path: root/include
2013-05-25Merge tag 'pm+acpi-3.10-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: - Additional CPU ID for the intel_pstate driver from Dirk Brandewie. - More cpufreq fixes related to ARM big.LITTLE support and locking from Viresh Kumar. - VIA C7 cpufreq build fix from Rafał Bilski. - ACPI power management fix making it possible to use device power states regardless of the CONFIG_PM setting from Rafael J Wysocki. - New ACPI video blacklist item from Bastian Triller. * tag 'pm+acpi-3.10-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / video: Add "Asus UL30A" to ACPI video detect blacklist cpufreq: arm_big_little_dt: Instantiate as platform_driver cpufreq: arm_big_little_dt: Register driver only if DT has valid data cpufreq / e_powersaver: Fix linker error when ACPI processor is a module cpufreq / intel_pstate: Add additional supported CPU ID cpufreq: Drop rwsem lock around CPUFREQ_GOV_POLICY_EXIT ACPI / PM: Allow device power states to be used for CONFIG_PM unset
2013-05-25Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dma fixes from Vinod Koul: "We have two patches from Andy & Rafael fixing the Lynxpoint dma" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: ACPI / LPSS: register clock device for Lynxpoint DMA properly dma: acpi-dma: parse CSRT to extract additional resources
2013-05-24Merge branch 'akpm' (incoming from Andrew Morton)Linus Torvalds
Merge fixes from Andrew Morton: "A bunch of fixes and one simple fbdev driver which missed the merge window because people will still talking about it (to no great effect)." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (30 commits) aio: fix kioctx not being freed after cancellation at exit time mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas drivers/rtc/rtc-max8998.c: check for pdata presence before dereferencing ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap() random: fix accounting race condition with lockless irq entropy_count update drivers/char/random.c: fix priming of last_data mm/memory_hotplug.c: fix printk format warnings nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundary drivers/block/brd.c: fix brd_lookup_page() race fbdev: FB_GOLDFISH should depend on HAS_DMA drivers/rtc/rtc-pl031.c: pass correct pointer to free_irq() auditfilter.c: fix kernel-doc warnings aio: fix io_getevents documentation revert "selftest: add simple test for soft-dirty bit" drivers/leds/leds-ot200.c: fix error caused by shifted mask mm/THP: use pmd_populate() to update the pmd with pgtable_t pointer linux/kernel.h: fix kernel-doc warning mm compaction: fix of improper cache flush in migration code rapidio/tsi721: fix bug in MSI interrupt handling hfs: avoid crash in hfs_bnode_create ...
2013-05-24Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "We didn't have any fixes sent up for -rc2, so this is a slightly larger batch. A bit all over the place platform-wise; OMAP, at91, marvell, renesas, sunxi, ux500, etc. I tried to summarize highlights but there isn't a whole lot to point out. Lots of little things fixed all over. A couple of defconfig updates due to new/changing options." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (44 commits) ARM: at91/sama5: fix incorrect PMC pcr div definition ARM: at91/dt: fix macb pinctrl_macb_rmii_mii_alt definition ARM: at91: at91sam9n12: move external irq declatation to DT ARM: shmobile: marzen: Use error values in usb_power_* ARM: tegra: defconfig fixes ARM: nomadik: fix IRQ assignment for SMC ethernet ARM: vt8500: Add missing NULL terminator in dt_compat clk: tegra: add ac97 controller clock clk: tegra: remove USB from clk init table ARM: dts: mvebu: Fix wrong the address reg value for the L2-cache node ARM: plat-orion: Fix num_resources and id for ge10 and ge11 ARM: OMAP2+: hwmod: Remove sysc slave idle and auto idle apis SERIAL: OMAP: Remove the slave idle handling from the driver ARM: OMAP2+: serial: Remove the un-used slave idle hooks ARM: OMAP2+: hwmod-data: UART IP needs software control to manage sidle modes ARM: OMAP2+: hwmod: Add a new flag to handle SIDLE in SWSUP only in active ARM: OMAP2+: hwmod: Fix sidle programming in _enable_sysc()/_idle_sysc() arm: mvebu: fix the 'ranges' property to handle PCIe ARM: mvebu: select ARCH_REQUIRE_GPIOLIB for mvebu platform ARM: AM33XX: Add missing .clkdm_name to clkdiv32k_ick clock ...
