path: root/init/main.c
2015-09-10kmod: use system_unbound_wq instead of khelperFrederic Weisbecker
We need to launch the usermodehelper kernel threads with the widest affinity and this is partly why we use khelper. This workqueue has unbound properties and thus a wide affinity inherited by all its children. Now khelper also has special properties that we aren't much interested in: ordered and singlethread. There is really no need about ordering as all we do is creating kernel threads. This can be done concurrently. And singlethread is a useless limitation as well. The workqueue engine already proposes generic unbound workqueues that don't share these useless properties and handle well parallel jobs. The only worrysome specific is their affinity to the node of the current CPU. It's fine for creating the usermodehelper kernel threads but those inherit this affinity for longer jobs such as requesting modules. This patch proposes to use these node affine unbound workqueues assuming that a node is sufficient to handle several parallel usermodehelper requests. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-07fs, file table: reinit files_stat.max_files after deferred memory initialisationMel Gorman
Dave Hansen reported the following; My laptop has been behaving strangely with 4.2-rc2. Once I log in to my X session, I start getting all kinds of strange errors from applications and see this in my dmesg: VFS: file-max limit 8192 reached The problem is that the file-max is calculated before memory is fully initialised and miscalculates how much memory the kernel is using. This patch recalculates file-max after deferred memory initialisation. Note that using memory hotplug infrastructure would not have avoided this problem as the value is not recalculated after memory hot-add. 4.1: files_stat.max_files = 6582781 4.2-rc2: files_stat.max_files = 8192 4.2-rc2 patched: files_stat.max_files = 6562467 Small differences with the patch applied and 4.1 but not enough to matter. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Dave Hansen <dave.hansen@intel.com> Cc: Nicolai Stange <nicstange@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Alex Ng <alexng@microsoft.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: finish initialisation of struct pages before basic setupMel Gorman
Waiman Long reported that 24TB machines hit OOM during basic setup when struct page initialisation was deferred. One approach is to initialise memory on demand but it interferes with page allocator paths. This patch creates dedicated threads to initialise memory before basic setup. It then blocks on a rw_semaphore until completion as a wait_queue and counter is overkill. This may be slower to boot but it's simplier overall and also gets rid of a section mangling which existed so kswapd could do the initialisation. [akpm@linux-foundation.org: include rwsem.h, use DECLARE_RWSEM, fix comment, remove unneeded cast] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Waiman Long <waiman.long@hp.com Cc: Nathan Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Scott Norton <scott.norton@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-26Merge tag 'driver-core-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here is the driver core / firmware changes for 4.2-rc1. A number of small changes all over the place in the driver core, and in the firmware subsystem. Nothing really major, full details in the shortlog. Some of it is a bit of churn, given that the platform driver probing changes was found to not work well, so they were reverted. All of these have been in linux-next for a while with no reported issues" * tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits) Revert "base/platform: Only insert MEM and IO resources" Revert "base/platform: Continue on insert_resource() error" Revert "of/platform: Use platform_device interface" Revert "base/platform: Remove code duplication" firmware: add missing kfree for work on async call fs: sysfs: don't pass count == 0 to bin file readers base:dd - Fix for typo in comment to function driver_deferred_probe_trigger(). base/platform: Remove code duplication of/platform: Use platform_device interface base/platform: Continue on insert_resource() error base/platform: Only insert MEM and IO resources firmware: use const for remaining firmware names firmware: fix possible use after free on name on asynchronous request firmware: check for file truncation on direct firmware loading firmware: fix __getname() missing failure check drivers: of/base: move of_init to driver_init drivers/base: cacheinfo: fix annoying typo when DT nodes are absent sysfs: disambiguate between "error code" and "failure" in comments driver-core: fix build for !CONFIG_MODULES driver-core: make __device_attach() static ...
