path: root/init
2012-03-31new helper: ext2_image_size()Al Viro
... implemented that way since the next commit will leave it almost alone in ext2_fs.h - most of the file (including struct ext2_super_block) is going to move to fs/ext2/ext2.h. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31get rid of pointless includes of ext2_fs.hAl Viro
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Move all declarations of free_initmem() to linux/mm.hDavid Howells
Move all declarations of free_initmem() to linux/mm.h so that there's only one and it's used by everything. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-c6x-dev@linux-c6x.org cc: microblaze-uclinux@itee.uq.edu.au cc: linux-sh@vger.kernel.org cc: sparclinux@vger.kernel.org cc: x86@kernel.org cc: linux-mm@kvack.org
2012-03-26params: <level>_initcall-like kernel parametersPawel Moll
This patch adds a set of macros that can be used to declare kernel parameters to be parsed _before_ initcalls at a chosen level are executed. We rename the now-unused "flags" field of struct kernel_param as the level. It's signed, for when we use this for early params as well, in future. Linker macro collating init calls had to be modified in order to add additional symbols between levels that are later used by the init code to split the calls into blocks. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-23init/do_mounts.c: print error code on mount failureBernhard Walle
Printing the error code makes it easier to debug the cause of a mount failure. For example I had the problem that the root file system could not be mounted read-writeable because my SD card was write-protected. Without an error code it looks like the SD card was not detected at all. Signed-off-by: Bernhard Walle <bernhard@bwalle.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23init: check printed flag to skip printing messageDiwakar Tundlam
Otherwise the 'Calibration skipped' message gets printed everytime a CPU is hotplugged in, cluttering console for systems that frequently hotplug CPUs. Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: Sameer Nanda <snanda@chromium.org> Cc: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc merge from Benjamin Herrenschmidt: "Here's the powerpc batch for this merge window. It is going to be a bit more nasty than usual as in touching things outside of arch/powerpc mostly due to the big iSeriesectomy :-) We finally got rid of the bugger (legacy iSeries support) which was a PITA to maintain and that nobody really used anymore. Here are some of the highlights: - Legacy iSeries is gone. Thanks Stephen ! There's still some bits and pieces remaining if you do a grep -ir series arch/powerpc but they are harmless and will be removed in the next few weeks hopefully. - The 'fadump' functionality (Firmware Assisted Dump) replaces the previous (equivalent) "pHyp assisted dump"... it's a rewrite of a mechanism to get the hypervisor to do crash dumps on pSeries, the new implementation hopefully being much more reliable. Thanks Mahesh Salgaonkar. - The "EEH" code (pSeries PCI error handling & recovery) got a big spring cleaning, motivated by the need to be able to implement a new backend for it on top of some new different type of firwmare. The work isn't complete yet, but a good chunk of the cleanups is there. Note that this adds a field to struct device_node which is not very nice and which Grant objects to. I will have a patch soon that moves that to a powerpc private data structure (hopefully before rc1) and we'll improve things further later on (hopefully getting rid of the need for that pointer completely). Thanks Gavin Shan. - I dug into our exception & interrupt handling code to improve the way we do lazy interrupt handling (and make it work properly with "edge" triggered interrupt sources), and while at it found & fixed a wagon of issues in those areas, including adding support for page fault retry & fatal signals on page faults. - Your usual random batch of small fixes & updates, including a bunch of new embedded boards, both Freescale and APM based ones, etc..." I fixed up some conflicts with the generalized irq-domain changes from Grant Likely, hopefully correctly. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits) powerpc/ps3: Do not adjust the wrapper load address powerpc: Remove the rest of the legacy iSeries include files powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces init: Remove CONFIG_PPC_ISERIES powerpc: Remove FW_FEATURE ISERIES from arch code tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable powerpc/spufs: Fix double unlocks powerpc/5200: convert mpc5200 to use of_platform_populate() powerpc/mpc5200: add options to mpc5200_defconfig powerpc/mpc52xx: add a4m072 board support powerpc/mpc5200: update mpc5200_defconfig to fit for charon board Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board MAINTAINERS: Update PowerPC 4xx tree powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board powerpc: document the FSL MPIC message register binding powerpc: add support for MPIC message register API powerpc/fsl: Added aliased MSIIR register address to MSI node in dts powerpc/85xx: mpc8548cds - add 36-bit dts ...
