path: root/include
2014-01-25mm: Make {,set}page_address() static inline if WANT_PAGE_VIRTUALGeert Uytterhoeven
commit f92f455f67fef27929e6043499414605b0c94872 upstream. {,set}page_address() are macros if WANT_PAGE_VIRTUAL. If !WANT_PAGE_VIRTUAL, they're plain C functions. If someone calls them with a void *, this pointer is auto-converted to struct page * if !WANT_PAGE_VIRTUAL, but causes a build failure on architectures using WANT_PAGE_VIRTUAL (arc, m68k and sparc64): drivers/md/bcache/bset.c: In function `__btree_sort': drivers/md/bcache/bset.c:1190: warning: dereferencing `void *' pointer drivers/md/bcache/bset.c:1190: error: request for member `virtual' in something not a structure or union Convert them to static inline functions to fix this. There are already plenty of users of struct page members inside <linux/mm.h>, so there's no reason to keep them as macros. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Michael S. Tsirkin <mst@redhat.com> Tested-by: Guenter Roeck <linux@roeck-us.net> Tested-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-25crash_dump: fix compilation error (on MIPS at least)Qais Yousef
commit 5a610fcc7390ee60308deaf09426ada87a1eeec2 upstream. In file included from kernel/crash_dump.c:2:0: include/linux/crash_dump.h:22:27: error: unknown type name `pgprot_t' when CONFIG_CRASH_DUMP=y The error was traced back to commit 9cb218131de1 ("vmcore: introduce remap_oldmem_pfn_range()") include <asm/pgtable.h> to get the missing definition Signed-off-by: Qais Yousef <qais.yousef@imgtec.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-25i2c: Re-instate body of i2c_parent_is_i2c_adapter()Stephen Warren
commit 2fac2b891f287691c27ee8d2eeecf39571b27fea upstream. The body of i2c_parent_is_i2c_adapter() is currently guarded by I2C_MUX. It should be CONFIG_I2C_MUX instead. Among potentially other problems, this resulted in i2c_lock_adapter() only locking I2C mux child adapters, and not the parent adapter. In turn, this could allow inter-mingling of mux child selection and I2C transactions, which could result in I2C transactions being directed to the wrong I2C bus, and possibly even switching between busses in the middle of a transaction. One concrete issue caused by this bug was corrupted HDMI EDID reads during boot on the NVIDIA Tegra Seaboard system, although this only became apparent in recent linux-next, when the boot timing was changed just enough to trigger the race condition. Fixes: 3923172b3d70 ("i2c: reduce parent checking to a NOOP in non-I2C_MUX case") Cc: Phil Carmody <phil.carmody@partner.samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15ipv4: fix tunneled VM traffic over hw VXLAN/GRE GSO NICWei-Chun Chao
[ Upstream commit 7a7ffbabf99445704be01bff5d7e360da908cf8e ] VM to VM GSO traffic is broken if it goes through VXLAN or GRE tunnel and the physical NIC on the host supports hardware VXLAN/GRE GSO offload (e.g. bnx2x and next-gen mlx4). Two issues - (VXLAN) VM traffic has SKB_GSO_DODGY and SKB_GSO_UDP_TUNNEL with SKB_GSO_TCP/UDP set depending on the inner protocol. GSO header integrity check fails in udp4_ufo_fragment if inner protocol is TCP. Also gso_segs is calculated incorrectly using skb->len that includes tunnel header. Fix: robust check should only be applied to the inner packet. (VXLAN & GRE) Once GSO header integrity check passes, NULL segs is returned and the original skb is sent to hardware. However the tunnel header is already pulled. Fix: tunnel header needs to be restored so that hardware can perform GSO properly on the original packet. Signed-off-by: Wei-Chun Chao <weichunc@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15vlan: Fix header ops passthru when doing TX VLAN offload.David S. Miller
[ Upstream commit 2205369a314e12fcec4781cc73ac9c08fc2b47de ] When the vlan code detects that the real device can do TX VLAN offloads in hardware, it tries to arrange for the real device's header_ops to be invoked directly. But it does so illegally, by simply hooking the real device's header_ops up to the VLAN device. This doesn't work because we will end up invoking a set of header_ops routines which expect a device type which matches the real device, but will see a VLAN device instead. Fix this by providing a pass-thru set of header_ops which will arrange to pass the proper real device instead. To facilitate this add a dev_rebuild_header(). There are implementations which provide a ->cache and ->create but not a ->rebuild (f.e. PLIP). So we need a helper function just like dev_hard_header() to avoid crashes. Use this helper in the one existing place where the header_ops->rebuild was being invoked, the neighbour code. With lots of help from Florian Westphal. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15ip_gre: fix msg_name parsing for recvfrom/recvmsgTimo Teräs
[ Upstream commit 0e3da5bb8da45890b1dc413404e0f978ab71173e ] ipgre_header_parse() needs to parse the tunnel's ip header and it uses mac_header to locate the iphdr. This got broken when gre tunneling was refactored as mac_header is no longer updated to point to iphdr. Introduce skb_pop_mac_header() helper to do the mac_header assignment and use it in ipgre_rcv() to fix msg_name parsing. Bug introduced in commit c54419321455 (GRE: Refactor GRE tunneling code.) Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15net: unix: allow set_peek_off to failSasha Levin
[ Upstream commit 12663bfc97c8b3fdb292428105dd92d563164050 ] unix_dgram_recvmsg() will hold the readlock of the socket until recv is complete. In the same time, we may try to setsockopt(SO_PEEK_OFF) which will hang until unix_dgram_recvmsg() will complete (which can take a while) without allowing us to break out of it, triggering a hung task spew. Instead, allow set_peek_off to fail, this way userspace will not hang. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ACPIPHP / radeon / nouveau: Fix VGA switcheroo problem related to hotplugRafael J. Wysocki
