path: root/include
2013-07-21pinctrl: am33xx dt binding: correct include pathIan Campbell
Using #include <include/...> is a bit odd. It happens to work because the DTC flags include -Iarch/FOO/boot/dts as well as arch/FOO/boot/dts/include and arch/FOO/boot/dts/include/dt-bindings is a symlink to include/dt-bindings. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-14Merge branch 'slab/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull slab update from Pekka Enberg: "Highlights: - Fix for boot-time problems on some architectures due to init_lock_keys() not respecting kmalloc_caches boundaries (Christoph Lameter) - CONFIG_SLUB_CPU_PARTIAL requested by RT folks (Joonsoo Kim) - Fix for excessive slab freelist draining (Wanpeng Li) - SLUB and SLOB cleanups and fixes (various people)" I ended up editing the branch, and this avoids two commits at the end that were immediately reverted, and I instead just applied the oneliner fix in between myself. * 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux slub: Check for page NULL before doing the node_match check mm/slab: Give s_next and s_stop slab-specific names slob: Check for NULL pointer before calling ctor() slub: Make cpu partial slab support configurable slab: add kmalloc() to kernel API documentation slab: fix init_lock_keys slob: use DIV_ROUND_UP where possible slub: do not put a slab to cpu partial list when cpu_partial is 0 mm/slub: Use node_nr_slabs and node_nr_objs in get_slabinfo mm/slub: Drop unnecessary nr_partials mm/slab: Fix /proc/slabinfo unwriteable for slab mm/slab: Sharing s_next and s_stop between slab and slub mm/slab: Fix drain freelist excessively slob: Rework #ifdeffery in slab.h mm, slab: moved kmem_cache_alloc_node comment to correct place
2013-07-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs stuff from Al Viro: "O_TMPFILE ABI changes, Oleg's fput() series, misc cleanups, including making simple_lookup() usable for filesystems with non-NULL s_d_op, which allows us to get rid of quite a bit of ugliness" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: sunrpc: now we can just set ->s_d_op cgroup: we can use simple_lookup() now efivarfs: we can use simple_lookup() now make simple_lookup() usable for filesystems that set ->s_d_op configfs: don't open-code d_alloc_name() __rpc_lookup_create_exclusive: pass string instead of qstr rpc_create_*_dir: don't bother with qstr llist: llist_add() can use llist_add_batch() llist: fix/simplify llist_add() and llist_add_batch() fput: turn "list_head delayed_fput_list" into llist_head fs/file_table.c:fput(): add comment Safer ABI for O_TMPFILE
2013-07-14rpc_create_*_dir: don't bother with qstrAl Viro
just pass the name Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Just a bunch of small fixes and tidy ups: 1) Finish the "busy_poll" renames, from Eliezer Tamir. 2) Fix RCU stalls in IFB driver, from Ding Tianhong. 3) Linearize buffers properly in tun/macvtap zerocopy code. 4) Don't crash on rmmod in vxlan, from Pravin B Shelar. 5) Spinlock used before init in alx driver, from Maarten Lankhorst. 6) A sparse warning fix in bnx2x broke TSO checksums, fix from Dmitry Kravkov. 7) Dummy and ifb driver load failure paths can oops, fixes from Tan Xiaojun and Ding Tianhong. 8) Correct MTU calculations in IP tunnels, from Alexander Duyck. 9) Account all TCP retransmits in SNMP stats properly, from Yuchung Cheng. 10) atl1e and via-rhine do not handle DMA mapping failures properly, from Neil Horman. 11) Various equal-cost multipath route fixes in ipv6 from Hannes Frederic Sowa" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (36 commits) ipv6: only static routes qualify for equal cost multipathing via-rhine: fix dma mapping errors atl1e: fix dma mapping warnings tcp: account all retransmit failures usb/net/r815x: fix cast to restricted __le32 usb/net/r8152: fix integer overflow in expression net: access page->private by using page_private net: strict_strtoul is obsolete, use kstrtoul instead drivers/net/ieee802154: don't use devm_pinctrl_get_select_default() in probe drivers/net/ethernet/cadence: don't use devm_pinctrl_get_select_default() in probe drivers/net/can/c_can: don't use devm_pinctrl_get_select_default() in probe net/usb: add relative mii functions for r815x net/tipc: use %*phC to dump small buffers in hex form qlcnic: Adding Maintainers. gre: Fix MTU sizing check for gretap tunnels pkt_sched: sch_qfq: remove forward declaration of qfq_update_agg_ts pkt_sched: sch_qfq: improve efficiency of make_eligible gso: Update tunnel segmentation to support Tx checksum offload inet: fix spacing in assignment ifb: fix oops when loading the ifb failed ...
