Each SSI has "ssi", "ssi_ipg" clocks, and they share same gate bits.
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This is the same change for imx6sx clock driver as "ARM: imx6q: add BYPASS
support for PLL clocks" for imx6q. The difference is that only anaclk1
is available on imx6sx.
This is the same change for imx6sl clock driver as "ARM: imx6q: add BYPASS
is available on imx6sl.
The imx6q clock driver currently hard-codes all PLL clocks to source
from OSC24M without BYPASS support. The patch adds the missing lvds_in
clock which is mutually exclusive with lvds_gate, and implements BYPASS
and BYPASS_CLK_SRC selection for PLL clocks as per Figure 10-3. Primary
Clock Generation in IMX6DQRM, i.e. both BYPASS_CLK_SRC and BYPASS bits
are implemented as mux clocks, and ENABLE bit of PLL clocks is
implemented as a gate clock after BYPASS mux.
ASRC has "asrc", "asrc_ipg", "asrc_mem" clocks, and they share
the same gate bits.
There are three clock for ESAI, esai_extal, esai_ipg, esai_mem. Rename
'esai' to 'esai_extal', 'esai_ahb' to 'esai_mem', and add 'esai_ipg'.
Make the clock for ESAI more clear and align them with imx6sx.
This commit adds PLL7 which is required for USBPHY1. It also adds
the USB PHY and USB Controller clocks and the gates to enable them.
Acked-by: Jingchang Lu <jingchang.lu@freescale.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Pull ARM SoC fixes from Olof Johansson:
"Here's the weekly batch of fixes from arm-soc.
The delta is a largeish negative delta, due to revert of SMP support
for Broadcom's STB SoC -- it was accidentally merged before some
issues had been addressed, so they will make a new attempt for 3.18.
I didn't see a need for a full revert of the whole platform due to
this, we're keeping the rest enabled.
The rest is mostly:
- a handful of DT fixes for i.MX (Hummingboard/Cubox-i in particular)
- some MTD/NAND fixes for OMAP
- minor DT fixes for shmobile
- warning fix for UP builds on vexpress/spc
There's also a couple of patches that wires up hwmod on TI's DRA7 SoC
so it can boot. Drivers and the rest had landed for 3.17, and it's
small and isolated so it made sense to pick up now even if it's not a
bugfix"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
vexpress/spc: fix a build warning on array bounds
ARM: DRA7: hwmod: Add dra74x and dra72x specific ocp interface lists
ARM: DRA7: Add support for soc_is_dra74x() and soc_is_dra72x() variants
MAINTAINERS: catch special Rockchip code locations
ARM: dts: microsom-ar8035: MDIO pad must be set open drain
ARM: dts: omap54xx-clocks: Fix the l3 and l4 clock rates
ARM: brcmstb: revert SMP support
ARM: OMAP2+: hwmod: Rearm wake-up interrupts for DT when MUSB is idled
ARM: dts: Enable UART wake-up events for beagleboard
ARM: dts: Remove twl6030 clk32g "regulator"
ARM: OMAP2+: omap_device: remove warning that clk alias already exists
ARM: OMAP: fix %d confusingly prefixed with 0x in format string
ARM: dts: DRA7: fix interrupt-cells for GPIO
mtd: nand: omap: Fix 1-bit Hamming code scheme, omap_calculate_ecc()
ARM: dts: omap3430-sdp: Revert to using software ECC for NAND
ARM: OMAP2+: GPMC: Support Software ECC scheme via DT
mtd: nand: omap: Revert to using software ECC by default
ARM: dts: hummingboard/cubox-i: change SPDIF output to be more descriptive
ARM: dts: hummingboard/cubox-i: add USB OC pinctrl configuration
ARM: shmobile: r8a7791: add missing 0x0100 for SDCKCR
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi bugfixes from Mark Brown:
"A smattering of bug fixes for the SPI subsystem, all in driver code
which has seen active work recently and none of them with any great
global impact.
There's also a new ACPI ID for the pxa2xx driver which required no
code changes and the addition of kerneldoc for some structure fields
that were missing it and generating warnings during documentation
builds as a result"
* tag 'spi-v3.17-rc3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi: sh-msiof: Fix transmit-only DMA transfers
spi/rockchip: Avoid accidentally turning off the clock
spi: dw: fix kernel crash due to NULL pointer dereference
spi: dw-pci: fix bug when regs left uninitialized
spi: davinci: fix SPI_NO_CS functionality
spi/rockchip: fixup incorrect dma direction setting
spi/pxa2xx: Add ACPI ID for Intel Braswell
spi: spi-au1550: fix build failure
spi: rspi: Fix leaking of unused DMA descriptors
spi: sh-msiof: Fix leaking of unused DMA descriptors
spi: Add missing kerneldoc bits
spi/omap-mcspi: Fix the spi task hangs waiting dma_rx
'spi/fix/doc', 'spi/fix/dw', 'spi/fix/omap-mcspi', 'spi/fix/pxa2xx', 'spi/fix/rockchip' and 'spi/fix/rspi' into spi-linus
Merge patches from Andrew Morton:
"22 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (22 commits)
kexec: purgatory: add clean-up for purgatory directory
Documentation/kdump/kdump.txt: add ARM description
flush_icache_range: export symbol to fix build errors
tools: selftests: fix build issue with make kselftests target
ocfs2: quorum: add a log for node not fenced
ocfs2: o2net: set tcp user timeout to max value
ocfs2: o2net: don't shutdown connection when idle timeout
ocfs2: do not write error flag to user structure we cannot copy from/to
x86/purgatory: use approprate -m64/-32 build flag for arch/x86/purgatory
drivers/rtc/rtc-s5m.c: re-add support for devices without irq specified
xattr: fix check for simultaneous glibc header inclusion
kexec: remove CONFIG_KEXEC dependency on crypto
kexec: create a new config option CONFIG_KEXEC_FILE for new syscall
x86,mm: fix pte_special versus pte_numa
hugetlb_cgroup: use lockdep_assert_held rather than spin_is_locked
mm/zpool: use prefixed module loading
zram: fix incorrect stat with failed_reads
lib: turn CONFIG_STACKTRACE into an actual option.
