This adds support for Ricoh RN5T567 PMIC used on Colibri iMX7. The
driver should get unified with rn5t618 driver.
Ricoh RN5T618 is a power management IC which integrates 3 step-down
DCDC converters, 7 low-dropout regulators, a Li-ion battery charger,
fuel gauge, ADC, GPIOs and a watchdog timer.
This commit adds a MFD core driver to support the I2C communication
with the device.
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
(cherry picked from commit 9bb9e29c78f8d8ee310987fd58a2b908a4ce0c40)
This patch allows for easy integration of a custom Linux boot logo to
replace the Tux' being shown by default.
Use gimp or the like to create a raw PPM in your desired resolution.
Reduce the number of colours in the image to 224:
user@host:~$ ppmquant 224 Toradex-640x480.ppm > \
Toradex-640x480-224.ppm
ppmquant: making histogram...
ppmquant: 370 colors found
ppmquant: choosing 224 colors...
ppmquant: mapping image to new colors...
Convert it from raw PPM to ASCII format:
user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \
Toradex-640x480-ascii-224.ppm
Copy it into the Linux sources:
cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\
logo_custom_clut224.ppm
Activate exclusively custom Linux logo in the kernel configuration:
Device Drivers -> Graphics support -> Bootup logo ->
Custom 224-color Linux logo
And re-compile the kernel.
(cherry picked from commit fa2371bff9ac03581881849d8f95678ef3992719)
(cherry picked from commit 481ced9057f340a80bf23775a55a9b657c49201f)
Rather than relying on special USB/PHY pins/registers use the generic
extcon framework with its extcon-usb-gpio implementation to detect ID
and VBUS changes.
(cherry picked from commit a257098741b441e6e84ffe97b7793c580642d502)
Add resource-managed extcon device register function for convenience.
For example, if a extcon device is attached with new
devm_extcon_dev_register(), that extcon device is automatically
unregistered on driver detach.
Signed-off-by: Sangjung Woo <sangjung.woo@samsung.com>
[Fix bug about devm_extcon_dev_match/release() and code clean by Chanwoo Choi]
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
(cherry picked from commit 1111244ff4493448c0ee66e814e20c6e81d3b93d)
The gpio binding document says that new code should always use named
gpios. Patch 40b73183 added support to parse a list of gpios from child
nodes, but does not make it possible to use named gpios. This patch adds
the con_id property and implements it is done in gpiolib.c, where the
old-style of using unnamed gpios still works.
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
Acked-by: Bryan Wu <cooloney@gmail.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
(cherry picked from commit 1feb57a245a4910b03202a814ffc51a900bd4aca)
Device tree nodes are already treated as objects, and we already want to
expose them to userspace which is done using the /proc filesystem today.
Right now the kernel has to do a lot of work to keep the /proc view in
sync with the in-kernel representation. If device_nodes are switched to
be kobjects then the device tree code can be a whole lot simpler. It
also turns out that switching to using /sysfs from /proc results in
smaller code and data size, and the userspace ABI won't change if
/proc/device-tree symlinks to /sys/firmware/devicetree/base.
v7: Add missing sysfs_bin_attr_init()
v6: Add __of_add_property() early init fixes from Pantelis
v5: Rename firmware/ofw to firmware/devicetree
Fix updating property values in sysfs
v4: Fixed build error on Powerpc
Fixed handling of dynamic nodes on powerpc
v3: Fixed handling of duplicate attribute and child node names
v2: switch to using sysfs bin_attributes which solve the problem of
reporting incorrect property size.
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
(cherry picked from commit 75b57ecf9d1d1e17d099ab13b8f48e6e038676be)
Add new generic routines are provided for retrieving properties from
device description objects in the platform firmware in case there are
no struct device objects for them (either those objects have not been
created yet or they do not exist at all).
