The keypad port (KPP) module is clocked by the IPG root clock
through clock gate CCM_CCGR170.
print_hex_dump_debug() is likely supposed to be analogous to pr_debug() or
dev_dbg() & friends. Currently it will adhere to dynamic debug, but will
not stub out prints if CONFIG_DEBUG is not set. Let's make it do the
right thing, because I am tired of having my dmesg buffer full of hex
dumps on production systems.
(cherry picked from commit cdf17449af1d9b596742c260134edd6c1fac2792)
Add support for ADV7280 decoder found on Toradex Analogue
Camera Adapter V2.0A
Signed-off-by: Sanchayan Maity <sanchayan.maity@toradex.com>
(cherry picked from commit 481bf320816c56c726197d6155341c2f94aeb6be)
Signed-off-by: Daniel Kochmanski <dkochmanski@antmicro.com>
(cherry picked from commit 7e934e8d9af114113c8de9bbf8b8728639fbc52d)
In order to use the auxiliar ADC inputs of STMPE811 devices we need
to add resources for the ADC block. Also move the ADC macros from
the touchscreen driver to the general header file. We will need them
for the ADC driver in future.
(cherry picked from commit 824e28985b9cccb8906500aa20b7c33a95e6608a)
drivers/mfd/stmpe.c
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
(cherry picked from commit 0487f174fa672b60c4fa491b43277b901bcf05d7)
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com>
(cherry picked from commit 6877ada3d15adf762cae8b7edce979a77ebc0313)
Rather than relying on special USB/PHY pins/registers use the
generic extcon framework with its extcon-usb-gpio implementation
to detect ID and VBUS changes.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
(cherry picked from commit be04dc33f409996c37d8c69702748890b4968c67)
Added platform data struct to define interrupt and reset GPIO. This
allows to initialize the touchscreen controller inside the driver
rather then in each platform and use the driver as a module.
(cherry picked from commit cb82730b70f31af3b43041ac4e47de69c18016c9)
(cherry picked from commit b0c045aef6b33205bffc1489a2887a88eae8809e)
This patch allows for easy integration of a custom Linux boot logo to
replace the Tux' being shown by default.
Use gimp or the like to create a raw PPM in your desired resolution.
Reduce the number of colours in the image to 224:
user@host:~$ ppmquant 224 Toradex-640x480.ppm > \
Toradex-640x480-224.ppm
ppmquant: making histogram...
ppmquant: 370 colors found
ppmquant: choosing 224 colors...
ppmquant: mapping image to new colors...
Convert it from raw PPM to ASCII format:
user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \
Toradex-640x480-ascii-224.ppm
Copy it into the Linux sources:
cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\
logo_custom_clut224.ppm
Activate exclusively custom Linux logo in the kernel configuration:
Device Drivers -> Graphics support -> Bootup logo ->
Custom 224-color Linux logo
And re-compile the kernel.
(cherry picked from commit fa2371bff9ac03581881849d8f95678ef3992719)
(cherry picked from commit f57ace3fcce595dfbd5c4eb70d0392c8a8f6282d)
The Ricoh RN5T567 is from the same family as the Ricoh RN5T618 is,
the differences are:
+ DCDC4
+ Slightly different output voltage/currents
+ 32kHz Output
- ADC/Charger capabilities
Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit ffa57d218bae244bdde3f4b3f4a77b00e9d3f1de)
The header file is used by the SPI and I2C variant of the driver.
Therefore, move it to a more generic place under platform_data.
(cherry picked from commit 4774f400935fbb44a25f5e8fd5c5583431e28ac1)
(cherry picked from commit d5c1c8db840babae16623c6fcbf7ec1934fda117)
Extend the driver to support Ricoh RN5T567. Support the additional
DCDC and slightly different voltage range of LDORTC1.
(cherry picked from commit 259bdcc12178dd99ebb96d70dccb65855a04e182)
Linux 4.1.35
* tag 'v4.1.35': (98 commits)
Linux 4.1.35
xhci: fix usb2 resume timing and races.