mm: actually clear pmd_numa before invalidating
memblock, memhotplug: fix wrong type in memblock_find_in_range_node().
The guard was introduced in commit ea1a8217b06b ("xattr: guard against
simultaneous glibc header inclusion") but it is using #ifdef to check
for a define that is either set to 1 or 0. Fix it to use #if instead.
* Without this patch:
$ { echo "#include <sys/xattr.h>"; echo "#include <linux/xattr.h>"; } | gcc -E -Iinclude/uapi - >/dev/null
include/uapi/linux/xattr.h:19:0: warning: "XATTR_CREATE" redefined [enabled by default]
#define XATTR_CREATE 0x1 /* set value, fail if attr already exists */
/usr/include/x86_64-linux-gnu/sys/xattr.h:32:0: note: this is the location of the previous definition
#define XATTR_CREATE XATTR_CREATE
* With this patch:
(no warnings)
Signed-off-by: Filipe Brandenburger <filbranden@google.com>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Cc: Allan McRae <allan@archlinux.org>
Cc: <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a bunch of fixes for the USB drivers for 3.17-rc3.
Also in here is the movement of the usbip driver out of staging, into
the "real" part of the kernel, it had to wait until after -rc1 to
handle the merge issues involved between the USB and staging trees.
The code is identical, just file movements there.
The USB fixes are all over the place, new device ids, xhci fixes for
reported issues and the usual gadget driver fixes as well. All have
been in linux-next for a while now"
* tag 'usb-3.17-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (46 commits)
USB: fix build error with CONFIG_PM_RUNTIME disabled
Revert "usb: ehci/ohci-exynos: Fix PHY getting sequence"
xhci: Disable streams on Via XHCI with device-id 0x3432
USB: serial: fix potential heap buffer overflow
USB: serial: fix potential stack buffer overflow
usb: hub: Prevent hub autosuspend if usbcore.autosuspend is -1
USB: sisusb: add device id for Magic Control USB video
usb: dwc2: gadget: Set the default EP max packet value as 8 bytes
usb: ehci: using wIndex + 1 for hub port
USB: storage: add quirk for Newer Technology uSCSI SCSI-USB converter
MAINTAINERS: Add an entry for USB/IP driver
usbip: remove struct usb_device_id table
usbip: move usbip kernel code out of staging
usbip: move usbip userspace code out of staging
USB: whiteheat: Added bounds checking for bulk command response
usb: gadget: remove $(PWD) in ccflags-y
usb: pch_udc: usb gadget device support for Intel Quark X1000
usb: gadget: uvc: fix possible lockup in uvc gadget
usb: wusbcore: fix below build warning
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 bugfixes from Ted Ts'o:
"Ext4 bug fixes for 3.17, to provide better handling of memory
allocation failures, and to fix some journaling bugs involving
journal checksums and FALLOC_FL_ZERO_RANGE"
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: fix same-dir rename when inline data directory overflows
jbd2: fix descriptor block size handling errors with journal_csum
jbd2: fix infinite loop when recovering corrupt journal blocks
ext4: update i_disksize coherently with block allocation on error path
ext4: fix transaction issues for ext4_fallocate and ext_zero_range
ext4: fix incorect journal credits reservation in ext4_zero_range
ext4: move i_size,i_disksize update routines to helper function
ext4: fix BUG_ON in mb_free_blocks()
ext4: propagate errors up to ext4_find_entry()'s callers
Pull block layer fixes from Jens Axboe:
"A smaller collection of fixes that have come up since the initial
merge window pull request. This contains:
- error handling cleanup and support for larger than 16 byte cdbs in
sg_io() from Christoph. The latter just matches what bsg and
friends support, sg_io() got left out in the merge.
- an option for brd to expose partitions in /proc/partitions. They
are hidden by default for compat reasons. From Dmitry Monakhov.
- a few blk-mq fixes from me - killing a dead/unused flag, fix for
merging happening even if turned off, and correction of a few
comments.
- removal of unnecessary ->owner setting in systemace. From Michal
Simek.
- two related fixes for a problem with nesting freezing of queues in
blk-mq. One from Ming Lei removing an unecessary freeze operation,
and another from Tejun fixing the nesting regression introduced in
the merge window.
- fix for a BUG_ON() at bio_endio time when protection info is
attached and the IO has an error. From Sagi Grimberg.
- two scsi_ioctl bug fixes for regressions with scsi-mq from Tony
Battersby.