The following functions are provided:
fwnode_property_present()
fwnode_property_read_u8()
fwnode_property_read_u16()
fwnode_property_read_u32()
fwnode_property_read_u64()
fwnode_property_read_string()
fwnode_property_read_u8_array()
fwnode_property_read_u16_array()
fwnode_property_read_u32_array()
fwnode_property_read_u64_array()
fwnode_property_read_string_array()
in analogy with the corresponding functions for struct device added
previously. For all of them, the first argument is a pointer to struct
fwnode_handle (new type) that allows a device description object
(depending on what platform firmware interface is in use) to be
obtained.
Add a new macro device_for_each_child_node() for iterating over the
children of the device description object associated with a given
device and a new function device_get_child_node_count() returning the
number of a given device's child nodes.
The interface covers both ACPI and Device Trees.
Suggested-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Grant Likely <grant.likely@linaro.org>
(cherry picked from commit 8a0662d9ed2968e1186208336a8e1fab3fdfea63)
Add a uniform interface by which device drivers can request device
properties from the platform firmware by providing a property name
and the corresponding data type. The purpose of it is to help to
write portable code that won't depend on any particular platform
firmware interface.
The following general helper functions are added:
device_property_present()
device_property_read_u8()
device_property_read_u16()
device_property_read_u32()
device_property_read_u64()
device_property_read_string()
device_property_read_u8_array()
device_property_read_u16_array()
device_property_read_u32_array()
device_property_read_u64_array()
device_property_read_string_array()
The first one allows the caller to check if the given property is
present. The next 5 of them allow single-valued properties of
various types to be retrieved in a uniform way. The remaining 5 are
for reading properties with multiple values (arrays of either numbers
or strings).
This change set includes material from Mika Westerberg and Aaron Lu.
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
(cherry picked from commit b31384fa5de37a100507751dfb5c0a49d06cee67)
Commit 21f2aae91e902aad ("leds: leds-gpio: Add support for GPIO
descriptors") already converted most of the driver to use GPIO descriptors.
What is still missing is the platform specific hook gpio_blink_set() and
board files which pass legacy GPIO numbers to this driver in platform data.
In this patch we handle the former and convert gpio_blink_set() to take
GPIO descriptor instead. In order to do this we convert the existing four
users to accept GPIO descriptor and translate it to legacy GPIO number in
the platform code. This effectively "pushes" legacy GPIO number usage from
the driver to platforms.
Also add comment to the remaining block describing that it is legacy code
path and we are getting rid of it eventually.
Suggested-by: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
(cherry picked from commit c673a2b4008103525a3cf21bedf15ffac37bfef0)
GPIO descriptors are the preferred way over legacy GPIO numbers
nowadays. Convert the driver to use GPIO descriptors internally but
still allow passing legacy GPIO numbers from platform data to support
existing platforms.
(cherry picked from commit 5c51277a9ababfa44a7f944100bdc9fbda139905)
Some drivers need to deal with only firmware representation of its
GPIOs. An example would be a GPIO button array driver where each button
is described as a separate firmware node in device tree. Typically these
child nodes do not have physical representation in the Linux device
model.
In order to help device drivers to handle such firmware child nodes we
add dev[m]_get_named_gpiod_from_child() that takes a child firmware
node pointer as its second argument (the first one is the parent device
itself), finds the GPIO using whatever is the underlying firmware
method, and requests the GPIO properly.
(cherry picked from commit 40b7318319281b1bdec804f6435f26cadd329c13)
Device Tree is used in many embedded systems to describe the system
configuration to the OS. It supports attaching properties or name-value
pairs to the devices it describe. With these properties one can pass
additional information to the drivers that would not be available
otherwise.
ACPI is another configuration mechanism (among other things) typically
seen, but not limited to, x86 machines. ACPI allows passing arbitrary
data from methods but there has not been mechanism equivalent to Device
Tree until the introduction of _DSD in the recent publication of the
ACPI 5.1 specification.
In order to facilitate ACPI usage in systems where Device Tree is
typically used, it would be beneficial to standardize a way to retrieve
Device Tree style properties from ACPI devices, which is what we do in
this patch.