2015-06-10ACPI / init: Switch over platform to the ACPI mode laterRafael J. Wysocki
Commit 73f7d1ca3263 "ACPI / init: Run acpi_early_init() before timekeeping_init()" moved the ACPI subsystem initialization, including the ACPI mode enabling, to an earlier point in the initialization sequence, to allow the timekeeping subsystem use ACPI early. Unfortunately, that resulted in boot regressions on some systems and the early ACPI initialization was moved toward its original position in the kernel initialization code by commit c4e1acbb35e4 "ACPI / init: Invoke early ACPI initialization later". However, that turns out to be insufficient, as boot is still broken on the Tyan S8812 mainboard. To fix that issue, split the ACPI early initialization code into two pieces so the majority of it still located in acpi_early_init() and the part switching over the platform into the ACPI mode goes into a new function, acpi_subsystem_init(), executed at the original early ACPI initialization spot. That fixes the Tyan S8812 boot problem, but still allows ACPI tables to be loaded earlier which is useful to the EFI code in efi_enter_virtual_mode(). Link: https://bugzilla.kernel.org/show_bug.cgi?id=97141 Fixes: 73f7d1ca3263 "ACPI / init: Run acpi_early_init() before timekeeping_init()" Reported-and-tested-by: Marius Tolzmann <tolzmann@molgen.mpg.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org> Reviewed-by: Lee, Chun-Yi <jlee@suse.com>
2015-05-20module: add extra argument for parse_params() callbackLuis R. Rodriguez
This adds an extra argument onto parse_params() to be used as a way to make the unused callback a bit more useful and generic by allowing the caller to pass on a data structure of its choice. An example use case is to allow us to easily make module parameters for every module which we will do next. @ parse @ identifier name, args, params, num, level_min, level_max; identifier unknown, param, val, doing; type s16; @@ extern char *parse_args(const char *name, char *args, const struct kernel_param *params, unsigned num, s16 level_min, s16 level_max, + void *arg, int (*unknown)(char *param, char *val, const char *doing + , void *arg )); @ parse_mod @ identifier name, args, params, num, level_min, level_max; identifier unknown, param, val, doing; type s16; @@ char *parse_args(const char *name, char *args, const struct kernel_param *params, unsigned num, s16 level_min, s16 level_max, + void *arg, int (*unknown)(char *param, char *val, const char *doing + , void *arg )) { ... } @ parse_args_found @ expression R, E1, E2, E3, E4, E5, E6; identifier func; @@ ( R = parse_args(E1, E2, E3, E4, E5, E6, + NULL, func); | R = parse_args(E1, E2, E3, E4, E5, E6, + NULL, &func); | R = parse_args(E1, E2, E3, E4, E5, E6, + NULL, NULL); | parse_args(E1, E2, E3, E4, E5, E6, + NULL, func); | parse_args(E1, E2, E3, E4, E5, E6, + NULL, &func); | parse_args(E1, E2, E3, E4, E5, E6, + NULL, NULL); ) @ parse_args_unused depends on parse_args_found @ identifier parse_args_found.func; @@ int func(char *param, char *val, const char *unused + , void *arg ) { ... } @ mod_unused depends on parse_args_found @ identifier parse_args_found.func; expression A1, A2, A3; @@ - func(A1, A2, A3); + func(A1, A2, A3, NULL); Generated-by: Coccinelle SmPL Cc: cocci@systeme.lip6.fr Cc: Tejun Heo <tj@kernel.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Hellwig <hch@infradead.org> Cc: Felipe Contreras <felipe.contreras@gmail.com> Cc: Ewan Milne <emilne@redhat.com> Cc: Jean Delvare <jdelvare@suse.de> Cc: Hannes Reinecke <hare@suse.de> Cc: Jani Nikula <jani.nikula@intel.com> Cc: linux-kernel@vger.kernel.org Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-17kernel/fork.c: new function for max_threadsHeinrich Schuchardt
PAGE_SIZE is not guaranteed to be equal to or less than 8 times the THREAD_SIZE. E.g. architecture hexagon may have page size 1M and thread size 4096. This would lead to a division by zero in the calculation of max_threads. With this patch the buggy code is moved to a separate function set_max_threads. The error is not fixed. After fixing the problem in a separate patch the new function can be reused to adjust max_threads after adding or removing memory. Argument mempages of function fork_init() is removed as totalram_pages is an exported symbol. The creation of separate patches for refactoring to a new function and for fixing the logic was suggested by Ingo Molnar. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge first patchbomb from Andrew Morton: - arch/sh updates - ocfs2 updates - kernel/watchdog feature - about half of mm/ * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (122 commits) Documentation: update arch list in the 'memtest' entry Kconfig: memtest: update number of test patterns up to 17 arm: add support for memtest arm64: add support for memtest memtest: use phys_addr_t for physical addresses mm: move memtest under mm mm, hugetlb: abort __get_user_pages if current has been oom killed mm, mempool: do not allow atomic resizing memcg: print cgroup information when system panics due to panic_on_oom mm: numa: remove migrate_ratelimited mm: fold arch_randomize_brk into ARCH_HAS_ELF_RANDOMIZE mm: split ET_DYN ASLR from mmap ASLR s390: redefine randomize_et_dyn for ELF_ET_DYN_BASE mm: expose arch_mmap_rnd when available s390: standardize mmap_rnd() usage powerpc: standardize mmap_rnd() usage mips: extract logic for mmap_rnd() arm64: standardize mmap_rnd() usage x86: standardize mmap_rnd() usage arm: factor out mmap ASLR into mmap_rnd ...
