commit d7591f0c41ce3e67600a982bab6989ef0f07b3ce upstream.
The three variants use same copy&pasted code, condense this into a
helper and use that.
Make sure info.name is 0-terminated.
commit 0188346f21e6546498c2a0f84888797ad4063fc5 upstream.
Always returned 0.
commit ce683e5f9d045e5d67d1312a42b359cb2ab2a13c upstream.
We're currently asserting that targetoff + targetsize <= nextoff.
Extend it to also check that targetoff is >= sizeof(xt_entry).
Since this is generic code, add an argument pointing to the start of the
match/target, we can then derive the base structure size from the delta.
We also need the e->elems pointer in a followup change to validate matches.
commit fc1221b3a163d1386d1052184202d5dc50d302d1 upstream.
32bit rulesets have different layout and alignment requirements, so once
more integrity checks get added to xt_check_entry_offsets it will reject
well-formed 32bit rulesets.
commit 7d35812c3214afa5b37a675113555259cfd67b98 upstream.
Currently arp/ip and ip6tables each implement a short helper to check that
the target offset is large enough to hold one xt_entry_target struct and
that t->u.target_size fits within the current rule.
Unfortunately these checks are not sufficient.
To avoid adding new tests to all of ip/ip6/arptables move the current
checks into a helper, then extend this helper in followup patches.
commit dd5f1b049dc139876801db3cdd0f20d21fd428cc upstream.
The INTID mask is wrong, and is made a signed value, which has
nteresting effects in the KVM emulation. Let's sanitize it.
[ Upstream commit 7e059158d57b79159eaf1f504825d19866ef2c42 ]
Prior to 4.3, openvswitch tunnel vports (vxlan, gre and geneve) could
transmit vxlan packets of any size, constrained only by the ability to
send out the resulting packets. 4.3 introduced netdevs corresponding
to tunnel vports. These netdevs have an MTU, which limits the size of
a packet that can be successfully encapsulated. The default MTU
values are low (1500 or less), which is awkwardly small in the context
of physical networks supporting jumbo frames, and leads to a
conspicuous change in behaviour for userspace.
Instead, set the MTU on openvswitch-created netdevs to be the relevant
maximum (i.e. the maximum IP packet size minus any relevant overhead),
effectively restoring the behaviour prior to 4.3.
Signed-off-by: David Wragg <david@weave.works>
[ Upstream commit f0a3fdca794d1e68ae284ef4caefe681f7c18e89 ]
These structures are defined only if __USE_MISC is set in glibc net/if.h
headers, ie when _BSD_SOURCE or _SVID_SOURCE are defined.
CC: Jan Engelhardt <jengelh@inai.de>
CC: Josh Boyer <jwboyer@fedoraproject.org>
CC: Stephen Hemminger <shemming@brocade.com>
CC: Waldemar Brodkorb <mail@waldemar-brodkorb.de>
CC: Gabriel Laskar <gabriel@lse.epita.fr>
CC: Mikko Rapeli <mikko.rapeli@iki.fi>
Fixes: 4a91cb61bb99 ("uapi glibc compat: fix compile errors when glibc net/if.h included before linux/if.h")
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit da4ed55165d41b1073f9a476f1c18493e9bf8c8e ]
The problem is that fib_info->nh is [0] so the struct fib_info
allocation size depends on number of nexthops. If we just copy fib_info,
we do not copy the nexthops info and driver accesses memory which is not
ours.
Given the fact that fib4 does not defer operations and therefore it does
not need copy, just pass the pointer down to drivers as it was done
before.
Fixes: 850d0cbc91 ("switchdev: remove pointers from switchdev objects")
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
commit 310944d148e3600dcff8b346bee7fa01d34903b1 upstream.
The component master driver imx-drm-core matches component devices using
their of_node. Since commit 950b410dd1ab ("gpu: ipu-v3: Fix imx-ipuv3-crtc
module autoloading"), the imx-ipuv3-crtc dev->of_node is not set during
probing. Before that, of_node was set and caused an of: modalias to be
used instead of the platform: modalias, which broke module autoloading.
On the other hand, if dev->of_node is not set yet when the imx-ipuv3-crtc
probe function calls component_add, component matching in imx-drm-core
fails. While dev->of_node will be set once the next component tries to
bring up the component master, imx-drm-core component binding will never
succeed if one of the crtc devices is probed last.
Add of_node to the component platform data and match against the
pdata->of_node instead of dev->of_node in imx-drm-core to work around
this problem.
Fixes: 950b410dd1ab ("gpu: ipu-v3: Fix imx-ipuv3-crtc module autoloading")
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Lothar Waßmann <LW@KARO-electronics.de>
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Chris Ruehl <chris.ruehl@gtsys.com.hk>
commit 759c01142a5d0f364a462346168a56de28a80f52 upstream.
On no-so-small systems, it is possible for a single process to cause an
OOM condition by filling large pipes with data that are never read. A
typical process filling 4000 pipes with 1 MB of data will use 4 GB of
memory. On small systems it may be tricky to set the pipe max size to
prevent this from happening.
This patch makes it possible to enforce a per-user soft limit above
which new pipes will be limited to a single page, effectively limiting
them to 4 kB each, as well as a hard limit above which no new pipes may
be created for this user. This has the effect of protecting the system
against memory abuse without hurting other users, and still allowing
pipes to work correctly though with less data at once.