2013-07-13Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: - watchdog fixes for full dynticks - improved debug output for full dynticks - remove an obsolete full dynticks check - two ARM SoC clocksource drivers for sharing across SoCs - tick broadcast fix for CPU hotplug * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick: broadcast: Check broadcast mode on CPU hotplug clocksource: arm_global_timer: Add ARM global timer support clocksource: Add Marvell Orion SoC timer nohz: Remove obsolete check for full dynticks CPUs to be RCU nocbs watchdog: Boot-disable by default on full dynticks watchdog: Rename confusing state variable watchdog: Register / unregister watchdog kthreads on sysctl control nohz: Warn if the machine can not perform nohz_full
2013-07-13Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking updates from Thomas Gleixner: "Header cleanup as requested by Linus" (This is the "don't include support for ww_mutex in a header file that everybody wants, when almost nobody wants the ww part" change) * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: mutex: Move ww_mutex definitions to ww_mutex.h
2013-07-13Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "MIPS updates: - All the things that didn't make 3.10. - Removes the Windriver PPMC platform. Nobody will miss it. - Remove a workaround from kernel/irq/irqdomain.c which was there exclusivly for MIPS. Patch by Grant Likely. - More small improvments for the SEAD 3 platform - Improvments on the BMIPS / SMP support for the BCM63xx series. - Various cleanups of dead leftovers. - Platform support for the Cavium Octeon-based EdgeRouter Lite. Two large KVM patchsets didn't make it for this pull request because their respective authors are vacationing" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (124 commits) MIPS: Kconfig: Add missing MODULES dependency to VPE_LOADER MIPS: BCM63xx: CLK: Add dummy clk_{set,round}_rate() functions MIPS: SEAD3: Disable L2 cache on SEAD-3. MIPS: BCM63xx: Enable second core SMP on BCM6328 if available MIPS: BCM63xx: Add SMP support to prom.c MIPS: define write{b,w,l,q}_relaxed MIPS: Expose missing pci_io{map,unmap} declarations MIPS: Malta: Update GCMP detection. Revert "MIPS: make CAC_ADDR and UNCAC_ADDR account for PHYS_OFFSET" MIPS: APSP: Remove <asm/kspd.h> SSB: Kconfig: Amend SSB_EMBEDDED dependencies MIPS: microMIPS: Fix improper definition of ISA exception bit. MIPS: Don't try to decode microMIPS branch instructions where they cannot exist. MIPS: Declare emulate_load_store_microMIPS as a static function. MIPS: Fix typos and cleanup comment MIPS: Cleanup indentation and whitespace MIPS: BMIPS: support booting from physical CPU other than 0 MIPS: Only set cpu_has_mmips if SYS_SUPPORTS_MICROMIPS MIPS: GIC: Fix gic_set_affinity infinite loop MIPS: Don't save/restore OCTEON wide multiplier state on syscalls. ...
2013-07-13Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull InfiniBand/RDMA changes from Roland Dreier: - AF_IB (native IB addressing) for CMA from Sean Hefty - new mlx5 driver for Mellanox Connect-IB adapters (including post merge request fixes) - SRP fixes from Bart Van Assche (including fix to first merge request) - qib HW driver updates - resurrection of ocrdma HW driver development - uverbs conversion to create fds with O_CLOEXEC set - other small changes and fixes * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (66 commits) mlx5: Return -EFAULT instead of -EPERM IB/qib: Log all SDMA errors unconditionally IB/qib: Fix module-level leak mlx5_core: Adjust hca_cap.uar_page_sz to conform to Connect-IB spec IB/srp: Let srp_abort() return FAST_IO_FAIL if TL offline IB/uverbs: Use get_unused_fd_flags(O_CLOEXEC) instead of get_unused_fd() mlx5_core: Fixes for sparse warnings IB/mlx5: Make profile[] static in main.c mlx5: Fix parameter type of health_handler_t mlx5: Add driver for Mellanox Connect-IB adapters IB/core: Add reserved values to enums for low-level driver use IB/srp: Bump driver version and release date IB/srp: Make HCA completion vector configurable IB/srp: Maintain a single connection per I_T nexus IB/srp: Fail I/O fast if target offline IB/srp: Skip host settle delay IB/srp: Avoid skipping srp_reset_host() after a transport error IB/srp: Fix remove_one crash due to resource exhaustion IB/qib: New transmitter tunning settings for Dell 1.1 backplane IB/core: Fix error return code in add_port() ...
2013-07-13Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This series contain: - new i2c video drivers: ml86v7667 (video decoder), ths8200 (video encoder) - a new video driver for EasyCap cards based on Fushicai USBTV007 - Improved support for OF and embedded systems, with V4L2 async initialization and a better support for clocks - API cleanups on the ioctls used by the v4l2 debug tool - Lots of cleanups - As usual, several driver improvements and new cards additions - Revert two changesets that change the minimal symbol rate for stv0399, as request by Manu - Update MAINTAINERS and other files to point to my new e-mail" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (378 commits) MAINTAINERS & ABI: Update to point to my new email [media] stb0899: restore minimal rate to 5Mbauds [media] exynos4-is: Correct colorspace handling at FIMC-LITE [media] exynos4-is: Set valid initial format on FIMC.n subdevs [media] exynos4-is: Set valid initial format on FIMC-IS-ISP subdev pads [media] exynos4-is: Fix format propagation on FIMC-IS-ISP subdev [media] exynos4-is: Set valid initial format at FIMC-LITE [media] exynos4-is: Fix format propagation on FIMC-LITE.n subdevs [media] MAINTAINERS: Update S5P/Exynos FIMC driver entry [media] Documentation: Update driver's directory in video4linux/fimc.txt [media] exynos4-is: Change fimc-is firmware file names [media] exynos4-is: Add support for Exynos5250 MIPI-CSIS [media] exynos4-is: Add Exynos5250 SoC support to fimc-lite driver [media] exynos4-is: Drop drvdata handling in fimc-lite for non-dt platforms [media] media: i2c: tvp514x: remove manual setting of subdev name [media] media: i2c: tvp7002: remove manual setting of subdev name [media] mem2mem: set missing v4l2_dev pointer [media] wl128x: add missing struct v4l2_device [media] tvp514x: Fix init seqeunce [media] saa7134: Fix sparse warnings by adding __user annotation ...
