To avoid potential problems with an empty /dev open /dev/console
from rootfs instead of waiting to mount our root filesystem and
mounting it there. This effectively guarantees that there will
be a device node, and it won't be on a filesystem that we will
ever unmount, so there are no issues with leaving /dev/console
open and pinning the filesystem.
This is actually more effective than automatically mounting
devtmpfs on /dev because it removes removes the occasionally
problematic assumption that /dev/console exists from the boot
code.
With this patch I was able to throw busybox on my /boot partition
(which has no /dev directory) and boot into userspace without
problems.
The only possible negative consequence I can think of is that
someone out there deliberately used did not use a character device
that is major 5 minor 2 for /dev/console. Does anyone know of a
situation in which that could make sense?
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
x86: Fix out of order of gsi
x86: apic: Fix mismerge, add arch_probe_nr_irqs() again
x86, irq: Keep chip_data in create_irq_nr and destroy_irq
xen: Remove unnecessary arch specific xen irq functions.
smp: Use nr_cpus= to set nr_cpu_ids early
x86, irq: Remove arch_probe_nr_irqs
sparseirq: Use radix_tree instead of ptrs array
sparseirq: Change irq_desc_ptrs to static
init: Move radix_tree_init() early
irq: Remove unnecessary bootmem code
x86: Add iMac9,1 to pci_reboot_dmi_table
x86: Convert i8259_lock to raw_spinlock
x86: Convert nmi_lock to raw_spinlock
x86: Convert ioapic_lock and vector_lock to raw_spinlock
x86: Avoid race condition in pci_enable_msix()
x86: Fix SCI on IOAPIC != 0
x86, ia32_aout: do not kill argument mapping
x86, irq: Move __setup_vector_irq() before the first irq enable in cpu online path
x86, irq: Update the vector domain for legacy irqs handled by io-apic
x86, irq: Don't block IRQ0_VECTOR..IRQ15_VECTOR's on all cpu's
Update the rcu_dereference() usages to take advantage of the new
lockdep-based checking.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-6-git-send-email-paulmck@linux.vnet.ibm.com>
[ -v2: fix allmodconfig missing symbol export build failure on x86 ]
On x86, before prefill_possible_map(), nr_cpu_ids will be NR_CPUS aka
CONFIG_NR_CPUS.
Add nr_cpus= to set nr_cpu_ids. so we can simulate cpus <=8 are installed on
normal config.
-v2: accordging to Christoph, acpi_numa_init should use nr_cpu_ids in stead of
NR_CPUS.
-v3: add doc in kernel-parameters.txt according to Andrew.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <1265793639-15071-34-git-send-email-yinghai@kernel.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Prepare for using radix trees in early_irq_init().
LKML-Reference: <1265793639-15071-30-git-send-email-yinghai@kernel.org>
ima wants to create an inode information struct (iint) when inodes are
allocated. This means that at least the part of ima which does this
allocation (the allocation is filled with information later) should
before any inodes are created. To accomplish this we split the ima
initialization routine placing the kmem cache allocator inside a
security_initcall() function. Since this makes use of radix trees we also
need to make sure that is initialized before security_initcall().
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
A UP machine has 1 active cpu, not having the boot-cpu in the
active map when starting the scheduler confuses things.
LKML-Reference: <20091216170517.423469527@chello.nl>
The symbol 'call' is a static symbol used for initcall_debug. This same
symbol name is used locally by a couple functions and produces the
following sparse warnings:
warning: symbol 'call' shadows an earlier one
Fix this noise by renaming the local symbols.
Jon confirms that recent modprobe will look in /proc/cmdline, so these
cmdline options can still be used.