- a cfq weight update fix and subsequent comment update from Toshiaki
Makita"
* 'for-linus' of git://git.kernel.dk/linux-block:
cfq-iosched: Add comments on update timing of weight
cfq-iosched: Fix wrong children_weight calculation
block: fix error handling in sg_io
fix regression in SCSI_IOCTL_SEND_COMMAND
scsi-mq: fix requests that use a separate CDB buffer
block: support > 16 byte CDBs for SG_IO
block: cleanup error handling in sg_io
brd: add ram disk visibility option
block: systemace: Remove .owner field for driver
blk-mq: blk_mq_freeze_queue() should allow nesting
blk-mq: correct a few wrong/bad comments
block: Fix BUG_ON when pi errors occur
blk-mq: don't allow merges if turned off for the queue
blk-mq: get rid of unused BLK_MQ_F_SHOULD_SORT flag
blk-mq: fix WARNING "percpu_ref_kill() called more than once!"
It turns out that there are some serious problems with the on-disk
format of journal checksum v2. The foremost is that the function to
calculate descriptor tag size returns sizes that are too big. This
causes alignment issues on some architectures and is compounded by the
fact that some parts of jbd2 use the structure size (incorrectly) to
determine the presence of a 64bit journal instead of checking the
feature flags.
Therefore, introduce journal checksum v3, which enlarges the
descriptor block tag format to allow for full 32-bit checksums of
journal blocks, fix the journal tag function to return the correct
sizes, and fix the jbd2 recovery code to use feature flags to
determine 64bitness.
Add a few function helpers so we don't have to open-code quite so
many pieces.
Switching to a 16-byte block size was found to increase journal size
overhead by a maximum of 0.1%, to convert a 32-bit journal with no
checksumming to a 32-bit journal with checksum v3 enabled.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reported-by: TR Reardon <thomas_reardon@hotmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@vger.kernel.org
The seqno_fence_init() function's cond argument isn't described in the
kerneldoc comment. Fix that to silence a warning when building DocBook
documentation.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
For v3.12 and prior, 1-bit Hamming code ECC via software was the
default choice. Commit c66d039197e4 in v3.13 changed the behaviour
to use 1-bit Hamming code via Hardware using a different ECC layout
i.e. (ROM code layout) than what is used by software ECC.
This ECC layout change causes NAND filesystems created in v3.12
and prior to be unusable in v3.13 and later. So revert back to
using software ECC by default if an ECC scheme is not explicitely
specified.
This defect can be observed on the following boards during legacy boot
-omap3beagle
-omap3touchbook
-overo
-am3517crane
-devkit8000
-ldp
-3430sdp
Signed-off-by: Roger Quadros <rogerq@ti.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
Pull NFS client fixes from Trond Myklebust:
"Highlights:
- more fixes for read/write codepath regressions
* sleeping while holding the inode lock
* stricter enforcement of page contiguity when coalescing requests
* fix up error handling in the page coalescing code
- don't busy wait on SIGKILL in the file locking code"
* tag 'nfs-for-3.17-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
nfs: Don't busy-wait on SIGKILL in __nfs_iocounter_wait
nfs: can_coalesce_requests must enforce contiguity
nfs: disallow duplicate pages in pgio page vectors
nfs: don't sleep with inode lock in lock_and_join_requests
nfs: fix error handling in lock_and_join_requests
nfs: use blocking page_group_lock in add_request
nfs: fix nonblocking calls to nfs_page_group_lock
nfs: change nfs_page_group_lock argument
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull fix for ftrace function tracer/profiler conflict from Steven Rostedt:
"The rewrite of the ftrace code that makes it possible to allow for
separate trampolines had a design flaw with the interaction between
the function and function_graph tracers.
The main flaw was the simplification of the use of multiple tracers
having the same filter (like function and function_graph, that use the
set_ftrace_filter file to filter their code). The design assumed that
the two tracers could never run simultaneously as only one tracer can
be used at a time. The problem with this assumption was that the
function profiler could be implemented on top of the function graph
tracer, and the function profiler could run at the same time as the
function tracer. This caused the assumption to be broken and when
ftrace detected this failed assumpiton it would spit out a nasty
warning and shut itself down.
Instead of using a single ftrace_ops that switches between the
function and function_graph callbacks, the two tracers can again use
their own ftrace_ops. But instead of having a complex hierarchy of
ftrace_ops, the filter fields are placed in its own structure and the
ftrace_ops can carefully use the same filter. This change took a bit
to be able to allow for this and currently only the global_ops can
share the same filter, but this new design can easily be modified to
allow for any ftrace_ops to share its filter with another ftrace_ops.
The first four patches deal with the change of allowing the ftrace_ops
to share the filter (and this needs to go to 3.16 as well).
The fifth patch fixes a bug that was also caused by the new changes
but only for archs other than x86, and only if those archs implement a
direct call to the function_graph tracer which they do not do yet but
will in the future. It does not need to go to stable, but needs to be
fixed before the other archs update their code to allow direct calls
to the function_graph trampoline"
* tag 'trace-fixes-v3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ftrace: Use current addr when converting to nop in __ftrace_replace_code()
ftrace: Fix function_profiler and function tracer together
ftrace: Fix up trampoline accounting with looping on hash ops
ftrace: Update all ftrace_ops for a ftrace_hash_ops update
ftrace: Allow ftrace_ops to use the hashes from other ops
At this point, USB/IP kernel code is fully functional
and can be moved out of staging.