commit f244d8b623dae7a7bc695b0336f67729b95a9736 upstream. The changes in the ACPI-based PCI hotplug (ACPIPHP) subsystem made during the 3.12 development cycle uncovered a problem with VGA switcheroo that on some systems, when the device-specific method (ATPX in the radeon case, _DSM in the nouveau case) is used to turn off the discrete graphics, the BIOS generates ACPI hotplug events for that device and those events cause ACPIPHP to attempt to remove the device from the system (they are events for a device that was present previously and is not present any more, so that's what should be done according to the spec). Then, the system stops functioning correctly. Since the hotplug events in question were simply silently ignored previously, the least intrusive way to address that problem is to make ACPIPHP ignore them again. For this purpose, introduce a new ACPI device flag, no_hotplug, and modify ACPIPHP to ignore hotplug events for PCI devices whose ACPI companions have that flag set. Next, make the radeon and nouveau switcheroo detection code set the no_hotplug flag for the discrete graphics' ACPI companion. Fixes: bbd34fcdd1b2 (ACPI / hotplug / PCI: Register all devices under the given bridge) References: https://bugzilla.kernel.org/show_bug.cgi?id=61891 References: https://bugzilla.kernel.org/show_bug.cgi?id=64891 Reported-and-tested-by: Mike Lothian <mike@fireburn.co.uk> Reported-and-tested-by: <madcatx@atlas.cz> Reported-and-tested-by: Joaquín Aramendía <samsagax@gmail.com> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09aio/migratepages: make aio migrate pages saneBenjamin LaHaise
commit 8e321fefb0e60bae4e2a28d20fc4fa30758d27c6 upstream. The arbitrary restriction on page counts offered by the core migrate_page_move_mapping() code results in rather suspicious looking fiddling with page reference counts in the aio_migratepage() operation. To fix this, make migrate_page_move_mapping() take an extra_count parameter that allows aio to tell the code about its own reference count on the page being migrated. While cleaning up aio_migratepage(), make it validate that the old page being passed in is actually what aio_migratepage() expects to prevent misbehaviour in the case of races. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm: numa: guarantee that tlb_flush_pending updates are visible before page ↵Mel Gorman
table updates commit af2c1401e6f9177483be4fad876d0073669df9df upstream. According to documentation on barriers, stores issued before a LOCK can complete after the lock implying that it's possible tlb_flush_pending can be visible after a page table update. As per revised documentation, this patch adds a smp_mb__before_spinlock to guarantee the correct ordering. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm: fix TLB flush race between migration, and change_protection_rangeRik van Riel
commit 20841405940e7be0617612d521e206e4b6b325db upstream. There are a few subtle races, between change_protection_range (used by mprotect and change_prot_numa) on one side, and NUMA page migration and compaction on the other side. The basic race is that there is a time window between when the PTE gets made non-present (PROT_NONE or NUMA), and the TLB is flushed. During that time, a CPU may continue writing to the page. This is fine most of the time, however compaction or the NUMA migration code may come in, and migrate the page away. When that happens, the CPU may continue writing, through the cached translation, to what is no longer the current memory location of the process. This only affects x86, which has a somewhat optimistic pte_accessible. All other architectures appear to be safe, and will either always flush, or flush whenever there is a valid mapping, even with no permissions (SPARC). The basic race looks like this: CPU A CPU B CPU C load TLB entry make entry PTE/PMD_NUMA fault on entry read/write old page start migrating page change PTE/PMD to new page read/write old page [*] flush TLB reload TLB from new entry read/write new page lose data [*] the old page may belong to a new user at this point! The obvious fix is to flush remote TLB entries, by making sure that pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may still be accessible if there is a TLB flush pending for the mm. This should fix both NUMA migration and compaction. [mgorman@suse.de: fix build] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm: numa: avoid unnecessary disruption of NUMA hinting during migrationMel Gorman
commit de466bd628e8d663fdf3f791bc8db318ee85c714 upstream. do_huge_pmd_numa_page() handles the case where there is parallel THP migration. However, by the time it is checked the NUMA hinting information has already been disrupted. This patch adds an earlier check with some helpers. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libata: implement ATA_HORKAGE_NO_NCQ_TRIM and apply it to Micro M500 SSDsMarc Carino
commit f78dea064c5f7de07de4912a6e5136dbc443d614 upstream. Certain drives cannot handle queued TRIM commands properly, even though support is indicated in the IDENTIFY DEVICE buffer. This patch allows for disabling the commands for the affected drives and apply it to the Micron/Crucial M500 SSDs which exhibit incorrect protocol behavior when issued queued TRIM commands, which could lead to silent data corruption. tj: Merged two unnecessarily split patches and made minor edits including shortening horkage name. Signed-off-by: Marc Carino <marc.ceeeee@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/g/1387246554-7311-1-git-send-email-marc.ceeeee@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09auxvec.h: account for AT_HWCAP2 in AT_VECTOR_SIZE_BASEArd Biesheuvel
commit f60900f2609e893c7f8d0bccc7ada4947dac4cd5 upstream. Commit 2171364d1a92 ("powerpc: Add HWCAP2 aux entry") introduced a new AT_ auxv entry type AT_HWCAP2 but failed to update AT_VECTOR_SIZE_BASE accordingly. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Fixes: 2171364d1a92 (powerpc: Add HWCAP2 aux entry) Acked-by: Michael Neuling <michael@neuling.org> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09drm/radeon: 0x9649 is SUMO2 not SUMOAlex Deucher
commit d00adcc8ae9e22eca9d8af5f66c59ad9a74c90ec upstream. Fixes rendering corruption due to incorrect gfx configuration. bug: https://bugs.freedesktop.org/show_bug.cgi?id=63599 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09drm/radeon: expose render backend mask to the userspaceMarek Olšák
commit 439a1cfffe2c1a06e5a6394ccd5d18a8e89b15d3 upstream. This will allow userspace to correctly program the PA_SC_RASTER_CONFIG register, so it can be considered a fix. Signed-off-by: Marek Olšák <marek.olsak@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09target/file: Update hw_max_sectors based on current block_sizeNicholas Bellinger
commit 95cadace8f3959282e76ebf8b382bd0930807d2c upstream. This patch allows FILEIO to update hw_max_sectors based on the current max_bytes_per_io. This is required because vfs_[writev,readv]() can accept a maximum of 2048 iovecs per call, so the enforced hw_max_sectors really needs to be calculated based on block_size. This addresses a >= v3.5 bug where block_size=512 was rejecting > 1M sized I/O requests, because FD_MAX_SECTORS was hardcoded to 2048 for the block_size=4096 case. (v2: Use max_bytes_per_io instead of ->update_hw_max_sectors) Reported-by: Henrik Goldman <hg@x-formation.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09kexec: migrate to reboot cpuVivek Goyal
