To support a wider variety of backlight setups, introduce an optional
enable GPIO. Legacy users of the platform data already have a means of
supporting GPIOs by using the .init(), .exit() and .notify() hooks. DT
users however cannot use those, so an alternative method is required.
In order to ease the introduction of the optional enable GPIO, make it
available in the platform data first, so that existing users can be
converted. Once that has happened a second patch will add code to make
use of it in the driver.
Signed-off-by: Thierry Reding <treding@nvidia.com>
(cherry picked from commit 2b9b1620349e325f184c68cddf3b484499c163c0)
This reverts commit 95730406a0e3bbd7f862718782924a3c367845a1.
This reverts commit 74df06fb565b7250bc86d79727b66bb02259d54c.
This reverts commit 08a13bacb43f206239ae0f1ccbe37325993e2b1b.
Both firmware and kernel are using the same set of constants
in a header file, this patch separates them in to a single file.
That way it will be easier to track changes to FW or kernel.
Add ability to switch between 24.1 and 24.0 lvds modes.
Mode description can be found in "Using 24-bpp LVDS Panels with
Intel® Mobile Chipsets for Embedded Applications".
Increased SPI speed for transfers and peripheral speed.
Switch to cleaning IRQ flags on read, instead of separate write.
Switched to zero-copy on SPI reads.
Some functionality used by android binary drivers
were missing.
Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
b271e8fa67a6d9c4600274a25636cfe00fdd1b68
We have never used the IOCTL FREE_OBJ_CTX. Using it leads to context being
only partially available, and can lead to use-after-free.
Bug 1885775
Change-Id: I9d2b632ab79760f8186d02e0f35861b3a6aae649
Signed-off-by: Debarshi Dutta <ddutta@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1506479
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
This patch includes CAN driver and improvements in SPI communications
for Apalis TK1 k20 based MFD.
Requires firmware version 0.9.
Check a few input params to make sure there is
no potential for a heap overflow in the driver.
(Back ported from Nexus N9 project)
Bug 1757475 (nvidia)
Bug 1832830 (nvidia)
Bug 28193342 (google)
Change-Id: I979fa38c5f453cfad7070f0340ec04adde5bac13
Signed-off-by: Amey Asgaonkar <aasgaonkar@nvidia.com>
Reviewed-on: http://git-master/r/1271369
Reviewed-by: Frank Chen <frankc@nvidia.com>
Tested-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Several places in the camera stack can hit integer overflows or cause
bad allocations if userspace passes in a bogus sizeofvalue parameter.
Protect against this by using appropriately-sized integer types, adding
range checks, replacing array-allocation calls with kcalloc(), and
checking for allocations returning ZERO_SIZE_PTR.
For one specific ioctl (PCLLK_IOCTL_UPDATE) sizeofvalue = 0 is fine,
since when that happens the subdrivers won't actually touch the returned
allocation. In fact the existing userspace camera driver makes calls
like these and expects them to succeed! Handle this special case by
adding a __camera_get_params variant that optionally treats zero-sized
inputs as valid.
(back ported from Nexus N9 project)
Bug 1832830
Change-Id: Ie3250d8a4b814de5820fa0190b4cbd1af3ca4b3f
Reported-by: Jianqiang Zhao <zhaojianqiang1@gmail.com>
Signed-off-by: Greg Hackmann <ghackmann@google.com>
Reviewed-on: http://git-master/r/1271367
On Apalis TK1 boards K20 MCU is used
for CAN, GPIO, ADC and touch screen.
This patch includes support for core MFD device, GPIO, ADC
and touch screen.
commit 19be0eaffa3ac7d8eb6784ad9bdbc7d67ed8e619 upstream.
This is an ancient bug that was actually attempted to be fixed once
(badly) by me eleven years ago in commit 4ceb5db9757a ("Fix
get_user_pages() race for write access") but that was then undone due to
problems on s390 by commit f33ea7f404e5 ("fix get_user_pages bug").
In the meantime, the s390 situation has long been fixed, and we can now
fix it by checking the pte_dirty() bit properly (and do it better). The
s390 dirty bit was implemented in abf09bed3cce ("s390/mm: implement
software dirty bits") which made it into v3.9. Earlier kernels will
have to look at the page state itself.