See http://bugzilla.kernel.org/show_bug.cgi?id=14164
Reported-by: Adam Williamson <awilliam@redhat.com>
Cc: stable@kernel.org
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: fix requeue_pi key imbalance
futex: Fix typo in FUTEX_WAIT/WAKE_BITSET_PRIVATE definitions
rcu: Place root rcu_node structure in separate lockdep class
rcu: Make hot-unplugged CPU relinquish its own RCU callbacks
rcu: Move rcu_barrier() to rcutree
futex: Move exit_pi_state() call to release_mm()
futex: Nullify robust lists after cleanup
futex: Fix locking imbalance
panic: Fix panic message visibility by calling bust_spinlocks(0) before dying
rcu: Replace the rcu_barrier enum with pointer to call_rcu*() function
rcu: Clean up code based on review feedback from Josh Triplett, part 4
rcu: Clean up code based on review feedback from Josh Triplett, part 3
rcu: Fix rcu_lock_map build failure on CONFIG_PROVE_LOCKING=y
rcu: Clean up code to address Ingo's checkpatch feedback
rcu: Clean up code based on review feedback from Josh Triplett, part 2
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits)
cpumask: Move deprecated functions to end of header.
cpumask: remove unused deprecated functions, avoid accusations of insanity
cpumask: use new-style cpumask ops in mm/quicklist.
cpumask: use mm_cpumask() wrapper: x86
cpumask: use mm_cpumask() wrapper: um
cpumask: use mm_cpumask() wrapper: mips
cpumask: use mm_cpumask() wrapper: mn10300
cpumask: use mm_cpumask() wrapper: m32r
cpumask: use mm_cpumask() wrapper: arm
cpumask: Use accessors for cpu_*_mask: um
cpumask: Use accessors for cpu_*_mask: powerpc
cpumask: Use accessors for cpu_*_mask: mips
cpumask: Use accessors for cpu_*_mask: m32r
cpumask: remove arch_send_call_function_ipi
cpumask: arch_send_call_function_ipi_mask: s390
cpumask: arch_send_call_function_ipi_mask: powerpc
cpumask: arch_send_call_function_ipi_mask: mips
cpumask: arch_send_call_function_ipi_mask: m32r
cpumask: arch_send_call_function_ipi_mask: alpha
cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
It's only defined for NR_CPUS > BITS_PER_LONG; cpu_all_mask is always
defined (and const).
These issues identified during an old-fashioned face-to-face code
review extending over many hours.
o Add comments for tricky parts of code, and correct comments
that have passed their sell-by date.
o Get rid of the vestiges of rcu_init_sched(), which is no
longer needed now that PREEMPT_RCU is gone.
o Move the #include of rcutree_plugin.h to the end of
rcutree.c, which means that, rather than having a random
collection of forward declarations, the new set of forward
declarations document the set of plugins. The new home for
this #include also allows __rcu_init_preempt() to move into
rcutree_plugin.h.
o Fix rcu_preempt_check_callbacks() to be static.
Suggested-by: Josh Triplett <josh@joshtriplett.org>
Cc: akpm@linux-foundation.org
Cc: niv@us.ibm.com
LKML-Reference: <12537246443924-git-send-email->
Peter Zijlstra <peterz@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6
* 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6:
SFI: remove unneeded includes
sfi: Remove unused code
SFI: Hook PCI MMCONFIG
x86: add arch-specific SFI support
SFI: add capability to parse ACPI tables
SFI: add platform-independent core support
SFI: create linux/sfi.h
SFI: Simple Firmware Interface - MAINTAINERS, Kconfig
Sizing of memory allocations shouldn't depend on the number of physical
pages found in a system, as that generally includes (perhaps a huge amount
of) non-RAM pages. The amount of what actually is usable as storage
should instead be used as a basis here.
Some of the calculations (i.e. those not intending to use high memory)
should likely even use (totalram_pages - totalhigh_pages).
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Patrick McHardy <kaber@trash.net>
arch/x86/kernel/setup.c
drivers/acpi/power.c
init/main.c
Signed-off-by: Len Brown <len.brown@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
Driver Core: devtmpfs - kernel-maintained tmpfs-based /dev
debugfs: Modify default debugfs directory for debugging pktcdvd.
debugfs: Modified default dir of debugfs for debugging UHCI.
debugfs: Change debugfs directory of IWMC3200
debugfs: Change debuhgfs directory of trace-events-sample.h
debugfs: Fix mount directory of debugfs by default in events.txt
hpilo: add poll f_op
hpilo: add interrupt handler
hpilo: staging for interrupt handling
driver core: platform_device_add_data(): use kmemdup()
Driver core: Add support for compatibility classes
uio: add generic driver for PCI 2.3 devices
driver-core: move dma-coherent.c from kernel to driver/base
mem_class: fix bug
mem_class: use minor as index instead of searching the array
driver model: constify attribute groups
UIO: remove 'default n' from Kconfig
Driver core: Add accessor for device platform data
Driver core: move dev_get/set_drvdata to drivers/base/dd.c
Driver core: add new device to bus's list before probing
Devtmpfs lets the kernel create a tmpfs instance called devtmpfs
very early at kernel initialization, before any driver-core device
is registered. Every device with a major/minor will provide a
device node in devtmpfs.
