path: root/init
2013-02-14efi: Make 'efi_enabled' a function to query EFI facilitiesMatt Fleming
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream. Originally 'efi_enabled' indicated whether a kernel was booted from EFI firmware. Over time its semantics have changed, and it now indicates whether or not we are booted on an EFI machine with bit-native firmware, e.g. 64-bit kernel with 64-bit firmware. The immediate motivation for this patch is the bug report at, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 which details how running a platform driver on an EFI machine that is designed to run under BIOS can cause the machine to become bricked. Also, the following report, https://bugzilla.kernel.org/show_bug.cgi?id=47121 details how running said driver can also cause Machine Check Exceptions. Drivers need a new means of detecting whether they're running on an EFI machine, as sadly the expression, if (!efi_enabled) hasn't been a sufficient condition for quite some time. Users actually want to query 'efi_enabled' for different reasons - what they really want access to is the list of available EFI facilities. For instance, the x86 reboot code needs to know whether it can invoke the ResetSystem() function provided by the EFI runtime services, while the ACPI OSL code wants to know whether the EFI config tables were mapped successfully. There are also checks in some of the platform driver code to simply see if they're running on an EFI machine (which would make it a bad idea to do BIOS-y things). This patch is a prereq for the samsung-laptop fix patch. Signed-off-by: Matt Fleming <matt.fleming@intel.com> Cc: David Airlie <airlied@linux.ie> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Olof Johansson <olof@lixom.net> Cc: Peter Jones <pjones@redhat.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Konrad Rzeszutek Wilk <konrad@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31efi: Defer freeing boot services memory until after ACPI initJosh Triplett
commit 785107923a83d8456bbd8564e288a24d84109a46 upstream. Some new ACPI 5.0 tables reference resources stored in boot services memory, so keep that memory around until we have ACPI and can extract data from it. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Link: http://lkml.kernel.org/r/baaa6d44bdc4eb0c58e5d1b4ccd2c729f854ac55.1348876882.git.josh@joshtriplett.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Matt Fleming <matt@console-pimps.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17module_param: stop double-calling parameters.Rusty Russell
commit ae82fdb1406ad41d68f07027fe31f2d35ba22a90 upstream. Commit 026cee0086fe1df4cf74691cf273062cc769617d "params: <level>_initcall-like kernel parameters" set old-style module parameters to level 0. And we call those level 0 calls where we used to, early in start_kernel(). We also loop through the initcall levels and call the levelled module_params before the corresponding initcall. Unfortunately level 0 is early_init(), so we call the standard module_param calls twice. (Turns out most things don't care, but at least ubi.mtd does). Change the level to -1 for standard module_param calls. Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01Fix blocking allocations called very early during bootupLinus Torvalds
commit 31a67102f4762df5544bc2dfb34a931233d2a5b2 upstream. During early boot, when the scheduler hasn't really been fully set up, we really can't do blocking allocations because with certain (dubious) configurations the "might_resched()" calls can actually result in scheduling events. We could just make such users always use GFP_ATOMIC, but quite often the code that does the allocation isn't really aware of the fact that the scheduler isn't up yet, and forcing that kind of random knowledge on the initialization code is just annoying and not good for anybody. And we actually have a the 'gfp_allowed_mask' exactly for this reason: it's just that the kernel init sequence happens to set it to allow blocking allocations much too early. So move the 'gfp_allowed_mask' initialization from 'start_kernel()' (which is some of the earliest init code, and runs with preemption disabled for good reasons) into 'kernel_init()'. kernel_init() is run in the newly created thread that will become the 'init' process, as opposed to the early startup code that runs within the context of what will be the first idle thread. So by the time we reach 'kernel_init()', we know that the scheduler must be at least limping along, because we've already scheduled from the idle thread into the init thread. Reported-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-05init: don't try mounting device as nfs root unless type fully matchesSasha Levin