commit c97102ba96324da330078ad8619ba4dfe840dbe3 upstream. Commit 1b3a5d02ee07 ("reboot: move arch/x86 reboot= handling to generic kernel") moved reboot= handling to generic code. In the process it also removed the code in native_machine_shutdown() which are moving reboot process to reboot_cpu/cpu0. I guess that thought must have been that all reboot paths are calling migrate_to_reboot_cpu(), so we don't need this special handling. But kexec reboot path (kernel_kexec()) is not calling migrate_to_reboot_cpu() so above change broke kexec. Now reboot can happen on non-boot cpu and when INIT is sent in second kerneo to bring up BP, it brings down the machine. So start calling migrate_to_reboot_cpu() in kexec reboot path to avoid this problem. Bisected by WANG Chao. Reported-by: Matthew Whitehead <mwhitehe@redhat.com> Reported-by: Dave Young <dyoung@redhat.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Tested-by: Baoquan He <bhe@redhat.com> Tested-by: WANG Chao <chaowang@redhat.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20vfs: split out vfs_getattr_nosecJ. Bruce Fields
commit b7a6ec52dd4eced4a9bcda9ca85b3c8af84d3c90 upstream. The filehandle lookup code wants this version of getattr. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20x86, build, icc: Remove uninitialized_var() from compiler-intel.hH. Peter Anvin
commit 503cf95c061a0551eb684da364509297efbe55d9 upstream. When compiling with icc, <linux/compiler-gcc.h> ends up included because the icc environment defines __GNUC__. Thus, we neither need nor want to have this macro defined in both compiler-gcc.h and compiler-intel.h, and the fact that they are inconsistent just makes the compiler spew warnings. Reported-by: Sunil K. Pandey <sunil.k.pandey@intel.com> Cc: Kevin B. Smith <kevin.b.smith@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/n/tip-0mbwou1zt7pafij09b897lg3@git.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20usb: xhci: Link TRB must not occur within a USB payload burstDavid Laight
commit 35773dac5f862cb1c82ea151eba3e2f6de51ec3e upstream. Section 4.11.7.1 of rev 1.0 of the xhci specification states that a link TRB can only occur at a boundary between underlying USB frames (512 bytes for high speed devices). If this isn't done the USB frames aren't formatted correctly and, for example, the USB3 ethernet ax88179_178a card will stop sending (while still receiving) when running a netperf tcp transmit test with (say) and 8k buffer. This should be a candidate for stable, the ax88179_178a driver defaults to gso and tso enabled so it passes a lot of fragmented skb to the USB stack. Notes from Sarah: Discussion: http://marc.info/?l=linux-usb&m=138384509604981&w=2 This patch fixes a long-standing xHCI driver bug that was revealed by a change in 3.12 in the usb-net driver. Commit 638c5115a794981441246fa8fa5d95c1875af5ba "USBNET: support DMA SG" added support to use bulk endpoint scatter-gather (urb->sg). Only the USB ethernet drivers trigger this bug, because the mass storage driver sends sg list entries in page-sized chunks. This patch only fixes the issue for bulk endpoint scatter-gather. The problem will still occur for periodic endpoints, because hosts will interpret no-op transfers as a request to skip a service interval, which is not what we want. Luckily, the USB core isn't set up for scatter-gather on isochronous endpoints, and no USB drivers use scatter-gather for interrupt endpoints. Document this known limitation so that developers won't try to use urb->sg for interrupt endpoints until this issue is fixed. The more comprehensive fix would be to allow link TRBs in the middle of the endpoint ring and revert this patch, but that fix would touch too much code to be allowed in for stable. This patch should be backported to kernels as old as 3.12, that contain the commit 638c5115a794981441246fa8fa5d95c1875af5ba "USBNET: support DMA SG". Without this patch, the USB network device gets wedged, and stops sending packets. Mark Lord confirms this patch fixes the regression: http://marc.info/?l=linux-netdev&m=138487107625966&w=2 Signed-off-by: David Laight <david.laight@aculab.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Tested-by: Mark Lord <mlord@pobox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20PCI: Disable Bus Master only on kexec rebootKhalid Aziz
commit 4fc9bbf98fd66f879e628d8537ba7c240be2b58e upstream. Add a flag to tell the PCI subsystem that kernel is shutting down in preparation to kexec a kernel. Add code in PCI subsystem to use this flag to clear Bus Master bit on PCI devices only in case of kexec reboot. This fixes a power-off problem on Acer Aspire V5-573G and likely other machines and avoids any other issues caused by clearing Bus Master bit on PCI devices in normal shutdown path. The problem was introduced by b566a22c2332 ("PCI: disable Bus Master on PCI device shutdown"). This patch is based on discussion at http://marc.info/?l=linux-pci&m=138425645204355&w=2 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63861 Reported-by: Chang Liu <cl91tp@gmail.com> Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20ALSA: memalloc.h - fix wrong truncation of dma_addr_tStefano Panella
commit 932e9dec380c67ec15ac3eb073bb55797d8b4801 upstream. When running a 32bit kernel the hda_intel driver is still reporting a 64bit dma_mask if the HW supports it. From sound/pci/hda/hda_intel.c: /* allow 64bit DMA address if supported by H/W */ if ((gcap & ICH6_GCAP_64OK) && !pci_set_dma_mask(pci, DMA_BIT_MASK(64))) pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(64)); else { pci_set_dma_mask(pci, DMA_BIT_MASK(32)); pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(32)); } which means when there is a call to dma_alloc_coherent from snd_malloc_dev_pages a machine address bigger than 32bit can be returned. This can be true in particular if running the 32bit kernel as a pv dom0 under the Xen Hypervisor or PAE on bare metal. The problem is that when calling setup_bdle to program the BLE the dma_addr_t returned from the dma_alloc_coherent is wrongly truncated from snd_sgbuf_get_addr if running a 32bit kernel: static inline dma_addr_t snd_sgbuf_get_addr(struct snd_dma_buffer *dmab, size_t offset) { struct snd_sg_buf *sgbuf = dmab->private_data; dma_addr_t addr = sgbuf->table[offset >> PAGE_SHIFT].addr; addr &= PAGE_MASK; return addr + offset % PAGE_SIZE; } where PAGE_MASK in a 32bit kernel is zeroing the upper 32bit af addr. Without this patch the HW will fetch the 32bit truncated address, which is not the one obtained from dma_alloc_coherent and will result to a non working audio but can corrupt host memory at a random location. The current patch apply to v3.13-rc3-74-g6c843f5 Signed-off-by: Stefano Panella <stefano.panella@citrix.com> Reviewed-by: Frediano Ziglio <frediano.ziglio@citrix.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20ALSA: compress: Fix 64bit ABI incompatibilityTakashi Iwai
