernel.org/show_bug.cgi?id=16056
If other processes are blocked waiting for kswapd to free up some memory so
that they can make progress, then we cannot allow kswapd to block on those
processes.
commit c9a8bbb7704cbf515c0fc68970abbe4e91d68521 upstream.
ACPICA uses acpi_hw_write_gpe_enable_reg() to re-enable a GPE after
an event signaled by it has been handled. However, this function
writes the entire GPE enable mask to the GPE's enable register which
may not be correct. Namely, if one of the other GPEs in the same
register was previously enabled by acpi_enable_gpe() and subsequently
disabled using acpi_set_gpe(), acpi_hw_write_gpe_enable_reg() will
re-enable it along with the target GPE.
To fix this issue rework acpi_hw_write_gpe_enable_reg() so that it
calls acpi_hw_low_set_gpe() with a special action value,
ACPI_GPE_COND_ENABLE, that will make it only enable the GPE if the
corresponding bit in its register's enable_for_run mask is set.
Signed-off-by: Len Brown <len.brown@intel.com>
commit fd247447c1d94a79d5cfc647430784306b3a8323 upstream.
ACPICA uses acpi_ev_enable_gpe() for enabling GPEs at the low level,
which is incorrect, because this function only enables the GPE if the
corresponding bit in its enable register's enable_for_run mask is set.
This causes acpi_set_gpe() to work incorrectly if used for enabling
GPEs that were not previously enabled with acpi_enable_gpe(). As a
result, among other things, wakeup-only GPEs are never enabled by
acpi_enable_wakeup_device(), so the devices that use them are unable
to wake up the system.
To fix this issue remove acpi_ev_enable_gpe() and its counterpart
acpi_ev_disable_gpe() and replace acpi_hw_low_disable_gpe() with
acpi_hw_low_set_gpe() that will be used instead to manipulate GPE
enable bits at the low level. Make the users of acpi_ev_enable_gpe()
and acpi_ev_disable_gpe() call acpi_hw_low_set_gpe() instead and
make sure that GPE enable masks are only updated by acpi_enable_gpe()
and acpi_disable_gpe() when GPE reference counters change from 0
to 1 and from 1 to 0, respectively.
commit dd336c554d8926c3348a2d5f2a5ef5597f6d1a06 upstream.
fix memory leak introduced by the patch 6e03a201bbe:
firmware: speed up request_firmware()
1. vfree won't release pages there were allocated explicitly and mapped
using vmap. The memory has to be vunmap-ed and the pages needs
to be freed explicitly
2. page array is moved into the 'struct
firmware' so that we can free it from release_firmware()
and not only in fw_dev_release()
The fix doesn't break the firmware load speed.
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Ming Lei <tom.leiming@gmail.com>
Singed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit 8a64c0f6b7ec7f758c4ef445e49f479e27fa2236 upstream.
When operating in 1-bit mode, SDAT1 is used as dedicated interrupt line.
However, the 8686 will only drive this line when the ECSI bit is set in
the CCCR_IF register.
Thanks to Alagu Sankar for pointing me in the right direction.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Alagu Sankar <alagusankar@embwise.com>
Cc: Volker Ernst <volker.ernst@txtr.com>
Cc: Dan Williams <dcbw@redhat.com>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Holger Schurig <hs4233@mail.mn-solutions.de>
Cc: Bing Zhao <bzhao@marvell.com>
Cc: libertas-dev@lists.infradead.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-mmc@vger.kernel.org
Acked-by: Dan Williams <dcbw@redhat.com>
commit b6dacf63e9fb2e7a1369843d6cef332f76fca6a3 upstream.
The ACPI spec tells us that the firmware will reenable SCI_EN on resume.
Reality disagrees in some cases. The ACPI spec tells us that the only way
to set SCI_EN is via an SMM call.
https://bugzilla.kernel.org/show_bug.cgi?id=13745 shows us that doing so
may break machines. Tracing the ACPI calls made by Windows shows that it
unconditionally sets SCI_EN on resume with a direct register write, and
therefore the overwhelming probability is that everything is fine with
this behaviour.
Tested-by: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Kamal Mostafa <kamal@canonical.com>
commit 718be4aaf3613cf7c2d097f925abc3d3553c0605 upstream.
It turns out that there is a bit in the _CST for Intel FFH C3
that tells the OS if we should be checking BM_STS or not.
Linux has been unconditionally checking BM_STS.
