commit 9f244e9cfd70c7c0f82d3c92ce772ab2a92d9f64 upstream.
[Issue]
When pstore is in panic and emergency-restart paths, it may be blocked
in those paths because it simply takes spin_lock.
This is an example scenario which pstore may hang up in a panic path:
- cpuA grabs psinfo->buf_lock
- cpuB panics and calls smp_send_stop
- smp_send_stop sends IRQ to cpuA
- after 1 second, cpuB gives up on cpuA and sends an NMI instead
- cpuA is now in an NMI handler while still holding buf_lock
- cpuB is deadlocked
This case may happen if a firmware has a bug and
cpuA is stuck talking with it more than one second.
Also, this is a similar scenario in an emergency-restart path:
- cpuA grabs psinfo->buf_lock and stucks in a firmware
- cpuB kicks emergency-restart via either sysrq-b or hangcheck timer.
And then, cpuB is deadlocked by taking psinfo->buf_lock again.
[Solution]
This patch avoids the deadlocking issues in both panic and emergency_restart
paths by introducing a function, is_non_blocking_path(), to check if a cpu
can be blocked in current path.
With this patch, pstore is not blocked even if another cpu has
taken a spin_lock, in those paths by changing from spin_lock_irqsave
to spin_trylock_irqsave.
In addition, according to a comment of emergency_restart() in kernel/sys.c,
spin_lock shouldn't be taken in an emergency_restart path to avoid
deadlock. This patch fits the comment below.
<snip>
* emergency_restart - reboot the system
* Without shutting down any hardware or taking any locks
* reboot the system. This is called when we know we are in
* trouble so this is our best effort to reboot. This is
* safe to call in interrupt context.
void emergency_restart(void)
<snip>
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Acked-by: Don Zickus <dzickus@redhat.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: CAI Qian <caiqian@redhat.com>
commit f84adf4921ae3115502f44ff467b04bf2f88cf04 upstream.
Replace llist_for_each_entry_safe with a while loop.
llist_for_each_entry_safe can trigger a bug in GCC 4.1, so it's best
to remove it and use a while loop and do the deletion manually.
Specifically this bug can be triggered by hot-unplugging a disk, either
by doing xm block-detach or by save/restore cycle.
BUG: unable to handle kernel paging request at fffffffffffffff0
IP: [<ffffffffa0047223>] blkif_free+0x63/0x130 [xen_blkfront]
The crash call trace is:
bad_area_nosemaphore+0x13/0x20
do_page_fault+0x25e/0x4b0
page_fault+0x25/0x30
? blkif_free+0x63/0x130 [xen_blkfront]
blkfront_resume+0x46/0xa0 [xen_blkfront]
xenbus_dev_resume+0x6c/0x140
pm_op+0x192/0x1b0
device_resume+0x82/0x1e0
dpm_resume+0xc9/0x1a0
dpm_resume_end+0x15/0x30
do_suspend+0x117/0x1e0
When drilling down to the assembler code, on newer GCC it does
.L29:
cmpq $-16, %r12 #, persistent_gnt check
je .L30 #, out of the loop
.L25:
... code in the loop
testq %r13, %r13 # n
je .L29 #, back to the top of the loop
movq 16(%r12), %r13 # <variable>.node.next, n
jne .L25 #, back to the top of the loop
.L30:
While on GCC 4.1, it is:
L78:
je .L78 #, back to the top of the loop
movq 16(%rbx), %r13 # <variable>.node.next, n
jmp .L78 #, back to the top of the loop
Which basically means that the exit loop condition instead of
being:
&(pos)->member != NULL;
is:
which makes the loop unbound.
Since xen-blkfront is the only user of the llist_for_each_entry_safe
macro remove it from llist.h.
Orabug: 16263164
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit c3ad83d9efdfe6a86efd44945a781f00c879b7b4 upstream.
Otherwise, ext4 file systems with the quota featured enable will get a
very confusing "No such process" error message if the quota code is
built as a module and the quota_v2 module has not been loaded.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Acked-by: Jan Kara <jack@suse.cz>
[ Upstream commit da8c87241c26aac81a64c7e4d21d438a33018f4e ]
There are two places to call vlan_set_encap_proto():
vlan_untag() and __pop_vlan_tci().
vlan_untag() assumes skb->data points after mac addr, otherwise
the following code
vhdr = (struct vlan_hdr *) skb->data;
vlan_tci = ntohs(vhdr->h_vlan_TCI);
__vlan_hwaccel_put_tag(skb, vlan_tci);
skb_pull_rcsum(skb, VLAN_HLEN);
won't be correct. But __pop_vlan_tci() assumes points _before_
mac addr.
In vlan_set_encap_proto(), it looks for some magic L2 value
after mac addr:
rawp = skb->data;
if (*(unsigned short *) rawp == 0xFFFF)
Therefore __pop_vlan_tci() is obviously wrong.
A quick fix is avoiding using skb->data in vlan_set_encap_proto(),
use 'vhdr+1' is always correct in both cases.