Signed-off-by: Valentina Manea <valentina.manea.m@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull gpio fixes from Linus Walleij:
- a largeish fix for the IRQ handling in the new Zynq driver. The
quite verbose commit message gives the exact details.
- move some defines for gpiod flags outside an ifdef to make stub
functions work again.
- various minor fixes that we can accept for -rc1.
* tag 'gpio-v3.17-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio-lynxpoint: enable input sensing in resume
gpio: move GPIOD flags outside #ifdef
gpio: delete unneeded test before of_node_put
gpio: zynq: Fix IRQ handlers
gpiolib: devres: use correct structure type name in sizeof
MAINTAINERS: Change maintainer for gpio-bcm-kona.c
Pull drm fixes from Dave Airlie:
"Intel and radeon fixes.
Post KS/LC git requests from i915 and radeon stacked up. They are all
fixes along with some new pci ids for radeon, and one maintainers file
entry.
- i915: display fixes and irq fixes
- radeon: pci ids, and misc gpuvm, dpm and hdp cache"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (29 commits)
MAINTAINERS: Add entry for Renesas DRM drivers
drm/radeon: add additional SI pci ids
drm/radeon: add new bonaire pci ids
drm/radeon: add new KV pci id
Revert "drm/radeon: Use write-combined CPU mappings of ring buffers with PCIe"
drm/radeon: fix active_cu mask on SI and CIK after re-init (v3)
drm/radeon: fix active cu count for SI and CIK
drm/radeon: re-enable selective GPUVM flushing
drm/radeon: Sync ME and PFP after CP semaphore waits v4
drm/radeon: fix display handling in radeon_gpu_reset
drm/radeon: fix pm handling in radeon_gpu_reset
drm/radeon: Only flush HDP cache for indirect buffers from userspace
drm/radeon: properly document reloc priority mask
drm/i915: don't try to retrain a DP link on an inactive CRTC
drm/i915: make sure VDD is turned off during system suspend
drm/i915: cancel hotplug and dig_port work during suspend and unload
drm/i915: fix HPD IRQ reenable work cancelation
drm/i915: take display port power domain in DP HPD handler
drm/i915: Don't try to enable cursor from setplane when crtc is disabled
drm/i915: Skip load detect when intel_crtc->new_enable==true
This handles the 'nonblock=false' case in nfs_lock_and_join_requests.
If the group is already locked and blocking is allowed, drop the inode lock
and wait for the group lock to be cleared before trying it all again.
This should fix warnings found in peterz's tree (sched/wait branch), where
might_sleep() checks are added to wait.[ch].
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
Reviewed-by: Peng Tao <tao.peng@primarydata.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Pull networking fixes from David Miller:
"Here are some bug fixes that have piled up during ksummit/linuxcon.
1) Fix endian problems in ibmveth, from Anton Blanchard.
2) IPV6 routing code does GFP_KERNEL allocation in atomic, fix from
Benjamin Block.
3) SCTP association fixes from Daniel Borkmann.
4) When multiple VLAN headers are present we have to make sure the
second and subsequent ones are pullable in the SKB otherwise we
blindly dereference garbage. From Jiri Benc.
5) The argument adjustment of the signature of hlist_add_after*()
introduced a regression in the batman-adv code, fix from Sven
Eckelmann.
6) Fix TX hang handling to avoid a panic in i40e, from Anjali Singhai
Jain.
7) PTP flag test is inverted in i40e driver, from Jesse Brandeburg.
8) ATM LEC driver needs to hold RTNL mutex over MTU changes, from
Chas Williams.
9) Truncate packets larger then the TPACKET_V3 format configured
buffers, otherwise we overwrite past the end of said buffers.
From Eric Dumazet.
10) Fix endianness bugs in qlcnic firmware handling, from Rajesh
Borundia and Shahed Shaikh.
11) CXGB4 sometimes doesn't get all of the TX completion events it
should resulting in SKBs getting stuck in the TX queue, from
Hariprasad Shenai.
12) When the FEC chip's PTP clock is disabled, you can't access the
register. Add necessary checks to avoid the resulting hang, from
Fugang Duan"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (37 commits)
drivers: isdn: eicon: xdi_msg.h: Fix typo in #ifndef
net: sctp: fix suboptimal edge-case on non-active active/retrans path selection
net: sctp: spare unnecessary comparison in sctp_trans_elect_best
net: ethernet: broadcom: bnx2x: Remove redundant #ifdef
ibmveth: Fix endian issues with rx_no_buffer statistic
net: xgene: fix possible NULL dereference in xgene_enet_free_desc_rings()
openvswitch: fix panic with multiple vlan headers
net: ipv6: fib: don't sleep inside atomic lock
net: fec: ptp: avoid register access when ipg clock is disabled
cxgb4: Free completed tx skbs promptly
cxgb4: Fix race condition in cleanup
sctp: not send SCTP_PEER_ADDR_CHANGE notifications with failed probe
bnx2x: Revert UNDI flushing mechanism
qlcnic: Fix endianess issue in firmware load from file operation
qlcnic: Fix endianess issue in FW dump template header
qlcnic: Fix flash access interface to application
MAINTAINERS: Add section for MRF24J40 IEEE 802.15.4 radio driver
macvlan: Allow setting multicast filter on all macvlan types
packet: handle too big packets for PACKET_V3
MAINTAINERS: add entry for ec_bhf driver
Currently the top level debug file system function tracer shares its
ftrace_ops with the function graph tracer. This was thought to be fine
because the tracers are not used together, as one can only enable
function or function_graph tracer in the current_tracer file.