If the chip-set is configured to enable BM_STS,
it can retard or completely prevent entry into
deep C-states -- as illustrated by turbostat:
http://userweb.kernel.org/~lenb/acpi/utils/pmtools/turbostat/
ref: Intel Processor Vendor-Specific ACPI Interface Specification
table 4 "_CST FFH GAS Field Encoding"
Bit 1: Set to 1 if OSPM should use Bus Master avoidance for this C-state
https://bugzilla.kernel.org/show_bug.cgi?id=15886
commit bf988435bd5b53529f4408a8efb1f433f6ddfda9 upstream.
struct ethtool_rxnfc was originally defined in 2.6.27 for the
ETHTOOL_{G,S}RXFH command with only the cmd, flow_type and data
fields. It was then extended in 2.6.30 to support various additional
commands. These commands should have been defined to use a new
structure, but it is too late to change that now.
Since user-space may still be using the old structure definition
for the ETHTOOL_{G,S}RXFH commands, and since they do not need the
additional fields, only copy the originally defined fields to and
from user-space.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
commit c6353b4520788e34098bbf61c73fb9618ca7fdd6 upstream.
For yet unknown reason, MCP89 on MBP 7,1 doesn't work w/ ahci under
linux but the controller doesn't require explicit mode setting and
works fine with ata_generic. Make ahci ignore the controller on MBP
7,1 and let ata_generic take it for now.
Reported in bko#15923.
https://bugzilla.kernel.org/show_bug.cgi?id=15923
NVIDIA is investigating why ahci mode doesn't work.
Cc: Peer Chen <pchen@nvidia.com>
Reported-by: Anders Østhus <grapz666@gmail.com>
Reported-by: Andreas Graf <andreas_graf@csgraf.de>
Reported-by: Benoit Gschwind <gschwind@gnu-log.net>
Reported-by: Damien Cassou <damien.cassou@gmail.com>
Reported-by: tixetsal@juno.com
commit 9c695203a7ddbe49dba5f22f4c941d24f47475df upstream.
A __naked function is defined in C but with a body completely implemented
by asm(), including any prologue and epilogue. These asm() bodies expect
standard calling conventions for parameter passing. Older GCCs implement
that correctly, but 4.[56] currently do not, see GCC PR44290. In the
Linux kernel this breaks ARM, causing most arch/arm/mm/copypage-*.c
modules to get miscompiled, resulting in kernel crashes during bootup.
Part of the kernel fix is to augment the __naked function attribute to
also imply noinline and noclone. This patch implements that, and has been
verified to fix boot failures with gcc-4.5 compiled 2.6.34 and 2.6.35-rc1
kernels. The patch is a no-op with older GCCs.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
Signed-off-by: Khem Raj <raj.khem@gmail.com>
commit b26c949755c06ec79e55a75817210083bd78fc9a upstream.
When I added the flags I must have been using a 25 line terminal and missed the following flags.
The collided with flag has one user in staging despite being in-tree for 5 years.
I'm happy to push this via my drm tree unless someone really wants to do it.
commit f8324e20f8289dffc646d64366332e05eaacab25 upstream.
The kernel's math-emu code contains a macro _FP_FROM_INT() which is
used to convert an integer to a raw normalized floating-point value.
It does this basically in three steps:
1. Compute the exponent from the number of leading zero bits.
2. Downshift large fractions to put the MSB in the right position
for normalized fractions.
3. Upshift small fractions to put the MSB in the right position.
There is an boundary error in step 2, causing a fraction with its
MSB exactly one bit above the normalized MSB position to not be
downshifted. This results in a non-normalized raw float, which when
packed becomes a massively inaccurate representation for that input.
The impact of this depends on a number of arch-specific factors,
but it is known to have broken emulation of FXTOD instructions
on UltraSPARC III, which was originally reported as GCC bug 44631
<http://gcc.gnu.org/bugzilla/show_bug.cgi?id=44631>.
Any arch which uses math-emu to emulate conversions from integers to
same-size floats may be affected.
The fix is simple: the exponent comparison used to determine if the
fraction should be downshifted must be "<=" not "<".
I'm sending a kernel module to test this as a reply to this message.
There are also SPARC user-space test cases in the GCC bug entry.
commit b0f77d0eae0c58a5a9691a067ada112ceeae2d00 upstream.
Fix problem in reading the tx_queue recorded in a socket. In
dev_pick_tx, the TX queue is read by doing a check with
sk_tx_queue_recorded on the socket, followed by a sk_tx_queue_get.