2013-07-13llist: llist_add() can use llist_add_batch()Oleg Nesterov
llist_add(new, head) can simply use llist_add_batch(new, new, head), no need to duplicate the code. This obviously uninlines llist_add() and to me this is a win. But we can make llist_add_batch() inline if this is desirable, in this case gcc can notice that new_first == new_last if the caller is llist_add(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13llist: fix/simplify llist_add() and llist_add_batch()Oleg Nesterov
1. This is mostly theoretical, but llist_add*() need ACCESS_ONCE(). Otherwise it is not guaranteed that the first cmpxchg() uses the same value for old_entry and new_last->next. 2. These helpers cache the result of cmpxchg() and read the initial value of head->first before the main loop. I do not think this makes sense. In the likely case cmpxchg() succeeds, otherwise it doesn't hurt to reload head->first. I think it would be better to simplify the code and simply read ->first before cmpxchg(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13fput: turn "list_head delayed_fput_list" into llist_headOleg Nesterov
fput() and delayed_fput() can use llist and avoid the locking. This is unlikely path, it is not that this change can improve the performance, but this way the code looks simpler. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13Safer ABI for O_TMPFILEAl Viro
[suggested by Rasmus Villemoes] make O_DIRECTORY | O_RDWR part of O_TMPFILE; that will fail on old kernels in a lot more cases than what I came up with. And make sure O_CREAT doesn't get there... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-12Merge branch 'linus' into timers/urgentThomas Gleixner
Get upstream changes so we can apply fixes against them Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-07-12mutex: Move ww_mutex definitions to ww_mutex.hMaarten Lankhorst
Move the definitions for wound/wait mutexes out to a separate header, ww_mutex.h. This reduces clutter in mutex.h, and increases readability. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Cc: Dave Airlie <airlied@gmail.com> Link: http://lkml.kernel.org/r/51D675DC.3000907@canonical.com [ Tidied up the code a bit. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-07-11Merge branches 'mlx5', 'qib' and 'srp' into for-nextRoland Dreier
2013-07-11mlx5_core: Adjust hca_cap.uar_page_sz to conform to Connect-IB specMoshe Lazer
Sparse reported an endianness bug in the assignment to hca_cap.uar_page_sz. Fix the declaration of this field to be __be16 (which is what is in the firmware spec), renaming the field to log_uar_pg_size to conform to the spec, which fixes the endianness bug reported by sparse. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Moshe Lazer <moshel@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-07-11Merge tag 'dm-3.11-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper changes from Alasdair G Kergon: "Add a device-mapper target called dm-switch to provide a multipath framework for storage arrays that dynamically reconfigure their preferred paths for different device regions. Fix a bug in the verity target that prevented its use with some specific sizes of devices. Improve some locking mechanisms in the device-mapper core and bufio. Add Mike Snitzer as a device-mapper maintainer. A few more clean-ups and fixes" * tag 'dm-3.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: dm: add switch target dm: update maintainers dm: optimize reorder structure dm: optimize use SRCU and RCU dm bufio: submit writes outside lock dm cache: fix arm link errors with inline dm verity: use __ffs and __fls dm flakey: correct ctr alloc failure mesg dm verity: remove pointless comparison dm: use __GFP_HIGHMEM in __vmalloc dm verity: fix inability to use a few specific devices sizes dm ioctl: set noio flag to avoid __vmalloc deadlock dm mpath: fix ioctl deadlock when no paths
2013-07-11Merge branch 'for-3.11/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO updates from Jens Axboe: "Here are the core IO block bits for 3.11. It contains: - A tweak to the reserved tag logic from Jan, for weirdo devices with just 3 free tags. But for those it improves things substantially for random writes. - Periodic writeback fix from Jan. Marked for stable as well. - Fix for a race condition in IO scheduler switching from Jianpeng. - The hierarchical blk-cgroup support from Tejun. This is the grunt of the series. - blk-throttle fix from Vivek. Just a note that I'm in the middle of a relocation, whole family is flying out tomorrow. Hence I will be awal the remainder of this week, but back at work again on Monday the 15th. CC'ing Tejun, since any potential "surprises" will most likely be from the blk-cgroup work. But it's been brewing for a while and sitting in my tree and linux-next for a long time, so should be solid." * 'for-3.11/core' of git://git.kernel.dk/linux-block: (36 commits) elevator: Fix a race in elevator switching block: Reserve only one queue tag for sync IO if only 3 tags are available writeback: Fix periodic writeback after fs mount blk-throttle: implement proper hierarchy support blk-throttle: implement throtl_grp->has_rules[] blk-throttle: Account for child group's start time in parent while bio climbs up blk-throttle: add throtl_qnode for dispatch fairness blk-throttle: make throtl_pending_timer_fn() ready for hierarchy blk-throttle: make tg_dispatch_one_bio() ready for hierarchy blk-throttle: make blk_throtl_bio() ready for hierarchy blk-throttle: make blk_throtl_drain() ready for hierarchy blk-throttle: dispatch from throtl_pending_timer_fn() blk-throttle: implement dispatch looping blk-throttle: separate out throtl_service_queue->pending_timer from throtl_data->dispatch_work blk-throttle: set REQ_THROTTLED from throtl_charge_bio() and gate stats update with it blk-throttle: implement sq_to_tg(), sq_to_td() and throtl_log() blk-throttle: add throtl_service_queue->parent_sq blk-throttle: generalize update_disptime optimization in blk_throtl_bio() blk-throttle: dispatch to throtl_data->service_queue.bio_lists[] blk-throttle: move bio_lists[] and friends to throtl_service_queue ...
