path: root/include
2018-03-13Merge tag 'v4.4.121' into toradex_vf_4.4-nextColibri-VF_LXDE-Image_2.8b2.97-20180331Max Krummenacher
This is the 4.4.121 stable release
2018-03-11udplite: fix partial checksum initializationAlexey Kodanev
[ Upstream commit 15f35d49c93f4fa9875235e7bf3e3783d2dd7a1b ] Since UDP-Lite is always using checksum, the following path is triggered when calculating pseudo header for it: udp4_csum_init() or udp6_csum_init() skb_checksum_init_zero_check() __skb_checksum_validate_complete() The problem can appear if skb->len is less than CHECKSUM_BREAK. In this particular case __skb_checksum_validate_complete() also invokes __skb_checksum_complete(skb). If UDP-Lite is using partial checksum that covers only part of a packet, the function will return bad checksum and the packet will be dropped. It can be fixed if we skip skb_checksum_init_zero_check() and only set the required pseudo header checksum for UDP-Lite with partial checksum before udp4_csum_init()/udp6_csum_init() functions return. Fixes: ed70fcfcee95 ("net: Call skb_checksum_init in IPv4") Fixes: e4f45b7f40bd ("net: Call skb_checksum_init in IPv6") Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11nospec: Allow index argument to have const-qualified typeRasmus Villemoes
commit b98c6a160a057d5686a8c54c79cc6c8c94a7d0c8 upstream. The last expression in a statement expression need not be a bare variable, quoting gcc docs The last thing in the compound statement should be an expression followed by a semicolon; the value of this subexpression serves as the value of the entire construct. and we already use that in e.g. the min/max macros which end with a ternary expression. This way, we can allow index to have const-qualified type, which will in some cases avoid the need for introducing a local copy of index of non-const qualified type. That, in turn, can prevent readers not familiar with the internals of array_index_nospec from wondering about the seemingly redundant extra variable, and I think that's worthwhile considering how confusing the whole _nospec business is. The expression _i&_mask has type unsigned long (since that is the type of _mask, and the BUILD_BUG_ONs guarantee that _i will get promoted to that), so in order not to change the type of the whole expression, add a cast back to typeof(_i). Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/151881604837.17395.10812767547837568328.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28ip_tunnel: replace dst_cache with generic implementationPaolo Abeni
commit e09acddf873bf775b208b452a4c3a3fd26fa9427 upstream. The current ip_tunnel cache implementation is prone to a race that will cause the wrong dst to be cached on cuncurrent dst cache miss and ip tunnel update via netlink. Replacing with the generic implementation fix the issue. Signed-off-by: Paolo Abeni <pabeni@redhat.com> Suggested-and-acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25x86/retpoline: Avoid retpolines for built-in __init functionsDavid Woodhouse
(cherry picked from commit 66f793099a636862a71c59d4a6ba91387b155e0c) There's no point in building init code with retpolines, since it runs before any potentially hostile userspace does. And before the retpoline is actually ALTERNATIVEd into place, for much of it. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: karahmed@amazon.de Cc: peterz@infradead.org Cc: bp@alien8.de Link: https://lkml.kernel.org/r/1517484441-1420-2-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> [jwang: port to 4.4] Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25vfs, fdtable: Prevent bounds-check bypass via speculative executionDan Williams
(cherry picked from commit 56c30ba7b348b90484969054d561f711ba196507) 'fd' is a user controlled value that is used as a data dependency to read from the 'fdt->fd' array. In order to avoid potential leaks of kernel memory values, block speculative execution of the instruction stream that could issue reads based on an invalid 'file *' returned from __fcheck_files. Co-developed-by: Elena Reshetova <elena.reshetova@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: kernel-hardening@lists.openwall.com Cc: gregkh@linuxfoundation.org Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: torvalds@linux-foundation.org Cc: alan@linux.intel.com Link: https://lkml.kernel.org/r/151727418500.33451.17392199002892248656.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> [jwang: cherry pick to 4.4] Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25array_index_nospec: Sanitize speculative array de-referencesDan Williams
(cherry picked from commit f3804203306e098dae9ca51540fcd5eb700d7f40) array_index_nospec() is proposed as a generic mechanism to mitigate against Spectre-variant-1 attacks, i.e. an attack that bypasses boundary checks via speculative execution. The array_index_nospec() implementation is expected to be safe for current generation CPUs across multiple architectures (ARM, x86). Based on an original implementation by Linus Torvalds, tweaked to remove speculative flows by Alexei Starovoitov, and tweaked again by Linus to introduce an x86 assembly implementation for the mask generation. Co-developed-by: Linus Torvalds <torvalds@linux-foundation.org> Co-developed-by: Alexei Starovoitov <ast@kernel.org> Suggested-by: Cyril Novikov <cnovikov@lynx.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: kernel-hardening@lists.openwall.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Russell King <linux@armlinux.org.uk> Cc: gregkh@linuxfoundation.org Cc: torvalds@linux-foundation.org Cc: alan@linux.intel.com Link: https://lkml.kernel.org/r/151727414229.33451.18411580953862676575.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> [jwang: cherry pick to 4.4] Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25module/retpoline: Warn about missing retpoline in moduleAndi Kleen
(cherry picked from commit caf7501a1b4ec964190f31f9c3f163de252273b8) There's a risk that a kernel which has full retpoline mitigations becomes vulnerable when a module gets loaded that hasn't been compiled with the right compiler or the right option. To enable detection of that mismatch at module load time, add a module info string "retpoline" at build time when the module was compiled with retpoline support. This only covers compiled C source, but assembler source or prebuilt object files are not checked. If a retpoline enabled kernel detects a non retpoline protected module at load time, print a warning and report it in the sysfs vulnerability file. [ tglx: Massaged changelog ] Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: gregkh@linuxfoundation.org Cc: torvalds@linux-foundation.org Cc: jeyu@kernel.org Cc: arjan@linux.intel.com Link: https://lkml.kernel.org/r/20180125235028.31211-1-andi@firstfloor.org Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> [jwang: port to 4.4] Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25netlink: fix nla_put_{u8,u16,u32} for KASANArnd Bergmann