The limit are controlled by two new sysctls : pipe-user-pages-soft, and
pipe-user-pages-hard. Both may be disabled by setting them to zero. The
default soft limit allows the default number of FDs per process (1024)
to create pipes of the default size (64kB), thus reaching a limit of 64MB
before starting to create only smaller pipes. With 256 processes limited
to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB =
1084 MB of memory allocated for a user. The hard limit is disabled by
default to avoid breaking existing applications that make intensive use
of pipes (eg: for splicing).
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
Cc: Moritz Muehlenhoff <moritz@wikimedia.org>
commit 4b50bcc7eda4d3cc9e3f2a0aa60e590fedf728c5 upstream.
Since commit 92923ca3aace ("mm: meminit: only set page reserved in the
memblock region") the reserved bit is set on reserved memblock regions.
However start and end address are passed as unsigned long. This is only
32bit on i386, so it can end up marking the wrong pages reserved for
ranges at 4GB and above.
This was observed on a 32bit Xen dom0 which was booted with initial
memory set to a value below 4G but allowing to balloon in memory
(dom0_mem=1024M for example). This would define a reserved bootmem
region for the additional memory (for example on a 8GB system there was
a reverved region covering the 4GB-8GB range). But since the addresses
were passed on as unsigned long, this was actually marking all pages
from 0 to 4GB as reserved.
Fixes: 92923ca3aacef63 ("mm: meminit: only set page reserved in the memblock region")
Link: http://lkml.kernel.org/r/1463491221-10573-1-git-send-email-stefan.bader@canonical.com
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
commit f05795d3d771f30a7bdc3a138bf714b06d42aa95 upstream.
Add intermediate STARGET_REMOVE state to scsi_target_state to avoid
running into the BUG_ON() in scsi_target_reap(). The STARGET_REMOVE
state is only valid in the path from scsi_remove_target() to
scsi_target_destroy() indicating this target is going to be removed.
This re-fixes the problem introduced in commits bc3f02a795d3 ("[SCSI]
scsi_remove_target: fix softlockup regression on hot remove") and
40998193560d ("scsi: restart list search after unlock in
scsi_remove_target") in a more comprehensive way.
[mkp: Included James' fix for scsi_target_destroy()]
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Fixes: 40998193560dab6c3ce8d25f4fa58a23e252ef38
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: James Bottomley <jejb@linux.vnet.ibm.com>
commit ca9eb49aa9562eaadf3cea071ec7018ad6800425 upstream.
The generic copy_siginfo() is currently defined in
asm-generic/siginfo.h, after including uapi/asm-generic/siginfo.h which
defines the generic struct siginfo. However this makes it awkward for an
architecture to use it if it has to define its own struct siginfo (e.g.
MIPS and potentially IA64), since it means that asm-generic/siginfo.h
can only be included after defining the arch-specific siginfo, which may
be problematic if the arch-specific definition needs definitions from
uapi/asm-generic/siginfo.h.
It is possible to work around this by first including
uapi/asm-generic/siginfo.h to get the constants before defining the
arch-specific siginfo, and include asm-generic/siginfo.h after. However
uapi headers can't be included by other uapi headers, so that first
include has to be in an ifdef __kernel__, with the non __kernel__ case
including the non-UAPI header instead.
Instead of that mess, move the generic copy_siginfo() definition into
linux/signal.h, which allows an arch-specific uapi/asm/siginfo.h to
include asm-generic/siginfo.h and define the arch-specific siginfo, and
for the generic copy_siginfo() to see that arch-specific definition.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Petr Malat <oss@malat.biz>
Cc: Christopher Ferris <cferris@google.com>
Cc: linux-mips@linux-mips.org
Cc: linux-ia64@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/12478/
commit 54cf809b9512be95f53ed4a5e3b631d1ac42f0fa upstream.
Similar to commits:
51d7d5205d33 ("powerpc: Add smp_mb() to arch_spin_is_locked()")
d86b8da04dfa ("arm64: spinlock: serialise spin_unlock_wait against concurrent lockers")
qspinlock suffers from the fact that the _Q_LOCKED_VAL store is
unordered inside the ACQUIRE of the lock.
And while this is not a problem for the regular mutual exclusive
critical section usage of spinlocks, it breaks creative locking like:
spin_lock(A) spin_lock(B)
spin_unlock_wait(B) if (!spin_is_locked(A))
do_something() do_something()
In that both CPUs can end up running do_something at the same time,
because our _Q_LOCKED_VAL store can drop past the spin_unlock_wait()
spin_is_locked() loads (even on x86!!).
To avoid making the normal case slower, add smp_mb()s to the less used
spin_unlock_wait() / spin_is_locked() side of things to avoid this
problem.
Reported-and-tested-by: Davidlohr Bueso <dave@stgolabs.net>
Reported-by: Giovanni Gherdovich <ggherdovich@suse.com>
commit 0f40fbbcc34e093255a2b2d70b6b0fb48c3f39aa upstream.
OpenSSH expects the (non-blocking) read() of pty master to return
EAGAIN only if it has received all of the slave-side output after
it has received SIGCHLD. This used to work on pre-3.12 kernels.
This fix effectively forces non-blocking read() and poll() to
block for parallel i/o to complete for all ttys. It also unwinds
these changes:
1) f8747d4a466ab2cafe56112c51b3379f9fdb7a12
tty: Fix pty master read() after slave closes
2) 52bce7f8d4fc633c9a9d0646eef58ba6ae9a3b73
pty, n_tty: Simplify input processing on final close
3) 1a48632ffed61352a7810ce089dc5a8bcd505a60
pty: Fix input race when closing
Inspired by analysis and patch from Marc Aurele La France <tsi@tuyoix.net>
Reported-by: Volth <openssh@volth.com>
Reported-by: Marc Aurele La France <tsi@tuyoix.net>
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=52
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=2492
Signed-off-by: Brian Bloniarz <brian.bloniarz@gmail.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
commit 6fb650d43da3e7054984dc548eaa88765a94d49f upstream.
