commit 05971120fca43e0357789a14b3386bb56eef2201 upstream.
It is curently possible to run a VM with architected timers support
without creating an in-kernel VGIC, which will result in interrupts from
the virtual timer going nowhere.
To address this issue, move the architected timers initialization to the
time when we run a VCPU for the first time, and then only initialize
(and enable) the architected timers if we have a properly created and
initialized in-kernel VGIC.
When injecting interrupts from the virtual timer to the vgic, the
current setup should ensure that this never calls an on-demand init of
the VGIC, which is the only call path that could return an error from
kvm_vgic_inject_irq(), so capture the return value and raise a warning
if there's an error there.
We also change the kvm_timer_init() function from returning an int to be
a void function, since the function always succeeds.
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org>
commit 6cbde8253a8143ada18ec0d1711230747a7c1934 upstream.
Add a stub for kvm_vgic_addr when compiling without
CONFIG_KVM_ARM_VGIC. The usefulness of this configurarion is extremely
doubtful, but let's fix it anyway (until we decide that we'll always
support a VGIC).
Reported-by: Michele Paolino <m.paolino@virtualopensystems.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
commit 39f1f78d53b9bcbca91967380c5f0f2305a5c55f upstream.
too many places open-code it
commit bba0bdd7ad4713d82338bcd9b72d57e9335a664b upstream.
SCSI transport drivers and SCSI LLDs block a SCSI device if the
transport layer is not operational. This means that in this state
no requests should be processed, even if the REQ_PREEMPT flag has
been set. This patch avoids that a rescan shortly after a cable
pull sporadically triggers the following kernel oops:
BUG: unable to handle kernel paging request at ffffc9001a6bc084
IP: [<ffffffffa04e08f2>] mlx4_ib_post_send+0xd2/0xb30 [mlx4_ib]
Process rescan-scsi-bus (pid: 9241, threadinfo ffff88053484a000, task ffff880534aae100)
Call Trace:
[<ffffffffa0718135>] srp_post_send+0x65/0x70 [ib_srp]
[<ffffffffa071b9df>] srp_queuecommand+0x1cf/0x3e0 [ib_srp]
[<ffffffffa0001ff1>] scsi_dispatch_cmd+0x101/0x280 [scsi_mod]
[<ffffffffa0009ad1>] scsi_request_fn+0x411/0x4d0 [scsi_mod]
[<ffffffff81223b37>] __blk_run_queue+0x27/0x30
[<ffffffff8122a8d2>] blk_execute_rq_nowait+0x82/0x110
[<ffffffff8122a9c2>] blk_execute_rq+0x62/0xf0
[<ffffffffa000b0e8>] scsi_execute+0xe8/0x190 [scsi_mod]
[<ffffffffa000b2f3>] scsi_execute_req+0xa3/0x130 [scsi_mod]
[<ffffffffa000c1aa>] scsi_probe_lun+0x17a/0x450 [scsi_mod]
[<ffffffffa000ce86>] scsi_probe_and_add_lun+0x156/0x480 [scsi_mod]
[<ffffffffa000dc2f>] __scsi_scan_target+0xdf/0x1f0 [scsi_mod]
[<ffffffffa000dfa3>] scsi_scan_host_selected+0x183/0x1c0 [scsi_mod]
[<ffffffffa000edfb>] scsi_scan+0xdb/0xe0 [scsi_mod]
[<ffffffffa000ee13>] store_scan+0x13/0x20 [scsi_mod]
[<ffffffff811c8d9b>] sysfs_write_file+0xcb/0x160
[<ffffffff811589de>] vfs_write+0xce/0x140
[<ffffffff81158b53>] sys_write+0x53/0xa0
[<ffffffff81464592>] system_call_fastpath+0x16/0x1b
[<00007f611c9d9300>] 0x7f611c9d92ff
Reported-by: Max Gurtuvoy <maxg@mellanox.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
commit 04f9b74e4d96d349de12fdd4e6626af4a9f75e09 upstream.
Now that the definition is centralized in <linux/kernel.h>, the
definitions of U32_MAX (and related) elsewhere in the kernel can be
removed.
Signed-off-by: Alex Elder <elder@linaro.org>
Acked-by: Sage Weil <sage@inktank.com>
commit 89a0714106aac7309c7dfa0f004b39e1e89d2942 upstream.
Create constants that define the maximum and minimum values
representable by the kernel types u8, s8, u16, s16, and so on.
Cc: Sage Weil <sage@inktank.com>
commit 77719536dc00f8fd8f5abe6dadbde5331c37f996 upstream.
The symbol U32_MAX is defined in several spots. Change these
definitions to be conditional. This is in preparation for the next
patch, which centralizes the definition in <linux/kernel.h>.
commit 5925a0555bdaf0b396a84318cbc21ba085f6c0d3 upstream.
sk_dst_cache has __rcu annotation, so we need a cast to avoid
following sparse error :
include/net/sock.h:1774:19: warning: incorrect type in initializer (different address spaces)
include/net/sock.h:1774:19: expected struct dst_entry [noderef] <asn:4>*__ret
include/net/sock.h:1774:19: got struct dst_entry *dst
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Fixes: 7f502361531e ("ipv4: irq safe sk_dst_[re]set() and ipv4_sk_update_pmtu() fix")
commit f044636d972246d451e06226cc1675d5da389762 upstream.