Also, the VM has become more scalable, and what used a purely
theoretical race back then has become easier to trigger.
To fix it, we introduce a new internal FOLL_COW flag to mark the "yes,
we already did a COW" rather than play racy games with FOLL_WRITE that
is very fundamental, and then use the pte dirty flag to validate that
the FOLL_COW flag is still valid.
Reported-and-tested-by: Phil "not Paul" Oester <kernel@linuxace.com>
Reviewed-by: Michal Hocko <mhocko@suse.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Nick Piggin <npiggin@gmail.com>
Cc: stable@vger.kernel.org
[wt: s/gup.c/memory.c; s/follow_page_pte/follow_page_mask;
s/faultin_page/__get_user_page]
Signed-off-by: Willy Tarreau <w@1wt.eu>
Change-Id: I6fbb1abf656ff7e05ec4c65f07dbbdd694546fb4
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Signed-off-by: Sumit Gupta <sumitg@nvidia.com>
Reviewed-on: http://git-master/r/1241321
Tested-by: Bibek Basu <bbasu@nvidia.com>
commit 95272c29378ee7dc15f43fa2758cb28a5913a06d upstream.
-ftracer can duplicate asm blocks causing compilation to fail in
noclone functions. For example, KVM declares a global variable
in an asm like
asm("2: ... \n
.pushsection data \n
.global vmx_return \n
vmx_return: .long 2b");
and -ftracer causes a double declaration.
Cc: Michal Marek <mmarek@suse.cz>
Cc: kvm@vger.kernel.org
Reported-by: Linda Walsh <lkml@tlinx.org>
(cherry picked from commit 5d814ad8d35e5e23e0c27fb0f0b80c1044ecefad)
commit cb984d101b30eb7478d32df56a0023e4603cba7f upstream.
As gcc major version numbers are going to advance rather rapidly in the
future, there's no real value in separate files for each compiler
version.
Deduplicate some of the macros #defined in each file too.
Neaten comments using normal kernel commenting style.
Cc: Segher Boessenkool <segher@kernel.crashing.org>
Cc: Sasha Levin <levinsasha928@gmail.com>
Cc: Alan Modra <amodra@gmail.com>
[ philm: backport to 3.10-stable ]
Signed-off-by: Philip Müller <philm@manjaro.org>
(cherry picked from commit a4a4f1cd733fe5b345db4e8cc19bb8868d562a8a)
This patch allows for easy integration of a custom Linux boot logo to
replace the Tux' being shown by default.
Use gimp or the like to create a raw PPM in your desired resolution.
Reduce the number of colours in the image to 224:
user@host:~$ ppmquant 224 Toradex-640x480.ppm > \
Toradex-640x480-224.ppm
ppmquant: making histogram...
ppmquant: 370 colors found
ppmquant: choosing 224 colors...
ppmquant: mapping image to new colors...
Convert it from raw PPM to ASCII format:
user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \
Toradex-640x480-ascii-224.ppm
Copy it into the Linux sources:
cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\
logo_custom_clut224.ppm
Activate exclusively custom Linux logo in the kernel configuration:
Device Drivers -> Graphics support -> Bootup logo ->
Custom 224-color Linux logo
And re-compile the kernel.
(cherry picked from commit fa2371bff9ac03581881849d8f95678ef3992719)
Added support to use polling mode instead of interrupts
through a property in dt
Bug 1679083
Change-Id: Ic82ab592822cc96bacda05124d38ddd913e09af9
Reviewed-on: http://git-master/r/840233
(cherry picked from commit cd1c4db5adc8317572106099da37fa434245e699)
Reviewed-on: http://git-master/r/1009988
(cherry picked from commit b29ce03a6b7ebb306ff157640470dd5ab99c6f6b)
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/1175213
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
SPI register access for T210 and earlier chips depend
on SPI clock frequency. Provided an option to set SPI
clock at max frequency for register access.
Bug 1675625
Change-Id: Ie52c83cd4602604822462d9f02ddf31ead83aafc
Reviewed-on: http://git-master/r/1009782
(cherry picked from commit a2ccd28f2850538064668568432fee5d70a22e82)
Reviewed-on: http://git-master/r/1174581
We're missing include/linux/compiler-gcc5.h which is required now
because gcc branched off to v5 in trunk.