When a USB driver is bound to an interface (either through probing or
by claiming it) or is unbound from an interface, the USB core always
disables Link Power Management during the transition and then
re-enables it afterward. The reason is because the driver might want
to prevent hub-initiated link power transitions, in which case the HCD
would have to recalculate the various LPM parameters. This
recalculation takes place when LPM is re-enabled and the new
parameters are sent to the device and its parent hub.
However, if the driver does not want to prevent hub-initiated link
power transitions then none of this work is necessary. The parameters
don't need to be recalculated, and LPM doesn't need to be disabled and
re-enabled.
It turns out that disabling and enabling LPM can be time-consuming,
enough so that it interferes with user programs that want to claim and
release interfaces rapidly via usbfs. Since the usbfs kernel driver
doesn't set the disable_hub_initiated_lpm flag, we can speed things up
and get the user programs to work by leaving LPM alone whenever the
flag isn't set.
And while we're improving the way disable_hub_initiated_lpm gets used,
let's also fix its kerneldoc.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Matthew Giassa <matthew@giassa.net>
CC: Mathias Nyman <mathias.nyman@intel.com>
commit bb208f144cf3f59d8f89a09a80efd04389718907 upstream.
As described in 'can: m_can: tag current CAN FD controllers as non-ISO'
(6cfda7fbebe) it is possible to define fixed configuration options by
setting the according bit in 'ctrlmode' and clear it in 'ctrlmode_supported'.
This leads to the incovenience that the fixed configuration bits can not be
passed by netlink even when they have the correct values (e.g. non-ISO, FD).
This patch fixes that issue and not only allows fixed set bit values to be set
again but now requires(!) to provide these fixed values at configuration time.
A valid CAN FD configuration consists of a nominal/arbitration bittiming, a
data bittiming and a control mode with CAN_CTRLMODE_FD set - which is now
enforced by a new can_validate() function. This fix additionally removed the
inconsistency that was prohibiting the support of 'CANFD-only' controller
drivers, like the RCar CAN FD.
For this reason a new helper can_set_static_ctrlmode() has been introduced to
provide a proper interface to handle static enabled CAN controller options.
Reported-by: Ramesh Shanmugasundaram <ramesh.shanmugasundaram@bp.renesas.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Reviewed-by: Ramesh Shanmugasundaram <ramesh.shanmugasundaram@bp.renesas.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 3b672623079bb3e5685b8549e514f2dfaa564406 upstream.
The buck9 regulator of S2MPS11 PMIC had incorrect vsel_mask (0xff
instead of 0x1f) thus reading entire register as buck9's voltage. This
effectively caused regulator core to interpret values as higher voltages
than they were and then to set real voltage much lower than intended.
The buck9 provides power to other regulators, including LDO13
and LDO19 which supply the MMC2 (SD card). On Odroid XU3/XU4 the lower
voltage caused SD card detection errors on Odroid XU3/XU4:
mmc1: card never left busy state
mmc1: error -110 whilst initialising SD card
During driver probe the regulator core was checking whether initial
voltage matches the constraints. With incorrect vsel_mask of 0xff and
default value of 0x50, the core interpreted this as 5 V which is outside
of constraints (3-3.775 V). Then the regulator core was adjusting the
voltage to match the constraints. With incorrect vsel_mask this new
voltage mapped to a vere low voltage in the driver.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 54d5ca871e72f2bb172ec9323497f01cd5091ec7 upstream.
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
linux/if.h MIME-Version: 1.0
[ Upstream commit 4a91cb61bb995e5571098188092e296192309c77 ]
glibc's net/if.h contains copies of definitions from linux/if.h and these
conflict and cause build failures if both files are included by application
source code. Changes in uapi headers, which fixed header file dependencies to
include linux/if.h when it was needed, e.g. commit 1ffad83d, made the
net/if.h and linux/if.h incompatibilities visible as build failures for
userspace applications like iproute2 and xtables-addons.
This patch fixes compile errors when glibc net/if.h is included before
linux/if.h:
./linux/if.h:99:21: error: redeclaration of enumerator ‘IFF_NOARP’
./linux/if.h:98:23: error: redeclaration of enumerator ‘IFF_RUNNING’
./linux/if.h:97:26: error: redeclaration of enumerator ‘IFF_NOTRAILERS’
./linux/if.h:96:27: error: redeclaration of enumerator ‘IFF_POINTOPOINT’
./linux/if.h:95:24: error: redeclaration of enumerator ‘IFF_LOOPBACK’
./linux/if.h:94:21: error: redeclaration of enumerator ‘IFF_DEBUG’
./linux/if.h:93:25: error: redeclaration of enumerator ‘IFF_BROADCAST’
./linux/if.h:92:19: error: redeclaration of enumerator ‘IFF_UP’
./linux/if.h:252:8: error: redefinition of ‘struct ifconf’
./linux/if.h:203:8: error: redefinition of ‘struct ifreq’
./linux/if.h:169:8: error: redefinition of ‘struct ifmap’
./linux/if.h:107:23: error: redeclaration of enumerator ‘IFF_DYNAMIC’
./linux/if.h:106:25: error: redeclaration of enumerator ‘IFF_AUTOMEDIA’
./linux/if.h:105:23: error: redeclaration of enumerator ‘IFF_PORTSEL’
./linux/if.h:104:25: error: redeclaration of enumerator ‘IFF_MULTICAST’
./linux/if.h:103:21: error: redeclaration of enumerator ‘IFF_SLAVE’
./linux/if.h:102:22: error: redeclaration of enumerator ‘IFF_MASTER’
./linux/if.h:101:24: error: redeclaration of enumerator ‘IFF_ALLMULTI’
./linux/if.h:100:23: error: redeclaration of enumerator ‘IFF_PROMISC’
The cases where linux/if.h is included before net/if.h need a similar fix in
the glibc side, or the order of include files can be changed userspace
code as a workaround.