2013-05-24linux/kernel.h: fix kernel-doc warningRandy Dunlap
Fix kernel-doc warning in <linux/kernel.h>: Warning(include/linux/kernel.h:590): No description found for parameter 'ip' scripts/kernel-doc cannot handle macros, functions, or function prototypes between the function or macro that is being documented and its definition, so move these prototypes above the function that is being documented. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24wait: fix false timeouts when using wait_event_timeout()Imre Deak
Many callers of the wait_event_timeout() and wait_event_interruptible_timeout() expect that the return value will be positive if the specified condition becomes true before the timeout elapses. However, at the moment this isn't guaranteed. If the wake-up handler is delayed enough, the time remaining until timeout will be calculated as 0 - and passed back as a return value - even if the condition became true before the timeout has passed. Fix this by returning at least 1 if the condition becomes true. This semantic is in line with what wait_for_condition_timeout() does; see commit bb10ed09 ("sched: fix wait_for_completion_timeout() spurious failure under heavy load"). Daniel said "We have 3 instances of this bug in drm/i915. One case even where we switch between the interruptible and not interruptible wait_event_timeout variants, foolishly presuming they have the same semantics. I very much like this." One such bug is reported at https://bugs.freedesktop.org/show_bug.cgi?id=64133 Signed-off-by: Imre Deak <imre.deak@intel.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Dave Jones <davej@redhat.com> Cc: Lukas Czerner <lczerner@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24rapidio: add enumeration/discovery start from user spaceAlexandre Bounine
Add RapidIO enumeration/discovery start from user space. User space start allows to defer RapidIO fabric scan until the moment when all participating endpoints are initialized avoiding mandatory synchronized start of all endpoints (which may be challenging in systems with large number of RapidIO endpoints). Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24rapidio: make enumeration/discovery configurableAlexandre Bounine
Systems that use RapidIO fabric may need to implement their own enumeration and discovery methods which are better suitable for needs of a target application. The following set of patches is intended to simplify process of introduction of new RapidIO fabric enumeration/discovery methods. The first patch offers ability to add new RapidIO enumeration/discovery methods using kernel configuration options. This new configuration option mechanism allows to select statically linked or modular enumeration/discovery method(s) from the list of existing methods or use external module(s). This patch also updates the currently existing enumeration/discovery code to be used as a statically linked or modular method. The corresponding configuration option is named "Basic enumeration/discovery" method. This is the only one configuration option available today but new methods are expected to be introduced after adoption of provided patches. The second patch address a long time complaint of RapidIO subsystem users regarding fabric enumeration/discovery start sequence. Existing implementation offers only a boot-time enumeration/discovery start which requires synchronized boot of all endpoints in RapidIO network. While it works for small closed configurations with limited number of endpoints, using this approach in systems with large number of endpoints is quite challenging. To eliminate requirement for synchronized start the second patch introduces RapidIO enumeration/discovery start from user space. For compatibility with the existing RapidIO subsystem implementation, automatic boot time enumeration/discovery start can be configured in by specifying "rio-scan.scan=1" command line parameter if statically linked basic enumeration method is selected. This patch: Rework to implement RapidIO enumeration/discovery method selection combined with ability to use enumeration/discovery as a kernel module. This patch adds ability to introduce new RapidIO enumeration/discovery methods using kernel configuration options. Configuration option mechanism allows to select statically linked or modular enumeration/discovery method from the list of existing methods or use external modules. If a modular enumeration/discovery is selected each RapidIO mport device can have its own method attached to it. The existing enumeration/discovery code was updated to be used as statically linked or modular method. This configuration option is named "Basic enumeration/discovery" method. Several common routines have been moved from rio-scan.c to make them available to other enumeration methods and reduce number of exported symbols. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "It's been a while since my last pull request so quite a few fixes have piled up." Indeed. 1) Fix nf_{log,queue} compilation with PROC_FS disabled, from Pablo Neira Ayuso. 2) Fix data corruption on some tg3 chips with TSO enabled, from Michael Chan. 3) Fix double insertion of VLAN tags in be2net driver, from Sarveshwar Bandi. 4) Don't have TCP's MD5 support pass > PAGE_SIZE page offsets in scatter-gather entries into the crypto layer, the crypto layer can't handle that. From Eric Dumazet. 5) Fix lockdep splat in 802.1Q MRP code, also from Eric Dumazet. 6) Fix OOPS in netfilter log module when called from conntrack, from Hans Schillstrom. 7) FEC driver needs to use netif_tx_{lock,unlock}_bh() rather than the non-BH disabling variants. From Fabio Estevam. 8) TCP GSO can generate out-of-order packets, fix from Eric Dumazet. 9) vxlan driver doesn't update 'used' field of fdb entries when it should, from Sridhar Samudrala. 10) ipv6 should use kzalloc() to allocate inet6 socket cork options, otherwise we can OOPS in ip6_cork_release(). From Eric Dumazet. 11) Fix races in bonding set mode, from Nikolay Aleksandrov. 12) Fix checksum generation regression added by "r8169: fix 8168evl frame padding.", from Francois Romieu. 13) ip_gre can look at stale SKB data pointer, fix from Eric Dumazet. 14) Fix checksum handling when GSO is enabled in bnx2x driver with certain chips, from Yuval Mintz. 15) Fix double free in batman-adv, from Martin Hundebøll. 16) Fix device startup synchronization with firmware in tg3 driver, from Nithin Sujit. 17) perf networking dropmonitor doesn't work at all due to mixed up trace parameter ordering, from Ben Hutchings. 18) Fix proportional rate reduction handling in tcp_ack(), from Nandita Dukkipati. 19) IPSEC layer doesn't return an error when a valid state is detected, causing an OOPS. Fix from Timo Teräs. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (85 commits) be2net: bug fix on returning an invalid nic descriptor tcp: xps: fix reordering issues net: Revert unused variable changes. xfrm: properly handle invalid states as an error virtio_net: enable napi for all possible queues during open tcp: bug fix in proportional rate reduction. net: ethernet: sun: drop unused variable net: ethernet: korina: drop unused variable net: ethernet: apple: drop unused variable qmi_wwan: Added support for Cinterion's PLxx WWAN Interface perf: net_dropmonitor: Remove progress indicator perf: net_dropmonitor: Use bisection in symbol lookup perf: net_dropmonitor: Do not assume ordering of dictionaries perf: net_dropmonitor: Fix symbol-relative addresses perf: net_dropmonitor: Fix trace parameter order net: fec: use a more proper compatible string for MVF type device qlcnic: Fix updating netdev->features qlcnic: remove netdev->trans_start updates within the driver qlcnic: Return proper error codes from probe failure paths tg3: Update version to 3.132 ...