mm: remove gup_flags FOLL_WRITE games from __get_user_pages()
timekeeping: Fix __ktime_get_fast_ns() regression
time: Add cycles to nanoseconds translation
Linux 4.1.34
openrisc: fix the fix of copy_from_user()
avr32: fix 'undefined reference to `___copy_from_user'
fix memory leaks in tracing_buffers_splice_read()
tracing: Move mutex to protect against resetting of seq data
MIPS: SMP: Fix possibility of deadlock when bringing CPUs online
MIPS: Fix pre-r6 emulation FPU initialisation
btrfs: ensure that file descriptor used with subvol ioctls is a dir
fix fault_in_multipages_...() on architectures with no-op access_ok()
ocfs2: fix start offset to ocfs2_zero_range_for_truncate()
fanotify: fix list corruption in fanotify_get_response()
fsnotify: add a way to stop queueing events on group shutdown
autofs: use dentry flags to block walks during expire
autofs races
ocfs2/dlm: fix race between convert and migration
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ Upstream commit 19be0eaffa3ac7d8eb6784ad9bdbc7d67ed8e619 ]
This is an ancient bug that was actually attempted to be fixed once
(badly) by me eleven years ago in commit 4ceb5db9757a ("Fix
get_user_pages() race for write access") but that was then undone due to
problems on s390 by commit f33ea7f404e5 ("fix get_user_pages bug").
In the meantime, the s390 situation has long been fixed, and we can now
fix it by checking the pte_dirty() bit properly (and do it better). The
s390 dirty bit was implemented in abf09bed3cce ("s390/mm: implement
software dirty bits") which made it into v3.9. Earlier kernels will
have to look at the page state itself.
Also, the VM has become more scalable, and what used a purely
theoretical race back then has become easier to trigger.
To fix it, we introduce a new internal FOLL_COW flag to mark the "yes,
we already did a COW" rather than play racy games with FOLL_WRITE that
is very fundamental, and then use the pte dirty flag to validate that
the FOLL_COW flag is still valid.
Reported-and-tested-by: Phil "not Paul" Oester <kernel@linuxace.com>
Reviewed-by: Michal Hocko <mhocko@suse.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Nick Piggin <npiggin@gmail.com>
Cc: stable@vger.kernel.org
Linux 4.1.33
* tag 'v4.1.33': (1760 commits)
Linux 4.1.33
Revert "ARC: mm: don't loose PTE_SPECIAL in pte_modify()"
x86/AMD: Apply erratum 665 on machines without a BIOS fix
x86/paravirt: Do not trace _paravirt_ident_*() functions
ovl: listxattr: use strnlen()
ovl: remove posix_acl_default from workdir
serial: 8250: added acces i/o products quad and octal serial cards
sysfs: correctly handle read offset on PREALLOC attrs
sysfs: correctly handle short reads on PREALLOC attrs.
kernfs: don't depend on d_find_any_alias() when generating notifications
dm crypt: fix free of bad values after tfm allocation failure
dm crypt: fix error with too large bios
dm log writes: fix check of kthread_run() return value
dm log writes: fix bug with too large bios
dm log writes: move IO accounting earlier to fix error path
NFSv4.x: Fix a refcount leak in nfs_callback_up_net
xfs: prevent dropping ioend completions during buftarg wait
xfs: fix superblock inprogress check
USB: serial: option: add WeTelecom 0x6802 and 0x6803 products
USB: avoid left shift by -1
[ Upstream commit e23d4159b109167126e5bcd7f3775c95de7fee47 ]
Switching iov_iter fault-in to multipages variants has exposed an old
bug in underlying fault_in_multipages_...(); they break if the range
passed to them wraps around. Normally access_ok() done by callers will
prevent such (and it's a guaranteed EFAULT - ERR_PTR() values fall into
such a range and they should not point to any valid objects).
However, on architectures where userland and kernel live in different
MMU contexts (e.g. s390) access_ok() is a no-op and on those a range
with a wraparound can reach fault_in_multipages_...().
Since any wraparound means EFAULT there, the fix is trivial - turn
those
while (uaddr <= end)
into
if (unlikely(uaddr > end))
return -EFAULT;
do
while (uaddr <= end);
Reported-by: Jan Stancek <jstancek@redhat.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
Cc: stable@vger.kernel.org # v3.5+
[ Upstream commit 96d41019e3ac55f6f0115b0ce97e4f24a3d636d2 ]
fanotify_get_response() calls fsnotify_remove_event() when it finds that
group is being released from fanotify_release() (bypass_perm is set).
However the event it removes need not be only in the group's notification
queue but it can have already moved to access_list (userspace read the
event before closing the fanotify instance fd) which is protected by a
different lock. Thus when fsnotify_remove_event() races with
fanotify_release() operating on access_list, the list can get corrupted.
Fix the problem by moving all the logic removing permission events from
the lists to one place - fanotify_release().
Fixes: 5838d4442bd5 ("fanotify: fix double free of pending permission events")
Link: http://lkml.kernel.org/r/1473797711-14111-3-git-send-email-jack@suse.cz
Reported-by: Miklos Szeredi <mszeredi@redhat.com>
Tested-by: Miklos Szeredi <mszeredi@redhat.com>
Reviewed-by: Miklos Szeredi <mszeredi@redhat.com>
Cc: <stable@vger.kernel.org>
[ Upstream commit 12703dbfeb15402260e7554d32a34ac40c233990 ]
Implement a function that can be called when a group is being shutdown
to stop queueing new events to the group. Fanotify will use this.