Devtmpfs can be changed and altered by userspace at any time,
and in any way needed - just like today's udev-mounted tmpfs.
Unmodified udev versions will run just fine on top of it, and will
recognize an already existing kernel-created device node and use it.
The default node permissions are root:root 0600. Proper permissions
and user/group ownership, meaningful symlinks, all other policy still
needs to be applied by userspace.
If a node is created by devtmps, devtmpfs will remove the device node
when the device goes away. If the device node was created by
userspace, or the devtmpfs created node was replaced by userspace, it
will no longer be removed by devtmpfs.
If it is requested to auto-mount it, it makes init=/bin/sh work
without any further userspace support. /dev will be fully populated
and dynamic, and always reflect the current device state of the kernel.
With the commonly used dynamic device numbers, it solves the problem
where static devices nodes may point to the wrong devices.
It is intended to make the initial bootup logic simpler and more robust,
by de-coupling the creation of the inital environment, to reliably run
userspace processes, from a complex userspace bootstrap logic to provide
a working /dev.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Jan Blunck <jblunck@suse.de>
Tested-By: Harald Hoyer <harald@redhat.com>
Tested-By: Scott James Remnant <scott@ubuntu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits)
powerpc64: convert to dynamic percpu allocator
sparc64: use embedding percpu first chunk allocator
percpu: kill lpage first chunk allocator
x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA
percpu: update embedding first chunk allocator to handle sparse units
percpu: use group information to allocate vmap areas sparsely
vmalloc: implement pcpu_get_vm_areas()
vmalloc: separate out insert_vmalloc_vm()
percpu: add chunk->base_addr
percpu: add pcpu_unit_offsets[]
percpu: introduce pcpu_alloc_info and pcpu_group_info
percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward
percpu: add @align to pcpu_fc_alloc_fn_t
percpu: make @dyn_size mandatory for pcpu_setup_first_chunk()
percpu: drop @static_size from first chunk allocators
percpu: generalize first chunk allocator selection
percpu: build first chunk allocators selectively
percpu: rename 4k first chunk allocator to page
percpu: improve boot messages
percpu: fix pcpu_reclaim() locking
Fix trivial conflict as by Tejun Heo in kernel/sched.c
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (64 commits)
sched: Fix sched::sched_stat_wait tracepoint field
sched: Disable NEW_FAIR_SLEEPERS for now
sched: Keep kthreads at default priority
sched: Re-tune the scheduler latency defaults to decrease worst-case latencies
sched: Turn off child_runs_first
sched: Ensure that a child can't gain time over it's parent after fork()
sched: enable SD_WAKE_IDLE
sched: Deal with low-load in wake_affine()
sched: Remove short cut from select_task_rq_fair()
sched: Turn on SD_BALANCE_NEWIDLE
sched: Clean up topology.h
sched: Fix dynamic power-balancing crash
sched: Remove reciprocal for cpu_power
sched: Try to deal with low capacity, fix update_sd_power_savings_stats()
sched: Scale down cpu_power due to RT tasks
sched: Implement dynamic cpu_power
sched: Add smt_gain
sched: Update the cpu_power sum during load-balance
sched: Add SD_PREFER_SIBLING
Ingo was getting warnings from rcu_scheduler_starting()
indicating that context switches had occurred before RCU ended
its special early-boot handling of grace periods.
This is a dangerous condition, as it indicates that RCU might
have prematurely ended grace periods. This exploratory fix
moves rcu_scheduler_starting() earlier in boot.
Reported-by: Ingo Molnar <mingo@elte.hu>
drivers/sfi/sfi_core.c contains the generic SFI implementation.
