commit e8c82c2e23e3527e0c9dc195e432c16784d270fa upstream.
An XFS workload showed up a bug in the lockless pagecache patch. Basically it
would go into an "infinite" loop, although it would sometimes be able to break
out of the loop! The reason is a missing compiler barrier in the "increment
reference count unless it was zero" case of the lockless pagecache protocol in
the gang lookup functions.
This would cause the compiler to use a cached value of struct page pointer to
retry the operation with, rather than reload it. So the page might have been
removed from pagecache and freed (refcount==0) but the lookup would not correctly
notice the page is no longer in pagecache, and keep attempting to increment the
refcount and failing, until the page gets reallocated for something else. This
isn't a data corruption because the condition will be detected if the page has
been reallocated. However it can result in a lockup.
Linus points out that ACCESS_ONCE is also required in that pointer load, even
if it's absence is not causing a bug on our particular build. The most general
way to solve this is just to put an rcu_dereference in radix_tree_deref_slot.
Assembly of find_get_pages,
before:
.L220:
movq (%rbx), %rax #* ivtmp.1162, tmp82
movq (%rax), %rdi #, prephitmp.1149
.L218:
testb $1, %dil #, prephitmp.1149
jne .L217 #,
testq %rdi, %rdi # prephitmp.1149
je .L203 #,
cmpq $-1, %rdi #, prephitmp.1149
je .L217 #,
movl 8(%rdi), %esi # <variable>._count.counter, c
testl %esi, %esi # c
je .L218 #,
after:
.L212:
movq (%rbx), %rax #* ivtmp.1109, tmp81
movq (%rax), %rdi #, ret
testb $1, %dil #, ret
jne .L211 #,
testq %rdi, %rdi # ret
je .L197 #,
cmpq $-1, %rdi #, ret
je .L211 #,
je .L212 #,
(notice the obvious infinite loop in the first example, if page->count remains 0)
Signed-off-by: Nick Piggin <npiggin@suse.de>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
commit 18e6959c385f3edf3991fa6662a53dac4eb10d5b upstream.
This assertion is incorrect for lockless pagecache. By definition if we
have an unpinned page that we are trying to take a speculative reference
to, it may become the tail of a compound page at any time (if it is
freed, then reallocated as a compound page).
It was still a valid assertion for the vmscan.c LRU isolation case, but
it doesn't seem incredibly helpful... if somebody wants it, they can
put it back directly where it applies in the vmscan code.
commit 54566b2c1594c2326a645a3551f9d989f7ba3c5e upstream.
With the write_begin/write_end aops, page_symlink was broken because it
could no longer pass a GFP_NOFS type mask into the point where the
allocations happened. They are done in write_begin, which would always
assume that the filesystem can be entered from reclaim. This bug could
cause filesystem deadlocks.
The funny thing with having a gfp_t mask there is that it doesn't really
allow the caller to arbitrarily tinker with the context in which it can be
called. It couldn't ever be GFP_ATOMIC, for example, because it needs to
take the page lock. The only thing any callers care about is __GFP_FS
anyway, so turn that into a single flag.
Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on
this flag in their write_begin function. Change __grab_cache_page to
accept a nofs argument as well, to honour that flag (while we're there,
change the name to grab_cache_page_write_begin which is more instructive
and does away with random leading underscores).
This is really a more flexible way to go in the end anyway -- if a
filesystem happens to want any extra allocations aside from the pagecache
ones in ints write_begin function, it may now use GFP_KERNEL (rather than
GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a
random example).
[kosaki.motohiro@jp.fujitsu.com: fix ubifs]
[kosaki.motohiro@jp.fujitsu.com: fix fuse]
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: <stable@kernel.org>
[ Cleaned up the calling convention: just pass in the AOP flags
untouched to the grab_cache_page_write_begin() function. That
just simplifies everybody, and may even allow future expansion of the
logic. - Linus ]
commit 2b66421995d2e93c9d1a0111acf2581f8529c6e5 upstream.
commit d4e82042c4cfa87a7d51710b71f568fe80132551 upstream.
commit ee6a093222549ac0c72cfd296c69fa5e7d6daa34 upstream.
This enables the use of syscall wrappers to do proper sign extension
for 64-bit programs.
commit 1a94bc34768e463a93cb3751819709ab0ea80a01 upstream.
By selecting HAVE_SYSCALL_WRAPPERS architectures can activate
system call wrappers in order to sign extend system call arguments.
