The direction field is set on 7 bits, thus we need to AND it with 0111 111 mask
in order to retrieve it, that is 0x7F, not 0xCF as it is now.
Fixes: ade7ef7ba (staging:iio: Differential channel handling)
Signed-off-by: Cristina Ciocan <cristina.ciocan@intel.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Pull audit updates from Eric Paris:
"So this change across a whole bunch of arches really solves one basic
problem. We want to audit when seccomp is killing a process. seccomp
hooks in before the audit syscall entry code. audit_syscall_entry
took as an argument the arch of the given syscall. Since the arch is
part of what makes a syscall number meaningful it's an important part
of the record, but it isn't available when seccomp shoots the
syscall...
For most arch's we have a better way to get the arch (syscall_get_arch)
So the solution was two fold: Implement syscall_get_arch() everywhere
there is audit which didn't have it. Use syscall_get_arch() in the
seccomp audit code. Having syscall_get_arch() everywhere meant it was
a useless flag on the stack and we could get rid of it for the typical
syscall entry.
The other changes inside the audit system aren't grand, fixed some
records that had invalid spaces. Better locking around the task comm
field. Removing some dead functions and structs. Make some things
static. Really minor stuff"
* git://git.infradead.org/users/eparis/audit: (31 commits)
audit: rename audit_log_remove_rule to disambiguate for trees
audit: cull redundancy in audit_rule_change
audit: WARN if audit_rule_change called illegally
audit: put rule existence check in canonical order
next: openrisc: Fix build
audit: get comm using lock to avoid race in string printing
audit: remove open_arg() function that is never used
audit: correct AUDIT_GET_FEATURE return message type
audit: set nlmsg_len for multicast messages.
audit: use union for audit_field values since they are mutually exclusive
audit: invalid op= values for rules
audit: use atomic_t to simplify audit_serial()
kernel/audit.c: use ARRAY_SIZE instead of sizeof/sizeof[0]
audit: reduce scope of audit_log_fcaps
audit: reduce scope of audit_net_id
audit: arm64: Remove the audit arch argument to audit_syscall_entry
arm64: audit: Add audit hook in syscall_trace_enter/exit()
audit: x86: drop arch from __audit_syscall_entry() interface
sparc: implement is_32bit_task
sparc: properly conditionalize use of TIF_32BIT
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Highlights from the I2C subsystem for 3.18:
- new drivers for Axxia AM55xx, and Hisilicon hix5hd2 SoC.
- designware driver gained AMD support, exynos gained exynos7 support
The rest is usual driver stuff. Hopefully no lowlights this time"
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: i801: Add Device IDs for Intel Sunrise Point PCH
i2c: hix5hd2: add i2c controller driver
i2c-imx: Disable the clock on probe failure
i2c: designware: Add support for AMD I2C controller
i2c: designware: Rework probe() to get clock a bit later
i2c: designware: Default to fast mode in case of ACPI
i2c: axxia: Add I2C driver for AXM55xx
i2c: exynos: add support for HSI2C module on Exynos7
i2c: mxs: detect No Slave Ack on SELECT in PIO mode
i2c: cros_ec: Remove EC_I2C_FLAG_10BIT
i2c: cros-ec-tunnel: Add of match table
i2c: rcar: remove sign-compare flaw
i2c: ismt: Use minimum descriptor size
i2c: imx: Add arbitration lost check
i2c: rk3x: Remove unlikely() annotations
i2c: rcar: check for no IRQ in rcar_i2c_irq()
i2c: rcar: make rcar_i2c_prepare_msg() *void*
i2c: rcar: simplify check for last message
i2c: designware: add support of platform data to set I2C mode
i2c: designware: add support of I2C standard mode
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/RDMA updates from Roland Dreier:
- large set of iSER initiator improvements
- hardware driver fixes for cxgb4, mlx5 and ocrdma
- small fixes to core midlayer
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (47 commits)
RDMA/cxgb4: Fix ntuple calculation for ipv6 and remove duplicate line
RDMA/cxgb4: Add missing neigh_release in find_route
RDMA/cxgb4: Take IPv6 into account for best_mtu and set_emss
RDMA/cxgb4: Make c4iw_wr_log_size_order static
IB/core: Fix XRC race condition in ib_uverbs_open_qp
IB/core: Clear AH attr variable to prevent garbage data
RDMA/ocrdma: Save the bit environment, spare unncessary parenthesis
RDMA/ocrdma: The kernel has a perfectly good BIT() macro - use it
RDMA/ocrdma: Don't memset() buffers we just allocated with kzalloc()
RDMA/ocrdma: Remove a unused-label warning
RDMA/ocrdma: Convert kernel VA to PA for mmap in user
RDMA/ocrdma: Get vlan tag from ib_qp_attrs
RDMA/ocrdma: Add default GID at index 0
IB/mlx5, iser, isert: Add Signature API additions
Target/iser: Centralize ib_sig_domain setting
IB/iser: Centralize ib_sig_domain settings
IB/mlx5: Use extended internal signature layout
IB/iser: Set IP_CSUM as default guard type
IB/iser: Remove redundant assignment
IB/mlx5: Use enumerations for PI copy mask
Pull networking fixes from David Miller:
"A quick batch of bug fixes:
1) Fix build with IPV6 disabled, from Eric Dumazet.