But that assumption proved to be incorrect. The function profiler
can use the function graph tracer when function tracing is enabled.
Since all function graph users uses the function tracing ftrace_ops
this causes a conflict and when a user enables both function profiling
as well as the function tracer it will crash ftrace and disable it.
The quick solution so far is to move them as separate ftrace_ops like
it was earlier. The problem though is to synchronize the functions that
are traced because both function and function_graph tracer are limited
by the selections made in the set_ftrace_filter and set_ftrace_notrace
files.
To handle this, a new structure is made called ftrace_ops_hash. This
structure will now hold the filter_hash and notrace_hash, and the
ftrace_ops will point to this structure. That will allow two ftrace_ops
to share the same hashes.
Since most ftrace_ops do not share the hashes, and to keep allocation
simple, the ftrace_ops structure will include both a pointer to the
ftrace_ops_hash called func_hash, as well as the structure itself,
called local_hash. When the ops are registered, the func_hash pointer
will be initialized to point to the local_hash within the ftrace_ops
structure. Some of the ftrace internal ftrace_ops will be initialized
statically. This will allow for the function and function_graph tracer
to have separate ops but still share the same hash tables that determine
what functions they trace.
Cc: stable@vger.kernel.org # 3.16 (apply after 3.17-rc4 is out)
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Will Deacon:
"This small set of fixes addresses a few issues introduced during the
merge window, including:
- fix typo in I-cache detection that was causing us to treat all
I-caches as aliasing
- hook up memfd_create and getrandom syscalls for native and compat
- revert a temporary hack for defconfig builds in -next (the audit
tree changes didn't make it in this merge window)
- a couple of UEFI fixes for TEXT_OFFSET fuzzing and /memreserve/
- a simple sparsemem fix for 48-bit physical addressing
- small defconfig updates to get autotesters working with X-gene"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
Revert "arm64: Do not invoke audit_syscall_* functions if !CONFIG_AUDIT_SYSCALL"
arm64: mm: update max pa bits to 48
arm64: ignore DT memreserve entries when booting in UEFI mode
arm64: configs: Enable X-Gene SATA and ethernet in defconfig
arm64: align randomized TEXT_OFFSET on 4 kB boundary
asm-generic: add memfd_create system call to unistd.h
arm64: compat: wire up memfd_create and getrandom syscalls for aarch32
arm64: fix typo in I-cache policy detection
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=82912
The GPIOD flags are defined inside the #ifdef CONFIG_GPIOLIB
switch, making the gpiolib stubs fail if these flags are used
by a consumer. This is not correct: the stubs should compile
fine without GPIOLIB.
Reported-by: Ulf Hansson <ulf.hansson@linaro.org>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
Commit da3c6647(I2C/ACPI: Clean up I2C ACPI code and Add CONFIG_I2C_ACPI
config) adds a new kernel config I2C_ACPI and make I2C core built in
when the config is selected. This is wrong because distributions
etc generally compile I2C as a module and the commit broken that.
This patch is to rename I2C_ACPI to ACPI_I2C_OPREGION. New config
only controls ACPI I2C operation region code and depends on I2C=y.
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
[wsa: removed unrelated change for Kconfig]
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Instead of hard coding the value properly document
that this is an userspace interface.
No intended functional change.
Signed-off-by: Christian König <christian.koenig@amd.com>
Commit 9183df25fe7b ("shm: add memfd_create() syscall") added a new
system call (memfd_create) but didn't update the asm-generic unistd
header.
This patch adds the new system call to the asm-generic version of
unistd.h so that it can be used by architectures such as arm64.
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
A wildcard entry with the 32-bits OUI 0x600d8400 was added as part of
the BCM7xxx internal PHY driver, but that entry might match other PHYs
that are not covered by this driver, so let's just remove it.
Fixes: b560a58c45c6 ("net: phy: add Broadcom BCM7xxx internal PHY driver")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: David S. Miller <davem@greenl8ke.davemloft.net>
Pull more SCSI changes from James Bottomley:
"This is a small set of updates which missed the first pull. It's more
msix updates, some iscsi and qla4xxx fixes, we also have some string
null termination fixes a return value fix and a couple of pm8001
firmware fixes.
Just a note, we do have a couple of bug fixes coming under separate
cover, but they don't have to be part of the merge window"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
iscsi class: Fix freeing of skb in get host error path
scsi: fix u14-34f printk format warnings
pm8001: fix pm8001_store_update_fw
pm8001: Fix erratic calculation in update_flash
pm8001: Update MAINTAINERS list
libiscsi: return new error code when nop times out
iscsi class: fix get_host_stats return code when not supported
iscsi class: fix get_host_stats error handling
qla4xxx: fix get_host_stats error propagation
qla4xxx: check the return value of dma_alloc_coherent()
scsi: qla4xxx: ql4_mbx.c: Cleaning up missing null-terminate in conjunction with strncpy
scsi: qla4xxx: ql4_os.c: Cleaning up missing null-terminate in conjunction with strncpy
qla4xxx: Use pci_enable_msix_exact() instead of pci_enable_msix()
pm8001: Use pci_enable_msix_exact() instead of pci_enable_msix()
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input layer fixes from Dmitry Torokhov:
"Second round of updates for the input subsystem. Mostly small fixups
to the code merged in the first round (atmel_mxt_ts, wacom) but also a
smallish patch to xbox driver to support Xbox One controllers and a
patch to better handle Synaptics profile sensors found in Cr-48
Chromebooks that should not affect any other devices"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: edt-ft5x06 - remove superfluous assignment
Input: xpad - add support for Xbox One controllers
Input: atmel_mxt_ts - fix a few issues reported by Coverity
Input: atmel_mxt_ts - split config update a bit
Input: atmel_mxt_ts - simplify mxt_initialize a bit
Input: joystick - use get_cycles on ARMv8
Input: wacom - fix compiler warning if !CONFIG_PM
Input: cap1106 - allow changing key mapping from userspace
Input: synaptics - use firmware data for Cr-48
Input: synaptics - properly initialize slots for semi-MT
Input: MT - make slot cleanup callable outside mt_sync_frame()
Input: atmel_mxt_ts - mXT224 DMA quirk was fixed in firmware v2.0.AA
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac
Pull EDAC updates from Mauro Carvalho Chehab.