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-03-21init: Remove CONFIG_PPC_ISERIESStephen Rothwell
It is no longer selectable, so remove the check for it. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-03-20Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes for v3.4 from Ingo Molnar * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) printk: Make it compile with !CONFIG_PRINTK sched/x86: Fix overflow in cyc2ns_offset sched: Fix nohz load accounting -- again! sched: Update yield() docs printk/sched: Introduce special printk_sched() for those awkward moments sched/nohz: Correctly initialize 'next_balance' in 'nohz' idle balancer sched: Cleanup cpu_active madness sched: Fix load-balance wreckage sched: Clean up parameter passing of proc_sched_autogroup_set_nice() sched: Ditch per cgroup task lists for load-balancing sched: Rename load-balancing fields sched: Move load-balancing arguments into helper struct sched/rt: Do not submit new work when PI-blocked sched/rt: Prevent idle task boosting sched/wait: Add __wake_up_all_locked() API sched/rt: Document scheduler related skip-resched-check sites sched/rt: Use schedule_preempt_disabled() sched/rt: Add schedule_preempt_disabled() sched/rt: Do not throttle when PI boosting sched/rt: Keep period timer ticking when rt throttling is active ...
2012-03-15init: fix wording error in mm_init commentJim Cromie
s/countinuous/contiguous/, reword sentence. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-21rcu: Move RCU_TRACE to lib/Kconfig.debugPaul E. McKenney
The RCU_TRACE kernel parameter has always been intended for debugging, not for production use. Formalize this by moving RCU_TRACE from init/Kconfig to lib/Kconfig.debug. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits) audit: no leading space in audit_log_d_path prefix audit: treat s_id as an untrusted string audit: fix signedness bug in audit_log_execve_info() audit: comparison on interprocess fields audit: implement all object interfield comparisons audit: allow interfield comparison between gid and ogid audit: complex interfield comparison helper audit: allow interfield comparison in audit rules Kernel: Audit Support For The ARM Platform audit: do not call audit_getname on error audit: only allow tasks to set their loginuid if it is -1 audit: remove task argument to audit_set_loginuid audit: allow audit matching on inode gid audit: allow matching on obj_uid audit: remove audit_finish_fork as it can't be called audit: reject entry,always rules audit: inline audit_free to simplify the look of generic code audit: drop audit_set_macxattr as it doesn't do anything audit: inline checks for not needing to collect aux records audit: drop some potentially inadvisable likely notations ... Use evil merge to fix up grammar mistakes in Kconfig file. Bad speling and horrible grammar (and copious swearing) is to be expected, but let's keep it to commit messages and comments, rather than expose it to users in config help texts or printouts.
2012-01-17Kernel: Audit Support For The ARM PlatformNathaniel Husted
This patch provides functionality to audit system call events on the ARM platform. The implementation was based off the structure of the MIPS platform and information in this (http://lists.fedoraproject.org/pipermail/arm/2009-October/000382.html) mailing list thread. The required audit_syscall_exit and audit_syscall_entry checks were added to ptrace using the standard registers for system call values (r0 through r3). A thread information flag was added for auditing (TIF_SYSCALL_AUDIT) and a meta-flag was added (_TIF_SYSCALL_WORK) to simplify modifications to the syscall entry/exit. Now, if either the TRACE flag is set or the AUDIT flag is set, the syscall_trace function will be executed. The prober changes were made to Kconfig to allow CONFIG_AUDITSYSCALL to be enabled. Due to platform availability limitations, this patch was only tested on the Android platform running the modified "android-goldfish-2.6.29" kernel. A test compile was performed using Code Sourcery's cross-compilation toolset and the current linux-3.0 stable kernel. The changes compile without error. I'm hoping, due to the simple modifications, the patch is "obviously correct". Signed-off-by: Nathaniel Husted <nhusted@gmail.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: only allow tasks to set their loginuid if it is -1Eric Paris