Currently, we'll try mounting any device who's major device number is UNNAMED_MAJOR as NFS root. This would happen for non-NFS devices as well (such as 9p devices) but it wouldn't cause any issues since mounting the device as NFS would fail quickly and the code proceeded to doing the proper mount: [ 101.522716] VFS: Unable to mount root fs via NFS, trying floppy. [ 101.534499] VFS: Mounted root (9p filesystem) on device 0:18. Commit 6829a048102a ("NFS: Retry mounting NFSROOT") introduced retries when mounting NFS root, which means that now we don't immediately fail and instead it takes an additional 90+ seconds until we stop retrying, which has revealed the issue this patch fixes. This meant that it would take an additional 90 seconds to boot when we're not using a device type which gets detected in order before NFS. This patch modifies the NFS type check to require device type to be 'Root_NFS' instead of requiring the device to have an UNNAMED_MAJOR major. This makes boot process cleaner since we now won't go through the NFS mounting code at all when the device isn't an NFS root ("/dev/nfs"). Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-25init: fix bug where environment vars can't be passed via boot argsChris Metcalf
Commit 026cee0086f had the side-effect of dropping the '=' from the unknown boot arguments that are passed to init as environment variables. This is because parse_args() puts a NUL in the string where the '=' was when it passes the "param" and "val" pointers to the parsing subfunctions. Previously, unknown_bootoption() was the last parse_args() subfunction to run, and it carefully put back the '=' character. Now the ignore_unknown_bootoption() is the last one to run, and it wasn't doing the necessary repair, so the envp params ended up with the embedded NUL and were no longer seen as valid environment variables by init. Tested-by: Woody Suwalski <terraluna977@gmail.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-04-02Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Pull cpumask cleanups from Rusty Russell: "(Somehow forgot to send this out; it's been sitting in linux-next, and if you don't want it, it can sit there another cycle)" I'm a sucker for things that actually delete lines of code. Fix up trivial conflict in arch/arm/kernel/kprobes.c, where Rusty fixed a user of &cpu_online_map to be cpu_online_mask, but that code got deleted by commit b21d55e98ac2 ("ARM: 7332/1: extract out code patch function from kprobes"). * tag 'for-linus' of git://github.com/rustyrussell/linux: cpumask: remove old cpu_*_map. documentation: remove references to cpu_*_map. drivers/cpufreq/db8500-cpufreq: remove references to cpu_*_map. remove references to cpu_*_map in arch/
2012-03-31new helper: ext2_image_size()Al Viro
... implemented that way since the next commit will leave it almost alone in ext2_fs.h - most of the file (including struct ext2_super_block) is going to move to fs/ext2/ext2.h. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31get rid of pointless includes of ext2_fs.hAl Viro
2012-03-29documentation: remove references to cpu_*_map.Rusty Russell
This has been obsolescent for a while, fix documentation and misc comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Move all declarations of free_initmem() to linux/mm.hDavid Howells
Move all declarations of free_initmem() to linux/mm.h so that there's only one and it's used by everything. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-c6x-dev@linux-c6x.org cc: microblaze-uclinux@itee.uq.edu.au cc: linux-sh@vger.kernel.org cc: sparclinux@vger.kernel.org cc: x86@kernel.org cc: linux-mm@kvack.org
2012-03-26params: <level>_initcall-like kernel parametersPawel Moll
This patch adds a set of macros that can be used to declare kernel parameters to be parsed _before_ initcalls at a chosen level are executed. We rename the now-unused "flags" field of struct kernel_param as the level. It's signed, for when we use this for early params as well, in future. Linker macro collating init calls had to be modified in order to add additional symbols between levels that are later used by the init code to split the calls into blocks. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-23init/do_mounts.c: print error code on mount failureBernhard Walle
Printing the error code makes it easier to debug the cause of a mount failure. For example I had the problem that the root file system could not be mounted read-writeable because my SD card was write-protected. Without an error code it looks like the SD card was not detected at all. Signed-off-by: Bernhard Walle <bernhard@bwalle.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23init: check printed flag to skip printing messageDiwakar Tundlam
Otherwise the 'Calibration skipped' message gets printed everytime a CPU is hotplugged in, cluttering console for systems that frequently hotplug CPUs. Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: Sameer Nanda <snanda@chromium.org> Cc: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc merge from Benjamin Herrenschmidt: "Here's the powerpc batch for this merge window. It is going to be a bit more nasty than usual as in touching things outside of arch/powerpc mostly due to the big iSeriesectomy :-) We finally got rid of the bugger (legacy iSeries support) which was a PITA to maintain and that nobody really used anymore. Here are some of the highlights: - Legacy iSeries is gone. Thanks Stephen ! There's still some bits and pieces remaining if you do a grep -ir series arch/powerpc but they are harmless and will be removed in the next few weeks hopefully. - The 'fadump' functionality (Firmware Assisted Dump) replaces the previous (equivalent) "pHyp assisted dump"... it's a rewrite of a mechanism to get the hypervisor to do crash