If a given device described in ACPI namespace wants to export properties it
must implement _DSD method (Device Specific Data, introduced with ACPI 5.1)
that returns the properties in a package of packages. For example:
Name (_DSD, Package () {
ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"),
Package () {
Package () {"name1", <VALUE1>},
Package () {"name2", <VALUE2>},
The UUID reserved for properties is daffd814-6eba-4d8c-8a91-bc9bbf4aa301
and is documented in the ACPI 5.1 companion document called "_DSD
Implementation Guide" [1], [2].
We add several helper functions that can be used to extract these
properties and convert them to different Linux data types.
The ultimate goal is that we only have one device property API that
retrieves the requested properties from Device Tree or from ACPI
transparent to the caller.
[1] http://www.uefi.org/sites/default/files/resources/_DSD-implementation-guide-toplevel.htm
[2] http://www.uefi.org/sites/default/files/resources/_DSD-device-properties-UUID.pdf
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Reviewed-by: Grant Likely <grant.likely@linaro.org>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
(cherry picked from commit ffdcd955c3078af3ce117edcfce80fde1a512bed)
The huge majority of GPIOs have their direction and initial value set
right after being obtained by one of the gpiod_get() functions. The
integer GPIO API had gpio_request_one() that took a convenience flags
parameter allowing to specify an direction and value applied to the
returned GPIO. This feature greatly simplifies client code and ensures
errors are always handled properly.
A similar feature has been requested for the gpiod API. Since setting
the direction of a GPIO is so often the very next action done after
obtaining its descriptor, we prefer to extend the existing functions
instead of introducing new functions that would raise the
number of gpiod getters to 16 (!).
The drawback of this approach is that all gpiod clients need to be
updated. To limit the pain, temporary macros are introduced that allow
gpiod_get*() to be called with or without the extra flags argument. They
will be removed once all consumer code has been updated.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit 39b2bbe3d715cf5013b5c48695ccdd25bd3bf120)
This patch moves <acpi/acpi.h> out of CONFIG_ACPI condition so that all
ACPICA prototypes can be seen by the CONFIG_ACPI=n Linux kernel builds.
Note that we can do this because ACPICA has implemented stubs for all
ACPICA prototypes that are currently referenced by the Linux kernel.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
(cherry picked from commit 633adaba49d46dcaa4289de5b25c562b54ff575b)
The forthcoming patch will make <acpi/acpi.h> to be visible to all kernel
source code. Thus for the architectures that do not support ACPI and
haven't implemented <asm/acenv.h>, we need to make it excluded.
(cherry picked from commit d334c823b27401721591e0f1220050a41af08165)
<asm/acpi.h>
There is a mis-order inclusion for <asm/acpi.h>.
As we will enforce including <linux/acpi.h> for all Linux ACPI users, we
can find the inclusion order is as follows:
<linux/acpi.h>
<acpi/acpi.h>
<acpi/platform/acenv.h>
(acenv.h before including aclinux.h)
<acpi/platform/aclinux.h>
(aclinux.h before including asm/acpi.h)
<asm/acpi.h> @Redundant@
(ACPICA specific stuff)
(Linux ACPI specific stuff) ? - - - - - - - - - - - - +
(aclinux.h after including asm/acpi.h) @Invisible@ |
(acenv.h after including aclinux.h) @Invisible@ |
other ACPICA headers @Invisible@ |
<acpi/acpi_bus.h> |
<acpi/acpi_drivers.h> |
<asm/acpi.h> (Excluded) |
(Linux ACPI specific stuff) ! <- - - - - - - - - - - - - +
NOTE that, in ACPICA, <acpi/platform/acenv.h> is more like Kconfig
generated <generated/autoconf.h> for Linux, it is meant to be included
before including any ACPICA code.