2013-07-11Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "Lots of activity this round on performance improvements in target-core while benchmarking the prototype scsi-mq initiator code with vhost-scsi fabric ports, along with a number of iscsi/iser-target improvements and hardening fixes for exception path cases post v3.10 merge. The highlights include: - Make persistent reservations APTPL buffer allocated on-demand, and drop per t10_reservation buffer. (grover) - Make virtual LUN=0 a NULLIO device, and skip allocation of NULLIO device pages (grover) - Add transport_cmd_check_stop write_pending bit to avoid extra access of ->t_state_lock is WRITE I/O submission fast-path. (nab) - Drop unnecessary CMD_T_DEV_ACTIVE check from transport_lun_remove_cmd to avoid extra access of ->t_state_lock in release fast-path. (nab) - Avoid extra t_state_lock access in __target_execute_cmd fast-path (nab) - Drop unnecessary vhost-scsi wait_for_tasks=true usage + ->t_state_lock access in release fast-path. (nab) - Convert vhost-scsi to use modern se_cmd->cmd_kref TARGET_SCF_ACK_KREF usage (nab) - Add tracepoints for SCSI commands being processed (roland) - Refactoring of iscsi-target handling of ISCSI_OP_NOOP + ISCSI_OP_TEXT to be transport independent (nab) - Add iscsi-target SendTargets=$IQN support for in-band discovery (nab) - Add iser-target support for in-band discovery (nab + Or) - Add iscsi-target demo-mode TPG authentication context support (nab) - Fix isert_put_reject payload buffer post (nab) - Fix iscsit_add_reject* usage for iser (nab) - Fix iscsit_sequence_cmd reject handling for iser (nab) - Fix ISCSI_OP_SCSI_TMFUNC handling for iser (nab) - Fix session reset bug with RDMA_CM_EVENT_DISCONNECTED (nab) The last five iscsi/iser-target items are CC'ed to stable, as they do address issues present in v3.10 code. They are certainly larger than I'd like for stable patch set, but are important to ensure proper REJECT exception handling in iser-target for 3.10.y" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits) iser-target: Ignore non TEXT + LOGOUT opcodes for discovery target: make queue_tm_rsp() return void target: remove unused codes from enum tcm_tmrsp_table iscsi-target: kstrtou* configfs attribute parameter cleanups iscsi-target: Fix tfc_tpg_auth_cit configfs length overflow iscsi-target: Fix tfc_tpg_nacl_auth_cit configfs length overflow iser-target: Add support for ISCSI_OP_TEXT opcode + payload handling iser-target: Rename sense_buf_[dma,len] to pdu_[dma,len] iser-target: Add vendor_err debug output target: Add (obsolete) checking for PMI/LBA fields in READ CAPACITY(10) target: Return correct sense data for IO past the end of a device target: Add tracepoints for SCSI commands being processed iser-target: Fix session reset bug with RDMA_CM_EVENT_DISCONNECTED iscsi-target: Fix ISCSI_OP_SCSI_TMFUNC handling for iser iscsi-target: Fix iscsit_sequence_cmd reject handling for iser iscsi-target: Fix iscsit_add_reject* usage for iser iser-target: Fix isert_put_reject payload buffer post iscsi-target: missing kfree() on error path iscsi-target: Drop left-over iscsi_conn->bad_hdr target: Make core_scsi3_update_and_write_aptpl return sense_reason_t ...
2013-07-11Merge tag 'remoteproc-3.11-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc Pull remoteproc fixes from Ohad Ben-Cohen: "Trivial remoteproc fixes by Suman Anna, Wei Yongjun and Thomas Meyer" * tag 'remoteproc-3.11-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: remoteproc: Cocci spatch "memdup.spatch" remoteproc: free carveout memories only after unmapping them remoteproc/omap: fix a sparse warning remoteproc: fix checkpatch errors in remoteproc code remoteproc: fix error return code in rproc_fw_boot()
2013-07-11Merge tag 'xtensa-next-20130710' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa updates from Chris Zankel. * tag 'xtensa-next-20130710' of git://github.com/czankel/xtensa-linux: (22 commits) xtensa: remove the second argument of __bio_kmap_atomic() xtensa: add static function tracer support xtensa: Flat DeviceTree copy not future-safe xtensa: check TLB sanity on return to userspace xtensa: adjust boot parameters address when INITIALIZE_XTENSA_MMU_INSIDE_VMLINUX is selected xtensa: bootparams: fix typo xtensa: tell git to ignore generated .dtb files xtensa: ccount based sched_clock xtensa: ccount based clockevent implementation xtensa: consolidate ccount access routines xtensa: cleanup ccount frequency tracking xtensa: timex.h: remove unused symbols xtensa: tell git to ignore copied zlib source files xtensa: fix section mismatch in pcibios_fixup_bus xtensa: ISS: fix section mismatch in iss_net_setup arch: xtensa: include: asm: compiling issue, need cmpxchg64() defined. xtensa: xtfpga: fix section mismatch xtensa: remove unused platform_init_irq() xtensa: tell git to ignore generated files xtensa: flush TLB entries for pages of non-current mm correctly ...
2013-07-11Merge tag 'pm+acpi-3.11-rc1-more' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management and ACPI updates from Rafael Wysocki: - Fix for a recent cpufreq regression that caused WARN() to trigger overzealously in a couple of places and spam the kernel log with useless garbage as a result. From Viresh Kumar. - ACPI dock fix removing a discrepancy between the definition of acpi_dock_init(), which says that the function returns int, and its header in the header file, which says that it is a void function. The function is now defined as void too. - ACPI PM fix for failures to update device power states as needed, for example, during resume from system suspend, because the old state was deeper than the new one, but the new one is not D0. - Fix for two debug messages in the ACPI power resources code that don't have a newline at the end and make the kernel log difficult to read. From Mika Westerberg. - Two ACPI cleanups from Naresh Bhat and Haicheng Li. - cpupower updates from Thomas Renninger, including Intel Haswell support improvements and a new idle-set subcommand among other things. * tag 'pm+acpi-3.11-rc1-more' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / power: add missing newline to debug messages cpupower: Add Haswell family 0x45 specific idle monitor to show PC8,9,10 states cpupower: Haswell also supports the C-states introduced with SandyBridge cpupower: Introduce idle-set subcommand and C-state enabling/disabling cpupower: Implement disabling of cstate interface cpupower: Make idlestate usage unsigned ACPI / fan: Initialize acpi_state variable ACPI / scan: remove unused LIST_HEAD(acpi_device_list) ACPI / dock: Actually define acpi_dock_init() as void ACPI / PM: Fix corner case in acpi_bus_update_power() cpufreq: Fix serialization of frequency transitions
2013-07-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "There are not too many changes this time, except two new platform thermal drivers, ti-soc-thermal driver and x86_pkg_temp_thermal driver, and a couple of small fixes. Highlights: - move the ti-soc-thermal driver out of the staging tree to the thermal tree. - introduce the x86_pkg_temp_thermal driver. This driver registers CPU digital temperature package level sensor as a thermal zone. - small fixes/cleanups including removing redundant use of platform_set_drvdata() and of_match_ptr for all platform thermal drivers" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (34 commits) thermal: cpu_cooling: fix stub function thermal: ti-soc-thermal: use standard GPIO DT bindings thermal: MAINTAINERS: Add git tree path for SoC specific updates thermal: fix x86_pkg_temp_thermal.c build and Kconfig Thermal: Documentation for x86 package temperature thermal driver Thermal: CPU Package temperature thermal thermal: consider emul_temperature while computing trend thermal: ti-soc-thermal: add DT example for DRA752 chip thermal: ti-soc-thermal: add dra752 chip to device table thermal: ti-soc-thermal: add thermal data for DRA752 chips thermal: ti-soc-thermal: remove usage of IS_ERR_OR_NULL thermal: ti-soc-thermal: freeze FSM while computing trend thermal: ti-soc-thermal: remove external heat while extrapolating hotspot thermal: ti-soc-thermal: update DT reference for OMAP5430 x86, mcheck, therm_throt: Process package thresholds thermal: cpu_cooling: fix 'descend' check in get_property() Thermal: spear: Remove redundant use of of_match_ptr Thermal: kirkwood: Remove redundant use of of_match_ptr Thermal: dove: Remove redundant use of of_match_ptr Thermal: armada: Remove redundant use of of_match_ptr ...