2015-04-14lib/ioremap.c: add huge I/O map capability interfacesToshi Kani
Add ioremap_pud_enabled() and ioremap_pmd_enabled(), which return 1 when I/O mappings with pud/pmd are enabled on the kernel. ioremap_huge_init() calls arch_ioremap_pud_supported() and arch_ioremap_pmd_supported() to initialize the capabilities at boot-time. A new kernel option "nohugeiomap" is also added, so that user can disable the huge I/O map capabilities when necessary. Signed-off-by: Toshi Kani <toshi.kani@hp.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Robert Elliott <Elliott@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU changes from Ingo Molnar: "The main changes in this cycle were: - changes permitting use of call_rcu() and friends very early in boot, for example, before rcu_init() is invoked. - add in-kernel API to enable and disable expediting of normal RCU grace periods. - improve RCU's handling of (hotplug-) outgoing CPUs. - NO_HZ_FULL_SYSIDLE fixes. - tiny-RCU updates to make it more tiny. - documentation updates. - miscellaneous fixes" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (58 commits) cpu: Provide smpboot_thread_init() on !CONFIG_SMP kernels as well cpu: Defer smpboot kthread unparking until CPU known to scheduler rcu: Associate quiescent-state reports with grace period rcu: Yet another fix for preemption and CPU hotplug rcu: Add diagnostics to grace-period cleanup rcutorture: Default to grace-period-initialization delays rcu: Handle outgoing CPUs on exit from idle loop cpu: Make CPU-offline idle-loop transition point more precise rcu: Eliminate ->onoff_mutex from rcu_node structure rcu: Process offlining and onlining only at grace-period start rcu: Move rcu_report_unblock_qs_rnp() to common code rcu: Rework preemptible expedited bitmask handling rcu: Remove event tracing from rcu_cpu_notify(), used by offline CPUs rcutorture: Enable slow grace-period initializations rcu: Provide diagnostic option to slow down grace-period initialization rcu: Detect stalls caused by failure to propagate up rcu_node tree rcu: Eliminate empty HOTPLUG_CPU ifdef rcu: Simplify sync_rcu_preempt_exp_init() rcu: Put all orphan-callback-related code under same comment rcu: Consolidate offline-CPU callback initialization ...
2015-04-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Usual trivial tree updates. Nothing outstanding -- mostly printk() and comment fixes and unused identifier removals" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: goldfish: goldfish_tty_probe() is not using 'i' any more powerpc: Fix comment in smu.h qla2xxx: Fix printks in ql_log message lib: correct link to the original source for div64_u64 si2168, tda10071, m88ds3103: Fix firmware wording usb: storage: Fix printk in isd200_log_config() qla2xxx: Fix printk in qla25xx_setup_mode init/main: fix reset_device comment ipwireless: missing assignment goldfish: remove unreachable line of code coredump: Fix do_coredump() comment stacktrace.h: remove duplicate declaration task_struct smpboot.h: Remove unused function prototype treewide: Fix typo in printk messages treewide: Fix typo in printk messages mod_devicetable: fix comment for match_flags
2015-04-13cpu: Defer smpboot kthread unparking until CPU known to schedulerPaul E. McKenney
Currently, smpboot_unpark_threads() is invoked before the incoming CPU has been added to the scheduler's runqueue structures. This might potentially cause the unparked kthread to run on the wrong CPU, since the correct CPU isn't fully set up yet. That causes a sporadic, hard to debug boot crash triggering on some systems, reported by Borislav Petkov, and bisected down to: 2a442c9c6453 ("x86: Use common outgoing-CPU-notification code") This patch places smpboot_unpark_threads() in a CPU hotplug notifier with priority set so that these kthreads are unparked just after the CPU has been added to the runqueues. Reported-and-tested-by: Borislav Petkov <bp@suse.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-03-06init/main: fix reset_device commentFrans Klaver
Fix incorrect spelling of situation. Signed-off-by: Frans Klaver <fransklaver@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-03-05cpuset: initialize cpuset a bit earlyZefan Li
Now we call ss->bind() in cgroup_init(), so cgroup_init() will call cpuset_bind() and then the latter will access top_cpuset's cpumask, which is NULL, because cpuset_init() is called after cgroup_init() The simplest fix is to swap cgroup_init() and cpuset_init(). Cc: Vladimir Davydov <vdavydov@parallels.com> Fixes: 295458e67284 ("cgroup: call cgroup_subsys->bind on cgroup subsys initialization") Reported by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vladimir Davydov <vdavydov@parallels.com>
2015-02-13init: remove CONFIG_INIT_FALLBACKAndy Lutomirski
CONFIG_INIT_FALLBACK adds config bloat without an obvious use case that makes it worth keeping around. Delete it. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Chuck Ebbert <cebbert.lkml@gmail.com> Cc: Frank Rowand <frowand.list@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Rob Landley <rob@landley.net> Cc: Shuah Khan <shuah.kh@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-22init: Get rid of x86ismsThomas Gleixner
The UP local API support can be set up from an early initcall. No need for horrible hackery in the init code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/20150115211703.827943883@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #2 from Al Viro: "Next pile (and there'll be one or two more). The large piece in this one is getting rid of /proc/*/ns/* weirdness; among other things, it allows to (finally) make nameidata completely opaque outside of fs/namei.c, making for easier further cleanups in there" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coda_venus_readdir(): use file_inode() fs/namei.c: fold link_path_walk() call into path_init() path_init(): don't bother with LOOKUP_PARENT in argument fs/namei.c: new helper (path_cleanup()) path_init(): store the "base" pointer to file in nameidata itself make default ->i_fop have ->open() fail with ENXIO make nameidata completely opaque outside of fs/namei.c kill proc_ns completely take the targets of /proc/*/ns/* symlinks to separate fs bury struct proc_ns in fs/proc copy address of proc_ns_ops into ns_common new helpers: ns_alloc_inum/ns_free_inum make proc_ns_operations work with struct ns_common * instead of void * switch the rest of proc_ns_operations to working with &...->ns netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns common object embedded into various struct ....ns