Ensure that other operations which raced with our setattr RPC call
cannot revert the file attribute changes that were made on the server.
To do so, we artificially bump the attribute generation counter on
the inode so that all calls to nfs_fattr_init() that precede ours
will be dropped.
The motivation for the patch came from Chuck Lever's reports of readaheads
racing with truncate operations and causing the file size to be reverted.
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Tested-by: Chuck Lever <chuck.lever@oracle.com>
Acked-by: NeilBrown <neilb@suse.de>
PREEMPT_NONE
commit 8603e1b30027f943cc9c1eef2b291d42c3347af1 upstream.
cancel[_delayed]_work_sync() are implemented using
__cancel_work_timer() which grabs the PENDING bit using
try_to_grab_pending() and then flushes the work item with PENDING set
to prevent the on-going execution of the work item from requeueing
itself.
try_to_grab_pending() can always grab PENDING bit without blocking
except when someone else is doing the above flushing during
cancelation. In that case, try_to_grab_pending() returns -ENOENT. In
this case, __cancel_work_timer() currently invokes flush_work(). The
assumption is that the completion of the work item is what the other
canceling task would be waiting for too and thus waiting for the same
condition and retrying should allow forward progress without excessive
busy looping
Unfortunately, this doesn't work if preemption is disabled or the
latter task has real time priority. Let's say task A just got woken
up from flush_work() by the completion of the target work item. If,
before task A starts executing, task B gets scheduled and invokes
__cancel_work_timer() on the same work item, its try_to_grab_pending()
will return -ENOENT as the work item is still being canceled by task A
and flush_work() will also immediately return false as the work item
is no longer executing. This puts task B in a busy loop possibly
preventing task A from executing and clearing the canceling state on
the work item leading to a hang.
task A task B worker
executing work
set work CANCELING
flush_work()
block for work completion
completion, wakes up A
while (forever) {
-ENOENT as work is being canceled
flush_work()
false as work is no longer executing
This patch removes the possible hang by updating __cancel_work_timer()
to explicitly wait for clearing of CANCELING rather than invoking
flush_work() after try_to_grab_pending() fails with -ENOENT.
Link: http://lkml.kernel.org/g/20150206171156.GA8942@axis.com
v3: bit_waitqueue() can't be used for work items defined in vmalloc
area. Switched to custom wake function which matches the target
work item and exclusive wait and wakeup.
v2: v1 used wake_up() on bit_waitqueue() which leads to NULL deref if
the target bit waitqueue has wait_bit_queue's on it. Use
DEFINE_WAIT_BIT() and __wake_up_bit() instead. Reported by Tomeu
Vizoso.
Reported-by: Rabin Vincent <rabin.vincent@axis.com>
Cc: Tomeu Vizoso <tomeu.vizoso@gmail.com>
Tested-by: Jesper Nilsson <jesper.nilsson@axis.com>
Tested-by: Rabin Vincent <rabin.vincent@axis.com>
commit 30b0a105d9f7141e4cbf72ae5511832457d89788 upstream.
Right now, the migration code in migrate_page_copy() uses copy_huge_page()
for hugetlbfs and thp pages:
if (PageHuge(page) || PageTransHuge(page))
copy_huge_page(newpage, page);
So, yay for code reuse. But:
void copy_huge_page(struct page *dst, struct page *src)
struct hstate *h = page_hstate(src);
and a non-hugetlbfs page has no page_hstate(). This works 99% of the
time because page_hstate() determines the hstate from the page order
alone. Since the page order of a THP page matches the default hugetlbfs
page order, it works.
But, if you change the default huge page size on the boot command-line
(say default_hugepagesz=1G), then we might not even *have* a 2MB hstate
so page_hstate() returns null and copy_huge_page() oopses pretty fast
since copy_huge_page() dereferences the hstate:
if (unlikely(pages_per_huge_page(h) > MAX_ORDER_NR_PAGES)) {
Mel noticed that the migration code is really the only user of these
functions. This moves all the copy code over to migrate.c and makes
copy_huge_page() work for THP by checking for it explicitly.
I believe the bug was introduced in commit b32967ff101a ("mm: numa: Add
THP migration for the NUMA working set scanning fault case")
[akpm@linux-foundation.org: fix coding-style and comment text, per Naoya Horiguchi]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Hillf Danton <dhillf@gmail.com>
Tested-by: Dave Jiang <dave.jiang@intel.com>
This is a single hunk introduced later in the upstream commit
cb900f41215447433cbc456d1c4294e858a84d7c (mm, hugetlb: convert
hugetlbfs to use split pmd lock). We need page_hstate even for
!HUGETLB_PAGE case for the next patch (mm: thp: give transparent
hugepage code a separate copy_page).
commit f40386a4e976acb2bd3e0f9ead11e8e769acbe98 upstream.
With CONFIG_HUGETLBFS=n:
mm/migrate.c: In function `do_move_page_to_node_array':
include/linux/hugetlb.h:140:33: warning: statement with no effect [-Wunused-value]
#define isolate_huge_page(p, l) false
mm/migrate.c:1170:4: note: in expansion of macro `isolate_huge_page'
isolate_huge_page(page, &pagelist);
Reported-by: Borislav Petkov <bp@alien8.de>
Tested-by: Borislav Petkov <bp@alien8.de>
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: David Rientjes <rientjes@google.com>
commit e66f17ff71772b209eed39de35aaa99ba819c93d upstream.