In the above figure, there is a question mark for "Linux ACPI specific
stuff" in <asm/acpi.h> which should be included after including all other
ACPICA header files. Thus they really need to be moved to the position
marked with exclaimation mark or the definitions in the blocks marked with
"@Invisible@" will be invisible to such architecture specific "Linux ACPI
specific stuff" header blocks. This leaves 2 issues:
1. All environmental definitions in these blocks should have a copy in the
area marked with "@Redundant@" if they are required by the "Linux ACPI
specific stuff".
2. We cannot use any ACPICA defined types in <asm/acpi.h>.
This patch splits architecture specific ACPICA stuff from <asm/acpi.h> to
fix this issue.
(cherry picked from commit 07d8391433380fc72f999d99c554b1cfedea9778)
From ACPICA's perspective, <acpi/actypes.h> should be included after
inclusion of <acpi/platform/acenv.h>. But currently in Linux,
<acpi/platform/aclinux.h> included by <acpi/platform/acenv.h> has
included <acpi/actypes.h> to find ACPICA types for inline functions.
This causes the following problem:
1. Redundant code in <asm/acpi.h> and <acpi/platform/aclinux.h>:
Linux must be careful to keep conditions for <acpi/actypes.h> inclusion
consistent with the conditions for <acpi/platform/aclinux.h> inclusion.
Which finally leads to the issue that we have to keep many useless macro
definitions in <acpi/platform/aclinux.h> or <asm/acpi.h>.
Such conditions include:
COMPILER_DEPENDENT_UINT64
COMPILER_DEPENDENT_INT64
ACPI_INLINE
ACPI_SYSTEM_XFACE
ACPI_EXTERNAL_XFACE
ACPI_INTERNAL_XFACE
ACPI_INTERNAL_VAR_XFACE
ACPI_MUTEX_TYPE
DEBUGGER_THREADING
ACPI_ACQUIRE_GLOBAL_LOCK
ACPI_RELEASE_GLOBAL_LOCK
ACPI_FLUSH_CPU_CACHE
They have default implementations in <include/acpi/platform/acenv.h>
while Linux need to keep a copy in <asm/acpi.h> to avoid build errors.
This patch introduces <acpi/platform/aclinuxex.h> to fix this issue by
splitting conditions and declarations (most of them are inline functions)
into 2 header files so that the wrong inclusion of <acpi/actypes.h> can be
removed from <acpi/platform/aclinux.h>.
This patch also removes old ACPI_NATIVE_INTERFACE_HEADER mechanism which is
not preferred by Linux and adds the platform/acenvex.h to be the solution
to solve this issue.
(cherry picked from commit d13bd5a602982cd7f697e39b13ac736c2c553af1)
(cherry picked from commit 6a3790a67bf22b0162337ef2faade225cc86c8b6)
Introduce gpiod_get_optional() and gpiod_get_index_optional() helpers
that make it easier for drivers to handle optional GPIOs.
Currently in order to handle optional GPIOs, a driver needs to special
case error handling for -ENOENT, such as this:
gpio = gpiod_get(dev, "foo");
if (IS_ERR(gpio)) {
if (PTR_ERR(gpio) != -ENOENT)
return PTR_ERR(gpio);
gpio = NULL;
if (gpio) {
/* set up GPIO */
With these new helpers the above is reduced to:
gpio = gpiod_get_optional(dev, "foo");
if (IS_ERR(gpio))
if (gpio) {
/* set up GPIO */
While at it, device-managed variants of these functions are also
provided.
Signed-off-by: Thierry Reding <treding@nvidia.com>
(cherry picked from commit 29a1f2333e07bbbecb920cc78fd035fe8f53207a)
device
This patch add device managed devm_extcon_dev_{allocate,free} to automatically
free the memory of extcon_dev structure without handling free operation.
Reviewed-by: Felipe Balbi <balbi@ti.com>
(cherry picked from commit 739ba1bfdb15e773999aafddbd6c59b5737797a0)
This patch move simply OF helper function to extcon core and change function
name as following:
- of_extcon_get_extcon_dev() -> extcon_get_edev_by_phandle()
Acked-by: Felipe Balbi <balbi@ti.com>
(cherry picked from commit 1ad94ffef22c0a6e2ee6ba90a800c32fd29ffa1f)
The need to know the number of array elements in a property is
a common pattern. To prevent duplication of open-coded implementations
add a helper static function that also centralises strict sanity
checking and DTB format details, as well as a set of wrapper functions
for u8, u16, u32 and u64.
