commit 7bc069c6bc4ede519a7116be1b9e149a1dbf787a upstream
The masked difference is what needs to be compared against 1, rather
than the difference of masked values (which can be negative).
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Nick Piggin <npiggin@suse.de>
Commit efc491814308f89d5ef6c4fe19ae4552a67d4132 upstream
radeon: misc corrections
I have a new PCI-E radeon RV380 series card (PCI device ID 5b64) that
hangs in my sparc64 boxes when the init scripts set the font. The problem
goes away if I disable acceleration.
I haven't figured out that bug yet, but along the way I found some
corrections to make based upon some auditing.
1) The RB2D_DC_FLUSH_ALL value used by the kernel fb driver
and the XORG video driver differ. I've made the kernel
match what XORG is using.
2) In radeonfb_engine_reset() we have top-level code structure
that roughly looks like:
if (family is 300, 350, or V350)
do this;
else
do that;
if (family is NOT 300, OR
family is NOT 350, OR
family is NOT V350)
do another thing;
this last conditional makes no sense, is always true,
and obviously was likely meant to be "family is NOT
300, 350, or V350". So I've made the code match the
intent.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
[ Upstream commit d72609e17fd93bb2f7e0f7e1bdc70b6d20e43843 ]
Correct sparc64's implementation of FUTEX_OP_ANDN to do a
bitwise negate of the oparg parameter before applying the
AND operation. All other archs that support FUTEX_OP_ANDN
either negate oparg explicitly (frv, ia64, mips, sh, x86),
or do so indirectly by using an and-not instruction (powerpc).
Since sparc64 has and-not, I chose to use that solution.
I've not found any use of FUTEX_OP_ANDN in glibc so the
impact of this bug is probably minor. But other user-space
components may try to use it so it should still get fixed.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
commit 969830b2fedf8336c41d6195f49d250b1e166ff8 upstream
Some chips appear to have the 2D engine hang during screen redraw,
typically in a sequence of copyarea operations. This appear to be
solved by adding a flush of the engine destination pixel cache
and waiting for the engine to be idle before issuing the accel
operation. The performance impact seems to be fairly small.
Here is a trace on an RV370 (PCI device ID 0x5b64), it records the
RBBM_STATUS register, then the source x/y, destination x/y, and
width/height used for the copy:
radeonfb_prim_copyarea: STATUS[00000140] src[210:70] dst[210:60] wh[a0:10]
radeonfb_prim_copyarea: STATUS[00000140] src[2b8:70] dst[2b8:60] wh[88:10]
radeonfb_prim_copyarea: STATUS[00000140] src[348:70] dst[348:60] wh[40:10]
radeonfb_prim_copyarea: STATUS[80020140] src[390:70] dst[390:60] wh[88:10]
radeonfb_prim_copyarea: STATUS[8002613f] src[40:80] dst[40:70] wh[28:10]
radeonfb_prim_copyarea: STATUS[80026139] src[a8:80] dst[a8:70] wh[38:10]
radeonfb_prim_copyarea: STATUS[80026133] src[e8:80] dst[e8:70] wh[80:10]
radeonfb_prim_copyarea: STATUS[8002612d] src[170:80] dst[170:70] wh[30:10]
radeonfb_prim_copyarea: STATUS[80026127] src[1a8:80] dst[1a8:70] wh[8:10]
radeonfb_prim_copyarea: STATUS[80026121] src[1b8:80] dst[1b8:70] wh[88:10]
radeonfb_prim_copyarea: STATUS[8002611b] src[248:80] dst[248:70] wh[68:10]
When things are going fine the copies complete before the next ROP is
even issued, but all of a sudden the 2D unit becomes active (bit 17 in
RBBM_STATUS) and the FIFO retry (bit 13) and FIFO pipeline busy (bit
14) are set as well. The FIFO begins to backup until it becomes full.
What happens next is the radeon_fifo_wait() times out, and we access
the chip illegally leading to a bus error which usually wedges the
box. None of this makes it to the console screen, of course :-)
radeon_fifo_wait() should be modified to reset the accelerator when
this timeout happens instead of programming the chip anyways.
radeonfb: FIFO Timeout !
