path: root/init/version.c
2009-12-12kbuild: move utsrelease.h to include/generatedSam Ravnborg
Fix up all users of utsrelease.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move compile.h to include/generatedSam Ravnborg
2008-07-25init/version.c: define version_string only if CONFIG_KALLSYMS is not definedDaniel Guilak
int Version_* is only used with ksymoops, which is only needed (according to README and Documentation/Changes) if CONFIG_KALLSYMS is NOT defined. Therefore this patch defines version_string only if CONFIG_KALLSYMS is not defined. Signed-off-by: Daniel Guilak <daniel@danielguilak.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25init/version.c: silence sparse warning by declaring the version stringDaniel Guilak
2007-01-11Don't put "linux_banner" in the .init sectionLinus Torvalds
It might save a few bytes after bootup, but it causes the string to be linked in at the end of the final vmlinux image, which defeats the whole point of doing all this, namely allowing some broken user-space binaries to search for the kernel version string in the kernel binary. So just remove the __init specifier. Cc: Olaf Hering <olaf@aepfle.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Andrew Morton <akpm@osdl.org> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-10[PATCH] fix linux banner format stringRoman Zippel
Revert previous attempts at messing with the linux banner string and simply use a separate format string for proc. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: Olaf Hering <olaf@aepfle.de> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Andrew Morton <akpm@osdl.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-11Make SLES9 "get_kernel_version" work on the kernel binary againLinus Torvalds
As reported by Andy Whitcroft, at least the SLES9 initrd build process depends on getting the kernel version from the kernel binary. It does that by simply trawling the binary and looking for the signature of the "linux_banner" string (the string "Linux version " to be exact. Which is really broken in itself, but whatever..) That got broken when the string was changed to allow /proc/version to change the UTS release information dynamically, and "get_kernel_version" thus returned "%s" (see commit a2ee8649ba6d71416712e798276bf7c40b64e6e5: "[PATCH] Fix linux banner utsname information"). This just restores "linux_banner" as a static string, which should fix the version finding. And /proc/version simply uses a different string. To avoid wasting even that miniscule amount of memory, the early boot string should really be marked __initdata, but that just causes the same bug in SLES9 to re-appear, since it will then find other occurrences of "Linux version " first. Cc: Andy Whitcroft <apw@shadowen.org> Acked-by: Herbert Poetzl <herbert@13thfloor.at> Cc: Andi Kleen <ak@suse.de> Cc: Andrew Morton <akpm@osdl.org> Cc: Steve Fox <drfickle@us.ibm.com> Acked-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Fix linux banner utsname informationHerbert Poetzl
utsname information is shown in the linux banner, which also is used for /proc/version (which can have different utsname values inside a uts namespaces). this patch makes the varying data arguments and changes the string to a format string, using those arguments. Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: implement utsname namespacesSerge E. Hallyn
This patch defines the uts namespace and some manipulators. Adds the uts namespace to task_struct, and initializes a system-wide init namespace. It leaves a #define for system_utsname so sysctl will compile. This define will be removed in a separate patch. [akpm@osdl.org: build fix, cleanup] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03kbuild: introduce utsrelease.hSam Ravnborg
include/linux/version.h contained both actual KERNEL version and UTS_RELEASE that contains a subset from git SHA1 for when kernel was compiled as part of a git repository. This had the unfortunate side-effect that all files including version.h would be recompiled when some git changes was made due to changes SHA1. Split it out so we keep independent parts in separate files. Also update checkversion.pl script to no longer check for UTS_RELEASE. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