It has a private header, sfi_core.h, for its own use and the
private use of future files in drivers/sfi/
Signed-off-by: Feng Tang <feng.tang@intel.com>
Some architectures initialize clocks and timers in late_time_init and
x86 wants to do the same to avoid FIXMAP hackery for calibrating the
TSC. That would result in undefined sched_clock readout and wreckaged
printk timestamps again. We probably have those already on archs which
do all their time/clock setup in late_time_init.
There is no harm to move that after late_time_init except that a few
more boot timestamps are stale. The scheduler is not active at that
point so no real wreckage is expected.
LKML-Reference: <new-submission>
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: Fix too large stack usage in do_one_initcall()
tracing: handle broken names in ftrace filter
ftrace: Unify effect of writing to trace_options and option/*
One of my testboxes triggered this nasty stack overflow crash
during SCSI probing:
[ 5.874004] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.875004] device: 'sda': device_add
[ 5.878004] BUG: unable to handle kernel NULL pointer dereference at 00000a0c
[ 5.878004] IP: [<b1008321>] print_context_stack+0x81/0x110
[ 5.878004] *pde = 00000000
[ 5.878004] Thread overran stack, or stack corrupted
[ 5.878004] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
[ 5.878004] last sysfs file:
[ 5.878004]
[ 5.878004] Pid: 1, comm: swapper Not tainted (2.6.31-rc6-tip-01272-g9919e28-dirty #5685)
[ 5.878004] EIP: 0060:[<b1008321>] EFLAGS: 00010083 CPU: 0
[ 5.878004] EIP is at print_context_stack+0x81/0x110
[ 5.878004] EAX: cf8a3000 EBX: cf8a3fe4 ECX: 00000049 EDX: 00000000
[ 5.878004] ESI: b1cfce84 EDI: 00000000 EBP: cf8a3018 ESP: cf8a2ff4
[ 5.878004] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
[ 5.878004] Process swapper (pid: 1, ti=cf8a2000 task=cf8a8000 task.ti=cf8a3000)
[ 5.878004] Stack:
[ 5.878004] b1004867 fffff000 cf8a3ffc
[ 5.878004] Call Trace:
[ 5.878004] [<b1004867>] ? kernel_thread_helper+0x7/0x10
[ 5.878004] Oops: 0000 [#2] PREEMPT SMP DEBUG_PAGEALLOC
The oops did not reveal any more details about the real stack
that we have and the system got into an infinite loop of
recursive pagefaults.
So i booted with CONFIG_STACK_TRACER=y and the 'stacktrace' boot
parameter. The box did not crash (timings/conditions probably
changed a tiny bit to trigger the catastrophic crash), but the
/debug/tracing/stack_trace file was rather revealing:
Depth Size Location (72 entries)
0) 3704 52 __change_page_attr+0xb8/0x290
1) 3652 24 __change_page_attr_set_clr+0x43/0x90
2) 3628 60 kernel_map_pages+0x108/0x120
3) 3568 40 prep_new_page+0x7d/0x130
4) 3528 84 get_page_from_freelist+0x106/0x420
5) 3444 116 __alloc_pages_nodemask+0xd7/0x550
6) 3328 36 allocate_slab+0xb1/0x100
7) 3292 36 new_slab+0x1c/0x160
8) 3256 36 __slab_alloc+0x133/0x2b0
9) 3220 4 kmem_cache_alloc+0x1bb/0x1d0
10) 3216 108 create_object+0x28/0x250
11) 3108 40 kmemleak_alloc+0x81/0xc0
12) 3068 24 kmem_cache_alloc+0x162/0x1d0
13) 3044 52 scsi_pool_alloc_command+0x29/0x70
14) 2992 20 scsi_host_alloc_command+0x22/0x70
15) 2972 24 __scsi_get_command+0x1b/0x90
16) 2948 28 scsi_get_command+0x35/0x90
17) 2920 24 scsi_setup_blk_pc_cmnd+0xd4/0x100
18) 2896 128 sd_prep_fn+0x332/0xa70
19) 2768 36 blk_peek_request+0xe7/0x1d0