* 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac:
sb_edac: add support for Haswell based systems
sb_edac: Fix mix tab/spaces alignments
edac: add DDR4 and RDDR4
sb_edac: remove bogus assumption on mc ordering
sb_edac: make minimal use of channel_mask
sb_edac: fix socket detection on Ivy Bridge controllers
sb_edac: update Kconfig description
sb_edac: search devices using product id
sb_edac: make RIR limit retrieval per model
sb_edac: make node id retrieval per model
sb_edac: make memory type detection per memory controller
We used to use this for determining whether to sort the dispatch list,
but it's unused now.
Signed-off-by: Jens Axboe <axboe@fb.com>
Pull more ACPI and power management updates from Rafael Wysocki:
"These are a couple of regression fixes, cpuidle menu governor
optimizations, fixes for ACPI proccessor and battery drivers,
hibernation fix to avoid problems related to the e820 memory map,
fixes for a few cpufreq drivers and a new version of the suspend
profiling tool analyze_suspend.py.
Specifics:
- Fix for an ACPI-based device hotplug regression introduced in 3.14
that causes a kernel panic to trigger when memory hot-remove is
attempted with CONFIG_ACPI_HOTPLUG_MEMORY unset from Tang Chen
- Fix for a cpufreq regression introduced in 3.16 that triggers a
"sleeping function called from invalid context" bug in
dev_pm_opp_init_cpufreq_table() from Stephen Boyd
- ACPI battery driver fix for a warning message added in 3.16 that
prints silly stuff sometimes from Mariusz Ceier
- Hibernation fix for safer handling of mismatches in the 820 memory
map between the configurations during image creation and during the
subsequent restore from Chun-Yi Lee
- ACPI processor driver fix to handle CPU hotplug notifications
correctly during system suspend/resume from Lan Tianyu
- Series of four cpuidle menu governor cleanups that also should
speed it up a bit from Mel Gorman
- Fixes for the speedstep-smi, integrator, cpu0 and arm_big_little
cpufreq drivers from Hans Wennborg, Himangi Saraogi, Markus
Pargmann and Uwe Kleine-König
- Version 3.0 of the analyze_suspend.py suspend profiling tool from
Todd E Brandt"
* tag 'pm+acpi-3.17-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / battery: Fix warning message in acpi_battery_get_state()
PM / tools: analyze_suspend.py: update to v3.0
cpufreq: arm_big_little: fix module license spec
cpufreq: speedstep-smi: fix decimal printf specifiers
ACPI / hotplug: Check scan handlers in acpi_scan_hot_remove()
cpufreq: OPP: Avoid sleeping while atomic
cpufreq: cpu0: Do not print error message when deferring
cpufreq: integrator: Use set_cpus_allowed_ptr
PM / hibernate: avoid unsafe pages in e820 reserved regions
ACPI / processor: Make acpi_cpu_soft_notify() process CPU FROZEN events
cpuidle: menu: Lookup CPU runqueues less
cpuidle: menu: Call nr_iowait_cpu less times
cpuidle: menu: Use ktime_to_us instead of reinventing the wheel
cpuidle: menu: Use shifts when calculating averages where possible
"I'm sending this out, in particular, to get the iwlwifi fix
propagated:
1) Fix build due to missing include in i40e driver, from Lucas
Tanure.
2) Memory leak in openvswitch port allocation, from Chirstoph Jaeger.
3) Check DMA mapping errors in myri10ge, from Stanislaw Gruszka.
4) Fix various deadlock scenerios in sunvnet driver, from Sowmini
Varadhan.
5) Fix cxgb4i build failures with incompatible Kconfig settings of
the driver vs ipv6, from Anish Bhatt.
6) Fix generation of ACK packet timestamps in the presence of TSO
which will be split up, from Willem de Bruijn.
7) Don't enable sched scan in iwlwifi driver, it causes firmware
crashes in some revisions. From Emmanuel Grumbach.
8) Revert a macvlan simplification that causes crashes.
9) Handle RTT calculations properly in the presence of repair'd SKBs,
from Andrey Vagin.
10) SIT tunnel lookup uses wrong device index in compares, from
Shmulik Ladkani.
11) Handle MTU reductions in TCP properly for ipv4 mapped ipv6
sockets, from Neal Cardwell.
12) Add missing annotations in rhashtable code, from Thomas Graf.