Signed-off-by: Cong Wang <amwang@redhat.com>
Cc: Jesse Gross <jesse@nicira.com>
Acked-by: Jesse Gross <jesse@nicira.com>
[ Upstream commit 5b0520425e5ea81ba95ec486dd6bbb59a09fff0e ]
Now we handle icmp errors in each transport protocol's err_handler,
for icmp protocols, that is ping_err. Since this handler only care
of those icmp errors triggered by echo request, errors triggered
by echo reply(which sent by kernel) are sliently ignored.
So wrap ping_err() with icmp_err() to deal with those icmp errors.
Signed-off-by: Li Wei <lw@cn.fujitsu.com>
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ]
It looks like its possible to open thousands of TCP IPv6
sessions on a server, all landing in a single slot of TCP hash
table. Incoming packets have to lookup sockets in a very
long list.
We should hash all bits from foreign IPv6 addresses, using
a salt and hash mix, not a simple XOR.
inet6_ehashfn() can also separately use the ports, instead
of xoring them.
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
[ Upstream commit ecd9883724b78cc72ed92c98bcb1a46c764fff21 ]
Eric Dumazet wrote:
| Some strange crashes happen in rt6_check_expired(), with access
| to random addresses.
| At first glance, it looks like the RTF_EXPIRES and
| stuff added in commit 1716a96101c49186b
| (ipv6: fix problem with expired dst cache)
| are racy : same dst could be manipulated at the same time
| on different cpus.
| At some point, our stack believes rt->dst.from contains a dst pointer,
| while its really a jiffie value (as rt->dst.expires shares the same area
| of memory)
| rt6_update_expires() should be fixed, or am I missing something ?
| CC Neil because of https://bugzilla.redhat.com/show_bug.cgi?id=892060
Because we do not have any locks for dst_entry, we cannot change
essential structure in the entry; e.g., we cannot change reference
to other entity.
To fix this issue, split 'from' and 'expires' field in dst_entry
out of union. Once it is 'from' is assigned in the constructor,
keep the reference until the very last stage of the life time of
the object.
Of course, it is unsafe to change 'from', so make rt6_set_from simple
just for fresh entries.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Reported-by: Neil Horman <nhorman@tuxdriver.com>
CC: Gao Feng <gaofeng@cn.fujitsu.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Reported-by: Steinar H. Gunderson <sesse@google.com>
Reviewed-by: Neil Horman <nhorman@tuxdriver.com>
[ Upstream commit dec34fb0f5b7873de45132a84a3af29e61084a6b ]
When SOCK_REFCNT_DEBUG is enabled, below build error is met:
kernel/sysctl_binary.o: In function `sk_refcnt_debug_release':
include/net/sock.h:1025: multiple definition of `sk_refcnt_debug_release'
kernel/sysctl.o:include/net/sock.h:1025: first defined here
kernel/audit.o: In function `sk_refcnt_debug_release':
make[1]: *** [kernel/built-in.o] Error 1
make: *** [kernel] Error 2
So we decide to make sk_refcnt_debug_release static to eliminate
the error.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
commit e93a9a868792ad71cdd09d75e5a02d8067473c4e upstream.
I've still got lockdep warnings even after Alan's patch, and it seems that
yet more band aids are required to paper over similar paths for
unbind_con_driver() and unregister_con_driver(). After this hack, lockdep
warnings are finally gone.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
commit 50e244cc793d511b86adea24972f3a7264cae114 upstream.
Adjust the console layer to allow a take over call where the caller
already holds the locks. Make the fb layer lock in order.
This is partly a band aid, the fb layer is terminally confused about the
locking rules it uses for its notifiers it seems.
[akpm@linux-foundation.org: remove stray non-ascii char, tidy comment]
[akpm@linux-foundation.org: export do_take_over_console()]
[airlied: cleanup another non-ascii char]
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 2a2483072393b27f4336ab068a1f48ca19ff1c1e upstream.
When we switch from 256->512 byte font rendering mode, it means the
current contents of the screen is being reinterpreted. The bit that holds
the high bit of the 9-bit font, may have been previously set, and thus
the new font misrenders.
The problem case we see is grub2 writes spaces with the bit set, so it
ends up with data like 0x820, which gets reinterpreted into 0x120 char
which the font translates into G with a circumflex. This flashes up on
screen at boot and is quite ugly.
A current side effect of this patch though is that any rendering on the
screen changes color to a slightly darker color, but at least the screen
no longer corrupts.
v2: as suggested by hpa, always clear the attribute space, whether we
are are going to or from 512 chars.
commit b531f81b0d70ffbe8d70500512483227cc532608 upstream.
Commit 99fc86450c439039d2ef88d06b222fd51a779176 "ALSA: usb-mixer:
parse descriptors with structs" introduced a set of useful parsers
for descriptors. Unfortunately the parses for the Processing Unit
Descriptor came with a very subtle bug...
Functions uac_processing_unit_iProcessing() and
uac_processing_unit_specific() were indexing the baSourceID array
forgetting the fields before the iProcessing and process-specific
descriptors.
The problem was observed with Sound Blaster Extigy mixer,
where nNrModes in Up/Down-mix Processing Unit Descriptor
was accessed at offset 10 of the descriptor (value 0)
instead of offset 15 (value 7). In result the resulting
control had interesting limit values:
Simple mixer control 'Channel Routing Mode Select',0
Capabilities: volume volume-joined penum
Playback channels: Mono
Capture channels: Mono
Limits: 0 - -1
Mono: -1 [100%]
Fixed by starting from the bmControls, which was calculated
correctly, instead of baSourceID.