commit b4391db42308c9940944b5d7be5ca4b78fb88dd0 upstream. When CONFIG_KASAN is enabled, the "--param asan-stack=1" causes rather large stack frames in some functions. This goes unnoticed normally because CONFIG_FRAME_WARN is disabled with CONFIG_KASAN by default as of commit 3f181b4d8652 ("lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=y"). The kernelci.org build bot however has the warning enabled and that led me to investigate it a little further, as every build produces these warnings: net/wireless/nl80211.c:4389:1: warning: the frame size of 2240 bytes is larger than 2048 bytes [-Wframe-larger-than=] net/wireless/nl80211.c:1895:1: warning: the frame size of 3776 bytes is larger than 2048 bytes [-Wframe-larger-than=] net/wireless/nl80211.c:1410:1: warning: the frame size of 2208 bytes is larger than 2048 bytes [-Wframe-larger-than=] net/bridge/br_netlink.c:1282:1: warning: the frame size of 2544 bytes is larger than 2048 bytes [-Wframe-larger-than=] Most of this problem is now solved in gcc-8, which can consolidate the stack slots for the inline function arguments. On older compilers we can add a workaround by declaring a local variable in each function to pass the inline function argument. Cc: stable@vger.kernel.org Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715 Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net> [arnd: rebased to 4.4-stable] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25genirq/msi: Add stubs for get_cached_msi_msg/pci_write_msi_msgArnd Bergmann
commit 2f44e29cef006a4b0a4ecf7d4c5aac7d0fbb505c upstream. A bug fix to the MSIx handling in vfio added references to functions that may not be defined if MSI is disabled in the kernel, resulting in this link error: drivers/built-in.o: In function `vfio_msi_set_vector_signal': :(.text+0x450808): undefined reference to `get_cached_msi_msg' :(.text+0x45080c): undefined reference to `write_msi_msg' As suggested by Alex Williamson, add stub implementations for get_cached_msi_msg() and pci_write_msi_msg(). In case this bugfix gets backported, please note that the #ifdef has changed over time, originally both functions were implemented in drivers/pci/msi.c and controlled by CONFIG_PCI_MSI, while nowadays get_cached_msi_msg() is part of the generic MSI support and can be used without PCI. Fixes: b8f02af096b1 ("vfio/pci: Restore MSIx message prior to enabling") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Alex Williamson <alex.williamson@redhat.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Bart Van Assche <bart.vanassche@sandisk.com> Link: http://lkml.kernel.org/r/1413190208.4202.34.camel@ul30vt.home Link: http://lkml.kernel.org/r/20170214215343.3307861-1-arnd@arndb.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25mtd: sh_flctl: pass FIFO as physical addressArnd Bergmann
commit 1873315fb156cbc8e46f28e8b128f17ff6c31728 upstream. By convention, the FIFO address we pass using dmaengine_slave_config is a physical address in the form that is understood by the DMA engine, as a dma_addr_t, phys_addr_t or resource_size_t. The sh_flctl driver however passes a virtual __iomem address that gets cast to dma_addr_t in the slave driver. This happens to work on shmobile because that platform sets up an identity mapping for its MMIO regions, but such code is not portable to other platforms, and prevents us from ever changing the platform mapping or reusing the driver on other architectures like ARM64 that might not have the mapping. We also get a warning about a type mismatch for the case that dma_addr_t is wider than a pointer, i.e. when CONFIG_LPAE is set: drivers/mtd/nand/sh_flctl.c: In function 'flctl_setup_dma': drivers/mtd/nand/sh_flctl.c:163:17: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] cfg.dst_addr = (dma_addr_t)FLDTFIFO(flctl); This changes the driver to instead pass the physical address of the FIFO that is extracted from the MMIO resource, making the code more portable and avoiding the warning. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25driver-core: use 'dev' argument in dev_dbg_ratelimited stubArnd Bergmann
commit 1f62ff34a90471d1b735bac2c79e894afc7c59bc upstream. dev_dbg_ratelimited() is a macro that ignores its first argument when DEBUG is not set, which can lead to unused variable warnings: ethernet/mellanox/mlxsw/pci.c: In function 'mlxsw_pci_cqe_sdq_handle': ethernet/mellanox/mlxsw/pci.c:646:18: warning: unused variable 'pdev' [-Wunused-variable] ethernet/mellanox/mlxsw/pci.c: In function 'mlxsw_pci_cqe_rdq_handle': ethernet/mellanox/mlxsw/pci.c:671:18: warning: unused variable 'pdev' [-Wunused-variable] The macro already ensures that all its other arguments are silently ignored by the compiler without triggering a warning, through the use of the no_printk() macro, but the dev argument is not passed into that. This changes the definition to use the same trick as no_printk() with an if(0) that leads the compiler to not evaluate the side-effects but still see that 'dev' might not be unused. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Suggested-by: Andrew Lunn <andrew@lunn.ch> Fixes: 6f586e663e3b ("driver-core: Shut up dev_dbg_reatelimited() without DEBUG") Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25clk: fix a panic error caused by accessing NULL pointerCai Li
[ Upstream commit 975b820b6836b6b6c42fb84cd2e772e2b41bca67 ] In some cases the clock parent would be set NULL when doing re-parent, it will cause a NULL pointer accessing if clk_set trace event is enabled. This patch sets the parent as "none" if the input parameter is NULL. Fixes: dfc202ead312 (clk: Add tracepoints for hardware operations) Signed-off-by: Cai Li <cai.li@spreadtrum.com> Signed-off-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25net_sched: red: Avoid illegal valuesNogah Frankel
[ Upstream commit 8afa10cbe281b10371fee5a87ab266e48d71a7f9 ] Check the qmin & qmax values doesn't overflow for the given Wlog value. Check that qmin <= qmax. Fixes: a783474591f2 ("[PKT_SCHED]: Generic RED layer") Signed-off-by: Nogah Frankel <nogahf@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25net_sched: red: Avoid devision by zeroNogah Frankel
[ Upstream commit 5c472203421ab4f928aa1ae9e1dbcfdd80324148 ] Do not allow delta value to be zero since it is used as a divisor. Fixes: 8af2a218de38 ("sch_red: Adaptative RED AQM") Signed-off-by: Nogah Frankel <nogahf@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25Provide a function to create a NUL-terminated string from unterminated dataDavid Howells
commit f35157417215ec138c920320c746fdb3e04ef1d5 upstream. Provide a function, kmemdup_nul(), that will create a NUL-terminated string from an unterminated character array where the length is known in advance. This is better than kstrndup() in situations where we already know the string length as the strnlen() in kstrndup() is superfluous. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25net: replace dst_cache ip6_tunnel implementation with the generic onePaolo Abeni
