commit e285d5bfb7e9785d289663baef252dd315e171f8 upstream.
According to ETSI TS 102 622 specification chapter 4.4 pipe identifier
is 7 bits long which allows for 128 unique pipe IDs. Because
NFC_HCI_MAX_PIPES is used as the number of pipes supported and not
as the max pipe ID, its value should be 128 instead of 127.
nfc_hci_recv_from_llc extracts pipe ID from packet header using
NFC_HCI_FRAGMENT(0x7F) mask which allows for pipe ID value of 127.
Same happens when NCI_HCP_MSG_GET_PIPE() is being used. With
pipes array having only 127 elements and pipe ID of 127 the OOB memory
access will result.
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Allen Pais <allen.pais@oracle.com>
Suggested-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Suren Baghdasaryan <surenb@google.com>
Cc: stable <stable@vger.kernel.org>
commit 7a9cdebdcc17e426fb5287e4a82db1dfe86339b2 upstream.
Jann Horn points out that the vmacache_flush_all() function is not only
potentially expensive, it's buggy too. It also happens to be entirely
unnecessary, because the sequence number overflow case can be avoided by
simply making the sequence number be 64-bit. That doesn't even grow the
data structures in question, because the other adjacent fields are
already 64-bit.
So simplify the whole thing by just making the sequence number overflow
case go away entirely, which gets rid of all the complications and makes
the code faster too. Win-win.
[ Oleg Nesterov points out that the VMACACHE_FULL_FLUSHES statistics
also just goes away entirely with this ]
Reported-by: Jann Horn <jannh@google.com>
Suggested-by: Will Deacon <will.deacon@arm.com>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Cc: stable@kernel.org
[ Upstream commit d89d41556141a527030a15233135ba622ba3350d ]
Android's header sanitization tool chokes on static inline functions having a
trailing semicolon, leading to an incorrectly parsed header file. While the
tool should obviously be fixed, also fix the header files for the two affected
functions: ethtool_get_flow_spec_ring() and ethtool_get_flow_spec_ring_vf().
Fixes: 8cf6f497de40 ("ethtool: Add helper routines to pass vf to rx_flow_spec")
Reporetd-by: Blair Prescott <blair.prescott@broadcom.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit 8ef4227615e158faa4ee85a1d6466782f7e22f2f upstream.
A recent change to the mm code in:
87744ab3832b mm: fix cache mode tracking in vm_insert_mixed()
started enforcing checking the memory type against the registered list for
amixed pfn insertion mappings. It happens that the drm drivers for a number
of gpus relied on this being broken. Currently the driver only inserted
VRAM mappings into the tracking table when they came from the kernel,
and userspace mappings never landed in the table. This led to a regression
where all the mapping end up as UC instead of WC now.
I've considered a number of solutions but since this needs to be fixed
in fixes and not next, and some of the solutions were going to introduce
overhead that hadn't been there before I didn't consider them viable at
this stage. These mainly concerned hooking into the TTM io reserve APIs,
but these API have a bunch of fast paths I didn't want to unwind to add
this to.
The solution I've decided on is to add a new API like the arch_phys_wc
APIs (these would have worked but wc_del didn't take a range), and
use them from the drivers to add a WC compatible mapping to the table
for all VRAM on those GPUs. This means we can then create userspace
mapping that won't get degraded to UC.
v1.1: use CONFIG_X86_PAT + add some comments in io.h
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: x86@kernel.org
Cc: mcgrof@suse.com
Cc: Dan Williams <dan.j.williams@intel.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit bb24153a3f13dd0dbc1f8055ad97fe346d598f66 upstream.
The default delay 5 jiffies is too much when the kernel is compiled with
HZ=100 - it results in jumpy cursor in Xwindow.
In order to find out the optimal delay, I benchmarked the driver on
1280x720x30fps video. I found out that with HZ=1000, 10ms is acceptable,
but with HZ=250 or HZ=300, we need 4ms, so that the video is played
without any frame skips.
This patch changes the delay to this value.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 1c48db44924298ad0cb5a6386b88017539be8822 upstream.
PFSID should be used in the invalidation descriptor for flushing
device IOTLBs on SRIOV VFs.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Cc: "Ashok Raj" <ashok.raj@intel.com>
Cc: "Lu Baolu" <baolu.lu@linux.intel.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit 0f725561e168485eff7277d683405c05b192f537 upstream.
When SRIOV VF device IOTLB is invalidated, we need to provide
the PF source ID such that IOMMU hardware can gauge the depth
of invalidation queue which is shared among VFs. This is needed
when device invalidation throttle (DIT) capability is supported.
This patch adds bit definitions for checking and tracking PFSID.
commit 2afc9166f79b8f6da5f347f48515215ceee4ae37 upstream.
Introduce these two functions and export them such that the next patch
can add calls to these functions from the SCSI core.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: <stable@vger.kernel.org>
[ Upstream commit c133459765fae249ba482f62e12f987aec4376f0 ]
CC [M] drivers/net/ethernet/freescale/fman/fman.o
In file included from ../drivers/net/ethernet/freescale/fman/fman.c:35:
../include/linux/fsl/guts.h: In function 'guts_set_dmacr':
../include/linux/fsl/guts.h:165:2: error: implicit declaration of function 'clrsetbits_be32' [-Werror=implicit-function-declaration]
clrsetbits_be32(&guts->dmacr, 3 << shift, device << shift);
Cc: Madalin Bucur <madalin.bucur@nxp.com>
Cc: netdev@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
[ Upstream commit a69258f7aa2623e0930212f09c586fd06674ad79 ]
After fixing the way DCTCP tracking delayed ACKs, the delayed-ACK
related callbacks are no longer needed
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Lawrence Brakmo <brakmo@fb.com>
[ Upstream commit 9ce7bc036ae4cfe3393232c86e9e1fea2153c237 ]
It is a waste of memory to use a full "struct netns_sysctl_ipv6"
while only one pointer is really used, considering netns_sysctl_ipv6
keeps growing.