2014-12-16Merge tag 'trace-3.19-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "As the merge window is still open, and this code was not as complex as I thought it might be. I'm pushing this in now. This will allow Thomas to debug his irq work for 3.20. This adds two new features: 1) Allow traceopoints to be enabled right after mm_init(). By passing in the trace_event= kernel command line parameter, tracepoints can be enabled at boot up. For debugging things like the initialization of interrupts, it is needed to have tracepoints enabled very early. People have asked about this before and this has been on my todo list. As it can be helpful for Thomas to debug his upcoming 3.20 IRQ work, I'm pushing this now. This way he can add tracepoints into the IRQ set up and have users enable them when things go wrong. 2) Have the tracepoints printed via printk() (the console) when they are triggered. If the irq code locks up or reboots the box, having the tracepoint output go into the kernel ring buffer is useless for debugging. But being able to add the tp_printk kernel command line option along with the trace_event= option will have these tracepoints printed as they occur, and that can be really useful for debugging early lock up or reboot problems. This code is not that intrusive and it passed all my tests. Thomas tried them out too and it works for his needs. Link: http://lkml.kernel.org/r/20141214201609.126831471@goodmis.org" * tag 'trace-3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Add tp_printk cmdline to have tracepoints go to printk() tracing: Move enabling tracepoints to just after rcu_init()
2014-12-15tracing: Move enabling tracepoints to just after rcu_init()Steven Rostedt (Red Hat)
Enabling tracepoints at boot up can be very useful. The tracepoint can be initialized right after RCU has been. There's no need to wait for the early_initcall() to be called. That's too late for some things that can use tracepoints for debugging. Move the logic to enable tracepoints out of the initcalls and into init/main.c to right after rcu_init(). This also allows trace_printk() to be used early too. Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1412121539300.16494@nanos Link: http://lkml.kernel.org/r/20141214164104.307127356@goodmis.org Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Suggested-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-12-14Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security layer updates from James Morris: "In terms of changes, there's general maintenance to the Smack, SELinux, and integrity code. The IMA code adds a new kconfig option, IMA_APPRAISE_SIGNED_INIT, which allows IMA appraisal to require signatures. Support for reading keys from rootfs before init is call is also added" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits) selinux: Remove security_ops extern security: smack: fix out-of-bounds access in smk_parse_smack() VFS: refactor vfs_read() ima: require signature based appraisal integrity: provide a hook to load keys when rootfs is ready ima: load x509 certificate from the kernel integrity: provide a function to load x509 certificate from the kernel integrity: define a new function integrity_read_file() Security: smack: replace kzalloc with kmem_cache for inode_smack Smack: Lock mode for the floor and hat labels ima: added support for new kernel cmdline parameter ima_template_fmt ima: allocate field pointers array on demand in template_desc_init_fields() ima: don't allocate a copy of template_fmt in template_desc_init_fields() ima: display template format in meas. list if template name length is zero ima: added error messages to template-related functions ima: use atomic bit operations to protect policy update interface ima: ignore empty and with whitespaces policy lines ima: no need to allocate entry for comment ima: report policy load status ima: use path names cache ...
2014-12-13mm/page_ext: resurrect struct page extending code for debuggingJoonsoo Kim
When we debug something, we'd like to insert some information to every page. For this purpose, we sometimes modify struct page itself. But, this has drawbacks. First, it requires re-compile. This makes us hesitate to use the powerful debug feature so development process is slowed down. And, second, sometimes it is impossible to rebuild the kernel due to third party module dependency. At third, system behaviour would be largely different after re-compile, because it changes size of struct page greatly and this structure is accessed by every part of kernel. Keeping this as it is would be better to reproduce errornous situation. This feature is intended to overcome above mentioned problems. This feature allocates memory for extended data per page in certain place rather than the struct page itself. This memory can be accessed by the accessor functions provided by this code. During the boot process, it checks whether allocation of huge chunk of memory is needed or not. If not, it avoids allocating memory at all. With this advantage, we can include this feature into the kernel in default and can avoid rebuild and solve related problems. Until now, memcg uses this technique. But, now, memcg decides to embed their variable to struct page itself and it's code to extend struct page has been removed. I'd like to use this code to develop debug feature, so this patch resurrect it. To help these things to work well, this patch introduces two callbacks for clients. One is the need callback which is mandatory if user wants to avoid useless memory allocation at boot-time. The other is optional, init callback, which is used to do proper initialization after memory is allocated. Detailed explanation about purpose of these functions is in code comment. Please refer it. Others are completely same with previous extension code in memcg. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Dave Hansen <dave@sr71.net> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Jungsoo Son <jungsoo.son@lge.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10Merge branch 'nsfs' into for-nextAl Viro
2014-12-10take the targets of /proc/*/ns/* symlinks to separate fsAl Viro
New pseudo-filesystem: nsfs. Targets of /proc/*/ns/* live there now. It's not mountable (not even registered, so it's not in /proc/filesystems, etc.). Files on it *are* bindable - we explicitly permit that in do_loopback(). This stuff lives in fs/nsfs.c now; proc_ns_fget() moved there as well. get_proc_ns() is a macro now (it's simply returning ->i_private; would have been an inline, if not for header ordering headache). proc_ns_inode() is an ex-parrot. The interface used in procfs is ns_get_path(path, task, ops) and ns_get_name(buf, size, task, ops). Dentries and inodes are never hashed; a non-counting reference to dentry is stashed in ns_common (removed by ->d_prune()) and reused by ns_get_path() if present. See ns_get_path()/ns_prune_dentry/nsfs_evict() for details of that mechanism. As the result, proc_ns_follow_link() has stopped poking in nd->path.mnt; it does nd_jump_link() on a consistent <vfsmount,dentry> pair it gets from ns_get_path(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-10init: allow CONFIG_INIT_FALLBACK=n to disable defaults if init= failsAndy Lutomirski