Just copy the relevant bits out of include/linux/compiler-gcc4.h,
no new code is added as of now.
This fixes a build error when using gcc 5.
Cc: <stable@vger.kernel.org>
(cherry picked from commit 71458cfc782eafe4b27656e078d379a34e472adf)
We need to validate power on/off function size passed
in from user mode in order to avoid integer overflow
or out of memory failures.
Bug 1745100
Change-Id: Idddd848f7dc1e864559ad219f9204325128484e5
Signed-off-by: Frank Chen <frankc@nvidia.com>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/1114354
(cherry picked from commit 8b3afcc132882f3102083f9a24de7f55476ca59b)
Reviewed-on: http://git-master/r/1150944
Increase NVAVP_MAX_RELOCATION_COUNT to max. possible value
and add check to return error if num_relocs in
nvavp_pushbuffer_submit_ioctl exceeds
Bug 1739930
Change-Id: Ief36cedd692aa53135fc6a0039b19f18609259dd
Signed-off-by: Somasundaram S <somasundaram@nvidia.com>
Reviewed-on: http://git-master/r/1030885
Tested-by: Somu Sundaram <somasundarams@nvidia.com>
This reverts commit 24584959ad4822e985e3a072ca8f44b69f2afc33.
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Change-Id: I5a2b7c64f47643ef482caa8b2da81d018747109b
Reviewed-on: http://git-master/r/759478
This reverts commit 8eadba170693964dc30b1e6ab0a80df012858bc0.
Change-Id: Icd990d1e9c8df4c66c46e7e29a03cc6233e206bd
Reviewed-on: http://git-master/r/759473
Using Tegra WDT to trigger FIQ when system is in soft lockup.
Bug 1581432
Change-Id: I853a88a3f6e9402c978db18c5a63e903c582040a
Signed-off-by: Renn Wu <rewu@nvidia.com>
Reviewed-on: http://git-master/r/265871
(cherry picked from commit f115f435d471af22ddec5e9d969662f79193f846)
Reviewed-on: http://git-master/r/680353
Detect when the CPU goes online/offline.
Bug 1634024
Change-Id: I989a9aefbc32a70070b37fe42ce5dcf75b18263b
Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com>
Reviewed-on: http://git-master/r/729497
(cherry picked from commit a2eec5a5ea12fb50e073b322ca9d948818179968)
Reviewed-on: http://git-master/r/748094
Reviewed-by: Andrey Trachenko <atrachenko@nvidia.com>
Unwinding based on arm32 ehabi: fix broken backtraces when
all unwind entries are located in exidx section and
extab section is not exist.
Bug 1625585
Change-Id: I800e1347b04aa2c2c8802b81478931985c19feb2
Reviewed-on: http://git-master/r/720598
(cherry picked from commit dfc9e9e4ce081b3116e457711e2f4a67fabb169c)
Reviewed-on: http://git-master/r/748089
Use simple disassembler to verify unwind table entry against function code.
Bug 1618651
Signed-off-by: Dmitry Antipov <dantipov@nvidia.com>
Change-Id: Ib75b50f1bb753b7358fcc08107bfefc3133b4f0c
Reviewed-on: http://git-master/r/714784
(cherry picked from commit 3a68f6164a4652d027fd2e62d7eb7d5ec5906dbc)
Reviewed-on: http://git-master/r/748087
Tested-by: Igor Nabirushkin <inabirushkin@nvidia.com>
Unwinding: store individual URC codes for each method.
Bug 1624134
Change-Id: I3b2045f9c9147354f3440e326fd3aeccb5e0458d
Reviewed-on: http://git-master/r/717848
(cherry picked from commit e5ceff53d63e668a19d36196823f6c185ce48e88)
Reviewed-on: http://git-master/r/748086
* Add task states into sched samples.
* Store task exit_state field.
Bug 1624099
Change-Id: I4a25aa6c15b59da987688342478127dccc5c0a1c
Reviewed-on: http://git-master/r/717839
(cherry picked from commit 9c512cace5ad5d8719a5a8df553cd313e41f4402)
Reviewed-on: http://git-master/r/747753
Add unwind reason codes for dwarf unwinding.