The problem is that there is not mutual exclusion across these
calls in the socket so it it is possible that the queue in the
sock can be invalidated after sk_tx_queue_recorded is called so
that sk_tx_queue get returns -1, which sets 65535 in queue_index
and thus dev_pick_tx returns 65536 which is a bogus queue and
can cause crash in dev_queue_xmit.
We fix this by only calling sk_tx_queue_get which does the proper
checks. The interface is that sk_tx_queue_get returns the TX queue
if the sock argument is non-NULL and TX queue is recorded, else it
returns -1. sk_tx_queue_recorded is no longer used so it can be
completely removed.
Signed-off-by: Tom Herbert <therbert@google.com>
For some Netbook computers with Broadcom BCM4312 wireless interfaces,
the SPROM has been moved to a new location. When the ssb driver tries to
read the old location, the systems hangs when trying to read a
non-existent location. Such freezes are particularly bad as they do not
log the failure.
This patch is modified from commit
da1fdb02d9200ff28b6f3a380d21930335fe5429 with some pieces from other
mainline changes so that it can be applied to stable 2.6.34.Y.
Per document, for feature control MSR:
Bit 1 enables VMXON in SMX operation. If the bit is clear, execution
of VMXON in SMX operation causes a general-protection exception.
Bit 2 enables VMXON outside SMX operation. If the bit is clear, execution
of VMXON outside SMX operation causes a general-protection exception.
This patch is to enable this kind of check with SMX for VMXON in KVM.
Signed-off-by: Shane Wang <shane.wang@intel.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
(Cherry-picked from commit cafd66595d92591e4bd25c3904e004fc6f897e2d)
commit ac9721f3f54b27a16c7e1afb2481e7ee95a70318 upstream.
In order to move toward separate buffer objects, rework the whole
perf_mmap_data construct to be a more self-sufficient entity, one
with its own lifetime rules.
This greatly sanitizes the whole output redirection code, which
was riddled with bugs and races.
LKML-Reference: <new-submission>
commit b9b76dfaac6fa2c289ee8a005be637afd2da7e2f upstream.
BUG: unable to handle kernel NULL pointer dereference at
0000000000000006
IP: [<ffffffff8107bd37>] ftrace_raw_event_signal_generate+0x87/0x140
TP_STORE_SIGINFO() forgets about SEND_SIG_FORCED, fix.
We should probably export is_si_special() and change TP_STORE_SIGINFO()
to use it in the longer term.
Acked-by: Roland McGrath <roland@redhat.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <20100603213409.GA8307@redhat.com>
commit 7d683a09990ff095a91b6e724ecee0ff8733274a upstream.
It's used to superblock ->s_magic, which is unsigned long.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Reviewed-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 79907d89c397b8bc2e05b347ec94e928ea919d33 upstream.
10, 233 is allocated officially to /dev/kmview which is shipping in
Ubuntu and Debian distributions. vhost_net seem to have borrowed it
without making a proper request and this causes regressions in the other
distributions.
vhost_net can use a dynamic minor so use that instead. Also update the
file with a comment to try and avoid future misunderstandings.
Signed-off-by: Alan Cox <device@lanana.org>
[ We should have caught this before 2.6.34 got released. - Linus ]
commit 4daedcfe8c6851aa01cc1997220f2577f4039c13 upstream.
JMB362 is a new variant of jmicron controller which is similar to
JMB360 but has two SATA ports instead of one. As there is no PATA
port, single function AHCI mode can be used as in JMB360. Add pci
quirk for JMB362.
Reported-by: Aries Lee <arieslee@jmicron.com>
commit b83733639a494d5f42fa00a2506563fbd2d3015d upstream.
It was reported in http://lkml.org/lkml/2010/3/8/309 that 32 bit readv and
writev AIO operations were not functioning properly. It turns out that
the code to convert the 32bit io vectors to 64 bits was never written.
The results of that can be pretty bad, but in my testing, it mostly ended
up in generating EFAULT as we walked off the list of I/O vectors provided.
This patch set fixes the problem in my environment. are greatly
appreciated.
This patch:
Factor out code that will be used by both compat_do_readv_writev and the
compat aio submission code paths.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Reported-by: Michael Tokarev <mjt@tls.msk.ru>
Cc: Zach Brown <zach.brown@oracle.com>
commit 73367bd8eef4f4eb311005886aaa916013073265 upstream.
This patch is meant to improve the performance of SLUB by moving the local
kmem_cache_node lock into it's own cacheline separate from kmem_cache.