commit 607f725f6f7d5ec3759fbc16224afb60e2152a5b upstream. This also fix a potential race into the existing tunnel code, which could lead to the wrong dst to be permanenty cached: CPU1: CPU2: <xmit on ip6_tunnel> <cache lookup fails> dst = ip6_route_output(...) <tunnel params are changed via nl> dst_cache_reset() // no effect, // the cache is empty dst_cache_set() // the wrong dst // is permanenty stored // into the cache With the new dst implementation the above race is not possible since the first cache lookup after dst_cache_reset will fail due to the timestamp check Signed-off-by: Paolo Abeni <pabeni@redhat.com> Suggested-and-acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Manoj Boopathi Raj <manojboopathi@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25net: add dst_cache supportPaolo Abeni
commit 911362c70df5b766c243dc297fadeaced786ffd8 upstream. This patch add a generic, lockless dst cache implementation. The need for lock is avoided updating the dst cache fields only in per cpu scope, and requiring that the cache manipulation functions are invoked with the local bh disabled. The refresh_ts and reset_ts fields are used to ensure the cache consistency in case of cuncurrent cache update (dst_cache_set*) and reset operation (dst_cache_reset). Consider the following scenario: CPU1: CPU2: <cache lookup with emtpy cache: it fails> <get dst via uncached route lookup> <related configuration changes> dst_cache_reset() dst_cache_set() The dst entry set passed to dst_cache_set() should not be used for later dst cache lookup, because it's obtained using old configuration values. Since the refresh_ts is updated only on dst_cache lookup, the cached value in the above scenario will be discarded on the next lookup. Signed-off-by: Paolo Abeni <pabeni@redhat.com> Suggested-and-acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Manoj Boopathi Raj <manojboopathi@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22x86: fix build warnign with 32-bit PAEArnd Bergmann
I ran into a 4.9 build warning in randconfig testing, starting with the KAISER patches: arch/x86/kernel/ldt.c: In function 'alloc_ldt_struct': arch/x86/include/asm/pgtable_types.h:208:24: error: large integer implicitly truncated to unsigned type [-Werror=overflow] #define __PAGE_KERNEL (__PAGE_KERNEL_EXEC | _PAGE_NX) ^ arch/x86/kernel/ldt.c:81:6: note: in expansion of macro '__PAGE_KERNEL' __PAGE_KERNEL); ^~~~~~~~~~~~~ I originally ran into this last year when the patches were part of linux-next, and tried to work around it by using the proper 'pteval_t' types consistently, but that caused additional problems. This takes a much simpler approach, and makes the argument type of the dummy helper always 64-bit, which is wide enough for any page table layout and won't hurt since this call is just an empty stub anyway. Fixes: 8f0baadf2bea ("kaiser: merged update") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16crypto: poly1305 - remove ->setkey() methodEric Biggers
commit a16e772e664b9a261424107784804cffc8894977 upstream. Since Poly1305 requires a nonce per invocation, the Linux kernel implementations of Poly1305 don't use the crypto API's keying mechanism and instead expect the key and nonce as the first 32 bytes of the data. But ->setkey() is still defined as a stub returning an error code. This prevents Poly1305 from being used through AF_ALG and will also break it completely once we start enforcing that all crypto API users (not just AF_ALG) call ->setkey() if present. Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16crypto: hash - introduce crypto_hash_alg_has_setkey()Eric Biggers
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream. Templates that use an shash spawn can use crypto_shash_alg_has_setkey() to determine whether the underlying algorithm requires a key or not. But there was no corresponding function for ahash spawns. Add it. Note that the new function actually has to support both shash and ahash algorithms, since the ahash API can be used with either. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16mtd: cfi: convert inline functions to macrosArnd Bergmann
commit 9e343e87d2c4c707ef8fae2844864d4dde3a2d13 upstream. The map_word_() functions, dating back to linux-2.6.8, try to perform bitwise operations on a 'map_word' structure. This may have worked with compilers that were current then (gcc-3.4 or earlier), but end up being rather inefficient on any version I could try now (gcc-4.4 or higher). Specifically we hit a problem analyzed in gcc PR81715 where we fail to reuse the stack space for local variables. This can be seen immediately in the stack consumption for cfi_staa_erase_varsize() and other functions that (with CONFIG_KASAN) can be up to 2200 bytes. Changing the inline functions into macros brings this down to 1280 bytes. Without KASAN, the same problem exists, but the stack consumption is lower to start with, my patch shrinks it from 920 to 496 bytes on with arm-linux-gnueabi-gcc-5.4, and saves around 1KB in .text size for cfi_cmdset_0020.c, as it avoids copying map_word structures for each call to one of these helpers. With the latest gcc-8 snapshot, the problem is fixed in upstream gcc, but nobody uses that yet, so we should still work around it in mainline kernels and probably backport the workaround to stable kernels as well. We had a couple of other functions that suffered from the same gcc bug, and all of those had a simpler workaround involving dummy variables in the inline function. Unfortunately that did not work here, the macro hack was the best I could come up with. It would also be helpful to have someone to a little performance testing on the patch, to see how much it helps in terms of CPU utilitzation. Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715 Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Richard Weinberger <richard@nod.at> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16netfilter: nf_queue: Make the queue_handler pernetEric W. Biederman