At the moment we allow tasks to set their loginuid if they have CAP_AUDIT_CONTROL. In reality we want tasks to set the loginuid when they log in and it be impossible to ever reset. We had to make it mutable even after it was once set (with the CAP) because on update and admin might have to restart sshd. Now sshd would get his loginuid and the next user which logged in using ssh would not be able to set his loginuid. Systemd has changed how userspace works and allowed us to make the kernel work the way it should. With systemd users (even admins) are not supposed to restart services directly. The system will restart the service for them. Thus since systemd is going to loginuid==-1, sshd would get -1, and sshd would be allowed to set a new loginuid without special permissions. If an admin in this system were to manually start an sshd he is inserting himself into the system chain of trust and thus, logically, it's his loginuid that should be used! Since we have old systems I make this a Kconfig option. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-14Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1 * tag 'for-linus' of git://github.com/rustyrussell/linux: module_param: check that bool parameters really are bool. intelfbdrv.c: bailearly is an int module_param paride/pcd: fix bool verbose module parameter. module_param: make bool parameters really bool (drivers & misc) module_param: make bool parameters really bool (arch) module_param: make bool parameters really bool (core code) kernel/async: remove redundant declaration. printk: fix unnecessary module_param_name. lirc_parallel: fix module parameter description. module_param: avoid bool abuse, add bint for special cases. module_param: check type correctness for module_param_array modpost: use linker section to generate table. modpost: use a table rather than a giant if/else statement. modules: sysfs - export: taint, coresize, initsize kernel/params: replace DEBUGP with pr_debug module: replace DEBUGP with pr_debug module: struct module_ref should contains long fields module: Fix performance regression on modules with large symbol tables module: Add comments describing how the "strmap" logic works Fix up conflicts in scripts/mod/file2alias.c due to the new linker- generated table approach to adding __mod_*_device_table entries. The ARM sa11x0 mcp bus needed to be converted to that too.
2012-01-12c/r: introduce CHECKPOINT_RESTORE symbolCyrill Gorcunov
For checkpoint/restore we need auxilary features being compiled into the kernel, such as additional prctl codes, /proc/<pid>/map_files and etc... but same time these features are not mandatory for a regular kernel so CHECKPOINT_RESTORE config symbol should bring a way to disable them all at once if one wish to get rid of additional functionality. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Vagin <avagin@openvz.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: Vasiliy Kulikov <segoon@openwall.com> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-13module_param: make bool parameters really bool (core code)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-11Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix lockup by limiting load-balance retries on lock-break sched: Fix CONFIG_CGROUP_SCHED dependency sched: Remove empty #ifdefs
2012-01-11Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/intel config: Fix the APB_TIMER selection x86/mrst: Add additional debug prints for pb_keys x86/intel config: Revamp configuration to allow for Moorestown and Medfield x86/intel/scu/ipc: Match the changes in the x86 configuration x86/apb: Fix configuration constraints x86: Fix INTEL_MID silly x86/Kconfig: Cyclone-timer depends on x86-summit x86: Reduce clock calibration time during slave cpu startup x86/config: Revamp configuration for MID devices x86/sfi: Kill the IRQ as id hack
2012-01-11Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/numa: Add constraints check for nid parameters mm, x86: Remove debug_pagealloc_enabled x86/mm: Initialize high mem before free_all_bootmem() arch/x86/kernel/e820.c: quiet sparse noise about plain integer as NULL pointer arch/x86/kernel/e820.c: Eliminate bubble sort from sanitize_e820_map() x86: Fix mmap random address range x86, mm: Unify zone_sizes_init() x86, mm: Prepare zone_sizes_init() for unification x86, mm: Use max_low_pfn for ZONE_NORMAL on 64-bit x86, mm: Wrap ZONE_DMA32 with CONFIG_ZONE_DMA32 x86, mm: Use max_pfn instead of highend_pfn x86, mm: Move zone init from paging_init() on 64-bit x86, mm: Use MAX_DMA_PFN for ZONE_DMA on 32-bit