2013-05-23Merge tag 'pci-v3.10-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "Here are some more fixes for v3.10. The Moorestown update broke Intel Medfield devices, so I reverted it. The acpiphp change fixes a regression: we broke hotplug notifications to host bridges when we split acpiphp into the host-bridge related part and the endpoint-related part. Moorestown Revert "x86/pci/mrst: Use configuration mechanism 1 for 00:00.0, 00:02.0, 00:03.0" Hotplug PCI: acpiphp: Re-enumerate devices when host bridge receives Bus Check" * tag 'pci-v3.10-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: Revert "x86/pci/mrst: Use configuration mechanism 1 for 00:00.0, 00:02.0, 00:03.0" PCI: acpiphp: Re-enumerate devices when host bridge receives Bus Check
2013-05-23Merge tag 'tty-3.10-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg Kroah-Hartman: "Here are some tty / serial driver fixes for 3.10-rc2. Nothing huge, although the rocket driver fix looks large, it's just moving the code around to fix the reported build issues in it. Other than that, this has the fix for the of-reported lockdep warning from the vt layer, as well as some other needed bugfixes. All of these have been in linux-next for a while" * tag 'tty-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: mxser: Fix build warning introduced by dfc7b837c7f9 (Re: linux-next: build warning after merge of the tty.current tree) tty: mxser: fix usage of opmode_ioaddr serial: 8250_dw: add ACPI ID for Intel BayTrail TTY: Fix tty miss restart after we turn off flow-control tty/vt: Fix vc_deallocate() lock order TTY: ehv_bytechan: add missing platform_driver_unregister() when module exit TTY: rocket, fix more no-PCI warnings serial: mcf: missing uart_unregister_driver() on error in mcf_init() tty: serial: mpc5xxx: fix error handing in mpc52xx_uart_init() serial: samsung: add missing platform_driver_unregister() when module exit serial: pl011: protect attribute read from NULL platform data struct tty: nwpserial: Pass correct pointer to free_irq() serial: 8250_dw: Add valid clk pointer check
2013-05-23Merge tag 'usb-3.10-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg Kroah-Hartman: "Here are a number of tiny USB bugfixes / new device ids for 3.10-rc2 The majority of these are USB gadget fixes, but they are all small. Other than that, some USB host controller fixes, and USB serial driver fixes for problems reported with them. Also hopefully a fixed up USB_OTG Kconfig dependancy, that one seems to be almost impossible to get right for all of the different platforms these days." * tag 'usb-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (56 commits) USB: cxacru: potential underflow in cxacru_cm_get_array() USB: ftdi_sio: Add support for Newport CONEX motor drivers USB: option: add device IDs for Dell 5804 (Novatel E371) WWAN card usb: ohci: fix goto wrong tag in err case usb: isp1760-if: fix memleak when platform_get_resource fail usb: ehci-s5p: fix memleak when fallback to pdata USB: serial: clean up chars_in_buffer USB: ti_usb_3410_5052: fix chars_in_buffer overhead USB: io_ti: fix chars_in_buffer overhead USB: ftdi_sio: fix chars_in_buffer overhead USB: ftdi_sio: clean up get_modem_status USB: serial: add generic wait_until_sent implementation USB: serial: add wait_until_sent operation USB: set device dma_mask without reference to global data USB: Blacklisted Cinterion's PLxx WWAN Interface usb: option: Add Telewell TW-LTE 4G USB: EHCI: remove bogus #error USB: reset resume quirk needed by a hub USB: usb-stor: realtek_cr: Fix compile error usb, chipidea: fix link error when USB_EHCI_HCD is a module ...
2013-05-22Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS update from Ralf Baechle: - Fix a build error if <linux/printk.h> is included without <linux/linkage.h> having been included before. - Cleanup and fix the damage done by the generic idle loop patch. - A kprobes fix that brings the MIPS code in line with what other architectures are for quite a while already. - Wire up the native getdents64(2) syscall for 64 bit - for some reason it was only for the compat ABIs. This has been reported to cause an application issue. This turned out bigger than I meant but the wait instruction support code was driving me nuts. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: N64: Wire getdents64(2) kprobes/mips: Fix to check double free of insn slot MIPS: Idle: Break r4k_wait into two functions and fix it. MIPS: Idle: Do address fiddlery in helper functions. MIPS: Idle: Consolidate all declarations in <asm/idle.h>. MIPS: Idle: Don't call local_irq_disable() in cpu_wait() implementations. MIPS: Idle: Re-enable irqs at the end of r3081, au1k and loongson2 cpu_wait. MIPS: Idle: Make call of function pointer readable. MIPS: Idle: Consistently reformat inline assembler. MIPS: Idle: cleaup SMTC idle hook as per Linux coding style. MIPS: Consolidate idle loop / WAIT instruction support in a single file. MIPS: clock.h: Remove declaration of cpu_wait. Add include dependencies to <linux/printk.h>. MIPS: Rewrite pfn_valid to work in modules, too.
