Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Kai Bankett <chaosman@ontika.net>
Acked-by: Anders Larsen <al@alarsen.net>
Acked-by: Bob Copeland <me@bobcopeland.com>
Cc: Anton Altaparmakov <anton@tuxera.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Cc: Joern Engel <joern@logfs.org>
Cc: Prasad Joshi <prasadjoshi.linux@gmail.com>
Cc: Benny Halevy <bhalevy@tonian.com>
Acked-by: Boaz Harrosh <bharrosh@panasas.com>
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: Dustin Kirkland <dustin.kirkland@gazzang.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Note sysctl_hugetlb_shm_group can only be written in the root user
in the initial user namespace, so we can assume sysctl_hugetlb_shm_group
is in the initial user namespace.
Cc: William Irwin <wli@holomorphy.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Felipe Balbi <balbi@ti.com>
Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Now that the type changes are done, here is the final set of
changes to make the quota code work when user namespaces are enabled.
Small cleanups and fixes to make the code build when user namespaces
are enabled.
Cc: Jan Kara <jack@suse.cz>
Modify quota_send_warning to take struct kqid instead a type and
identifier pair.
When sending netlink broadcasts always convert uids and quota
identifiers into the intial user namespace. There is as yet no way to
send a netlink broadcast message with different contents to receivers
in different namespaces, so for the time being just map all of the
identifiers into the initial user namespace which preserves the
current behavior.
Change the callers of quota_send_warning in gfs2, xfs and dquot
to generate a struct kqid to pass to quota send warning. When
all of the user namespaces convesions are complete a struct kqid
values will be availbe without need for conversion, but a conversion
is needed now to avoid needing to convert everything at once.
Cc: Ben Myers <bpm@sgi.com>
Cc: Alex Elder <elder@kernel.org>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Update the quotactl user space interface to successfull compile with
user namespaces support enabled and to hand off quota identifiers to
lower layers of the kernel in struct kqid instead of type and qid
pairs.
The quota on function is not converted because while it takes a quota
type and an id. The id is the on disk quota format to use, which
is something completely different.
The signature of two struct quotactl_ops methods were changed to take
struct kqid argumetns get_dqblk and set_dqblk.
The dquot, xfs, and ocfs2 implementations of get_dqblk and set_dqblk
are minimally changed so that the code continues to work with
the change in parameter type.
This is the first in a series of changes to always store quota
identifiers in the kernel in struct kqid and only use raw type and qid
values when interacting with on disk structures or userspace. Always
using struct kqid internally makes it hard to miss places that need
conversion to or from the kernel internal values.
Cc: Mark Fasheh <mfasheh@suse.com>
Convert ext2, ext3, and ext4 to fully support the posix acl changes,
using e_uid e_gid instead e_id.
Enabled building with posix acls enabled, all filesystems supporting
user namespaces, now also support posix acls when user namespaces are enabled.
Cc: Theodore Tso <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
- When tracing capture the kuid.
- When displaying the data to user space convert the kuid into the
user namespace of the process that opened the report file.
BSD process accounting conveniently passes the file the accounting
records will be written into to do_acct_process. The file credentials
captured the user namespace of the opener of the file. Use the file
credentials to format the uid and the gid of the current process into
the user namespace of the user that started the bsd process
accounting.
Cc: Pavel Emelyanov <xemul@openvz.org>
Reviewed-by: Serge Hallyn <serge.hallyn@canonical.com>
- Explicitly limit exit task stat broadcast to the initial user and
pid namespaces, as it is already limited to the initial network
namespace.
- For broadcast task stats explicitly generate all of the idenitiers
in terms of the initial user namespace and the initial pid
namespace.
- For request stats report them in terms of the current user namespace
and the current pid namespace. Netlink messages are delivered
syncrhonously to the kernel allowing us to get the user namespace
and the pid namespace from the current task.
- Pass the namespaces for representing pids and uids and gids
into bacct_add_task.
Cc: Balbir Singh <bsingharora@gmail.com>
- Explicitly format uids gids in audit messges in the initial user
namespace. This is safe because auditd is restrected to be in
- Convert audit_sig_uid into a kuid_t.