2012-01-10Merge branch 'nfs-for-3.3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'nfs-for-3.3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4: Change the default setting of the nfs4_disable_idmapping parameter NFSv4: Save the owner/group name string when doing open NFS: Remove pNFS bloat from the generic write path pnfs-obj: Must return layout on IO error pnfs-obj: pNFS errors are communicated on iodata->pnfs_error NFS: Cache state owners after files are closed NFS: Clean up nfs4_find_state_owners_locked() NFSv4: include bitmap in nfsv4 get acl data nfs: fix a minor do_div portability issue NFSv4.1: cleanup comment and debug printk NFSv4.1: change nfs4_free_slot parameters for dynamic slots NFSv4.1: cleanup init and reset of session slot tables NFSv4.1: fix backchannel slotid off-by-one bug nfs: fix regression in handling of context= option in NFSv4 NFS - fix recent breakage to NFS error handling. NFS: Retry mounting NFSROOT SUNRPC: Clean up the RPCSEC_GSS service ticket requests
2012-01-10sched: Fix CONFIG_CGROUP_SCHED dependencyFabio Estevam
The dependency bug was pointed out by this build warning: warning: (SCHED_AUTOGROUP) selects CGROUP_SCHED which has unmet direct dependencies (CGROUPS && EXPERIMENTAL) Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: a.p.zijlstra@chello.nl Cc: Fabio Estevam <festevam@gmail.com> Link: http://lkml.kernel.org/r/1326192383-5113-1-git-send-email-festevam@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-08Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (165 commits) reiserfs: Properly display mount options in /proc/mounts vfs: prevent remount read-only if pending removes vfs: count unlinked inodes vfs: protect remounting superblock read-only vfs: keep list of mounts for each superblock vfs: switch ->show_options() to struct dentry * vfs: switch ->show_path() to struct dentry * vfs: switch ->show_devname() to struct dentry * vfs: switch ->show_stats to struct dentry * switch security_path_chmod() to struct path * vfs: prefer ->dentry->d_sb to ->mnt->mnt_sb vfs: trim includes a bit switch mnt_namespace ->root to struct mount vfs: take /proc/*/mounts and friends to fs/proc_namespace.c vfs: opencode mntget() mnt_set_mountpoint() vfs: spread struct mount - remaining argument of next_mnt() vfs: move fsnotify junk to struct mount vfs: move mnt_devname vfs: move mnt_list to struct mount vfs: switch pnode.h macros to struct mount * ...
2012-01-06vfs: prefer ->dentry->d_sb to ->mnt->mnt_sbAl Viro
2012-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1958 commits) net: pack skb_shared_info more efficiently net_sched: red: split red_parms into parms and vars net_sched: sfq: extend limits cnic: Improve error recovery on bnx2x devices cnic: Re-init dev->stats_addr after chip reset net_sched: Bug in netem reordering bna: fix sparse warnings/errors bna: make ethtool_ops and strings const xgmac: cleanups net: make ethtool_ops const vmxnet3" make ethtool ops const xen-netback: make ops structs const virtio_net: Pass gfp flags when allocating rx buffers. ixgbe: FCoE: Add support for ndo_get_fcoe_hbainfo() call netdev: FCoE: Add new ndo_get_fcoe_hbainfo() call igb: reset PHY after recovering from PHY power down igb: add basic runtime PM support igb: Add support for byte queue limits. e1000: cleanup CE4100 MDIO registers access e1000: unmap ce4100_gbe_mdio_base_virt in e1000_remove ...
2012-01-06Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (64 commits) cpu: Export cpu_up() rcu: Apply ACCESS_ONCE() to rcu_boost() return value Revert "rcu: Permit rt_mutex_unlock() with irqs disabled" docs: Additional LWN links to RCU API rcu: Augment rcu_batch_end tracing for idle and callback state rcu: Add rcutorture tests for srcu_read_lock_raw() rcu: Make rcutorture test for hotpluggability before offlining CPUs driver-core/cpu: Expose hotpluggability to the rest of the kernel rcu: Remove redundant rcu_cpu_stall_suppress declaration rcu: Adaptive dyntick-idle preparation rcu: Keep invoking callbacks if CPU otherwise idle rcu: Irq nesting is always 0 on rcu_enter_idle_common rcu: Don't check irq nesting from rcu idle entry/exit rcu: Permit dyntick-idle with callbacks pending rcu: Document same-context read-side constraints rcu: Identify dyntick-idle CPUs on first force_quiescent_state() pass rcu: Remove dynticks false positives and RCU failures rcu: Reduce latency of rcu_prepare_for_idle() rcu: Eliminate RCU_FAST_NO_HZ grace-period hang rcu: Avoid needlessly IPIing CPUs at GP end ...