Bug 1611073
Change-Id: Ic7f324f526ba34505e3b9bbedae7b98c29ce097d
Reviewed-on: http://git-master/r/711654
(cherry picked from commit ea2a41fa9056145e3f1cbe6f97c7725f51a08f3e)
Reviewed-on: http://git-master/r/747750
Support dwarf unwinding for arm32 files (based on
eh_frame sections).
Bug 1611069
Change-Id: Ie057ebcfcff75ccb2d3e62aa7cb85ac4b090930c
Reviewed-on: http://git-master/r/707903
(cherry picked from commit 950855f44e647b22508f2d31fe373fffd9e0642f)
Reviewed-on: http://git-master/r/747745
bug 200035711
Change-Id: I2efdabe31ec2ab5b6b0253f54484365e61890e91
Signed-off-by: Seshagir.H <sholi@nvidia.com>
Reviewed-on: http://git-master/r/538920
(cherry picked from commit ef940296b6f41e4669fe7da4c48bf34091af2512)
Reviewed-on: http://git-master/r/725516
Reviewed-by: Jeetesh Burman <jburman@nvidia.com>
Tested-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Bug 1563244
Change-Id: Ic4a43df8d11f87b3f62c652109abf540874224c4
Reviewed-on: http://git-master/r/#/c/557255/
Signed-off-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
(cherry picked from commit fd23e040930d735191a4fcc85ba692496aeb8b56)
Reviewed-on: http://git-master/r/737315
Bug 200044433
Change-Id: I792062649c247229270678a44d10323d2744b569
Signed-off-by: Kassey Li <kasseyl@nvidia.com>
Reviewed-on: http://git-master/r/721561
Bug 1598204
Change-Id: I453d18ce570e57c0feab8dc3b24cc2c957b95301
Signed-off-by: Ming Wong <miwong@nvidia.com>
Reviewed-on: http://git-master/r/672147
Firmwares are currently released at the time we close the channel
device node. This causes unexpected side effects in cases where
the finalize_poweron is called only once to get the device booted
during the first time the device is accessed.
This patch fixes the issue by not releasing the firmware after it
has once loaded.
Bug 200033244
Change-Id: I8fc6748846e56ac0cc347feb170b239533a47252
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-on: http://git-master/r/495220
(cherry-picked from commit 69bce0a17ad1e5457cfce0d66f6e1b4add7e9820)
Reviewed-on: http://git-master/r/670671
Bug 1600299
Change-Id: I63f4d597bcc8b960407a7291fde6aa2ddb5bec25
Reviewed-on: http://git-master/r/674099
Tegra Profiler: when collecting backtraces, record
remaining data stack size.
Bug 1584533
Bug 1598009
Change-Id: I608ab73f8e1b7da84221a17a782080fdf5598111
Reviewed-on: http://git-master/r/658431
(cherry picked from commit 803c1a41e9b7ebcbf297bd7ce5caeed1d1f800ce)
Reviewed-on: http://git-master/r/672039
Tegra Profiler: add lower bound of memory for unwinding.
Bug 1574379
Bug 1598009
Change-Id: Ia3c412caa0c2adfe603c08b3916bd57f3ea14255
Reviewed-on: http://git-master/r/594457
(cherry picked from commit e94dc4b70c045322c27d83fbe56a3c9690258443)
Reviewed-on: http://git-master/r/672029
Tegra Profiler: send samples via memory mapping areas
to the user space.
Bug 1566270
Bug 1598009
Change-Id: I19aae4ca1f8d6a3ae7c36e99fb018d8fcd2152d3
Reviewed-on: http://git-master/r/559124
(cherry picked from commit 1a53b2fc3f15aeed1eee0f9aa6e259ae476acb82)
Reviewed-on: http://git-master/r/672026
During shutdown/reboot process, its better to
finish any pending irqwork so that the work is
not scheduled after devices like i2c are shutdown.
This patch provides hook to be called from rtc driver after disabling
rtc irq. Also any further request to access rtc_class_ops will
be prohibited.
Bug 200072946
Change-Id: I8eb20e5214a31fbc8a280ccfff8e190a5fabbb96
Reviewed-on: http://git-master/r/677750
Implement Tegra WDT FIQ debug function.
Default is disabled.
Bug 1581432
Change-Id: Ic81ab4cd3285080016b37191e6e0fab18e330a30
Reviewed-on: http://git-master/r/#/c/271988
Reviewed-on: http://git-master/r/662550