Now the mentioned control is fine:
Limits: 0 - 6
Mono: 0 [0%]
Signed-off-by: Pawel Moll <mail@pawelmoll.com>
commit 513b032c98b4b9414aa4e9b4a315cb1bf0380101 upstream.
The PPS serial line discipline wants to attach a PPS device to a tty
without changing the tty code to add a struct pps_device * pointer.
Since the number of PPS devices in a typical system is generally very low
(n=1 is by far the most common), it's practical to search the entire list
of allocated pps devices. (We capture the timestamp before the lookup,
so the timing isn't affected.)
It is a bit ugly that this function, which is part of the in-kernel
PPS API, has to be in pps.c as opposed to kapi,c, but that's not
something that affects users.
Signed-off-by: George Spelvin <linux@horizon.com>
Acked-by: Rodolfo Giometti <giometti@enneenne.com>
commit 85f024401bf80746ae08b7fd5809a9b16accf0b1 upstream.
It was mistakenly defined to be 24 instead of the next higher number 25.
Reported-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Stephen Hurd <shurd@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux into akpm
Pull hp parisc automounter fix from Helge Deller:
"This unbreaks automounter support for the parisc architecture (and
probably aarch64 as well).""
* 'autofs-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
unbreak automounter support on 64-bit kernel with 32-bit userspace (v2)
Pull networking fixes from David Miller:
1) Revert iwlwifi reclaimed packet tracking, it causes problems for a
bunch of folks. From Emmanuel Grumbach.
2) Work limiting code in brcmsmac wifi driver can clear tx status
without processing the event. From Arend van Spriel.
3) rtlwifi USB driver processes wrong SKB, fix from Larry Finger.
4) l2tp tunnel delete can race with close, fix from Tom Parkin.
5) pktgen_add_device() failures are not checked at all, fix from Cong
Wang.
6) Fix unintentional removal of carrier off from tun_detach(),
otherwise we confuse userspace, from Michael S. Tsirkin.
7) Don't leak socket reference counts and ubufs in vhost-net driver,
from Jason Wang.
8) vmxnet3 driver gets it's initial carrier state wrong, fix from Neil
Horman.
9) Protect against USB networking devices which spam the host with 0
length frames, from Bjørn Mork.
10) Prevent neighbour overflows in ipv6 for locally destined routes,
from Marcelo Ricardo. This is the best short-term fix for this, a
longer term fix has been implemented in net-next.
11) L2TP uses ipv4 datagram routines in it's ipv6 code, whoops. This
mistake is largely because the ipv6 functions don't even have some
kind of prefix in their names to suggest they are ipv6 specific.
From Tom Parkin.
12) Check SYN packet drops properly in tcp_rcv_fastopen_synack(), from
Yuchung Cheng.
13) Fix races and TX skb freeing bugs in via-rhine's NAPI support, from
Francois Romieu and your's truly.
14) Fix infinite loops and divides by zero in TCP congestion window
handling, from Eric Dumazet, Neal Cardwell, and Ilpo Järvinen.
15) AF_PACKET tx ring handling can leak kernel memory to userspace, fix
from Phil Sutter.
16) Fix error handling in ipv6 GRE tunnel transmit, from Tommi Rantala.
17) Protect XEN netback driver against hostile frontend putting garbage
into the rings, don't leak pages in TX GOP checking, and add proper
resource releasing in error path of xen_netbk_get_requests(). From
Ian Campbell.
18) SCTP authentication keys should be cleared out and released with
kzfree(), from Daniel Borkmann.
19) L2TP is a bit too clever trying to maintain skb->truesize, and ends
up corrupting socket memory accounting to the point where packet
sending is halted indefinitely. Just remove the adjustments
entirely, they aren't really needed. From Eric Dumazet.
20) ATM Iphase driver uses a data type with the same name as the S390
headers, rename to fix the build. From Heiko Carstens.
21) Fix a typo in copying the inner network header offset from one SKB
to another, from Pravin B Shelar.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (56 commits)
net: sctp: sctp_endpoint_free: zero out secret key data
net: sctp: sctp_setsockopt_auth_key: use kzfree instead of kfree
atm/iphase: rename fregt_t -> ffreg_t
net: usb: fix regression from FLAG_NOARP code
l2tp: dont play with skb->truesize
net: sctp: sctp_auth_key_put: use kzfree instead of kfree
netback: correct netbk_tx_err to handle wrap around.
xen/netback: free already allocated memory on failure in xen_netbk_get_requests
xen/netback: don't leak pages on failure in xen_netbk_tx_check_gop.
xen/netback: shutdown the ring if it contains garbage.
net: qmi_wwan: add more Huawei devices, including E320
net: cdc_ncm: add another Huawei vendor specific device
ipv6/ip6_gre: fix error case handling in ip6gre_tunnel_xmit()
tcp: fix for zero packets_in_flight was too broad
brcmsmac: rework of mac80211 .flush() callback operation
ssb: unregister gpios before unloading ssb
bcma: unregister gpios before unloading bcma
rtlwifi: Fix scheduling while atomic bug
net: usbnet: fix tx_dropped statistics
tcp: ipv6: Update MIB counters for drops
automount-support is broken on the parisc architecture, because the existing
#if list does not include a check for defined(__hppa__). The HPPA (parisc)
architecture is similiar to other 64bit Linux targets where we have to define
autofs_wqt_t (which is passed back and forth to user space) as int type which
has a size of 32bit across 32 and 64bit kernels.