2) Several more cases of caching SKB data pointers across calls to
pskb_may_pull(), thus referencing potentially free'd memory. From
Li RongQing.
3) DSA phy code tests operation presence improperly, instead of going:
if (x->ops->foo)
r = x->ops->foo(args);
it was going:
if (x->ops->foo(args))
Fix from Andew Lunn"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
Net: DSA: Fix checking for get_phy_flags function
ipv6: fix a potential use after free in sit.c
ipv6: fix a potential use after free in ip6_offload.c
ipv4: fix a potential use after free in gre_offload.c
tcp: fix build error if IPv6 is not enabled
Pull slave-dmaengine updates from Vinod Koul:
"For dmaengine contributions we have:
- designware cleanup by Andy
- my series moving device_control users to dmanegine_xxx APIs for
later removal of device_control API
- minor fixes spread over drivers mainly mv_xor, pl330, mmp, imx-sdma
etc"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (60 commits)
serial: atmel: add missing dmaengine header
dmaengine: remove FSLDMA_EXTERNAL_START
dmaengine: freescale: remove FSLDMA_EXTERNAL_START control method
carma-fpga: move to fsl_dma_external_start()
carma-fpga: use dmaengine_xxx() API
dmaengine: freescale: add and export fsl_dma_external_start()
dmaengine: add dmaengine_prep_dma_sg() helper
video: mx3fb: use dmaengine_terminate_all() API
serial: sh-sci: use dmaengine_terminate_all() API
net: ks8842: use dmaengine_terminate_all() API
mtd: sh_flctl: use dmaengine_terminate_all() API
mtd: fsmc_nand: use dmaengine_terminate_all() API
V4L2: mx3_camer: use dmaengine_pause() API
dmaengine: coh901318: use dmaengine_terminate_all() API
pata_arasan_cf: use dmaengine_terminate_all() API
dmaengine: edma: check for echan->edesc => NULL in edma_dma_pause()
dmaengine: dw: export probe()/remove() and Co to users
dmaengine: dw: enable and disable controller when needed
dmaengine: dw: always export dw_dma_{en,dis}able
dmaengine: dw: introduce dw_dma_on() helper
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev updates from Tomi Valkeinen:
- new 6x10 font
- various small fixes and cleanups
* tag 'fbdev-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (30 commits)
fonts: Add 6x10 font
videomode: provide dummy inline functions for !CONFIG_OF
video/atmel_lcdfb: Introduce regulator support
fbdev: sh_mobile_hdmi: Re-init regs before irq re-enable on resume
framebuffer: fix screen corruption when copying
framebuffer: fix border color
arm, fbdev, omap2, LLVMLinux: Remove nested function from omapfb
arm, fbdev, omap2, LLVMLinux: Remove nested function from omap2 dss
video: fbdev: valkyriefb.c: use container_of to resolve fb_info_valkyrie from fb_info
video: fbdev: pxafb.c: use container_of to resolve pxafb_info/layer from fb_info
video: fbdev: cyber2000fb.c: use container_of to resolve cfb_info from fb_info
video: fbdev: controlfb.c: use container_of to resolve fb_info_control from fb_info
video: fbdev: sa1100fb.c: use container_of to resolve sa1100fb_info from fb_info
video: fbdev: stifb.c: use container_of to resolve stifb_info from fb_info
video: fbdev: sis: sis_main.c: Cleaning up missing null-terminate in conjunction with strncpy
video: valkyriefb: Fix unused variable warning in set_valkyrie_clock()
video: fbdev: use %*ph specifier to dump small buffers
video: mx3fb: always enable BACKLIGHT_LCD_SUPPORT
video: fbdev: au1200fb: delete double assignment
video: fbdev: sis: delete double assignment
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm
Pull second batch of changes for KVM/{arm,arm64} from Marc Zyngier:
"The most obvious thing is the sizeable MMU changes to support 48bit
VAs on arm64.
Summary:
- support for 48bit IPA and VA (EL2)
- a number of fixes for devices mapped into guests
- yet another VGIC fix for BE
- a fix for CPU hotplug
- a few compile fixes (disabled VGIC, strict mm checks)"
[ I'm pulling directly from Marc at the request of Paolo Bonzini, whose
backpack was stolen at Düsseldorf airport and will do new keys and
rebuild his web of trust. - Linus ]
* tag 'kvm-arm-for-3.18-take-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm:
arm/arm64: KVM: Fix BE accesses to GICv2 EISR and ELRSR regs
arm: kvm: STRICT_MM_TYPECHECKS fix for user_mem_abort
arm/arm64: KVM: Ensure memslots are within KVM_PHYS_SIZE
arm64: KVM: Implement 48 VA support for KVM EL2 and Stage-2
arm/arm64: KVM: map MMIO regions at creation time
arm64: kvm: define PAGE_S2_DEVICE as read-only by default
ARM: kvm: define PAGE_S2_DEVICE as read-only by default
arm/arm64: KVM: add 'writable' parameter to kvm_phys_addr_ioremap
arm/arm64: KVM: fix potential NULL dereference in user_mem_abort()
arm/arm64: KVM: use __GFP_ZERO not memset() to get zeroed pages
ARM: KVM: fix vgic-disabled build
arm: kvm: fix CPU hotplug
Pull MIPS updates from Ralf Baechle:
"This is the MIPS pull request for the next kernel:
- Zubair's patch series adds CMA support for MIPS. Doing so it also
touches ARM64 and x86.