2012-01-05NFS: Retry mounting NFSROOTChuck Lever
Lukas Razik <linux@razik.name> reports that on his SPARC system, booting with an NFS root file system stopped working after commit 56463e50 "NFS: Use super.c for NFSROOT mount option parsing." We found that the network switch to which Lukas' client was attached was delaying access to the LAN after the client's NIC driver reported that its link was up. The delay was longer than the timeouts used in the NFS client during mounting. NFSROOT worked for Lukas before commit 56463e50 because in those kernels, the client's first operation was an rpcbind request to determine which port the NFS server was listening on. When that request failed after a long timeout, the client simply selected the default NFS port (2049). By that time the switch was allowing access to the LAN, and the mount succeeded. Neither of these client behaviors is desirable, so reverting 56463e50 is really not a choice. Instead, introduce a mechanism that retries the NFSROOT mount request several times. This is the same tactic that normal user space NFS mounts employ to overcome server and network delays. Signed-off-by: Lukas Razik <linux@razik.name> [ cel: match kernel coding style, add proper patch description ] [ cel: add exponential back-off ] Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: Lukas Razik <linux@razik.name> Cc: stable@kernel.org # > 2.6.38 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-03init/initramfs.c: should use umode_tAl Viro
2011-12-12Basic kernel memory functionality for the Memory ControllerGlauber Costa
This patch lays down the foundation for the kernel memory component of the Memory Controller. As of today, I am only laying down the following files: * memory.independent_kmem_limit * memory.kmem.limit_in_bytes (currently ignored) * memory.kmem.usage_in_bytes (always zero) Signed-off-by: Glauber Costa <glommer@parallels.com> CC: Kirill A. Shutemov <kirill@shutemov.name> CC: Paul Menage <paul@paulmenage.org> CC: Greg Thelen <gthelen@google.com> CC: Johannes Weiner <jweiner@redhat.com> CC: Michal Hocko <mhocko@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-11rcu: Permit RCU_FAST_NO_HZ to be used by TREE_PREEMPT_RCUPaul E. McKenney
The new implementation of RCU_FAST_NO_HZ is compatible with preemptible RCU, so this commit removes the Kconfig restriction that previously prohibited this. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-12-06mm, x86: Remove debug_pagealloc_enabledStanislaw Gruszka
When (no)bootmem finish operation, it pass pages to buddy allocator. Since debug_pagealloc_enabled is not set, we will do not protect pages, what is not what we want with CONFIG_DEBUG_PAGEALLOC=y. To fix remove debug_pagealloc_enabled. That variable was introduced by commit 12d6f21e "x86: do not PSE on CONFIG_DEBUG_PAGEALLOC=y" to get more CPA (change page attribude) code testing. But currently we have CONFIG_CPA_DEBUG, which test CPA. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/1322582711-14571-1-git-send-email-sgruszka@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-06init/main.c: Execute lockdep_init() as early as possibleMing Lei
This patch fixes a lockdep warning on ARM platforms: [ 0.000000] WARNING: lockdep init error! Arch code didn't call lockdep_init() early enough? [ 0.000000] Call stack leading to lockdep invocation was: [ 0.000000] [<c00164bc>] save_stack_trace_tsk+0x0/0x90 [ 0.000000] [<ffffffff>] 0xffffffff The warning is caused by printk inside smp_setup_processor_id(). It is safe to do this because lockdep_init() doesn't depend on smp_setup_processor_id(), so improve things that printk can be called as early as possible without lockdep complaint. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Reviewed-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1321508072-23853-1-git-send-email-tom.leiming@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86: Reduce clock calibration time during slave cpu startupJack Steiner
Reduce the startup time for slave cpus. Adds hooks for an arch-specific function for clock calibration. These hooks are used on x86. If a newly started cpu has the same phys_proc_id as a core already active, uses the TSC for the delay loop and has a CONSTANT_TSC, use the already-calculated value of loops_per_jiffy. This patch reduces the time required to start slave cpus on a 4096 cpu system from: 465 sec OLD 62 sec NEW This reduces boot time on a 4096p system by almost 7 minutes. Nice... Signed-off-by: Jack Steiner <steiner@sgi.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: John Stultz <john.stultz@linaro.org> [fix CONFIG_SMP=n build] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-06Merge branch 'upstream/jump-label-noearly' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/jump-label-noearly' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: jump-label: initialize jump-label subsystem much earlier x86/jump_label: add arch_jump_label_transform_static() s390/jump-label: add arch_jump_label_transform_static() jump_label: add arch_jump_label_transform_static() to optimise non-live code updates sparc/jump_label: drop arch_jump_label_text_poke_early() x86/jump_label: drop arch_jump_label_text_poke_early() jump_label: if a key has already been initialized, don't nop it out stop_machine: make stop_machine safe and efficient to call early jump_label: use proper atomic_t initializer Conflicts: - arch/x86/kernel/jump_label.c Added __init_or_module to arch_jump_label_text_poke_early vs removal of that function entirely - kernel/stop_machine.c same patch ("stop_machine: make stop_machine safe and efficient to call early") merged twice, with whitespace fix in one version