20) 2732 56 scsi_request_fn+0x54/0x520
21) 2676 12 __generic_unplug_device+0x2b/0x40
22) 2664 24 blk_execute_rq_nowait+0x59/0x80
23) 2640 172 blk_execute_rq+0x6b/0xb0
24) 2468 32 scsi_execute+0xe0/0x140
25) 2436 64 scsi_execute_req+0x152/0x160
26) 2372 60 scsi_vpd_inquiry+0x6c/0x90
27) 2312 44 scsi_get_vpd_page+0x112/0x160
28) 2268 52 sd_revalidate_disk+0x1df/0x320
29) 2216 92 rescan_partitions+0x98/0x330
30) 2124 52 __blkdev_get+0x309/0x350
31) 2072 8 blkdev_get+0xf/0x20
32) 2064 44 register_disk+0xff/0x120
33) 2020 36 add_disk+0x6e/0xb0
34) 1984 44 sd_probe_async+0xfb/0x1d0
35) 1940 44 __async_schedule+0xf4/0x1b0
36) 1896 8 async_schedule+0x12/0x20
37) 1888 60 sd_probe+0x305/0x360
38) 1828 44 really_probe+0x63/0x170
39) 1784 36 driver_probe_device+0x5d/0x60
40) 1748 16 __device_attach+0x49/0x50
41) 1732 32 bus_for_each_drv+0x5b/0x80
42) 1700 24 device_attach+0x6b/0x70
43) 1676 16 bus_attach_device+0x47/0x60
44) 1660 76 device_add+0x33d/0x400
45) 1584 52 scsi_sysfs_add_sdev+0x6a/0x2c0
46) 1532 108 scsi_add_lun+0x44b/0x460
47) 1424 116 scsi_probe_and_add_lun+0x182/0x4e0
48) 1308 36 __scsi_add_device+0xd9/0xe0
49) 1272 44 ata_scsi_scan_host+0x10b/0x190
50) 1228 24 async_port_probe+0x96/0xd0
51) 1204 44 __async_schedule+0xf4/0x1b0
52) 1160 8 async_schedule+0x12/0x20
53) 1152 48 ata_host_register+0x171/0x1d0
54) 1104 60 ata_pci_sff_activate_host+0xf3/0x230
55) 1044 44 ata_pci_sff_init_one+0xea/0x100
56) 1000 48 amd_init_one+0xb2/0x190
57) 952 8 local_pci_probe+0x13/0x20
58) 944 32 pci_device_probe+0x68/0x90
59) 912 44 really_probe+0x63/0x170
60) 868 36 driver_probe_device+0x5d/0x60
61) 832 20 __driver_attach+0x89/0xa0
62) 812 32 bus_for_each_dev+0x5b/0x80
63) 780 12 driver_attach+0x1e/0x20
64) 768 72 bus_add_driver+0x14b/0x2d0
65) 696 36 driver_register+0x6e/0x150
66) 660 20 __pci_register_driver+0x53/0xc0
67) 640 8 amd_init+0x14/0x16
68) 632 572 do_one_initcall+0x2b/0x1d0
69) 60 12 do_basic_setup+0x56/0x6a
70) 48 20 kernel_init+0x84/0xce
71) 28 28 kernel_thread_helper+0x7/0x10
There's a lot of fat functions on that stack trace, but
the largest of all is do_one_initcall(). This is due to
the boot trace entry variables being on the stack.
Fixing this is relatively easy, initcalls are fundamentally
serialized, so we can move the local variables to file scope.
Note that this large stack footprint was present for a
couple of months already - what pushed my system over
the edge was the addition of kmemleak to the call-chain:
This pushes the total to ~3800 bytes, only a tiny bit
more was needed to corrupt the on-kernel-stack thread_info.
The fix reduces the stack footprint from 572 bytes
to 28 bytes.
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: <stable@kernel.org>
arch/sparc/kernel/smp_64.c
arch/x86/kernel/cpu/perf_counter.c
arch/x86/kernel/setup_percpu.c
drivers/cpufreq/cpufreq_ondemand.c
mm/percpu.c
Conflicts in core and arch percpu codes are mostly from commit
ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many
num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all
the first chunk allocators into mm/percpu.c, the changes are moved
from arch code to mm/percpu.c.
nr_cpu_ids is dependent only on cpu_possible_map and
setup_per_cpu_areas() already depends on cpu_possible_map and will use
nr_cpu_ids. Initialize nr_cpu_ids before setting up percpu areas.
