commit d3f7eae182b04997be19343a23f7009170f4f7a5 upstream
The Averatec 2370 and some other Turion laptop BIOS seems to program the
ENABLE_C1E MSR inconsistently between cores. This confuses the lapic
use heuristics because when C1E is enabled anywhere it seems to affect
the complete chip.
Use a global flag instead of a per cpu flag to handle this.
If any CPU has C1E enabled disabled lapic use.
Thanks to Cal Peake for debugging.
Cc: tglx@linutronix.de
Cc: Chuck Ebbert <cebbert@redhat.com>
Signed-off-by: Andi Kleen <ak@suse.de>
commit 09d74cdd88a59a18f2ad7cfa0b6045ed1817b632 in mainline.
Subject: [PATCH] [KBUILD]: Sanitize tc_ematch headers.
The headers in tc_ematch are used by iproute2, so these headers should
be processed.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
RX790 can't do MSI like its predecessors. Disable MSI on RX790.
Signed-off-by: Tejun Heo <htejun@gmail.com>
RD580 can't do MSI like its predecessors. Disable MSI on RD580.
Signed-off-by: Tejun Heo <teheo@suse.de>
RS690 can't do MSI like its predecessors. Disable MSI on RS690.
Cc: Henry Su <henry.su@amd.com>
[TCP]: Invoke tcp_sendmsg() directly, do not use inet_sendmsg().
As discovered by Evegniy Polyakov, if we try to sendmsg after
a connection reset, we can do incredibly stupid things.
The core issue is that inet_sendmsg() tries to autobind the
socket, but we should never do that for TCP. Instead we should
just go straight into TCP's sendmsg() code which will do all
of the necessary state and pending socket error checks.
TCP's sendpage already directly vectors to tcp_sendpage(), so this
merely brings sendmsg() in line with that.
Author: Chuck Ebbert <cebbert@redhat.com>
Add xt_statistic.h to the list of headers to install.
Apparently needed to build newer versions of iptables.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
The underflow exception cases were wrong.
This is one weird area of ieee1754 handling in that the underflow
behavior changes based upon whether underflow is enabled in the trap
enable mask of the FPU control register. As a specific case the Sparc
V9 manual gives us the following description:
If UFM = 0: Underflow occurs if a nonzero result is tiny and a
loss of accuracy occurs. Tininess may be detected
before or after rounding. Loss of accuracy may be
either a denormalization loss or an inexact result.
If UFM = 1: Underflow occurs if a nonzero result is tiny.
Tininess may be detected before or after rounding.
What this amounts to in the packing case is if we go subnormal,
we set underflow if any of the following are true:
1) rounding sets inexact
2) we ended up rounding back up to normal (this is the case where
we set the exponent to 1 and set the fraction to zero), this
should set inexact too
3) underflow is set in FPU control register trap-enable mask
The initially discovered example was "DBL_MIN / 16.0" which
incorrectly generated an underflow. It should not, unless underflow
is set in the trap-enable mask of the FPU csr.
Another example, "0x0.0000000000001p-1022 / 16.0", should signal both
inexact and underflow. The cpu implementations and ieee1754
literature is very clear about this. This is case #2 above.
However, if underflow is set in the trap enable mask, only underflow
should be set and reported as a trap. That is handled properly by the
prioritization logic in
arch/sparc{,64}/math-emu/math.c:record_exception().
Based upon a report and test case from Jakub Jelinek.
[NET]: Share correct feature code between bridging and bonding
http://bugzilla.kernel.org/show_bug.cgi?id=8797 shows that the
bonding driver may produce bogus combinations of the checksum
flags and SG/TSO.
For example, if you bond devices with NETIF_F_HW_CSUM and
NETIF_F_IP_CSUM you'll end up with a bonding device that
has neither flag set. If both have TSO then this produces
an illegal combination.
The bridge device on the other hand has the correct code to
deal with this.
In fact, the same code can be used for both. So this patch
moves that logic into net/core/dev.c and uses it for both
bonding and bridging.
In the process I've made small adjustments such as only
setting GSO_ROBUST if at least one constituent device
supports it.
These functions depend on "result" being initalized to 0, but "result"
is not included as an input constraint to the inline assembly block
following its initialization, only as an output constraint. Thus gcc
thinks it doesn't need to initialize it, so result ends up undefined
if the "unless" condition is true.
This fixes an oops in sunrpc where the faulty atomics caused
rpciod_up() to not start the workqueue as it should.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Revert 7e92b4fc345f5b6f57585fbe5ffdb0f24d7c9b26. It broke Sébastien Dugué's
machine and Jeff said (persuasively)
This seems like it will break decades-long-working stuff, in favor of
breaking new ground in our favorite area, "trusting the BIOS."