13) Fix false interpretation of two RTOs as being from the same TCP
loss event in the FRTO code, from Neal Cardwell"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (42 commits)
netlink: Annotate RCU locking for seq_file walker
rhashtable: fix annotations for rht_for_each_entry_rcu()
rhashtable: unexport and make rht_obj() static
rhashtable: RCU annotations for next pointers
tcp: fix ssthresh and undo for consecutive short FRTO episodes
tcp: don't allow syn packets without timestamps to pass tcp_tw_recycle logic
tcp: fix tcp_release_cb() to dispatch via address family for mtu_reduced()
sit: Fix ipip6_tunnel_lookup device matching criteria
net: ethernet: ibm: ehea: Remove duplicate object from Makefile
net: xgene: Check negative return value of xgene_enet_get_ring_size()
tcp: don't use timestamp from repaired skb-s to calculate RTT (v2)
net: xilinx: Remove .owner field for driver
Revert "macvlan: simplify the structure port"
iwlwifi: mvm: disable scheduled scan to prevent firmware crash
xen-netback: remove loop waiting function
xen-netback: don't stop dealloc kthread too early
xen-netback: move NAPI add/remove calls
xen-netback: fix debugfs entry creation
xen-netback: fix debugfs write length check
net-timestamp: fix missing tcp fragmentation cases
Call rcu_deference_raw() directly from within rht_for_each_entry_rcu()
as list_for_each_entry_rcu() does.
Fixes the following sparse warnings:
net/netlink/af_netlink.c:2906:25: expected struct rhash_head const *__mptr
net/netlink/af_netlink.c:2906:25: got struct rhash_head [noderef] <asn:4>*<noident>
Fixes: e341694e3eb57fc ("netlink: Convert netlink_lookup() to use RCU protected hash table")
Signed-off-by: Thomas Graf <tgraf@suug.ch>
No need to export rht_obj(), all inner to outer object translations
occur internally. It was intended to be used with rht_for_each() which
now primarily serves as the iterator for rhashtable_remove_pprev() to
effectively flush and free the full table.
Properly annotate next pointers as access is RCU protected in
the lookup path.
tcp_tw_recycle heavily relies on tcp timestamps to build a per-host
ordering of incoming connections and teardowns without the need to
hold state on a specific quadruple for TCP_TIMEWAIT_LEN, but only for
the last measured RTO. To do so, we keep the last seen timestamp in a
per-host indexed data structure and verify if the incoming timestamp
in a connection request is strictly greater than the saved one during
last connection teardown. Thus we can verify later on that no old data
packets will be accepted by the new connection.
During moving a socket to time-wait state we already verify if timestamps
where seen on a connection. Only if that was the case we let the
time-wait socket expire after the RTO, otherwise normal TCP_TIMEWAIT_LEN
will be used. But we don't verify this on incoming SYN packets. If a
connection teardown was less than TCP_PAWS_MSL seconds in the past we
cannot guarantee to not accept data packets from an old connection if
no timestamps are present. We should drop this SYN packet. This patch
closes this loophole.
Please note, this patch does not make tcp_tw_recycle in any way more
usable but only adds another safety check:
Sporadic drops of SYN packets because of reordering in the network or
in the socket backlog queues can happen. Users behing NAT trying to
connect to a tcp_tw_recycle enabled server can get caught in blackholes
and their connection requests may regullary get dropped because hosts
behind an address translator don't have synchronized tcp timestamp clocks.
tcp_tw_recycle cannot work if peers don't have tcp timestamps enabled.
In general, use of tcp_tw_recycle is disadvised.
Cc: Florian Westphal <fw@strlen.de>
Make sure we use the correct address-family-specific function for
handling MTU reductions from within tcp_release_cb().
Previously AF_INET6 sockets were incorrectly always using the IPv6
code path when sometimes they were handling IPv4 traffic and thus had
an IPv4 dst.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Diagnosed-by: Willem de Bruijn <willemb@google.com>
Fixes: 563d34d057862 ("tcp: dont drop MTU reduction indications")
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
We don't know right timestamp for repaired skb-s. Wrong RTT estimations
isn't good, because some congestion modules heavily depends on it.
This patch adds the TCPCB_REPAIRED flag, which is included in
TCPCB_RETRANS.
Thanks to Eric for the advice how to fix this issue.