We have a race condition between move_pages() and freeing hugepages, where
move_pages() calls follow_page(FOLL_GET) for hugepages internally and
tries to get its refcount without preventing concurrent freeing. This
race crashes the kernel, so this patch fixes it by moving FOLL_GET code
for hugepages into follow_huge_pmd() with taking the page table lock.
This patch intentionally removes page==NULL check after pte_page.
This is justified because pte_page() never returns NULL for any
architectures or configurations.
This patch changes the behavior of follow_huge_pmd() for tail pages and
then tail pages can be pinned/returned. So the caller must be changed to
properly handle the returned tail pages.
We could have a choice to add the similar locking to
follow_huge_(addr|pud) for consistency, but it's not necessary because
currently these functions don't support FOLL_GET flag, so let's leave it
for future development.
Here is the reproducer:
$ cat movepages.c
#include <stdio.h>
#include <stdlib.h>
#include <numaif.h>
#define ADDR_INPUT 0x700000000000UL
#define HPS 0x200000
#define PS 0x1000
int main(int argc, char *argv[]) {
int i;
int nr_hp = strtol(argv[1], NULL, 0);
int nr_p = nr_hp * HPS / PS;
int ret;
void **addrs;
int *status;
int *nodes;
pid_t pid;
pid = strtol(argv[2], NULL, 0);
addrs = malloc(sizeof(char *) * nr_p + 1);
status = malloc(sizeof(char *) * nr_p + 1);
nodes = malloc(sizeof(char *) * nr_p + 1);
while (1) {
for (i = 0; i < nr_p; i++) {
addrs[i] = (void *)ADDR_INPUT + i * PS;
nodes[i] = 1;
status[i] = 0;
ret = numa_move_pages(pid, nr_p, addrs, nodes, status,
MPOL_MF_MOVE_ALL);
if (ret == -1)
err("move_pages");
nodes[i] = 0;
status[i] = 0;
MPOL_MF_MOVE_ALL);
if (ret == -1)
err("move_pages");
return 0;
$ cat hugepage.c
#include <stdio.h>
#include <sys/mman.h>
#include <string.h>
char *p;
while (1) {
p = mmap((void *)ADDR_INPUT, nr_hp * HPS, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_HUGETLB, -1, 0);
if (p != (void *)ADDR_INPUT) {
perror("mmap");
break;
memset(p, 0, nr_hp * HPS);
munmap(p, nr_hp * HPS);
$ sysctl vm.nr_hugepages=40
$ ./hugepage 10 &
$ ./movepages 10 $(pgrep -f hugepage)
Fixes: e632a938d914 ("mm: migrate: add hugepage migration code to move_pages()")
Reported-by: Hugh Dickins <hughd@google.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Steve Capper <steve.capper@linaro.org>
Cc: <stable@vger.kernel.org> [3.12+]
Signed-off-by: Jiri Slaby <jslaby@suse.cz> [backport to 3.12]
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Cc: stable@vger.kernel.org
commit f161d4b44d7cc1dc66b53365215227db356378b1 upstream.
This patch addresses the original PR_APTPL_BUF_LEN = 8k limitiation
for write-out of PR APTPL metadata that Martin has recently been
running into.
It changes core_scsi3_update_and_write_aptpl() to use vzalloc'ed
memory instead of kzalloc, and increases the default hardcoded
length to 256k.
It also adds logic in core_scsi3_update_and_write_aptpl() to double
the original length upon core_scsi3_update_aptpl_buf() failure, and
retries until the vzalloc'ed buffer is large enough to accommodate
the outgoing APTPL metadata.
Reported-by: Martin Svec <martin.svec@zoner.cz>
commit 5efd2ea8c9f4f12916ffc8ba636792ce052f6911 upstream.
the following error pops up during "testusb -a -t 10"
| musb-hdrc musb-hdrc.1.auto: dma_pool_free buffer-128, f134e000/be842000 (bad dma)
hcd_buffer_create() creates a few buffers, the smallest has 32 bytes of
size. ARCH_KMALLOC_MINALIGN is set to 64 bytes. This combo results in
hcd_buffer_alloc() returning memory which is 32 bytes aligned and it
might by identified by buffer_offset() as another buffer. This means the
buffer which is on a 32 byte boundary will not get freed, instead it
tries to free another buffer with the error message.
This patch fixes the issue by creating the smallest DMA buffer with the
size of ARCH_KMALLOC_MINALIGN (or 32 in case ARCH_KMALLOC_MINALIGN is
smaller). This might be 32, 64 or even 128 bytes. The next three pools
will have the size 128, 512 and 2048.
In case the smallest pool is 128 bytes then we have only three pools
instead of four (and zero the first entry in the array).
The last pool size is always 2048 bytes which is the assumed PAGE_SIZE /
2 of 4096. I doubt it makes sense to continue using PAGE_SIZE / 2 where
we would end up with 8KiB buffer in case we have 16KiB pages.
Instead I think it makes sense to have a common size(s) and extend them
if there is need to.