commit 6733cf572a9e20db2b7580a5dd39d5782d571eec upstream. snd_pcm_uframes_t is defined as unsigned long so it would take different sizes depending on 32 or 64bit architectures. As we don't want this ABI incompatibility, and there is no real 64bit user yet, let's make it the fixed size with __u32. Also bump the protocol version number to 0.1.2. Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11crypto: scatterwalk - Use sg_chain_ptr on chain entriesTom Lendacky
commit 389a5390583a18e45bc4abd4439291abec5e7a63 upstream. Now that scatterwalk_sg_chain sets the chain pointer bit the sg_page call in scatterwalk_sg_next hits a BUG_ON when CONFIG_DEBUG_SG is enabled. Use sg_chain_ptr instead of sg_page on a chain entry. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11SCSI: Disable WRITE SAME for RAID and virtual host adapter driversMartin K. Petersen
commit 54b2b50c20a61b51199bedb6e5d2f8ec2568fb43 upstream. Some host adapters do not pass commands through to the target disk directly. Instead they provide an emulated target which may or may not accurately report its capabilities. In some cases the physical device characteristics are reported even when the host adapter is processing commands on the device's behalf. This can lead to adapter firmware hangs or excessive I/O errors. This patch disables WRITE SAME for devices connected to host adapters that provide an emulated target. Driver writers can disable WRITE SAME by setting the no_write_same flag in the host adapter template. [jejb: fix up rejections due to eh_deadline patch] Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11efivars, efi-pstore: Hold off deletion of sysfs entry until the scan is ↵Seiji Aguchi
completed commit e0d59733f6b1796b8d6692642c87d7dd862c3e3a upstream. Currently, when mounting pstore file system, a read callback of efi_pstore driver runs mutiple times as below. - In the first read callback, scan efivar_sysfs_list from head and pass a kmsg buffer of a entry to an upper pstore layer. - In the second read callback, rescan efivar_sysfs_list from the entry and pass another kmsg buffer to it. - Repeat the scan and pass until the end of efivar_sysfs_list. In this process, an entry is read across the multiple read function calls. To avoid race between the read and erasion, the whole process above is protected by a spinlock, holding in open() and releasing in close(). At the same time, kmemdup() is called to pass the buffer to pstore filesystem during it. And then, it causes a following lockdep warning. To make the dynamic memory allocation runnable without taking spinlock, holding off a deletion of sysfs entry if it happens while scanning it via efi_pstore, and deleting it after the scan is completed. To implement it, this patch introduces two flags, scanning and deleting, to efivar_entry. On the code basis, it seems that all the scanning and deleting logic is not needed because __efivars->lock are not dropped when reading from the EFI variable store. But, the scanning and deleting logic is still needed because an efi-pstore and a pstore filesystem works as follows. In case an entry(A) is found, the pointer is saved to psi->data. And efi_pstore_read() passes the entry(A) to a pstore filesystem by releasing __efivars->lock. And then, the pstore filesystem calls efi_pstore_read() again and the same entry(A), which is saved to psi->data, is used for resuming to scan a sysfs-list. So, to protect the entry(A), the logic is needed. [ 1.143710] ------------[ cut here ]------------ [ 1.144058] WARNING: CPU: 1 PID: 1 at kernel/lockdep.c:2740 lockdep_trace_alloc+0x104/0x110() [ 1.144058] DEBUG_LOCKS_WARN_ON(irqs_disabled_flags(flags)) [ 1.144058] Modules linked in: [ 1.144058] CPU: 1 PID: 1 Comm: systemd Not tainted 3.11.0-rc5 #2 [ 1.144058] 0000000000000009 ffff8800797e9ae0 ffffffff816614a5 ffff8800797e9b28 [ 1.144058] ffff8800797e9b18 ffffffff8105510d 0000000000000080 0000000000000046 [ 1.144058] 00000000000000d0 00000000000003af ffffffff81ccd0c0 ffff8800797e9b78 [ 1.144058] Call Trace: [ 1.144058] [<ffffffff816614a5>] dump_stack+0x54/0x74 [ 1.144058] [<ffffffff8105510d>] warn_slowpath_common+0x7d/0xa0 [ 1.144058] [<ffffffff8105517c>] warn_slowpath_fmt+0x4c/0x50 [ 1.144058] [<ffffffff8131290f>] ? vsscanf+0x57f/0x7b0 [ 1.144058] [<ffffffff810bbd74>] lockdep_trace_alloc+0x104/0x110 [ 1.144058] [<ffffffff81192da0>] __kmalloc_track_caller+0x50/0x280 [ 1.144058] [<ffffffff815147bb>] ? efi_pstore_read_func.part.1+0x12b/0x170 [ 1.144058] [<ffffffff8115b260>] kmemdup+0x20/0x50 [ 1.144058] [<ffffffff815147bb>] efi_pstore_read_func.part.1+0x12b/0x170 [ 1.144058] [<ffffffff81514800>] ? efi_pstore_read_func.part.1+0x170/0x170 [ 1.144058] [<ffffffff815148b4>] efi_pstore_read_func+0xb4/0xe0 [ 1.144058] [<ffffffff81512b7b>] __efivar_entry_iter+0xfb/0x120 [ 1.144058] [<ffffffff8151428f>] efi_pstore_read+0x3f/0x50 [ 1.144058] [<ffffffff8128d7ba>] pstore_get_records+0x9a/0x150 [ 1.158207] [<ffffffff812af25c>] ? selinux_d_instantiate+0x1c/0x20 [ 1.158207] [<ffffffff8128ce30>] ? parse_options+0x80/0x80 [ 1.158207] [<ffffffff8128ced5>] pstore_fill_super+0xa5/0xc0 [ 1.158207] [<ffffffff811ae7d2>] mount_single+0xa2/0xd0 [ 1.158207] [<ffffffff8128ccf8>] pstore_mount+0x18/0x20 [ 1.158207] [<ffffffff811ae8b9>] mount_fs+0x39/0x1b0 [ 1.158207] [<ffffffff81160550>] ? __alloc_percpu+0x10/0x20 [ 1.158207] [<ffffffff811c9493>] vfs_kern_mount+0x63/0xf0 [ 1.158207] [<ffffffff811cbb0e>] do_mount+0x23e/0xa20 [ 1.158207] [<ffffffff8115b51b>] ? strndup_user+0x4b/0xf0 [ 1.158207] [<ffffffff811cc373>] SyS_mount+0x83/0xc0 [ 1.158207] [<ffffffff81673cc2>] system_call_fastpath+0x16/0x1b [ 1.158207] ---[ end trace 61981bc62de9f6f4 ]--- Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Tested-by: Madper Xie <cxie@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11ASoC: dapm: Use SND_SOC_DAPM_INIT_REG_VAL in SND_SOC_DAPM_MUXStephen Warren
commit faf6615bf05bc5cecc6e22013b9cb21c77784fd1 upstream. SND_SOC_DAPM_MUX() doesn't currently initialize the .mask field. This results in the mux never affecting HW, since no bits are ever set or cleared. Fix SND_SOC_DAPM_MUX() to use SND_SOC_DAPM_INIT_REG_VAL() to set up the reg, shift, on_val, and off_val fields like almost all other SND_SOC_xxx() macros. It looks like this was a "typo" in the fixed commit linked below. This makes the speakers on the Toshiba AC100 (PAZ00) laptop work again. Fixes: de9ba98b6d26 ("ASoC: dapm: Make widget power register settings more flexible") Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11crypto: scatterwalk - Set the chain pointer indication bitTom Lendacky