This patch fixes the warning:
[ 879.562947] WARNING: CPU: 0 PID: 2825 at net/ipv4/tcp_input.c:3078 tcp_ack+0x11f5/0x1380()
[ 879.567253] CPU: 0 PID: 2825 Comm: socket-tcpbuf-l Not tainted 3.16.0-next-20140811 #1
[ 879.567829] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 879.568177] 0000000000000000 00000000c532680c ffff880039643d00 ffffffff817aa2d2
[ 879.568776] 0000000000000000 ffff880039643d38 ffffffff8109afbd ffff880039d6ba80
[ 879.569386] ffff88003a449800 000000002983d6bd 0000000000000000 000000002983d6bc
[ 879.569982] Call Trace:
[ 879.570264] [<ffffffff817aa2d2>] dump_stack+0x4d/0x66
[ 879.570599] [<ffffffff8109afbd>] warn_slowpath_common+0x7d/0xa0
[ 879.570935] [<ffffffff8109b0ea>] warn_slowpath_null+0x1a/0x20
[ 879.571292] [<ffffffff816d0a05>] tcp_ack+0x11f5/0x1380
[ 879.571614] [<ffffffff816d10bd>] tcp_rcv_established+0x1ed/0x710
[ 879.571958] [<ffffffff816dc9da>] tcp_v4_do_rcv+0x10a/0x370
[ 879.572315] [<ffffffff81657459>] release_sock+0x89/0x1d0
[ 879.572642] [<ffffffff816c81a0>] do_tcp_setsockopt.isra.36+0x120/0x860
[ 879.573000] [<ffffffff8110a52e>] ? rcu_read_lock_held+0x6e/0x80
[ 879.573352] [<ffffffff816c8912>] tcp_setsockopt+0x32/0x40
[ 879.573678] [<ffffffff81654ac4>] sock_common_setsockopt+0x14/0x20
[ 879.574031] [<ffffffff816537b0>] SyS_setsockopt+0x80/0xf0
[ 879.574393] [<ffffffff817b40a9>] system_call_fastpath+0x16/0x1b
[ 879.574730] ---[ end trace a17cbc38eb8c5c00 ]---
v2: moving setting of skb->when for repaired skb-s in tcp_write_xmit,
where it's set for other skb-s.
Fixes: 431a91242d8d ("tcp: timestamp SYN+DATA messages")
Fixes: 740b0f1841f6 ("tcp: switch rtt estimations to usec resolution")
Cc: Eric Dumazet <edumazet@google.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Signed-off-by: Andrey Vagin <avagin@openvz.org>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/rdma updates from Roland Dreier:
"Main set of InfiniBand/RDMA updates for 3.17 merge window:
- MR reregistration support
- MAD support for RMPP in userspace
- iSER and SRP initiator updates
- ocrdma hardware driver updates
- other fixes..."
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (52 commits)
IB/srp: Fix return value check in srp_init_module()
RDMA/ocrdma: report asic-id in query device
RDMA/ocrdma: Update sli data structure for endianness
RDMA/ocrdma: Obtain SL from device structure
RDMA/uapi: Include socket.h in rdma_user_cm.h
IB/srpt: Handle GID change events
IB/mlx5: Use ARRAY_SIZE instead of sizeof/sizeof[0]
IB/mlx4: Use ARRAY_SIZE instead of sizeof/sizeof[0]
RDMA/amso1100: Check for integer overflow in c2_alloc_cq_buf()
IPoIB: Remove unnecessary test for NULL before debugfs_remove()
IB/mad: Add user space RMPP support
IB/mad: add new ioctl to ABI to support new registration options
IB/mad: Add dev_notice messages for various umad/mad registration failures
IB/mad: Update module to [pr|dev]_* style print messages
IB/ipoib: Avoid multicast join attempts with invalid P_key
IB/umad: Update module to [pr|dev]_* style print messages
IB/ipoib: Avoid flushing the workqueue from worker context
IB/ipoib: Use P_Key change event instead of P_Key polling mechanism
IB/ipath: Add P_Key change event support
mlx4_core: Add support for secure-host and SMP firewall
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull more powerpc updates from Ben Herrenschmidt:
"Here are some more powerpc bits for 3.17, essentially fixes.
The biggest series, also aimed at -stable, is from Aneesh and is the
result of weeks and weeks of debugging to find out why the heck or THP
implementation was occasionally triggering multi-hit errors in our
level 1 TLB. It ended up being a combination of issues including
subtleties as to how we should invalidate those special 'MPSS' pages
we use to allow the use of 16M pages inside 4K/64K "base page size"
segments (you really have to love our MMU !)
Another interesting one in the "OMG" category is the series from
Michael adding memory barriers to spin_is_locked(). That's also the
result of many days of debugging to figure out why the semaphore code
would occasionally crash in ways that made no sense. It ended up
being some creative lock stacking that was defeated by the fact that
our locks allow a load inside the locked section to be re-ordered with
the load of the lock value itself (I'm still of two mind about whether
to kill that once and for all by putting a heavier barrier back into
our lock implementation...). The fixes come with a long explanation
in the cset comments, feel free to read it if you feel like having a
headache today"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (25 commits)
powerpc/thp: Add tracepoints to track hugepage invalidate
powerpc/mm: Use read barrier when creating real_pte
powerpc/thp: Use ACCESS_ONCE when loading pmdp
powerpc/thp: Invalidate with vpn in loop
powerpc/thp: Handle combo pages in invalidate
powerpc/thp: Invalidate old 64K based hash page mapping before insert of 4k pte
powerpc/thp: Don't recompute vsid and ssize in loop on invalidate
powerpc/thp: Add write barrier after updating the valid bit
powerpc: reorder per-cpu NUMA information's initialization
powerpc/perf/hv-24x7: Use kmem_cache_free
powerpc/pseries/hvcserver: Fix endian issue in hvcs_get_partner_info
powerpc: Hard disable interrupts in xmon
powerpc: remove duplicate definition of TEXASR_FS
powerpc/pseries: Avoid deadlock on removing ddw
powerpc/pseries: Failure on removing device node
powerpc/boot: Use correct zlib types for comparison
powerpc/powernv: Interface to register/unregister opal dump region
printk: Add function to return log buffer address and size
powerpc: Add POWER8 features to CPU_FTRS_POSSIBLE/ALWAYS
powerpc/ppc476: Disable BTAC
'mlx4', 'mlx5', 'ocrdma' and 'srp' into for-next