Suggested-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Heiko Stuebner <heiko.stuebner@bqreaders.com>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit ad54a0cfbeb4bd4033d09017557ccbc423f9d5ff)
Remove translation protection for applications as Linux tools folder will
start to use such types.
In Linux kernel source tree, after removing this translation protection,
the u8/u16/u32/u64/s32/s64 typedefs are exposed for both __KERNEL__ builds
and !__KERNEL__ builds (tools/power/acpi) and the original definitions of
ACPI_UINT8/16/32/64_MAX are changed.
For !__KERNEL__ builds, this kind of defintions should already been tested
by the distribution vendors that are distributing binary ACPICA package and
we've achieved the successful built/run test result in the kernel source
tree.
For __KERNEL__ builds, there are 2 things affected:
1. u8/u16/u32/u64/s32/s64 type definitions:
Since Linux has already type defined u8/u16/u32/u64/s32/s64 in
include/uapi/asm-generic/int-ll64.h for __KERNEL__. In order not to
introduce build regressions where the 2 typedefs are differed,
ACPI_USE_SYSTEM_INTTYPES is introduced to mask out ACPICA's typedefs.
It must be defined for Linux __KERNEL__ builds.
2. ACPI_UINT8/16/32/64_MAX definitions:
Before applying this change:
ACPI_UINT8_MAX: sizeof (UINT8)
UINT8: unsigned char
ACPI_UINT16_MAX: sizeof (UINT16)
UINT16: unsigned short
ACPI_UINT32_MAX: sizeof (UINT32)
INT32: int
UINT32: unsigned int
ACPI_UINT64_MAX: sizeof (UINT64)
INT64: COMPILER_DEPENDENT_INT64
COMPILER_DEPENDENT_INT64: signed long (IA64) or
signed long long (IA32)
UINT64: COMPILER_DEPENDENT_UINT64
COMPILER_DEPENDENT_UINT64: unsigned long (IA64) or
unsigned long long (IA32)
After applying this change:
ACPI_UINT8_MAX: sizeof (u8)
u8: unsigned char
UINT8: (removed from actypes.h)
ACPI_UINT16_MAX: sizeof (u16)
u16: unsigned short
UINT16: (removed from actypes.h)
ACPI_UINT32_MAX: sizeof (u32)
INT32/UINT32: (removed from actypes.h)
s32: signed int
u32: unsigned int
ACPI_UINT64_MAX: sizeof (u64)
INT64/UINT64: (removed from actypes.h)
u64: unsigned long long
s64: signed long long
COMPILER_DEPENDENT_INT64: signed long (IA64) (not used any more)
signed long long (IA32) (not used any more)
COMPILER_DEPENDENT_UINT64: unsigned long (IA64) (not used any more)
unsigned long long (IA32) (not used any more)
All definitions are equal except ACPI_UINT64_MAX for CONFIG_IA64. It
is changed from sizeof(unsigned long) to sizeof(unsigned long long).
By investigation, 64bit Linux kernel build is LP64 compliant, i.e.,
sizeof(long) and (pointer) are 64. As sizeof(unsigned long) equals to
sizeof(unsigned long long) on IA64 platform where CONFIG_64BIT cannot be
disabled, this change actually will not affect the value of
ACPI_UINT64_MAX on IA64 platforms.
This patch is necessary for the ACPICA's acpidump tool to build
correctly. Lv Zheng.
(cherry picked from commit e252652fb2664d42de19f933aa3688bbc470de3f)
Added platform data struct to define interrupt and reset GPIO. This
allows to initialize the touchscreen controller inside the driver
rather then in each platform and use the driver as a module.