If a user puts init=/whatever on the command line and /whatever can't be run, then the kernel will try a few default options before giving up. If init=/whatever came from a bootloader prompt, then this is unexpected but probably harmless. On the other hand, if it comes from a script (e.g. a tool like virtme or perhaps a future kselftest script), then the fallbacks are likely to exist, but they'll do the wrong thing. For example, they might unexpectedly invoke systemd. This adds a config option CONFIG_INIT_FALLBACK. If unset, then a failure to run the specified init= process be fatal. The tentative plan is to remove CONFIG_INIT_FALLBACK for 3.20. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Rob Landley <rob@landley.net> Cc: Chuck Ebbert <cebbert.lkml@gmail.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Shuah Khan <shuah.kh@samsung.com> Cc: Frank Rowand <frowand.list@gmail.com> Cc: Josh Triplett <josh@joshtriplett.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10mm: embed the memcg pointer directly into struct pageJohannes Weiner
Memory cgroups used to have 5 per-page pointers. To allow users to disable that amount of overhead during runtime, those pointers were allocated in a separate array, with a translation layer between them and struct page. There is now only one page pointer remaining: the memcg pointer, that indicates which cgroup the page is associated with when charged. The complexity of runtime allocation and the runtime translation overhead is no longer justified to save that *potential* 0.19% of memory. With CONFIG_SLUB, page->mem_cgroup actually sits in the doubleword padding after the page->private member and doesn't even increase struct page, and then this patch actually saves space. Remaining users that care can still compile their kernels without CONFIG_MEMCG. text data bss dec hex filename 8828345 1725264 983040 11536649 b00909 vmlinux.old 8827425 1725264 966656 11519345 afc571 vmlinux.new [mhocko@suse.cz: update Documentation/cgroups/memory.txt] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vladimir Davydov <vdavydov@parallels.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-19Merge branch 'next' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into next
2014-11-17integrity: provide a hook to load keys when rootfs is readyDmitry Kasatkin
Keys can only be loaded once the rootfs is mounted. Initcalls are not suitable for that. This patch defines a special hook to load the x509 public keys onto the IMA keyring, before attempting to access any file. The keys are required for verifying the file's signature. The hook is called after the root filesystem is mounted and before the kernel calls 'init'. Changes in v3: * added more explanation to the patch description (Mimi) Changes in v2: * Hook renamed as 'integrity_load_keys()' to handle both IMA and EVM keys by integrity subsystem. * Hook patch moved after defining loading functions Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-11-11param: fix crash on bad kernel argumentsDaniel Thompson
Currently if the user passes an invalid value on the kernel command line then the kernel will crash during argument parsing. On most systems this is very hard to debug because the console hasn't been initialized yet. This is a regression due to commit 51e158c12aca ("param: hand arguments after -- straight to init") which, in response to the systemd debug controversy, made it possible to explicitly pass arguments to init. To achieve this parse_args() was extended from simply returning an error code to returning a pointer. Regretably the new init args logic does not perform a proper validity check on the pointer resulting in a crash. This patch fixes the validity check. Should the check fail then no arguments will be passed to init. This is reasonable and matches how the kernel treats its own arguments (i.e. no error recovery). Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Cc: stable@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2014-10-14kernel/param: consolidate __{start,stop}___param[] in <linux/moduleparam.h>Geert Uytterhoeven
Consolidate the various external const and non-const declarations of __start___param[] and __stop___param in <linux/moduleparam.h>. This requires making a few struct kernel_param pointers in kernel/params.c const. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-13Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes in this cycle were: - Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave Hansen) - Various sched/idle refinements for better idle handling (Nicolas Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot) - sched/numa updates and optimizations (Rik van Riel) - sysbench speedup (Vincent Guittot) - capacity calculation cleanups/refactoring (Vincent Guittot) - Various cleanups to thread group iteration (Oleg Nesterov) - Double-rq-lock removal optimization and various refactorings (Kirill Tkhai) - various sched/deadline fixes ... and lots of other changes" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits) sched/dl: Use dl_bw_of() under rcu_read_lock_sched() sched/fair: Delete resched_cpu() from idle_balance() sched, time: Fix build error with 64 bit cputime_t on 32 bit systems sched: Improve sysbench performance by fixing spurious active migration sched/x86: Fix up typo in topology detection x86, sched: Add new topology for multi-NUMA-node CPUs sched/rt: Use resched_curr() in task_tick_rt() sched: Use rq->rd in sched_setaffinity() under RCU read lock sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask' sched: Use dl_bw_of() under RCU read lock sched/fair: Remove duplicate code from can_migrate_task() sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW sched: print_rq(): Don't use tasklist_lock sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock() sched: Fix the task-group check in tg_has_rt_tasks() sched/fair: Leverage the idle state info when choosing the "idlest" cpu sched: Let the scheduler see CPU idle states sched/deadline: Fix inter- exclusive cpusets migrations sched/deadline: Clear dl_entity params when setscheduling to different class sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault() ...