It's just not worth it for serial ports, IMO. Serial ports are something
that just shouldn't break at this late stage in the game. My new Intel
platform boxes don't even have serial ports, so I question the value of
messing with serial port probing even more... because... just wait a year,
and your box won't have a serial port either! :)
I certainly don't object to the use of platform devices (or isa_driver),
but the probe change seems questionable. That's sorta analagous to
rewriting the floppy driver probe routine. Sure you could do it... but why
risk all that damage and go through debugging all over again?
It seems clear from this report that we cannot, should not, trust BIOS for
something (a) so simple and (b) that has been working for over a decade.
Much discussion ensued and we've decided to have another go at all of this.
Cc: Sébastien Dugué <sebastien.dugue@bull.net>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Adam Belay <ambx1@neo.rr.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
Cc: Sascha Sommer <saschasommer@freenet.de>
This patch changes the RFCOMM TTY release process so that the TTY is kept
on the list until it is really freed. A new device flag is used to keep
track of released TTYs.
Signed-off-by: Ville Tervo <ville.tervo@nokia.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
With the cfq_queue hash removal, we inadvertently got rid of the
async queue sharing. This was not intentional, in fact CFQ purposely
shares the async queue per priority level to get good merging for
async writes.
So put some logic in cfq_get_queue() to track the shared queues.
As reported by Gustavo de Nardin <gustavodn@mandriva.com.br>, while trying to
compile xosview (http://xosview.sourceforge.net/) with upstream kernel
headers being used you get the following errors:
serialmeter.cc:48:30: error: linux/serial_reg.h: No such file or directory
serialmeter.cc: In member function 'virtual void
SerialMeter::checkResources()':
serialmeter.cc:71: error: 'UART_LSR' was not declared in this scope
serialmeter.cc:71: error: 'UART_MSR' was not declared in this scope
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Cc: Gustavo de Nardin <gustavodn@mandriva.com.br>
[NETFILTER]: ipt_iprange.h must #include <linux/types.h>
ipt_iprange.h must #include <linux/types.h> since it uses __be32.
This patch fixes kernel Bugzilla #7604.
[XFRM]: Fix crash introduced by struct dst_entry reordering
XFRM expects xfrm_dst->u.next to be same pointer as dst->next, which
was broken by the dst_entry reordering in commit 1e19e02c~, causing
an oops in xfrm_bundle_ok when walking the bundle upwards.
Kill xfrm_dst->u.next and change the only user to use dst->next instead.
The SiS966 has one additional PCI-ID 1180.
If the chipset is using this PCI-ID, the primary channel is connected to the
first PATA-port. The secondary channel is connected to SATA-ports in IDE
emulation mode. The legacy IO-ports are used.
The including of the PCI-ID into pata_sis is not sufficient, because the legacy
driver in drivers/ide is initialized before pata_sis.
Signed-off-by: Uwe Koziolek <uwe.koziolek@gmx.net>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
This patch fixes the following 2.6.22 regression with CONFIG_KALLSYMS=n:
<-- snip -->
CC arch/m32r/kernel/traps.o
In file included from /home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/arch/m32r/kernel/traps.c:14:
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h: In function 'lookup_symbol_name':
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h:66: error: 'ERANGE' undeclared (first use in this function)
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h:66: error: (Each undeclared identifier is reported only once
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h:66: error: for each function it appears in.)
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h: In function 'lookup_symbol_attrs':
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h:71: error: 'ERANGE' undeclared (first use in this function)
make[2]: *** [arch/m32r/kernel/traps.o] Error 1
<-- snip -->
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Fix scheduling latency issue on 24K, 34K and 74K cores
[MIPS] Add macros to encode processor revisions.
[MIPS] RM7000: Enable ICACHE_REFILLS_WORKAROUND_WAR.
[MIPS] SMTC: Fix cut'n'paste bug in Kconfig.debug
[MIPS] Change libgcc-style functions from lib-y to obj-y
[MIPS] Fix timer/performance interrupt detection
[MIPS] AP/SP: Avoid triggering the 34K E125 performance issue
[MIPS] 64-bit TO_PHYS_MASK macro for RM9000 processors
o Commit 1833d6bc72893265f22addd79cf52e6987496e0f broke the build if
compiled with CONFIG_ES7000=y and CONFIG_X86_GENERICARCH=n
arch/i386/kernel/built-in.o(.init.text+0x4fa9): In function `acpi_parse_madt':
: undefined reference to `acpi_madt_oem_check'
arch/i386/kernel/built-in.o(.init.text+0x7406): In function `smp_read_mpc':
: undefined reference to `mps_oem_check'
arch/i386/kernel/built-in.o(.init.text+0x8990): In function
`connect_bsp_APIC':
: undefined reference to `enable_apic_mode'
make: *** [.tmp_vmlinux1] Error 1
o Fix the build issue. Provided the definitions of missing functions.
o Don't have ES7000 machine. Only compile tested.