During the discussion on the mailing list, H. Peter Anvin suggested to invert
the #if list since only specific platforms (specifically those who do not have
a 32bit userspace, like IA64 and Alpha) should have autofs_wqt_t as unsigned
long type.
This suggestion is probably the best way to go, since Arm64 (and maybe others?)
seems to have a non-working automounter. So in the long run even for other new
upcoming architectures this inverted check seem to be the best solution, since
it will not require them to change this #if again (unless they are 64bit only).
Signed-off-by: Helge Deller <deller@gmx.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Ian Kent <raven@themaw.net>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
CC: James Bottomley <James.Bottomley@HansenPartnership.com>
CC: Rolf Eike Beer <eike-kernel@sf-tec.de>
In commit 6509141f9c2ba74df6cc72ec35cd1865276ae3a4 ("usbnet: add new
flag FLAG_NOARP for usb net devices"), the newly added flag NOARP was
using an already defined value, which broke drivers using flag
MULTI_PACKET.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Pull block layer updates from Jens Axboe:
"I've got a few bits pending for 3.8 final, that I better get sent out.
It's all been sitting for a while, I consider it safe.
It contains:
- Two bug fixes for mtip32xx, fixing a driver hang and a crash.
- A few-liner protocol error fix for drbd.
- A few fixes for the xen block front/back driver, fixing a potential
data corruption issue.
- A race fix for disk_clear_events(), causing spurious warnings. Out
of the Chrome OS base.
- A deadlock fix for disk_clear_events(), moving it to the a
unfreezable workqueue. Also from the Chrome OS base."
* 'for-linus' of git://git.kernel.dk/linux-block:
drbd: fix potential protocol error and resulting disconnect/reconnect
mtip32xx: fix for crash when the device surprise removed during rebuild
mtip32xx: fix for driver hang after a command timeout
block: prevent race/cleanup
block: remove deadlock in disk_clear_events
xen-blkfront: handle bvecs with partial data
llist/xen-blkfront: implement safe version of llist_for_each_entry
xen-blkback: implement safe iterator for the list of persistent grants
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg Kroah-Hartman:
"Here are a few tiny USB fixes for 3.8-rc6.
Nothing major here, some host controller bug fixes to resolve a number
of bugs that people have reported, and a bunch of additional device
ids are added to a number of drivers (which caused code to be deleted
from the usb-storage driver, always nice)"
* tag 'usb-3.8-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (22 commits)
USB: storage: optimize to match the Huawei USB storage devices and support new switch command
USB: storage: Define a new macro for USB storage match rules
USB: ftdi_sio: add Zolix FTDI PID
USB: option: add Changhong CH690
USB: ftdi_sio: add PID/VID entries for ELV WS 300 PC II
USB: add OWL CM-160 support to cp210x driver
USB: EHCI: fix bug in scheduling periodic split transfers
USB: EHCI: fix for leaking isochronous data
USB: option: add support for Telit LE920
USB: qcserial: add Telit Gobi QDL device
USB: EHCI: fix timer bug affecting port resume
USB: UHCI: notify usbcore about port resumes
USB: EHCI: notify usbcore about port resumes
USB: add usb_hcd_{start,end}_port_resume
USB: EHCI: unlink one async QH at a time
USB: EHCI: remove ASS/PSS polling timeout
usb: Using correct way to clear usb3.0 device's remote wakeup feature.
usb: Prevent dead ports when xhci is not enabled
USB: XHCI: fix memory leak of URB-private data
drivers: xhci: fix incorrect bit test
The macro for_each_memcg_cache_index contains a silly yet potentially
deadly mistake. Although the macro parameter is _idx, the loop tests
are done over i, not _idx.
This hasn't generated any problems so far, because all users use i as a
loop index. However, while playing with an extension of the code I
ended using another loop index and the compiler was quick to complain.
Unfortunately, this is not the kind of thing that testing reveals =(
Signed-off-by: Glauber Costa <glommer@parallels.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
We use rwsem since commit 5a505085f043 ("mm/rmap: Convert the struct
anon_vma::mutex to an rwsem"). And most of comments are converted to
the new rwsem lock; while just 2 more missed from:
$ git grep 'anon_vma->mutex'
Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
The datagram_*_ctl functions in net/ipv6/datagram.c are IPv6-specific. Since
datagram_send_ctl is publicly exported it should be appropriately named to
reflect the fact that it's for IPv6 only.
Signed-off-by: Tom Parkin <tparkin@katalix.com>
Signed-off-by: James Chapman <jchapman@katalix.com>
Pull x86 fixes from Peter Anvin:
"This is a collection of miscellaneous fixes, the most important one is
the fix for the Samsung laptop bricking issue (auto-blacklisting the
samsung-laptop driver); the efi_enabled() changes you see below are
prerequisites for that fix.