Also, since "struct netns_frags" has cache line alignment,
it is better to move the frags_hdr pointer outside, otherwise
we spend a full cache line for this pointer.
This saves 192 bytes of memory per netns.
Fixes: c038a767cd69 ("ipv6: add a new namespace for nf_conntrack_reasm")
[ Upstream commit 455f05ecd2b219e9a216050796d30c830d9bc393 ]
syzbot reported that we reinitialize an active delayed
work in vsock_stream_connect():
ODEBUG: init active (active state 0) object type: timer_list hint:
delayed_work_timer_fn+0x0/0x90 kernel/workqueue.c:1414
WARNING: CPU: 1 PID: 11518 at lib/debugobjects.c:329
debug_print_object+0x16a/0x210 lib/debugobjects.c:326
The pattern is apparently wrong, we should only initialize
the dealyed work once and could repeatly schedule it. So we
have to move out the initializations to allocation side.
And to avoid confusion, we can split the shared dwork
into two, instead of re-using the same one.
Fixes: d021c344051a ("VSOCK: Introduce VM Sockets")
Reported-by: <syzbot+8a9b1bd330476a4f3db6@syzkaller.appspotmail.com>
Cc: Andy king <acking@vmware.com>
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Jorgen Hansen <jhansen@vmware.com>
[ Upstream commit 0dcb82254d65f72333aa50ad626d1e9665ad093b ]
llc_sap_put() decreases the refcnt before deleting sap
from the global list. Therefore, there is a chance
llc_sap_find() could find a sap with zero refcnt
in this global list.
Close this race condition by checking if refcnt is zero
or not in llc_sap_find(), if it is zero then it is being
removed so we can just treat it as gone.
Reported-by: <syzbot+278893f3f7803871f7ce@syzkaller.appspotmail.com>
commit 785a19f9d1dd8a4ab2d0633be4656653bd3de1fc upstream.
The following kernel panic was observed on ARM64 platform due to a stale
TLB entry.
1. ioremap with 4K size, a valid pte page table is set.
2. iounmap it, its pte entry is set to 0.
3. ioremap the same address with 2M size, update its pmd entry with
a new value.
4. CPU may hit an exception because the old pmd entry is still in TLB,
which leads to a kernel panic.
Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page
table") has addressed this panic by falling to pte mappings in the above
case on ARM64.
To support pmd mappings in all cases, TLB purge needs to be performed
in this case on ARM64.
Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page()
so that TLB purge can be added later in seprate patches.
[toshi.kani@hpe.com: merge changes, rewrite patch description]
Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces")
Signed-off-by: Chintan Pandya <cpandya@codeaurora.org>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: mhocko@suse.com
Cc: akpm@linux-foundation.org
Cc: hpa@zytor.com
Cc: linux-mm@kvack.org
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Michal Hocko <mhocko@suse.com>
Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com
commit bb29648102335586e9a66289a1d98a0cb392b6e5 upstream.
syzbot reported a crash in vmac_final() when multiple threads
concurrently use the same "vmac(aes)" transform through AF_ALG. The bug
is pretty fundamental: the VMAC template doesn't separate per-request
state from per-tfm (per-key) state like the other hash algorithms do,
but rather stores it all in the tfm context. That's wrong.
Also, vmac_final() incorrectly zeroes most of the state including the
derived keys and cached pseudorandom pad. Therefore, only the first
VMAC invocation with a given key calculates the correct digest.
Fix these bugs by splitting the per-tfm state from the per-request state
and using the proper init/update/final sequencing for requests.
Reproducer for the crash:
#include <linux/if_alg.h>
#include <sys/socket.h>
#include <unistd.h>
int main()
int fd;
struct sockaddr_alg addr = {
.salg_type = "hash",
.salg_name = "vmac(aes)",
char buf[256] = { 0 };
fd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(fd, (void *)&addr, sizeof(addr));
setsockopt(fd, SOL_ALG, ALG_SET_KEY, buf, 16);
fork();
fd = accept(fd, NULL, NULL);
for (;;)
write(fd, buf, 256);
The immediate cause of the crash is that vmac_ctx_t.partial_size exceeds
VMAC_NHBYTES, causing vmac_final() to memset() a negative length.
Reported-by: syzbot+264bca3a6e8d645550d3@syzkaller.appspotmail.com
Fixes: f1939f7c5645 ("crypto: vmac - New hash algorithm for intel_txt support")
Cc: <stable@vger.kernel.org> # v2.6.32+
commit 6c26fcd2abfe0a56bbd95271fce02df2896cfd24 upstream.
pfn_modify_allowed() and arch_has_pfn_modify_check() are outside of the
!__ASSEMBLY__ section in include/asm-generic/pgtable.h, which confuses
assembler on archs that don't have __HAVE_ARCH_PFN_MODIFY_ALLOWED (e.g.
ia64) and breaks build:
include/asm-generic/pgtable.h: Assembler messages:
include/asm-generic/pgtable.h:538: Error: Unknown opcode `static inline bool pfn_modify_allowed(unsigned long pfn,pgprot_t prot)'
include/asm-generic/pgtable.h:540: Error: Unknown opcode `return true'
include/asm-generic/pgtable.h:543: Error: Unknown opcode `static inline bool arch_has_pfn_modify_check(void)'
include/asm-generic/pgtable.h:545: Error: Unknown opcode `return false'
arch/ia64/kernel/entry.S:69: Error: `mov' does not fit into bundle
Move those two static inlines into the !__ASSEMBLY__ section so that they
don't confuse the asm build pass.
Fixes: 42e4089c7890 ("x86/speculation/l1tf: Disallow non privileged high MMIO PROT_NONE mappings")
[groeck: Context changes]
commit 377eeaa8e11fe815b1d07c81c4a0e2843a8c15eb upstream
For the L1TF workaround its necessary to limit the swap file size to below
MAX_PA/2, so that the higher bits of the swap offset inverted never point
to valid memory.