This change was tested in x86 userspace on Debian unstable with
scripts/headers_compile_test.sh:
$ make headers_install && \
cd usr/include && ../../scripts/headers_compile_test.sh -l -k
cc -Wall -c -nostdinc -I /usr/lib/gcc/i586-linux-gnu/5/include -I /usr/lib/gcc/i586-linux-gnu/5/include-fixed -I . -I /home/mcfrisk/src/linux-2.6/usr/headers_compile_test_include.2uX2zH -I /home/mcfrisk/src/linux-2.6/usr/headers_compile_test_include.2uX2zH/i586-linux-gnu -o /dev/null ./linux/if.h_libc_before_kernel.h
PASSED libc before kernel test: ./linux/if.h
Reported-by: Jan Engelhardt <jengelh@inai.de>
Reported-by: Josh Boyer <jwboyer@fedoraproject.org>
Reported-by: Stephen Hemminger <shemming@brocade.com>
Reported-by: Waldemar Brodkorb <mail@waldemar-brodkorb.de>
Cc: Gabriel Laskar <gabriel@lse.epita.fr>
Signed-off-by: Mikko Rapeli <mikko.rapeli@iki.fi>
[ Upstream commit 2ccccf5fb43ff62b2b96cc58d95fc0b3596516e4 ]
When the bottom qdisc decides to, for example, drop some packet,
it calls qdisc_tree_decrease_qlen() to update the queue length
for all its ancestors, we need to update the backlog too to
keep the stats on root qdisc accurate.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit 86a7996cc8a078793670d82ed97d5a99bb4e8496 ]
Remove nearly duplicated code and prepare for the following patch.
[ Upstream commit 2c94b53738549d81dc7464a32117d1f5112c64d3 ]
Prior to commit d92cff89a0c8 ("net_dbg_ratelimited: turn into no-op
when !DEBUG") the implementation of net_dbg_ratelimited() was buggy
for both the DEBUG and CONFIG_DYNAMIC_DEBUG cases.
The bug was that net_ratelimit() was being called and, despite
returning true, nothing was being printed to the console. This
resulted in messages like the following -
"net_ratelimit: %d callbacks suppressed"
with no other output nearby.
After commit d92cff89a0c8 ("net_dbg_ratelimited: turn into no-op when
!DEBUG") the bug is fixed for the DEBUG case. However, there's no
output at all for CONFIG_DYNAMIC_DEBUG case.
This patch restores debug output (if enabled) for the
Add a definition of net_dbg_ratelimited() for the CONFIG_DYNAMIC_DEBUG
case. The implementation takes care to check that dynamic debugging is
enabled before calling net_ratelimit().
Fixes: d92cff89a0c8 ("net_dbg_ratelimited: turn into no-op when !DEBUG")
Signed-off-by: Tim Bingham <tbingham@akamai.com>
[ Upstream commit 92117d8443bc5afacc8d5ba82e541946310f106e ]
On a system with >32Gbyte of phyiscal memory and infinite RLIMIT_MEMLOCK,
the malicious application may overflow 32-bit bpf program refcnt.
It's also possible to overflow map refcnt on 1Tb system.
Impose 32k hard limit which means that the same bpf program or
map cannot be shared by more than 32k processes.
Fixes: 1be7f75d1668 ("bpf: enable non-root eBPF programs")
Reported-by: Jann Horn <jannh@google.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 046339eaab26804f52f6604877f5674f70815b26 ]
For set/query MTU port firmware commands the MTU field
is 16 bits, here I changed all the "int mtu" parameters
of the functions wrapping those firmware commands to be u16.
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
commit 60901df3aed230d4565dca003f11b6a95fbf30d9 upstream.
Commit 1084b1988d22dc165c9dbbc2b0e057f9248ac4db (xen: Add Xen specific
page definition) caused a regression in 4.4.
The xen functions to convert between pages and pfns fail due to an
overflow on systems where a physical address may not fit in an
unsigned long (e.g. x86 32 bit PAE systems). Rework the conversion to
avoid overflow. This should also result in simpler object code.
This bug manifested itself as disk corruption with Linux 4.4 when
using blkfront in a Xen HVM x86 32 bit guest with more than 4 GiB of
memory.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 689de1d6ca95b3b5bd8ee446863bf81a4883ea25 upstream.
This is a fairly minimal fixup to the horribly bad behavior of hash_64()
with certain input patterns.
In particular, because the multiplicative value used for the 64-bit hash
was intentionally bit-sparse (so that the multiply could be done with
shifts and adds on architectures without hardware multipliers), some
bits did not get spread out very much. In particular, certain fairly
common bit ranges in the input (roughly bits 12-20: commonly with the
most information in them when you hash things like byte offsets in files
or memory that have block factors that mean that the low bits are often
zero) would not necessarily show up much in the result.