ERROR(0): Cheetah error trap taken afsr[0010080005000000] afar[000007f900800e40] TL1(0)
ERROR(0): TPC[595114] TNPC[595118] O7[459788] TSTATE[11009601]
ERROR(0): TPC<radeonfb_copyarea+0xfc/0x248>
ERROR(0): M_SYND(0), E_SYND(0), Privileged
ERROR(0): Highest priority error (0000080000000000) "Bus error response from system bus"
ERROR(0): D-cache idx[0] tag[0000000000000000] utag[0000000000000000] stag[0000000000000000]
ERROR(0): D-cache data0[0000000000000000] data1[0000000000000000] data2[0000000000000000] data3[0000000000000000]
ERROR(0): I-cache idx[0] tag[0000000000000000] utag[0000000000000000] stag[0000000000000000] u[0000000000000000] l[00\
ERROR(0): I-cache INSN0[0000000000000000] INSN1[0000000000000000] INSN2[0000000000000000] INSN3[0000000000000000]
ERROR(0): I-cache INSN4[0000000000000000] INSN5[0000000000000000] INSN6[0000000000000000] INSN7[0000000000000000]
ERROR(0): E-cache idx[800e40] tag[000000000e049f4c]
ERROR(0): E-cache data0[fffff8127d300180] data1[00000000004b5384] data2[0000000000000000] data3[0000000000000000]
Ker:xnel panic - not syncing: Irrecoverable deferred error trap.
Another quirk is that these copyarea calls will not happen until the
first drivers/char/vt.c:redraw_screen() occurs. This will only happen
if you 1) VC switch or 2) run "consolechars" or 3) unblank the screen.
This seems to happen because until a redraw_screen() the screen scrolling
method used by fbcon is not finalized yet. I've seen this with other fb
drivers too.
So if all you do is boot straight into X you will never see this bug on
the relevant chips.
commit 0282b7f2a874e72c18fcd5a112ccf67f71ba7f5c upstream
This patch (as1121) fixes a bug in the USB serial core. When a device
is unregistered, the core will give back its minors -- even if the
device hasn't been assigned any!
The patch reserves the highest minor value (255) to mean that no minor
was assigned. It also removes some dead code and does a small style
fixup.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit d2cd74b158d7214a556226e3312f9fb1de64d7ae upstream
On Audigy2 Platinum, the Analog/Digital mixer switch is inverted.
https://bugzilla.novell.com/show_bug.cgi?id=396204
The patch adds a simple workaround.
There might be another device requiring a similar fix, too (or fix for
audigy2 generically), but right now I fix only the known broken one.
commit e48d6d97bb6bd8c008045ea0522ea8278fdccc55 upstream
ASUS A9T laptop uses line-out pin as the real front-output while
other devices use it as the surround.
commit 73f20e58b1d586e9f6d3ddc3aad872829aca7743 upstream
The on-disk media specification field in FAT is only 8-bits, so testing for
<=0xff is pointless, and can generate a "comparison is always true due to
limited range of data type" warning.
While we're there, convert FAT_VALID_MEDIA() into a C function - the present
implementation is buggy: it generates either one or two references to its
argument.
Cc: Frank Seidel <fseidel@suse.de>
Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Correct hash flushing from huge_ptep_set_wrprotect() [stable tree version]
A fix for incorrect flushing of the hash page table at fork() for
hugepages was recently committed as
86df86424939d316b1f6cfac1b6204f0c7dee317. Without this fix, a process
can make a MAP_PRIVATE hugepage mapping, then fork() and have writes
to the mapping after the fork() pollute the child's version.
Unfortunately this bug also exists in the stable branch. In fact in
that case copy_hugetlb_page_range() from mm/hugetlb.c calls
ptep_set_wrprotect() directly, the hugepage variant hook
huge_ptep_set_wrprotect() doesn't even exist.
The patch below is a port of the fix to the stable25/master branch.
It introduces a huge_ptep_set_wrprotect() call, but this is #defined
to be equal to ptep_set_wrprotect() unless the arch defines its own
version and sets __HAVE_ARCH_HUGE_PTEP_SET_WRPROTECT.