commit dc3ee32e96d74dd6c80eed63af5065cb75899299 upstream. Florian Weber reported: > Under full load (unshare() in loop -> OOM conditions) we can > get kernel panic: > > BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 > IP: [<ffffffff81476c85>] nfqnl_nf_hook_drop+0x35/0x70 > [..] > task: ffff88012dfa3840 ti: ffff88012dffc000 task.ti: ffff88012dffc000 > RIP: 0010:[<ffffffff81476c85>] [<ffffffff81476c85>] nfqnl_nf_hook_drop+0x35/0x70 > RSP: 0000:ffff88012dfffd80 EFLAGS: 00010206 > RAX: 0000000000000008 RBX: ffffffff81add0c0 RCX: ffff88013fd80000 > [..] > Call Trace: > [<ffffffff81474d98>] nf_queue_nf_hook_drop+0x18/0x20 > [<ffffffff814738eb>] nf_unregister_net_hook+0xdb/0x150 > [<ffffffff8147398f>] netfilter_net_exit+0x2f/0x60 > [<ffffffff8141b088>] ops_exit_list.isra.4+0x38/0x60 > [<ffffffff8141b652>] setup_net+0xc2/0x120 > [<ffffffff8141bd09>] copy_net_ns+0x79/0x120 > [<ffffffff8106965b>] create_new_namespaces+0x11b/0x1e0 > [<ffffffff810698a7>] unshare_nsproxy_namespaces+0x57/0xa0 > [<ffffffff8104baa2>] SyS_unshare+0x1b2/0x340 > [<ffffffff81608276>] entry_SYSCALL_64_fastpath+0x1e/0xa8 > Code: 65 00 48 89 e5 41 56 41 55 41 54 53 83 e8 01 48 8b 97 70 12 00 00 48 98 49 89 f4 4c 8b 74 c2 18 4d 8d 6e 08 49 81 c6 88 00 00 00 <49> 8b 5d 00 48 85 db 74 1a 48 89 df 4c 89 e2 48 c7 c6 90 68 47 > The simple fix for this requires a new pernet variable for struct nf_queue that indicates when it is safe to use the dynamically allocated nf_queue state. As we need a variable anyway make nf_register_queue_handler and nf_unregister_queue_handler pernet. This allows the existing logic of when it is safe to use the state from the nfnetlink_queue module to be reused with no changes except for making it per net. The syncrhonize_rcu from nf_unregister_queue_handler is moved to a new function nfnl_queue_net_exit_batch so that the worst case of having a syncrhonize_rcu in the pernet exit path is not experienced in batch mode. Reported-by: Florian Westphal <fw@strlen.de> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Cc: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16don't put symlink bodies in pagecache into highmemAl Viro
commit 21fc61c73c3903c4c312d0802da01ec2b323d174 upstream. kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jin Qian <jinqian@google.com> Signed-off-by: Jin Qian <jinqian@android.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03bpf: avoid false sharing of map refcount with max_entriesDaniel Borkmann
[ upstream commit be95a845cc4402272994ce290e3ad928aff06cb9 ] In addition to commit b2157399cc98 ("bpf: prevent out-of-bounds speculation") also change the layout of struct bpf_map such that false sharing of fast-path members like max_entries is avoided when the maps reference counter is altered. Therefore enforce them to be placed into separate cachelines. pahole dump after change: struct bpf_map { const struct bpf_map_ops * ops; /* 0 8 */ struct bpf_map * inner_map_meta; /* 8 8 */ void * security; /* 16 8 */ enum bpf_map_type map_type; /* 24 4 */ u32 key_size; /* 28 4 */ u32 value_size; /* 32 4 */ u32 max_entries; /* 36 4 */ u32 map_flags; /* 40 4 */ u32 pages; /* 44 4 */ u32 id; /* 48 4 */ int numa_node; /* 52 4 */ bool unpriv_array; /* 56 1 */ /* XXX 7 bytes hole, try to pack */ /* --- cacheline 1 boundary (64 bytes) --- */ struct user_struct * user; /* 64 8 */ atomic_t refcnt; /* 72 4 */ atomic_t usercnt; /* 76 4 */ struct work_struct work; /* 80 32 */ char name[16]; /* 112 16 */ /* --- cacheline 2 boundary (128 bytes) --- */ /* size: 128, cachelines: 2, members: 17 */ /* sum members: 121, holes: 1, sum holes: 7 */ }; Now all entries in the first cacheline are read only throughout the life time of the map, set up once during map creation. Overall struct size and number of cachelines doesn't change from the reordering. struct bpf_map is usually first member and embedded in map structs in specific map implementations, so also avoid those members to sit at the end where it could potentially share the cacheline with first map values e.g. in the array since remote CPUs could trigger map updates just as well for those (easily dirtying members like max_entries intentionally as well) while having subsequent values in cache. Quoting from Google's Project Zero blog [1]: Additionally, at least on the Intel machine on which this was tested, bouncing modified cache lines between cores is slow, apparently because the MESI protocol is used for cache coherence [8]. Changing the reference counter of an eBPF array on one physical CPU core causes the cache line containing the reference counter to be bounced over to that CPU core, making reads of the reference counter on all other CPU cores slow until the changed reference counter has been written back to memory. Because the length and the reference counter of an eBPF array are stored in the same cache line, this also means that changing the reference counter on one physical CPU core causes reads of the eBPF array's length to be slow on other physical CPU cores (intentional false sharing). While this doesn't 'control' the out-of-bounds speculation through masking the index as in commit b2157399cc98, triggering a manipulation of the map's reference counter is really trivial, so lets not allow to easily affect max_entries from it. Splitting to separate cachelines also generally makes sense from a performance perspective anyway in that fast-path won't have a cache miss if the map gets pinned, reused in other progs, etc out of control path, thus also avoids unintentional false sharing. [1] https://googleprojectzero.blogspot.ch/2018/01/reading-privileged-memory-with-side.html Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31net: tcp: close sock if net namespace is exitingDan Streetman
[ Upstream commit 4ee806d51176ba7b8ff1efd81f271d7252e03a1d ] When a tcp socket is closed, if it detects that its net namespace is exiting, close immediately and do not wait for FIN sequence. For normal sockets, a reference is taken to their net namespace, so it will never exit while the socket is open. However, kernel sockets do not take a reference to their net namespace, so it may begin exiting while the kernel socket is still open. In this case if the kernel socket is a tcp socket, it will stay open trying to complete its close sequence. The sock's dst(s) hold a reference to their interface, which are all transferred to the namespace's loopback interface when the real interfaces are taken down. When the namespace tries to take down its loopback interface, it hangs waiting for all references to the loopback interface to release, which results in messages like: unregister_netdevice: waiting for lo to become free. Usage count = 1 These messages continue until the socket finally times out and closes. Since the net namespace cleanup holds the net_mutex while calling its registered pernet callbacks, any new net namespace initialization is blocked until the current net namespace finishes exiting. After this change, the tcp socket notices the exiting net namespace, and closes immediately, releasing its dst(s) and their reference to the loopback interface, which lets the net namespace continue exiting. Link: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1711407 Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=97811 Signed-off-by: Dan Streetman <ddstreet@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31ipv4: Make neigh lookup keys for loopback/point-to-point devices be INADDR_ANYJim Westfall