There's a bigger patch-series brewing to fix up things more completely,
but this is the fairly minimal fix for the 64-bit hashing problem. It
simply picks a much better constant multiplier, spreading the bits out a
lot better.
NOTE! For 32-bit architectures, the bad old hash_64() remains the same
for now, since 64-bit multiplies are expensive. The bigger hashing
cleanup will replace the 32-bit case with something better.
The new constants were picked by George Spelvin who wrote that bigger
cleanup series. I just picked out the constants and part of the comment
from that series.
Cc: George Spelvin <linux@horizon.com>
commit 50359819794b4a16ae35051cd80f2dab025f6019 upstream.
Commit e6d5e7d90be9 ("clk-divider: Fix READ_ONLY when divider > 1") removed
the special ops struct for read-only clocks and instead opted to handle
them inside the regular ops.
On the rk3368 this results in breakage as aclkm now gets set a value.
While it is the same divider value, the A53 core still doesn't like it,
which can result in the cpu ending up in a hang.
The reason being that "ACLKENMasserts one clock cycle before the rising
edge of ACLKM" and the clock should only be touched when STANDBYWFIL2
is asserted.
To fix this, reintroduce the read-only ops but do include the round_rate
callback. That way no writes that may be unsafe are done to the divider
register in any case.
The Rockchip use of the clk_divider_ops is adapted to this split again,
as is the nxp, lpc18xx-ccu driver that was included since the original
commit. On lpc18xx-ccu the divider seems to always be read-only
so only uses the new ops now.
Fixes: e6d5e7d90be9 ("clk-divider: Fix READ_ONLY when divider > 1")
Reported-by: Zhang Qing <zhangqing@rock-chips.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit f719e3754ee2f7275437e61a6afd520181fdd43b upstream.
Jiri Bohac is reporting for a problem where the attempt
to reschedule existing connection to another real server
needs proper redirect for the conntrack used by the IPVS
connection. For example, when IPVS connection is created
to NAT-ed real server we alter the reply direction of
conntrack. If we later decide to select different real
server we can not alter again the conntrack. And if we
expire the old connection, the new connection is left
without conntrack.
So, the only way to redirect both the IPVS connection and
the Netfilter's conntrack is to drop the SYN packet that
hits existing connection, to wait for the next jiffie
to expire the old connection and its conntrack and to rely
on client's retransmission to create new connection as
usually.
Jiri Bohac provided a fix that drops all SYNs on rescheduling,
I extended his patch to do such drops only for connections
that use conntrack. Here is the original report from Jiri Bohac:
Since commit dc7b3eb900aa ("ipvs: Fix reuse connection if real server
is dead"), new connections to dead servers are redistributed
immediately to new servers. The old connection is expired using
ip_vs_conn_expire_now() which sets the connection timer to expire
immediately.
However, before the timer callback, ip_vs_conn_expire(), is run
to clean the connection's conntrack entry, the new redistributed
connection may already be established and its conntrack removed
instead.
Fix this by dropping the first packet of the new connection
instead, like we do when the destination server is not available.
The timer will have deleted the old conntrack entry long before
the first packet of the new connection is retransmitted.
Fixes: dc7b3eb900aa ("ipvs: Fix reuse connection if real server is dead")
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit e7e0c3e26587749b62d17b9dd0532874186c77f7 upstream.
The number of planes in videobuf2 is specific to a buffer. In order to
verify that the planes array provided by the user is long enough, a new
vb2_buf_op is required.
Call __verify_planes_array() when the dequeued buffer is known. Return an
error to the caller if there was one, otherwise remove the buffer from the
done list.
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 28093f9f34cedeaea0f481c58446d9dac6dd620f upstream.
In gather_pte_stats() a THP pmd is cast into a pte, which is wrong
because the layouts may differ depending on the architecture. On s390
this will lead to inaccurate numa_maps accounting in /proc because of
misguided pte_present() and pte_dirty() checks on the fake pte.
On other architectures pte_present() and pte_dirty() may work by chance,
but there may be an issue with direct-access (dax) mappings w/o
underlying struct pages when HAVE_PTE_SPECIAL is set and THP is
available. In vm_normal_page() the fake pte will be checked with
pte_special() and because there is no "special" bit in a pmd, this will
always return false and the VM_PFNMAP | VM_MIXEDMAP checking will be
skipped. On dax mappings w/o struct pages, an invalid struct page
pointer would then be returned that can crash the kernel.
This patch fixes the numa_maps THP handling by introducing new "_pmd"
variants of the can_gather_numa_stats() and vm_normal_page() functions.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com>
cgroup_subsys->post_attach callback
commit 5cf1cacb49aee39c3e02ae87068fc3c6430659b0 upstream.
Since e93ad19d0564 ("cpuset: make mm migration asynchronous"), cpuset
kicks off asynchronous NUMA node migration if necessary during task
migration and flushes it from cpuset_post_attach_flush() which is
called at the end of __cgroup_procs_write(). This is to avoid
performing migration with cgroup_threadgroup_rwsem write-locked which
can lead to deadlock through dependency on kworker creation.
memcg has a similar issue with charge moving, so let's convert it to
an official callback rather than the current one-off cpuset specific
function. This patch adds cgroup_subsys->post_attach callback and
makes cpuset register cpuset_post_attach_flush() as its ->post_attach.