2014-10-13Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main changes in this cycle were: - changes related to No-CBs CPUs and NO_HZ_FULL - RCU-tasks implementation - torture-test updates - miscellaneous fixes - locktorture updates - RCU documentation updates" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (81 commits) workqueue: Use cond_resched_rcu_qs macro workqueue: Add quiescent state between work items locktorture: Cleanup header usage locktorture: Cannot hold read and write lock locktorture: Fix __acquire annotation for spinlock irq locktorture: Support rwlocks rcu: Eliminate deadlock between CPU hotplug and expedited grace periods locktorture: Document boot/module parameters rcutorture: Rename rcutorture_runnable parameter locktorture: Add test scenario for rwsem_lock locktorture: Add test scenario for mutex_lock locktorture: Make torture scripting account for new _runnable name locktorture: Introduce torture context locktorture: Support rwsems locktorture: Add infrastructure for torturing read locks torture: Address race in module cleanup locktorture: Make statistics generic locktorture: Teach about lock debugging locktorture: Support mutexes locktorture: Add documentation ...
2014-09-19init/main.c: Give init_task a canaryAaron Tomlin
Tasks get their end of stack set to STACK_END_MAGIC with the aim to catch stack overruns. Currently this feature does not apply to init_task. This patch removes this restriction. Note that a similar patch was posted by Prarit Bhargava some time ago but was never merged: http://marc.info/?l=linux-kernel&m=127144305403241&w=2 Signed-off-by: Aaron Tomlin <atomlin@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: aneesh.kumar@linux.vnet.ibm.com Cc: dzickus@redhat.com Cc: bmr@redhat.com Cc: jcastillo@redhat.com Cc: jgh@redhat.com Cc: minchan@kernel.org Cc: tglx@linutronix.de Cc: hannes@cmpxchg.org Cc: Alex Thorlton <athorlton@sgi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Daeseok Youn <daeseok.youn@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Fabian Frederick <fabf@skynet.be> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Michael Opdenacker <michael.opdenacker@free-electrons.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/1410527779-8133-2-git-send-email-atomlin@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-09-16rcu: Fix attempt to avoid unsolicited offloading of callbacksPaul E. McKenney
Commit b58cc46c5f6b (rcu: Don't offload callbacks unless specifically requested) failed to adjust the callback lists of the CPUs that are known to be no-CBs CPUs only because they are also nohz_full= CPUs. This failure can result in callbacks that are posted during early boot getting stranded on nxtlist for CPUs whose no-CBs property becomes apparent late, and there can also be spurious warnings about offline CPUs posting callbacks. This commit fixes these problems by adding an early-boot rcu_init_nohz() that properly initializes the no-CBs CPUs. Note that kernels built with CONFIG_RCU_NOCB_CPU_ALL=y or with CONFIG_RCU_NOCB_CPU=n do not exhibit this bug. Neither do kernels booted without the nohz_full= boot parameter. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Pranith Kumar <bobby.prani@gmail.com> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-09-13nohz: Move nohz full init call to tick initFrederic Weisbecker
This way we unbloat a bit main.c and more importantly we initialize nohz full after init_IRQ(). This dependency will be needed in further patches because nohz full needs irq work to raise its own IRQ. Information about the support for this ability on ARM64 is obtained on init_IRQ() which initialize the pointer to __smp_call_function. Since tick_init() is called right after init_IRQ(), this is a good place to call tick_nohz_init() and prepare for that dependency. Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2014-08-08init/main.c: code clean-upFabian Frederick
Fixing some checkpatch warnings(remove global initialization, move __initdata, coalesce formats ...) Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-11Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Most of this is cleaning up various driver sysfs permissions so we can re-add the perm check (we unified the module param and sysfs checks, but the module ones were stronger so we weakened them temporarily). Param parsing gets documented, and also "--" now forces args to be handed to init (and ignored by the kernel). Module NX/RO protections get tightened: we now set them before calling parse_args()" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: set nx before marking module MODULE_STATE_COMING. samples/kobject/: avoid world-writable sysfs files. drivers/hid/hid-picolcd_fb: avoid world-writable sysfs files. drivers/staging/speakup/: avoid world-writable sysfs files. drivers/regulator/virtual: avoid world-writable sysfs files. drivers/scsi/pm8001/pm8001_ctl.c: avoid world-writable sysfs files. drivers/hid/hid-lg4ff.c: avoid world-writable sysfs files. drivers/video/fbdev/sm501fb.c: avoid world-writable sysfs files. drivers/mtd/devices/docg3.c: avoid world-writable sysfs files. speakup: fix incorrect perms on speakup_acntsa.c cpumask.h: silence warning with -Wsign-compare Documentation: Update kernel-parameters.tx param: hand arguments after -- straight to init modpost: Fix resource leak in read_dump()