[ Upstream commit cd9ff4de0107c65d69d02253bb25d6db93c3dbc1 ] Map all lookup neigh keys to INADDR_ANY for loopback/point-to-point devices to avoid making an entry for every remote ip the device needs to talk to. This used the be the old behavior but became broken in a263b3093641f (ipv4: Make neigh lookups directly in output packet path) and later removed in 0bb4087cbec0 (ipv4: Fix neigh lookup keying over loopback/point-to-point devices) because it was broken. Signed-off-by: Jim Westfall <jwestfall@surrealistic.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31tcp: __tcp_hdrlen() helperCraig Gallek
commit d9b3fca27385eafe61c3ca6feab6cb1e7dc77482 upstream. tcp_hdrlen is wasteful if you already have a pointer to struct tcphdr. This splits the size calculation into a helper function that can be used if a struct tcphdr is already available. Signed-off-by: Craig Gallek <kraig@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31ipv6: Fix getsockopt() for sockets with default IPV6_AUTOFLOWLABELBen Hutchings
[ Upstream commit e9191ffb65d8e159680ce0ad2224e1acbde6985c ] Commit 513674b5a2c9 ("net: reevalulate autoflowlabel setting after sysctl setting") removed the initialisation of ipv6_pinfo::autoflowlabel and added a second flag to indicate whether this field or the net namespace default should be used. The getsockopt() handling for this case was not updated, so it currently returns 0 for all sockets for which IPV6_AUTOFLOWLABEL is not explicitly enabled. Fix it to return the effective value, whether that has been set at the socket or net namespace level. Fixes: 513674b5a2c9 ("net: reevalulate autoflowlabel setting after sysctl ...") Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31eventpoll.h: add missing epoll event masksGreg KH
commit 7e040726850a106587485c21bdacc0bfc8a0cbed upstream. [resend due to me forgetting to cc: linux-api the first time around I posted these back on Feb 23] From: Greg Kroah-Hartman <gregkh@linuxfoundation.org> For some reason these values are not in the uapi header file, so any libc has to define it themselves. To prevent them from needing to do this, just have the kernel provide the correct values. Reported-by: Elliott Hughes <enh@google.com> Signed-off-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31Revert "module: Add retpoline tag to VERMAGIC"Greg Kroah-Hartman
commit 5132ede0fe8092b043dae09a7cc32b8ae7272baa upstream. This reverts commit 6cfb521ac0d5b97470883ff9b7facae264b7ab12. Turns out distros do not want to make retpoline as part of their "ABI", so this patch should not have been merged. Sorry Andi, this was my fault, I suggested it when your original patch was the "correct" way of doing this instead. Reported-by: Jiri Kosina <jikos@kernel.org> Fixes: 6cfb521ac0d5 ("module: Add retpoline tag to VERMAGIC") Acked-by: Andi Kleen <ak@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: rusty@rustcorp.com.au Cc: arjan.van.de.ven@intel.com Cc: jeyu@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31netfilter: fix IS_ERR_VALUE usagePablo Neira Ayuso
commit 92b4423e3a0bc5d43ecde4bcad871f8b5ba04efd upstream. This is a forward-port of the original patch from Andrzej Hajda, he said: "IS_ERR_VALUE should be used only with unsigned long type. Otherwise it can work incorrectly. To achieve this function xt_percpu_counter_alloc is modified to return unsigned long, and its result is assigned to temporary variable to perform error checking, before assigning to .pcnt field. The patch follows conclusion from discussion on LKML [1][2]. [1]: http://permalink.gmane.org/gmane.linux.kernel/2120927 [2]: http://permalink.gmane.org/gmane.linux.kernel/2150581" Original patch from Andrzej is here: http://patchwork.ozlabs.org/patch/582970/ This patch has clashed with input validation fixes for x_tables. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Michal Kubecek <mkubecek@suse.cz>
2018-01-31netfilter: x_tables: speed up jump target validationFlorian Westphal
commit f4dc77713f8016d2e8a3295e1c9c53a21f296def upstream. The dummy ruleset I used to test the original validation change was broken, most rules were unreachable and were not tested by mark_source_chains(). In some cases rulesets that used to load in a few seconds now require several minutes. sample ruleset that shows the behaviour: echo "*filter" for i in $(seq 0 100000);do printf ":chain_%06x - [0:0]\n" $i done for i in $(seq 0 100000);do printf -- "-A INPUT -j chain_%06x\n" $i printf -- "-A INPUT -j chain_%06x\n" $i printf -- "-A INPUT -j chain_%06x\n" $i done echo COMMIT [ pipe result into iptables-restore ] This ruleset will be about 74mbyte in size, with ~500k searches though all 500k[1] rule entries. iptables-restore will take forever (gave up after 10 minutes) Instead of always searching the entire blob for a match, fill an array with the start offsets of every single ipt_entry struct, then do a binary search to check if the jump target is present or not. After this change ruleset restore times get again close to what one gets when reverting 36472341017529e (~3 seconds on my workstation). [1] every user-defined rule gets an implicit RETURN, so we get 300k jumps + 100k userchains + 100k returns -> 500k rule entries Fixes: 36472341017529e ("netfilter: x_tables: validate targets of jumps") Reported-by: Jeff Wu <wujiafu@gmail.com> Tested-by: Jeff Wu <wujiafu@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31drivers: base: cacheinfo: fix x86 with CONFIG_OF enabledSudeep Holla
commit fac51482577d5e05bbb0efa8d602a3c2111098bf upstream. With CONFIG_OF enabled on x86, we get the following error on boot: " Failed to find cpu0 device node Unable to detect cache hierarchy from DT for CPU 0 " and the cacheinfo fails to get populated in the corresponding sysfs entries. This is because cache_setup_of_node looks for of_node for setting up the shared cpu_map without checking that it's already populated in the architecture specific callback. In order to indicate that the shared cpu_map is already populated, this patch introduces a boolean `cpu_map_populated` in struct cpu_cacheinfo that can be used by the generic code to skip cache_shared_cpu_map_setup. This patch also sets that boolean for x86. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31time: Avoid undefined behaviour in ktime_add_safe()Vegard Nossum