This arch preprocessor flag is kind of nasty, but it seems the sanest
way to introduce this fix with minimum risk of breaking other archs
for whom prep_set_wprotect() is suitable for hugepages.
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
commit a1531acd43310a7e4571d52e8846640667f4c74b upstream
Ingo Molnar provided a fix to not call _PPC at processor driver
initialization time in "[PATCH] ACPI: fix cpufreq regression" (git
commit e4233dec749a3519069d9390561b5636a75c7579)
But it can still happen that _PPC is called at processor driver
initialization time.
This patch should make sure that this is not possible anymore.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Cc: Len Brown <lenb@kernel.org>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
commit 0c65f459ce6c8bd873a61b3ae1e57858ab1debf3 upstream
arm's fls() is implemented as a macro, causing it to misbehave when passed
64-bit arguments. Fix.
Cc: Nickolay Vinogradov <nickolay@protei.ru>
Tested-by: Krzysztof Halasa <khc@pm.waw.pl>
[ Upstream commit 74988bd85d1cb97987534fd7ffbc570e81145418 ]
The IOMMU code and the block layer can split things
up using different rules, so this can't work reliably.
section
commit fb5e2b379732e1a6ea32392980bb42e0212db842 upstream
Due to the addition of __attribute__((__cold__)) to a few symbols
without adjusting the linker scripts, those symbols currently may end
up outside the [_stext,_etext) range, as they get placed in
.text.unlikely by (at least) gcc 4.3.0. This may confuse code not only
outside of the kernel, symbol_put_addr()'s BUG() could also trigger.
Hence we need to add .text.unlikely (and for future uses of
__attribute__((__hot__)) also .text.hot) to the TEXT_TEXT() macro.
Issue observed by Lukas Lipavsky.
Tested-by: Lukas Lipavsky <llipavsky@suse.cz>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
[ Upstream commit 47112e25da41d9059626033986dc3353e101f815 ]
This patch clamps the cscov setsockopt values to a maximum of 0xFFFF.
Setsockopt values greater than 0xffff can cause an unwanted
wrap-around. Further, IPv6 jumbograms are not supported (RFC 3838,
3.5), so that values greater than 0xffff are not even useful.
Further changes: fixed a typo in the documentation.
[ Add USHORT_MAX from upstream to linux/kernel.h -DaveM ]
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
[ Upstream commit ebb36a978131810c98e7198b1187090c697cf99f ]
Based upon a report by Olaf Hering.
commit 18ce3751ccd488c78d3827e9f6bf54e6322676fb upstream
fsync_buffers_list() and sync_dirty_buffer() both issue async writes and
then immediately wait on them. Conceptually, that makes them sync writes
and we should treat them as such so that the IO schedulers can handle
them appropriately.
This patch fixes a write starvation issue that Lin Ming reported, where
xx is stuck for more than 2 minutes because of a large number of
synchronous IO in the system:
INFO: task kjournald:20558 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
message.
kjournald D ffff810010820978 6712 20558 2
ffff81022ddb1d10 0000000000000046 ffff81022e7baa10 ffffffff803ba6f2
ffff81022ecd0000 ffff8101e6dc9160 ffff81022ecd0348 000000008048b6cb
0000000000000086 ffff81022c4e8d30 0000000000000000 ffffffff80247537
Call Trace:
[<ffffffff803ba6f2>] kobject_get+0x12/0x17
[<ffffffff80247537>] getnstimeofday+0x2f/0x83
[<ffffffff8029c1ac>] sync_buffer+0x0/0x3f
[<ffffffff8066d195>] io_schedule+0x5d/0x9f
[<ffffffff8029c1e7>] sync_buffer+0x3b/0x3f
[<ffffffff8066d3f0>] __wait_on_bit+0x40/0x6f
[<ffffffff8066d48b>] out_of_line_wait_on_bit+0x6c/0x78
[<ffffffff80243909>] wake_bit_function+0x0/0x23
[<ffffffff8029e3ad>] sync_dirty_buffer+0x98/0xcb
[<ffffffff8030056b>] journal_commit_transaction+0x97d/0xcb6
[<ffffffff8023a676>] lock_timer_base+0x26/0x4b
[<ffffffff8030300a>] kjournald+0xc1/0x1fb
[<ffffffff802438db>] autoremove_wake_function+0x0/0x2e
[<ffffffff80302f49>] kjournald+0x0/0x1fb
[<ffffffff802437bb>] kthread+0x47/0x74
[<ffffffff8022de51>] schedule_tail+0x28/0x5d
[<ffffffff8020cac8>] child_rip+0xa/0x12
[<ffffffff80243774>] kthread+0x0/0x74
[<ffffffff8020cabe>] child_rip+0x0/0x12
Lin Ming confirms that this patch fixes the issue. I've run tests with
it for the past week and no ill effects have been observed, so I'm
proposing it for inclusion into 2.6.26.