Cc: Natalie Protasevich <protasnb@gmail.com>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Andi Kleen <ak@suse.de>
The idle loop goes to sleep using the WAIT instruction if !need_resched().
This has is suffering from from a race condition that if if just after
need_resched has returned 0 an interrupt might set TIF_NEED_RESCHED but
we've just completed the test so go to sleep anyway. This would be
trivial to fix by just disabling interrupts during that sequence as in:
local_irq_disable();
if (!need_resched())
__asm__("wait");
local_irq_enable();
but the processor architecture leaves it undefined if a processor calling
WAIT with interrupts disabled will ever restart its pipeline and indeed
some processors have made use of the freedom provided by the architecture
definition. This has been resolved and the Config7.WII bit indicates that
the use of WAIT is safe on 24K, 24KE and 34K cores. It also is safe on
74K starting revision 2.1.0 so enable the use of WAIT with interrupts
disabled for 74K based on a c0_prid of at least that.
Older processors used to encode processor version and revision in two
4-bit bitfields, the 4K seems to simply count up and even newer MTI cores
have switched to use the 8-bits as 3:3:2 bitfield with the last field as
the patch number.
The RM7000 processors and the E9000 cores have a bug (though PMC-Sierra
opposes it being called that) where invalid instructions in the same
I-cache line worth of instructions being fetched may case spurious
exceptions.
The workaround for this was only enabled for E9000 cores; enable it also
for all RM7000-based platforms.
Signed-off-by: Andrew Sharp <tigerand@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: document some of keycodes
Input: add a new EV_SW SW_RADIO event, for radio switches on laptops
Input: serio - take drv_mutex in serio_cleanup()
Input: atkbd - use printk_ratelimit for spurious ACK messages
Input: atkbd - throttle LED switching
Input: i8042 - add HP Pavilion ZT1000 to the MUX blacklist
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Update defconfigs
[POWERPC] Uninline and export virq_to_hw() for the pasemi_mac driver
[POWERPC] Fix PMI breakage in cbe_cbufreq driver
[POWERPC] Disable old EMAC driver in arch/powerpc
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
This marks the declaration of die() correctly, removing "control reaches
end of non-void function" warnings from non-void functions that die() at
the end.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Some IP35 defines snuck into some IP32-specific code during the DMA re-write.
Signed-off-by: Joshua Kinard <kumba@gentoo.org>
This file accidentally got truncated instead of deleted in commit df30b11.
Signed-off-by: Marco Roeland <marco.roeland@xs4all.nl>
Cc: Robert P. J. Day <rpjday@mindspring.com>
Cc: Jesper Juhl <jesper.juhl@gmail.com>
Cc: Alex Riesen <raa.lkml@gmail.com>
Cc: Robin Getz <robin.getz@analog.com>
Acked-by: Bryan Wu <bryan.wu@analog.com>
Uninline virq_to_hw and export it so modules can use it. The alternative
would be to export the irq_map array instead, but it's an infrequently
called function, and keeping the array unexported seems considerably
cleaner.
This is needed so that the pasemi_mac driver can be compiled as a module.
Commit 52ade9b3b97fd3bea42842a056fe0786c28d0555 changed the suspend code
ordering to execute pm_ops->prepare() after the device model per-device
.suspend() calls in order to fix some ACPI-related issues. Unfortunately, it
broke the at91 platform which assumed that pm_ops->prepare() would be called
before suspending devices.
at91 used pm_ops->prepare() to get notified of the target system sleep state,
so that it could use this information while suspending devices. However, with
the current suspend code ordering pm_ops->prepare() is called too late for
this purpose. Thus, at91 needs an additional method in 'struct pm_ops' that
will be used for notifying the platform of the target system sleep state.
Moreover, in the future such a method will also be needed by ACPI.
This patch adds the .set_target() method to 'struct pm_ops' and makes the
suspend code call it, if implemented, before executing the device model
per-device .suspend() calls. It also modifies the at91 code to use
pm_ops->set_target() instead of pm_ops->prepare().
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Greg KH <greg@kroah.com>
Provide stubs for more PCI bus/slot functions when CONFIG_PCI=n.
Cc: Matt Domsch <Matt_Domsch@dell.com>
/home/rpjday/AMD/k/topics/0_hi/hi1.c:15: error: dereferencing pointer to incomplete type
/home/rpjday/AMD/k/topics/0_hi/hi1.c:16: error: dereferencing pointer to incomplete type
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6:
[SPARC64]: Add linux/pagemap.h to asm/tlb.h
[SPARC64]: Need to set state to IDLE during sun4v IRQ enable.
[SPARC64]: Fix VIRQ enabling.