2013-05-22Merge tag 'omap-fixes-a-for-3.10-rc' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into fixes From Paul Walmsley: Fix the OMAP serial driver to work correctly on OMAP4 when booting with DT. * tag 'omap-fixes-a-for-3.10-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending: ARM: OMAP2+: hwmod: Remove sysc slave idle and auto idle apis SERIAL: OMAP: Remove the slave idle handling from the driver ARM: OMAP2+: serial: Remove the un-used slave idle hooks ARM: OMAP2+: hwmod-data: UART IP needs software control to manage sidle modes ARM: OMAP2+: hwmod: Add a new flag to handle SIDLE in SWSUP only in active ARM: OMAP2+: hwmod: Fix sidle programming in _enable_sysc()/_idle_sysc() Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-22Merge tag 'mfd-fixes-3.10-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes Pull mfd fixes from Samuel Ortiz: "This is the first batch of MFD fixes for 3.10. It's bigger than I would like, most of it is due to the big ab/db8500 merge that went through during the 3.10 merge window. So we have: - Some build fixes for the tps65912 and ab8500 drivers. - A couple of build fixes for the the si476x driver with pre 4.3 gcc compilers. - A few runtime breakage fixes (probe failures or oopses) for the ab8500 and db8500 drivers. - Some sparse or regular gcc warning fixes for the si476x, ab8500 and cros_ec drivers." * tag 'mfd-fixes-3.10-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes: mfd: ab8500-sysctrl: Let sysctrl driver work without pdata mfd: db8500-prcmu: Update stored DSI PLL divider value mfd: ab8500-sysctrl: Always enable pm_power_off handler mfd: ab8500-core: Pass GPADC compatible string to MFD core mfd: db8500-prcmu: Supply the pdata_size attribute for db8500-thermal mfd: ab8500-core: Use the correct driver name when enabling gpio/pinctrl mfd: ab8500: Pass AB8500 IRQ to debugfs code by resource mfd: ab8500-gpadc: Suppress 'ignoring regulator_enable() return value' warning mfd: ab8500-sysctrl: Set sysctrl_dev during probe mfd: ab8500-sysctrl: Fix sparse warning mfd: abx500-core: Fix sparse warning mfd: ab8500: Debugfs code depends on gpadc mfd: si476x: Use get_unaligned_be16() for unaligned be16 loads mfd: cros_ec_spi: Use %z to format pointer differences mfd: si476x: Do not use binary constants mfd: tps65912: Select MFD_CORE
2013-05-22Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio fixes from Rusty Russell: "A build fix and a uapi exposure fix. The build fix is later than I liked, but my first version broke linux-next due to overzealous header clean." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio_console: fix uapi header Hoist memcpy_fromiovec/memcpy_toiovec into lib/
2013-05-22Add include dependencies to <linux/printk.h>.Ralf Baechle
If <linux/linkage.h> has not been included before <linux/printk.h>, a build error like the below one will result: CC arch/mips/kernel/idle.o In file included from arch/mips/kernel/idle.c:17:0: include/linux/printk.h:109:1: error: data definition has no type or storage class [-Werror] include/linux/printk.h:109:1: error: type defaults to ‘int’ in declaration of ‘asmlinkage’ [-Werror=implicit-int] include/linux/printk.h:110:1: error: ‘format’ attribute only applies to function types [-Werror=attributes] include/linux/printk.h:110:1: error: expected ‘,’ or ‘;’ before ‘int’ include/linux/printk.h:114:1: error: data definition has no type or storage class [-Werror] include/linux/printk.h:114:1: error: type defaults to ‘int’ in declaration of ‘asmlinkage’ [-Werror=implicit-int] include/linux/printk.h:115:1: error: ‘format’ attribute only applies to function types [-Werror=attributes] include/linux/printk.h:115:1: error: expected ‘,’ or ‘;’ before ‘int’ include/linux/printk.h:117:1: error: data definition has no type or storage class [-Werror] include/linux/printk.h:117:1: error: type defaults to ‘int’ in declaration of ‘asmlinkage’ [-Werror=implicit-int] include/linux/printk.h:118:1: error: ‘format’ attribute only applies to function types [-Werror=attributes] include/linux/printk.h:118:1: error: ‘__cold__’ attribute ignored [-Werror=attributes] include/linux/printk.h:118:1: error: expected ‘,’ or ‘;’ before ‘asmlinkage’ include/linux/printk.h:122:1: error: data definition has no type or storage class [-Werror] include/linux/printk.h:122:1: error: type defaults to ‘int’ in declaration of ‘asmlinkage’ [-Werror=implicit-int] include/linux/printk.h:123:1: error: ‘format’ attribute only applies to function types [-Werror=attributes] include/linux/printk.h:123:1: error: ‘__cold__’ attribute ignored [-Werror=attributes] include/linux/printk.h:123:1: error: expected ‘,’ or ‘;’ before ‘int’ In file included from include/linux/kernel.h:14:0, from include/linux/sched.h:15, from arch/mips/kernel/idle.c:18: include/linux/dynamic_debug.h: In function ‘ddebug_dyndbg_module_param_cb’: include/linux/dynamic_debug.h:124:3: error: implicit declaration of function ‘printk’ [-Werror=implicit-function-declaration] Fixed by including <linux/linkage.h>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-05-22ACPI / PM: Allow device power states to be used for CONFIG_PM unsetRafael J. Wysocki
Currently, drivers/acpi/device_pm.c depends on CONFIG_PM and all of the functions defined in there are replaced with static inline stubs if that option is unset. However, CONFIG_PM means, roughly, "runtime PM or suspend/hibernation support" and some of those functions are useful regardless of that. For example, they are used by the ACPI fan driver for controlling fans and acpi_device_set_power() is called during device removal. Moreover, device initialization may depend on setting device power states properly. For these reasons, make the routines manipulating ACPI device power states defined in drivers/acpi/device_pm.c available for CONFIG_PM unset too. Reported-by: Zhang Rui <rui.zhang@intel.com> Reported-and-tested-by: Michel Lespinasse <walken@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: 3.9+ <stable@vger.kernel.org>
2013-05-21Merge branch 'drm-radeon-sun-hainan' of ↵Linus Torvalds