This is accomplished by simply removing the local_node when NUMA is enabled.
On my system with 2 nodes I saw around a 5% performance increase w/
hackbench times dropping from 6.2 seconds to 5.9 seconds on average. I
suspect the performance gain would increase as the number of nodes
increases, but I do not have the data to currently back that up.
Bugzilla-Reference: http://bugzilla.kernel.org/show_bug.cgi?id=15713
Reported-by: Alex Shi <alex.shi@intel.com>
Tested-by: Alex Shi <alex.shi@intel.com>
Acked-by: Yanmin Zhang <yanmin_zhang@linux.intel.com>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
commit 0f1f694260e0d35b5ce7d471f6e679c3dd4d7d94 upstream.
Commit 756dee75872a2a764b478e18076360b8a4ec9045 ("SLUB: Get rid of dynamic DMA
kmalloc cache allocation") makes S390 run out of kmalloc caches. Increase the
number of kmalloc caches to a safe size.
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Tested-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
commit 9d85cba718efeef9ca00ce3f7f34f5880737aa9b upstream.
The aio compat code was not converting the struct iovecs from 32bit to
64bit pointers, causing either EINVAL to be returned from io_getevents, or
EFAULT as the result of the I/O. This patch passes a compat flag to
io_submit to signal that pointer conversion is necessary for a given iocb
array.
A variant of this was tested by Michael Tokarev. I have also updated the
libaio test harness to exercise this code path with good success.
Further, I grabbed a copy of ltp and ran the
testcases/kernel/syscall/readv and writev tests there (compiled with -m32
on my 64bit system). All seems happy, but extra eyes on this would be
welcome.
[akpm@linux-foundation.org: fix CONFIG_COMPAT=n build]
commit e9d6c157385e4efa61cb8293e425c9d8beba70d3 upstream.
Shaohua Li reported parallel file copy on tmpfs can lead to OOM killer.
This is regression of caused by commit 9ff473b9a7 ("vmscan: evict
streaming IO first"). Wow, It is 2 years old patch!
Currently, tmpfs file cache is inserted active list at first. This means
that the insertion doesn't only increase numbers of pages in anon LRU, but
it also reduces anon scanning ratio. Therefore, vmscan will get totally
confused. It scans almost only file LRU even though the system has plenty
unused tmpfs pages.
Historically, lru_cache_add_active_anon() was used for two reasons.
1) Intend to priotize shmem page rather than regular file cache.
2) Intend to avoid reclaim priority inversion of used once pages.
But we've lost both motivation because (1) Now we have separate anon and
file LRU list. then, to insert active list doesn't help such priotize.
(2) In past, one pte access bit will cause page activation. then to
insert inactive list with pte access bit mean higher priority than to
insert active list. Its priority inversion may lead to uninteded lru
chun. but it was already solved by commit 645747462 (vmscan: detect
mapped file pages used only once). (Thanks Hannes, you are great!)
Thus, now we can use lru_cache_add_anon() instead.
Reported-by: Shaohua Li <shaohua.li@intel.com>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
commit ff9c895f07d36193c75533bda8193bde8ca99d02 upstream.
This patch (as1368) fixes a rather obscure bug in usbmon: When tracing
URBs sent by the scatter-gather library, it accesses the data buffers
while they are still mapped for DMA.
The solution is to move the mapping and unmapping out of the s-g
library and into the usual place in hcd.c. This requires the addition
of new URB flag bits to describe the kind of mapping needed, since we
have to call dma_map_sg() if the HCD supports native scatter-gather
operation and dma_map_page() if it doesn't. The nice thing about
having the new flags is that they simplify the testing for unmapping.
The patch removes the only caller of usb_buffer_[un]map_sg(), so those
functions are #if'ed out. A later patch will remove them entirely.
As a result of this change, urb->sg will be set in situations where
it wasn't set previously. Hence the xhci and whci drivers are
adjusted to test urb->num_sgs instead, which retains its original
meaning and is nonzero only when the HCD has to handle a scatterlist.
Finally, even when a submission error occurs we don't want to hand
URBs to usbmon before they are unmapped. The submission path is
rearranged so that map_urb_for_dma() is called only for non-root-hub
URBs and unmap_urb_for_dma() is called immediately after a submission
error. This simplifies the error handling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
rtnetlink: make SR-IOV VF interface symmetric
sctp: delete active ICMP proto unreachable timer when free transport
tcp: fix MD5 (RFC2385) support
Now we have a set of nested attributes:
IFLA_VFINFO_LIST (NESTED)
IFLA_VF_INFO (NESTED)
IFLA_VF_MAC
IFLA_VF_VLAN
IFLA_VF_TX_RATE
This allows a single set to operate on multiple attributes if desired.