2011-11-02sysctl: make CONFIG_SYSCTL_SYSCALL default to nWANG Cong
When I tried to send a patch to remove it, Andi told me we still need to keep compabitlies for old libc, so we can't remove this completely. Then just make it default to n and remove the doc from feature-removal-schedule.txt. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02init: add root=PARTUUID=UUID/PARTNROFF=%d supportWill Drewry
Expand root=PARTUUID=UUID syntax to support selecting a root partition by integer offset from a known, unique partition. This approach provides similar properties to specifying a device and partition number, but using the UUID as the unique path prior to evaluating the offset. For example, root=PARTUUID=99DE9194-FC15-4223-9192-FC243948F88B/PARTNROFF=1 selects the partition with UUID 99DE.. then select the next partition. This change is motivated by a particular usecase in Chromium OS where the bootloader can easily determine what partition it is on (by UUID) but doesn't perform general partition table walking. That said, support for this model provides a direct mechanism for the user to modify the root partition to boot without specifically needing to extract each UUID or update the bootloader explicitly when the root partition UUID is changed (if it is recreated to be larger, for instance). Pinning to a /boot-style partition UUID allows the arbitrary root partition reconfiguration/modifications with slightly less ambiguity than just [dev][partition] and less stringency than the specific root partition UUID. [sfr@canb.auug.org.au: fix init sections warning] Signed-off-by: Will Drewry <wad@chromium.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02init/do_mounts_rd.c: fix ramdisk identification for padded cramfsNeil Armstrong
When a cramfs ramdisk padded with 512 bytes is given to the kernel, the current identify_ramdisk_image function fails to identify it. Tested with a padded cramfs image on an ARM based board. Signed-off-by: Neil Armstrong <narmstrong@neotion.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Davidlohr Bueso <dave@gnu.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-26Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) llist: Add back llist_add_batch() and llist_del_first() prototypes sched: Don't use tasklist_lock for debug prints sched: Warn on rt throttling sched: Unify the ->cpus_allowed mask copy sched: Wrap scheduler p->cpus_allowed access sched: Request for idle balance during nohz idle load balance sched: Use resched IPI to kick off the nohz idle balance sched: Fix idle_cpu() llist: Remove cpu_relax() usage in cmpxchg loops sched: Convert to struct llist llist: Add llist_next() irq_work: Use llist in the struct irq_work logic llist: Return whether list is empty before adding in llist_add() llist: Move cpu_relax() to after the cmpxchg() llist: Remove the platform-dependent NMI checks llist: Make some llist functions inline sched, tracing: Show PREEMPT_ACTIVE state in trace_sched_switch sched: Remove redundant test in check_preempt_tick() sched: Add documentation for bandwidth control sched: Return unused runtime on group dequeue ...
2011-10-26Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits) rcu: Move propagation of ->completed from rcu_start_gp() to rcu_report_qs_rsp() rcu: Remove rcu_needs_cpu_flush() to avoid false quiescent states rcu: Wire up RCU_BOOST_PRIO for rcutree rcu: Make rcu_torture_boost() exit loops at end of test rcu: Make rcu_torture_fqs() exit loops at end of test rcu: Permit rt_mutex_unlock() with irqs disabled rcu: Avoid having just-onlined CPU resched itself when RCU is idle rcu: Suppress NMI backtraces when stall ends before dump rcu: Prohibit grace periods during early boot rcu: Simplify unboosting checks rcu: Prevent early boot set_need_resched() from __rcu_pending() rcu: Dump local stack if cannot dump all CPUs' stacks rcu: Move __rcu_read_unlock()'s barrier() within if-statement rcu: Improve rcu_assign_pointer() and RCU_INIT_POINTER() documentation rcu: Make rcu_assign_pointer() unconditionally insert a memory barrier rcu: Make rcu_implicit_dynticks_qs() locals be correct size rcu: Eliminate in_irq() checks in rcu_enter_nohz() nohz: Remove nohz_cpu_mask rcu: Document interpretation of RCU-lockdep splats rcu: Allow rcutorture's stat_interval parameter to be changed at runtime ...