All architectures where the ABI defines that the caller of a function
has to perform sign extension probably need this.
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
commit e55380edf68796d75bf41391a781c68ee678587d upstream.
This way it matches the generic system call name convention.
commit 2ed7c03ec17779afb4fcfa3b8c61df61bd4879ba upstream.
Convert all system calls to return a long. This should be a NOP since all
converted types should have the same size anyway.
With the exception of sys_exit_group which returned void. But that doesn't
matter since the system call doesn't return.
commit 4c696ba7982501d43dea11dbbaabd2aa8a19cc42 upstream.
Move declarations to correct header file.
commit 4ae8978cf92a96257cd8998a49e781be83571d64 upstream.
The problems lie in the types used for some inotify interfaces, both at the kernel level and at the glibc level. This mail addresses the kernel problem. I will follow up with some suggestions for glibc changes.
For the sys_inotify_rm_watch() interface, the type of the 'wd' argument is
currently 'u32', it should be '__s32' . That is Robert's suggestion, and
is consistent with the other declarations of watch descriptors in the
kernel source, in particular, the inotify_event structure in
include/linux/inotify.h:
struct inotify_event {
__s32 wd; /* watch descriptor */
__u32 mask; /* watch mask */
__u32 cookie; /* cookie to synchronize two events */
__u32 len; /* length (including nulls) of name */
char name[0]; /* stub for possible name */
The patch makes the changes needed for inotify_rm_watch().
Signed-off-by: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Robert Love <rlove@google.com>
Cc: Vegard Nossum <vegard.nossum@gmail.com>
Cc: Ulrich Drepper <drepper@redhat.com>
commit 1c5745aa380efb6417b5681104b007c8612fb496 upstream.
Redo:
5b7dba4: sched_clock: prevent scd->clock from moving backwards
which had to be reverted due to s2ram hangs:
ca7e716: Revert "sched_clock: prevent scd->clock from moving backwards"
... this time with resume restoring GTOD later in the sequence
taken into account as well.
The "timekeeping_suspended" flag is not very nice but we cannot call into
GTOD before it has been properly resumed and the scheduler will run very
early in the resume sequence.
commit 5289f46b9de04bde181d833d48df9671b69c4b08 upstream.
flush_tlb_mm's "optimized" uniprocessor case of allocating a new
context for userspace is exposing a race where we can suddely return
to a syscall with the protection id and space id out of sync, trapping
on the next userspace access.
Debugged-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Tested-by: Helge Deller <deller@gmx.de>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
commit d253eee20195b25e298bf162a6e72f14bf4803e5 upstream.
Due to a wrong safety check in af_can.c it was not possible to filter
for SFF frames with a specific CAN identifier without getting the
same selected CAN identifier from a received EFF frame also.
This fix has a minimum (but user visible) impact on the CAN filter
API and therefore the CAN version is set to a new date.
Indeed the 'old' API is still working as-is. But when now setting
CAN_(EFF|RTR)_FLAG in can_filter.can_mask you might get less traffic
than before - but still the stuff that you expected to get for your
defined filter ...
Thanks to Kurt Van Dijck for pointing at this issue and for the review.
Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net>
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be>
commit ae8d04e2ecbb233926860e9ce145eac19c7835dc upstream.
VMI initialiation can relocate the fixmap, causing early_ioremap to
malfunction if it is initialized before the relocation. To fix this,
VMI activation is split into two phases; the detection, which must
happen before setting up ioremap, and the activation, which must happen
after parsing early boot parameters.
This fixes a crash on boot when VMI is enabled under VMware.
Signed-off-by: Zachary Amsden <zach@vmware.com>
commit b563cf59c4d67da7d671788a9848416bfa4180ab upstream.
PnP encodes the resource type directly as its struct resource->flags value
which is an unsigned long. Make it so...
Signed-off-by: Rene Herman <rene.herman@gmail.com>
Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
commit bf2a9a39639b8b51377905397a5005f444e9a892 upstream.
binfmt_script and binfmt_misc disallow recursion to avoid stack overflow
using sh_bang and misc_bang. It causes problem in some cases:
$ echo '#!/bin/ls' > /tmp/t0
$ echo '#!/tmp/t0' > /tmp/t1
$ echo '#!/tmp/t1' > /tmp/t2
$ chmod +x /tmp/t*
$ /tmp/t2
zsh: exec format error: /tmp/t2
Similar problem with binfmt_misc.