Add a mechanism for the architecture to override the swap file size check
in swapfile.c and add a x86 specific max swapfile check function that
enforces that limit.
The check is only enabled if the CPU is vulnerable to L1TF.
In VMs with 42bit MAX_PA the typical limit is 2TB now, on a native system
with 46bit PA it is 32TB. The limit is only per individual swap file, so
it's always possible to exceed these limits with multiple swap files or
partitions.
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Dave Hansen <dave.hansen@intel.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit 42e4089c7890725fcd329999252dc489b72f2921 upstream
For L1TF PROT_NONE mappings are protected by inverting the PFN in the page
table entry. This sets the high bits in the CPU's address space, thus
making sure to point to not point an unmapped entry to valid cached memory.
Some server system BIOSes put the MMIO mappings high up in the physical
address space. If such an high mapping was mapped to unprivileged users
they could attack low memory by setting such a mapping to PROT_NONE. This
could happen through a special device driver which is not access
protected. Normal /dev/mem is of course access protected.
To avoid this forbid PROT_NONE mappings or mprotect for high MMIO mappings.
Valid page mappings are allowed because the system is then unsafe anyways.
It's not expected that users commonly use PROT_NONE on MMIO. But to
minimize any impact this is only enforced if the mapping actually refers to
a high MMIO address (defined as the MAX_PA-1 bit being set), and also skip
the check for root.
For mmaps this is straight forward and can be handled in vm_insert_pfn and
in remap_pfn_range().
For mprotect it's a bit trickier. At the point where the actual PTEs are
accessed a lot of state has been changed and it would be difficult to undo
on an error. Since this is a uncommon case use a separate early page talk
walk pass for MMIO PROT_NONE mappings that checks for this condition
early. For non MMIO and non PROT_NONE there are no changes.
[dwmw2: Backport to 4.9]
[groeck: Backport to 4.4]
commit 1745cbc5d0dee0749a6bc0ea8e872c5db0074061 upstream
The x86 vvar vma contains pages with differing cacheability
flags. x86 currently implements this by manually inserting all
the ptes using (io_)remap_pfn_range when the vma is set up.
x86 wants to move to using .fault with VM_FAULT_NOPAGE to set up
the mappings as needed. The correct API to use to insert a pfn
in .fault is vm_insert_pfn(), but vm_insert_pfn() can't override the
vma's cache mode, and the HPET page in particular needs to be
uncached despite the fact that the rest of the VMA is cached.
Add vm_insert_pfn_prot() to support varying cacheability within
the same non-COW VMA in a more sane manner.
x86 could alternatively use multiple VMAs, but that's messy,
would break CRIU, and would create unnecessary VMAs that would
waste memory.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Link: http://lkml.kernel.org/r/d2938d1eb37be7a5e4f86182db646551f11e45aa.1451446564.git.luto@kernel.org
commit 17dbca119312b4e8173d4e25ff64262119fcef38 upstream
L1TF core kernel workarounds are cheap and normally always enabled, However
they still should be reported in sysfs if the system is vulnerable or
mitigated. Add the necessary CPU feature/bug bits.
- Extend the existing checks for Meltdowns to determine if the system is
vulnerable. All CPUs which are not vulnerable to Meltdown are also not
vulnerable to L1TF
- Check for 32bit non PAE and emit a warning as there is no practical way
for mitigation due to the limited physical address bits
- If the system has more than MAX_PA/2 physical memory the invert page
workarounds don't protect the system against the L1TF attack anymore,
because an inverted physical address will also point to valid
memory. Print a warning in this case and report that the system is
vulnerable.
Add a function which returns the PFN limit for the L1TF mitigation, which
will be used in follow up patches for sanity and range checks.
[ tglx: Renamed the CPU feature bit to L1TF_PTEINV ]
[ dwmw2: Backport to 4.9 (cpufeatures.h, E820) ]
commit 08bb558ac11ab944e0539e78619d7b4c356278bd upstream.
Make the MR writability flags check, which is performed in umem.c,
a static inline function in file ib_verbs.h
This allows the function to be used by low-level infiniband drivers.
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit e01e80634ecdde1dd113ac43b3adad21b47f3957 upstream.
One of the classes of kernel stack content leaks[1] is exposing the
contents of prior heap or stack contents when a new process stack is
allocated. Normally, those stacks are not zeroed, and the old contents
remain in place. In the face of stack content exposure flaws, those
contents can leak to userspace.
Fixing this will make the kernel no longer vulnerable to these flaws, as
the stack will be wiped each time a stack is assigned to a new process.
There's not a meaningful change in runtime performance; it almost looks
like it provides a benefit.
Performing back-to-back kernel builds before:
Run times: 157.86 157.09 158.90 160.94 160.80
Mean: 159.12
Std Dev: 1.54
and after:
Run times: 159.31 157.34 156.71 158.15 160.81
Mean: 158.46
Std Dev: 1.46
Instead of making this a build or runtime config, Andy Lutomirski
recommended this just be enabled by default.
[1] A noisy search for many kinds of stack content leaks can be seen here:
https://cve.mitre.org/cgi-bin/cvekey.cgi?keyword=linux+kernel+stack+leak
I did some more with perf and cycle counts on running 100,000 execs of
/bin/true.
before:
Cycles: 218858861551 218853036130 214727610969 227656844122 224980542841
Mean: 221015379122.60
Std Dev: 4662486552.47
after:
Cycles: 213868945060 213119275204 211820169456 224426673259 225489986348
Mean: 217745009865.40
Std Dev: 5935559279.99
It continues to look like it's faster, though the deviation is rather
wide, but I'm not sure what I could do that would be less noisy. I'm
open to ideas!