dumps on pSeries, the new implementation hopefully being much more reliable. Thanks Mahesh Salgaonkar. - The "EEH" code (pSeries PCI error handling & recovery) got a big spring cleaning, motivated by the need to be able to implement a new backend for it on top of some new different type of firwmare. The work isn't complete yet, but a good chunk of the cleanups is there. Note that this adds a field to struct device_node which is not very nice and which Grant objects to. I will have a patch soon that moves that to a powerpc private data structure (hopefully before rc1) and we'll improve things further later on (hopefully getting rid of the need for that pointer completely). Thanks Gavin Shan. - I dug into our exception & interrupt handling code to improve the way we do lazy interrupt handling (and make it work properly with "edge" triggered interrupt sources), and while at it found & fixed a wagon of issues in those areas, including adding support for page fault retry & fatal signals on page faults. - Your usual random batch of small fixes & updates, including a bunch of new embedded boards, both Freescale and APM based ones, etc..." I fixed up some conflicts with the generalized irq-domain changes from Grant Likely, hopefully correctly. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits) powerpc/ps3: Do not adjust the wrapper load address powerpc: Remove the rest of the legacy iSeries include files powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces init: Remove CONFIG_PPC_ISERIES powerpc: Remove FW_FEATURE ISERIES from arch code tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable powerpc/spufs: Fix double unlocks powerpc/5200: convert mpc5200 to use of_platform_populate() powerpc/mpc5200: add options to mpc5200_defconfig powerpc/mpc52xx: add a4m072 board support powerpc/mpc5200: update mpc5200_defconfig to fit for charon board Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board MAINTAINERS: Update PowerPC 4xx tree powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board powerpc: document the FSL MPIC message register binding powerpc: add support for MPIC message register API powerpc/fsl: Added aliased MSIIR register address to MSI node in dts powerpc/85xx: mpc8548cds - add 36-bit dts ...
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-03-21init: Remove CONFIG_PPC_ISERIESStephen Rothwell
It is no longer selectable, so remove the check for it. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-03-20Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes for v3.4 from Ingo Molnar * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) printk: Make it compile with !CONFIG_PRINTK sched/x86: Fix overflow in cyc2ns_offset sched: Fix nohz load accounting -- again! sched: Update yield() docs printk/sched: Introduce special printk_sched() for those awkward moments sched/nohz: Correctly initialize 'next_balance' in 'nohz' idle balancer sched: Cleanup cpu_active madness sched: Fix load-balance wreckage sched: Clean up parameter passing of proc_sched_autogroup_set_nice() sched: Ditch per cgroup task lists for load-balancing sched: Rename load-balancing fields sched: Move load-balancing arguments into helper struct sched/rt: Do not submit new work when PI-blocked sched/rt: Prevent idle task boosting sched/wait: Add __wake_up_all_locked() API sched/rt: Document scheduler related skip-resched-check sites sched/rt: Use schedule_preempt_disabled() sched/rt: Add schedule_preempt_disabled() sched/rt: Do not throttle when PI boosting sched/rt: Keep period timer ticking when rt throttling is active ...
2012-03-15init: fix wording error in mm_init commentJim Cromie
s/countinuous/contiguous/, reword sentence. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-21rcu: Move RCU_TRACE to lib/Kconfig.debugPaul E. McKenney
The RCU_TRACE kernel parameter has always been intended for debugging, not for production use. Formalize this by moving RCU_TRACE from init/Kconfig to lib/Kconfig.debug. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits) audit: no leading space in audit_log_d_path prefix audit: treat s_id as an untrusted string audit: fix signedness bug in audit_log_execve_info() audit: comparison on interprocess fields audit: implement all object interfield comparisons audit: allow interfield comparison between gid and ogid audit: complex interfield comparison helper audit: allow interfield comparison in audit rules Kernel: Audit Support For The ARM Platform audit: do not call audit_getname on error audit: only allow tasks to set their loginuid if it is -1 audit: remove task argument to audit_set_loginuid audit: allow audit matching on inode gid audit: allow matching on obj_uid audit: remove audit_finish_fork as it can't be called audit: reject entry,always rules audit: inline audit_free to simplify the look of generic code audit: drop audit_set_macxattr as it doesn't do anything audit: inline checks for not needing to collect aux records audit: drop some potentially inadvisable likely notations ... Use evil merge to fix up grammar mistakes in Kconfig file. Bad speling and horrible grammar (and copious swearing) is to be expected, but let's keep it to commit messages and comments, rather than expose it to users in config help texts or printouts.