This patch introduces field 'recursion_depth' into struct linux_binprm to
track recursion level in binfmt_misc and binfmt_script. If recursion
level more then BINPRM_MAX_RECURSION it generates -ENOEXEC.
[akpm@linux-foundation.org: make linux_binprm.recursion_depth a uint]
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Pavel Emelyanov <xemul@openvz.org>
commit 4afe978530702c934dfdb11f54073136818b2119 upstream.
When a checkpointing IO fails, current JBD code doesn't check the error
and continue journaling. This means latest metadata can be lost from both
the journal and filesystem.
This patch leaves the failed metadata blocks in the journal space and
aborts journaling in the case of log_do_checkpoint(). To achieve this, we
need to do:
1. don't remove the failed buffer from the checkpoint list where in
the case of __try_to_free_cp_buf() because it may be released or
overwritten by a later transaction
2. log_do_checkpoint() is the last chance, remove the failed buffer
from the checkpoint list and abort the journal
3. when checkpointing fails, don't update the journal super block to
prevent the journaled contents from being cleaned. For safety,
don't update j_tail and j_tail_sequence either
4. when checkpointing fails, notify this error to the ext3 layer so
that ext3 don't clear the needs_recovery flag, otherwise the
journaled contents are ignored and cleaned in the recovery phase
5. if the recovery fails, keep the needs_recovery flag
6. prevent cleanup_journal_tail() from being called between
__journal_drop_transaction() and journal_abort() (a race issue
between journal_flush() and __log_wait_for_space()
Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
Acked-by: Jan Kara <jack@suse.cz>
Cc: <linux-ext4@vger.kernel.org>
commit f2f1fa78a155524b849edf359e42a3001ea652c0 upstream.
There's no point in having too short SG_IO timeouts, since if the
command does end up timing out, we'll end up through the reset sequence
that is several seconds long in order to abort the command that timed
out.
As a result, shorter timeouts than a few seconds simply do not make
sense, as the recovery would be longer than the timeout itself.
Add a BLK_MIN_SG_TIMEOUT to match the existign BLK_DEFAULT_SG_TIMEOUT.
Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Jens Axboe <jens.axboe@oracle.com>
Cc: Jeff Garzik <jeff@garzik.org>
trimed down version of commit 05496769e5da83ce22ed97345afd9c7b71d6bd24 upstream.
Some devices such as "cciss/c0d0p9" will cause jbd2 setup and teardown
failures when /proc filenames are created with embedded slashes. This
is a slimmed down version of commit 05496769, with the stack reduction
aspects of the patch omitted to meet the -stable criteria.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 5f23b734963ec7eaa3ebcd9050da0c9b7d143dd3 upstream.
This is an implementation of David Miller's suggested fix in:
https://bugzilla.redhat.com/show_bug.cgi?id=470201
It has been updated to use wait_event() instead of
wait_event_interruptible().
Paraphrasing the description from the above report, it makes sendmsg()
block while UNIX garbage collection is in progress. This avoids a
situation where child processes continue to queue new FDs over a
AF_UNIX socket to a parent which is in the exit path and running
garbage collection on these FDs. This contention can result in soft
lockups and oom-killing of unrelated processes.
Signed-off-by: dann frazier <dannf@hp.com>
commit ac70a964b0e22a95af3628c344815857a01461b7 upstream.
Some recent Seagate harddrives have firmware bug which causes FLUSH
CACHE to timeout under certain circumstances if NCQ is being used.
This can be worked around by disabling NCQ and fixed by updating the
firmware. Implement ATA_HORKAGE_FIRMWARE_UPDATE and blacklist these
devices.
The wiki page has been updated to contain information on this issue.
http://ata.wiki.kernel.org/index.php/Known_issues
backport of commit 97a70e548bd97d5a46ae9d44f24aafcc013fd701 to the 2.6.27 kernel.
The NUMA code on x86_32 creates special memory mapping that allows
each node's pgdat to be located in this node's memory. For this
purpose it allocates a memory area at the end of each node's memory
and maps this area so that it is accessible with virtual addresses
belonging to low memory. As a result, if there is high memory,
these NUMA-allocated areas are physically located in high memory,
although they are mapped to low memory addresses.