Link: http://lkml.kernel.org/r/20180221021659.GA37073@beast
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Cc: Mel Gorman <mgorman@techsingularity.net>
[ Srivatsa: Backported to 4.4.y ]
Signed-off-by: Srivatsa S. Bhat <srivatsa@csail.mit.edu>
Reviewed-by: Srinidhi Rao <srinidhir@vmware.com>
commit 73c8d8945505acdcbae137c2e00a1232e0be709f upstream.
Maintain the tracing on/off setting of the ring_buffer when switching
to the trace buffer snapshot.
Taking a snapshot is done by swapping the backup ring buffer
(max_tr_buffer). But since the tracing on/off setting is defined
by the ring buffer, when swapping it, the tracing on/off setting
can also be changed. This causes a strange result like below:
/sys/kernel/debug/tracing # cat tracing_on
1
/sys/kernel/debug/tracing # echo 0 > tracing_on
0
/sys/kernel/debug/tracing # echo 1 > snapshot
1
0
We don't touch tracing_on, but snapshot changes tracing_on
setting each time. This is an anomaly, because user doesn't know
that each "ring_buffer" stores its own tracing-enable state and
the snapshot is done by swapping ring buffers.
Link: http://lkml.kernel.org/r/153149929558.11274.11730609978254724394.stgit@devbox
Cc: Shuah Khan <shuah@kernel.org>
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Hiraku Toyooka <hiraku.toyooka@cybertrust.co.jp>
Fixes: debdd57f5145 ("tracing: Make a snapshot feature available from userspace")
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
[ Updated commit log and comment in the code ]
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit 9a9c9b51e54618861420093ae6e9b50a961914c5 ]
We want to add finer control of the number of ACK packets sent after
ECN events.
This patch is not changing current behavior, it only enables following
change.
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit 4f212e40468650e220c1770876c7f25b8e0c1ff5 ]
To comply with eDP1.4a this bit should be set when enabling PSR2.
Signed-off-by: José Roberto de Souza <jose.souza@intel.com>
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180328223046.16125-1-jose.souza@intel.com
[ Upstream commit 1c74d5c0de0c2cc29fef97a19251da2ad6f579bd ]
Currently we are enabling handling of interrupts specific to Tegra124+
which happen to overlap with previous generations. Let's specify
interrupts mask per SoC generation for consistency and in a preparation
of squashing of Tegra20 driver into the common one that will enable
handling of GART faults which may be undesirable by newer generations.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit 9c4a121e82634aa000a702c98cd6f05b27d6e186 ]
Add support for the BCM43364 chipset via an SDIO interface, as used in
e.g. the Murata 1FX module.
The BCM43364 uses the same firmware as the BCM43430 (which is already
included), the only difference is the omission of Bluetooth.
However, the SDIO_ID for the BCM43364 is 02D0:A9A4, giving it a MODALIAS
of sdio:c00v02D0dA9A4, which doesn't get recognised and hence doesn't
load the brcmfmac module. Adding the 'A9A4' ID in the appropriate place
triggers the brcmfmac driver to load, and then correctly use the
firmware file 'brcmfmac43430-sdio.bin'.
Signed-off-by: Sean Lanigan <sean@lano.id.au>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
[ Upstream commit 8a22a3e1e768c309b718f99bd86f9f25a453e0dc ]
Inclusion of include/dma-iommu.h when CONFIG_IOMMU_DMA is not selected
results in the following splat:
In file included from drivers/irqchip/irq-gic-v3-mbi.c:20:0:
./include/linux/dma-iommu.h:95:69: error: unknown type name ‘dma_addr_t’
static inline int iommu_get_msi_cookie(struct iommu_domain *domain, dma_addr_t base)
./include/linux/dma-iommu.h:108:74: warning: ‘struct list_head’ declared inside parameter list will not be visible outside of this definition or declaration
static inline void iommu_dma_get_resv_regions(struct device *dev, struct list_head *list)
scripts/Makefile.build:312: recipe for target 'drivers/irqchip/irq-gic-v3-mbi.o' failed
Fix it by including linux/types.h.
Cc: Rob Herring <robh@kernel.org>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Cc: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Link: https://lkml.kernel.org/r/20180508121438.11301-5-marc.zyngier@arm.com
[ Upstream commit bd975e691486ba52790ba23cc9b4fecab7bc0d31 ]
When listing sets with timeout support, there's a probability that
just timing out entries with "0" timeout value is listed/saved.
However when restoring the saved list, the zero timeout value means
permanent elelements.
The new behaviour is that timing out entries are listed with "timeout 1"
instead of zero.
Fixes netfilter bugzilla #1258.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
[ Upstream commit a0496ef2c23b3b180902dd185d0d63ccbc624cf8 ]
Per DCTCP RFC8257 (Section 3.2) the ACK reflecting the CE status change
has to be sent immediately so the sender can respond quickly:
""" When receiving packets, the CE codepoint MUST be processed as follows:
1. If the CE codepoint is set and DCTCP.CE is false, set DCTCP.CE to
true and send an immediate ACK.
2. If the CE codepoint is not set and DCTCP.CE is true, set DCTCP.CE
to false and send an immediate ACK.
Previously DCTCP implementation may continue to delay the ACK. This
patch fixes that to implement the RFC by forcing an immediate ACK.