- remove the last instance of IRQF_DISABLED from arch/mips
- updates to two of the MIPS defconfig files.
- cleanup of how cache coherency bits are handled on MIPS and
implement support for write-combining.
- platform upgrades for Alchemy
- move MIPS DTS files to arch/mips/boot/dts/"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (24 commits)
MIPS: ralink: remove deprecated IRQF_DISABLED
MIPS: pgtable.h: Implement the pgprot_writecombine function for MIPS
MIPS: cpu-probe: Set the write-combine CCA value on per core basis
MIPS: pgtable-bits: Define the CCA bit for WC writes on Ingenic cores
MIPS: pgtable-bits: Move the CCA bits out of the core's ifdef blocks
MIPS: DMA: Add cma support
x86: use generic dma-contiguous.h
arm64: use generic dma-contiguous.h
asm-generic: Add dma-contiguous.h
MIPS: BPF: Add new emit_long_instr macro
MIPS: ralink: Move device-trees to arch/mips/boot/dts/
MIPS: Netlogic: Move device-trees to arch/mips/boot/dts/
MIPS: sead3: Move device-trees to arch/mips/boot/dts/
MIPS: Lantiq: Move device-trees to arch/mips/boot/dts/
MIPS: Octeon: Move device-trees to arch/mips/boot/dts/
MIPS: Add support for building device-tree binaries
MIPS: Create common infrastructure for building built-in device-trees
MIPS: SEAD3: Enable DEVTMPFS
MIPS: SEAD3: Regenerate defconfigs
MIPS: Alchemy: DB1300: Add touch penirq support
Pull NFS client updates from Trond Myklebust:
"Highlights include:
Stable fixes:
- fix an uninitialised pointer Oops in the writeback error path
- fix a bogus warning (and early exit from the loop) in nfs_generic_pgio()
Features:
- Add NFSv4.2 SEEK feature and client support for lseek(SEEK_HOLE/SEEK_DATA)
Other fixes:
- pnfs: replace broken pnfs_put_lseg_async
- Remove dead prototype for nfs4_insert_deviceid_node"
* tag 'nfs-for-3.18-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
NFS: Fix a bogus warning in nfs_generic_pgio
NFS: Fix an uninitialised pointer Oops in the writeback error path
NFSv4.1/pnfs: replace broken pnfs_put_lseg_async
NFSv4: Remove dead prototype for nfs4_insert_deviceid_node()
NFS: Implement SEEK
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device-mapper updates from Mike Snitzer:
"I rebased the DM tree ontop of linux-block.git's 'for-3.18/core' at
the beginning of October because DM core now depends on the newly
introduced bioset_create_nobvec() interface.
Summary:
- fix DM's long-standing excessive use of memory by leveraging the
new bioset_create_nobvec() interface when creating the DM's bioset
- fix a few bugs in dm-bufio and dm-log-userspace
- add DM core support for a DM multipath use-case that requires
loading DM tables that contain devices that have failed (by
allowing active and inactive DM tables to share dm_devs)
- add discard support to the DM raid target; like MD raid456 the user
must opt-in to raid456 discard support be specifying the
devices_handle_discard_safely=Y module param"
* tag 'dm-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm log userspace: fix memory leak in dm_ulog_tfr_init failure path
dm bufio: when done scanning return from __scan immediately
dm bufio: update last_accessed when relinking a buffer
dm raid: add discard support for RAID levels 4, 5 and 6
dm raid: add discard support for RAID levels 1 and 10
dm: allow active and inactive tables to share dm_devs
dm mpath: stop queueing IO when no valid paths exist
dm: use bioset_create_nobvec()
dm: remove nr_iovecs parameter from alloc_tio()
Pull core block layer changes from Jens Axboe:
"This is the core block IO pull request for 3.18. Apart from the new
and improved flush machinery for blk-mq, this is all mostly bug fixes
and cleanups.
- blk-mq timeout updates and fixes from Christoph.
- Removal of REQ_END, also from Christoph. We pass it through the
->queue_rq() hook for blk-mq instead, freeing up one of the request
bits. The space was overly tight on 32-bit, so Martin also killed
REQ_KERNEL since it's no longer used.
- blk integrity updates and fixes from Martin and Gu Zheng.
- Update to the flush machinery for blk-mq from Ming Lei. Now we
have a per hardware context flush request, which both cleans up the
code should scale better for flush intensive workloads on blk-mq.
- Improve the error printing, from Rob Elliott.
- Backing device improvements and cleanups from Tejun.
- Fixup of a misplaced rq_complete() tracepoint from Hannes.
