path: root/init/do_mounts_rd.c
2016-11-24init: use pr_cont() when displaying rotator during ramdisk loading.Nicolas Schichan
Otherwise each individual rotator char would be printed in a new line: (...) [ 0.642350] - [ 0.644374] | [ 0.646367] - (...) Signed-off-by: Nicolas Schichan <nicolas.schichan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-26init, Documentation: Remove ramdisk_blocksize mentionsRobert Elliott
The brd driver has never supported the ramdisk_blocksize kernel parameter that was in the rd driver it replaced, so remove mention of this parameter from comments and Documentation. Commit 9db5579be4bb ("rewrite rd") replaced rd with brd, keeping a brd_blocksize variable in struct brd_device but never using it. Commit a2cba2913c76 ("brd: get rid of unused members from struct brd_device") removed the unused variable. Commit f5abc8e75815 ("Documentation/blockdev/ramdisk.txt: updates") removed mentions of ramdisk_blocksize from that file. Signed-off-by: Robert Elliott <elliott@hpe.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2014-08-08initramfs: support initramfs that is bigger than 2GiBYinghai Lu
Now with 64bit bzImage and kexec tools, we support ramdisk that size is bigger than 2g, as we could put it above 4G. Found compressed initramfs image could not be decompressed properly. It turns out that image length is int during decompress detection, and it will become < 0 when length is more than 2G. Furthermore, during decompressing len as int is used for inbuf count, that has problem too. Change len to long, that should be ok as on 32 bit platform long is 32bits. Tested with following compressed initramfs image as root with kexec. gzip, bzip2, xz, lzma, lzop, lz4. run time for populate_rootfs(): size name Nehalem-EX Westmere-EX Ivybridge-EX 9034400256 root_img : 26s 24s 30s 3561095057 root_img.lz4 : 28s 27s 27s 3459554629 root_img.lzo : 29s 29s 28s 3219399480 root_img.gz : 64s 62s 49s 2251594592 root_img.xz : 262s 260s 183s 2226366598 root_img.lzma: 386s 376s 277s 2901482513 root_img.bz2 : 635s 599s Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rashika Kheria <rashika.kheria@gmail.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Cc: P J P <ppandit@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Cc: "Daniel M. Weeks" <dan@danweeks.net> Cc: Alexandre Courbot <acourbot@nvidia.com> Cc: Jan Beulich <JBeulich@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-25cramfs: take headers to fs/cramfsAl Viro
2013-11-13./Makefile: export initial ramdisk compression config optionP J P
Make menuconfig allows one to choose compression format of an initial ramdisk image. But this choice does not result in duly compressed ramdisk image. Because - $ make install - does not pass on the selected compression choice to the dracut(8) tool, which creates the initramfs file. dracut(8) generates the image with the default compression, ie. gzip(1). This patch exports the selected compression option to a sub-shell environment, so that it could be used by dracut(8) tool to generate appropriately compressed initramfs images. There isn't a straightforward way to pass on options to dracut(8) via positional parameters. Because it is indirectly invoked at the end of a $ make install sequence. # make install -> arch/$arch/boot/Makefile -> arch/$arch/boot/install.sh -> /sbing/installkernel ... -> /sbin/new-kernel-pkg ... -> /sbin/dracut ... Signed-off-by: P J P <ppandit@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13init/do_mounts_rd.c: fix NULL pointer dereference while loading initramfsP J P
Make menuconfig allows one to choose compression format of an initial ramdisk image. But this choice does not result in duly compressed initial ramdisk image. Because - $ make install - does not pass on the selected compression choice to the dracut(8) tool, which creates the initramfs file. dracut(8) generates the image with the default compression, ie. gzip(1). If a user chose any other compression instead of gzip(1), it leads to a crash due to NULL pointer dereference in crd_load(), caused by a NULL function pointer returned by the 'decompress_method()' routine. Because the initramfs image is gzip(1) compressed, whereas the kernel knows only to decompress the chosen format and not gzip(1). This patch replaces the crash by an explicit panic() call with an appropriate error message. This shall prevent the kernel from eventually panicking in: init/do_mounts.c: mount_block_root() with -> panic("VFS: Unable to mount root fs on %s", b); [akpm@linux-foundation.org: mention that the problem is with the ramdisk, don't print known-to-be-NULL value] Signed-off-by: P J P <prasad@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31init: disable sparse checking of the mount.o source filesH Hartley Sweeten
The init/mount.o source files produce a number of sparse warnings of the type: warning: incorrect type in argument 1 (different address spaces) expected char [noderef] <asn:1>*dev_name got char *name This is due to the syscalls expecting some of the arguments to be user pointers but they are being passed as kernel pointers. This is harmless but adds a lot of noise to a sparse build. To limit the noise just disable the sparse checking in the relevant source files, but still display a warning so that the user knows this has been done. Since the sparse checking has been disabled we can also remove the __user __force casts that are scattered thru the source. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-31new helper: ext2_image_size()Al Viro
... implemented that way since the next commit will leave it almost alone in ext2_fs.h - most of the file (including struct ext2_super_block) is going to move to fs/ext2/ext2.h. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-21init: Remove CONFIG_PPC_ISERIESStephen Rothwell
It is no longer selectable, so remove the check for it. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-11-02init/do_mounts_rd.c: fix ramdisk identification for padded cramfsNeil Armstrong