2013-07-11Merge tag 'nfs-for-3.11-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull second set of NFS client updates from Trond Myklebust: "This mainly contains some small readdir optimisations that had dependencies on Al Viro's readdir rewrite. There is also a fix for a nasty deadlock which surfaced earlier in this merge window. Highlights include: - Fix an_rpc pipefs regression that causes a deadlock on mount - Readdir optimisations by Scott Mayhew and Jeff Layton - clean up the rpc_pipefs dentry operation setup" * tag 'nfs-for-3.11-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: SUNRPC: Fix a deadlock in rpc_client_register() rpc_pipe: rpc_dir_inode_operations can be static NFS: Allow nfs_updatepage to extend a write under additional circumstances NFS: Make nfs_readdir revalidate less often NFS: Make nfs_attribute_cache_expired() non-static rpc_pipe: set dentry operations at d_alloc time nfs: set verifier on existing dentries in nfs_prime_dcache
2013-07-11Merge tag 'for-linus-3.11-merge-window-part-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull second round of 9p patches from Eric Van Hensbergen: "Several of these patches were rebased in order to correct style issues. Only stylistic changes were made versus the patches which were in linux-next for two weeks. The rebases have been in linux-next for 3 days and have passed my regressions. The bulk of these are RDMA fixes and improvements. There's also some additions on the extended attributes front to support some additional namespaces and a new option for TCP to force allocation of mount requests from a priviledged port" * tag 'for-linus-3.11-merge-window-part-2' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: fs/9p: Remove the unused variable "err" in v9fs_vfs_getattr() 9P: Add cancelled() to the transport functions. 9P/RDMA: count posted buffers without a pending request 9P/RDMA: Improve error handling in rdma_request 9P/RDMA: Do not free req->rc in error handling in rdma_request() 9P/RDMA: Use a semaphore to protect the RQ 9P/RDMA: Protect against duplicate replies 9P/RDMA: increase P9_RDMA_MAXSIZE to 1MB 9pnet: refactor struct p9_fcall alloc code 9P/RDMA: rdma_request() needs not allocate req->rc 9P: Fix fcall allocation for rdma fs/9p: xattr: add trusted and security namespaces net/9p: add privport option to 9p tcp transport
2013-07-11Merge branch 'for-3.11' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from Bruce Fields: "Changes this time include: - 4.1 enabled on the server by default: the last 4.1-specific issues I know of are fixed, so we're not going to find the rest of the bugs without more exposure. - Experimental support for NFSv4.2 MAC Labeling (to allow running selinux over NFS), from Dave Quigley. - Fixes for some delicate cache/upcall races that could cause rare server hangs; thanks to Neil Brown and Bodo Stroesser for extreme debugging persistence. - Fixes for some bugs found at the recent NFS bakeathon, mostly v4 and v4.1-specific, but also a generic bug handling fragmented rpc calls" * 'for-3.11' of git://linux-nfs.org/~bfields/linux: (31 commits) nfsd4: support minorversion 1 by default nfsd4: allow destroy_session over destroyed session svcrpc: fix failures to handle -1 uid's sunrpc: Don't schedule an upcall on a replaced cache entry. net/sunrpc: xpt_auth_cache should be ignored when expired. sunrpc/cache: ensure items removed from cache do not have pending upcalls. sunrpc/cache: use cache_fresh_unlocked consistently and correctly. sunrpc/cache: remove races with queuing an upcall. nfsd4: return delegation immediately if lease fails nfsd4: do not throw away 4.1 lock state on last unlock nfsd4: delegation-based open reclaims should bypass permissions svcrpc: don't error out on small tcp fragment svcrpc: fix handling of too-short rpc's nfsd4: minor read_buf cleanup nfsd4: fix decoding of compounds across page boundaries nfsd4: clean up nfs4_open_delegation NFSD: Don't give out read delegations on creates nfsd4: allow client to send no cb_sec flavors nfsd4: fail attempts to request gss on the backchannel nfsd4: implement minimal SP4_MACH_CRED ...
2013-07-11Merge tag 'trace-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing changes from Steven Rostedt: "The majority of the changes here are cleanups for the large changes that were added to 3.10, which includes several bug fixes that have been marked for stable. As for new features, there were a few, but nothing to write to LWN about. These include: New function trigger called "dump" and "cpudump" that will cause ftrace to dump its buffer to the console when the function is called. The difference between "dump" and "cpudump" is that "dump" will dump the entire contents of the ftrace buffer, where as "cpudump" will only dump the contents of the ftrace buffer for the CPU that called the function. Another small enhancement is a new sysctl switch called "traceoff_on_warning" which, when enabled, will disable tracing if any WARN_ON() is triggered. This is useful if you want to debug what caused a warning and do not want to risk losing your trace data by the ring buffer overwriting the data before you can disable it. There's also a kernel command line option that will make this enabled at boot up called the same thing" * tag 'trace-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (34 commits) tracing: Make tracing_open_generic_{tr,tc}() static tracing: Remove ftrace() function tracing: Remove TRACE_EVENT_TYPE enum definition tracing: Make tracer_tracing_{off,on,is_on}() static tracing: Fix irqs-off tag display in syscall tracing uprobes: Fix return value in error handling path tracing: Fix race between deleting buffer and setting events tracing: Add trace_array_get/put() to event handling tracing: Get trace_array ref counts when accessing trace files tracing: Add trace_array_get/put() to handle instance refs better tracing: Protect ftrace_trace_arrays list in trace_events.c tracing: Make trace_marker use the correct per-instance buffer ftrace: Do not run selftest if command line parameter is set tracing/kprobes: Don't pass addr=ip to perf_trace_buf_submit() tracing: Use flag buffer_disabled for irqsoff tracer tracing/kprobes: Turn trace_probe->files into list_head tracing: Fix disabling of soft disable tracing: Add missing syscall_metadata comment tracing: Simplify code for showing of soft disabled flag tracing/kprobes: Kill probe_enable_lock ...