- Make blk_get_request() return error pointers, fixing up issues
where we NULL deref when a device goes bad or missing. From Joe
Lawrence.
- Prep work for drastically reducing the memory consumption of dm
devices from Junichi Nomura. This allows creating clone bio sets
without preallocating a lot of memory.
- Fix a blk-mq hang on certain combinations of queue depths and
hardware queues from me.
- Limit memory consumption for blk-mq devices for crash dump
scenarios and drivers that use crazy high depths (certain SCSI
shared tag setups). We now just use a single queue and limited
depth for that"
* 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits)
block: Remove REQ_KERNEL
blk-mq: allocate cpumask on the home node
bio-integrity: remove the needless fail handle of bip_slab creating
block: include func name in __get_request prints
block: make blk_update_request print prefix match ratelimited prefix
blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio
block: fix alignment_offset math that assumes io_min is a power-of-2
blk-mq: Make bt_clear_tag() easier to read
blk-mq: fix potential hang if rolling wakeup depth is too high
block: add bioset_create_nobvec()
block: use bio_clone_fast() in blk_rq_prep_clone()
block: misplaced rq_complete tracepoint
sd: Honor block layer integrity handling flags
block: Replace strnicmp with strncasecmp
block: Add T10 Protection Information functions
block: Don't merge requests if integrity flags differ
block: Integrity checksum flag
block: Relocate bio integrity flags
block: Add a disk flag to block integrity profile
block: Add prefix to block integrity profile flags
Pull MTD update from Brian Norris:
"Sorry for delaying this a bit later than usual. There's one mild
regression from 3.16 that was noticed during the 3.17 cycle, and I
meant to send a fix for it along with this pull request. I'll
probably try to queue it up for a later pull request once I've had a
better look at it, hopefully by -rc2 at the latest.
Summary for this pull:
NAND
- Cleanup for Denali driver
- Atmel: add support for new page sizes
- Atmel: fix up 'raw' mode support
- Atmel: miscellaneous cleanups
- New timing mode helpers for non-ONFI NAND
- OMAP: allow driver to be (properly) built as a module
- bcm47xx: RESET support and other cleanups
SPI NOR
- Miscellaneous cleanups, to prepare framework for wider use (some
further work still pending)
- Compile-time configuration to select 4K vs. 64K support for flash
that support both (necessary for using UBIFS on some SPI NOR)
A few scattered code quality fixes, detected by Coverity
See the changesets for more"
* tag 'for-linus-20141015' of git://git.infradead.org/linux-mtd: (59 commits)
mtd: nand: omap: Correct CONFIG_MTD_NAND_OMAP_BCH help message
mtd: nand: Force omap_elm to be built as a module if omap2_nand is a module
mtd: move support for struct flash_platform_data into m25p80
mtd: spi-nor: add Kconfig option to disable 4K sectors
mtd: nand: Move ELM driver and rename as omap_elm
nand: omap2: Replace pr_err with dev_err
nand: omap2: Remove horrible ifdefs to fix module probe
mtd: nand: add Hynix's H27UCG8T2ATR-BC to nand_ids table
mtd: nand: support ONFI timing mode retrieval for non-ONFI NANDs
mtd: physmap_of: Add non-obsolete map_rom probe
mtd: physmap_of: Fix ROM support via OF
MAINTAINERS: add l2-mtd.git, 'next' tree for MTD
mtd: denali: fix indents and other trivial things
mtd: denali: remove unnecessary parentheses
mtd: denali: remove another set-but-unused variable
mtd: denali: fix include guard and license block of denali.h
mtd: nand: don't break long print messages
mtd: bcm47xxnflash: replace some magic numbers
mtd: bcm47xxnflash: NAND_CMD_RESET support
mtd: bcm47xxnflash: add cmd_ctrl handler
Pull md updates from Neil Brown:
- a few minor bug fixes
- quite a lot of code tidy-up and simplification
- remove PRINT_RAID_DEBUG ioctl. I'm fairly sure it is unused, and it
isn't particularly useful.
* tag 'md/3.18' of git://neil.brown.name/md: (21 commits)
lib/raid6: Add log level to printks
md: move EXPORT_SYMBOL to after function in md.c
md: discard PRINT_RAID_DEBUG ioctl
md: remove MD_BUG()
md: clean up 'exit' labels in md_ioctl().
md: remove unnecessary test for MD_MAJOR in md_ioctl()
md: don't allow "-sync" to be set for device in an active array.
md: remove unwanted white space from md.c
md: don't start resync thread directly from md thread.
md: Just use RCU when checking for overlap between arrays.
md: avoid potential long delay under pers_lock
md: simplify export_array()
md: discard find_rdev_nr in favour of find_rdev_nr_rcu
md: use wait_event() to simplify md_super_wait()
md: be more relaxed about stopping an array which isn't started.
md/raid1: process_checks doesn't use its return value.
md/raid5: fix init_stripe() inconsistencies
md/raid10: another memory leak due to reshape.
md: use set_bit/clear_bit instead of shift/mask for bi_flags changes.
md/raid1: minor typos and reformatting.