Tested with this packetdrill script provided by Larry Brakmo
0.000 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
0.000 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
0.000 setsockopt(3, SOL_TCP, TCP_CONGESTION, "dctcp", 5) = 0
0.000 bind(3, ..., ...) = 0
0.000 listen(3, 1) = 0
0.100 < [ect0] SEW 0:0(0) win 32792 <mss 1000,sackOK,nop,nop,nop,wscale 7>
0.100 > SE. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK,nop,wscale 8>
0.110 < [ect0] . 1:1(0) ack 1 win 257
0.200 accept(3, ..., ...) = 4
+0 setsockopt(4, SOL_SOCKET, SO_DEBUG, [1], 4) = 0
0.200 < [ect0] . 1:1001(1000) ack 1 win 257
0.200 > [ect01] . 1:1(0) ack 1001
0.200 write(4, ..., 1) = 1
0.200 > [ect01] P. 1:2(1) ack 1001
0.200 < [ect0] . 1001:2001(1000) ack 2 win 257
+0.005 < [ce] . 2001:3001(1000) ack 2 win 257
+0.000 > [ect01] . 2:2(0) ack 2001
// Previously the ACK below would be delayed by 40ms
+0.000 > [ect01] E. 2:2(0) ack 3001
+0.500 < F. 9501:9501(0) ack 4 win 257
[ Upstream commit 27cde44a259c380a3c09066fc4b42de7dde9b1ad ]
Currently when a DCTCP receiver delays an ACK and receive a
data packet with a different CE mark from the previous one's, it
sends two immediate ACKs acking previous and latest sequences
respectly (for ECN accounting).
Previously sending the first ACK may mark off the delayed ACK timer
(tcp_event_ack_sent). This may subsequently prevent sending the
second ACK to acknowledge the latest sequence (tcp_ack_snd_check).
The culprit is that tcp_send_ack() assumes it always acknowleges
the latest sequence, which is not true for the first special ACK.
The fix is to not make the assumption in tcp_send_ack and check the
actual ack sequence before cancelling the delayed ACK. Further it's
safer to pass the ack sequence number as a local variable into
tcp_send_ack routine, instead of intercepting tp->rcv_nxt to avoid
future bugs like this.
Reported-by: Neal Cardwell <ncardwell@google.com>
commit 8bf37d8c067bb7eb8e7c381bdadf9bd89182b6bc upstream
The migitation control is simpler to implement in architecture code as it
avoids the extra function call to check the mode. Aside of that having an
explicit seccomp enabled mode in the architecture mitigations would require
even more workarounds.
Move it into architecture code and provide a weak function in the seccomp
code. Remove the 'which' argument as this allows the architecture to decide
which mitigations are relevant for seccomp.
Reviewed-by: Matt Helsley (VMware) <matt.helsley@gmail.com>
Reviewed-by: Alexey Makhalov <amakhalov@vmware.com>
Reviewed-by: Bo Gan <ganb@vmware.com>
commit 00a02d0c502a06d15e07b857f8ff921e3e402675 upstream
If a seccomp user is not interested in Speculative Store Bypass mitigation
by default, it can set the new SECCOMP_FILTER_FLAG_SPEC_ALLOW flag when
adding filters.
commit 356e4bfff2c5489e016fdb925adbf12a1e3950ee upstream
For certain use cases it is desired to enforce mitigations so they cannot
be undone afterwards. That's important for loader stubs which want to
prevent a child from disabling the mitigation again. Will also be used for
seccomp(). The extra state preserving of the prctl state for SSB is a
preparatory step for EBPF dymanic speculation control.
commit 7bbf1373e228840bb0295a2ca26d548ef37f448e upstream
Adjust arch_prctl_get/set_spec_ctrl() to operate on tasks other than
current.
This is needed both for /proc/$pid/status queries and for seccomp (since
thread-syncing can trigger seccomp in non-current threads).
commit b617cfc858161140d69cc0b5cc211996b557a1c7 upstream
Add two new prctls to control aspects of speculation related vulnerabilites
and their mitigations to provide finer grained control over performance
impacting mitigations.
PR_GET_SPECULATION_CTRL returns the state of the speculation misfeature
which is selected with arg2 of prctl(2). The return value uses bit 0-2 with
the following meaning:
Bit Define Description
0 PR_SPEC_PRCTL Mitigation can be controlled per task by
PR_SET_SPECULATION_CTRL
1 PR_SPEC_ENABLE The speculation feature is enabled, mitigation is
disabled
2 PR_SPEC_DISABLE The speculation feature is disabled, mitigation is
enabled
If all bits are 0 the CPU is not affected by the speculation misfeature.
If PR_SPEC_PRCTL is set, then the per task control of the mitigation is
available. If not set, prctl(PR_SET_SPECULATION_CTRL) for the speculation
misfeature will fail.
PR_SET_SPECULATION_CTRL allows to control the speculation misfeature, which
is selected by arg2 of prctl(2) per task. arg3 is used to hand in the
control value, i.e. either PR_SPEC_ENABLE or PR_SPEC_DISABLE.
The common return values are:
EINVAL prctl is not implemented by the architecture or the unused prctl()
arguments are not 0
ENODEV arg2 is selecting a not supported speculation misfeature
PR_SET_SPECULATION_CTRL has these additional return values:
ERANGE arg3 is incorrect, i.e. it's not either PR_SPEC_ENABLE or PR_SPEC_DISABLE
ENXIO prctl control of the selected speculation misfeature is disabled
The first supported controlable speculation misfeature is
PR_SPEC_STORE_BYPASS. Add the define so this can be shared between
architectures.
Based on an initial patch from Tim Chen and mostly rewritten.
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit c456442cd3a59eeb1d60293c26cbe2ff2c4e42cf upstream
Add the sysfs file for the new vulerability. It does not do much except
show the words 'Vulnerable' for recent x86 cores.
Intel cores prior to family 6 are known not to be vulnerable, and so are
some Atoms and some Xeon Phi.
It assumes that older Cyrix, Centaur, etc. cores are immune.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
[ Upstream commit 8b7008620b8452728cadead460a36f64ed78c460 ]
The pfmemalloc flag indicates that the skb was allocated from
the PFMEMALLOC reserves, and the flag is currently copied on skb
copy and clone.
However, an skb copied from an skb flagged with pfmemalloc
wasn't necessarily allocated from PFMEMALLOC reserves, and on
the other hand an skb allocated that way might be copied from an
skb that wasn't.
So we should not copy the flag on skb copy, and rather decide
whether to allow an skb to be associated with sockets unrelated
to page reclaim depending only on how it was allocated.
Move the pfmemalloc flag before headers_start[0] using an
existing 1-bit hole, so that __copy_skb_header() doesn't copy
it.