The other issues fixed are booting on OLPC XO-1.5, an UV fix, NMI
debugging, and requiring CAP_SYS_RAWIO for MSR references, just as
with I/O port references."
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
samsung-laptop: Disable on EFI hardware
efi: Make 'efi_enabled' a function to query EFI facilities
smp: Fix SMP function call empty cpu mask race
x86/msr: Add capabilities check
x86/dma-debug: Bump PREALLOC_DMA_DEBUG_ENTRIES
x86/olpc: Fix olpc-xo1-sci.c build errors
arch/x86/platform/uv: Fix incorrect tlb flush all issue
x86-64: Fix unwind annotations in recent NMI changes
x86-32: Start out cr0 clean, disable paging before modifying cr3/4
A device sending 0 length frames as fast as it can has been
observed killing the host system due to the resulting memory
pressure.
Temporarily disable RX skb allocation and URB submission when
the current error ratio is high, preventing us from trying to
allocate an infinite number of skbs. Reenable as soon as we
are finished processing the done queue, allowing the device
to continue working after short error bursts.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Acked-by: Oliver Neukum <oneukum@suse.de>
Originally 'efi_enabled' indicated whether a kernel was booted from
EFI firmware. Over time its semantics have changed, and it now
indicates whether or not we are booted on an EFI machine with
bit-native firmware, e.g. 64-bit kernel with 64-bit firmware.
The immediate motivation for this patch is the bug report at,
https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557
which details how running a platform driver on an EFI machine that is
designed to run under BIOS can cause the machine to become
bricked. Also, the following report,
https://bugzilla.kernel.org/show_bug.cgi?id=47121
details how running said driver can also cause Machine Check
Exceptions. Drivers need a new means of detecting whether they're
running on an EFI machine, as sadly the expression,
if (!efi_enabled)
hasn't been a sufficient condition for quite some time.
Users actually want to query 'efi_enabled' for different reasons -
what they really want access to is the list of available EFI
facilities.
For instance, the x86 reboot code needs to know whether it can invoke
the ResetSystem() function provided by the EFI runtime services, while
the ACPI OSL code wants to know whether the EFI config tables were
mapped successfully. There are also checks in some of the platform
driver code to simply see if they're running on an EFI machine (which
would make it a bad idea to do BIOS-y things).
This patch is a prereq for the samsung-laptop fix patch.
Cc: David Airlie <airlied@linux.ie>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Peter Jones <pjones@redhat.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Steve Langasek <steve.langasek@canonical.com>
Cc: Konrad Rzeszutek Wilk <konrad@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: <stable@vger.kernel.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFD fixes from Samuel Ortiz:
"This is the first pull request for MFD fixes for 3.8
We have some build failure fixes (twl4030, vexpress, abx500 and
tps65910), some actual runtime oops and lockup fixes (rtsx, da9052),
and some more hypothetical NULL pointers dereferences fixes for
pcf50633 and max776xx.
Then we also have additional rtsx fixes for a correct switch output
voltage and clock divider correctness for rtl8411 (rtsx driver), and
irqdomain fix for db8550-prcmu, and some more cosmetic fixes for
arizona and wm5102."
* tag 'mfd-for-linus-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6:
mfd: rtsx: Fix oops when rtsx_pci_sdmmc is not probed
mfd: wm5102: Fix definition of WM5102_MAX_REGISTER
mfd: twl4030: Don't warn about uninitialized return code
mfd: da9052/53 lockup fix
mfd: rtsx: Add clock divider hook
mmc: rtsx: Call MFD hook to switch output voltage
mfd: rtsx: Add output voltage switch hook
mfd: Fix compile errors and warnings when !CONFIG_AB8500_BM
mfd: vexpress: Export global functions to fix build error
mfd: arizona: Check errors from regcache_sync()
mfd: tc3589x: Use simple irqdomain
mfd: pcf50633: Init pcf->dev before using it
mfd: max77693: Init max77693->dev before using it
mfd: max77686: Init max77686->dev before using it
mfd: db8500-prcmu: Fix irqdomain usage
mfd: tps65910: Select REGMAP_IRQ in Kconfig to fix build error
mfd: arizona: Disable control interface reporting for WM5102 and WM5110
Pull networking updates from David Miller:
"Much more accumulated than I would have liked due to an unexpected
bout with a nasty flu:
1) AH and ESP input don't set ECN field correctly because the
transport head of the SKB isn't set correctly, fix from Li
RongQing.
2) If netfilter conntrack zones are disabled, we can return an
uninitialized variable instead of the proper error code. Fix from
Borislav Petkov.
3) Fix double SKB free in ath9k driver beacon handling, from Felix
Feitkau.
4) Remove bogus assumption about netns cleanup ordering in
nf_conntrack, from Pablo Neira Ayuso.
5) Remove a bogus BUG_ON in the new TCP fastopen code, from Eric
Dumazet. It uses spin_is_locked() in it's test and is therefore
unsuitable for UP.
6) Fix SELINUX labelling regressions added by the tuntap multiqueue
changes, from Paul Moore.
7) Fix CRC errors with jumbo frame receive in tg3 driver, from Nithin
Nayak Sujir.