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"One cc: stable commit, the rest are a series of minor cleanups which
have been sitting in MST's tree during my vacation. I changed a
function name and made one trivial change, then they spent two days in
linux-next"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
virtio-rng: refactor probe error handling
virtio_scsi: drop scan callback
virtio_balloon: enable VQs early on restore
virtio_scsi: fix race on device removal
virito_scsi: use freezable WQ for events
virtio_net: enable VQs early on restore
virtio_console: enable VQs early on restore
virtio_scsi: enable VQs early on restore
virtio_blk: enable VQs early on restore
virtio_scsi: move kick event out from virtscsi_init
virtio_net: fix use after free on allocation failure
9p/trans_virtio: enable VQs early
virtio: add API to enable VQs early
virtio_net: minor cleanup
virtio-net: drop config_mutex
virtio_net: drop config_enable
virtio-blk: drop config_mutex
$ make M=net/ipv4
CC net/ipv4/route.o
In file included from net/ipv4/route.c:102:0:
include/net/tcp.h: In function ‘tcp_v6_iif’:
include/net/tcp.h:738:32: error: ‘union <anonymous>’ has no member named ‘h6’
return TCP_SKB_CB(skb)->header.h6.iif;
Fixes: 870c3151382c ("ipv6: introduce tcp_v6_iif()")
1) Include fixes for netrom and dsa (Fabian Frederick and Florian
Fainelli)
2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO.
3) Several SKB use after free fixes (vxlan, openvswitch, vxlan,
ip_tunnel, fou), from Li ROngQing.
4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy.
5) Use after free in virtio_net, from Michael S Tsirkin.
6) Fix flow mask handling for megaflows in openvswitch, from Pravin B
Shelar.
7) ISDN gigaset and capi bug fixes from Tilman Schmidt.
8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin.
9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov.
10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong
Wang and Eric Dumazet.
11) Don't overwrite end of SKB when parsing malformed sctp ASCONF
chunks, from Daniel Borkmann.
12) Don't call sock_kfree_s() with NULL pointers, this function also has
the side effect of adjusting the socket memory usage. From Cong Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
bna: fix skb->truesize underestimation
net: dsa: add includes for ethtool and phy_fixed definitions
openvswitch: Set flow-key members.
netrom: use linux/uaccess.h
dsa: Fix conversion from host device to mii bus
tipc: fix bug in bundled buffer reception
sfc: add support for skb->xmit_more
r8152: return -EBUSY for runtime suspend
ipv4: fix a potential use after free in fou.c
ipv4: fix a potential use after free in ip_tunnel_core.c
hyperv: Add handling of IP header with option field in netvsc_set_hash()
openvswitch: Create right mask with disabled megaflows
vxlan: fix a free after use
openvswitch: fix a use after free
ipv4: dst_entry leak in ip_send_unicast_reply()
ipv4: clean up cookie_v4_check()
ipv4: share tcp_v4_save_options() with cookie_v4_check()
ipv4: call __ip_options_echo() in cookie_v4_check()
atm: simplify lanai.c by using module_pci_driver
net/dsa/slave.c uses functions and structures declared in phy_fixed.h
but does not explicitely include it, while dsa.h needs structure
declarations for 'struct ethtool_wolinfo' and 'struct ethtool_eee', fix
those by including the correct header files.
Fixes: ec9436baedb6 ("net: dsa: allow drivers to do link adjustment")
Fixes: ce31b31c68e7 ("net: dsa: allow updating fixed PHY link information")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Commit 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line
misses") added a regression for SO_BINDTODEVICE on IPv6.
This is because we still use inet6_iif() which expects that IP6 control
block is still at the beginning of skb->cb[]
This patch adds tcp_v6_iif() helper and uses it where necessary.
Because __inet6_lookup_skb() is used by TCP and DCCP, we add an iif
parameter to it.
Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
Acked-by: Cong Wang <cwang@twopensource.com>
We can retrieve opt from skb, no need to pass it as a parameter.
And opt should always be non-NULL, no need to check.
Cc: Krzysztof Kolasa <kkolasa@winsoft.pl>
Cc: Eric Dumazet <edumazet@google.com>
Tested-by: Krzysztof Kolasa <kkolasa@winsoft.pl>
Signed-off-by: Cong Wang <cwang@twopensource.com>
cookie_v4_check() allocates ip_options_rcu in the same way
with tcp_v4_save_options(), we can just make it a helper function.
Avoid confusion between pid and portid.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
The EIRSR and ELRSR registers are 32-bit registers on GICv2, and we
store these as an array of two such registers on the vgic vcpu struct.
However, we access them as a single 64-bit value or as a bitmap pointer
in the generic vgic code, which breaks BE support.
Instead, store them as u64 values on the vgic structure and do the
word-swapping in the assembly code, which already handles the byte order
for BE systems.
Tested-by: Victor Kamensky <victor.kamensky@linaro.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Add ndo_gso_check which a device can define to indicate whether is
is capable of doing GSO on a packet. This funciton would be called from
the stack to determine whether software GSO is needed to be done. A
driver should populate this function if it advertises GSO types for
which there are combinations that it wouldn't be able to handle. For
instance a device that performs UDP tunneling might only implement
support for transparent Ethernet bridging type of inner packets
or might have limitations on lengths of inner headers.