commit 41da8b5adba77e22584f8b45f9641504fa885308 upstream. The scatterwalk_crypto_chain function invokes the scatterwalk_sg_chain function to chain two scatterlists, but the chain pointer indication bit is not set. When the resulting scatterlist is used, for example, by sg_nents to count the number of scatterlist entries, a segfault occurs because sg_nents does not follow the chain pointer to the chained scatterlist. Update scatterwalk_sg_chain to set the chain pointer indication bit as is done by the sg_chain function. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08take anon inode allocation to libfs.cAl Viro
commit 6987843ff7e836ea65b554905aec34d2fad05c94 upstream. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08mm: numa: return the number of base pages altered by protection changesMel Gorman
commit 72403b4a0fbdf433c1fe0127e49864658f6f6468 upstream. Commit 0255d4918480 ("mm: Account for a THP NUMA hinting update as one PTE update") was added to account for the number of PTE updates when marking pages prot_numa. task_numa_work was using the old return value to track how much address space had been updated. Altering the return value causes the scanner to do more work than it is configured or documented to in a single unit of work. This patch reverts that commit and accounts for the number of THP updates separately in vmstat. It is up to the administrator to interpret the pair of values correctly. This is a straight-forward operation and likely to only be of interest when actively debugging NUMA balancing problems. The impact of this patch is that the NUMA PTE scanner will scan slower when THP is enabled and workloads may converge slower as a result. On the flip size system CPU usage should be lower than recent tests reported. This is an illustrative example of a short single JVM specjbb test specjbb 3.12.0 3.12.0 vanilla acctupdates TPut 1 26143.00 ( 0.00%) 25747.00 ( -1.51%) TPut 7 185257.00 ( 0.00%) 183202.00 ( -1.11%) TPut 13 329760.00 ( 0.00%) 346577.00 ( 5.10%) TPut 19 442502.00 ( 0.00%) 460146.00 ( 3.99%) TPut 25 540634.00 ( 0.00%) 549053.00 ( 1.56%) TPut 31 512098.00 ( 0.00%) 519611.00 ( 1.47%) TPut 37 461276.00 ( 0.00%) 474973.00 ( 2.97%) TPut 43 403089.00 ( 0.00%) 414172.00 ( 2.75%) 3.12.0 3.12.0 vanillaacctupdates User 5169.64 5184.14 System 100.45 80.02 Elapsed 252.75 251.85 Performance is similar but note the reduction in system CPU time. While this showed a performance gain, it will not be universal but at least it'll be behaving as documented. The vmstats are obviously different but here is an obvious interpretation of them from mmtests. 3.12.0 3.12.0 vanillaacctupdates NUMA page range updates 1408326 11043064 NUMA huge PMD updates 0 21040 NUMA PTE updates 1408326 291624 "NUMA page range updates" == nr_pte_updates and is the value returned to the NUMA pte scanner. NUMA huge PMD updates were the number of THP updates which in combination can be used to calculate how many ptes were updated from userspace. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Alex Thorlton <athorlton@sgi.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08netfilter: push reasm skb through instead of original frag skbsJiri Pirko
[ Upstream commit 6aafeef03b9d9ecf255f3a80ed85ee070260e1ae ] Pushing original fragments through causes several problems. For example for matching, frags may not be matched correctly. Take following example: <example> On HOSTA do: ip6tables -I INPUT -p icmpv6 -j DROP ip6tables -I INPUT -p icmpv6 -m icmp6 --icmpv6-type 128 -j ACCEPT and on HOSTB you do: ping6 HOSTA -s2000 (MTU is 1500) Incoming echo requests will be filtered out on HOSTA. This issue does not occur with smaller packets than MTU (where fragmentation does not happen) </example> As was discussed previously, the only correct solution seems to be to use reassembled skb instead of separete frags. Doing this has positive side effects in reducing sk_buff by one pointer (nfct_reasm) and also the reams dances in ipvs and conntrack can be removed. Future plan is to remove net/ipv6/netfilter/nf_conntrack_reasm.c entirely and use code in net/ipv6/reassembly.c instead. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08inet: fix addr_len/msg->msg_namelen assignment in recv_error and rxpmtu ↵Hannes Frederic Sowa
functions [ Upstream commit 85fbaa75037d0b6b786ff18658ddf0b4014ce2a4 ] Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage of uninitialized memory to user in recv syscalls") conditionally updated addr_len if the msg_name is written to. The recv_error and rxpmtu functions relied on the recvmsg functions to set up addr_len before. As this does not happen any more we have to pass addr_len to those functions as well and set it to the size of the corresponding sockaddr length. This broke traceroute and such. Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls") Reported-by: Brad Spengler <spender@grsecurity.net> Reported-by: Tom Labanowski Cc: mpb <mpb.mail@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ] This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08pkt_sched: fq: fix pacing for small framesEric Dumazet
[ Upstream commit f52ed89971adbe79b6438c459814034707b8ab91 ] For performance reasons, sch_fq tried hard to not setup timers for every sent packet, using a quantum based heuristic : A delay is setup only if the flow exhausted its credit. Problem is that application limited flows can refill their credit for every queued packet, and they can evade pacing. This problem can also be triggered when TCP flows use small MSS values, as TSO auto sizing builds packets that are smaller than the default fq quantum (3028 bytes) This patch adds a 40 ms delay to guard flow credit refill. Fixes: afe4fd062416 ("pkt_sched: fq: Fair Queue packet scheduler") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Maciej Żenczykowski <maze@google.com> Cc: Willem de Bruijn <willemb@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08pkt_sched: fq: warn users using defrateEric Dumazet
[ Upstream commit 65c5189a2b57b9aa1d89e4b79da39928257c9505 ] Commit 7eec4174ff29 ("pkt_sched: fq: fix non TCP flows pacing") obsoleted TCA_FQ_FLOW_DEFAULT_RATE without notice for the users. Suggested by David Miller Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08random32: fix off-by-one in seeding requirementDaniel Borkmann