Link: http://lkml.kernel.org/r/1473797711-14111-2-git-send-email-jack@suse.cz
[ Upstream commit d4690f1e1cdabb4d61207b6787b1605a0dc0aeab ]
... by turning it into what used to be multipages counterpart
[ Upstream commit 9ad18b75c2f6e4a78ce204e79f37781f8815c0fa ]
both for access_ok() failures and for faults halfway through
[ Upstream commit a02613a4ba679eacec8251976d02809d533fa717 ]
Current implemantation ptr argument evaluate 2 times.
It'll be an unexpected result.
Changes v5:
Remove unnecessary const.
Changes v4:
Temporary pointer type change to const void*
Changes v3:
Some build error fix.
Changes v2:
Argument x protect.
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
[ Upstream commit ebf9ff753c041b296241990aef76163bbb2cc9c8 ]
Some irqchip drivers need to take the generic chip lock outside of the
irq context.
Provide the irq_gc_{lock_irqsave,unlock_irqrestore}() helpers to allow
one to disable irqs while entering a critical section protected by
gc->lock.
Note that we do not provide optimized version of these helpers for !SMP,
because they are not called from the hot-path.
[ tglx: Added a comment when these helpers should be [not] used ]
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Link: http://lkml.kernel.org/r/1473775109-4192-1-git-send-email-boris.brezillon@free-electrons.com
[ Upstream commit 2545e5da080b4839dd859e3b09343a884f6ab0e3 ]
... in all cases, including the failing access_ok()
Note that some architectures using asm-generic/uaccess.h have
__copy_from_user() not zeroing the tail on failure halfway
through. This variant works either way.
[ Upstream commit 69874ec233871a62e1bc8c89e643993af93a8630 ]
Add the device ID for the PF of the NFP4000. The device ID for the VF,
0x6003, is already present as PCI_DEVICE_ID_NETRONOME_NFP6000_VF.
Signed-off-by: Simon Horman <simon.horman@netronome.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit a755e169031dac9ebaed03302c4921687c271d62 ]
Device IDs for the Netronome NFP3200, NFP3240, NFP6000, and NFP6000 SR-IOV
devices.
Signed-off-by: Jason S. McMullan <jason.mcmullan@netronome.com>
[simon: edited changelog]
[ Upstream commit 4097461897df91041382ff6fcd2bfa7ee6b2448c ]
As explained in 1407814240-4275-1-git-send-email-decui@microsoft.com we
have a hard load dependency between i8042 and atkbd which prevents
keyboard from working on Gen2 Hyper-V VMs.
> hyperv_keyboard invokes serio_interrupt(), which needs a valid serio
> driver like atkbd.c. atkbd.c depends on libps2.c because it invokes
> ps2_command(). libps2.c depends on i8042.c because it invokes
> i8042_check_port_owner(). As a result, hyperv_keyboard actually
> depends on i8042.c.
> For a Generation 2 Hyper-V VM (meaning no i8042 device emulated), if a
> Linux VM (like Arch Linux) happens to configure CONFIG_SERIO_I8042=m
> rather than =y, atkbd.ko can't load because i8042.ko can't load(due to
> no i8042 device emulated) and finally hyperv_keyboard can't work and
> the user can't input: https://bugs.archlinux.org/task/39820
> (Ubuntu/RHEL/SUSE aren't affected since they use CONFIG_SERIO_I8042=y)
To break the dependency we move away from using i8042_check_port_owner()
and instead allow serio port owner specify a mutex that clients should use
to serialize PS/2 command stream.
Reported-by: Mark Laws <mdl@60hz.org>
Tested-by: Mark Laws <mdl@60hz.org>
[ Upstream commit db1bb44c4c7e8d49ed674dc59e5222d99c698088 ]
We're always tracing IPv4 or IPv6 addresses, so we can save a lot
of space on the ringbuffer by allocating the correct sockaddr size.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Fixes: 83a712e0afef "sunrpc: add some tracepoints around ..."
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Add fb name check function pwm_backlight_check_fb_name(),
pwm driver can banding to fb with fb name when driver working
in device tree architecture.
Signed-off-by: Sandor Yu <Sandor.yu@nxp.com>
[ Upstream commit 3cb9185c67304b2a7ea9be73e7d13df6fb2793a1 ]
radix_tree_iter_retry() resets slot to NULL, but it doesn't reset tags.