Signed-off-by: Tom Herbert <therbert@google.com>
as users have been converted, so no need of this custom method
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
The freescale driver uses custom device control FSLDMA_EXTERNAL_START to
put the controller in external start mode.
Since we are planning to deprecate the device control, move this to exported
API. Subsequent patches will remove the FSLDMA_EXTERNAL_START
This was only prep API which didnt have an helper
The driver library functions can be used directly by the compound devices such
as ADSP or serial driver where DesignWare DMA IP is privately attached to the
main hardware.
Instead of creating a new platform device leaf they may call dw_dma_probe()
with given struct dw_dma_chip directly and make sure that the main device is
DMA capable.
The introduced include/linux/dma/dw.h is going to contain the private
extensions and structures which are shared for dw_dmac users in the kernel.
Meanwhile include/linux/platform_data/dma-dw.h keeps only platform related data
types and definitions.
Since we don't allow user to set registers directly through private slave
configuration we may move definitions to the regs.h because they are not used
anywhere except core.c part.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
git://git.linuxfoundation.org/llvmlinux/kernel
Pull LLVM updates from Behan Webster:
"These patches remove the use of VLAIS using a new SHASH_DESC_ON_STACK
macro.
Some of the previously accepted VLAIS removal patches haven't used
this macro. I will push new patches to consistently use this macro in
all those older cases for 3.19"
[ More LLVM patches coming in through subsystem trees, and LLVM itself
needs some fixes that are already in many distributions but not in
released versions of LLVM. Some day this will all "just work" - Linus ]
* tag 'llvmlinux-for-v3.18' of git://git.linuxfoundation.org/llvmlinux/kernel:
crypto: LLVMLinux: Remove VLAIS usage from crypto/testmgr.c
security, crypto: LLVMLinux: Remove VLAIS from ima_crypto.c
crypto: LLVMLinux: Remove VLAIS usage from libcrc32c.c
crypto: LLVMLinux: Remove VLAIS usage from crypto/hmac.c
crypto, dm: LLVMLinux: Remove VLAIS usage from dm-crypt
crypto: LLVMLinux: Remove VLAIS from crypto/.../qat_algs.c
crypto: LLVMLinux: Remove VLAIS from crypto/omap_sham.c
crypto: LLVMLinux: Remove VLAIS from crypto/n2_core.c
crypto: LLVMLinux: Remove VLAIS from crypto/mv_cesa.c
crypto: LLVMLinux: Remove VLAIS from crypto/ccp/ccp-crypto-sha.c
btrfs: LLVMLinux: Remove VLAIS
crypto: LLVMLinux: Add macro to remove use of VLAIS in crypto code
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"This pull-request includes:
- change in the IOMMU-API to convert the former iommu_domain_capable
function to just iommu_capable
- various fixes in handling RMRR ranges for the VT-d driver (one fix
requires a device driver core change which was acked by Greg KH)
- the AMD IOMMU driver now assigns and deassigns complete alias
groups to fix issues with devices using the wrong PCI request-id
- MMU-401 support for the ARM SMMU driver
- multi-master IOMMU group support for the ARM SMMU driver
- various other small fixes all over the place"
* tag 'iommu-updates-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (41 commits)
iommu/vt-d: Work around broken RMRR firmware entries
iommu/vt-d: Store bus information in RMRR PCI device path
iommu/vt-d: Only remove domain when device is removed
driver core: Add BUS_NOTIFY_REMOVED_DEVICE event
iommu/amd: Fix devid mapping for ivrs_ioapic override
iommu/irq_remapping: Fix the regression of hpet irq remapping
iommu: Fix bus notifier breakage
iommu/amd: Split init_iommu_group() from iommu_init_device()
iommu: Rework iommu_group_get_for_pci_dev()
iommu: Make of_device_id array const
amd_iommu: do not dereference a NULL pointer address.
iommu/omap: Remove omap_iommu unused owner field
iommu: Remove iommu_domain_has_cap() API function
IB/usnic: Convert to use new iommu_capable() API function
vfio: Convert to use new iommu_capable() API function
kvm: iommu: Convert to use new iommu_capable() API function
iommu/tegra: Convert to iommu_capable() API function
iommu/msm: Convert to iommu_capable() API function
iommu/vt-d: Convert to iommu_capable() API function
iommu/fsl: Convert to iommu_capable() API function
git://git.linaro.org/people/mike.turquette/linux
Pull clock tree updates from Mike Turquette:
"The clk tree changes for 3.18 are dominated by clock drivers. Mostly
fixes and enhancements to existing drivers as well as new drivers.
This tag contains a bit more arch code than I usually take due to some
OMAP2+ changes. Additionally it contains the restart notifier
handlers which are merged as a dependency into several trees.
The PXA changes are the only messy part. Due to having a stable tree
I had to revert one patch and follow up with one more fix near the tip
of this tag. Some dead code is introduced but it will soon become
live code after 3.18-rc1 is released as the rest of the PXA family is
converted over to the common clock framework.