2014-06-05Merge branch 'x86/espfix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull x86-64 espfix changes from Peter Anvin: "This is the espfix64 code, which fixes the IRET information leak as well as the associated functionality problem. With this code applied, 16-bit stack segments finally work as intended even on a 64-bit kernel. Consequently, this patchset also removes the runtime option that we added as an interim measure. To help the people working on Linux kernels for very small systems, this patchset also makes these compile-time configurable features" * 'x86/espfix' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Revert "x86-64, modify_ldt: Make support for 16-bit segments a runtime option" x86, espfix: Make it possible to disable 16-bit support x86, espfix: Make espfix64 a Kconfig option, fix UML x86, espfix: Fix broken header guard x86, espfix: Move espfix definitions into a separate header file x86-32, espfix: Remove filter for espfix32 due to race x86-64, espfix: Don't leak bits 31:16 of %esp returning to 16-bit stack
2014-06-04init/main.c: remove an ifdefAndrew Morton
2014-06-04kthreads: kill CLONE_KERNEL, change kernel_thread(kernel_init) to avoid ↵Oleg Nesterov
CLONE_SIGHAND 1. Remove CLONE_KERNEL, it has no users and it is dangerous. The (old) comment says "List of flags we want to share for kernel threads" but this is not true, we do not want to share ->sighand by default. This flag can only be used if the caller is sure that both parent/child will never play with signals (say, allow_signal/etc). 2. Change rest_init() to clone kernel_init() without CLONE_SIGHAND. In this case CLONE_SIGHAND does not really hurt, and it looks like optimization because copy_sighand() can avoid kmem_cache_alloc(). But in fact this only adds the minor pessimization. kernel_init() is going to exec the init process, and de_thread() will need to unshare ->sighand and do kmem_cache_alloc(sighand_cachep) anyway, but it needs to do more work and take tasklist_lock and siglock. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04init/main.c: add initcall_blacklist kernel parameterPrarit Bhargava
When a module is built into the kernel the module_init() function becomes an initcall. Sometimes debugging through dynamic debug can help, however, debugging built in kernel modules is typically done by changing the .config, recompiling, and booting the new kernel in an effort to determine exactly which module caused a problem. This patchset can be useful stand-alone or combined with initcall_debug. There are cases where some initcalls can hang the machine before the console can be flushed, which can make initcall_debug output inaccurate. Having the ability to skip initcalls can help further debugging of these scenarios. Usage: initcall_blacklist=<list of comma separated initcalls> ex) added "initcall_blacklist=sgi_uv_sysfs_init" as a kernel parameter and the log contains: blacklisting initcall sgi_uv_sysfs_init ... ... initcall sgi_uv_sysfs_init blacklisted ex) added "initcall_blacklist=foo_bar,sgi_uv_sysfs_init" as a kernel parameter and the log contains: blacklisting initcall foo_bar blacklisting initcall sgi_uv_sysfs_init ... ... initcall sgi_uv_sysfs_init blacklisted [akpm@linux-foundation.org: tweak printk text] Signed-off-by: Prarit Bhargava <prarit@redhat.com> Cc: Richard Weinberger <richard.weinberger@gmail.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: Rob Landley <rob@landley.net> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04init/main.c: don't use pr_debug()Andrew Morton
Pertially revert commit ea676e846a81 ("init/main.c: convert to pr_foo()"). Unbeknownst to me, pr_debug() is different from the other pr_foo() levels: pr_debug() is a no-op when DEBUG is not defined. Happily, init/main.c does have a #define DEBUG so we didn't break initcall_debug. But the functioning of initcall_debug should not be dependent upon the presence of that #define DEBUG. Reported-by: Russell King <rmk@arm.linux.org.uk> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04kernel/printk: use symbolic defines for console loglevelsBorislav Petkov
... instead of naked numbers. Stuff in sysrq.c used to set it to 8 which is supposed to mean above default level so set it to DEBUG instead as we're terminating/killing all tasks and we want to be verbose there. Also, correct the check in x86_64_start_kernel which should be >= as we're clearly issuing the string there for all debug levels, not only the magical 10. Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Joe Perches <joe@perches.com> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04memcg: kill start_kernel()->mm_init_owner(&init_mm)Oleg Nesterov
Remove start_kernel()->mm_init_owner(&init_mm, &init_task). This doesn't really hurt but unnecessary and misleading. init_task is the "swapper" thread == current, its ->mm is always NULL. And init_mm can only be used as ->active_mm, not as ->mm. mm_init_owner() has a single caller with this patch, perhaps it should die. mm_init() can initialize ->owner under #ifdef. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Peter Chiang <pchiang@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-21Merge commit '7ed6fb9b5a5510e4ef78ab27419184741169978a' into x86/espfixH. Peter Anvin
Merge in Linus' tree with: fa81511bb0bb x86-64, modify_ldt: Make support for 16-bit segments a runtime option ... reverted, to avoid a conflict. This commit is no longer necessary with the proper fix in place. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-05-05asmlinkage: Add explicit __visible to drivers/*, lib/*, kernel/*Andi Kleen
As requested by Linus add explicit __visible to the asmlinkage users. This marks functions visible to assembler. Tree sweep for rest of tree. Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1398984278-29319-4-git-send-email-andi@firstfloor.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-05-04x86, espfix: Make espfix64 a Kconfig option, fix UMLH. Peter Anvin