commit 979515c5645830465739254abc1b1648ada41518 upstream. I ran into this: ================================================================================ UBSAN: Undefined behaviour in kernel/time/hrtimer.c:310:16 signed integer overflow: 9223372036854775807 + 50000 cannot be represented in type 'long long int' CPU: 2 PID: 4798 Comm: trinity-c2 Not tainted 4.8.0-rc1+ #91 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014 0000000000000000 ffff88010ce6fb88 ffffffff82344740 0000000041b58ab3 ffffffff84f97a20 ffffffff82344694 ffff88010ce6fbb0 ffff88010ce6fb60 000000000000c350 ffff88010ce6f968 dffffc0000000000 ffffffff857bc320 Call Trace: [<ffffffff82344740>] dump_stack+0xac/0xfc [<ffffffff82344694>] ? _atomic_dec_and_lock+0xc4/0xc4 [<ffffffff8242df78>] ubsan_epilogue+0xd/0x8a [<ffffffff8242e6b4>] handle_overflow+0x202/0x23d [<ffffffff8242e4b2>] ? val_to_string.constprop.6+0x11e/0x11e [<ffffffff8236df71>] ? timerqueue_add+0x151/0x410 [<ffffffff81485c48>] ? hrtimer_start_range_ns+0x3b8/0x1380 [<ffffffff81795631>] ? memset+0x31/0x40 [<ffffffff8242e6fd>] __ubsan_handle_add_overflow+0xe/0x10 [<ffffffff81488ac9>] hrtimer_nanosleep+0x5d9/0x790 [<ffffffff814884f0>] ? hrtimer_init_sleeper+0x80/0x80 [<ffffffff813a9ffb>] ? __might_sleep+0x5b/0x260 [<ffffffff8148be10>] common_nsleep+0x20/0x30 [<ffffffff814906c7>] SyS_clock_nanosleep+0x197/0x210 [<ffffffff81490530>] ? SyS_clock_getres+0x150/0x150 [<ffffffff823c7113>] ? __this_cpu_preempt_check+0x13/0x20 [<ffffffff8162ef60>] ? __context_tracking_exit.part.3+0x30/0x1b0 [<ffffffff81490530>] ? SyS_clock_getres+0x150/0x150 [<ffffffff81007bd3>] do_syscall_64+0x1b3/0x4b0 [<ffffffff845f85aa>] entry_SYSCALL64_slow_path+0x25/0x25 ================================================================================ Add a new ktime_add_unsafe() helper which doesn't check for overflow, but doesn't throw a UBSAN warning when it does overflow either. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31sched/deadline: Use the revised wakeup rule for suspending constrained dl tasksDaniel Bristot de Oliveira
commit 3effcb4247e74a51f5d8b775a1ee4abf87cc089a upstream. We have been facing some problems with self-suspending constrained deadline tasks. The main reason is that the original CBS was not designed for such sort of tasks. One problem reported by Xunlei Pang takes place when a task suspends, and then is awakened before the deadline, but so close to the deadline that its remaining runtime can cause the task to have an absolute density higher than allowed. In such situation, the original CBS assumes that the task is facing an early activation, and so it replenishes the task and set another deadline, one deadline in the future. This rule works fine for implicit deadline tasks. Moreover, it allows the system to adapt the period of a task in which the external event source suffered from a clock drift. However, this opens the window for bandwidth leakage for constrained deadline tasks. For instance, a task with the following parameters: runtime = 5 ms deadline = 7 ms [density] = 5 / 7 = 0.71 period = 1000 ms If the task runs for 1 ms, and then suspends for another 1ms, it will be awakened with the following parameters: remaining runtime = 4 laxity = 5 presenting a absolute density of 4 / 5 = 0.80. In this case, the original CBS would assume the task had an early wakeup. Then, CBS will reset the runtime, and the absolute deadline will be postponed by one relative deadline, allowing the task to run. The problem is that, if the task runs this pattern forever, it will keep receiving bandwidth, being able to run 1ms every 2ms. Following this behavior, the task would be able to run 500 ms in 1 sec. Thus running more than the 5 ms / 1 sec the admission control allowed it to run. Trying to address the self-suspending case, Luca Abeni, Giuseppe Lipari, and Juri Lelli [1] revisited the CBS in order to deal with self-suspending tasks. In the new approach, rather than replenishing/postponing the absolute deadline, the revised wakeup rule adjusts the remaining runtime, reducing it to fit into the allowed density. A revised version of the idea is: At a given time t, the maximum absolute density of a task cannot be higher than its relative density, that is: runtime / (deadline - t) <= dl_runtime / dl_deadline Knowing the laxity of a task (deadline - t), it is possible to move it to the other side of the equality, thus enabling to define max remaining runtime a task can use within the absolute deadline, without over-running the allowed density: runtime = (dl_runtime / dl_deadline) * (deadline - t) For instance, in our previous example, the task could still run: runtime = ( 5 / 7 ) * 5 runtime = 3.57 ms Without causing damage for other deadline tasks. It is note worthy that the laxity cannot be negative because that would cause a negative runtime. Thus, this patch depends on the patch: df8eac8cafce ("sched/deadline: Throttle a constrained deadline task activated after the deadline") Which throttles a constrained deadline task activated after the deadline. Finally, it is also possible to use the revised wakeup rule for all other tasks, but that would require some more discussions about pros and cons. [The main difference from the original commit is that the BW_SHIFT define was not present yet. As BW_SHIFT was introduced in a new feature, I just used the value (20), likewise we used to use before the #define. Other changes were required because of comments. - bistrot] Reported-by: Xunlei Pang <xpang@redhat.com> Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com> [peterz: replaced dl_is_constrained with dl_is_implicit] Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Juri Lelli <juri.lelli@arm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luca Abeni <luca.abeni@santannapisa.it> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Romulo Silva de Oliveira <romulo.deoliveira@ufsc.br> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tommaso Cucinotta <tommaso.cucinotta@sssup.it> Link: http://lkml.kernel.org/r/5c800ab3a74a168a84ee5f3f84d12a02e11383be.1495803804.git.bristot@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23module: Add retpoline tag to VERMAGICAndi Kleen
commit 6cfb521ac0d5b97470883ff9b7facae264b7ab12 upstream. Add a marker for retpoline to the module VERMAGIC. This catches the case when a non RETPOLINE compiled module gets loaded into a retpoline kernel, making it insecure. It doesn't handle the case when retpoline has been runtime disabled. Even in this case the match of the retcompile status will be enforced. This implies that even with retpoline run time disabled all modules loaded need to be recompiled. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: rusty@rustcorp.com.au Cc: arjan.van.de.ven@intel.com Cc: jeyu@kernel.org Cc: torvalds@linux-foundation.org Link: https://lkml.kernel.org/r/20180116205228.4890-1-andi@firstfloor.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23scsi: sg: disable SET_FORCE_LOW_DMAHannes Reinecke
commit 745dfa0d8ec26b24f3304459ff6e9eacc5c8351b upstream. The ioctl SET_FORCE_LOW_DMA has never worked since the initial git check-in, and the respective setting is nowadays handled correctly. So disable it entirely. Signed-off-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Tested-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23kconfig.h: use __is_defined() to check if MODULE is definedMasahiro Yamada