Among other things, it means a dump can be replayed to set state.
The current interface has yet to be released, so this seems like
something to consider for 2.6.34.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
TCP MD5 support uses percpu data for temporary storage. It currently
disables preemption so that same storage cannot be reclaimed by another
thread on same cpu.
We also have to make sure a softirq handler wont try to use also same
context. Various bug reports demonstrated corruptions.
Fix is to disable preemption and BH.
Reported-by: Bhaskar Dutta <bhaskie@gmail.com>
1) i_flags simply doesn't work for mount/unlink race prevention;
we may have many links to file and rm on one of those obviously
shouldn't prevent bind on top of another later on. To fix it
right way we need to mark _dentry_ as unsuitable for mounting
upon; new flag (DCACHE_CANT_MOUNT) is protected by d_flags and
i_mutex on the inode in question. Set it (with dont_mount(dentry))
in unlink/rmdir/etc., check (with cant_mount(dentry)) in places
in namespace.c that used to check for S_DEAD. Setting S_DEAD
is still needed in places where we used to set it (for directories
getting killed), since we rely on it for readdir/rmdir race
prevention.
2) rename()/mount() protection has another bogosity - we unhash
the target before we'd checked that it's not a mountpoint. Fixed.
3) ancient bogosity in pivot_root() - we locked i_mutex on the
right directory, but checked S_DEAD on the different (and wrong)
one. Noticed and fixed.
Originally, commit d899bf7b ("procfs: provide stack information for
threads") attempted to introduce a new feature for showing where the
threadstack was located and how many pages are being utilized by the
stack.
Commit c44972f1 ("procfs: disable per-task stack usage on NOMMU") was
applied to fix the NO_MMU case.
Commit 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on
64-bit") was applied to fix a bug in ia32 executables being loaded.
Commit 9ebd4eba7 ("procfs: fix /proc/<pid>/stat stack pointer for kernel
threads") was applied to fix a bug which had kernel threads printing a
userland stack address.
Commit 1306d603f ('proc: partially revert "procfs: provide stack
information for threads"') was then applied to revert the stack pages
being used to solve a significant performance regression.
This patch nearly undoes the effect of all these patches.
The reason for reverting these is it provides an unusable value in
field 28. For x86_64, a fork will result in the task->stack_start
value being updated to the current user top of stack and not the stack
start address. This unpredictability of the stack_start value makes
it worthless. That includes the intended use of showing how much stack
space a thread has.
Other architectures will get different values. As an example, ia64
gets 0. The do_fork() and copy_process() functions appear to treat the
stack_start and stack_size parameters as architecture specific.
I only partially reverted c44972f1 ("procfs: disable per-task stack usage
on NOMMU") . If I had completely reverted it, I would have had to change
mm/Makefile only build pagewalk.o when CONFIG_PROC_PAGE_MONITOR is
configured. Since I could not test the builds without significant effort,
I decided to not change mm/Makefile.
I only partially reverted 89240ba0 ("x86, fs: Fix x86 procfs stack
information for threads on 64-bit") . I left the KSTK_ESP() change in
place as that seemed worthwhile.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Stefani Seibold <stefani@seibold.net>
Cc: <stable@kernel.org>
dma_sync_single_range_for_cpu() and dma_sync_single_range_for_device() use
a wrong address with a partial synchronization.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
net: Fix FDDI and TR config checks in ipv4 arp and LLC.
IPv4: unresolved multicast route cleanup
mac80211: remove association work when processing deauth request
ar9170: wait for asynchronous firmware loading
ipv4: udp: fix short packet and bad checksum logging
phy: Fix initialization in micrel driver.
sctp: Fix a race between ICMP protocol unreachable and connect()
veth: Dont kfree_skb() after dev_forward_skb()
IPv6: fix IPV6_RECVERR handling of locally-generated errors
net/gianfar: drop recycled skbs on MTU change
iwlwifi: work around passive scan issue
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/ttm: Remove the ttm_bo_block_reservation() function.
drm/ttm: Remove some leftover debug messages.