Then NULL slot and non-zero iter.tags passed to radix_tree_next_slot()
leading to crash:
RIP: radix_tree_next_slot include/linux/radix-tree.h:473
find_get_pages_tag+0x334/0x930 mm/filemap.c:1452
Call Trace:
pagevec_lookup_tag+0x3a/0x80 mm/swap.c:960
mpage_prepare_extent_to_map+0x321/0xa90 fs/ext4/inode.c:2516
ext4_writepages+0x10be/0x2b20 fs/ext4/inode.c:2736
do_writepages+0x97/0x100 mm/page-writeback.c:2364
__filemap_fdatawrite_range+0x248/0x2e0 mm/filemap.c:300
filemap_write_and_wait_range+0x121/0x1b0 mm/filemap.c:490
ext4_sync_file+0x34d/0xdb0 fs/ext4/fsync.c:115
vfs_fsync_range+0x10a/0x250 fs/sync.c:195
vfs_fsync fs/sync.c:209
do_fsync+0x42/0x70 fs/sync.c:219
SYSC_fdatasync fs/sync.c:232
SyS_fdatasync+0x19/0x20 fs/sync.c:230
entry_SYSCALL_64_fastpath+0x23/0xc1 arch/x86/entry/entry_64.S:207
We must reset iterator's tags to bail out from radix_tree_next_slot()
and go to the slow-path in radix_tree_next_chunk().
Fixes: 46437f9a554f ("radix-tree: fix race in gang lookup")
Link: http://lkml.kernel.org/r/1468495196-10604-1-git-send-email-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Acked-by: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
[ Upstream commit e41f501d391265ff568f3e49d6128cc30856a36f ]
If CONFIG_KASAN is enabled and gcc is configured with
--disable-initfini-array and/or gold linker is used, gcc emits
.ctors/.dtors and .text.startup/.text.exit sections instead of
.init_array/.fini_array. .dtors section is not explicitly accounted in
the linker script and messes vvar/percpu layout.
We want:
ffffffff822bfd80 D _edata
ffffffff822c0000 D __vvar_beginning_hack
ffffffff822c0000 A __vvar_page
ffffffff822c0080 0000000000000098 D vsyscall_gtod_data
ffffffff822c1000 A __init_begin
ffffffff822c1000 D init_per_cpu__irq_stack_union
ffffffff822c1000 A __per_cpu_load
ffffffff822d3000 D init_per_cpu__gdt_page
We got:
ffffffff8279a600 D _edata
ffffffff8279b000 A __vvar_page
ffffffff8279c000 A __init_begin
ffffffff8279c000 D init_per_cpu__irq_stack_union
ffffffff8279c000 A __per_cpu_load
ffffffff8279e000 D __vvar_beginning_hack
ffffffff8279e080 0000000000000098 D vsyscall_gtod_data
ffffffff827ae000 D init_per_cpu__gdt_page
This happens because __vvar_page and .vvar get different addresses in
arch/x86/kernel/vmlinux.lds.S:
. = ALIGN(PAGE_SIZE);
__vvar_page = .;
.vvar : AT(ADDR(.vvar) - LOAD_OFFSET) {
/* work around gold bug 13023 */
__vvar_beginning_hack = .;
Discard .dtors/.fini_array/.text.exit, since we don't call dtors.
Merge .text.startup into init text.
Link: http://lkml.kernel.org/r/1467386363-120030-1-git-send-email-dvyukov@google.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Reviewed-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: <stable@vger.kernel.org> [4.0+]
[ Upstream commit abb2bafd295fe962bbadc329dbfb2146457283ac ]
The EFI firmware on Macs contains a full-fledged network stack for
downloading OS X images from osrecovery.apple.com. Unfortunately
on Macs introduced 2011 and 2012, EFI brings up the Broadcom 4331
wireless card on every boot and leaves it enabled even after
ExitBootServices has been called. The card continues to assert its IRQ
line, causing spurious interrupts if the IRQ is shared. It also corrupts
memory by DMAing received packets, allowing for remote code execution
over the air. This only stops when a driver is loaded for the wireless
card, which may be never if the driver is not installed or blacklisted.
The issue seems to be constrained to the Broadcom 4331. Chris Milsted
has verified that the newer Broadcom 4360 built into the MacBookPro11,3
(2013/2014) does not exhibit this behaviour. The chances that Apple will
ever supply a firmware fix for the older machines appear to be zero.
The solution is to reset the card on boot by writing to a reset bit in
its mmio space. This must be done as an early quirk and not as a plain
vanilla PCI quirk to successfully combat memory corruption by DMAed
packets: Matthew Garrett found out in 2012 that the packets are written
to EfiBootServicesData memory (http://mjg59.dreamwidth.org/11235.html).