The conversion is mostly one-to-one except that the new callback is
called under cgroup_mutex. This is to guarantee that no other
migration operations are started before ->post_attach callbacks are
finished. cgroup_mutex is one of the outermost mutex in the system
and has never been and shouldn't be a problem. We can add specialized
synchronization around __cgroup_procs_write() but I don't think
there's any noticeable benefit.
Cc: Li Zefan <lizefan@huawei.com>
Cc: Michal Hocko <mhocko@kernel.org>
commit e6bd18f57aad1a2d1ef40e646d03ed0f2515c9e3 upstream.
The drivers/infiniband stack uses write() as a replacement for
bi-directional ioctl(). This is not safe. There are ways to
trigger write calls that result in the return structure that
is normally written to user space being shunted off to user
specified kernel memory instead.
For the immediate repair, detect and deny suspicious accesses to
the write API.
For long term, update the user space libraries and the kernel API
to something that doesn't present the same security vulnerabilities
(likely a structured ioctl() interface).
The impacted uAPI interfaces are generally only available if
hardware from drivers/infiniband is installed in the system.
Reported-by: Jann Horn <jann@thejh.net>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
[ Expanded check to all known write() entry points ]
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 986ef95ecdd3eb6fa29433e68faa94c7624083be upstream.
mlx5 devices (Connect-IB, ConnectX-4, ConnectX-4-LX) has a limitation
where rdma read work queue entries cannot exceed 512 bytes.
A rdma_read wqe needs to fit in 512 bytes:
- wqe control segment (16 bytes)
- rdma segment (16 bytes)
- scatter elements (16 bytes each)
So max_sge_rd should be: (512 - 16 - 16) / 16 = 30.
Reported-by: Christoph Hellwig <hch@lst.de>
Tested-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Sagi Grimberg <sagig@grimberg.me>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
commit 3020ca711871fdaf0c15c8bab677a6bc302e28fe upstream.
The VSync polarity was negative instead of positive for the 4k CEA formats.
I probably copy-and-pasted these from the DMT 4k format, which does have a
negative VSync polarity.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Reported-by: Martin Bugge <marbugge@cisco.com>
commit 221004c66a58949a0f25c937a6789c0839feb530 upstream.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit fba7cd681b6155e2d93e7862fcd6f970336b83c3 upstream.
The recent decoupling of pagefault disable and preempt disable added an
explicit preempt_disable/enable() pair to the futex_atomic_cmpxchg_inatomic()
implementation in asm-generic/futex.h. But it forgot to add preempt_enable()
calls to the error handling code pathes, which results in a preemption count
imbalance.
This is observable on boot when the test for atomic_cmpxchg() is calling
futex_atomic_cmpxchg_inatomic() on a NULL pointer.
Add the missing preempt_enable() calls to the error handling code pathes.
[ tglx: Massaged changelog ]
Fixes: d9b9ff8c1889 ("sched/preempt, futex: Disable preemption in UP futex_atomic_cmpxchg_inatomic() explicitly")
Signed-off-by: Romain Perier <romain.perier@free-electrons.com>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: http://lkml.kernel.org/r/1460640963-690-1-git-send-email-romain.perier@free-electrons.com
commit 67b4eab91caf2ad574cab1b17ae09180ea2e116e upstream.
Revert 811a4e6fce09 ("PCI: Add helpers to manage pci_dev->irq and
pci_dev->irq_managed").
This is part of reverting 991de2e59090 ("PCI, x86: Implement
pcibios_alloc_irq() and pcibios_free_irq()") to fix regressions it
introduced.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=111211
Fixes: 991de2e59090 ("PCI, x86: Implement pcibios_alloc_irq() and pcibios_free_irq()")
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Rafael J. Wysocki <rafael@kernel.org>
CC: Jiang Liu <jiang.liu@linux.intel.com>
commit d101a125954eae1d397adda94ca6319485a50493 upstream.
This series fixes bugs in nfs and ext4 due to 4bacc9c9234c ("overlayfs:
Make f_path always point to the overlay and f_inode to the underlay").
Regular files opened on overlayfs will result in the file being opened on
the underlying filesystem, while f_path points to the overlayfs
mount/dentry.
This confuses filesystems which get the dentry from struct file and assume
it's theirs.
Add a new helper, file_dentry() [*], to get the filesystem's own dentry
from the file. This checks file->f_path.dentry->d_flags against
DCACHE_OP_REAL, and returns file->f_path.dentry if DCACHE_OP_REAL is not
set (this is the common, non-overlayfs case).
In the uncommon case it will call into overlayfs's ->d_real() to get the
underlying dentry, matching file_inode(file).
The reason we need to check against the inode is that if the file is copied
up while being open, d_real() would return the upper dentry, while the open
file comes from the lower dentry.
[*] If possible, it's better simply to use file_inode() instead.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Tested-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
Reviewed-by: Trond Myklebust <trond.myklebust@primarydata.com>
Cc: Daniel Axtens <dja@axtens.net>
commit 1363074667a6b7d0507527742ccd7bbed5e3ceaa upstream.
Add a new NO_REPORT_LUNS quirk and set it for Seagate drives with
an usb-id of: 0bc2:331a, as these will fail to respond to a
REPORT_LUNS command.
Reported-and-tested-by: David Webb <djw@noc.ac.uk>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[ Upstream commit 5a5abb1fa3b05dd6aa821525832644c1e7d2905f ]
Sasha Levin reported a suspicious rcu_dereference_protected() warning
found while fuzzing with trinity that is similar to this one:
[ 52.765684] net/core/filter.c:2262 suspicious rcu_dereference_protected() usage!