[ Upstream commit 51c37a70aaa3f95773af560e6db3073520513912 ] For properly initialising the Tausworthe generator [1], we have a strict seeding requirement, that is, s1 > 1, s2 > 7, s3 > 15. Commit 697f8d0348 ("random32: seeding improvement") introduced a __seed() function that imposes boundary checks proposed by the errata paper [2] to properly ensure above conditions. However, we're off by one, as the function is implemented as: "return (x < m) ? x + m : x;", and called with __seed(X, 1), __seed(X, 7), __seed(X, 15). Thus, an unwanted seed of 1, 7, 15 would be possible, whereas the lower boundary should actually be of at least 2, 8, 16, just as GSL does. Fix this, as otherwise an initialization with an unwanted seed could have the effect that Tausworthe's PRNG properties cannot not be ensured. Note that this PRNG is *not* used for cryptography in the kernel. [1] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme.ps [2] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme2.ps Joint work with Hannes Frederic Sowa. Fixes: 697f8d0348a6 ("random32: seeding improvement") Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Florian Weimer <fweimer@redhat.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04mfd: rtsx: Modify rts5249_optimize_phyWei WANG
commit 26b818511c6562ce372566c219a2ef1afea35fe6 upstream. In some platforms, specially Thinkpad series, rts5249 won't be initialized properly. So we need adjust some phy parameters to improve the compatibility issue. It is a little different between simulation and real chip. We have no idea about which configuration is better before tape-out. We set default settings according to simulation, but need to tune these parameters after getting the real chip. I can't explain every change in detail here. The below information is just a rough description: PHY_REG_REV: Disable internal clkreq_tx, enable rx_pwst PHY_BPCR: No change, just turn the magic number to macro definitions PHY_PCR: Change OOBS sensitivity, from 60mV to 90mV PHY_RCR2: Control charge-pump current automatically PHY_FLD4: Use TX cmu reference clock PHY_RDR: Change RXDSEL from 30nF to 1.9nF PHY_RCR1: Change the duration between adp_st and asserting cp_en from 0.32 us to 0.64us PHY_FLD3: Adjust internal timers PHY_TUNE: Fine tune the regulator12 output voltage Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Lee Jones <lee.jones@linaro.org> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04tracing: Allow events to have NULL stringsSteven Rostedt (Red Hat)
commit 4e58e54754dc1fec21c3a9e824bc108b05fdf46e upstream. If an TRACE_EVENT() uses __assign_str() or __get_str on a NULL pointer then the following oops will happen: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<c127a17b>] strlen+0x10/0x1a *pde = 00000000 ^M Oops: 0000 [#1] PREEMPT SMP Modules linked in: CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.13.0-rc1-test+ #2 Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006^M task: f5cde9f0 ti: f5e5e000 task.ti: f5e5e000 EIP: 0060:[<c127a17b>] EFLAGS: 00210046 CPU: 1 EIP is at strlen+0x10/0x1a EAX: 00000000 EBX: c2472da8 ECX: ffffffff EDX: c2472da8 ESI: c1c5e5fc EDI: 00000000 EBP: f5e5fe84 ESP: f5e5fe80 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 CR0: 8005003b CR2: 00000000 CR3: 01f32000 CR4: 000007d0 Stack: f5f18b90 f5e5feb8 c10687a8 0759004f 00000005 00000005 00000005 00200046 00000002 00000000 c1082a93 f56c7e28 c2472da8 c1082a93 f5e5fee4 c106bc61^M 00000000 c1082a93 00000000 00000000 00000001 00200046 00200082 00000000 Call Trace: [<c10687a8>] ftrace_raw_event_lock+0x39/0xc0 [<c1082a93>] ? ktime_get+0x29/0x69 [<c1082a93>] ? ktime_get+0x29/0x69 [<c106bc61>] lock_release+0x57/0x1a5 [<c1082a93>] ? ktime_get+0x29/0x69 [<c10824dd>] read_seqcount_begin.constprop.7+0x4d/0x75 [<c1082a93>] ? ktime_get+0x29/0x69^M [<c1082a93>] ktime_get+0x29/0x69 [<c108a46a>] __tick_nohz_idle_enter+0x1e/0x426 [<c10690e8>] ? lock_release_holdtime.part.19+0x48/0x4d [<c10bc184>] ? time_hardirqs_off+0xe/0x28 [<c1068c82>] ? trace_hardirqs_off_caller+0x3f/0xaf [<c108a8cb>] tick_nohz_idle_enter+0x59/0x62 [<c1079242>] cpu_startup_entry+0x64/0x192 [<c102299c>] start_secondary+0x277/0x27c Code: 90 89 c6 89 d0 88 c4 ac 38 e0 74 09 84 c0 75 f7 be 01 00 00 00 89 f0 48 5e 5d c3 55 89 e5 57 66 66 66 66 90 83 c9 ff 89 c7 31 c0 <f2> ae f7 d1 8d 41 ff 5f 5d c3 55 89 e5 57 66 66 66 66 90 31 ff EIP: [<c127a17b>] strlen+0x10/0x1a SS:ESP 0068:f5e5fe80 CR2: 0000000000000000 ---[ end trace 01bc47bf519ec1b2 ]--- New tracepoints have been added that have allowed for NULL pointers being assigned to strings. To fix this, change the TRACE_EVENT() code to check for NULL and if it is, it will assign "(null)" to it instead (similar to what glibc printf does). Reported-by: Shuah Khan <shuah.kh@samsung.com> Reported-by: Jovi Zhangwei <jovi.zhangwei@gmail.com> Link: http://lkml.kernel.org/r/CAGdX0WFeEuy+DtpsJzyzn0343qEEjLX97+o1VREFkUEhndC+5Q@mail.gmail.com Link: http://lkml.kernel.org/r/528D6972.9010702@samsung.com Fixes: 9cbf117662e2 ("tracing/events: provide string with undefined size support") Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ACPI / hotplug: Fix conflicted PCI bridge notify handlersToshi Kani
commit ca499fc87ed945094d952da0eb7eea7dbeb1feec upstream. The PCI host bridge scan handler installs its own notify handler, handle_hotplug_event_root(), by itself. Nevertheless, the ACPI hotplug framework also installs the common notify handler, acpi_hotplug_notify_cb(), for PCI root bridges. This causes acpi_hotplug_notify_cb() to call _OST method with unsupported error as hotplug.enabled is not set. To address this issue, introduce hotplug.ignore flag, which indicates that the scan handler installs its own notify handler by itself. The ACPI hotplug framework does not install the common notify handler when this flag is set. Signed-off-by: Toshi Kani <toshi.kani@hp.com> [rjw: Changed the name of the new flag] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04mtd: map: fixed bug in 64-bit systemsWang Haitao
commit a4d62babf988fe5dfde24437fa135ef147bc7aa0 upstream. Hardware: CPU: XLP832,the 64-bit OS NOR Flash:S29GL128S 128M Software: Kernel:2.6.32.41 Filesystem:JFFS2 When writing files, errors appear: Write len 182 but return retlen 180 Write of 182 bytes at 0x072c815c failed. returned -5, retlen 180 Write len 186 but return retlen 184 Write of 186 bytes at 0x072caff4 failed. returned -5, retlen 184 These errors exist only in 64-bit systems,not in 32-bit systems. After analysis, we found that the left shift operation is wrong in map_word_load_partial. For instance: unsigned char buf[3] ={0x9e,0x3a,0xea}; map_bankwidth(map) is 4; for (i=0; i < 3; i++) { int bitpos; bitpos = (map_bankwidth(map)-1-i)*8; orig.x[0] &= ~(0xff << bitpos); orig.x[0] |= buf[i] << bitpos; } The value of orig.x[0] is expected to be 0x9e3aeaff, but in this situation(64-bit System) we'll get the wrong value of 0xffffffff9e3aeaff due to the 64-bit sign extension: buf[i] is defined as "unsigned char" and the left-shift operation will convert it to the type of "signed int", so when left-shift buf[i] by 24 bits, the final result will get the wrong value: 0xffffffff9e3aeaff. If the left-shift bits are less than 24, then sign extension will not occur. Whereas the bankwidth of the nor flash we used is 4, therefore this BUG emerges. Signed-off-by: Pang Xunlei <pang.xunlei@zte.com.cn> Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn> Signed-off-by: Lu Zhongjun <lu.zhongjun@zte.com.cn> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ipc, msg: fix message length check for negative valuesMathias Krause