When cloning, we'll now take care of this flag explicitly,
contravening to the warning comment of __skb_clone().
While at it, restore the newline usage introduced by commit
b19372273164 ("net: reorganize sk_buff for faster
__copy_skb_header()") to visually separate bytes used in
bitfields after headers_start[0], that was gone after commit
a9e419dc7be6 ("netfilter: merge ctinfo into nfct pointer storage
area"), and describe the pfmemalloc flag in the kernel-doc
structure comment.
This doesn't change the size of sk_buff or cacheline boundaries,
but consolidates the 15 bits hole before tc_index into a 2 bytes
hole before csum, that could now be filled more easily.
Reported-by: Patrick Talbert <ptalbert@redhat.com>
Fixes: c93bdd0e03e8 ("netvm: allow skb allocation to use PFMEMALLOC reserves")
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
[ Upstream commit 169dc027fb02492ea37a0575db6a658cf922b854 ]
The rol32 call is currently rotating hash but the rol'd value is
being discarded. I believe the current code is incorrect and hash
should be assigned the rotated value returned from rol32.
Thanks to David Lebrun for spotting this.
commit d03db2bc26f0e4a6849ad649a09c9c73fccdc656 upstream.
Functions marked extern inline do not emit an externally visible
function when the gnu89 C standard is used. Some KBUILD Makefiles
overwrite KBUILD_CFLAGS. This is an issue for GCC 5.1+ users as without
an explicit C standard specified, the default is gnu11. Since c99, the
semantics of extern inline have changed such that an externally visible
function is always emitted. This can lead to multiple definition errors
of extern inline functions at link time of compilation units whose build
files have removed an explicit C standard compiler flag for users of GCC
5.1+ or Clang.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Suggested-by: H. Peter Anvin <hpa@zytor.com>
Suggested-by: Joe Perches <joe@perches.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Acked-by: Juergen Gross <jgross@suse.com>
Cc: acme@redhat.com
Cc: akataria@vmware.com
Cc: andrea.parri@amarulasolutions.com
Cc: ard.biesheuvel@linaro.org
Cc: aryabinin@virtuozzo.com
Cc: astrachan@google.com
Cc: boris.ostrovsky@oracle.com
Cc: brijesh.singh@amd.com
Cc: caoj.fnst@cn.fujitsu.com
Cc: geert@linux-m68k.org
Cc: ghackmann@google.com
Cc: gregkh@linuxfoundation.org
Cc: jan.kiszka@siemens.com
Cc: jarkko.sakkinen@linux.intel.com
Cc: jpoimboe@redhat.com
Cc: keescook@google.com
Cc: kirill.shutemov@linux.intel.com
Cc: kstewart@linuxfoundation.org
Cc: linux-efi@vger.kernel.org
Cc: linux-kbuild@vger.kernel.org
Cc: manojgupta@google.com
Cc: mawilcox@microsoft.com
Cc: michal.lkml@markovi.net
Cc: mjg59@google.com
Cc: mka@chromium.org
Cc: pombredanne@nexb.com
Cc: rientjes@google.com
Cc: rostedt@goodmis.org
Cc: sedat.dilek@gmail.com
Cc: thomas.lendacky@amd.com
Cc: tstellar@redhat.com
Cc: tweek@google.com
Cc: virtualization@lists.linux-foundation.org
Cc: will.deacon@arm.com
Cc: yamada.masahiro@socionext.com
Link: http://lkml.kernel.org/r/20180621162324.36656-2-ndesaulniers@google.com
commit 9a04dbcfb33b4012d0ce8c0282f1e3ca694675b1 upstream.
The motivation for commit abb2ea7dfd82 ("compiler, clang: suppress
warning for unused static inline functions") was to suppress clang's
warnings about unused static inline functions.
For configs without CONFIG_OPTIMIZE_INLINING enabled, such as any non-x86
architecture, `inline' in the kernel implies that
__attribute__((always_inline)) is used.
Some code depends on that behavior, see
https://lkml.org/lkml/2017/6/13/918:
net/built-in.o: In function `__xchg_mb':
arch/arm64/include/asm/cmpxchg.h:99: undefined reference to `__compiletime_assert_99'
The full fix would be to identify these breakages and annotate the
functions with __always_inline instead of `inline'. But since we are
late in the 4.12-rc cycle, simply carry forward the forced inlining
behavior and work toward moving arm64, and other architectures, toward
CONFIG_OPTIMIZE_INLINING behavior.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1706261552200.1075@chino.kir.corp.google.com
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Sodagudi Prasad <psodagud@codeaurora.org>
Tested-by: Sodagudi Prasad <psodagud@codeaurora.org>
Tested-by: Matthias Kaehlcke <mka@chromium.org>
Cc: Mark Rutland <mark.rutland@arm.com>
commit 6d53cefb18e4646fb4bf62ccb6098fb3808486df upstream.
Commit abb2ea7dfd82 ("compiler, clang: suppress warning for unused
static inline functions") just caused more warnings due to re-defining
the 'inline' macro.
So undef it before re-defining it, and also add the 'notrace' attribute
like the gcc version that this is overriding does.
Maybe this makes clang happier.
commit abb2ea7dfd82451d85ce669b811310c05ab5ca46 upstream.
GCC explicitly does not warn for unused static inline functions for
-Wunused-function. The manual states:
Warn whenever a static function is declared but not defined or
a non-inline static function is unused.
Clang does warn for static inline functions that are unused.
It turns out that suppressing the warnings avoids potentially complex
#ifdef directives, which also reduces LOC.
Suppress the warning for clang.
commit 240630e61870e62e39a97225048f9945848fa5f5 upstream.
There have been several reports of LPM related hard freezes about once
a day on multiple Lenovo 50 series models. Strange enough these reports
where not disk model specific as LPM issues usually are and some users
with the exact same disk + laptop where seeing them while other users
where not seeing these issues.