commit 5ac37f87ff18843aabab84cf75b2f8504c2d81fe upstream
Fix size of LDT entries. On x86-64, ldt_desc is a double-sized descriptor.
Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de>
Commit 41aefdcc98fdba47459eab67630293d67e855fc3 upstream
x86: shift bits the right way in native_read_tscp
native_read_tscp shifts the bits in the high order value in the
wrong direction, the attached patch fixes that.
Signed-off-by: Max Asbock <masbock@linux.vnet.ibm.com>
Acked-by: Glauber Costa <gcosta@redhat.com>
commit ad524d46f36bbc32033bb72ba42958f12bf49b06 upstream
When a 64-bit x86 processor runs in 32-bit PAE mode, a pte can
potentially have the same number of physical address bits as the
64-bit host ("Enhanced Legacy PAE Paging"). This means, in theory,
we could have up to 52 bits of physical address in a pte.
The 32-bit kernel uses a 32-bit unsigned long to represent a pfn.
This means that it can only represent physical addresses up to 32+12=44
bits wide. Rather than widening pfns everywhere, just set 2^44 as the
Linux x86_32-PAE architectural limit for physical address size.
This is a bugfix for two cases:
1. running a 32-bit PAE kernel on a machine with
more than 64GB RAM.
2. running a 32-bit PAE Xen guest on a host machine with
more than 64GB RAM
In both cases, a pte could need to have more than 36 bits of physical,
and masking it to 36-bits will cause fairly severe havoc.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Jan Beulich <jbeulich@novell.com>
commit 71c2742f5e6348d76ee62085cf0a13e5eff0f00e upstream
This patch changes the function reserve_bootmem_node() from void to int,
returning -ENOMEM if the allocation fails.
This fixes a build problem on x86 with CONFIG_KEXEC=y and
CONFIG_NEED_MULTIPLE_NODES=y
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Reported-by: Adrian Bunk <bunk@kernel.org>
commit 81b2dbcad86732ffc02bad87aa25c4651199fc77 in mainline.
vidiocgmbuf() does this:
mutex_lock(&fh->cap.vb_lock);
retval = videobuf_mmap_setup(&fh->cap, gbuffers, gbufsize,
V4L2_MEMORY_MMAP);
and videobuf_mmap_setup() then just does
mutex_lock(&q->vb_lock);
ret = __videobuf_mmap_setup(q, bcount, bsize, memory);
mutex_unlock(&q->vb_lock);
which is an obvious double-take deadlock.
This patch fixes this by having vidiocgmbuf() just call the
__videobuf_mmap_setup function instead.
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Reported-by: Koos Vriezen <koos.vriezen@gmail.com>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
commit 69c5ddf58a03da3686691ad2f293bc79fd977c10 upstream
Add ext2_find_{first,next}_bit(), which are needed for ext4.
They're derived out of the ext2_find_next_zero_bit found in the same file.
Compile tested with crosstools
[Reworked to preserve all symmetry with ext2_find_{first,next}_zero_bit()]
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10393
commit 24aac480e76c6f5d1391ac05c5e9c0eb9b0cd302 upstream
Date: Thu, 12 Jun 2008 15:21:34 -0700
Subject: cciss: add new hardware support
Add support for the next generation of HP Smart Array SAS/SATA
controllers. Shipping date is late Fall 2008.