Another trend in this tag is that multiple vendors have started to
push the complexity of changing their CPU frequency into the clock
driver, whereas this used to be done in CPUfreq drivers.
Changes to the clk core include a generic gpio-clock type and a
clk_set_phase() function added to the top-level clk.h api. Due to
some confusion on the fbdev mailing list the kernel boot parameters
documentation was updated to further explain the clk_ignore_unused
parameter, which is often required by users of the simplefb driver.
Finally some fixes to the locking around the clock debugfs stuff was
done to prevent deadlocks when interacting with other subsystems."
* tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits)
clk: pxa clocks build system fix
Revert "arm: pxa: Transition pxa27x to clk framework"
clk: samsung: register restart handlers for s3c2412 and s3c2443
clk: rockchip: add restart handler
clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate
doc/kernel-parameters.txt: clarify clk_ignore_unused
dts: add devicetree bindings for pxa27x clocks
clk: add pxa27x clock drivers
arm: pxa: add clock pll selection bits
clk: dts: document pxa clock binding
clk: add pxa clocks infrastructure
clk: gpio-gate: Ensure gpiod_ APIs are prototyped
clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe
clk: ti: LLVMLinux: Move __init outside of type definition
clk: ti: consider the fact that of_clk_get() might return an error
clk: ti: dra7-atl-clock: fix a memory leak
clk: ti: change clock init to use generic of_clk_init
clk: hix5hd2: add I2C clocks
clk: hix5hd2: add watchdog0 clocks
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Changes to existing drivers:
- DT clean-ups in da9055-core, max14577, rn5t618, arizona, hi6421, stmpe, twl4030
- Export symbols for use in modules in max14577
- Plenty of static code analysis/Coccinelle fixes throughout the SS
- Regmap clean-ups in arizona, wm5102, wm5110, da9052, tps65217, rk808
- Remove unused/duplicate code in da9052, 88pm860x, ti_ssp, lpc_sch, arizona
- Bug fixes in ti_am335x_tscadc, da9052, ti_am335x_tscadc, rtsx_pcr
- IRQ fixups in arizona, stmpe, max14577
- Regulator related changes in axp20x
- Pass DMA coherency information from parent => child in MFD core
- Rename DT document files for consistency
- Add ACPI support to the MFD core
- Add Andreas Werner to MAINTAINERS for MEN F21BMC
New drivers/supported devices:
- New driver for MEN 14F021P00 Board Management Controller
- New driver for Ricoh RN5T618 PMIC
- New driver for Rockchip RK808
- New driver for HiSilicon Hi6421 PMIC
- New driver for Qualcomm SPMI PMICs
- Add support for Intel Braswell in lpc_ich
- Add support for Intel 9 Series PCH in lpc_ich
- Add support for Intel Quark ILB in lpc_sch"
[ Delayed to after the poweer/reset pull due to Kconfig problems with
recursive Kconfig select/depends-on chains. - Linus ]
* tag 'mfd-for-linus-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (79 commits)
mfd: cros_ec: wait for completion of commands that return IN_PROGRESS
i2c: i2c-cros-ec-tunnel: Set retries to 3
mfd: cros_ec: move locking into cros_ec_cmd_xfer
mfd: cros_ec: stop calling ->cmd_xfer() directly
mfd: cros_ec: Delay for 50ms when we see EC_CMD_REBOOT_EC
MAINTAINERS: Adds Andreas Werner to maintainers list for MEN F21BMC
mfd: arizona: Correct mask to allow setting micbias external cap
mfd: Add ACPI support
Revert "mfd: wm5102: Manually apply register patch"
mfd: ti_am335x_tscadc: Update logic in CTRL register for 5-wire TS
mfd: dt-bindings: atmel-gpbr: Rename doc file to conform to naming convention
mfd: dt-bindings: qcom-pm8xxx: Rename doc file to conform to naming convention
mfd: Inherit coherent_dma_mask from parent device
mfd: Document DT bindings for Qualcomm SPMI PMICs
mfd: Add support for Qualcomm SPMI PMICs
mfd: dt-bindings: pm8xxx: Add new compatible string
mfd: axp209x: Drop the parent supplies field
mfd: twl4030-power: Use 'ti,system-power-controller' as alternative way to support system power off
mfd: dt-bindings: twl4030-power: Use the standard property to mark power control
mfd: syscon: Add Atmel GPBR DT bindings documention
Pull power supply and reset updates from Sebastian Reichel:
- Initial support for the following chips
* max77836 (charger)
* max14577 (charger)
* bq27742 (battery gauge)
* ltc2952 (poweroff)
* stih416 (restart)
* syscon-reboot (restart)
* gpio-restart (restart)
- cleanup of power supply core
- misc fixes in power supply and reset drivers
* tag 'for-v3.18' of git://git.infradead.org/battery-2.6: (48 commits)
power: ab8500_fg: Fix build warning
Documentation: charger: max14577: Update the date of introducing ABI
power: reset: corrections for simple syscon reboot driver
Documentation: power: reset: Add documentation for generic SYSCON reboot driver
power: reset: Add generic SYSCON register mapped reset
bq27x00_battery: Fix flag reading for bq27742
power: reset: use restart_notifier mechanism for msm-poweroff
power: Add simple gpio-restart driver
power: reset: st: Provide DT bindings for ST's Power Reset driver
power: reset: Add restart functionality for STiH41x platforms
power: charger-manager: Fix NULL pointer exception with missing cm-fuel-gauge