Our hibernation code does not take that into account and for this
reason hibernation fails on all x86_32 systems with CONFIG_NUMA=y and
with high memory present. Fix this by adding a special mapping for
the NUMA-allocated memory areas to the temporary page tables created
during the last phase of resume.
commit 58319b802a614f10f1b5238fbde7a4b2e9a60069 upstream.
Now that the PCI core manages the 'name' for each individual
hotplug driver, and all drivers (except rpaphp) have been converted
to use hotplug_slot_name(), there is no need for the PCI hotplug
core to drag around its own copy of name either.
Cc: kristen.c.accardi@intel.com
Cc: matthew@wil.cx
Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 0ad772ec464d3fcf9d210836b97e654f393606c4 upstream
In preparation for cleaning up the various hotplug drivers
such that they don't have to manage their own 'name' parameters
anymore, we provide the following convenience functions:
pci_slot_name()
hotplug_slot_name()
These helpers will be used by individual hotplug drivers.
Cc: matthew@wil.cx
commit 828f37683e6d3ab5912989df0d04201db7ad798e upstream.
Slot detection drivers can co-exist with hotplug drivers. The names
of the detected/claimed slots may be different depending on module
load order.
For legacy reasons, we need to allow hotplug drivers to override
the slot name if a detection driver is loaded first (and they find
the same slots).
Creating and overriding slot names should be an atomic operation,
otherwise you get a locking nightmare as various drivers race to
call pci_create_slot().
pci_create_slot() is already serialized by grabbing the pci_bus_sem.
We update the API and add a 'hotplug' param, which is:
set if the caller is a hotplug driver
NULL if the caller is a detection driver
pci_create_slot() does not actually use the 'hotplug' parameter in this
patch. A later patch will add the logic that uses it.
Cc: matthew@wil.cx
commit 1359f2701b96abd9bb69c1273fb995a093b6409a upstream.
Update pci_hp_register() to take a const char *name parameter.
The motivation for this is to clean up the individual hotplug
drivers so that each one does not have to manage its own name.
The PCI core should be the place where we manage the name.
We update the interface and all callsites first, in a
"no functional change" manner, and clean up the drivers later.
Reviewed-by: Matthew Wilcox <willy@linux.intel.com>
commit b627c8b17ccacba38c975bc0f69a49fc4e5261c9 upstream.
Impact: fix boot crash on AMD IOMMU if CONFIG_GART_IOMMU is off
Currently these macros evaluate to a no-op except the kernel is compiled
with GART or Calgary support. But we also need these macros when we have
SWIOTLB, VT-d or AMD IOMMU in the kernel. Since we always compile at
least with SWIOTLB we can define these macros always.
This patch is also for stable backport for the same reason the SWIOTLB
default selection patch is.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 6ff2d39b91aec3dcae951afa982059e3dd9b49dc upstream.
2nd part of the fixes needed for
http://bugzilla.kernel.org/show_bug.cgi?id=11796.
When the idr tree is either grown or shrunk, then the update to the number
of layers and the top pointer were not atomic. This race caused crashes.
The attached patch fixes that by replicating the layers counter in each
layer, thus idr_find doesn't need idp->layers anymore.
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Cc: Clement Calmels <cboulte@gmail.com>
Cc: Nadia Derbey <Nadia.Derbey@bull.net>
Cc: Pierre Peiffer <peifferp@gmail.com>
commit 8f7b0ba1c853919b85b54774775f567f30006107 upstream.
Inotify watch removals suck violently.
To kick the watch out we need (in this order) inode->inotify_mutex and
ih->mutex. That's fine if we have a hold on inode; however, for all
other cases we need to make damn sure we don't race with umount. We can
*NOT* just grab a reference to a watch - inotify_unmount_inodes() will
happily sail past it and we'll end with reference to inode potentially
outliving its superblock.
Ideally we just want to grab an active reference to superblock if we
can; that will make sure we won't go into inotify_umount_inodes() until
we are done. Cleanup is just deactivate_super().
However, that leaves a messy case - what if we *are* racing with
umount() and active references to superblock can't be acquired anymore?
We can bump ->s_count, grab ->s_umount, which will almost certainly wait
until the superblock is shut down and the watch in question is pining
for fjords. That's fine, but there is a problem - we might have hit the
window between ->s_active getting to 0 / ->s_count - below S_BIAS (i.e.
the moment when superblock is past the point of no return and is heading
for shutdown) and the moment when deactivate_super() acquires
->s_umount.