[ 52.765688] other info that might help us debug this:
[ 52.765695] rcu_scheduler_active = 1, debug_locks = 1
[ 52.765701] 1 lock held by a.out/1525:
[ 52.765704] #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff816a64b7>] rtnl_lock+0x17/0x20
[ 52.765721] stack backtrace:
[ 52.765728] CPU: 1 PID: 1525 Comm: a.out Not tainted 4.5.0+ #264
[ 52.765768] Call Trace:
[ 52.765775] [<ffffffff813e488d>] dump_stack+0x85/0xc8
[ 52.765784] [<ffffffff810f2fa5>] lockdep_rcu_suspicious+0xd5/0x110
[ 52.765792] [<ffffffff816afdc2>] sk_detach_filter+0x82/0x90
[ 52.765801] [<ffffffffa0883425>] tun_detach_filter+0x35/0x90 [tun]
[ 52.765810] [<ffffffffa0884ed4>] __tun_chr_ioctl+0x354/0x1130 [tun]
[ 52.765818] [<ffffffff8136fed0>] ? selinux_file_ioctl+0x130/0x210
[ 52.765827] [<ffffffffa0885ce3>] tun_chr_ioctl+0x13/0x20 [tun]
[ 52.765834] [<ffffffff81260ea6>] do_vfs_ioctl+0x96/0x690
[ 52.765843] [<ffffffff81364af3>] ? security_file_ioctl+0x43/0x60
[ 52.765850] [<ffffffff81261519>] SyS_ioctl+0x79/0x90
[ 52.765858] [<ffffffff81003ba2>] do_syscall_64+0x62/0x140
[ 52.765866] [<ffffffff817d563f>] entry_SYSCALL64_slow_path+0x25/0x25
Same can be triggered with PROVE_RCU (+ PROVE_RCU_REPEATEDLY) enabled
from tun_attach_filter() when user space calls ioctl(tun_fd, TUN{ATTACH,
DETACH}FILTER, ...) for adding/removing a BPF filter on tap devices.
Since the fix in f91ff5b9ff52 ("net: sk_{detach|attach}_filter() rcu
fixes") sk_attach_filter()/sk_detach_filter() now dereferences the
filter with rcu_dereference_protected(), checking whether socket lock
is held in control path.
Since its introduction in 994051625981 ("tun: socket filter support"),
tap filters are managed under RTNL lock from __tun_chr_ioctl(). Thus the
sock_owned_by_user(sk) doesn't apply in this specific case and therefore
triggers the false positive.
Extend the BPF API with __sk_attach_filter()/__sk_detach_filter() pair
that is used by tap filters and pass in lockdep_rtnl_is_held() for the
rcu_dereference_protected() checks instead.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit fe30937b65354c7fec244caebbdaae68e28ca797 ]
bond_get_stats() can be called from rtnetlink (with RTNL held)
or from /proc/net/dev seq handler (with RCU held)
The logic added in commit 5f0c5f73e5ef ("bonding: make global bonding
stats more reliable") kind of assumed only one cpu could run there.
If multiple threads are reading /proc/net/dev, stats can be really
messed up after a while.
A second problem is that some fields are 32bit, so we need to properly
handle the wrap around problem.
Given that RTNL is not always held, we need to use
bond_for_each_slave_rcu().
Fixes: 5f0c5f73e5ef ("bonding: make global bonding stats more reliable")
Cc: Andy Gospodarek <gospo@cumulusnetworks.com>
Cc: Jay Vosburgh <j.vosburgh@gmail.com>
Cc: Veaceslav Falico <vfalico@gmail.com>
Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 4c656c13b254d598e83e586b7b4d36a2043dad85 ]
This fixes a regression in the bridge ageing time caused by:
commit c62987bbd8a1 ("bridge: push bridge setting ageing_time down to switchdev")
There are users of Linux bridge which use the feature that if ageing time
is set to 0 it causes entries to never expire. See:
https://www.linuxfoundation.org/collaborate/workgroups/networking/bridge
For a pure software bridge, it is unnecessary for the code to have
arbitrary restrictions on what values are allowable.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 2793a23aacbd754dbbb5cb75093deb7e4103bace ]
Netdevice parameter hard_header_len is variously interpreted both as
an upper and lower bound on link layer header length. The field is
used as upper bound when reserving room at allocation, as lower bound
when validating user input in PF_PACKET.
Clarify the definition to be maximum header length. For validation
of untrusted headers, add an optional validate member to header_ops.
Allow bypassing of validation by passing CAP_SYS_RAWIO, for instance
for deliberate testing of corrupt input. In this case, pad trailing
bytes, as some device drivers expect completely initialized headers.
See also http://comments.gmane.org/gmane.linux.network/401064
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 1837b2e2bcd23137766555a63867e649c0b637f0 ]
The current reserved_tailroom calculation fails to take hlen and tlen into
account.
skb:
[__hlen__|__data____________|__tlen___|__extra__]
head skb_end_offset
In this representation, hlen + data + tlen is the size passed to alloc_skb.