This type of memory is made available to the page allocator by
efi_free_boot_services(). Plain vanilla PCI quirks run much later, in
subsys initcall level. In-between a time window would be open for memory
corruption. Random crashes occurring in this time window and attributed
to DMAed packets have indeed been observed in the wild by Chris
Bainbridge.
When Matthew Garrett analyzed the memory corruption issue in 2012, he
sought to fix it with a grub quirk which transitions the card to D3hot:
http://git.savannah.gnu.org/cgit/grub.git/commit/?id=9d34bb85da56
This approach does not help users with other bootloaders and while it
may prevent DMAed packets, it does not cure the spurious interrupts
emanating from the card. Unfortunately the card's mmio space is
inaccessible in D3hot, so to reset it, we have to undo the effect of
Matthew's grub patch and transition the card back to D0.
Note that the quirk takes a few shortcuts to reduce the amount of code:
The size of BAR 0 and the location of the PM capability is identical
on all affected machines and therefore hardcoded. Only the address of
BAR 0 differs between models. Also, it is assumed that the BCMA core
currently mapped is the 802.11 core. The EFI driver seems to always take
care of this.
Michael Büsch, Bjorn Helgaas and Matt Fleming contributed feedback
towards finding the best solution to this problem.
The following should be a comprehensive list of affected models:
iMac13,1 2012 21.5" [Root Port 00:1c.3 = 8086:1e16]
iMac13,2 2012 27" [Root Port 00:1c.3 = 8086:1e16]
Macmini5,1 2011 i5 2.3 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini5,2 2011 i5 2.5 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini5,3 2011 i7 2.0 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini6,1 2012 i5 2.5 GHz [Root Port 00:1c.1 = 8086:1e12]
Macmini6,2 2012 i7 2.3 GHz [Root Port 00:1c.1 = 8086:1e12]
MacBookPro8,1 2011 13" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro8,2 2011 15" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro8,3 2011 17" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro9,1 2012 15" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro9,2 2012 13" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro10,1 2012 15" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro10,2 2012 13" [Root Port 00:1c.1 = 8086:1e12]
For posterity, spurious interrupts caused by the Broadcom 4331 wireless
card resulted in splats like this (stacktrace omitted):
irq 17: nobody cared (try booting with the "irqpoll" option)
handlers:
[<ffffffff81374370>] pcie_isr
[<ffffffffc0704550>] sdhci_irq [sdhci] threaded [<ffffffffc07013c0>] sdhci_thread_irq [sdhci]
[<ffffffffc0a0b960>] azx_interrupt [snd_hda_codec]
Disabling IRQ #17
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=79301
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111781
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=728916
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=895951#c16
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1009819
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1098621
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1149632#c5
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1279130
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1332732
Tested-by: Konstantin Simanov <k.simanov@stlk.ru> # [MacBookPro8,1]
Tested-by: Lukas Wunner <lukas@wunner.de> # [MacBookPro9,1]
Tested-by: Bryan Paradis <bryan.paradis@gmail.com> # [MacBookPro9,2]
Tested-by: Andrew Worsley <amworsley@gmail.com> # [MacBookPro10,1]
Tested-by: Chris Bainbridge <chris.bainbridge@gmail.com> # [MacBookPro10,2]
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Chris Milsted <cmilsted@redhat.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Michael Buesch <m@bues.ch>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: b43-dev@lists.infradead.org
Cc: linux-pci@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: stable@vger.kernel.org # 123456789abc: x86/quirks: Apply nvidia_bugs quirk only on root bus
Cc: stable@vger.kernel.org # 123456789abc: x86/quirks: Reintroduce scanning of secondary buses
Link: http://lkml.kernel.org/r/48d0972ac82a53d460e5fce77a07b2560db95203.1465690253.git.lukas@wunner.de
[ Did minor readability edits. ]
[ Upstream commit 94477bff390aa4612d2332c8abafaae0a13d6923 ]
There are cases where it is desired to see if a proposed placement
is compatible with a buffer object before calling ttm_bo_validate().
Signed-off-by: Sinclair Yeh <syeh@vmware.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
This is the first of a 3-patch series to fix a black screen
issue observed on Ubuntu 16.04 server.
[ Upstream commit f4dc77713f8016d2e8a3295e1c9c53a21f296def ]
The dummy ruleset I used to test the original validation change was broken,
most rules were unreachable and were not tested by mark_source_chains().