git://people.freedesktop.org/~airlied/linux Pull radeon sun/hainan support from Dave Airlie: "Since I know its outside the merge window, but since this is new hw I thought I'd try and provoke the new hw exception, it just fills in the blanks in the driver for the new AMD sun and hainan chipsets." * 'drm-radeon-sun-hainan' of git://people.freedesktop.org/~airlied/linux: drm/radeon: add Hainan pci ids drm/radeon: add golden register settings for Hainan (v2) drm/radeon: sun/hainan chips do not have UVD (v2) drm/radeon: track which asics have UVD drm/radeon: radeon-asic updates for Hainan drm/radeon: fill in ucode loading support for Hainan drm/radeon: don't touch DCE or VGA regs on Hainan (v3) drm/radeon: fill in GPU init for Hainan (v2) drm/radeon: add chip family for Hainan
2013-05-20Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2013-05-20tty/vt: Fix vc_deallocate() lock orderPeter Hurley
Now that the tty port owns the flip buffers and i/o is allowed from the driver even when no tty is attached, the destruction of the tty port (and the flip buffers) must ensure that no outstanding work is pending. Unfortunately, this creates a lock order problem with the console_lock (see attached lockdep report [1] below). For single console deallocation, drop the console_lock prior to port destruction. When multiple console deallocation, defer port destruction until the consoles have been deallocated. tty_port_destroy() is not required if the port has not been used; remove from vc_allocate() failure path. [1] lockdep report from Dave Jones <davej@redhat.com> ====================================================== [ INFO: possible circular locking dependency detected ] 3.9.0+ #16 Not tainted ------------------------------------------------------- (agetty)/26163 is trying to acquire lock: blocked: ((&buf->work)){+.+...}, instance: ffff88011c8b0020, at: [<ffffffff81062065>] flush_work+0x5/0x2e0 but task is already holding lock: blocked: (console_lock){+.+.+.}, instance: ffffffff81c2fde0, at: [<ffffffff813bc201>] vt_ioctl+0xb61/0x1230 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (console_lock){+.+.+.}: [<ffffffff810b3f74>] lock_acquire+0xa4/0x210 [<ffffffff810416c7>] console_lock+0x77/0x80 [<ffffffff813c3dcd>] con_flush_chars+0x2d/0x50 [<ffffffff813b32b2>] n_tty_receive_buf+0x122/0x14d0 [<ffffffff813b7709>] flush_to_ldisc+0x119/0x170 [<ffffffff81064381>] process_one_work+0x211/0x700 [<ffffffff8106498b>] worker_thread+0x11b/0x3a0 [<ffffffff8106ce5d>] kthread+0xed/0x100 [<ffffffff81601cac>] ret_from_fork+0x7c/0xb0 -> #0 ((&buf->work)){+.+...}: [<ffffffff810b349a>] __lock_acquire+0x193a/0x1c00 [<ffffffff810b3f74>] lock_acquire+0xa4/0x210 [<ffffffff810620ae>] flush_work+0x4e/0x2e0 [<ffffffff81065305>] __cancel_work_timer+0x95/0x130 [<ffffffff810653b0>] cancel_work_sync+0x10/0x20 [<ffffffff813b8212>] tty_port_destroy+0x12/0x20 [<ffffffff813c65e8>] vc_deallocate+0xf8/0x110 [<ffffffff813bc20c>] vt_ioctl+0xb6c/0x1230 [<ffffffff813b01a5>] tty_ioctl+0x285/0xd50 [<ffffffff811ba825>] do_vfs_ioctl+0x305/0x530 [<ffffffff811baad1>] sys_ioctl+0x81/0xa0 [<ffffffff81601d59>] system_call_fastpath+0x16/0x1b other info that might help us debug this: [ 6760.076175] Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(console_lock); lock((&buf->work)); lock(console_lock); lock((&buf->work)); *** DEADLOCK *** 1 lock on stack by (agetty)/26163: #0: blocked: (console_lock){+.+.+.}, instance: ffffffff81c2fde0, at: [<ffffffff813bc201>] vt_ioctl+0xb61/0x1230 stack backtrace: Pid: 26163, comm: (agetty) Not tainted 3.9.0+ #16 Call Trace: [<ffffffff815edb14>] print_circular_bug+0x200/0x20e [<ffffffff810b349a>] __lock_acquire+0x193a/0x1c00 [<ffffffff8100a269>] ? sched_clock+0x9/0x10 [<ffffffff8100a269>] ? sched_clock+0x9/0x10 [<ffffffff8100a200>] ? native_sched_clock+0x20/0x80 [<ffffffff810b3f74>] lock_acquire+0xa4/0x210 [<ffffffff81062065>] ? flush_work+0x5/0x2e0 [<ffffffff810620ae>] flush_work+0x4e/0x2e0 [<ffffffff81062065>] ? flush_work+0x5/0x2e0 [<ffffffff810b15db>] ? mark_held_locks+0xbb/0x140 [<ffffffff8113c8a3>] ? __free_pages_ok.part.57+0x93/0xc0 [<ffffffff810b15db>] ? mark_held_locks+0xbb/0x140 [<ffffffff810652f2>] ? __cancel_work_timer+0x82/0x130 [<ffffffff81065305>] __cancel_work_timer+0x95/0x130 [<ffffffff810653b0>] cancel_work_sync+0x10/0x20 [<ffffffff813b8212>] tty_port_destroy+0x12/0x20 [<ffffffff813c65e8>] vc_deallocate+0xf8/0x110 [<ffffffff813bc20c>] vt_ioctl+0xb6c/0x1230 [<ffffffff810aec41>] ? lock_release_holdtime.part.30+0xa1/0x170 [<ffffffff813b01a5>] tty_ioctl+0x285/0xd50 [<ffffffff812b00f6>] ? inode_has_perm.isra.46.constprop.61+0x56/0x80 [<ffffffff811ba825>] do_vfs_ioctl+0x305/0x530 [<ffffffff812b04db>] ? selinux_file_ioctl+0x5b/0x110 [<ffffffff811baad1>] sys_ioctl+0x81/0xa0 [<ffffffff81601d59>] system_call_fastpath+0x16/0x1b Cc: Dave Jones <davej@redhat.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-20drm/radeon: add Hainan pci idsAlex Deucher
Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com>
2013-05-20Merge tag 'pinctrl-fixes-v3.10-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pinctrl fixes from Linus Walleij: - Three fixes to make the boot path for device tree work properly on the Nomadik pin controller. - Compile warning fix for the vt8500 driver. - Fix error path in pinctrl-single. - Free mappings in error path of the Lantiq controller. - Documentation fixes. * tag 'pinctrl-fixes-v3.10-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl/lantiq: Free mapping configs for both pin and groups pinctrl: single: fix error return code in pcs_parse_one_pinctrl_entry() pinctrl: generic: Fix typos and clarify comments pinctrl: vt8500: Fix incorrect data in WM8750 pinctrl table pinctrl: abx500: Rejiggle platform data and DT initialisation pinctrl: abx500: Specify failed sub-driver by ID instead of driver_data
2013-05-20virtio_console: fix uapi headerMichael S. Tsirkin
uapi should use __u32 not u32. Fix a macro in virtio_console.h which uses u32. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2013-05-20Hoist memcpy_fromiovec/memcpy_toiovec into lib/Rusty Russell
ERROR: "memcpy_fromiovec" [drivers/vhost/vhost_scsi.ko] undefined! That function is only present with CONFIG_NET. Turns out that crypto/algif_skcipher.c also uses that outside net, but it actually needs sockets anyway. In addition, commit 6d4f0139d642c45411a47879325891ce2a7c164a added CONFIG_NET dependency to CONFIG_VMCI for memcpy_toiovec, so hoist that function and revert that commit too. socket.h already includes uio.h, so no callers need updating; trying only broke things fo x86_64 randconfig (thanks Fengguang!). Reported-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-05-19SERIAL: OMAP: Remove the slave idle handling from the driverSantosh Shilimkar