[SPARC64]: Add irqs to mdesc_node.
Document some of keycodes, based on USB HUT 1.12 and current mapping
in HID driver.
Many laptops have rf-kill physical switches that are not keys, but slider
or rocker switches. Often (like in all ThinkPads with a radio kill slider
switch), they have both a slider/rocker switch and a hot key.
Trying to kludge a real switch to act like a key is not a very smart thing
to do if you can help it, and it gets specially bad when you are going to
have both in the same machine. So, we do the right thing and add an input
EV_SW event for radio kill switches.
The EV_SW SW_RADIO event is defined with positive logic, i.e. when the
switch is active, the radios are to be enabled. When the switch is
inactive, the radios are to be disabled.
Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
As seen on sparc64-allnoconfig:
CC arch/sparc64/mm/tlb.o
In file included from arch/sparc64/mm/tlb.c:19:
include/asm/tlb.h: In function 'tlb_flush_mmu':
include/asm/tlb.h:60: warning: implicit declaration of function 'release_pages'
include/asm/tlb.h: In function 'tlb_remove_page':
include/asm/tlb.h:92: warning: implicit declaration of function 'page_cache_release'
Not all the world is an i386. Many architectures need 64-bit arguments to be
aligned in suitable pairs of registers, and the original
sys_sync_file_range(int, loff_t, loff_t, int) was therefore wasting an
argument register for padding after the first integer. Since we don't
normally have more than 6 arguments for system calls, that left no room for
the final argument on some architectures.
Fix this by introducing sys_sync_file_range2(int, int, loff_t, loff_t) which
all fits nicely. In fact, ARM already had that, but called it
sys_arm_sync_file_range. Move it to fs/sync.c and rename it, then implement
the needed compatibility routine. And stop the missing syscall check from
bitching about the absence of sys_sync_file_range() if we've implemented
sys_sync_file_range2() instead.
Tested on PPC32 and with 32-bit and 64-bit userspace on PPC64.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Fix gcc warning and add parameter checking when CONFIG_EVENTFD=n:
fs/aio.c: In function 'aio_complete':
fs/aio.c:955: warning: statement with no effect
Cc: Davide Libenzi <davidel@xmailserver.org>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Make SN2 PCI code use ioremap rather than manually mangle the address
[IA64] Force error to surface in nofault code
[IA64] change sh_change_coherence oemcall to use nolock
[IA64] remove duplicate header include line
[IA64] Correct unwind validation code
[IA64] is_power_of_2-ia64/mm/hugetlbpage.c
ATA_HORKAGE_DMA_RW_ONLY for TORiSAN is verified to be subset of using
DMA for ATAPI commands which aren't aligned to 16 bytes. As libata
now doesn't use DMA for unaligned ATAPI commands, the horkage is
redundant. Kill it.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
The infamous abnormal status message triggers on not so abnormal cases
including empty port and even when it's being triggered on actual
errors the info it provides is redundant and out of context - higher
level functions will print the info in better safe later anyway.
Also, by being triggered all the time, it leads people to think that
the abnormality is somehow related to all ATA and system problems
they're experiencing and gives owners of healthy systems unfounded
doubts about the integrity of the universe. Make it a DPRINTK and
save the universe.
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 4449/1: more entries in arch/arm/boot/.gitignore
[ARM] 4452/1: Force the literal pool dump before reloc_end
[ARM] Update show_regs/oops register format
[ARM] Add support for pause_on_oops and display preempt/smp options
[MIPS] Count timer interrupts correctly.
[MIPS] SMTC and non-SMTC kernel and modules are incompatible
[MIPS] EMMA2RH: Disable GEN_RTC, it can't possibly work.
[MIPS] Remove a duplicated local variable in test_and_clear_bit()
[MIPS] use compat_siginfo in rt_sigframe_n32
[MIPS] 20K: Handle WAIT related bugs according to errata information
[MIPS] AP/SP requires shadow registers, auto enable support.
[MIPS] Fix pb1500 reg B access
[MIPS] Alchemy: Fix wrong cast
[MIPS] remove "support for" from system type entry
[MIPS] add io_map_base to pci_controller on Cobalt
[MIPS] __ucmpdi2 arguments are unsigned long long.
Change sn_change_coherence's ia64_sal_oemcall to the nolock variety since
PROM does the locking for this function internally.
Signed-off-by: Dean Nelson <dcn@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
So don't allow mixing.
Fix a sparse warning caused by 2c921d07f8c641e691b0dfd80a5cfe14c60ec489
include2/asm/bitops.h:313:23: warning: symbol 'res' shadows an earlier one
include2/asm/bitops.h:309:16: originally declared here
Signed-off-by: Pavel Kiryukhin <vksavl@gmail.com>
Will be used to store translated LDC rx-ino and tx-ino.