When a cramfs ramdisk padded with 512 bytes is given to the kernel, the current identify_ramdisk_image function fails to identify it. Tested with a padded cramfs image on an ARM based board. Signed-off-by: Neil Armstrong <narmstrong@neotion.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Davidlohr Bueso <dave@gnu.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22init: return proper error code in do_mounts_rd()Davidlohr Bueso
In do_mounts_rd() if memory cannot be allocated, return -ENOMEM. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26init: mark __user address space on string literalsNamhyung Kim
When calling syscall service routines in kernel, some of arguments should be user pointers but were missing __user markup on string literals. Add it. Removes some sparse warnings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-01-14init: make initrd/initramfs decompression failure a KERN_EMERG eventH. Peter Anvin
Impact: More consistent behaviour, avoid policy in the kernel Upgrade/downgrade initrd/initramfs decompression failure from inconsistently a panic or a KERN_ALERT message to a KERN_EMERG event. It is, however, possible do design a system which can recover from this (using the kernel builtin code and/or the internal initramfs), which means this is policy, not a technical necessity. A good way to handle this would be to have a panic-level=X option, to force a panic on a printk above a certain level. That is a separate patch, however. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-01-12bzip2/lzma: comprehensible error messages for missing decompressorH. Peter Anvin
Instead of failing to identify a compressed image with a decompressor that we don't have compiled in, identify it and fail with a comprehensible panic message. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-01-10Merge branch 'linus' into x86/setup-lzmaIngo Molnar
Conflicts: init/do_mounts_rd.c
2009-01-08bzip2/lzma: centralize format detectionH. Peter Anvin
Centralize the compression format detection to a common routine in the lib directory, and use it for both initramfs and initrd. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-05Squashfs: initrd supportPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-01-04bzip2/lzma: use a table to search for initramfs compression formatsH. Peter Anvin
Impact: Code simplification Instead of open-coding testing for initramfs compression formats, use a table. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-04bzip2/lzma: config and initramfs support for bzip2/lzma decompressionAlain Knaff
Impact: New code for initramfs decompression, new features This is the second part of the bzip2/lzma patch The bzip patch is based on an idea by Christian Ludwig, includes support for compressing the kernel with bzip2 or lzma rather than gzip. Both compressors give smaller sizes than gzip. Lzma's decompresses faster than bzip2. It also supports ramdisks and initramfs' compressed using these two compressors. The functionality has been successfully used for a couple of years by the udpcast project This version applies to "tip" kernel 2.6.28 This part contains: - support for new compressions (bzip2 and lzma) in initramfs and old-style ramdisk - config dialog for kernel compression (but new kernel compressions not yet supported) Signed-off-by: Alain Knaff <alain@knaff.lu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-16identify_ramdisk_image(): correct typo about return value in commentGeert Uytterhoeven
identify_ramdisk_image() returns 0 (not -1) if a gzipped ramdisk is found: if (buf[0] == 037 && ((buf[1] == 0213) || (buf[1] == 0236))) { printk(KERN_NOTICE "RAMDISK: Compressed image found at block %d\n", start_block); nblocks = 0; ^^^^^^^^^^^ goto done; } ... done: sys_lseek(fd, start_block * BLOCK_SIZE, 0); kfree(buf); return nblocks; ^^^^^^^^^^^^^^ Hence correct the typo in the comment, which has existed since the addition of compressed ramdisk support in 1.3.48. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25inflate: refactor inflate malloc codeThomas Petazzoni
Inflate requires some dynamic memory allocation very early in the boot process and this is provided with a set of four functions: malloc/free/gzip_mark/gzip_release. The old inflate code used a mark/release strategy rather than implement free. This new version instead keeps a count on the number of outstanding allocations and when it hits zero, it resets the malloc arena. This allows removing all the mark and release implementations and unifying all the malloc/free implementations. The architecture-dependent code must define two addresses: - free_mem_ptr, the address of the beginning of the area in which allocations should be made - free_mem_end_ptr, the address of the end of the area in which allocations should be made. If set to 0, then no check is made on the number of allocations, it just grows as much as needed The architecture-dependent code can also provide an arch_decomp_wdog() function call. This function will be called several times during the decompression process, and allow to notify the watchdog that the system is still running. If an architecture provides such a call, then it must define ARCH_HAS_DECOMP_WDOG so that the generic inflate code calls arch_decomp_wdog(). Work initially done by Matt Mackall, updated to a recent version of the kernel and improved by me. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <mikael.starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25init/: delete hard-coded setting and testing of BUILD_CRAMDISKRobert P. J. Day
There seems to be little point in explicitly setting, then testing the macro BUILD_CRAMDISK within the context of a single source file. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28init: fix integer as NULL pointer warningsHarvey Harrison
init/do_mounts_rd.c:215:13: warning: Using plain integer as NULL pointer init/do_mounts_md.c:136:45: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-26[PATCH] devfs: Remove devfs from the init codeGreg Kroah-Hartman
This patch removes the devfs code from the init/ directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