2013-07-10Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge more patches from Andrew Morton: "The rest of MM" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: mm: remove free_area_cache zswap: add documentation zswap: add to mm/ zbud: add to mm/
2013-07-10mm: remove free_area_cacheMichel Lespinasse
Since all architectures have been converted to use vm_unmapped_area(), there is no remaining use for the free_area_cache. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Helge Deller <deller@gmx.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-10zbud: add to mm/Seth Jennings
zbud is an special purpose allocator for storing compressed pages. It is designed to store up to two compressed pages per physical page. While this design limits storage density, it has simple and deterministic reclaim properties that make it preferable to a higher density approach when reclaim will be used. zbud works by storing compressed pages, or "zpages", together in pairs in a single memory page called a "zbud page". The first buddy is "left justifed" at the beginning of the zbud page, and the last buddy is "right justified" at the end of the zbud page. The benefit is that if either buddy is freed, the freed buddy space, coalesced with whatever slack space that existed between the buddies, results in the largest possible free region within the zbud page. zbud also provides an attractive lower bound on density. The ratio of zpages to zbud pages can not be less than 1. This ensures that zbud can never "do harm" by using more pages to store zpages than the uncompressed zpages would have used on their own. This implementation is a rewrite of the zbud allocator internally used by zcache in the driver/staging tree. The rewrite was necessary to remove some of the zcache specific elements that were ingrained throughout and provide a generic allocation interface that can later be used by zsmalloc and others. This patch adds zbud to mm/ for later use by zswap. Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Cc: Jenifer Hopper <jhopper@us.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Hansen <dave@sr71.net> Cc: Joe Perches <joe@perches.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Hugh Dickens <hughd@google.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Bob Liu <bob.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-10net: rename busy poll socket op and globalsEliezer Tamir
Rename LL_SO to BUSY_POLL_SO Rename sysctl_net_ll_{read,poll} to sysctl_busy_{read,poll} Fix up users of these variables. Fix documentation for sysctl. a patch for the socket.7 man page will follow separately, because of limitations of my mail setup. Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-10net: rename ll methods to busy-pollEliezer Tamir
Rename ndo_ll_poll to ndo_busy_poll. Rename sk_mark_ll to sk_mark_napi_id. Rename skb_mark_ll to skb_mark_napi_id. Correct all useres of these functions. Update comments and defines in include/net/busy_poll.h Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-10net: rename include/net/ll_poll.h to include/net/busy_poll.hEliezer Tamir
Rename the file and correct all the places where it is included. Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-10dm: optimize use SRCU and RCUMikulas Patocka
This patch removes "io_lock" and "map_lock" in struct mapped_device and "holders" in struct dm_table and replaces these mechanisms with sleepable-rcu. Previously, the code would call "dm_get_live_table" and "dm_table_put" to get and release table. Now, the code is changed to call "dm_get_live_table" and "dm_put_live_table". dm_get_live_table locks sleepable-rcu and dm_put_live_table unlocks it. dm_get_live_table_fast/dm_put_live_table_fast can be used instead of dm_get_live_table/dm_put_live_table. These *_fast functions use non-sleepable RCU, so the caller must not block between them. If the code changes active or inactive dm table, it must call dm_sync_table before destroying the old table. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2013-07-10Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Nothing interesting. Except the most embarrassing bugfix ever. But let's ignore that" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: cleanup call chain. module: do percpu allocation after uniqueness check. No, really! modules: don't fail to load on unknown parameters. ABI: Clarify when /sys/module/MODULENAME is created There is no /sys/parameters module: don't modify argument of module_kallsyms_lookup_name()
2013-07-10Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "No real surprises" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MAINTAINERS: add tools/virtio/ under virtio tools/virtio: move module license stub to module.h virtio: include asm/barrier explicitly virtio: VIRTIO_F_ANY_LAYOUT feature lguest: fix example launcher compilation for broken glibc headers. virtio-net: fix the race between channels setting and refill tools/lguest: real barriers. tools/lguest: fix missing rmb(). virtio_balloon: leak_balloon(): only tell host if we got pages deflated virtio-pci: fix leaks of msix_affinity_masks Fix comment typo "CONFIG_PAE"
2013-07-10Merge tag 'vfio-v3.11' of git://github.com/awilliam/linux-vfioLinus Torvalds
Pull vfio updates from Alex Williamson: "Largely hugepage support for vfio/type1 iommu and surrounding cleanups and fixes" * tag 'vfio-v3.11' of git://github.com/awilliam/linux-vfio: vfio/type1: Fix leak on error path vfio: Limit group opens vfio/type1: Fix missed frees and zero sized removes vfio: fix documentation vfio: Provide module option to disable vfio_iommu_type1 hugepage support vfio: hugepage support for vfio_iommu_type1 vfio: Convert type1 iommu to use rbtree
2013-07-10Merge tag 'mmc-updates-for-3.11-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: "MMC highlights for 3.11: Core: - Add support for eMMC 5.1 devices - Add MMC_CAP_AGGRESSIVE_PM capability for aggressive power management of eMMC/SD between requests, using runtime PM - Add an ioctl to perform the eMMC 4.5 Sanitize command. Sample code at: git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc-utils.git Drivers: - dw_mmc: Add support for Rockchip's Cortex-A9 SoCs - dw_mmc: Add support for Altera SoCFPGAs - sdhci-esdhc-imx: Add support for 8-bit bus width, non-removable cards - sdhci-bcm-kona: New driver for Broadcom Kona (281xx) SoCs - sdhi/tmio: Add DT DMA support" * tag 'mmc-updates-for-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (87 commits) mmc: bcm281xx SDHCI driver mmc: sdhci: add card_event callback to sdhci mmc: core: Fixup Oops for SDIO shutdown mmc: sdhci-pci: add another device id mmc: esdhc: Fix bug when writing to SDHCI_HOST_CONTROL register mmc: esdhc: Add support for 8-bit bus width and non-removable card mmc: core: production year for eMMC 4.41 and later mmc: omap: remove unnecessary #if 0's mmc: sdhci: fix ctrl_2 on super-speed selection mmc: dw_mmc-pltfm: add Rockchip variant mmc: dw_mmc-pltfm: move probe and remove below dt match table mmc: dw_mmc-pltfm: remove static from dw_mci_pltfm_remove mmc: sdhci-acpi: add support for eMMC hardware reset for HID 80860F14 mmc: sdhci-pci: add support for eMMC hardware reset for BYT eMMC. mmc: dw_mmc: Add support DW SD/MMC driver on SOCFPGA mmc: sdhci: fix caps2 for HS200 sdhci-pxav3: Fix runtime PM initialization mmc: core: Add DT-bindings for MMC_CAP2_FULL_PWR_CYCLE mmc: core: Invent MMC_CAP2_FULL_PWR_CYCLE mmc: core: Enable power_off_notify for eMMC shutdown sequence ...