commit 4e9b45a19241354daec281d7a785739829b52359 upstream. On 64 bit systems the test for negative message sizes is bogus as the size, which may be positive when evaluated as a long, will get truncated to an int when passed to load_msg(). So a long might very well contain a positive value but when truncated to an int it would become negative. That in combination with a small negative value of msg_ctlmax (which will be promoted to an unsigned type for the comparison against msgsz, making it a big positive value and therefore make it pass the check) will lead to two problems: 1/ The kmalloc() call in alloc_msg() will allocate a too small buffer as the addition of alen is effectively a subtraction. 2/ The copy_from_user() call in load_msg() will first overflow the buffer with userland data and then, when the userland access generates an access violation, the fixup handler copy_user_handle_tail() will try to fill the remainder with zeros -- roughly 4GB. That almost instantly results in a system crash or reset. ,-[ Reproducer (needs to be run as root) ]-- | #include <sys/stat.h> | #include <sys/msg.h> | #include <unistd.h> | #include <fcntl.h> | | int main(void) { | long msg = 1; | int fd; | | fd = open("/proc/sys/kernel/msgmax", O_WRONLY); | write(fd, "-1", 2); | close(fd); | | msgsnd(0, &msg, 0xfffffff0, IPC_NOWAIT); | | return 0; | } '--- Fix the issue by preventing msgsz from getting truncated by consistently using size_t for the message length. This way the size checks in do_msgsnd() could still be passed with a negative value for msg_ctlmax but we would fail on the buffer allocation in that case and error out. Also change the type of m_ts from int to size_t to avoid similar nastiness in other code paths -- it is used in similar constructs, i.e. signed vs. unsigned checks. It should never become negative under normal circumstances, though. Setting msg_ctlmax to a negative value is an odd configuration and should be prevented. As that might break existing userland, it will be handled in a separate commit so it could easily be reverted and reworked without reintroducing the above described bug. Hardening mechanisms for user copy operations would have catched that bug early -- e.g. checking slab object sizes on user copy operations as the usercopy feature of the PaX patch does. Or, for that matter, detect the long vs. int sign change due to truncation, as the size overflow plugin of the very same patch does. [akpm@linux-foundation.org: fix i386 min() warnings] Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Pax Team <pageexec@freemail.hu> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Brad Spengler <spender@grsecurity.net> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04rbtree: fix rbtree_postorder_for_each_entry_safe() iteratorJan Kara
commit 1310a5a99d900ee30b9f171146406bde0c6c2bd4 upstream. The iterator rbtree_postorder_for_each_entry_safe() relies on pointer underflow behavior when testing for loop termination. In particular it expects that &rb_entry(NULL, type, field)->field is NULL. But the result of this expression is not defined by a C standard and some gcc versions (e.g. 4.3.4) assume the above expression can never be equal to NULL. The net result is an oops because the iteration is not properly terminated. Fix the problem by modifying the iterator to avoid pointer underflows. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Michel Lespinasse <walken@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29usb: Don't enable USB 2.0 Link PM by default.Sarah Sharp
commit de68bab4fa96014cfaa6fcbcdb9750e32969fb86 upstream. How it's supposed to work: -------------------------- USB 2.0 Link PM is a lower power state that some newer USB 2.0 devices support. USB 3.0 devices certified by the USB-IF are required to support it if they are plugged into a USB 2.0 only port, or a USB 2.0 cable is used. USB 2.0 Link PM requires both a USB device and a host controller that supports USB 2.0 hardware-enabled LPM. USB 2.0 Link PM is designed to be enabled once by software, and the host hardware handles transitions to the L1 state automatically. The premise of USB 2.0 Link PM is to be able to put the device into a lower power link state when the bus is idle or the device NAKs USB IN transfers for a specified amount of time. ...but hardware is broken: -------------------------- It turns out many USB 3.0 devices claim to support USB 2.0 Link PM (by setting the LPM bit in their USB 2.0 BOS descriptor), but they don't actually implement it correctly. This manifests as the USB device refusing to respond to transfers when it is plugged into a USB 2.0 only port under the Haswell-ULT/Lynx Point LP xHCI host. These devices pass the xHCI driver's simple test to enable USB 2.0 Link PM, wait for the port to enter L1, and then bring it back into L0. They only start to break when L1 entry is interleaved with transfers. Some devices then fail to respond to the next control transfer (usually a Set Configuration). This results in devices never enumerating. Other mass storage devices (such as a later model Western Digital My Passport USB 3.0 hard drive) respond fine to going into L1 between control transfers. They ACK the entry, come out of L1 when the host needs to send a control transfer, and respond properly to those control transfers. However, when the first READ10 SCSI command is sent, the device NAKs the data phase while it's reading from the spinning disk. Eventually, the host requests to put the link into L1, and the device ACKs that request. Then it never responds to the data phase of the READ10 command. This results in not being able to read from the drive. Some mass storage devices (like the Corsair Survivor USB 3.0 flash drive) are well behaved. They ACK the entry into L1 during control transfers, and when SCSI commands start coming in, they NAK the requests to go into L1, because they need to be at full power. Not all USB 3.0 devices advertise USB 2.0 link PM support. My Point Grey USB 3.0 webcam advertises itself as a USB 2.1 device, but doesn't have a USB 2.0 BOS descriptor, so we don't enable USB 2.0 Link PM. I suspect that means the device isn't certified. What do we do about it? ----------------------- There's really no good way for the kernel to test these devices. Therefore, the kernel needs to disable USB 2.0 Link PM by default, and distros will have to enable it by writing 1 to the sysfs file /sys/bus/usb/devices/../power/usb2_hardware_lpm. Rip out the xHCI Link PM test, since it's not sufficient to detect these buggy devices, and don't automatically enable LPM after the device is addressed. This patch should be backported to kernels as old as 3.11, that contain the commit a558ccdcc71c7770c5e80c926a31cfe8a3892a09 "usb: xhci: add USB2 Link power management BESL support". Without this fix, some USB 3.0 devices will not enumerate or work properly under USB 2.0 ports on Haswell-ULT systems. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29NFSv4.2: Fix a mismatch between Linux labeled NFS and the NFSv4.2 specTrond Myklebust