drm/radeon: async event synchronization for drmWaitVblank
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_2.6.34' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
V4L/DVB: pxa_camera: move fifo reset direct before dma start
V4L/DVB: video: testing unsigned for less than 0
V4L/DVB: mx1-camera: compile fix
V4L/DVB: budget: Oops: "BUG: unable to handle kernel NULL pointer dereference"
V4L/DVB: ngene: Workaround for stuck DiSEqC pin
V4L/DVB: saa7146: fix regression of the av7110/budget-av driver
V4L/DVB: v4l: fix config dependencies: mxb and saa7191 are V4L2 drivers, not V4L1
V4L/DVB: feature-removal: announce videotext.h removal
V4L/DVB: V4L - vpfe capture - fix for kernel crash
V4L/DVB: gspca: make usb id 0461:0815 get handled by the right driver
V4L/DVB: gspca - stv06xx: Remove the 046d:08da from the stv06xx driver
V4L/DVB: gspca - sn9c20x: Correct onstack wait_queue_head declaration
V4L/DVB: saa7146: fix up bytesperline if it is an impossible value
V4L/DVB: V4L: vpfe_capture - free ccdc_lock when memory allocation fails
V4L/DVB: V4L - Makfile:Removed duplicate entry of davinci
V4L/DVB: omap24xxcam: potential buffer overflow
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: create rcu_my_thread_group_empty() wrapper
memcg: css_id() must be called under rcu_read_lock()
cgroup: Check task_lock in task_subsys_state()
sched: Fix an RCU warning in print_task()
cgroup: Fix an RCU warning in alloc_css_id()
cgroup: Fix an RCU warning in cgroup_path()
KEYS: Fix an RCU warning in the reading of user keys
It's unused and buggy in its current form, since it can place a bo
in the reserved state without removing it from lru lists.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
An earlier regression fix for the mxb driver (V4L/DVB: saa7146_vv: fix
regression where v4l2_device was registered too late) caused a new
regression in the av7110 driver.
Reverted the old fix and fixed the problem in the mxb driver instead.
Tested on mxb and budget-av cards.
The real problem is that the saa7146 framework has separate probe()
and attach() driver callbacks which should be rolled into one. This
is now done for the mxb driver, but others should do the same. Lack
of hardware makes this hard to do, though. I hope to get hold of some
hexium cards and then I can try to improve the framework to prevent
this from happening again.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Some RCU-lockdep splat repairs need to know whether they are running
in a single-threaded process. Unfortunately, the thread_group_empty()
primitive is defined in sched.h, and can induce #include hell. This
commit therefore introduces a rcu_my_thread_group_empty() wrapper that
is defined in rcupdate.c, thus avoiding the need to include sched.h
everywhere.
Signed-off-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
ICMP protocol unreachable handling completely disregarded
the fact that the user may have locked the socket. It proceeded
to destroy the association, even though the user may have
held the lock and had a ref on the association. This resulted
in the following:
Attempt to release alive inet socket f6afcc00
[ BUG: held lock freed! ]
somenu/2672 is freeing memory f6afcc00-f6afcfff, with a lock still held
there!
(sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c
1 lock held by somenu/2672:
#0: (sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c
stack backtrace:
Pid: 2672, comm: somenu Not tainted 2.6.32-telco #55
Call Trace:
[<c1232266>] ? printk+0xf/0x11
[<c1038553>] debug_check_no_locks_freed+0xce/0xff
[<c10620b4>] kmem_cache_free+0x21/0x66
[<c1185f25>] __sk_free+0x9d/0xab
[<c1185f9c>] sk_free+0x1c/0x1e
[<c1216e38>] sctp_association_put+0x32/0x89
[<c1220865>] __sctp_connect+0x36d/0x3f4
[<c122098a>] ? sctp_connect+0x13/0x4c
[<c102d073>] ? autoremove_wake_function+0x0/0x33
[<c12209a8>] sctp_connect+0x31/0x4c
[<c11d1e80>] inet_dgram_connect+0x4b/0x55
[<c11834fa>] sys_connect+0x54/0x71
[<c103a3a2>] ? lock_release_non_nested+0x88/0x239
[<c1054026>] ? might_fault+0x42/0x7c
[<c11847ab>] sys_socketcall+0x6d/0x178
[<c10da994>] ? trace_hardirqs_on_thunk+0xc/0x10
[<c1002959>] syscall_call+0x7/0xb
This was because the sctp_wait_for_connect() would aqcure the socket
lock and then proceed to release the last reference count on the
association, thus cause the fully destruction path to finish freeing
the socket.
The simplest solution is to start a very short timer in case the socket
is owned by user. When the timer expires, we can do some verification
and be able to do the release properly.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