power: max14577: Fix circular config SYSFS dependency
power: gpio-charger: do not use gpio value directly
power: max8925: Use of_get_child_by_name
power: max8925: Fix NULL ptr dereference on memory allocation failure
bq27x00_battery: Add support to bq27742
Documentation: charger: max14577: Document exported sysfs entry
devicetree: mfd: max14577: Add device tree bindings document
power: max17040: Add ID for MAX77836 Fuel Gauge block
charger: max14577: Configure battery-dependent settings from DTS and sysfs
drivers/power/reset/Kconfig
drivers/power/reset/Makefile
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph updates from Sage Weil:
"There is the long-awaited discard support for RBD (Guangliang Zhao,
Josh Durgin), a pile of RBD bug fixes that didn't belong in late -rc's
(Ilya Dryomov, Li RongQing), a pile of fs/ceph bug fixes and
performance and debugging improvements (Yan, Zheng, John Spray), and a
smattering of cleanups (Chao Yu, Fabian Frederick, Joe Perches)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (40 commits)
ceph: fix divide-by-zero in __validate_layout()
rbd: rbd workqueues need a resque worker
libceph: ceph-msgr workqueue needs a resque worker
ceph: fix bool assignments
libceph: separate multiple ops with commas in debugfs output
libceph: sync osd op definitions in rados.h
libceph: remove redundant declaration
ceph: additional debugfs output
ceph: export ceph_session_state_name function
ceph: include the initial ACL in create/mkdir/mknod MDS requests
ceph: use pagelist to present MDS request data
libceph: reference counting pagelist
ceph: fix llistxattr on symlink
ceph: send client metadata to MDS
ceph: remove redundant code for max file size verification
ceph: remove redundant io_iter_advance()
ceph: move ceph_find_inode() outside the s_mutex
ceph: request xattrs if xattr_version is zero
rbd: set the remaining discard properties to enable support
rbd: use helpers to handle discard for layered images correctly
virtio spec 0.9.X requires DRIVER_OK to be set before
VQs are used, but some drivers use VQs before probe
function returns.
Since DRIVER_OK is set after probe, this violates the spec.
Even though under virtio 1.0 transitional devices support this
behaviour, we want to make it possible for those early callers to become
spec compliant and eventually support non-transitional devices.
Add API for drivers to call before using VQs.
Sets DRIVER_OK internally.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Defer config changed notifications that arrive during
probe/scan/freeze/restore.
This will allow drivers to set DRIVER_OK earlier, without worrying about
racing with config change interrupts.
This change will also benefit old hypervisors (before 2009)
that send interrupts without checking DRIVER_OK: previously,
the callback could race with driver-specific initialization.
This will also help simplify drivers.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (cosmetic changes)
This is in preparation to extending config changed event handling
in core.
Wrapping these in an API also seems to make for a cleaner code.
Replace duplicated code in all transports with a single wrapper in
virtio.c.
The only functional change is in virtio_mmio.c: if a buggy device sends
us an interrupt before driver is set, we previously returned IRQ_NONE,
now we return IRQ_HANDLED.
As this must not happen in practice, this does not look like a big deal.
See also commit 3fff0179e33cd7d0a688dab65700c46ad089e934
virtio-pci: do not oops on config change if driver not loaded.
for the original motivation behind the driver check.
Resolve "logical 'and' applied to non-boolean constant" warnings"
that appear in W=2 builds by adding !! to a bit test.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
userspace programs that use eBPF instruction macros need to include two files:
uapi/linux/filter.h and uapi/linux/bpf.h
Move common macro definitions that are shared between classic BPF and eBPF
into uapi/linux/bpf_common.h, so that user app can include only one bpf.h file
Cc: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Bring in missing osd ops and strings, use macros to eliminate multiple
points of maintenance.
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
Reviewed-by: Sage Weil <sage@redhat.com>
ceph_release_page_vector was defined twice in libceph.h
Signed-off-by: Fabian Frederick <fabf@skynet.be>
this allow pagelist to present data that may be sent multiple times.
Signed-off-by: Yan, Zheng <zyan@redhat.com>
Function capi20_manufacturer() is declared with unsigned int cmd
argument but called with unsigned long.
Fix by correcting the function prototype since the actual argument
is part of the user visible API.
Spotted with Coverity.
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
no user uses this lock.
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
If the skb is not dropped afterwards we should run consume_skb instead
kfree_skb. Inside of function skb_unshare we do always a kfree_skb,
doesn't depend if skb_copy failed or was successful.
This patch switch this behaviour like skb_share_check, if allocation of
sk_buff failed we use kfree_skb otherwise consume_skb.
Signed-off-by: Alexander Aring <alex.aring@gmail.com>