It turns out that enabling LPM triggers a firmware bug somewhere, which
has been fixed in later BIOS versions.
This commit adds a new ahci_broken_lpm() function and a new ATA_FLAG_NO_LPM
for dealing with this.
The ahci_broken_lpm() function contains DMI match info for the 4 models
which are known to be affected by this and the DMI BIOS date field for
known good BIOS versions. If the BIOS date is older then the one in the
table LPM will be disabled and a warning will be printed.
Note the BIOS dates are for known good versions, some older versions may
work too, but we don't know for sure, the table is using dates from BIOS
versions for which users have confirmed that upgrading to that version
makes the problem go away.
Unfortunately I've been unable to get hold of the reporter who reported
that BIOS version 2.35 fixed the problems on the W541 for him. I've been
able to verify the DMI_SYS_VENDOR and DMI_PRODUCT_VERSION from an older
dmidecode, but I don't know the exact BIOS date as reported in the DMI.
Lenovo keeps a changelog with dates in their release notes, but the
dates there are the release dates not the build dates which are in DMI.
So I've chosen to set the date to which we compare to one day past the
release date of the 2.34 BIOS. I plan to fix this with a follow up
commit once I've the necessary info.
commit 082f2300cfa1a3d9d5221c38c5eba85d4ab98bd8 upstream.
Local random address needs to be updated before creating connection if
RPA from LE Direct Advertising Report was resolved in host. Otherwise
remote device might ignore connection request due to address mismatch.
This was affecting following qualification test cases:
GAP/CONN/SCEP/BV-03-C, GAP/CONN/GCEP/BV-05-C, GAP/CONN/DCEP/BV-05-C
Before patch:
< HCI Command: LE Set Random Address (0x08|0x0005) plen 6 #11350 [hci0] 84680.231216
Address: 56:BC:E8:24:11:68 (Resolvable)
Identity type: Random (0x01)
Identity: F2:F1:06:3D:9C:42 (Static)
> HCI Event: Command Complete (0x0e) plen 4 #11351 [hci0] 84680.246022
LE Set Random Address (0x08|0x0005) ncmd 1
Status: Success (0x00)
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #11352 [hci0] 84680.246417
Type: Passive (0x00)
Interval: 60.000 msec (0x0060)
Window: 30.000 msec (0x0030)
Own address type: Random (0x01)
Filter policy: Accept all advertisement, inc. directed unresolved RPA (0x02)
> HCI Event: Command Complete (0x0e) plen 4 #11353 [hci0] 84680.248854
LE Set Scan Parameters (0x08|0x000b) ncmd 1
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #11354 [hci0] 84680.249466
Scanning: Enabled (0x01)
Filter duplicates: Enabled (0x01)
> HCI Event: Command Complete (0x0e) plen 4 #11355 [hci0] 84680.253222
LE Set Scan Enable (0x08|0x000c) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 18 #11356 [hci0] 84680.458387
LE Direct Advertising Report (0x0b)
Num reports: 1
Event type: Connectable directed - ADV_DIRECT_IND (0x01)
Address type: Random (0x01)
Address: 53:38:DA:46:8C:45 (Resolvable)
Identity type: Public (0x00)
Identity: 11:22:33:44:55:66 (OUI 11-22-33)
Direct address type: Random (0x01)
Direct address: 7C:D6:76:8C:DF:82 (Resolvable)
RSSI: -74 dBm (0xb6)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #11357 [hci0] 84680.458737
Scanning: Disabled (0x00)
Filter duplicates: Disabled (0x00)
> HCI Event: Command Complete (0x0e) plen 4 #11358 [hci0] 84680.469982
< HCI Command: LE Create Connection (0x08|0x000d) plen 25 #11359 [hci0] 84680.470444
Scan interval: 60.000 msec (0x0060)
Scan window: 60.000 msec (0x0060)
Filter policy: White list is not used (0x00)
Peer address type: Random (0x01)
Peer address: 53:38:DA:46:8C:45 (Resolvable)
Min connection interval: 30.00 msec (0x0018)
Max connection interval: 50.00 msec (0x0028)
Connection latency: 0 (0x0000)
Supervision timeout: 420 msec (0x002a)
Min connection length: 0.000 msec (0x0000)
Max connection length: 0.000 msec (0x0000)
> HCI Event: Command Status (0x0f) plen 4 #11360 [hci0] 84680.474971
LE Create Connection (0x08|0x000d) ncmd 1
< HCI Command: LE Create Connection Cancel (0x08|0x000e) plen 0 #11361 [hci0] 84682.545385
> HCI Event: Command Complete (0x0e) plen 4 #11362 [hci0] 84682.551014
LE Create Connection Cancel (0x08|0x000e) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 19 #11363 [hci0] 84682.551074
LE Connection Complete (0x01)
Status: Unknown Connection Identifier (0x02)
Handle: 0
Role: Master (0x00)
Peer address type: Public (0x00)
Peer address: 00:00:00:00:00:00 (OUI 00-00-00)
Connection interval: 0.00 msec (0x0000)
Supervision timeout: 0 msec (0x0000)
Master clock accuracy: 0x00
After patch:
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #210 [hci0] 667.152459
> HCI Event: Command Complete (0x0e) plen 4 #211 [hci0] 667.153613
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #212 [hci0] 667.153704
> HCI Event: Command Complete (0x0e) plen 4 #213 [hci0] 667.154584
> HCI Event: LE Meta Event (0x3e) plen 18 #214 [hci0] 667.182619
Num reports: 1
Address: 50:52:D9:A6:48:A0 (Resolvable)
Direct address: 7C:C1:57:A5:B7:A8 (Resolvable)
Identity: F4:28:73:5D:38:B0 (Static)
RSSI: -70 dBm (0xba)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #215 [hci0] 667.182704
> HCI Event: Command Complete (0x0e) plen 4 #216 [hci0] 667.183599
< HCI Command: LE Set Random Address (0x08|0x0005) plen 6 #217 [hci0] 667.183645
Address: 7C:C1:57:A5:B7:A8 (Resolvable)
> HCI Event: Command Complete (0x0e) plen 4 #218 [hci0] 667.184590
< HCI Command: LE Create Connection (0x08|0x000d) plen 25 #219 [hci0] 667.184613
Peer address: 50:52:D9:A6:48:A0 (Resolvable)
> HCI Event: Command Status (0x0f) plen 4 #220 [hci0] 667.186558
> HCI Event: LE Meta Event (0x3e) plen 19 #221 [hci0] 667.485824
Handle: 0
Role: Master (0x00)
Connection interval: 50.00 msec (0x0028)
Master clock accuracy: 0x07
@ MGMT Event: Device Connected (0x000b) plen 13 {0x0002} [hci0] 667.485996
LE Address: 11:22:33:44:55:66 (OUI 11-22-33)
Flags: 0x00000000
Data length: 0
Signed-off-by: Szymon Janc <szymon.janc@codecoup.pl>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 15bfd21fbc5d35834b9ea383dc458a1f0c9e3434 upstream.