commit 4f920843d248946545415c1bf6120942048708ed upstream. The macro MODULE is not a config option, it is a per-file build option. So, config_enabled(MODULE) is not sensible. (There is another case in include/linux/export.h, where config_enabled() is used against a non-config option.) This commit renames some macros in include/linux/kconfig.h for the use for non-config macros and replaces config_enabled(MODULE) with __is_defined(MODULE). I am keeping config_enabled() because it is still referenced from some places, but I expect it would be deprecated in the future. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23EXPORT_SYMBOL() for asmAl Viro
commit 22823ab419d8ed884195cfa75483fd3a99bb1462 upstream. Add asm-usable variants of EXPORT_SYMBOL/EXPORT_SYMBOL_GPL. This commit just adds the default implementation; most of the architectures can simply add export.h to asm/Kbuild and start using <asm/export.h> from assembler. The rest needs to have their <asm/export.h> define everal macros and then explicitly include <asm-generic/export.h> One area where the things might diverge from default is the alignment; normally it's 8 bytes on 64bit targets and 4 on 32bit ones, both for unsigned long and for struct kernel_symbol. Unfortunately, amd64 and m68k are unusual - m68k aligns to 2 bytes (for both) and amd64 aligns struct kernel_symbol to 16 bytes. For those we'll need asm/export.h to override the constants used by generic version - KSYM_ALIGN and KCRC_ALIGN for kernel_symbol and unsigned long resp. And no, __alignof__ would not do the trick - on amd64 __alignof__ of struct kernel_symbol is 8, not 16. More serious source of unpleasantness is treatment of function descriptors on architectures that have those. Things like ppc64, parisc, ia64, etc. need more than the address of the first insn to call an arbitrary function. As the result, their representation of pointers to functions is not the typical "address of the entry point" - it's an address of a small static structure containing all the required information (including the entry point, of course). Sadly, the asm-side conventions differ in what the function name refers to - entry point or the function descriptor. On ppc64 we do the latter; bar: .quad foo is what void (*bar)(void) = foo; turns into and the rare places where we need to explicitly work with the label of entry point are dealt with as DOTSYM(foo). For our purposes it's ideal - generic macros are usable. However, parisc would have foo and P%foo used for label of entry point and address of the function descriptor and bar: .long P%foo woudl be used instead. ia64 goes similar to parisc in that respect, except that there it's @fptr(foo) rather than P%foo. Such architectures need to define KSYM_FUNC that would turn a function name into whatever is needed to refer to function descriptor. What's more, on such architectures we need to know whether we are exporting a function or an object - in assembler we have to tell that explicitly, to decide whether we want EXPORT_SYMBOL(foo) produce e.g. __ksymtab_foo: .quad foo or __ksymtab_foo: .quad @fptr(foo) For that reason we introduce EXPORT_DATA_SYMBOL{,_GPL}(), to be used for exports of data objects. On normal architectures it's the same thing as EXPORT_SYMBOL{,_GPL}(), but on parisc-like ones they differ and the right one needs to be used. Most of the exports are functions, so we keep EXPORT_SYMBOL for those... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/kbuild: enable modversions for symbols exported from asmAdam Borowski
commit 334bb773876403eae3457d81be0b8ea70f8e4ccc upstream. Commit 4efca4ed ("kbuild: modversions for EXPORT_SYMBOL() for asm") adds modversion support for symbols exported from asm files. Architectures must include C-style declarations for those symbols in asm/asm-prototypes.h in order for them to be versioned. Add these declarations for x86, and an architecture-independent file that can be used for common symbols. With f27c2f6 reverting 8ab2ae6 ("default exported asm symbols to zero") we produce a scary warning on x86, this commit fixes that. Signed-off-by: Adam Borowski <kilobyte@angband.pl> Tested-by: Kalle Valo <kvalo@codeaurora.org> Acked-by: Nicholas Piggin <npiggin@gmail.com> Tested-by: Peter Wu <peter@lekensteyn.nl> Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17sysfs/cpu: Add vulnerability folderThomas Gleixner
commit 87590ce6e373d1a5401f6539f0c59ef92dd924a9 upstream. As the meltdown/spectre problem affects several CPU architectures, it makes sense to have common way to express whether a system is affected by a particular vulnerability or not. If affected the way to express the mitigation should be common as well. Create /sys/devices/system/cpu/vulnerabilities folder and files for meltdown, spectre_v1 and spectre_v2. Allow architectures to override the show function. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linuxfoundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: David Woodhouse <dwmw@amazon.co.uk> Link: https://lkml.kernel.org/r/20180107214913.096657732@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17target: Avoid early CMD_T_PRE_EXECUTE failures during ABORT_TASKNicholas Bellinger
commit 1c21a48055a67ceb693e9c2587824a8de60a217c upstream. This patch fixes bug where early se_cmd exceptions that occur before backend execution can result in use-after-free if/when a subsequent ABORT_TASK occurs for the same tag. Since an early se_cmd exception will have had se_cmd added to se_session->sess_cmd_list via target_get_sess_cmd(), it will not have CMD_T_COMPLETE set by the usual target_complete_cmd() backend completion path. This causes a subsequent ABORT_TASK + __target_check_io_state() to signal ABORT_TASK should proceed. As core_tmr_abort_task() executes, it will bring the outstanding se_cmd->cmd_kref count down to zero releasing se_cmd, after se_cmd has already been queued with error status into fabric driver response path code. To address this bug, introduce a CMD_T_PRE_EXECUTE bit that is set at target_get_sess_cmd() time, and cleared immediately before backend driver dispatch in target_execute_cmd() once CMD_T_ACTIVE is set. Then, check CMD_T_PRE_EXECUTE within __target_check_io_state() to determine when an early exception has occured, and avoid aborting this se_cmd since it will have already been queued into fabric driver response path code. Reported-by: Donald White <dew@datera.io> Cc: Donald White <dew@datera.io> Cc: Mike Christie <mchristi@redhat.com> Cc: Hannes Reinecke <hare@suse.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17bpf: prevent out-of-bounds speculationAlexei Starovoitov