Bump the driver version to 3.6.20 to reflect the new hardware support from
patch 1 of this set.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
[ upstream commit: b9a2f2e450b0f770bb4347ae8d48eb2dea701e24 ]
The purpose of nla_parse_nested_compat() is to parse attributes which
contain a struct followed by a stream of nested attributes. So far,
it called nla_parse_nested() to parse the stream of nested attributes
which was wrong, as nla_parse_nested() expects a container attribute
as data which holds the attribute stream. It needs to call
nla_parse() directly while pointing at the next possible alignment
point after the struct in the beginning of the attribute.
With this patch, I can no longer reproduce the reported leftover
warnings.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Patrick McHardy <kaber@trash.net>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
support.
upstream commit: ca05a99a54db1db5bca72eccb5866d2a86f8517f
Source code out there hard-codes a notion of what the
_LINUX_CAPABILITY_VERSION #define means in terms of the semantics of the
raw capability system calls capget() and capset(). Its unfortunate, but
true.
Since the confusing header file has been in a released kernel, there is
software that is erroneously using 64-bit capabilities with the semantics
of 32-bit compatibilities. These recently compiled programs may suffer
corruption of their memory when sys_getcap() overwrites more memory than
they are coded to expect, and the raising of added capabilities when using
sys_capset().
As such, this patch does a number of things to clean up the situation
for all. It
1. forces the _LINUX_CAPABILITY_VERSION define to always retain its
legacy value.
2. adopts a new #define strategy for the kernel's internal
implementation of the preferred magic.
3. deprecates v2 capability magic in favor of a new (v3) magic
number. The functionality of v3 is entirely equivalent to v2,
the only difference being that the v2 magic causes the kernel
to log a "deprecated" warning so the admin can find applications
that may be using v2 inappropriately.
[User space code continues to be encouraged to use the libcap API which
protects the application from details like this. libcap-2.10 is the first
to support v3 capabilities.]
Fixes issue reported in https://bugzilla.redhat.com/show_bug.cgi?id=447518.
Thanks to Bojan Smojver for the report.
[akpm@linux-foundation.org: s/depreciate/deprecate/g]
[akpm@linux-foundation.org: be robust about put_user size]
Signed-off-by: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serue@us.ibm.com>
Cc: Bojan Smojver <bojan@rexursive.com>
Cc: stable@kernel.org
upstream commit: 6e7045990f35ef9250804b3fd85e855b8c2aaeb6.
[jkosina@suse.cz: Needed to fix apple aluminium keyboard regression]
Since 2.6.25 the HID_QUIRK_APPLE_HAS_FN quirk is enabled even for
non-laptop Apple keyboards of the Aluminium series. The USB version of
these don't need Numlock emulation, like the laptop (and Aluminium
Wireless) do, as they have a proper keypad.
This patch splits the Numlock emulation for Apple keyboards in a
different quirk flag, so that it can be enabled for all the keyboards
but the Aluminium USB ones.
If the Numlock emulation is enabled for Aluminium USB keyboards, the
JKL and UIO keys become the numeric pad, and the rest of the keyboard
is disabled, included the key used to disable Numlock.
Additionally, these keyboard should not have a Numlock at all, as the
Numlock key is instead replaced by the 'Clear' key as usual for Apple
USB keyboards.
Signed-off-by: Diego 'Flameeyes' Petteno <flameeyes@gmail.com>
upstream commit: b1979a5fda7869a790f4fd83fb06c78498d26ba1
CR4 manipulation is not protected against interrupts and preemption,
but KVM uses smp_function_call to manipulate the X86_CR4_VMXE bit
either from the CPU hotplug code or from the kvm_init call.
We need to protect the CR4 manipulation from both interrupts and
preemption.