There is a BUILD_BUG_ON() now in case someone has a minalign of more than
128 bytes.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 6ee8e25fc3e916193bce4ebb43d5439e1e2144ab upstream.
Commit e9fd702a58c4 ("audit: convert audit watches to use fsnotify
instead of inotify") broke handling of renames in audit. Audit code
wants to update inode number of an inode corresponding to watched name
in a directory. When something gets renamed into a directory to a
watched name, inotify previously passed moved inode to audit code
however new fsnotify code passes directory inode where the change
happened. That confuses audit and it starts watching parent directory
instead of a file in a directory.
This can be observed for example by doing:
cd /tmp
touch foo bar
auditctl -w /tmp/foo
touch foo
mv bar foo
touch foo
In audit log we see events like:
type=CONFIG_CHANGE msg=audit(1423563584.155:90): auid=1000 ses=2 op="updated rules" path="/tmp/foo" key=(null) list=4 res=1
type=PATH msg=audit(1423563584.155:91): item=2 name="bar" inode=1046884 dev=08:0 2 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=DELETE
type=PATH msg=audit(1423563584.155:91): item=3 name="foo" inode=1046842 dev=08:0 2 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=DELETE
type=PATH msg=audit(1423563584.155:91): item=4 name="foo" inode=1046884 dev=08:0 2 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=CREATE
and that's it - we see event for the first touch after creating the
audit rule, we see events for rename but we don't see any event for the
last touch. However we start seeing events for unrelated stuff
happening in /tmp.
Fix the problem by passing moved inode as data in the FS_MOVED_FROM and
FS_MOVED_TO events instead of the directory where the change happens.
This doesn't introduce any new problems because noone besides
audit_watch.c cares about the passed value:
fs/notify/fanotify/fanotify.c cares only about FSNOTIFY_EVENT_PATH events.
fs/notify/dnotify/dnotify.c doesn't care about passed 'data' value at all.
fs/notify/inotify/inotify_fsnotify.c uses 'data' only for FSNOTIFY_EVENT_PATH.
kernel/audit_tree.c doesn't care about passed 'data' at all.
kernel/audit_watch.c expects moved inode as 'data'.
Fixes: e9fd702a58c49db ("audit: convert audit watches to use fsnotify instead of inotify")
Cc: Paul Moore <paul@paul-moore.com>
Cc: Eric Paris <eparis@redhat.com>
[ Upstream commit bdbbb8527b6f6a358dbcb70dac247034d665b8e4 ]
In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock")
I tried to address contention on a socket lock, but the solution
I chose was horrible :
commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside
of TCP stack") addressed a selinux regression.
commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1")
took care of another regression.
commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression.
commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate")
was another shot in the dark.
Really, just use a proper socket per cpu, and remove the skb_orphan()
call, to re-enable flow control.
This solves a serious problem with FQ packet scheduler when used in
hostile environments, as we do not want to allocate a flow structure
for every RST packet sent in response to a spoofed packet.
[ Upstream commit df4d92549f23e1c037e83323aff58a21b3de7fe0 ]
Not caching dst_entries which cause redirects could be exploited by hosts
on the same subnet, causing a severe DoS attack. This effect aggravated
since commit f88649721268999 ("ipv4: fix dst race in sk_dst_get()").
Lookups causing redirects will be allocated with DST_NOCACHE set which
will force dst_release to free them via RCU. Unfortunately waiting for
RCU grace period just takes too long, we can end up with >1M dst_entries
waiting to be released and the system will run OOM. rcuos threads cannot
catch up under high softirq load.
Attaching the flag to emit a redirect later on to the specific skb allows
us to cache those dst_entries thus reducing the pressure on allocation
and deallocation.
This issue was discovered by Marcelo Leitner.
Cc: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Marcelo Leitner <mleitner@redhat.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
commit 4161b4505f1690358ac0a9ee59845a7887336b21 upstream.
When ak4114 work calls its callback and the callback invokes
ak4114_reinit(), it stalls due to flush_delayed_work(). For avoiding
this, control the reentrance by introducing a refcount. Also
flush_delayed_work() is replaced with cancel_delayed_work_sync().
The exactly same bug is present in ak4113.c and fixed as well.
Reported-by: Pavel Hofman <pavel.hofman@ivitera.com>
Acked-by: Jaroslav Kysela <perex@perex.cz>
Tested-by: Pavel Hofman <pavel.hofman@ivitera.com>
commit 9107ebbf9652c033eb5dd10a6ea34a132db3cde1 upstream.
Add support for realtek rts5250 pci card reader. The card reader has
some problems with DDR50 mode, so add a new quirks2 for broken ddr50.
Signed-off-by: Micky Ching <micky_ching@realsil.com.cn>
Signed-off-by: Chris Ball <chris@printf.net>
commit 13868bf20f2f2c305f96e23620b024e167d6f9cb upstream.
This patch defines a quirk for platforms unable to enable HS200 support.
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
Reviewed-by: Chuanxiao Dong <chuanxiao.dong@intel.com>
Acked-by: Dong Aisheng <b29396@freescale.com>
Cc: stable <stable@vger.kernel.org> # [3.13]
commit 291fdb0bcebd5e8db6af767c1fdc522167dad73d upstream.