A device may have boundary restrictions where the number of sectors
between boundaries exceeds its max transfer size. In this case, we need
to cap the max size to the smaller of the two limits.
Reported-by: Jitendra Bhivare <jitendra.bhivare@broadcom.com>
Tested-by: Jitendra Bhivare <jitendra.bhivare@broadcom.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Keith Busch <keith.busch@intel.com>
commit c043ec1ca5baae63726aae32abbe003192bc6eec upstream.
Currently, we use int for buffer length and bytes_per_datum. However,
kfifo uses unsigned int for length and size_t for element size. We need
to make sure these matches or we will have bugs related to overflow (in
the range between INT_MAX and UINT_MAX for length, for example).
In addition, set_bytes_per_datum uses size_t while bytes_per_datum is an
int, which would cause bugs for large values of bytes_per_datum.
Change buffer length to use unsigned int and bytes_per_datum to use
size_t.
Signed-off-by: Martin Kelly <mkelly@xevo.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
[bwh: Backported to 4.4:
- Drop change to iio_dma_buffer_set_length()
- Adjust filename, context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 2026d35741f2c3ece73c11eb7e4a15d7c2df9ebe upstream.
The function __builtin_expect returns long type (see the gcc
documentation), and so do macros likely and unlikely. Unfortunatelly, when
CONFIG_PROFILE_ANNOTATED_BRANCHES is selected, the macros likely and
unlikely expand to __branch_check__ and __branch_check__ truncates the
long type to int. This unintended truncation may cause bugs in various
kernel code (we found a bug in dm-writecache because of it), so it's
better to fix __branch_check__ to return long.
Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1805300818140.24812@file01.intranet.prod.int.rdu2.redhat.com
Fixes: 1f0d69a9fc815 ("tracing: profile likely and unlikely annotations")
commit 0cc3b0ec23ce4c69e1e890ed2b8d2fa932b14aad upstream.
We have a MAX_LFS_FILESIZE macro that is meant to be filled in by
filesystems (and other IO targets) that know they are 64-bit clean and
don't have any 32-bit limits in their IO path.
It turns out that our 32-bit value for that limit was bogus. On 32-bit,
the VM layer is limited by the page cache to only 32-bit index values,
but our logic for that was confusing and actually wrong. We used to
define that value to
(((loff_t)PAGE_SIZE << (BITS_PER_LONG-1))-1)
which is actually odd in several ways: it limits the index to 31 bits,
and then it limits files so that they can't have data in that last byte
of a page that has the highest 31-bit index (ie page index 0x7fffffff).
Neither of those limitations make sense. The index is actually the full
32 bit unsigned value, and we can use that whole full page. So the
maximum size of the file would logically be "PAGE_SIZE << BITS_PER_LONG".
However, we do wan tto avoid the maximum index, because we have code
that iterates over the page indexes, and we don't want that code to
overflow. So the maximum size of a file on a 32-bit host should
actually be one page less than the full 32-bit index.
So the actual limit is ULONG_MAX << PAGE_SHIFT. That means that we will
not actually be using the page of that last index (ULONG_MAX), but we
can grow a file up to that limit.
The wrong value of MAX_LFS_FILESIZE actually caused problems for Doug
Nazar, who was still using a 32-bit host, but with a 9.7TB 2 x RAID5
volume. It turns out that our old MAX_LFS_FILESIZE was 8TiB (well, one
byte less), but the actual true VM limit is one page less than 16TiB.
This was invisible until commit c2a9737f45e2 ("vfs,mm: fix a dead loop
in truncate_inode_pages_range()"), which started applying that
MAX_LFS_FILESIZE limit to block devices too.
NOTE! On 64-bit, the page index isn't a limiter at all, and the limit is
actually just the offset type itself (loff_t), which is signed. But for
clarity, on 64-bit, just use the maximum signed value, and don't make
people have to count the number of 'f' characters in the hex constant.
So just use LLONG_MAX for the 64-bit case. That was what the value had
been before too, just written out as a hex constant.
Fixes: c2a9737f45e2 ("vfs,mm: fix a dead loop in truncate_inode_pages_range()")
Reported-and-tested-by: Doug Nazar <nazard@nazar.ca>
Cc: Andreas Dilger <adilger@dilger.ca>
Cc: Mark Fasheh <mfasheh@versity.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Rafael Tinoco <rafael.tinoco@linaro.org>
[backported to 4.4.y due to requests of failed LTP tests - gregkh]
commit 607065bad9931e72207b0cac365d7d4abc06bd99 upstream.
When using large tcp_rmem[2] values (I did tests with 500 MB),
I noticed overflows while computing rcvwin.
Lets fix this before the following patch.
Acked-by: Wei Wang <weiwan@google.com>
[Backport: sysctl_tcp_rmem is not Namespace-ify'd in older kernels]