2013-07-10Merge tag 'for-3.11-rc1' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull pwm changes from Thierry Reding: "A new driver supports driving PWM signals using the TPU unit found on various Renesas SoCs. Furthermore support is added for the NXP PCA9685 LED controller. Another big chunk is the sysfs interface which has been in the works for quite some time. The remaining patches are a random assortment of cleanups and fixes" * tag 'for-3.11-rc1' of git://gitorious.org/linux-pwm/linux-pwm: pwm: pwm-tiehrpwm: Use clk_enable/disable instead clk_prepare/unprepare. pwm: pca9685: Fix wrong argument to set MODE1_SLEEP bit pwm: renesas-tpu: Add MODULE_ALIAS to make module auto loading work pwm: renesas-tpu: fix return value check in tpu_probe() pwm: Add Renesas TPU PWM driver pwm: Add sysfs interface pwm: Fill in missing .owner fields pwm: add pca9685 driver pwm: atmel-tcb: prepare clk before calling enable pwm: devm: alloc correct pointer size pwm: mxs: Let device core handle pinctrl MAINTAINERS: Update PWM subsystem entry
2013-07-10Merge tag 'for-v3.11' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery subsystem update from Anton Vorontsov: "Nothing exciting this time, just assorted fixes and cleanups" * tag 'for-v3.11' of git://git.infradead.org/battery-2.6: (25 commits) charger-manager: Fix regulator_get() return check charger-manager: Fix a bug when it unregisters notifier block of extcon tps65090-charger: Add dt node to power_supply sbs-battery: Add dt to power_supply struct power_supply: Add of_node_put to fix refcount power_supply: Move of_node out of the #ifdef CONFIG_OF power/reset: Make the vexpress driver optional on arm and arm64 charger-manager: Add missing newlines, fix a couple of typos, add pr_fmt tps65090-charger: Fix AC detect MAINTAINERS: Update email address for Anton Vorontsov charger-manager: Ensure event is not used as format string power_supply: Replace strict_strtoul() with kstrtoul() generic-adc-battery: Fix checking if none of the channels are supported power: Use platform_{get,set}_drvdata() pm2301_charger: Return error if create_singlethread_workqueue fails pm2301_charger: Fix NULL pointer dereference lp8727_charger: Support the device tree feature twl4030_charger: Remove unnecessary platform_set_drvdata() rx51_battery: Remove unnecessary platform_set_drvdata() jz4740-battery: Remove unnecessary platform_set_drvdata() ...
2013-07-10Merge tag 'mfd-3.11-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next Pull MFD update from Samuel Ortiz: "For the 3.11 merge we only have one new MFD driver for the Kontron PLD. But we also have: - Support for the TPS659038 PMIC from the palmas driver. - Intel's Coleto Creek and Avoton SoCs support from the lpc_ich driver. - RTL8411B support from the rtsx driver. - More DT support for the Arizona, max8998, twl4030-power and the ti_am335x_tsadc drivers. - The SSBI driver move under MFD. - A conversion to the devm_* API for most of the MFD drivers. - The twl4030-power got split from twl-core into its own module. - A major ti_am335x_adc cleanup, leading to a proper DT support. - Our regular arizona and wm* updates and cleanups from the Wolfson folks. - A better error handling and initialization, and a regulator subdevice addition for the 88pm80x driver. - A bulk platform_set_drvdata() call removal that's no longer need since commit 0998d0631001 ("device-core: Ensure drvdata = NULL when no driver is bound") * tag 'mfd-3.11-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next: (102 commits) mfd: sec: Provide max_register to regmap mfd: wm8994: Remove duplicate check for active JACKDET MAINTAINERS: Add include directory to MFD file patterns mfd: sec: Remove fields not used since regmap conversion watchdog: Kontron PLD watchdog timer driver mfd: max8998: Add support for Device Tree regulator: max8998: Use arrays for specifying voltages in platform data mfd: max8998: Add irq domain support regulator: palmas: Add TPS659038 support mfd: Kontron PLD mfd driver mfd: palmas: Add TPS659038 PMIC support mfd: palmas: Add SMPS10_BOOST feature mfd: palmas: Check if irq is valid mfd: lpc_ich: iTCO_wdt patch for Intel Coleto Creek DeviceIDs mfd: twl-core: Change TWL6025 references to TWL6032 mfd: davinci_voicecodec: Fix build breakage mfd: vexpress: Make the driver optional for arm and arm64 mfd: htc-egpio: Use devm_ioremap_nocache() instead of ioremap_nocache() mfd: davinci_voicecodec: Convert to use devm_* APIs mfd: twl4030-power: Fix relocking on error ...