Change the type of compat_sys_msgrcv's msgtyp parameter from long
to compat_long_t, since compat user space passes only a 32 bit signed
value.
Let the compat wrapper do proper sign extension to 64 bit of this
parameter.
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
Acked-by: Miklos Szeredi <mszeredi@suse.cz>
commit 45f87de57f8fad59302fd263dd81ffa4843b5b24 upstream.
Commit 2457aec63745 ("mm: non-atomically mark page accessed during page
cache allocation where possible") has added a separate parameter for
specifying gfp mask for radix tree allocations.
Not only this is less than optimal from the API point of view because it
is error prone, it is also buggy currently because
grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if
fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by
AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then
the radix tree allocation wouldn't obey the restriction and might
recurse into filesystem and cause deadlocks. This is the case for most
filesystems unfortunately because only ext4 and gfs2 are using
AOP_FLAG_NOFS.
Let's simply remove radix_gfp_mask parameter because the allocation
context is same for both page cache and for the radix tree. Just make
sure that the radix tree gets only the sane subset of the mask (e.g. do
not pass __GFP_WRITE).
Long term it is more preferable to convert remaining users of
AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this
interface even further.
Reported-by: Dave Chinner <david@fromorbit.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 6ada1fc0e1c4775de0e043e1bd3ae9d065491aa5 upstream.
An unvalidated user input is multiplied by a constant, which can result in
an undefined behaviour for large values. While this is validated later,
we should avoid triggering undefined behaviour.
[jstultz: include trivial milisecond->microsecond correction noticed
by Andy]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit c291ee622165cb2c8d4e7af63fffd499354a23be upstream.
Since the rework of the sparse interrupt code to actually free the
unused interrupt descriptors there exists a race between the /proc
interfaces to the irq subsystem and the code which frees the interrupt
descriptor.
CPU0 CPU1
show_interrupts()
desc = irq_to_desc(X);
free_desc(desc)
remove_from_radix_tree();
kfree(desc);
raw_spinlock_irq(&desc->lock);
/proc/interrupts is the only interface which can actively corrupt
kernel memory via the lock access. /proc/stat can only read from freed
memory. Extremly hard to trigger, but possible.
The interfaces in /proc/irq/N/ are not affected by this because the
removal of the proc file is serialized in procfs against concurrent
readers/writers. The removal happens before the descriptor is freed.
For architectures which have CONFIG_SPARSE_IRQ=n this is a non issue
as the descriptor is never freed. It's merely cleared out with the irq
descriptor lock held. So any concurrent proc access will either see
the old correct value or the cleared out ones.
Protect the lookup and access to the irq descriptor in
show_interrupts() with the sparse_irq_lock.
Provide kstat_irqs_usr() which is protecting the lookup and access
with sparse_irq_lock and switch /proc/stat to use it.
Document the existing kstat_irqs interfaces so it's clear that the
caller needs to take care about protection. The users of these
interfaces are either not affected due to SPARSE_IRQ=n or already
protected against removal.
Fixes: 1f5a5b87f78f "genirq: Implement a sane sparse_irq allocator"
[ Upstream commit 6d08acd2d32e3e877579315dc3202d7a5f336d98 ]
Resolve conflicts between glibc definition of IPV6 socket options
and those defined in Linux headers. Looks like earlier efforts to
solve this did not cover all the definitions.
It resolves warnings during iproute2 build.
Please consider for stable as well.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream.
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream.
On some ARMs the memory can be mapped pgprot_noncached() and still
be working for atomic operations. As pointed out by Colin Cross
<ccross@android.com>, in some cases you do want to use
pgprot_noncached() if the SoC supports it to see a debug printk
just before a write hanging the system.
On ARMs, the atomic operations on strongly ordered memory are
implementation defined. So let's provide an optional kernel parameter
for configuring pgprot_noncached(), and use pgprot_writecombine() by
default.
Cc: Rob Herring <robherring2@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
Cc: Olof Johansson <olof@lixom.net>
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit 041d7b98ffe59c59fdd639931dea7d74f9aa9a59 upstream.
A regression was caused by commit 780a7654cee8:
audit: Make testing for a valid loginuid explicit.
(which in turn attempted to fix a regression caused by e1760bd)
When audit_krule_to_data() fills in the rules to get a listing, there was a
missing clause to convert back from AUDIT_LOGINUID_SET to AUDIT_LOGINUID.
This broke userspace by not returning the same information that was sent and
expected.
The rule:
auditctl -a exit,never -F auid=-1
gives:
auditctl -l
LIST_RULES: exit,never f24=0 syscall=all
when it should give:
LIST_RULES: exit,never auid=-1 (0xffffffff) syscall=all
Tag it so that it is reported the same way it was set. Create a new
private flags audit_krule field (pflags) to store it that won't interact with
the public one from the API.
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream.
- Expose the knob to user space through a proc file /proc/<pid>/setgroups
A value of "deny" means the setgroups system call is disabled in the
current processes user namespace and can not be enabled in the
future in this user namespace.
A value of "allow" means the segtoups system call is enabled.
- Descendant user namespaces inherit the value of setgroups from
their parents.
- A proc file is used (instead of a sysctl) as sysctls currently do
not allow checking the permissions at open time.
- Writing to the proc file is restricted to before the gid_map
for the user namespace is set.