Original bug report: http://lkml.org/lkml/2008/5/7/48
Bugzilla entry: http://bugzilla.kernel.org/show_bug.cgi?id=10642
This is not a regression from 2.6.25, it's a long standing and hard to
trigger bug.
upstream commit: 6c7c6afbb8c0e60d32a563cae7c6889211e9d9d8
<linux/types.h> can't be used together with <sys/ustat.h> because they
both define struct ustat:
$ cat test.c
#include <sys/ustat.h>
#include <linux/types.h>
$ gcc -c test.c
In file included from test.c:2:
/usr/include/linux/types.h:165: error: redefinition of 'struct ustat'
has been reported a while ago to debian, but seems to have been
lost in cat fighting: http://bugs.debian.org/429064
Signed-off-by: maximilian attems <max@stro.at>
Cc: <stable@kernel.org>
[ This is a 2.6.25 backport of upstream changeset
28e6103665301ce60634e8a77f0b657c6cc099de with sparc32 build
fixes from Robert Reif ]
So, forever, we've had this ptrace_signal_deliver implementation
which tries to handle all of the nasties that can occur when the
debugger looks at a process about to take a signal. It's meant
to address all of these issues inside of the kernel so that the
debugger need not be mindful of such things.
Problem is, this doesn't work.
The idea was that we should do the syscall restart business first, so
that the debugger captures that state. Otherwise, if the debugger for
example saves the child's state, makes the child execute something
else, then restores the saved state, we won't handle the syscall
restart properly because we lose the "we're in a syscall" state.
The code here worked for most cases, but if the debugger actually
passes the signal through to the child unaltered, it's possible that
we would do a syscall restart when we shouldn't have.
In particular this breaks the case of debugging a process under a gdb
which is being debugged by yet another gdb. gdb uses sigsuspend
to wait for SIGCHLD of the inferior, but if gdb itself is being
debugged by a top-level gdb we get a ptrace_stop(). The top-level gdb
does a PTRACE_CONT with SIGCHLD to let the inferior gdb see the
signal. But ptrace_signal_deliver() assumed the debugger would cancel
out the signal and therefore did a syscall restart, because the return
error was ERESTARTNOHAND.
Fix this by simply making ptrace_signal_deliver() a nop, and providing
a way for the debugger to control system call restarting properly:
1) Report a "in syscall" software bit in regs->{tstate,psr}.
It is set early on in trap entry to a system call and is fully
visible to the debugger via ptrace() and regsets.
2) Test this bit right before doing a syscall restart. We have
to do a final recheck right after get_signal_to_deliver() in
case the debugger cleared the bit during ptrace_stop().
3) Clear the bit in trap return so we don't accidently try to set
that bit in the real register.
As a result we also get a ptrace_{is,clear}_syscall() for sparc32 just
like sparc64 has.
M68K has this same exact bug, and is now the only other user of the
ptrace_signal_deliver hook. It needs to be fixed in the same exact
way as sparc.
Just like mmap, we need to validate address ranges regardless
of MAP_FIXED.
sparc{,64}_mmap_check()'s flag argument is unused, remove.
Based upon a report and preliminary patch by
Jan Lieskovsky <jlieskov@redhat.com>
[ Upstream commit: 986bef854fab44012df678a5b51817d5274d3ca1 ]
Forever we had a PTRACE_SUNOS_DETACH which was unconditionally
recognized, regardless of the personality of the process.
Unfortunately, this value is what ended up in the GLIBC sys/ptrace.h
header file on sparc as PTRACE_DETACH and PT_DETACH.
So continue to recognize this old value. Luckily, it doesn't conflict
with anything we actually care about.
commit 5c3a121d52b30a1e53cdaa802fa1965fcd243164 upstream
System topology on intel based system needs to be exported
for non-numa case as well.
All parts of asm-i386/topology.h has come under
#ifdef CONFIG_NUMA after the merge to asm-x86/topology.h
/sys/devices/system/cpu/cpu?/topology/* is populated based on
ENABLE_TOPO_DEFINES
The sysfs cpu topology is not being populated on my dual socket
dual core xeon 5160 processor based (x86 32 bit) system.
CONFIG_NUMA is not set in my case yet the topology is relevant
and useful.
irqbalance daemon application depends on topology to build the
cpus and package list and it fails on Fedora9 beta since the
sysfs topology was not being populated in the 2.6.25 kernel.
I am not sure if it was intentional to not define ENABLE_TOPO_DEFINES
for non-numa systems.