commit b2157399cc9898260d6031c5bfe45fe137c1fbe7 upstream. Under speculation, CPUs may mis-predict branches in bounds checks. Thus, memory accesses under a bounds check may be speculated even if the bounds check fails, providing a primitive for building a side channel. To avoid leaking kernel data round up array-based maps and mask the index after bounds check, so speculated load with out of bounds index will load either valid value from the array or zero from the padded area. Unconditionally mask index for all array types even when max_entries are not rounded to power of 2 for root user. When map is created by unpriv user generate a sequence of bpf insns that includes AND operation to make sure that JITed code includes the same 'index & index_mask' operation. If prog_array map is created by unpriv user replace bpf_tail_call(ctx, map, index); with if (index >= max_entries) { index &= map->index_mask; bpf_tail_call(ctx, map, index); } (along with roundup to power 2) to prevent out-of-bounds speculation. There is secondary redundant 'if (index >= max_entries)' in the interpreter and in all JITs, but they can be optimized later if necessary. Other array-like maps (cpumap, devmap, sockmap, perf_event_array, cgroup_array) cannot be used by unpriv, so no changes there. That fixes bpf side of "Variant 1: bounds check bypass (CVE-2017-5753)" on all architectures with and without JIT. v2->v3: Daniel noticed that attack potentially can be crafted via syscall commands without loading the program, so add masking to those paths as well. Signed-off-by: Alexei Starovoitov <ast@kernel.org> Acked-by: John Fastabend <john.fastabend@gmail.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17bpf: add bpf_patch_insn_single helperDaniel Borkmann
commit c237ee5eb33bf19fe0591c04ff8db19da7323a83 upstream. Move the functionality to patch instructions out of the verifier code and into the core as the new bpf_patch_insn_single() helper will be needed later on for blinding as well. No changes in functionality. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17net: stmmac: enable EEE in MII, GMII or RGMII onlyJerome Brunet
[ Upstream commit 879626e3a52630316d817cbda7cec9a5446d1d82 ] Note in the databook - Section 4.4 - EEE : " The EEE feature is not supported when the MAC is configured to use the TBI, RTBI, SMII, RMII or SGMII single PHY interface. Even if the MAC supports multiple PHY interfaces, you should activate the EEE mode only when the MAC is operating with GMII, MII, or RGMII interface." Applying this restriction solves a stability issue observed on Amlogic gxl platforms operating with RMII interface and the internal PHY. Fixes: 83bf79b6bb64 ("stmmac: disable at run-time the EEE if not supported") Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Tested-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17sh_eth: fix SH7757 GEther initializationSergei Shtylyov
[ Upstream commit 5133550296d43236439494aa955bfb765a89f615 ] Renesas SH7757 has 2 Fast and 2 Gigabit Ether controllers, while the 'sh_eth' driver can only reset and initialize TSU of the first controller pair. Shimoda-san tried to solve that adding the 'needs_init' member to the 'struct sh_eth_plat_data', however the platform code still never sets this flag. I think that we can infer this information from the 'devno' variable (set to 'platform_device::id') and reset/init the Ether controller pair only for an even 'devno'; therefore 'sh_eth_plat_data::needs_init' can be removed... Fixes: 150647fb2c31 ("net: sh_eth: change the condition of initialization") Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17KVM: Fix stack-out-of-bounds read in write_mmioWanpeng Li
commit e39d200fa5bf5b94a0948db0dae44c1b73b84a56 upstream. Reported by syzkaller: BUG: KASAN: stack-out-of-bounds in write_mmio+0x11e/0x270 [kvm] Read of size 8 at addr ffff8803259df7f8 by task syz-executor/32298 CPU: 6 PID: 32298 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #18 Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016 Call Trace: dump_stack+0xab/0xe1 print_address_description+0x6b/0x290 kasan_report+0x28a/0x370 write_mmio+0x11e/0x270 [kvm] emulator_read_write_onepage+0x311/0x600 [kvm] emulator_read_write+0xef/0x240 [kvm] emulator_fix_hypercall+0x105/0x150 [kvm] em_hypercall+0x2b/0x80 [kvm] x86_emulate_insn+0x2b1/0x1640 [kvm] x86_emulate_instruction+0x39a/0xb90 [kvm] handle_exception+0x1b4/0x4d0 [kvm_intel] vcpu_enter_guest+0x15a0/0x2640 [kvm] kvm_arch_vcpu_ioctl_run+0x549/0x7d0 [kvm] kvm_vcpu_ioctl+0x479/0x880 [kvm] do_vfs_ioctl+0x142/0x9a0 SyS_ioctl+0x74/0x80 entry_SYSCALL_64_fastpath+0x23/0x9a The path of patched vmmcall will patch 3 bytes opcode 0F 01 C1(vmcall) to the guest memory, however, write_mmio tracepoint always prints 8 bytes through *(u64 *)val since kvm splits the mmio access into 8 bytes. This leaks 5 bytes from the kernel stack (CVE-2017-17741). This patch fixes it by just accessing the bytes which we operate on. Before patch: syz-executor-5567 [007] .... 51370.561696: kvm_mmio: mmio write len 3 gpa 0x10 val 0x1ffff10077c1010f After patch: syz-executor-13416 [002] .... 51302.299573: kvm_mmio: mmio write len 3 gpa 0x10 val 0xc1010f Reported-by: Dmitry Vyukov <dvyukov@google.com> Reviewed-by: Darren Kenny <darren.kenny@oracle.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Tested-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10kernel: make groups_sort calling a responsibility group_info allocatorsThiago Rafael Becker
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream. In testing, we found that nfsd threads may call set_groups in parallel for the same entry cached in auth.unix.gid, racing in the call of groups_sort, corrupting the groups for that entry and leading to permission denials for the client. This patch: - Make groups_sort globally visible. - Move the call to groups_sort to the modifiers of group_info - Remove the call to groups_sort from set_groups Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com> Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com> Reviewed-by: NeilBrown <neilb@suse.com> Acked-by: "J. Bruce Fields" <bfields@fieldses.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10fscache: Fix the default for fscache_maybe_release_page()David Howells
commit 98801506552593c9b8ac11021b0cdad12cab4f6b upstream. Fix the default for fscache_maybe_release_page() for when the cookie isn't valid or the page isn't cached. It mustn't return false as that indicates the page cannot yet be freed. The problem with the default is that if, say, there's no cache, but a network filesystem's pages are using up almost all the available memory, a system can OOM because the filesystem ->releasepage() op will not allow them to be released as fscache_maybe_release_page() incorrectly prevents it. This can be tested by writing a sequence of 512MiB files to an AFS mount. It does not affect NFS or CIFS because both of those wrap the call in a check of PG_fscache and it shouldn't bother Ceph as that only has PG_private set whilst writeback is in progress. This might be an issue for 9P, however. Note that the pages aren't entirely stuck. Removing a file or unmounting will clear things because that uses ->invalidatepage() instead. Fixes: 201a15428bd5 ("FS-Cache: Handle pages pending storage that get evicted under OOM conditions") Reported-by: Marc Dionne <marc.dionne@auristor.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Marc Dionne <marc.dionne@auristor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