This ensures that disabling setgroups at a user namespace
level will never remove the ability to call setgroups
from a process that already has that ability.
A process may opt in to the setgroups disable for itself by
creating, entering and configuring a user namespace or by calling
setns on an existing user namespace with setgroups disabled.
Processes without privileges already can not call setgroups so this
is a noop. Prodcess with privilege become processes without
privilege when entering a user namespace and as with any other path
to dropping privilege they would not have the ability to call
setgroups. So this remains within the bounds of what is possible
without a knob to disable setgroups permanently in a user namespace.
commit 273d2c67c3e179adb1e74f403d1e9a06e3f841b5 upstream.
setgroups is unique in not needing a valid mapping before it can be called,
in the case of setgroups(0, NULL) which drops all supplemental groups.
The design of the user namespace assumes that CAP_SETGID can not actually
be used until a gid mapping is established. Therefore add a helper function
to see if the user namespace gid mapping has been established and call
that function in the setgroups permission check.
This is part of the fix for CVE-2014-8989, being able to drop groups
without privilege using user namespaces.
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
commit 7ff4d90b4c24a03666f296c3d4878cd39001e81e upstream.
Today there are 3 instances of setgroups and due to an oversight their
permission checking has diverged. Add a common function so that
they may all share the same permission checking code.
This corrects the current oversight in the current permission checks
and adds a helper to avoid this in the future.
A user namespace security fix will update this new helper, shortly.
commit 42f74461a5b60cf6b42887e6d2ff5b7be4abf1ca upstream.
SFR reported this 2013-05-15:
> After merging the final tree, today's linux-next build (i386 defconfig)
> produced this warning:
> kernel/auditfilter.c: In function 'audit_data_to_entry':
> kernel/auditfilter.c:426:3: warning: this decimal constant is unsigned only
> in ISO C90 [enabled by default]
> Introduced by commit 780a7654cee8 ("audit: Make testing for a valid
> loginuid explicit") from Linus' tree.
Replace this decimal constant in the code with a macro to make it more readable
(add to the unsigned cast to quiet the warning).
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit ccf54555da9a5e91e454b909ca6a5303c7d6b910 upstream.
The direction field is set on 7 bits, thus we need to AND it with 0111 111 mask
in order to retrieve it, that is 0x7F, not 0xCF as it is now.
Fixes: ade7ef7ba (staging:iio: Differential channel handling)
Signed-off-by: Cristina Ciocan <cristina.ciocan@intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit ea9d0d771fcd32cd56070819749477d511ec9117 upstream.
DPCM can update the FE/BE connection states totally asynchronously
from the FE's PCM state. Most of FE/BE state changes are protected by
mutex, so that they won't race, but there are still some actions that
are uncovered. For example, suppose to switch a BE while a FE's
stream is running. This would call soc_dpcm_runtime_update(), which
sets FE's runtime_update flag, then sets up and starts BEs, and clears
FE's runtime_update flag again.
When a device emits XRUN during this operation, the PCM core triggers
snd_pcm_stop(XRUN). Since the trigger action is an atomic ops, this
isn't blocked by the mutex, thus it kicks off DPCM's trigger action.
It eventually updates and clears FE's runtime_update flag while
soc_dpcm_runtime_update() is running concurrently, and it results in
confusion.
Usually, for avoiding such a race, we take a lock. There is a PCM
stream lock for that purpose. However, as already mentioned, the
trigger action is atomic, and we can't take the lock for the whole
soc_dpcm_runtime_update() or other operations that include the lengthy
jobs like hw_params or prepare.
This patch provides an alternative solution. This adds a way to defer
the conflicting trigger callback to be executed at the end of FE/BE
state changes. For doing it, two things are introduced:
- Each runtime_update state change of FEs is protected via PCM stream
lock.
- The FE's trigger callback checks the runtime_update flag. If it's
not set, the trigger action is executed there. If set, mark the
pending trigger action and returns immediately.
- At the exit of runtime_update state change, it checks whether the
pending trigger is present. If yes, it executes the trigger action
at this point.
Reported-and-tested-by: Qiao Zhou <zhouqiao@marvell.com>
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit f144d1496b47e7450f41b767d0d91c724c2198bc upstream.
This can be set by quirks/drivers to be used by the architecture code
that assigns the MSI addresses.
We additionally add verification in the core MSI code that the values
assigned by the architecture do satisfy the limitation in order to fail
gracefully if they don't (ie. the arch hasn't been updated to deal with
that quirk yet).
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
commit f37c013409bb78ebb958821aa10d069e707cabac upstream.
On some newer laptops with a trackpoint the physical buttons for the
trackpoint have been removed to allow for a larger touchpad. On these
laptops the buttonpad has clearly marked areas on the top which are to be
used as trackpad buttons.
Users of the event device-node need to know about this, so that they can
properly interpret BTN_LEFT events as being a left / right / middle click
depending on where on the button pad the clicking finger is.
This commits adds a INPUT_PROP_TOPBUTTONPAD device property which drivers
for such buttonpads will use to signal to the user that this buttonpad not
only has the normal bottom button area, but also a top button area.
commit 0456c66f4e905e1ca839318219c770988b47975c upstream.
serio devices exposed via platform firmware interfaces such as ACPI may
provide additional identifying information of use to userspace.