We could just do drop_super() yield() and retry, but that's rather
antisocial and this stuff is luser-triggerable. OTOH, having grabbed
->s_umount and having found that we'd got there first (i.e. that
->s_root is non-NULL) we know that we won't race with
inotify_umount_inodes().
So we could grab a reference to watch and do the rest as above, just
with drop_super() instead of deactivate_super(), right? Wrong. We had
to drop ih->mutex before we could grab ->s_umount. So the watch
could've been gone already.
That still can be dealt with - we need to save watch->wd, do idr_find()
and compare its result with our pointer. If they match, we either have
the damn thing still alive or we'd lost not one but two races at once,
the watch had been killed and a new one got created with the same ->wd
at the same address. That couldn't have happened in inotify_destroy(),
but inotify_rm_wd() could run into that. Still, "new one got created"
is not a problem - we have every right to kill it or leave it alone,
whatever's more convenient.
So we can use idr_find(...) == watch && watch->inode->i_sb == sb as
"grab it and kill it" check. If it's been our original watch, we are
fine, if it's a newcomer - nevermind, just pretend that we'd won the
race and kill the fscker anyway; we are safe since we know that its
superblock won't be going away.
And yes, this is far beyond mere "not very pretty"; so's the entire
concept of inotify to start with.
Acked-by: Greg KH <greg@kroah.com>
commit 7ef9964e6d1b911b78709f144000aacadd0ebc21 upstream.
It has been thought that the per-user file descriptors limit would also
limit the resources that a normal user can request via the epoll
interface. Vegard Nossum reported a very simple program (a modified
version attached) that can make a normal user to request a pretty large
amount of kernel memory, well within the its maximum number of fds. To
solve such problem, default limits are now imposed, and /proc based
configuration has been introduced. A new directory has been created,
named /proc/sys/fs/epoll/ and inside there, there are two configuration
max_user_instances = Maximum number of devices - per user
max_user_watches = Maximum number of "watched" fds - per user
The current default for "max_user_watches" limits the memory used by epoll
to store "watches", to 1/32 of the amount of the low RAM. As example, a
256MB 32bit machine, will have "max_user_watches" set to roughly 90000.
That should be enough to not break existing heavy epoll users. The
default value for "max_user_instances" is set to 128, that should be
enough too.
This also changes the userspace, because a new error code can now come out
from EPOLL_CTL_ADD (-ENOSPC). The EMFILE from epoll_create() was already
listed, so that should be ok.
[akpm@linux-foundation.org: use get_current_user()]
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Reported-by: Vegard Nossum <vegardno@ifi.uio.no>
commit 352d026338378b1f13f044e33c1047da6e470056 upstream.
This patch (as1155) fixes a bug in usbcore. When interfaces are
deleted, either because the device was disconnected or because of a
configuration change, the extra attribute files and child endpoint
devices may get left behind. This is because the core removes them
before calling device_del(). But during device_del(), after the
driver is unbound the core will reinstall altsetting 0 and recreate
those extra attributes and children.
The patch prevents this by adding a flag to record when the interface
is in the midst of being unregistered. When the flag is set, the
attribute files and child devices will not be created.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit 8677142710516d986d932d6f1fba7be8382c1fec upstream
backported by Nikanth Karthikesan <knikanth@suse.de> to the 2.6.27.y tree.
block: fix nr_phys_segments miscalculation bug
This fixes the bug reported by Nikanth Karthikesan <knikanth@suse.de>:
http://lkml.org/lkml/2008/10/2/203
The root cause of the bug is that blk_phys_contig_segment
miscalculates q->max_segment_size.
blk_phys_contig_segment checks:
req->biotail->bi_size + next_req->bio->bi_size > q->max_segment_size
But blk_recalc_rq_segments might expect that req->biotail and the
previous bio in the req are supposed be merged into one
segment. blk_recalc_rq_segments might also expect that next_req->bio
and the next bio in the next_req are supposed be merged into one
segment. In such case, we merge two requests that can't be merged
here. Later, blk_rq_map_sg gives more segments than it should.
We need to keep track of segment size in blk_recalc_rq_segments and
use it to see if two requests can be merged. This patch implements it
in the similar way that we used to do for hw merging (virtual
merging).