- Enable building the audit code and user namespaces at the same time.
The net result is that the audit subsystem now uses kuid_t and kgid_t whenever
possible making it almost impossible to confuse a raw uid_t with a kuid_t
preventing bugs.
Cc: Eric Paris <eparis@redhat.com>
This patch adds Makefile and Kconfig files required for building an
AArch64 kernel.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
0, 0
In net/dns_resolver/dns_key.c and net/rxrpc/ar-key.c make them
work with user namespaces enabled where key_alloc takes kuids and kgids.
Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID instead of bare 0's.
Cc: Sage Weil <sage@inktank.com>
Cc: ceph-devel@vger.kernel.org
Cc: linux-afs@lists.infradead.org
- Replace key_user ->user_ns equality checks with kuid_has_mapping checks.
- Use from_kuid to generate key descriptions
- Use kuid_t and kgid_t and the associated helpers instead of uid_t and gid_t
- Avoid potential problems with file descriptor passing by displaying
keys in the user namespace of the opener of key status proc files.
Cc: linux-security-module@vger.kernel.org
Cc: keyrings@linux-nfs.org
Blink Blink this had not been converted to use struct pid ages ago?
- On drm open capture the openers kuid and struct pid.
- On drm close release the kuid and struct pid
- When reporting the uid and pid convert the kuid and struct pid
into values in the appropriate namespace.
Cc: dri-devel@lists.freedesktop.org
Acked-by: Dave Airlie <airlied@redhat.com>
- Store the ipc owner and creator with a kuid
- Store the ipc group and the crators group with a kgid.
- Add error handling to ipc_update_perms, allowing it to
fail if the uids and gids can not be converted to kuids
or kgids.
- Modify the proc files to display the ipc creator and
owner in the user namespace of the opener of the proc file.
- Only allow asking for events from the initial user and pid namespace,
where we generate the events in.
- Convert kuids and kgids into the initial user namespace to report
them via the process event connector.
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
CONFIG_HOTPLUG is a very old option, back when we had static systems and it was
odd that any type of device would be removed or added after the system had
started up. It is quite hard to disable it these days, and even if you do, it
only saves you about 200 bytes. However, if it is disabled, lots of bugs show
up because it is almost never tested if the option is disabled.
This is a step to eventually just remove the option entirely, which will clean
up all of the devinit* variable and function pointer options, that everyone
(myself include) ends up getting wrong eventually, causing real problems when
memory segments are removed yet we don't expect them to be.
Cc: Bjorn Helgaas <bhelgaas@google.com>
enabled.
Enable building of pf_key sockets and user namespace support at the
same time. This combination builds successfully so there is no reason
to forbid it.
S390, ia64 and powerpc all define their own version
of CONFIG_VIRT_CPU_ACCOUNTING. Generalize the config
and its description to a single place to avoid
duplication.
Cc: Maxim Krasnyansky <maxk@qualcomm.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: John W. Linville <linville@tuxdriver.com>
- Only allow adding matches from the initial user namespace
- Add the appropriate conversion functions to handle matches
against sockets in other user namespaces.
Cc: Jan Engelhardt <jengelh@medozas.de>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
user namespace
xt_recent creates a bunch of proc files and initializes their uid
and gids to the values of ip_list_uid and ip_list_gid. When
initialize those proc files convert those values to kuids so they
can continue to reside on the /proc inode.
xt_LOG always writes messages via sb_add via printk. Therefore when
xt_LOG logs the uid and gid of a socket a packet came from the
values should be converted to be in the initial user namespace.
Thus making xt_LOG as user namespace safe as possible.
The flow classifier can use uids and gids of the sockets that
are transmitting packets and do insert those uids and gids
into the packet classification calcuation. I don't fully
understand the details but it appears that we can depend
on specific uids and gids when making traffic classification
decisions.
To work with user namespaces enabled map from kuids and kgids
into uids and gids in the initial user namespace giving raw
integer values the code can play with and depend on.
To avoid issues of userspace depending on uids and gids in
packet classifiers installed from other user namespaces
and getting confused deny all packet classifiers that
use uids or gids that are not comming from a netlink socket
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Changli Gao <xiaosuo@gmail.com>