8) CXGB4 driver sets interrupt coalescing parameters only on first
queue, rather than all of them. Fix from Thadeu Lima de Souza
Cascardo.
9) Fix regression in the dispatch of read/write registers in dm9601
driver, from Tushar Behera.
10) ipv6_append_data miscalculates header length, from Romain KUNTZ.
11) Fix PMTU handling regressions on ipv4 routes, from Steffen
Klassert, Timo Teräs, and Julian Anastasov.
12) In 3c574_cs driver, add necessary parenthesis to "x << y & z"
expression. From Nickolai Zeldovich.
13) macvlan_get_size() causes underallocation netlink message space,
fix from Eric Dumazet.
14) Avoid division by zero in xfrm_replay_advance_bmp(), from Nickolai
Zeldovich. Amusingly the zero check was already there, we were
just performing it after the modulus :-)
15) Some more splice bug fixes from Eric Dumazet, which fix things
mostly eminating from how we now more aggressively use high-order
pages in SKBs.
16) Fix size calculation bug when freeing hash tables in the IPSEC
xfrm code, from Michal Kubecek.
17) Fix PMTU event propagation into socket cached routes, from Steffen
Klassert.
18) Fix off by one in TX buffer release in netxen driver, from Eric
Dumazet.
19) Fix rediculous memory allocation requirements introduced by the
tuntap multiqueue changes, from Jason Wang.
20) Remove bogus AMD platform workaround in r8169 driver that causes
major problems in normal operation, from Timo Teräs.
21) virtio-net set affinity and select queue don't handle
discontiguous cpu numbers properly, fix from Wanlong Gao.
22) Fix a route refcounting issue in loopback driver, from Eric
Dumazet. There's a similar fix coming that we might add to the
macvlan driver as well.
23) Fix SKB leaks in batman-adv's distributed arp table code, from
Matthias Schiffer.
24) r8169 driver gives descriptor ownership back the hardware before
we're done reading the VLAN tag out of it, fix from Francois
Romieu.
25) Checksums not calculated properly in GRE tunnel driver fix from
Pravin B Shelar.
26) Fix SCTP memory leak on namespace exit."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (101 commits)
dm9601: support dm9620 variant
SCTP: Free the per-net sysctl table on net exit. v2
net: phy: icplus: fix broken INTR pin settings
net: phy: icplus: Use the RGMII interface mode to configure clock delays
IP_GRE: Fix kernel panic in IP_GRE with GRE csum.
sctp: set association state to established in dupcook_a handler
ip6mr: limit IPv6 MRT_TABLE identifiers
r8169: fix vlan tag read ordering.
net: cdc_ncm: use IAD provided by the USB core
batman-adv: filter ARP packets with invalid MAC addresses in DAT
batman-adv: check for more types of invalid IP addresses in DAT
batman-adv: fix skb leak in batadv_dat_snoop_incoming_arp_reply()
net: loopback: fix a dst refcounting issue
virtio-net: reset virtqueue affinity when doing cpu hotplug
virtio-net: split out clean affinity function
virtio-net: fix the set affinity bug when CPU IDs are not consecutive
can: pch_can: fix invalid error codes
can: ti_hecc: fix invalid error codes
can: c_can: fix invalid error codes
r8169: remove the obsolete and incorrect AMD workaround
An issue has been reported where the PMIC either locks up or fails to
respond following a system Reset. This could result in a second write
in which the bus writes the current content of the write buffer to address
of the last I2C access.
The failure case is where this unwanted write transfers incorrect data to
a critical register.
This patch fixes this issue to by following any read or write with a dummy read
to a safe register address. A safe register address is one where the contents
will not affect the operation of the system.
Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com>
Add callback function conv_clk_and_div_n to convert between SSC clock
and its divider N.
For rtl8411, the formula to calculate SSC clock divider N is different
with the other card reader models.
Signed-off-by: Wei WANG <wei_wang@realsil.com.cn>
Different card reader has different method to switch output voltage,
add this callback to let the card reader implement its individual switch
function.
This is needed as rtl8411 has a specific switch output voltage procedure.
This patch (as1649) adds a mechanism for host controller drivers to
inform usbcore when they have begun or ended resume signalling on a
particular root-hub port. The core will then make sure that the root
hub does not get runtime-suspended while the port resume is going on.
Since commit 596d789a211d134dc5f94d1e5957248c204ef850 (USB: set hub's
default autosuspend delay as 0), the system tries to suspend hubs
whenever they aren't in use. While a root-hub port is being resumed,
the root hub does not appear to be in use. Attempted runtime suspends
fail because of the ongoing port resume, but the PM core just keeps on
trying over and over again. We want to prevent this wasteful effort.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Ming Lei <ming.lei@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sarah/xhci into usb-linus
Sarah writes:
USB/xhci: Misc fixes for 3.8.
Hi Greg,
Here's six patches for xHCI and the USB core. There's a couple of
patches to fix xHCI 1.0 field formats, some memory leaks, dead ports,
and USB 3.0 remote wakeup disabling.
All of these are marked for stable.
I know I owe you some re-works of failed stable patches from my last
patchset round, but I don't think I'm going to get to them before I head
off to Linux Conf Australia tomorrow.