In some cases rulesets that used to load in a few seconds now require
several minutes.
sample ruleset that shows the behaviour:
echo "*filter"
for i in $(seq 0 100000);do
printf ":chain_%06x - [0:0]\n" $i
done
printf -- "-A INPUT -j chain_%06x\n" $i
done
echo COMMIT
[ pipe result into iptables-restore ]
This ruleset will be about 74mbyte in size, with ~500k searches
though all 500k[1] rule entries. iptables-restore will take forever
(gave up after 10 minutes)
Instead of always searching the entire blob for a match, fill an
array with the start offsets of every single ipt_entry struct,
then do a binary search to check if the jump target is present or not.
After this change ruleset restore times get again close to what one
gets when reverting 36472341017529e (~3 seconds on my workstation).
[1] every user-defined rule gets an implicit RETURN, so we get
300k jumps + 100k userchains + 100k returns -> 500k rule entries
Fixes: 36472341017529e ("netfilter: x_tables: validate targets of jumps")
Reported-by: Jeff Wu <wujiafu@gmail.com>
Tested-by: Jeff Wu <wujiafu@gmail.com>
QSPI only support upto 16 LUT slots while the QSPI commands are more
than this number, reserve the last two slots for dynamic change (most
commands used in pairs). Later all extra supported commands will be add
in dynamic lut table.
Signed-off-by: Han Xu <han.xu@nxp.com>
[ Upstream commit d7591f0c41ce3e67600a982bab6989ef0f07b3ce ]
The three variants use same copy&pasted code, condense this into a
helper and use that.
Make sure info.name is 0-terminated.
[ Upstream commit 0188346f21e6546498c2a0f84888797ad4063fc5 ]
Always returned 0.
[ Upstream commit ce683e5f9d045e5d67d1312a42b359cb2ab2a13c ]
We're currently asserting that targetoff + targetsize <= nextoff.
Extend it to also check that targetoff is >= sizeof(xt_entry).
Since this is generic code, add an argument pointing to the start of the
match/target, we can then derive the base structure size from the delta.
We also need the e->elems pointer in a followup change to validate matches.
[ Upstream commit fc1221b3a163d1386d1052184202d5dc50d302d1 ]
32bit rulesets have different layout and alignment requirements, so once
more integrity checks get added to xt_check_entry_offsets it will reject
well-formed 32bit rulesets.
[ Upstream commit 7d35812c3214afa5b37a675113555259cfd67b98 ]
Currently arp/ip and ip6tables each implement a short helper to check that
the target offset is large enough to hold one xt_entry_target struct and
that t->u.target_size fits within the current rule.
Unfortunately these checks are not sufficient.
To avoid adding new tests to all of ip/ip6/arptables move the current
checks into a helper, then extend this helper in followup patches.
[ Upstream commit 759c01142a5d0f364a462346168a56de28a80f52 ]
On no-so-small systems, it is possible for a single process to cause an
OOM condition by filling large pipes with data that are never read. A
typical process filling 4000 pipes with 1 MB of data will use 4 GB of
memory. On small systems it may be tricky to set the pipe max size to
prevent this from happening.
This patch makes it possible to enforce a per-user soft limit above
which new pipes will be limited to a single page, effectively limiting
them to 4 kB each, as well as a hard limit above which no new pipes may
be created for this user. This has the effect of protecting the system
against memory abuse without hurting other users, and still allowing
pipes to work correctly though with less data at once.
The limit are controlled by two new sysctls : pipe-user-pages-soft, and
pipe-user-pages-hard. Both may be disabled by setting them to zero. The
default soft limit allows the default number of FDs per process (1024)
to create pipes of the default size (64kB), thus reaching a limit of 64MB
before starting to create only smaller pipes. With 256 processes limited
to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB =
1084 MB of memory allocated for a user. The hard limit is disabled by
default to avoid breaking existing applications that make intensive use
of pipes (eg: for splicing).
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
[ Upstream commit 2ccccf5fb43ff62b2b96cc58d95fc0b3596516e4 ]
When the bottom qdisc decides to, for example, drop some packet,
it calls qdisc_tree_decrease_qlen() to update the queue length
for all its ancestors, we need to update the backlog too to
keep the stats on root qdisc accurate.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit 86a7996cc8a078793670d82ed97d5a99bb4e8496 ]
Remove nearly duplicated code and prepare for the following patch.
[ Upstream commit f719e3754ee2f7275437e61a6afd520181fdd43b ]
Jiri Bohac is reporting for a problem where the attempt
to reschedule existing connection to another real server
needs proper redirect for the conntrack used by the IPVS
connection. For example, when IPVS connection is created
to NAT-ed real server we alter the reply direction of
conntrack. If we later decide to select different real
server we can not alter again the conntrack. And if we
expire the old connection, the new connection is left
without conntrack.