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Nikanth Karthikesan <knikanth@suse.de>
commit c5d712433ff57a66d8fb79a57a4fc7a7c3467b97 upstream
Fix the __pfn_to_page(pfn) macro so that it doesn't evaluate its
argument twice in the CONFIG_DISCONTIGMEM=y case, because 'pfn' may
be a result of a funtion call having side effects.
For example, the hibernation code applies pfn_to_page(pfn) to the
result of a function returning the pfn corresponding to the next set
bit in a bitmap and the current bit position is modified on each
call. This leads to "interesting" failures for CONFIG_DISCONTIGMEM=y
due to the current behavior of __pfn_to_page(pfn).
Acked-by: Pavel Machek <pavel@suse.cz>
commit 6209344f5a3795d34b7f2c0061f49802283b6bdd upstream
Previously I assumed that the receive queues of candidates don't
change during the GC. This is only half true, nothing can be received
from the queues (see comment in unix_gc()), but buffers could be added
through the other half of the socket pair, which may still have file
descriptors referring to it.
This can result in inc_inflight_move_tail() erronously increasing the
"inflight" counter for a unix socket for which dec_inflight() wasn't
previously called. This in turn can trigger the "BUG_ON(total_refs <
inflight_refs)" in a later garbage collection run.
Fix this by only manipulating the "inflight" counter for sockets which
are candidates themselves. Duplicating the file references in
unix_attach_fds() is also needed to prevent a socket becoming a
candidate for GC while the skb that contains it is not yet queued.
Reported-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 467622ef2acb01986eab37ef96c3632b3ea35999 upstream
For "unlock" cycles to 16bit devices in 8bit compatibility mode we need
to use the byte addresses 0xaaa and 0x555. These effectively match
the word address 0x555 and 0x2aa, except the latter has its low bit set.
Most chips don't care about the value of the 'A-1' pin in x8 mode,
but some -- like the ST M29W320D -- do. So we need to be careful to
set it where appropriate.
cfi_send_gen_cmd is only ever passed addresses where the low byte
is 0x00, 0x55 or 0xaa. Of those, only addresses ending 0xaa are
affected by this patch, by masking in the extra low bit when the device
is known to be in compatibility mode.
[dwmw2: Do it only when (cmd_ofs & 0xff) == 0xaa]
v4: Fix stupid typo in cfi_build_cmd_addr that failed to compile
I'm writing this patch way to late at night.
v3: Bring all of the work back into cfi_build_cmd_addr
including calling of map_bankwidth(map) and cfi_interleave(cfi)
So every caller doesn't need to.
v2: Only modified the address if we our device_type is larger than our
bus width.
commit f8d570a4745835f2238a33b537218a1bb03fc671 and
3b53fbf4314594fa04544b02b2fc6e607912da18 upstream (because once wasn't
good enough...)
__scm_destroy() walks the list of file descriptors in the scm_fp_list
pointed to by the scm_cookie argument.
Those, in turn, can close sockets and invoke __scm_destroy() again.
There is nothing which limits how deeply this can occur.
The idea for how to fix this is from Linus. Basically, we do all of
the fput()s at the top level by collecting all of the scm_fp_list
objects hit by an fput(). Inside of the initial __scm_destroy() we
keep running the list until it is empty.
[ Upstream commit 930cc144a043ff95e56b6888fa51c618b33f89e7 ]
I'm trying to move the powerpc math-emu code to use the include/math-emu bits.
In doing so I've been using TestFloat to see how good or bad we are
doing. For the most part the current math-emu code that PPC uses has
a number of issues that the code in include/math-emu seems to solve
(plus bugs we've had for ever that no one every realized).
Anyways, I've come across a case that we are flagging underflow and
inexact because we think we have a denormalized result from a double
precision divide:
000.FFFFFFFFFFFFF / 3FE.FFFFFFFFFFFFE
soft: 001.0000000000000 ..... syst: 001.0000000000000 ...ux
What it looks like is the results out of FP_DIV_D are:
D:
sign: 0
mantissa: 01000000 00000000
exp: -1023 (0)
The problem seems like we aren't normalizing the result and bumping the exp.
Now that I'm digging into this a bit I'm thinking my issue has to do with
the fix DaveM put in place from back in Aug 2007 (commit
405849610fd96b4f34cd1875c4c033228fea6c0f):
[MATH-EMU]: Fix underflow exception reporting.
2) we ended up rounding back up to normal (this is the case where
we set the exponent to 1 and set the fraction to zero), this
should set inexact too
Another example, "0x0.0000000000001p-1022 / 16.0", should signal both
inexact and underflow. The cpu implementations and ieee1754
literature is very clear about this. This is case #2 above.