commit f3f5a0f8cc40b942f4c0ae117df82eeb65f07d4d upstream. In the spec, the security label attribute id is '80', which means that it should be bit number 80-64 == 16 in the 3rd word of the bitmap. Fixes: 4488cc96c581: NFS: Add NFSv4.2 protocol constants Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: compress: fix drain calls blocking other compress functions (v6)Vinod Koul
commit f44f2a5417b2968a8724b352cc0b2545a6bcb1f4 upstream. The drain and drain_notify callback were blocked by low level driver until the draining was complete. Due to this being invoked with big fat mutex held, others ops like reading timestamp, calling pause, drop were blocked. So to fix this we add a new snd_compr_drain_notify() API. This would be required to be invoked by low level driver when drain or partial drain has been completed by the DSP. Thus we make the drain and partial_drain callback as non blocking and driver returns immediately after notifying DSP. The waiting is done while releasing the lock so that other ops can go ahead. [ The commit 917f4b5cba78 was wrongly applied from the preliminary patch. This commit corrects to the final version. Sorry for inconvenience! -- tiwai ] Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: compress: fix drain calls blocking other compress functionsVinod Koul
commit 917f4b5cba78980a527098a910d94139d3e82c8d upstream. The drain and drain_notify callback were blocked by low level driver untill the draining was complete. Due to this being invoked with big fat mutex held, others ops like reading timestamp, calling pause, drop were blocked. So to fix this we add a new snd_compr_drain_notify() API. This would be required to be invoked by low level driver when drain or partial drain has been completed by the DSP. Thus we make the drain and partial_drain callback as non blocking and driver returns immediately after notifying DSP. The waiting is done while relasing the lock so that other ops can go ahead. Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29exec/ptrace: fix get_dumpable() incorrect testsKees Cook
commit d049f74f2dbe71354d43d393ac3a188947811348 upstream. The get_dumpable() return value is not boolean. Most users of the function actually want to be testing for non-SUID_DUMP_USER(1) rather than SUID_DUMP_DISABLE(0). The SUID_DUMP_ROOT(2) is also considered a protected state. Almost all places did this correctly, excepting the two places fixed in this patch. Wrong logic: if (dumpable == SUID_DUMP_DISABLE) { /* be protective */ } or if (dumpable == 0) { /* be protective */ } or if (!dumpable) { /* be protective */ } Correct logic: if (dumpable != SUID_DUMP_USER) { /* be protective */ } or if (dumpable != 1) { /* be protective */ } Without this patch, if the system had set the sysctl fs/suid_dumpable=2, a user was able to ptrace attach to processes that had dropped privileges to that user. (This may have been partially mitigated if Yama was enabled.) The macros have been moved into the file that declares get/set_dumpable(), which means things like the ia64 code can see them too. CVE-2013-2929 Reported-by: Vasily Kulikov <segoon@openwall.com> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29sched, idle: Fix the idle polling state logicPeter Zijlstra
commit ea8117478918a4734586d35ff530721b682425be upstream. Mike reported that commit 7d1a9417 ("x86: Use generic idle loop") regressed several workloads and caused excessive reschedule interrupts. The patch in question failed to notice that the x86 code had an inverted sense of the polling state versus the new generic code (x86: default polling, generic: default !polling). Fix the two prominent x86 mwait based idle drivers and introduce a few new generic polling helpers (fixing the wrong smp_mb__after_clear_bit usage). Also switch the idle routines to using tif_need_resched() which is an immediate TIF_NEED_RESCHED test as opposed to need_resched which will end up being slightly different. Reported-by: Mike Galbraith <bitbucket@online.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: lenb@kernel.org Cc: tglx@linutronix.de Link: http://lkml.kernel.org/n/tip-nc03imb0etuefmzybzj7sprf@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-20ipv6: reset dst.expires value when clearing expire flagHannes Frederic Sowa
[ Upstream commit 01ba16d6ec85a1ec4669c75513a76b61ec53ee50 ] On receiving a packet too big icmp error we update the expire value by calling rt6_update_expires. This function uses dst_set_expires which is implemented that it can only reduce the expiration value of the dst entry. If we insert new routing non-expiry information into the ipv6 fib where we already have a matching rt6_info we only clear the RTF_EXPIRES flag in rt6i_flags and leave the dst.expires value as is. When new mtu information arrives for that cached dst_entry we again call dst_set_expires. This time it won't update the dst.expire value because we left the dst.expire value intact from the last update. So dst_set_expires won't touch dst.expires. Fix this by resetting dst.expires when clearing the RTF_EXPIRE flag. dst_set_expires checks for a zero expiration and updates the dst.expires. In the past this (not updating dst.expires) was necessary because dst.expire was placed in a union with the dst_entry *from reference and rt6_clean_expires did assign NULL to it. This split happend in ecd9883724b78cc72ed92c98bcb1a46c764fff21 ("ipv6: fix race condition regarding dst->expires and dst->from"). Reported-by: Steinar H. Gunderson <sgunderson@bigfoot.com> Reported-by: Valentijn Sessink <valentyn@blub.net> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Eric Dumazet <edumazet@google.com> Tested-by: Valentijn Sessink <valentyn@blub.net> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