Pull linus#master to merge PER_CPU_DEF_ATTRIBUTES and alpha build fix
changes. As alpha in percpu tree uses 'weak' attribute instead of
inline assembly, there's no need for __used attribute.
arch/alpha/include/asm/percpu.h
arch/mn10300/kernel/vmlinux.lds.S
include/linux/percpu-defs.h
This patch makes most !CONFIG_HAVE_SETUP_PER_CPU_AREA archs use
dynamic percpu allocator. The first chunk is allocated using
embedding helper and 8k is reserved for modules. This ensures that
the new allocator behaves almost identically to the original allocator
as long as static percpu variables are concerned, so it shouldn't
introduce much breakage.
s390 and alpha use custom SHIFT_PERCPU_PTR() to work around addressing
range limit the addressing model imposes. Unfortunately, this breaks
if the address is specified using a variable, so for now, the two
archs aren't converted.
The following architectures are affected by this change.
* sh
* arm
* cris
* mips
* sparc(32)
* blackfin
* avr32
* parisc (broken, under investigation)
* m32r
* powerpc(32)
As this change makes the dynamic allocator the default one,
CONFIG_HAVE_DYNAMIC_PER_CPU_AREA is replaced with its invert -
CONFIG_HAVE_LEGACY_PER_CPU_AREA, which is added to yet-to-be converted
archs. These archs implement their own setup_per_cpu_areas() and the
conversion is not trivial.
* powerpc(64)
* sparc(64)
* ia64
* alpha
* s390
Boot and batch alloc/free tests on x86_32 with debug code (x86_32
doesn't use default first chunk initialization). Compile tested on
sparc(32), powerpc(32), arm and alpha.
Kyle McMartin reported that this change breaks parisc. The problem is
still under investigation and he is okay with pushing this patch
forward and fixing parisc later.
[ Impact: use dynamic allocator for most archs w/o custom percpu setup ]
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Bryan Wu <cooloney@kernel.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
SLAB uses get/put_online_cpus() which use a mutex which is itself only
initialized when cpu_hotplug_init() is called. Currently we hang suring
boot in SLAB due to doing that too late.
Reported by James Bottomley and Sachin Sant (and possibly others).
Debugged by Benjamin Herrenschmidt.
This just removes the dynamic initialization of the data structures, and
replaces it with a static one, avoiding this dependency entirely, and
removing one unnecessary special initcall.
Tested-by: Sachin Sant <sachinp@in.ibm.com>
Tested-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
The page allocator also needs the masking of gfp flags during boot,
so this moves it out of slab/slub and uses it with the page allocator
as well.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Call constructors (gcc-generated initcall-like functions) during kernel
start and module load. Constructors are e.g. used for gcov data
initialization.
Disable constructor support for usermode Linux to prevent conflicts with
host glibc.
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Li Wei <W.Li@Sun.COM>
Cc: Michael Ellerman <michaele@au1.ibm.com>
Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com>
Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com>
Some architectures need to initialize SLAB caches to be able
to allocate page tables. They do that from pgtable_cache_init()
so the later should be called earlier now, best is before
vmalloc_init().
* akpm: (182 commits)
fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset
fbdev: *bfin*: fix __dev{init,exit} markings
fbdev: *bfin*: drop unnecessary calls to memset
fbdev: bfin-t350mcqb-fb: drop unused local variables
fbdev: blackfin has __raw I/O accessors, so use them in fb.h
fbdev: s1d13xxxfb: add accelerated bitblt functions
tcx: use standard fields for framebuffer physical address and length
fbdev: add support for handoff from firmware to hw framebuffers
intelfb: fix a bug when changing video timing
fbdev: use framebuffer_release() for freeing fb_info structures
radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb?
s3c-fb: CPUFREQ frequency scaling support
s3c-fb: fix resource releasing on error during probing
carminefb: fix possible access beyond end of carmine_modedb[]
acornfb: remove fb_mmap function
mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF
mb862xxfb: restrict compliation of platform driver to PPC
Samsung SoC Framebuffer driver: add Alpha Channel support
atmel-lcdc: fix pixclock upper bound detection
offb: use framebuffer_alloc() to allocate fb_info struct
Manually fix up conflicts due to kmemcheck in mm/slab.c
Fix allocating page cache/slab object on the unallowed node when memory
spread is set by updating tasks' mems_allowed after its cpuset's mems is
changed.