2013-07-10Merge tag 'regulator-v3.11-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator fixes from Mark Brown: "Fixes for the merge window A set of small fixes for issues noticed during the merge window, all very much non-invasive" * tag 'regulator-v3.11-2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: MAINTAINERS: Update git repository regulator: max8997: Fix a trivial typo in documentation regulator: s5m8767: Fix a trivial typo in documentation regulator: s2mps11: Convert ramp rate to uV/us and set default ramp rate regulator: s5m8767: Update s5m8767-regulator bindings document
2013-07-10Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire updates from Stefan Richter: "Make struct ieee1394_device_id.driver_data actually avaliable to 1394 protocol drivers. This is especially useful to 1394 audio drivers for model-specific parameters and methods" * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: remove support of fw_driver.driver.probe and .remove methods firewire: introduce fw_driver.probe and .remove methods
2013-07-10Merge branch 'timers/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into timers/urgent Pull nohz updates/fixes from Frederic Weisbecker: ' Note that "watchdog: Boot-disable by default on full dynticks" is a temporary solution to solve the issue with the watchdog that prevents the tick from stopping. This is to make sure that 3.11 doesn't have that problem as several people complained about it. A proper and longer term solution has been proposed by Peterz: http://lkml.kernel.org/r/20130618103632.GO3204@twins.programming.kicks-ass.net ' Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-09Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Okay this is the big one, I was stalled on the fbdev pull req as I stupidly let fbdev guys merge a patch I required to fix a warning with some patches I had, they ended up merging the patch from the wrong place, but the warning should be fixed. In future I'll just take the patch myself! Outside drm: There are some snd changes for the HDMI audio interactions on haswell, they've been acked for inclusion via my tree. This relies on the wound/wait tree from Ingo which is already merged. Major changes: AMD finally released the dynamic power management code for all their GPUs from r600->present day, this is great, off by default for now but also a huge amount of code, in fact it is most of this pull request. Since it landed there has been a lot of community testing and Alex has sent a lot of fixes for any bugs found so far. I suspect radeon might now be the biggest kernel driver ever :-P p.s. radeon.dpm=1 to enable dynamic powermanagement for anyone. New drivers: Renesas r-car display unit. Other highlights: - core: GEM CMA prime support, use new w/w mutexs for TTM reservations, cursor hotspot, doc updates - dvo chips: chrontel 7010B support - i915: Haswell (fbc, ips, vecs, watermarks, audio powerwell), Valleyview (enabled by default, rc6), lots of pll reworking, 30bpp support (this time for sure) - nouveau: async buffer object deletion, context/register init updates, kernel vp2 engine support, GF117 support, GK110 accel support (with external nvidia ucode), context cleanups. - exynos: memory leak fixes, Add S3C64XX SoC series support, device tree updates, common clock framework support, - qxl: cursor hotspot support, multi-monitor support, suspend/resume support - mgag200: hw cursor support, g200 mode limiting - shmobile: prime support - tegra: fixes mostly I've been banging on this quite a lot due to the size of it, and it seems to okay on everything I've tested it on." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (811 commits) drm/radeon/dpm: implement vblank_too_short callback for si drm/radeon/dpm: implement vblank_too_short callback for cayman drm/radeon/dpm: implement vblank_too_short callback for btc drm/radeon/dpm: implement vblank_too_short callback for evergreen drm/radeon/dpm: implement vblank_too_short callback for 7xx drm/radeon/dpm: add checks against vblank time drm/radeon/dpm: add helper to calculate vblank time drm/radeon: remove stray line in old pm code drm/radeon/dpm: fix display_gap programming on rv7xx drm/nvc0/gr: fix gpc firmware regression drm/nouveau: fix minor thinko causing bo moves to not be async on kepler drm/radeon/dpm: implement force performance level for TN drm/radeon/dpm: implement force performance level for ON/LN drm/radeon/dpm: implement force performance level for SI drm/radeon/dpm: implement force performance level for cayman drm/radeon/dpm: implement force performance levels for 7xx/eg/btc drm/radeon/dpm: add infrastructure to force performance levels drm/radeon: fix surface setup on r1xx drm/radeon: add support for 3d perf states on older asics drm/radeon: set default clocks for SI when DPM is disabled ...
2013-07-09Merge tag 'fbdev-for-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/plagnioj/linux-fbdev Pull fbdev update from Jean-Christophe PLAGNIOL-VILLARD: "Various fbdev changes for 3.11 - xilinxfb updates - Small cleanups and fixes to multiple drivers - OMAP display subsystem bug updates - imxfb dt support" * tag 'fbdev-for-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/plagnioj/linux-fbdev: (95 commits) video: imxfb: Add DT support video: i740fb: Make i740fb_init static fb: make fp_get_options name argument const video: mmp: fix graphics/video layer enable/mask swap issue video: mmp: fix memcpy wrong size for mmp_addr issue radeon: use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM) aty128fb: use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM) video: of_display_timing.h: Declare 'display_timing' fbdev: bfin-lq035q1-fb: Use dev_pm_ops fbmem: return -EFAULT on copy_to_user() failure OMAPDSS: DPI: Fix wrong pixel clock limit video: replace strict_strtoul() with kstrtoul() uvesafb: Correct/simplify warning message fb: fix atyfb unused data warnings fb: fix atyfb build warning video: imxfb: Make local symbols static video: udlfb: Make local symbol static video: udlfb: Use NULL instead of 0 video: smscufx: Use NULL instead of 0 video: remove unnecessary platform_set_drvdata() ...
2013-07-09NFS: Make nfs_attribute_cache_expired() non-staticScott Mayhew
NFS: Make nfs_attribute_cache_expired() non-static so we can call it from nfs_readdir(). Signed-off-by: Scott Mayhew <smayhew@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