In order to use the auxiliar ADC inputs of STMPE811 devices we need
to add resources for the ADC block. Also move the ADC macros from
the touchscreen driver to the general header file. We will need them
for the ADC driver in future.
drivers/mfd/stmpe.c
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com>
Rename host->max_discard_to to host->max_busy_timeout, to reflect that
it tells the mmc core layer about the maximum supported busy detection
timeout by the host.
This timeout is at the moment only applicable to erase/trim/discard
commands. By the renaming we provide the option of make use of it for
other commands that cares about busy detection. In other words, those
commands that wants an R1B response, like for example the mmc switch
command.
Do note that the max_busy_timeout is supposed to be specified only by
hosts supporting MMC_CAP_WAIT_WHILE_BUSY.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Chris Ball <chris@printf.net>
(cherry picked from commit 68eb80e06bfa06035d0304686124974780308fae)
counter"
Revert the patch and using upstream version instead.
This reverts commit 056ef389fba70e2de8d1c5d976a1c1bd0578d381.
Replace ext_csd "enhanced_area_en" attribute by
"partition_setting_completed". It was used whether or
not enhanced user area is defined and without checks of
EXT_CSD_PARTITION_SETTING_COMPLETED bit.
Signed-off-by: Grégory Soutadé <gsoutade@neotion.com>
There is a substantial amount of drivers that in go to SND_SOC_BIAS_OFF on
suspend and go back to SND_SOC_BIAS_SUSPEND on resume (Often this is even
the only thing done in the suspend and resume handlers). This patch
introduces a new suspend_bias_off flag, which when set by a driver will let
the ASoC core automatically put the device's DAPM context at the
SND_SOC_BIAS_OFF level during suspend. Once the device is resumed the DAPM
context will go back to SND_SOC_BIAS_STANDBY (if the context is idle,
otherwise to SND_SOC_BIAS_ON).
This will allow us to remove a fair bit of duplicated code from the drivers.
Signed-off-by: Mark Brown <broonie@kernel.org>
(cherry picked from commit 86dbf2ac6fcb2d2932d4610f2dfe0954aa0633f7)
sound/soc/soc-core.c
add pfuze3001 support.
Signed-off-by: Robin Gong <b38343@freescale.com>
When CONFIG_IMX_SEMA4 is NOT set, some modules may
still call SEMA4 APIs, need to add dummy function
to make sure build pass.
Signed-off-by: Anson Huang <b20788@freescale.com>
In order to workaround the PRE SoC bug recorded by errata ERR009624, the
software cannot write the PRE_CTRL register when the PRE writes the PRE_CTRL
register automatically to set the ENABLE bit(bit0) to 1 in the PRE repeat mode.
The software mechanism to set the PRE_CTRL register is different for PRE Y
resolution higher than 9 lines and lower than or equal to 9 lines.
For cases in which Y resolution is higher than 9 lines, before we update PRE
shadow, we just need to wait until the PRE store engine status runs out of
the problematic PRE automatic writing window.
While for cases in which Y resolutin is lower than or equal to 9 lines, we
have to update PRE shadow in the buffer flip interrupt handler.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
resolution higher than 9 lines and lower than or equal to 9 lines. So,
this patch defines the small Y resolution and adds a helper to check the
Y resolution.
This patch exports a function to set the PRE_CTRL register so that it could be
used by the software when the PRE automatic writing doesn't happen for sure.
Currently one mrq->data maybe execute dma_map_sg() twice
when mmc subsystem prepare over one new request, and the
following log show up:
sdhci[sdhci_pre_dma_transfer] invalid cookie: 24, next-cookie 25
In this condition, mrq->date map a dma-memory(1) in sdhci_pre_req
for the first time, and map another dma-memory(2) in sdhci_prepare_data
for the second time. But driver only unmap the dma-memory(2), and
dma-memory(1) never unmapped, which cause the dma memory leak issue.
This patch use another method to map the dma memory for the mrq->data
which can fix this dma memory leak issue.