Make espfix64 a hidden Kconfig option. This fixes the x86-64 UML build which had broken due to the non-existence of init_espfix_bsp() in UML: since UML uses its own Kconfig, this option does not appear in the UML build. This also makes it possible to make support for 16-bit segments a configuration option, for the people who want to minimize the size of the kernel. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Richard Weinberger <richard@nod.at> Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
2014-04-30x86-64, espfix: Don't leak bits 31:16 of %esp returning to 16-bit stackH. Peter Anvin
The IRET instruction, when returning to a 16-bit segment, only restores the bottom 16 bits of the user space stack pointer. This causes some 16-bit software to break, but it also leaks kernel state to user space. We have a software workaround for that ("espfix") for the 32-bit kernel, but it relies on a nonzero stack segment base which is not available in 64-bit mode. In checkin: b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels we "solved" this by forbidding 16-bit segments on 64-bit kernels, with the logic that 16-bit support is crippled on 64-bit kernels anyway (no V86 support), but it turns out that people are doing stuff like running old Win16 binaries under Wine and expect it to work. This works around this by creating percpu "ministacks", each of which is mapped 2^16 times 64K apart. When we detect that the return SS is on the LDT, we copy the IRET frame to the ministack and use the relevant alias to return to userspace. The ministacks are mapped readonly, so if IRET faults we promote #GP to #DF which is an IST vector and thus has its own stack; we then do the fixup in the #DF handler. (Making #GP an IST exception would make the msr_safe functions unsafe in NMI/MC context, and quite possibly have other effects.) Special thanks to: - Andy Lutomirski, for the suggestion of using very small stack slots and copy (as opposed to map) the IRET frame there, and for the suggestion to mark them readonly and let the fault promote to #DF. - Konrad Wilk for paravirt fixup and testing. - Borislav Petkov for testing help and useful comments. Reported-by: Brian Gerst <brgerst@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Andrew Lutomriski <amluto@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Dirk Hohndel <dirk@hohndel.org> Cc: Arjan van de Ven <arjan.van.de.ven@intel.com> Cc: comex <comexk@gmail.com> Cc: Alexander van Heukelum <heukelum@fastmail.fm> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: <stable@vger.kernel.org> # consider after upstream merge
2014-04-28param: hand arguments after -- straight to initRusty Russell
The kernel passes any args it doesn't need through to init, except it assumes anything containing '.' belongs to the kernel (for a module). This change means all users can clearly distinguish which arguments are for init. For example, the kernel uses debug ("dee-bug") to mean log everything to the console, where systemd uses the debug from the Scandinavian "day-boog" meaning "fail to boot". If a future versions uses argv[] instead of reading /proc/cmdline, this confusion will be avoided. eg: test 'FOO="this is --foo"' -- 'systemd.debug="true true true"' Gives: argv[0] = '/debug-init' argv[1] = 'test' argv[2] = 'systemd.debug=true true true' envp[0] = 'HOME=/' envp[1] = 'TERM=linux' envp[2] = 'FOO=this is --foo' Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2014-03-13ACPI / init: Invoke early ACPI initialization laterRafael J. Wysocki
Commit 73f7d1ca3263 (ACPI / init: Run acpi_early_init() before timekeeping_init()) optimistically moved the early ACPI initialization before timekeeping_init(), but that didn't work, because it broke fast TSC calibration for Julian Wollrath on Thinkpad x121e (and most likely for others too). The reason is that acpi_early_init() enables the SCI and that interferes with the fast TSC calibration mechanism. Thus follow the original idea to execute acpi_early_init() before efi_enter_virtual_mode() to help the EFI people for now and we can revisit the other problem that commit 73f7d1ca3263 attempted to address in the future (if really necessary). Fixes: 73f7d1ca3263 (ACPI / init: Run acpi_early_init() before timekeeping_init()) Reported-by: Julian Wollrath <jwollrath@web.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-05execve: use 'struct filename *' for executable name passingLinus Torvalds
This changes 'do_execve()' to get the executable name as a 'struct filename', and to free it when it is done. This is what the normal users want, and it simplifies and streamlines their error handling. The controlled lifetime of the executable name also fixes a use-after-free problem with the trace_sched_process_exec tracepoint: the lifetime of the passed-in string for kernel users was not at all obvious, and the user-mode helper code used UMH_WAIT_EXEC to serialize the pathname allocation lifetime with the execve() having finished, which in turn meant that the trace point that happened after mm_release() of the old process VM ended up using already free'd memory. To solve the kernel string lifetime issue, this simply introduces "getname_kernel()" that works like the normal user-space getname() function, except with the source coming from kernel memory. As Oleg points out, this also means that we could drop the tcomm[] array from 'struct linux_binprm', since the pathname lifetime now covers setup_new_exec(). That would be a separate cleanup. Reported-by: Igor Zhbanov <i.zhbanov@samsung.com> Tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