In order to update tasks' mems_allowed in time, we must modify the code of
memory policy. Because the memory policy is applied in the process's
context originally. After applying this patch, one task directly
manipulates anothers mems_allowed, and we use alloc_lock in the
task_struct to protect mems_allowed and memory policy of the task.
But in the fast path, we didn't use lock to protect them, because adding a
lock may lead to performance regression. But if we don't add a lock,the
task might see no nodes when changing cpuset's mems_allowed to some
non-overlapping set. In order to avoid it, we set all new allowed nodes,
then clear newly disallowed ones.
[lee.schermerhorn@hp.com:
The rework of mpol_new() to extract the adjusting of the node mask to
apply cpuset and mpol flags "context" breaks set_mempolicy() and mbind()
with MPOL_PREFERRED and a NULL nodemask--i.e., explicit local
allocation. Fix this by adding the check for MPOL_PREFERRED and empty
node mask to mpol_new_mpolicy().
Remove the now unneeded 'nodes = NULL' from mpol_new().
Note that mpol_new_mempolicy() is always called with a non-NULL
'nodes' parameter now that it has been removed from mpol_new().
Therefore, we don't need to test nodes for NULL before testing it for
'empty'. However, just to be extra paranoid, add a VM_BUG_ON() to
verify this assumption.]
I don't think the function name 'mpol_new_mempolicy' is descriptive
enough to differentiate it from mpol_new().
This function applies cpuset set context, usually constraining nodes
to those allowed by the cpuset. However, when the 'RELATIVE_NODES flag
is set, it also translates the nodes. So I settled on
'mpol_set_nodemask()', because the comment block for mpol_new() mentions
that we need to call this function to "set nodes".
Some additional minor line length, whitespace and typo cleanup.]
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
MAINTAINERS
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
General description: kmemcheck is a patch to the linux kernel that
detects use of uninitialized memory. It does this by trapping every
read and write to memory that was allocated dynamically (e.g. using
kmalloc()). If a memory address is read that has not previously been
written to, a message is printed to the kernel log.
Thanks to Andi Kleen for the set_memory_4k() solution.
Andrew Morton suggested documenting the shadow member of struct page.
Signed-off-by: Vegard Nossum <vegardno@ifi.uio.no>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
[export kmemcheck_mark_initialized]
[build fix for setup_max_cpus]
[rebased for mainline inclusion]
As explained by Benjamin Herrenschmidt:
Oh and btw, your patch alone doesn't fix powerpc, because it's missing
a whole bunch of GFP_KERNEL's in the arch code... You would have to
grep the entire kernel for things that check slab_is_available() and
even then you'll be missing some.
For example, slab_is_available() didn't always exist, and so in the
early days on powerpc, we used a mem_init_done global that is set form
mem_init() (not perfect but works in practice). And we still have code
using that to do the test.
Therefore, mask out __GFP_WAIT, __GFP_IO, and __GFP_FS in the slab allocators
in early boot code to avoid enabling interrupts.
Now, SLAB is configured in very early stage and it can be used in
init routine now.
But replacing alloc_bootmem() in FLAT/DISCONTIGMEM's page_cgroup()
initialization breaks the allocation, now.
(Works well in SPARSEMEM case...it supports MEMORY_HOTPLUG and
size of page_cgroup is in reasonable size (< 1 << MAX_ORDER.)
This patch revive FLATMEM+memory cgroup by using alloc_bootmem.
In future,
We stop to support FLATMEM (if no users) or rewrite codes for flatmem
completely.But this will adds more messy codes and overheads.
Reported-by: Li Zefan <lizf@cn.fujitsu.com>
Tested-by: Li Zefan <lizf@cn.fujitsu.com>
Tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
* 'for-linus' of git://linux-arm.org/linux-2.6:
kmemleak: Add the corresponding MAINTAINERS entry
kmemleak: Simple testing module for kmemleak
kmemleak: Enable the building of the memory leak detector
kmemleak: Remove some of the kmemleak false positives
kmemleak: Add modules support
kmemleak: Add kmemleak_alloc callback from alloc_large_system_hash
kmemleak: Add the vmalloc memory allocation/freeing hooks
kmemleak: Add the slub memory allocation/freeing hooks
kmemleak: Add the slob memory allocation/freeing hooks
kmemleak: Add the slab memory allocation/freeing hooks
kmemleak: Add documentation on the memory leak detector
kmemleak: Add the base support
Manual conflict resolution (with the slab/earlyboot changes) in:
drivers/char/vt.c
init/main.c
mm/slab.c
As suggested by Christoph Lameter, introduce mm_init() now that we initialize
all the kernel memory allocations together.