Fixes: 348487cb28e6 ("mmc: sdhci: use pipeline mmc requests to improve performance")
Reported-and-tested-by: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Haibo Chen <haibo.chen@freescale.com>
(cherry picked from commit d31911b9374a76560d2c8ea4aa6ce5781621e81d)
drivers/mmc/host/sdhci.c
drivers/mmc/host/sdhci.h
Add snvs root clock support.
Signed-off-by: Fugang Duan <B38611@freescale.com>
This patch removes imx6_usb_charger driver since we already move it to
chipidea imx specific controller driver.
Acked-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Li Jun <jun.li@freescale.com>
By using gstreamer plugin v4l2radio, it will call VIDIOC_S_CTRL with
V4L2_CID_AUDIO_MUTE, but return failed.
So add V4L2_CID_AUDIO_MUTE CTRL support for radio-si476x.
Signed-off-by: Zidan Wang <zidan.wang@freescale.com>
i.MX7D has a silicon issue on full speed termination after A device ends
a session, which causes it can not detect data pulse from B device if
A device isn't in low power mode, this patch work around it by override
Termsel bit to be 1 for FS mode termination. After A device detects data
pulse or turns on vbus, this override will be cleared and disabled.
There is occasion that dma callback come late after the substream is released.
Then there will be kernel dump.
[<805866b0>] (imx_pcm_dma_complete) from [<802fad9c>] (sdma_handle_channel_loop.isra.25+0x48/0x54)
[<802fad9c>] (sdma_handle_channel_loop.isra.25) from [<802fae48>] (sdma_tasklet+0xa0/0x1d4)
[<802fae48>] (sdma_tasklet) from [<800356e0>] (tasklet_action+0x64/0xf8)
[<800356e0>] (tasklet_action) from [<80034ea0>] (__do_softirq+0x104/0x218)
[<80034ea0>] (__do_softirq) from [<80035220>] (irq_exit+0xa8/0xec)
[<80035220>] (irq_exit) from [<8000ed44>] (handle_IRQ+0x3c/0x90)
[<8000ed44>] (handle_IRQ) from [<80008578>] (gic_handle_irq+0x28/0x5c)
[<80008578>] (gic_handle_irq) from [<80012100>] (__irq_svc+0x40/0x70)
The reason is the sdma tasklet is async with audio substream release. ALSA
think when terminate dma, the dma should be stopped and no callback be called.
This patch is to add new api dma_sync_wait_tasklet(), which is called in
snd_dmaengine_pcm_close(). It will make sure the callback not be called
after this funtion. Tasklet_kill is to wait scheduled tasklet end.
Tasklet_kill can't be added to terminate dma function, because terminate dma
function may be called in interrupt, but tasklet_kill can't be called in
interrupt context.
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
As SSI has dual fifo, add src_dualfifo and dst_dualfifo in imx_dma_data
to support dual fifo in DMA_DEV_TO_DEV.
Since we have of_usb_set_otg_caps to cover all otg related features,
remove of_usb_otg_adp_support.
Since we introduce usb_otg_caps in ci_hdrc_platform_data to cover all otg
related features, remove adp_support from ci_hdrc_platform_data.
Remove bcdOTG from usb_otg_descriptor since we introduce usb_otg20_descriptor
for OTG 2.0 or above, and usb_otg_descriptor is only for OTG 1.x.
Allocate usb otg descriptor and initialize it according to gadget's otg
capabilities, if usb_otg_caps is not set, keep settings as current gadget
drivers. With this 2 new interfaces, gadget can use usb_otg_descriptor
for OTG 1.x, and usb_otg20_descriptor for OTG 2.0 or above, and otg
features can be decided by the combination of usb hardware property
and driver config.
Reviewed-by: Roger Quadros <rogerq@ti.com>
Set gadget's otg capabilities according to controller's capability and otg
properties in device tree.
Check property of usb hardware to get otg version and if SRP, HNP and ADP
are disabled.