UART IP slave idle handling now taken care by runtime pm backend(hwmod layer) so remove the hackery from the driver. As discussed on the list, in future if dma mode needs to be brought back to this driver, UART sysc handling needs to be updated in framework such a way that no-idle/force idle profile can be supported. Given the broken dma mode for OMAP uarts, its very unlikely. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Tested-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Rajendra nayak <rnayak@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Tested-by: Kevin Hilman <khilman@linaro.org> # OMAP4/Panda Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-05-18Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree fixes from Grant Likely: "Device tree bug fixes and documentation updates for v3.10 Nothing earth shattering here. A build failure fix, and fix for releasing nodes and some documenation updates." * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: Documentation/devicetree: make semantic of initrd-end more explicit of/base: release the node correctly in of_parse_phandle_with_args() of/documentation: move video device bindings to a common place <linux/of_platform.h>: fix compilation warnings with DT disabled
2013-05-17PCI: acpiphp: Re-enumerate devices when host bridge receives Bus CheckYinghai Lu
When a PCI host bridge device receives a Bus Check notification, we must re-enumerate starting with the bridge to discover changes (devices that have been added or removed). Prior to 668192b678 ("PCI: acpiphp: Move host bridge hotplug to pci_root.c"), this happened in _handle_hotplug_event_bridge(). After that commit, _handle_hotplug_event_bridge() is not installed for host bridges, and the host bridge notify handler, _handle_hotplug_event_root() did not re-enumerate. This patch adds re-enumeration to _handle_hotplug_event_root(). This fixes cases where we don't notice the addition or removal of PCI devices, e.g., the PCI-to-USB ExpressCard in the bugzilla below. [bhelgaas: changelog, references] Reference: https://lkml.kernel.org/r/CAAh6nkmbKR3HTqm5ommevsBwhL_u0N8Rk7Wsms_LfP=nBgKNew@mail.gmail.com Reference: https://bugzilla.kernel.org/show_bug.cgi?id=57961 Reported-by: Gavin Guo <tuffkidtt@gmail.com> Tested-by: Gavin Guo <tuffkidtt@gmail.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> CC: stable@vger.kernel.org # v3.9+
2013-05-17bcma: add more core IDsRafał Miłecki
PCIe and ARM CR4 cores were found on 14e4:43b1 AKA BCM4352. Reported-by: Gabriel Thörnblad <gabriel@thornblad.com> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-05-16Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Fix for radeon nomodeset regression, old radeon interface cliprects fix, 2 qxl crasher fixes, and a couple of minor cleanups. I may have a new AMD hw support branch next week, its one of those doesn't affect anything existing just adds new support, I'll see how it shapes up and I might ask you to take it, just thought I'd warn in advance." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: drm/radeon: restore nomodeset operation (v2) qxl: fix bug with object eviction and update area drm/qxl: drop active_user_framebuffer as its unneeded qxl: drop unused variable. drm/qxl: fix ioport interactions for kernel submitted commands. drm: remove unused wrapper macros drm/radeon: check incoming cliprects pointer
2013-05-16USB: serial: add generic wait_until_sent implementationJohan Hovold
Add generic wait_until_sent implementation which polls for empty hardware buffers using the new port-operation tx_empty. The generic implementation will be used for all sub-drivers that implement tx_empty but does not define wait_until_sent. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-16USB: serial: add wait_until_sent operationJohan Hovold
Add wait_until_sent operation which can be used to wait for hardware buffers to drain. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-17mfd: ab8500-sysctrl: Always enable pm_power_off handlerFabio Baltieri
AB8500 sysctrl driver implements a pm_power_off handler, but that is currently not registered until a specific platform data field is enabled. This patch drops the platform data field and always registers ab8500_power_off if no other pm_power_off handler was defined before, and also introduces the necessary cleanup code in the driver's remove function. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-05-16Merge tag 'pm+acpi-3.10-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: - intel_pstate driver fixes and cleanups from Dirk Brandewie and Wei Yongjun. - cpufreq fixes related to ARM big.LITTLE support and the cpufreq-cpu0 driver from Viresh Kumar. - Assorted cpufreq fixes from Srivatsa S Bhat, Borislav Petkov, Wolfram Sang, Alexander Shiyan, and Nishanth Menon. - Assorted ACPI fixes from Catalin Marinas, Lan Tianyu, Alex Hung, Jan-Simon Möller, and Rafael J Wysocki. - Fix for a kfree() under spinlock in the PM core from Shuah Khan. - PM documentation updates from Borislav Petkov and Zhang Rui. * tag 'pm+acpi-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (30 commits) cpufreq: Preserve sysfs files across suspend/resume ACPI / scan: Fix memory leak on acpi_scan_init_hotplug() error path PM / hibernate: Correct documentation PM / Documentation: remove inaccurate suspend/hibernate transition lantency statement PM: Documentation update for freeze state cpufreq / intel_pstate: use vzalloc() instead of vmalloc()/memset(0) cpufreq, ondemand: Remove leftover debug line PM: Avoid calling kfree() under spinlock in dev_pm_put_subsys_data() cpufreq / kirkwood: don't check resource with devm_ioremap_resource cpufreq / intel_pstate: remove #ifdef MODULE compile fence cpufreq / intel_pstate: Remove idle mode PID cpufreq / intel_pstate: fix ffmpeg regression cpufreq / intel_pstate: use lowest requested max performance cpufreq / intel_pstate: remove idle time and duration from sample and calculations cpufreq: Fix incorrect dependecies for ARM SA11xx drivers cpufreq: ARM big LITTLE: Fix Kconfig entries cpufreq: cpufreq-cpu0: Free parent node for error cases cpufreq: cpufreq-cpu0: defer probe when regulator is not ready cpufreq: Issue CPUFREQ_GOV_POLICY_EXIT notifier before dropping policy refcount cpufreq: governors: Fix CPUFREQ_GOV_POLICY_{INIT|EXIT} notifiers ...