We don't associate the serio devices with the firmware device (we don't
set it as parent), so there's no way for userspace to make use of this
information.
We cannot change the parent for serio devices instantiated though a
firmware interface as that would break suspend / resume ordering.
Therefore this patch adds a new firmware_id sysfs attribute so that
userspace can get a string from there with any additional identifying
information the firmware interface may provide.
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
commit 5f16f3225b06242a9ee876f07c1c9b6ed36a22b6 upstream.
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
js: there is no change for ext4. This patch defines merely
inode_set_flags for jffs in the next patch. I wonder why do we
have both inode_set_flags and set_mask_bits? Looks like an
improperly resolved merge conflict.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: stable@kernel.org
commit d311d79de305f1ada47cadd672e6ed1b28a949eb upstream.
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support)
when sync_page_range() had been introduced; generic_file_write{,v}() correctly
synced
pos_after_write - written .. pos_after_write - 1
but generic_file_aio_write() synced
pos_before_write .. pos_before_write + written - 1
instead. Which is not the same thing with O_APPEND, obviously.
A couple of years later correct variant had been killed off when
everything switched to use of generic_file_aio_write().
All users of generic_file_aio_write() are affected, and the same bug
has been copied into other instances of ->aio_write().
The fix is trivial; the only subtle point is that generic_write_sync()
ought to be inlined to avoid calculations useless for the majority of
calls.
[ Upstream commit 84bc88688e3f6ef843aa8803dbcd90168bb89faf ]
There could be a signed overflow in the following code.
The expression, (32-logmask) is comprised between 0 and 31 included.
It may be equal to 31.
In such a case the left shift will produce a signed integer overflow.
According to the C99 Standard, this is an undefined behavior.
A simple fix is to replace the signed int 1 with the unsigned int 1U.
Signed-off-by: Vincent BENAYOUN <vincent.benayoun@trust-in-soft.com>
commit 9de7922bc709eee2f609cd01d98aaedc4cf5ea74 upstream.
Commit 6f4c618ddb0 ("SCTP : Add paramters validity check for
ASCONF chunk") added basic verification of ASCONF chunks, however,
it is still possible to remotely crash a server by sending a
special crafted ASCONF chunk, even up to pre 2.6.12 kernels:
skb_over_panic: text:ffffffffa01ea1c3 len:31056 put:30768
head:ffff88011bd81800 data:ffff88011bd81800 tail:0x7950
end:0x440 dev:<NULL>
kernel BUG at net/core/skbuff.c:129!
Call Trace:
<IRQ>
[<ffffffff8144fb1c>] skb_put+0x5c/0x70
[<ffffffffa01ea1c3>] sctp_addto_chunk+0x63/0xd0 [sctp]
[<ffffffffa01eadaf>] sctp_process_asconf+0x1af/0x540 [sctp]
[<ffffffff8152d025>] ? _read_unlock_bh+0x15/0x20
[<ffffffffa01e0038>] sctp_sf_do_asconf+0x168/0x240 [sctp]
[<ffffffffa01e3751>] sctp_do_sm+0x71/0x1210 [sctp]
[<ffffffff8147645d>] ? fib_rules_lookup+0xad/0xf0
[<ffffffffa01e6b22>] ? sctp_cmp_addr_exact+0x32/0x40 [sctp]
[<ffffffffa01e8393>] sctp_assoc_bh_rcv+0xd3/0x180 [sctp]
[<ffffffffa01ee986>] sctp_inq_push+0x56/0x80 [sctp]
[<ffffffffa01fcc42>] sctp_rcv+0x982/0xa10 [sctp]
[<ffffffffa01d5123>] ? ipt_local_in_hook+0x23/0x28 [iptable_filter]
[<ffffffff8148bdc9>] ? nf_iterate+0x69/0xb0
[<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0
[<ffffffff8148bf86>] ? nf_hook_slow+0x76/0x120
[<ffffffff81496ded>] ip_local_deliver_finish+0xdd/0x2d0
[<ffffffff81497078>] ip_local_deliver+0x98/0xa0
[<ffffffff8149653d>] ip_rcv_finish+0x12d/0x440
[<ffffffff81496ac5>] ip_rcv+0x275/0x350
[<ffffffff8145c88b>] __netif_receive_skb+0x4ab/0x750
[<ffffffff81460588>] netif_receive_skb+0x58/0x60
This can be triggered e.g., through a simple scripted nmap
connection scan injecting the chunk after the handshake, for
example, ...
-------------- INIT[ASCONF; ASCONF_ACK] ------------->
<----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
------------------ ASCONF; UNKNOWN ------------------>
... where ASCONF chunk of length 280 contains 2 parameters ...
1) Add IP address parameter (param length: 16)
2) Add/del IP address parameter (param length: 255)
... followed by an UNKNOWN chunk of e.g. 4 bytes. Here, the
Address Parameter in the ASCONF chunk is even missing, too.
This is just an example and similarly-crafted ASCONF chunks
could be used just as well.
The ASCONF chunk passes through sctp_verify_asconf() as all
parameters passed sanity checks, and after walking, we ended
up successfully at the chunk end boundary, and thus may invoke
sctp_process_asconf(). Parameter walking is done with
WORD_ROUND() to take padding into account.