Sarah Sharp
Pull ARM SoC fixes from Olof Johansson:
"Here's a long-pending fixes pull request for arm-soc (I didn't send
one in the -rc4 cycle).
The larger deltas are from:
- A fixup of error paths in the mvsdio driver
- Header file move for a driver that hadn't been properly converted
to multiplatform on i.MX, which was causing build failures when
included
- Device tree updates for at91 dealing mostly with their new pinctrl
setup merged in 3.8 and mistakes in those initial configs
The rest are the normal mix of small fixes all over the place; sunxi,
omap, imx, mvebu, etc, etc."
* tag 'fixes-for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
mfd: vexpress-sysreg: Don't skip initialization on probe
ARM: vexpress: Enable A7 cores in V2P-CA15_A7's Device Tree
ARM: vexpress: extend the MPIDR range used for pen release check
ARM: at91/dts: correct comment in at91sam9x5.dtsi for mii
ARM: at91/at91_dt_defconfig: add at91sam9n12 SoC to DT defconfig
ARM: at91/at91_dt_defconfig: remove memory specification to cmdline
ARM: at91/dts: add macb mii pinctrl config for kizbox
ARM: at91: rm9200: remake the BGA as default version
ARM: at91: fix gpios on i2c-gpio for RM9200 DT
ARM: at91/at91sam9x5 DTS: add SCK USART pins
ARM: at91/at91sam9x5 DTS: correct wrong PIO BANK values on u(s)arts
ARM: at91/at91-pinctrl documentation: fix typo and add some details
ARM: kirkwood: fix missing #interrupt-cells property
mmc: mvsdio: use devm_ API to simplify/correct error paths.
clk: mvebu/clk-cpu.c: fix memory leakage
ARM: OMAP2+: omap4-panda: add UART2 muxing for WiLink shared transport
ARM: OMAP2+: DT node Timer iteration fix
ARM: OMAP2+: Fix section warning for omap_init_ocp2scp()
ARM: OMAP2+: fix build break for omapdrm
ARM: OMAP2: Fix missing omap2xxx_clkt_vps_late_init function calls
Usb3.0 device defines function remote wakeup which is only for interface
recipient rather than device recipient. This is different with usb2.0 device's
remote wakeup feature which is defined for device recipient. According usb3.0
spec 9.4.5, the function remote wakeup can be modified by the SetFeature()
requests using the FUNCTION_SUSPEND feature selector. This patch is to use
correct way to disable usb3.0 device's function remote wakeup after suspend
error and resuming.
This should be backported to kernels as old as 3.4, that contain the
commit 623bef9e03a60adc623b09673297ca7a1cdfb367 "USB/xhci: Enable remote
wakeup for USB3 devices."
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k fixes from Geert Uytterhoeven:
"The asm-generic changeset has been ack'ed by Arnd."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: Wire up finit_module
asm-generic/dma-mapping-broken.h: Provide dma_alloc_attrs()/dma_free_attrs()
m68k: Provide dma_alloc_attrs()/dma_free_attrs()
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
From Tony Lindgren:
Minimal omap fixes for the -rc series:
- A build fix for recently merged omap DRM changes
- Regression fixes from the common clock framework conversion
for omap4 audio and omap2 reboot
- Regression fix for pandaboard WLAN control UART muxing caused by
u-boot only muxing essential pins nowadays
- Timer iteration fix for CONFIG_OF_DYNAMIC
- A section mismatch fix for ocp2scp init
* tag 'omap-for-v3.8-rc4/fixes-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (306 commits)
ARM: OMAP4: hwmod_data: Correct IDLEMODE for McPDM
ARM: OMAP4: clock data: Lock ABE DPLL on all revisions
+ Linux 3.8-rc4
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
Pull libata fixes from Jeff Garzik:
1) ahci: Fix typo that caused erronenous error handling.
Thought: I wonder if sparse could have caught this, somehow.
2) ahci: support a slightly odd Enmotus variant
3) core: fix a drive detection problem by correcting the logic by which
the DevSlp timing variables are obtained and used.
* tag 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
[libata] replace sata_settings with devslp_timing
[libata] ahci: Add support for Enmotus Bobcat device.
[libata] ahci: Fix lack of command retry after a success error handler.
Cleanup and preparation for the next change.
signal_wake_up(resume => true) is overused. None of ptrace/jctl callers
actually want to wakeup a TASK_WAKEKILL task, but they can't specify the
necessary mask.
Turn signal_wake_up() into signal_wake_up_state(state), reintroduce
signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up()
which adds __TASK_TRACED.
This way ptrace_signal_wake_up() can work "inside" ptrace_request()
even if the tracee doesn't have the TASK_WAKEKILL bit set.
drivers/mfd/ab8500-core.c:1015:21: error: ‘ab8500_bm_data’ undeclared here
include/linux/mfd/abx500/ab8500-bm.h:445:13: warning: ‘ab8500_fg_reinit’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:448:13: warning: ‘ab8500_charger_usb_state_changed’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:451:29: warning: ‘ab8500_btemp_get’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:455:12: warning: ‘ab8500_btemp_get_batctrl_temp’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:463:12: warning: ‘ab8500_fg_inst_curr_blocking’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:442:12: warning: ‘ab8500_fg_inst_curr_done’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:447:26: warning: ‘ab8500_fg_get’ defined but not used
Signed-off-by: Lee Jones <lee.jones@linaro.org>
fixes
From Sascha Hauer:
ARM i.MX fixes for -rc.