2013-05-16bonding: allow TSO being set on bonding masterEric Dumazet
In some situations, we need to disable TSO on bonding slaves. bonding device automatically unset TSO in bond_fix_features(), and performance is not good because : 1) We consume more cpu cycles. 2) GSO segmentation has some bugs leading to out of order TCP packets if this segmentation is done before virtual device. This particular problem will be addressed in a separate patch. This patch allows TSO being set/unset on the bonding master, so that GSO segmentation is done after bonding layer. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Michał Mirosław <mirqus@gmail.com> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Maciej Żenczykowski <maze@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-16Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== The following patchset contains three Netfilter fixes and update for the MAINTAINER file for your net tree, they are: * Fix crash if nf_log_packet is called from conntrack, in that case both interfaces are NULL, from Hans Schillstrom. This bug introduced with the logging netns support in the previous merge window. * Fix compilation of nf_log and nf_queue without CONFIG_PROC_FS, from myself. This bug was introduced in the previous merge window with the new netns support for the netfilter logging infrastructure. * Fix possible crash in xt_TCPOPTSTRIP due to missing sanity checkings to validate that the TCP header is well-formed, from myself. I can find this bug in 2.6.25, probably it's been there since the beginning. I'll pass this to -stable. * Update MAINTAINER file to point to new nf trees at git.kernel.org, remove Harald and use M: instead of P: (now obsolete tag) to keep Jozsef in the list of people. Please, consider pulling this. Thanks! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-16mac80211: fix spurious RCU warning and update documentationFelix Fietkau
Document rx vs tx status concurrency requirements. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-16Merge branch 'queue' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull target fixes from Nicholas Bellinger: "A handful of fixes + minor changes this time around, along with one important >= v3.9 regression fix for IBLOCK backends. The highlights include: - Use FD_MAX_SECTORS in FILEIO for block_device as well as files (agrover) - Fix processing of out-of-order CmdSNs with iSBD driver (shlomo) - Close long-standing target_put_sess_cmd() vs. core_tmr_abort_task() race with the addition of kref_put_spinlock_irqsave() (joern + greg-kh) - Fix IBLOCK WCE=1 + DPOFUA=1 backend WRITE regression in >= v3.9 (nab + bootc) Note these four patches are CC'ed to stable. Also, there is still some work left to be done on the active I/O shutdown path in target_wait_for_sess_cmds() used by tcm_qla2xxx + ib_isert fabrics that is still being discussed on the list, and will hopefully be resolved soon." * 'queue' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: close target_put_sess_cmd() vs. core_tmr_abort_task() race target: removed unused transport_state flag target/iblock: Fix WCE=1 + DPOFUA=1 backend WRITE regression MAINTAINERS: Update target git tree URL iscsi-target: Fix typos in RDMAEXTENSIONS macro usage target/rd: Add ramdisk bit for NULLIO operation iscsi-target: Fix processing of OOO commands iscsi-target: Make buf param of iscsit_do_crypto_hash_buf() const void * iscsi-target: Fix NULL pointer dereference in iscsit_send_reject target: Have dev/enable show if TCM device is configured target: Use FD_MAX_SECTORS/FD_BLOCKSIZE for blockdevs using fileio target: Remove unused struct members in se_dev_entry
2013-05-15broadcom: add include guards to include/linux/brcmphy.hFlorian Fainelli
include/linux/brcmphy.h is currently not protected against double inclusion, add ifdefs guard to fix that. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-15Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: - Cure for not using zalloc in the first place, which leads to random crashes with CPUMASK_OFF_STACK. - Revert a user space visible change which broke udev - Add a missing cpu_online early return introduced by the new full dyntick conversions - Plug a long standing race in the timer wheel cpu hotplug code. Sigh... - Cleanup NOHZ per cpu data on cpu down to prevent stale data on cpu up. * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: time: Revert ALWAYS_USE_PERSISTENT_CLOCK compile time optimizaitons timer: Don't reinitialize the cpu base lock during CPU_UP_PREPARE tick: Don't invoke tick_nohz_stop_sched_tick() if the cpu is offline tick: Cleanup NOHZ per cpu data on cpu down tick: Use zalloc_cpumask_var for allocating offstack cpumasks
2013-05-15Correct typo "supperspeed" to "superspeed".Robert P. J. Day
Tidy up kernel-doc content for USB GADGET. No functional change. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-05-15netfilter: log: netns NULL ptr bug when calling from conntrackHans Schillstrom
Since (69b34fb netfilter: xt_LOG: add net namespace support for xt_LOG), we hit this: [ 4224.708977] BUG: unable to handle kernel NULL pointer dereference at 0000000000000388 [ 4224.709074] IP: [<ffffffff8147f699>] ipt_log_packet+0x29/0x270 when callling log functions from conntrack both in and out are NULL i.e. the net pointer is invalid. Adding struct net *net in call to nf_logfn() will secure that there always is a vaild net ptr. Reported as netfilter's bugzilla bug 818: https://bugzilla.netfilter.org/show_bug.cgi?id=818 Reported-by: Ronald <ronald645@gmail.com> Signed-off-by: Hans Schillstrom <hans@schillstrom.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-05-15target: close target_put_sess_cmd() vs. core_tmr_abort_task() raceJoern Engel