So, the only way to redirect both the IPVS connection and
the Netfilter's conntrack is to drop the SYN packet that
hits existing connection, to wait for the next jiffie
to expire the old connection and its conntrack and to rely
on client's retransmission to create new connection as
usually.
Jiri Bohac provided a fix that drops all SYNs on rescheduling,
I extended his patch to do such drops only for connections
that use conntrack. Here is the original report from Jiri Bohac:
Since commit dc7b3eb900aa ("ipvs: Fix reuse connection if real server
is dead"), new connections to dead servers are redistributed
immediately to new servers. The old connection is expired using
ip_vs_conn_expire_now() which sets the connection timer to expire
immediately.
However, before the timer callback, ip_vs_conn_expire(), is run
to clean the connection's conntrack entry, the new redistributed
connection may already be established and its conntrack removed
instead.
Fix this by dropping the first packet of the new connection
instead, like we do when the destination server is not available.
The timer will have deleted the old conntrack entry long before
the first packet of the new connection is retransmitted.
Fixes: dc7b3eb900aa ("ipvs: Fix reuse connection if real server is dead")
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
[ Upstream commit fe30937b65354c7fec244caebbdaae68e28ca797 ]
bond_get_stats() can be called from rtnetlink (with RTNL held)
or from /proc/net/dev seq handler (with RCU held)
The logic added in commit 5f0c5f73e5ef ("bonding: make global bonding
stats more reliable") kind of assumed only one cpu could run there.
If multiple threads are reading /proc/net/dev, stats can be really
messed up after a while.
A second problem is that some fields are 32bit, so we need to properly
handle the wrap around problem.
Given that RTNL is not always held, we need to use
bond_for_each_slave_rcu().
Fixes: 5f0c5f73e5ef ("bonding: make global bonding stats more reliable")
Cc: Andy Gospodarek <gospo@cumulusnetworks.com>
Cc: Jay Vosburgh <j.vosburgh@gmail.com>
Cc: Veaceslav Falico <vfalico@gmail.com>
Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 2793a23aacbd754dbbb5cb75093deb7e4103bace ]
Netdevice parameter hard_header_len is variously interpreted both as
an upper and lower bound on link layer header length. The field is
used as upper bound when reserving room at allocation, as lower bound
when validating user input in PF_PACKET.
Clarify the definition to be maximum header length. For validation
of untrusted headers, add an optional validate member to header_ops.
Allow bypassing of validation by passing CAP_SYS_RAWIO, for instance
for deliberate testing of corrupt input. In this case, pad trailing
bytes, as some device drivers expect completely initialized headers.
See also http://comments.gmane.org/gmane.linux.network/401064
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 880621c2605b82eb5af91a2c94223df6f5a3fb64 ]
Commit 9c7077622dd91 ("packet: make packet_snd fail on len smaller
than l2 header") added validation for the packet size in packet_snd.
This change enforces that every packet needs a header (with at least
hard_header_len bytes) plus a payload with at least one byte. Before
this change the payload was optional.
This fixes PPPoE connections which do not have a "Service" or
"Host-Uniq" configured (which is violating the spec, but is still
widely used in real-world setups). Those are currently failing with the
following message: "pppd: packet size is too short (24 <= 24)"
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
[ Upstream commit 1837b2e2bcd23137766555a63867e649c0b637f0 ]
The current reserved_tailroom calculation fails to take hlen and tlen into
account.
skb:
[__hlen__|__data____________|__tlen___|__extra__]
head skb_end_offset
In this representation, hlen + data + tlen is the size passed to alloc_skb.
"extra" is the extra space made available in __alloc_skb because of
rounding up by kmalloc. We can reorder the representation like so:
[__hlen__|__data____________|__extra__|__tlen___]
head skb_end_offset
The maximum space available for ip headers and payload without
fragmentation is min(mtu, data + extra). Therefore,
reserved_tailroom
= data + extra + tlen - min(mtu, data + extra)
= skb_end_offset - hlen - min(mtu, skb_end_offset - hlen - tlen)
= skb_tailroom - min(mtu, skb_tailroom - tlen) ; after skb_reserve(hlen)
Compare the second line to the current expression:
reserved_tailroom = skb_end_offset - min(mtu, skb_end_offset)
and we can see that hlen and tlen are not taken into account.
The min() in the third line can be expanded into:
if mtu < skb_tailroom - tlen:
reserved_tailroom = skb_tailroom - mtu
else:
reserved_tailroom = tlen
Depending on hlen, tlen, mtu and the number of multicast address records,
the current code may output skbs that have less tailroom than
dev->needed_tailroom or it may output more skbs than needed because not all
space available is used.
