path: root/init/do_mounts_rd.c
2009-01-14init: make initrd/initramfs decompression failure a KERN_EMERG eventH. Peter Anvin
Impact: More consistent behaviour, avoid policy in the kernel Upgrade/downgrade initrd/initramfs decompression failure from inconsistently a panic or a KERN_ALERT message to a KERN_EMERG event. It is, however, possible do design a system which can recover from this (using the kernel builtin code and/or the internal initramfs), which means this is policy, not a technical necessity. A good way to handle this would be to have a panic-level=X option, to force a panic on a printk above a certain level. That is a separate patch, however. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-01-12bzip2/lzma: comprehensible error messages for missing decompressorH. Peter Anvin
Instead of failing to identify a compressed image with a decompressor that we don't have compiled in, identify it and fail with a comprehensible panic message. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-01-10Merge branch 'linus' into x86/setup-lzmaIngo Molnar
Conflicts: init/do_mounts_rd.c
2009-01-08bzip2/lzma: centralize format detectionH. Peter Anvin
Centralize the compression format detection to a common routine in the lib directory, and use it for both initramfs and initrd. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-05Squashfs: initrd supportPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-01-04bzip2/lzma: use a table to search for initramfs compression formatsH. Peter Anvin
Impact: Code simplification Instead of open-coding testing for initramfs compression formats, use a table. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-04bzip2/lzma: config and initramfs support for bzip2/lzma decompressionAlain Knaff
Impact: New code for initramfs decompression, new features This is the second part of the bzip2/lzma patch The bzip patch is based on an idea by Christian Ludwig, includes support for compressing the kernel with bzip2 or lzma rather than gzip. Both compressors give smaller sizes than gzip. Lzma's decompresses faster than bzip2. It also supports ramdisks and initramfs' compressed using these two compressors. The functionality has been successfully used for a couple of years by the udpcast project This version applies to "tip" kernel 2.6.28 This part contains: - support for new compressions (bzip2 and lzma) in initramfs and old-style ramdisk - config dialog for kernel compression (but new kernel compressions not yet supported) Signed-off-by: Alain Knaff <alain@knaff.lu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-16identify_ramdisk_image(): correct typo about return value in commentGeert Uytterhoeven
identify_ramdisk_image() returns 0 (not -1) if a gzipped ramdisk is found: if (buf[0] == 037 && ((buf[1] == 0213) || (buf[1] == 0236))) { printk(KERN_NOTICE "RAMDISK: Compressed image found at block %d\n", start_block); nblocks = 0; ^^^^^^^^^^^ goto done; } ... done: sys_lseek(fd, start_block * BLOCK_SIZE, 0); kfree(buf); return nblocks; ^^^^^^^^^^^^^^ Hence correct the typo in the comment, which has existed since the addition of compressed ramdisk support in 1.3.48. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25inflate: refactor inflate malloc codeThomas Petazzoni
Inflate requires some dynamic memory allocation very early in the boot process and this is provided with a set of four functions: malloc/free/gzip_mark/gzip_release. The old inflate code used a mark/release strategy rather than implement free. This new version instead keeps a count on the number of outstanding allocations and when it hits zero, it resets the malloc arena. This allows removing all the mark and release implementations and unifying all the malloc/free implementations. The architecture-dependent code must define two addresses: - free_mem_ptr, the address of the beginning of the area in which allocations should be made - free_mem_end_ptr, the address of the end of the area in which allocations should be made. If set to 0, then no check is made on the number of allocations, it just grows as much as needed The architecture-dependent code can also provide an arch_decomp_wdog() function call. This function will be called several times during the decompression process, and allow to notify the watchdog that the system is still running. If an architecture provides such a call, then it must define ARCH_HAS_DECOMP_WDOG so that the generic inflate code calls arch_decomp_wdog(). Work initially done by Matt Mackall, updated to a recent version of the kernel and improved by me. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <mikael.starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25init/: delete hard-coded setting and testing of BUILD_CRAMDISKRobert P. J. Day
There seems to be little point in explicitly setting, then testing the macro BUILD_CRAMDISK within the context of a single source file. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28init: fix integer as NULL pointer warningsHarvey Harrison
init/do_mounts_rd.c:215:13: warning: Using plain integer as NULL pointer init/do_mounts_md.c:136:45: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-26[PATCH] devfs: Remove devfs from the init codeGreg Kroah-Hartman
This patch removes the devfs code from the init/ directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