It is possible for one thread to to take se_sess->sess_cmd_lock in core_tmr_abort_task() before taking a reference count on se_cmd->cmd_kref, while another thread in target_put_sess_cmd() drops se_cmd->cmd_kref before taking se_sess->sess_cmd_lock. This introduces kref_put_spinlock_irqsave() and uses it in target_put_sess_cmd() to close the race window. Signed-off-by: Joern Engel <joern@logfs.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: <stable@vger.kernel.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-05-15target: removed unused transport_state flagJoern Engel
Signed-off-by: Joern Engel <joern@logfs.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-05-14time: Revert ALWAYS_USE_PERSISTENT_CLOCK compile time optimizaitonsJohn Stultz
Kay Sievers noted that the ALWAYS_USE_PERSISTENT_CLOCK config, which enables some minor compile time optimization to avoid uncessary code in mostly the suspend/resume path could cause problems for userland. In particular, the dependency for RTC_HCTOSYS on !ALWAYS_USE_PERSISTENT_CLOCK, which avoids setting the time twice and simplifies suspend/resume, has the side effect of causing the /sys/class/rtc/rtcN/hctosys flag to always be zero, and this flag is commonly used by udev to setup the /dev/rtc symlink to /dev/rtcN, which can cause pain for older applications. While the udev rules could use some work to be less fragile, breaking userland should strongly be avoided. Additionally the compile time optimizations are fairly minor, and the code being optimized is likely to be reworked in the future, so lets revert this change. Reported-by: Kay Sievers <kay@vrfy.org> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: stable <stable@vger.kernel.org> #3.9 Cc: Feng Tang <feng.tang@intel.com> Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Link: http://lkml.kernel.org/r/1366828376-18124-1-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-05-14Merge tag 'ext4_for_linus_stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 update from Ted Ts'o: "Fixed regressions (two stability regressions and a performance regression) introduced during the 3.10-rc1 merge window. Also included is a bug fix relating to allocating blocks after resizing an ext3 file system when using the ext4 file system driver" * tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: jbd,jbd2: fix oops in jbd2_journal_put_journal_head() ext4: revert "ext4: use io_end for multiple bios" ext4: limit group search loop for non-extent files ext4: fix fio regression
2013-05-14pinctrl: generic: Fix typos and clarify commentsLaurent Pinchart
Drive strength controls both sink and source currents, clarify the description accordingly. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-14ACPI / LPSS: register clock device for Lynxpoint DMA properlyRafael J. Wysocki
The DMA controller in Lynxpoint is enumerated as a regular ACPI device now. To work properly it is using the LPSS root clock as a functional clock. That's why we have to register the clock device accordingly to the ACPI ID of the DMA controller. The acpi_lpss.c module is responsible to do the job. This patch also removes hardcoded name of the DMA device in clk-lpt.c and the name of the root clock in acpi_lpss.c. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-05-14dma: acpi-dma: parse CSRT to extract additional resourcesAndy Shevchenko
Since we have CSRT only to get additional DMA controller resources, let's get rid of drivers/acpi/csrt.c and move its logic inside ACPI DMA helpers code. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-05-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Several small bug fixes all over: 1) be2net driver uses wrong payload length when submitting MAC list get requests to the chip. From Sathya Perla. 2) Fix mwifiex memory leak on driver unload, from Amitkumar Karwar. 3) Prevent random memory access in batman-adv, from Marek Lindner. 4) batman-adv doesn't check for pskb_trim_rcsum() errors, also from Marek Lindner. 5) Fix fec crashes on rapid link up/down, from Frank Li. 6) Fix inner protocol grovelling in GSO, from Pravin B Shelar. 7) Link event validation fix in qlcnic from Rajesh Borundia. 8) Not all FEC chips can support checksum offload, fix from Shawn Guo. 9) EXPORT_SYMBOL + inline doesn't make any sense, from Denis Efremov. 10) Fix race in passthru mode during device removal in macvlan, from Jiri Pirko. 11) Fix RCU hash table lookup socket state race in ipv6, leading to NULL pointer derefs, from Eric Dumazet. 12) Add several missing HAS_DMA kconfig dependencies, from Geert Uyttterhoeven. 13) Fix bogus PCI resource management in 3c59x driver, from Sergei Shtylyov. 14) Fix info leak in ipv6 GRE tunnel driver, from Amerigo Wang. 15) Fix device leak in ipv6 IPSEC policy layer, from Cong Wang. 16) DMA mapping leak fix in qlge from Thadeu Lima de Souza Cascardo. 17) Missing iounmap on probe failure in bna driver, from Wei Yongjun." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (40 commits) bna: add missing iounmap() on error in bnad_init() qlge: fix dma map leak when the last chunk is not allocated xfrm6: release dev before returning error ipv6,gre: do not leak info to user-space virtio_net: use default napi weight by default emac: Fix EMAC soft reset on 460EX/GT 3c59x: fix PCI resource management caif: CAIF_VIRTIO should depend on HAS_DMA net/ethernet: MACB should depend on HAS_DMA net/ethernet: ARM_AT91_ETHER should depend on HAS_DMA net/wireless: ATH9K should depend on HAS_DMA net/ethernet: STMMAC_ETH should depend on HAS_DMA net/ethernet: NET_CALXEDA_XGMAC should depend on HAS_DMA ipv6: do not clear pinet6 field macvlan: fix passthru mode race between dev removal and rx path ipv4: ip_output: remove inline marking of EXPORT_SYMBOL functions net/mlx4: Strengthen VLAN tags/priorities enforcement in VST mode net/mlx4_core: Add missing report on VST and spoof-checking dev caps net: fec: enable hardware checksum only on imx6q-fec qlcnic: Fix validation of link event command. ...