Here is the distilled glibc test case from Jakub Jelinek which prompted that
commit:
#include <float.h>
#include <fenv.h>
#include <stdio.h>
volatile double d = DBL_MIN;
volatile double e = 0x0.0000000000001p-1022;
volatile double f = 16.0;
int
main (void)
printf ("%x\n", fetestexcept (FE_UNDERFLOW));
d /= f;
e /= f;
return 0;
It looks like the case I have we are exact before rounding, but think it
looks like the rounding case since it appears as if "overflow is set".
000.FFFFFFFFFFFFF / 3FE.FFFFFFFFFFFFE = 001.0000000000000
I think the following adds the check for my case and still works for the
issue your commit was trying to resolve.
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
ide: workaround for bogus gcc warning in ide_sysfs_register_port()
ide-cd: Optiarc DVD RW AD-7200A does play audio
IDE: Fix platform device registration in Swarm IDE driver (v2)
ide-dma: fix ide_build_dmatable() for TRM290
ide-cd: temporary tray close fix
This one fixes http://bugzilla.kernel.org/show_bug.cgi?id=11602.
A more generic fix for drives which cannot autoclose tray will follow.
Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
[bart: add an extra parentheses for consistency with the rest of kernel code]
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
include/linux/stacktrace.h:13: warning:
'struct task_struct' declared inside parameter list
(This might be a hard error on sparc64, which uses this header and has
-Werror)
Reported-by: "Randy.Dunlap" <rdunlap@xenotime.net>
Cc: Arjan van de Ven <arjan@infradead.org>
Rework of SMTC support to make it work with the new clock event system,
allowing "tickless" operation, and to make it compatible with the use of
the "wait_irqoff" idle loop. The new clocking scheme means that the
previously optional IPI instant replay mechanism is now required, and has
been made more robust.
Signed-off-by: Kevin D. Kissell <kevink@paralogos.com>
Though from a hardware perspective it would be sensible to use only a
32-bit unsigned int type Linux defines interrupt flags to be stored in
an unsigned long and nothing else.
The previous patch db203d53d474aa068984e409d807628f5841da1b ("mm:
tiny-shmem fix lock ordering: mmap_sem vs i_mutex") to fix the lock
ordering in tiny-shmem breaks shared anonymous and IPC memory on NOMMU
architectures because it was using the expanding truncate to signal ramfs
to allocate a physically contiguous RAM backing the inode (otherwise it is
unusable for "memory mapping" it to userspace).
However do_truncate is what caused the lock ordering error, due to it
taking i_mutex. In this case, we can actually just call ramfs directly to
allocate memory for the mapping, rather than go via truncate.
Acked-by: Hugh Dickins <hugh@veritas.com>
Cc: Matt Mackall <mpm@selenic.com>
Fix inotify lock order reversal with mmap_sem due to holding locks over
copy_to_user.
Reported-by: "Daniel J Blueman" <daniel.blueman@gmail.com>
Tested-by: "Daniel J Blueman" <daniel.blueman@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
af_key: Free dumping state on socket close
XFRM,IPv6: initialize ip6_dst_blackhole_ops.kmem_cachep
ipv6: NULL pointer dereferrence in tcp_v6_send_ack
tcp: Fix NULL dereference in tcp_4_send_ack()
sctp: Fix kernel panic while process protocol violation parameter
iucv: Fix mismerge again.
ipsec: Fix pskb_expand_head corruption in xfrm_state_check_space
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
hrtimer: prevent migration of per CPU hrtimers
hrtimer: mark migration state
hrtimer: fix migration of CB_IRQSAFE_NO_SOFTIRQ hrtimers
hrtimer: migrate pending list on cpu offline
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Since call to function sctp_sf_abort_violation() need paramter 'arg' with
'struct sctp_chunk' type, it will read the chunk type and chunk length from
the chunk_hdr member of chunk. But call to sctp_sf_violation_paramlen()
always with 'struct sctp_paramhdr' type's parameter, it will be passed to
sctp_sf_abort_violation(). This may cause kernel panic.
|-- sctp_sf_abort_violation()
|-- sctp_make_abort_violation()
This patch fixed this problem. This patch also fix two place which called
sctp_sf_violation_paramlen() with wrong paramter type.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