This contains a single compilation fix for the CODA driver.
* tag 'imx-fixes-rc' of git://git.pengutronix.de/git/imx/linux-2.6:
[media] coda: Fix build due to iram.h rename
We do have some USB net devices, which cannot do ARP.
so we can introduce a new flag FLAG_NOARP, then client drivers
can easily handle this kind of devices
Signed-off-by: Wei Shuai <cpuwolf@gmail.com>
This implements a socket release callback function to check
if the socket cached route got invalid during the time
we owned the socket. The function is used from udp, raw
and ping sockets.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module fixes and a virtio block fix from Rusty Russell:
"Various minor fixes, but a slightly more complex one to fix the
per-cpu overload problem introduced recently by kvm id changes."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
module: put modules in list much earlier.
module: add new state MODULE_STATE_UNFORMED.
module: prevent warning when finit_module a 0 sized file
virtio-blk: Don't free ida when disk is in use
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull misc syscall fixes from Al Viro:
- compat syscall fixes (discussed back in December)
- a couple of "make life easier for sigaltstack stuff by reducing
inter-tree dependencies"
- fix up compiler/asmlinkage calling convention disagreement of
sys_clone()
- misc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
sys_clone() needs asmlinkage_protect
make sure that /linuxrc has std{in,out,err}
x32: fix sigtimedwait
x32: fix waitid()
switch compat_sys_wait4() and compat_sys_waitid() to COMPAT_SYSCALL_DEFINE
switch compat_sys_sigaltstack() to COMPAT_SYSCALL_DEFINE
CONFIG_GENERIC_SIGALTSTACK build breakage with asm-generic/syscalls.h
Ensure that kernel_init_freeable() is not inlined into non __init code
The ia64 function "thread_matches()" has no users since commit
e868a55c2a8c ("[IA64] remove find_thread_for_addr()"). Remove it.
This allows us to make ptrace_check_attach() static to kernel/ptrace.c,
which is good since we'll need to change the semantics of it and fix up
all the callers.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg Kroah-Hartman:
"Here are a few tty/serial driver fixes for 3.8-rc4 that resolve a
number of problems that people have been having, including the ptys
ioctl issue that is a regression fix"
* tag 'tty-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
8250/16?50: Add support for Broadcom TruManage redirected serial port
pty: return EINVAL for TIOCGPTN for BSD ptys
serial:ifx6x60:Keep word size accordance with SPI controller
tty: 8250_dw: Fix inverted arguments to serial_out in IRQ handler
serial: samsung: remove redundant setting of line config during port reset
serial:ifx6x60:Delete SPI timer when shut down port
tty/8250: The correct device id for this card is 0x0022
tty/8250: pbn_b0_8_1152000_200 is supposed to be an 8 port definition
tty: serial: vt8500: fix return value check in vt8500_serial_probe()
serial: mxs-auart: Index is unsigned
mxs: uart: fix setting RTS from software
Commit 816422ad7647 ("asm-generic, mm: pgtable: consolidate zero page
helpers") broke the compile on MIPS if SPARSEMEM is enabled. We get
this:
In file included from arch/mips/include/asm/pgtable.h:552,
from include/linux/mm.h:44,
from arch/mips/kernel/asm-offsets.c:14:
include/asm-generic/pgtable.h: In function 'my_zero_pfn':
include/asm-generic/pgtable.h:466: error: implicit declaration of function 'page_to_section'
In file included from arch/mips/kernel/asm-offsets.c:14:
include/linux/mm.h: At top level:
include/linux/mm.h:738: error: conflicting types for 'page_to_section'
include/asm-generic/pgtable.h:466: note: previous implicit declaration of 'page_to_section' was here
Due header files inter-dependencies, the only way I see to fix it is
convert my_zero_pfn() for __HAVE_COLOR_ZERO_PAGE to macros.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: David Daney <david.daney@cavium.com>
Add support for the UART device present in Broadcom TruManage capable
NetXtreme chips (ie: 5761m 5762, and 5725).
This implementation has a hidden transmit FIFO, so running in single-byte
interrupt mode results in too many interrupts. The UART_CAP_HFIFO
capability was added to track this. It continues to reload the THR as long
as the THRE and TSRE bits are set in the LSR up to a specified limit (1024
is used here).
Signed-off-by: Stephen Hurd <shurd@broadcom.com>
Cc: stable <stable@vger.kernel.org>
Pull ACPI and power management fixes from Rafael Wysocki:
- cpuidle regression fix related to the initialization of state
kobjects from Krzysztof Mazur.
- cpuidle fix removing some not very useful code and making some
user-visible problems go away at the same time. From Daniel Lezcano.
- ACPI build fix from Yinghai Lu.
* tag 'pm+acpi-for-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpuidle: remove the power_specified field in the driver
ACPI / glue: Fix build with ACPI_GLUE_DEBUG set
cpuidle: fix number of initialized/destroyed states