Fixes: 4c672e4b ("ipv6: mld: fix add_grhead skb_over_panic for devs with large MTUs")
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 4df2bf466a9c9c92f40d27c4aa9120f4e8227bfc ]
Otherwise loading a "snapshot" table using the same device for the
origin and COW devices, e.g.:
echo "0 20971520 snapshot 253:3 253:3 P 8" | dmsetup create snap
will trigger:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000098
[ 1958.979934] IP: [<ffffffffa040efba>] dm_exception_store_set_chunk_size+0x7a/0x110 [dm_snapshot]
[ 1958.989655] PGD 0
[ 1958.991903] Oops: 0000 [#1] SMP
[ 1959.059647] CPU: 9 PID: 3556 Comm: dmsetup Tainted: G IO 4.5.0-rc5.snitm+ #150
[ 1959.083517] task: ffff8800b9660c80 ti: ffff88032a954000 task.ti: ffff88032a954000
[ 1959.091865] RIP: 0010:[<ffffffffa040efba>] [<ffffffffa040efba>] dm_exception_store_set_chunk_size+0x7a/0x110 [dm_snapshot]
[ 1959.104295] RSP: 0018:ffff88032a957b30 EFLAGS: 00010246
[ 1959.110219] RAX: 0000000000000000 RBX: 0000000000000008 RCX: 0000000000000001
[ 1959.118180] RDX: 0000000000000000 RSI: 0000000000000008 RDI: ffff880329334a00
[ 1959.126141] RBP: ffff88032a957b50 R08: 0000000000000000 R09: 0000000000000001
[ 1959.134102] R10: 000000000000000a R11: f000000000000000 R12: ffff880330884d80
[ 1959.142061] R13: 0000000000000008 R14: ffffc90001c13088 R15: ffff880330884d80
[ 1959.150021] FS: 00007f8926ba3840(0000) GS:ffff880333440000(0000) knlGS:0000000000000000
[ 1959.159047] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1959.165456] CR2: 0000000000000098 CR3: 000000032f48b000 CR4: 00000000000006e0
[ 1959.173415] Stack:
[ 1959.175656] ffffc90001c13040 ffff880329334a00 ffff880330884ed0 ffff88032a957bdc
[ 1959.183946] ffff88032a957bb8 ffffffffa040f225 ffff880329334a30 ffff880300000000
[ 1959.192233] ffffffffa04133e0 ffff880329334b30 0000000830884d58 00000000569c58cf
[ 1959.200521] Call Trace:
[ 1959.203248] [<ffffffffa040f225>] dm_exception_store_create+0x1d5/0x240 [dm_snapshot]
[ 1959.211986] [<ffffffffa040d310>] snapshot_ctr+0x140/0x630 [dm_snapshot]
[ 1959.219469] [<ffffffffa0005c44>] ? dm_split_args+0x64/0x150 [dm_mod]
[ 1959.226656] [<ffffffffa0005ea7>] dm_table_add_target+0x177/0x440 [dm_mod]
[ 1959.234328] [<ffffffffa0009203>] table_load+0x143/0x370 [dm_mod]
[ 1959.241129] [<ffffffffa00090c0>] ? retrieve_status+0x1b0/0x1b0 [dm_mod]
[ 1959.248607] [<ffffffffa0009e35>] ctl_ioctl+0x255/0x4d0 [dm_mod]
[ 1959.255307] [<ffffffff813304e2>] ? memzero_explicit+0x12/0x20
[ 1959.261816] [<ffffffffa000a0c3>] dm_ctl_ioctl+0x13/0x20 [dm_mod]
[ 1959.268615] [<ffffffff81215eb6>] do_vfs_ioctl+0xa6/0x5c0
[ 1959.274637] [<ffffffff81120d2f>] ? __audit_syscall_entry+0xaf/0x100
[ 1959.281726] [<ffffffff81003176>] ? do_audit_syscall_entry+0x66/0x70
[ 1959.288814] [<ffffffff81216449>] SyS_ioctl+0x79/0x90
[ 1959.294450] [<ffffffff8167e4ae>] entry_SYSCALL_64_fastpath+0x12/0x71
[ 1959.323277] RIP [<ffffffffa040efba>] dm_exception_store_set_chunk_size+0x7a/0x110 [dm_snapshot]
[ 1959.333090] RSP <ffff88032a957b30>
[ 1959.336978] CR2: 0000000000000098
[ 1959.344121] ---[ end trace b049991ccad1169e ]---
Fixes: https://bugzilla.redhat.com/show_bug.cgi?id=1195899
Signed-off-by: Ding Xiang <dingxiang@huawei.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