2011-10-26params: make dashes and underscores in parameter names truly equalMichal Schmidt
The user may use "foo-bar" for a kernel parameter defined as "foo_bar". Make sure it works the other way around too. Apply the equality of dashes and underscores on early_params and __setup params as well. The example given in Documentation/kernel-parameters.txt indicates that this is the intended behaviour. With the patch the kernel accepts "log-buf-len=1M" as expected. https://bugzilla.redhat.com/show_bug.cgi?id=744545 Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (neatened implementations)
2011-10-25jump-label: initialize jump-label subsystem much earlierJeremy Fitzhardinge
Initialize jump_labels much, much earlier, so they're available for use during system setup. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2011-10-04Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: pick up the latest fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-01Merge branch 'rcu/next' of git://github.com/paulmckrcu/linux into core/rcuIngo Molnar
2011-09-29bootup: move 'usermodehelper_enable()' a little earlierwangyanqing
Commit d5767c53535a ("bootup: move 'usermodehelper_enable()' to the end of do_basic_setup()") moved 'usermodehelper_enable()' to end of do_basic_setup() to after the initcalls. But then I get failed to let uvesafb work on my computer, and lose the splash boot. So maybe we could start usermodehelper_enable a little early to make some task work that need eary init with the help of user mode. [ I would *really* prefer that initcalls not call into user space - even the real 'init' hasn't been execve'd yet, after all! But for uvesafb it really does look like we don't have much choice. I considered doing this when we mount the root filesystem, but depending on config options that is in multiple places. We could do the usermode helper enable as a rootfs_initcall().. So I'm just using wang yanqing's trivial patch. It's not wonderful, but it's simple and should work. We should revisit this some day, though. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-28rcu: Drive configuration directly from SMP and PREEMPTPaul E. McKenney
This commit eliminates the possibility of running TREE_PREEMPT_RCU when SMP=n and of running TINY_RCU when PREEMPT=y. People who really want these combinations can hand-edit init/Kconfig, but eliminating them as choices for production systems reduces the amount of testing required. It will also allow cutting out a few #ifdefs. Note that running TREE_RCU and TINY_RCU on single-CPU systems using SMP-built kernels is still supported. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28bootup: move 'usermodehelper_enable()' to the end of do_basic_setup()Linus Torvalds
Doing it just before starting to call into cpu_idle() made a sick kind of sense only because the original bug we fixed (see commit 288d5abec831: "Boot up with usermodehelper disabled") was about problems with some scheduler data structures not being initialized, and they had better be initialized at that point. But it really didn't make any other conceptual sense, and doing it after the initial "schedule()" call for the idle thread actually opened up a race: what if the main initialization thread did everything without needing to sleep, and got all the way into user land too? Without actually having scheduled back to the idle thread? Now, in normal circumstances that doesn't ever happen, but it looks like Richard Cochran triggered exactly that on his ARM IXP4xx machines: "I have some ARM IXP4xx based machines that use the two on chip MAC ports (aka NPEs). The NPE needs a firmware in order to function. Ever since the following commit [that 288d5abec831 one], it is no longer possible to bring up the interfaces during the init scripts." with a call trace showing an ioctl coming from user space. Richard says: "The init is busybox, and the startup script does mount, syslogd, and then ifup, so that all can go by quickly." The fix is to move the usermodehelper_enable() into the main 'init' thread, and just put it after we've done all our initcalls. By then, everything really should be up, but we've obviously not actually started the user-mode portion of init yet. Reported-and-tested-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-21init: carefully handle loglevel option on kernel cmdline.Alexander Sverdlin
When a malformed loglevel value (for example "${abc}") is passed on the kernel cmdline, the loglevel itself is being set to 0. That then suppresses all following messages, including all the errors and crashes caused by other malformed cmdline options. This could make debugging process quite tricky. This patch leaves the previous value of loglevel if the new value is incorrect and reports an error code in this case. Signed-off-by: Alexander Sverdlin <alexander.sverdlin@sysgo.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