This fix has been tested on the above mentioned dual core, dual socket
system.
Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
[NETFILTER]: nf_conntrack: padding breaks conntrack hash on ARM
Upstream commit 443a70d50:
commit 0794935e "[NETFILTER]: nf_conntrack: optimize hash_conntrack()"
results in ARM platforms hashing uninitialised padding. This padding
doesn't exist on other architectures.
Fix this by replacing NF_CT_TUPLE_U_BLANK() with memset() to ensure
everything is initialised. There were only 4 bytes that
NF_CT_TUPLE_U_BLANK() wasn't clearing anyway (or 12 bytes on ARM).
Signed-off-by: Philip Craig <philipc@snapgear.com>
[ Upstream commit: 2ad17defd596ca7e8ba782d5fc6950ee0e99513c ]
Fixes bug http://bugzilla.kernel.org/show_bug.cgi?id=10556
where conn templates with protocol=IPPROTO_IP can oops backup box.
Result from ip_vs_proto_get() should be checked because
protocol value can be invalid or unsupported in backup. But
for valid message we should not fail for templates which use
IPPROTO_IP. Also, add checks to validate message limits and
connection state. Show state NONE for templates using IPPROTO_IP.
Fix tested and confirmed by L0op8ack <l0op8ack@hotmail.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
[CRYPTO] api: Fix scatterwalk_sg_chain
[ Upstream commit: 8ec970d8561abb5645d4602433b772e268c96d05 ]
When I backed out of using the generic sg chaining (as it isn't currently
portable) and introduced scatterwalk_sg_chain/scatterwalk_sg_next I left
out the sg_is_last check in the latter. This causes it to potentially
dereference beyond the end of the sg array.
As most uses of scatterwalk_sg_next are bound by an overall length, this
only affected the chaining code in authenc and eseqiv. Thanks to Patrick
McHardy for identifying this problem.
This patch also clears the "last" bit on the head of the chained list as
it's no longer last. This also went missing in scatterwalk_sg_chain and
is present in sg_chain.
commit d5dee5c395062a55236318ac4eec1f4ebb9de6db upstream
Quota files cannot have tails because quota_write and quota_read functions do
not support them. So far when quota files did have tail, we just refused to
turn quotas on it. Sadly this check has been wrong and so there are now plenty
installations where quota files don't have NOTAIL flag set and so now after
fixing the check, they suddently fail to turn quotas on. Since it's easy to
unpack the tail from kernel, do this from reiserfs_quota_on() which solves the
problem and is generally nicer to users anyway.
Reported-by: <urhausen@urifabi.net>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Chris Mason <chris.mason@oracle.com>
[ Upstream commit: c5d18e984a313adf5a1a4ae69e0b1d93cf410229 ]
As it stands it's impossible to use any authentication algorithms
with an ID above 31 portably. It just happens to work on x86 but
fails miserably on ppc64.
The reason is that we're using a bit mask to check the algorithm
ID but the mask is only 32 bits wide.
After looking at how this is used in the field, I have concluded
that in the long term we should phase out state matching by IDs
because this is made superfluous by the reqid feature. For current
applications, the best solution IMHO is to allow all algorithms when
the bit masks are all ~0.
The following patch does exactly that.
This bug was identified by IBM when testing on the ppc64 platform
using the NULL authentication algorithm which has an ID of 251.
[ Upstream commit: c9c1014b2bd014c7ec037bbb6f58818162fdb265 ]
ASSERT_RTNL uses mutex_trylock to test whether the rtnl_mutex is
held. This bogus warnings when running in atomic context, which
f.e. happens when adding secondary unicast addresses through
macvlan or vlan or when synchronizing multicast addresses from
wireless devices.
Mid-term we might want to consider moving all address updates
to process context since the locking seems overly complicated,
for now just fix the bogus warning by changing ASSERT_RTNL to
use mutex_is_locked().
[ Upstream commit: dd9e0dda66ba38a2ddd1405ac279894260dc5c36 ]
This change is necessary to allow cwnd to grow during persistent
reordering. Cwnd moderation is applied when in the disorder state
and an ack that fills the hole comes in. If the hole was greater
than 3 packets, but less than tp->reordering, cwnd will shrink when
it should not have.