We can call vmalloc_init() after kmem_cache_init() and use kzalloc() instead of
the bootmem allocator when initializing vmalloc data structures.
Acked-by: Nick Piggin <npiggin@suse.de>
Cc: Yinghai Lu <yinghai@kernel.org>
This patch makes kmalloc() available earlier in the boot sequence so we can get
rid of some bootmem allocations. The bulk of the changes are due to
kmem_cache_init() being called with interrupts disabled which requires some
changes to allocator boostrap code.
Note: 32-bit x86 does WP protect test in mem_init() so we must setup traps
before we call mem_init() during boot as reported by Ingo Molnar:
We have a hard crash in the WP-protect code:
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...BUG: Int 14: CR2 ffcff000
[ 0.000000] EDI 00000188 ESI 00000ac7 EBP c17eaf9c ESP c17eaf8c
[ 0.000000] EBX 000014e0 EDX 0000000e ECX 01856067 EAX 00000001
[ 0.000000] err 00000003 EIP c10135b1 CS 00000060 flg 00010002
[ 0.000000] Stack: c17eafa8 c17fd410 c16747bc c17eafc4 c17fd7e5 000011fd f8616000 c18237cc
[ 0.000000] 00099800 c17bb000 c17eafec c17f1668 000001c5 c17f1322 c166e039 c1822bf0
[ 0.000000] c166e033 c153a014 c18237cc 00020800 c17eaff8 c17f106a 00020800 01ba5003
[ 0.000000] Pid: 0, comm: swapper Not tainted 2.6.30-tip-02161-g7a74539-dirty #52203
[ 0.000000] Call Trace:
[ 0.000000] [<c15357c2>] ? printk+0x14/0x16
[ 0.000000] [<c10135b1>] ? do_test_wp_bit+0x19/0x23
[ 0.000000] [<c17fd410>] ? test_wp_bit+0x26/0x64
[ 0.000000] [<c17fd7e5>] ? mem_init+0x1ba/0x1d8
[ 0.000000] [<c17f1668>] ? start_kernel+0x164/0x2f7
[ 0.000000] [<c17f1322>] ? unknown_bootoption+0x0/0x19c
[ 0.000000] [<c17f106a>] ? __init_begin+0x6a/0x6f
Acked-by Linus Torvalds <torvalds@linux-foundation.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Nick Piggin <npiggin@suse.de>
This patch adds the base support for the kernel memory leak
detector. It traces the memory allocation/freeing in a way similar to
the Boehm's conservative garbage collector, the difference being that
the unreferenced objects are not freed but only shown in
/sys/kernel/debug/kmemleak. Enabling this feature introduces an
overhead to memory allocations.
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
* 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits)
Revert "x86, bts: reenable ptrace branch trace support"
tracing: do not translate event helper macros in print format
ftrace/documentation: fix typo in function grapher name
tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK
tracing: add protection around module events unload
tracing: add trace_seq_vprint interface
tracing: fix the block trace points print size
ring-buffer: fix ret in rb_add_time_stamp
ring-buffer: pass in lockdep class key for reader_lock
tracing: add annotation to what type of stack trace is recorded
tracing: fix multiple use of __print_flags and __print_symbolic
tracing/events: fix output format of user stack
tracing/events: fix output format of kernel stack
tracing/trace_stack: fix the number of entries in the header
ring-buffer: discard timestamps that are at the start of the buffer
ring-buffer: try to discard unneeded timestamps
ring-buffer: fix bug in ring_buffer_discard_commit
ftrace: do not profile functions when disabled
tracing: make trace pipe recognize latency format flag
There is no format specifiers left in the linux_banner, and gcc-4.3
complains seeing the printk.
Signed-off-by: Alex Riesen <raa.lkml@gmail.com>
Merge reason: tracing/core was on a .30-rc1 base and was missing out on
on a handful of tracing fixes present in .30-rc5-almost.