"extra" is the extra space made available in __alloc_skb because of
rounding up by kmalloc. We can reorder the representation like so:
[__hlen__|__data____________|__extra__|__tlen___]
head skb_end_offset
The maximum space available for ip headers and payload without
fragmentation is min(mtu, data + extra). Therefore,
reserved_tailroom
= data + extra + tlen - min(mtu, data + extra)
= skb_end_offset - hlen - min(mtu, skb_end_offset - hlen - tlen)
= skb_tailroom - min(mtu, skb_tailroom - tlen) ; after skb_reserve(hlen)
Compare the second line to the current expression:
reserved_tailroom = skb_end_offset - min(mtu, skb_end_offset)
and we can see that hlen and tlen are not taken into account.
The min() in the third line can be expanded into:
if mtu < skb_tailroom - tlen:
reserved_tailroom = skb_tailroom - mtu
else:
reserved_tailroom = tlen
Depending on hlen, tlen, mtu and the number of multicast address records,
the current code may output skbs that have less tailroom than
dev->needed_tailroom or it may output more skbs than needed because not all
space available is used.
Fixes: 4c672e4b ("ipv6: mld: fix add_grhead skb_over_panic for devs with large MTUs")
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 9b368814b336b0a1a479135eb2815edbc00efd3c ]
We need to update the skb->csum after pulling the skb, otherwise
an unnecessary checksum (re)computation can ocure for IGMP/MLD packets
in the bridge code. Additionally this fixes the following splats for
network devices / bridge ports with support for and enabled RX checksum
offloading:
[ 43.986968] eth0: hw csum failure
[ 43.990344] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.0 #2
[ 43.996193] Hardware name: BCM2709
[ 43.999647] [<800204e0>] (unwind_backtrace) from [<8001cf14>] (show_stack+0x10/0x14)
[ 44.007432] [<8001cf14>] (show_stack) from [<801ab614>] (dump_stack+0x80/0x90)
[ 44.014695] [<801ab614>] (dump_stack) from [<802e4548>] (__skb_checksum_complete+0x6c/0xac)
[ 44.023090] [<802e4548>] (__skb_checksum_complete) from [<803a055c>] (ipv6_mc_validate_checksum+0x104/0x178)
[ 44.032959] [<803a055c>] (ipv6_mc_validate_checksum) from [<802e111c>] (skb_checksum_trimmed+0x130/0x188)
[ 44.042565] [<802e111c>] (skb_checksum_trimmed) from [<803a06e8>] (ipv6_mc_check_mld+0x118/0x338)
[ 44.051501] [<803a06e8>] (ipv6_mc_check_mld) from [<803b2c98>] (br_multicast_rcv+0x5dc/0xd00)
[ 44.060077] [<803b2c98>] (br_multicast_rcv) from [<803aa510>] (br_handle_frame_finish+0xac/0x51c)
Fixes: 9afd85c9e455 ("net: Export IGMP/MLD message validation code")
Reported-by: Álvaro Fernández Rojas <noltari@gmail.com>
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
commit 95272c29378ee7dc15f43fa2758cb28a5913a06d upstream.
-ftracer can duplicate asm blocks causing compilation to fail in
noclone functions. For example, KVM declares a global variable
in an asm like
asm("2: ... \n
.pushsection data \n
.global vmx_return \n
vmx_return: .long 2b");
and -ftracer causes a double declaration.
Cc: Michal Marek <mmarek@suse.cz>
Cc: kvm@vger.kernel.org
Reported-by: Linda Walsh <lkml@tlinx.org>
commit f75d48644c56a31731d17fa693c8175328957e1d upstream.
__clear_bit_unlock() is a special little snowflake. While it carries the
non-atomic '__' prefix, it is specifically documented to pair with
test_and_set_bit() and therefore should be 'somewhat' atomic.
Therefore the generic implementation of __clear_bit_unlock() cannot use
the fully non-atomic __clear_bit() as a default.
If an arch is able to do better; is must provide an implementation of
__clear_bit_unlock() itself.
Specifically, this came up as a result of hackbench livelock'ing in
slab_lock() on ARC with SMP + SLUB + !LLSC.
The issue was incorrect pairing of atomic ops.
slab_lock() -> bit_spin_lock() -> test_and_set_bit()
slab_unlock() -> __bit_spin_unlock() -> __clear_bit()
The non serializing __clear_bit() was getting "lost"
80543b8e: ld_s r2,[r13,0] <--- (A) Finds PG_locked is set
80543b90: or r3,r2,1 <--- (B) other core unlocks right here
80543b94: st_s r3,[r13,0] <--- (C) sets PG_locked (overwrites unlock)
Fixes ARC STAR 9000817404 (and probably more).
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Tested-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Helge Deller <deller@gmx.de>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Noam Camus <noamc@ezchip.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/20160309114054.GJ6356@twins.programming.kicks-ass.net
commit 3debb0a9ddb16526de8b456491b7db60114f7b5e upstream.
The trace_printk() code will allocate extra buffers if the compile detects
that a trace_printk() is used. To do this, the format of the trace_printk()
is saved to the __trace_printk_fmt section, and if that section is bigger
than zero, the buffers are allocated (along with a message that this has
happened).
If trace_printk() uses a format that is not a constant, and thus something
not guaranteed to be around when the print happens, the compiler optimizes
the fmt out, as it is not used, and the __trace_printk_fmt section is not
filled. This means the kernel will not allocate the special buffers needed
for the trace_printk() and the trace_printk() will not write anything to the
tracing buffer.
Adding a "__used" to the variable in the __trace_printk_fmt section will
keep it around, even though it is set to NULL. This will keep the string
from being printed in the debugfs/tracing/printk_formats section as it is
not needed.
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Fixes: 07d777fe8c398 "tracing: Add percpu buffers for trace_printk()"