Signed-off-by: John Heffner <jheffner@napa.none>
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
it821x: do not describe noraid parameter with its value
Pb1200/DBAu1200: fix bad IDE resource size
Au1200: IDE driver build fix
Au1200: kill IDE driver function prototypes
avr32 mustn't select HAVE_IDE
The header files for the Pb1200/DBAu1200 boards have wrong definition for the
IDE interface's decoded range length -- it should be 512 bytes according to
what the IDE driver does. In addition, the IDE platform device claims 1 byte
too many for its memory resource -- fix the platform code and the IDE driver
in accordance.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Fix these warnings emitted when compiling drivers/ide/mips/au1xxx-ide.c:
include/asm/mach-au1x00/au1xxx_ide.h:137: warning: 'auide_tune_drive' declared
`static' but never defined
include/asm/mach-au1x00/au1xxx_ide.h:138: warning: 'auide_tune_chipset' declared
by wiping out the whole "function prototyping" section from the header file
<asm-mips/mach-au1x00/au1xxx_ide.h> as it mostly declared functions that are
already dead in the IDE driver; move the only useful prototype into the driver.
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: update git url for blktrace
io context: increment task attachment count in ioc_task_link()
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
[TCP]: Add return value indication to tcp_prune_ofo_queue().
PS3: gelic: fix the oops on the broken IE returned from the hypervisor
b43legacy: fix DMA mapping leakage
mac80211: remove message on receiving unexpected unencrypted frames
Update rt2x00 MAINTAINERS entry
Add rfkill to MAINTAINERS file
rfkill: Fix device type check when toggling states
b43legacy: Fix usage of struct device used for DMAing
ssb: Fix usage of struct device used for DMAing
MAINTAINERS: move to generic repository for iwlwifi
b43legacy: fix initvals loading on bcm4303
rtl8187: Add missing priv->vif assignments
netconsole: only set CON_PRINTBUFFER if the user specifies a netconsole
[CAN]: Update documentation of struct sockaddr_can
MAINTAINERS: isdn4linux@listserv.isdn4linux.de is subscribers-only
[TCP]: Fix never pruned tcp out-of-order queue.
[NET_SCHED] sch_api: fix qdisc_tree_decrease_qlen() loop
The THERMAL_MAX_TRIPS value is set to 10. It is too few for the Compaq AP550
machine which has 12 trip points.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
The SPI core now expects num_chipselect to be set correctly as due to added
checks on the chip being selected before an transfer is allowed. This patch
adds a num_cs field to the platform data which needs to be set correctly
before adding the SPI platform device.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
mb_cache_entry_alloc() was allocating cache entries with GFP_KERNEL. But
filesystems are calling this function while holding xattr_sem so possible
recursion into the fs violates locking ordering of xattr_sem and transaction
start / i_mutex for ext2-4. Change mb_cache_entry_alloc() so that filesystems
can specify desired gfp mask and use GFP_NOFS from all of them.
Reported-by: Dave Jones <davej@redhat.com>
Cc: <linux-ext4@vger.kernel.org>
This patch fixes this error:
In file included from /home/wangcong/projects/linux-2.6/arch/um/kernel/smp.c:9:
include2/asm/tlb.h: In function `tlb_remove_page':
include2/asm/tlb.h:101: error: implicit declaration of function `page_cache_release'
And since including <linux/pagemap.h> in <linux/swap.h> will break sparc,
we add this #include in uml's own header.
Acked-by: Jeff Dike <jdike@addtoit.com>
Signed-off-by: WANG Cong <wangcong@zeuux.org>
This fixes DMA on architectures where DMA is nontrivial, like PPC64.
We must use the host-device's (PCI) struct device for any DMA
operation instead of the SSB device. For this we add a new
struct device pointer to the SSB device structure that will always
point to the right device for DMAing.
Without this patch b43 and b44 drivers won't work on complex-DMA
architectures, that for example need dev->archdata for DMA operations.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Thanks to Nikanth Karthikesan <knikanth@suse.de> for reporting this.