In sctp_process_asconf()'s TLV processing, we may fail in
sctp_process_asconf_param() e.g., due to removal of the IP
address that is also the source address of the packet containing
the ASCONF chunk, and thus we need to add all TLVs after the
failure to our ASCONF response to remote via helper function
sctp_add_asconf_response(), which basically invokes a
sctp_addto_chunk() adding the error parameters to the given
skb.
When walking to the next parameter this time, we proceed
with ...
length = ntohs(asconf_param->param_hdr.length);
asconf_param = (void *)asconf_param + length;
... instead of the WORD_ROUND()'ed length, thus resulting here
in an off-by-one that leads to reading the follow-up garbage
parameter length of 12336, and thus throwing an skb_over_panic
for the reply when trying to sctp_addto_chunk() next time,
which implicitly calls the skb_put() with that length.
Fix it by using sctp_walk_params() [ which is also used in
INIT parameter processing ] macro in the verification *and*
in ASCONF processing: it will make sure we don't spill over,
that we walk parameters WORD_ROUND()'ed. Moreover, we're being
more defensive and guard against unknown parameter types and
missized addresses.
Joint work with Vlad Yasevich.
Fixes: b896b82be4ae ("[SCTP] ADDIP: Support for processing incoming ASCONF_ACK chunks.")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit b69040d8e39f20d5215a03502a8e8b4c6ab78395 upstream.
When receiving a e.g. semi-good formed connection scan in the
form of ...
---------------- ASCONF_a; ASCONF_b ----------------->
... where ASCONF_a equals ASCONF_b chunk (at least both serials
need to be equal), we panic an SCTP server!
The problem is that good-formed ASCONF chunks that we reply with
ASCONF_ACK chunks are cached per serial. Thus, when we receive a
same ASCONF chunk twice (e.g. through a lost ASCONF_ACK), we do
not need to process them again on the server side (that was the
idea, also proposed in the RFC). Instead, we know it was cached
and we just resend the cached chunk instead. So far, so good.
Where things get nasty is in SCTP's side effect interpreter, that
is, sctp_cmd_interpreter():
While incoming ASCONF_a (chunk = event_arg) is being marked
!end_of_packet and !singleton, and we have an association context,
we do not flush the outqueue the first time after processing the
ASCONF_ACK singleton chunk via SCTP_CMD_REPLY. Instead, we keep it
queued up, although we set local_cork to 1. Commit 2e3216cd54b1
changed the precedence, so that as long as we get bundled, incoming
chunks we try possible bundling on outgoing queue as well. Before
this commit, we would just flush the output queue.
Now, while ASCONF_a's ASCONF_ACK sits in the corked outq, we
continue to process the same ASCONF_b chunk from the packet. As
we have cached the previous ASCONF_ACK, we find it, grab it and
do another SCTP_CMD_REPLY command on it. So, effectively, we rip
the chunk->list pointers and requeue the same ASCONF_ACK chunk
another time. Since we process ASCONF_b, it's correctly marked
with end_of_packet and we enforce an uncork, and thus flush, thus
crashing the kernel.
Fix it by testing if the ASCONF_ACK is currently pending and if
that is the case, do not requeue it. When flushing the output
queue we may relink the chunk for preparing an outgoing packet,
but eventually unlink it when it's copied into the skb right
before transmission.
Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet")
commit e10038a8ec06ac819b7552bb67aaa6d2d6f850c1 upstream.
This structure is not exposed to userspace, so fix this by defining
struct sk_filter; so we skip the casting in kernelspace. This is safe
since userspace has no way to lurk with that internal pointer.
Fixes: e6f30c7 ("netfilter: x_tables: add xt_bpf match")
Acked-by: Willem de Bruijn <willemb@google.com>
commit 96a2adbc6f501996418da9f7afe39bf0e4d006a9 upstream.
kernel/time/jiffies.c provides a default clocksource_default_clock()
definition explicitly marked "weak". arch/s390 provides its own definition
intended to override the default, but the "weak" attribute on the
declaration applied to the s390 definition as well, so the linker chose one
based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from
pcibios_get_phb_of_node decl")).
Remove the "weak" attribute from the clocksource_default_clock()
declaration so we always prefer a non-weak definition over the weak one,
independent of link order.
Fixes: f1b82746c1e9 ("clocksource: Cleanup clocksource selection")
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: John Stultz <john.stultz@linaro.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
CC: Daniel Lezcano <daniel.lezcano@linaro.org>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 107bcc6d566cb40184068d888637f9aefe6252dd upstream.
kernel/debug/debug_core.c provides a default kgdb_arch_pc() definition
explicitly marked "weak". Several architectures provide their own
definitions intended to override the default, but the "weak" attribute on
the declaration applied to the arch definitions as well, so the linker
chose one based on link order (see 10629d711ed7 ("PCI: Remove __weak
annotation from pcibios_get_phb_of_node decl")).
Remove the "weak" attribute from the declaration so we always prefer a
non-weak definition over the weak one, independent of link order.
Fixes: 688b744d8bc8 ("kgdb: fix signedness mixmatches, add statics, add declaration to header")
Tested-by: Vineet Gupta <vgupta@synopsys.com> # for ARC build
Reviewed-by: Harvey Harrison <harvey.harrison@gmail.com>