2012-01-17Kernel: Audit Support For The ARM PlatformNathaniel Husted
This patch provides functionality to audit system call events on the ARM platform. The implementation was based off the structure of the MIPS platform and information in this (http://lists.fedoraproject.org/pipermail/arm/2009-October/000382.html) mailing list thread. The required audit_syscall_exit and audit_syscall_entry checks were added to ptrace using the standard registers for system call values (r0 through r3). A thread information flag was added for auditing (TIF_SYSCALL_AUDIT) and a meta-flag was added (_TIF_SYSCALL_WORK) to simplify modifications to the syscall entry/exit. Now, if either the TRACE flag is set or the AUDIT flag is set, the syscall_trace function will be executed. The prober changes were made to Kconfig to allow CONFIG_AUDITSYSCALL to be enabled. Due to platform availability limitations, this patch was only tested on the Android platform running the modified "android-goldfish-2.6.29" kernel. A test compile was performed using Code Sourcery's cross-compilation toolset and the current linux-3.0 stable kernel. The changes compile without error. I'm hoping, due to the simple modifications, the patch is "obviously correct". Signed-off-by: Nathaniel Husted <nhusted@gmail.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: only allow tasks to set their loginuid if it is -1Eric Paris
At the moment we allow tasks to set their loginuid if they have CAP_AUDIT_CONTROL. In reality we want tasks to set the loginuid when they log in and it be impossible to ever reset. We had to make it mutable even after it was once set (with the CAP) because on update and admin might have to restart sshd. Now sshd would get his loginuid and the next user which logged in using ssh would not be able to set his loginuid. Systemd has changed how userspace works and allowed us to make the kernel work the way it should. With systemd users (even admins) are not supposed to restart services directly. The system will restart the service for them. Thus since systemd is going to loginuid==-1, sshd would get -1, and sshd would be allowed to set a new loginuid without special permissions. If an admin in this system were to manually start an sshd he is inserting himself into the system chain of trust and thus, logically, it's his loginuid that should be used! Since we have old systems I make this a Kconfig option. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-14Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1 * tag 'for-linus' of git://github.com/rustyrussell/linux: module_param: check that bool parameters really are bool. intelfbdrv.c: bailearly is an int module_param paride/pcd: fix bool verbose module parameter. module_param: make bool parameters really bool (drivers & misc) module_param: make bool parameters really bool (arch) module_param: make bool parameters really bool (core code) kernel/async: remove redundant declaration. printk: fix unnecessary module_param_name. lirc_parallel: fix module parameter description. module_param: avoid bool abuse, add bint for special cases. module_param: check type correctness for module_param_array modpost: use linker section to generate table. modpost: use a table rather than a giant if/else statement. modules: sysfs - export: taint, coresize, initsize kernel/params: replace DEBUGP with pr_debug module: replace DEBUGP with pr_debug module: struct module_ref should contains long fields module: Fix performance regression on modules with large symbol tables module: Add comments describing how the "strmap" logic works Fix up conflicts in scripts/mod/file2alias.c due to the new linker- generated table approach to adding __mod_*_device_table entries. The ARM sa11x0 mcp bus needed to be converted to that too.
2012-01-12c/r: introduce CHECKPOINT_RESTORE symbolCyrill Gorcunov
For checkpoint/restore we need auxilary features being compiled into the kernel, such as additional prctl codes, /proc/<pid>/map_files and etc... but same time these features are not mandatory for a regular kernel so CHECKPOINT_RESTORE config symbol should bring a way to disable them all at once if one wish to get rid of additional functionality. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Vagin <avagin@openvz.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: Vasiliy Kulikov <segoon@openwall.com> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-13module_param: make bool parameters really bool (core code)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-11Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix lockup by limiting load-balance retries on lock-break sched: Fix CONFIG_CGROUP_SCHED dependency sched: Remove empty #ifdefs
2012-01-11Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/intel config: Fix the APB_TIMER selection x86/mrst: Add additional debug prints for pb_keys x86/intel config: Revamp configuration to allow for Moorestown and Medfield x86/intel/scu/ipc: Match the changes in the x86 configuration x86/apb: Fix configuration constraints x86: Fix INTEL_MID silly x86/Kconfig: Cyclone-timer depends on x86-summit x86: Reduce clock calibration time during slave cpu startup x86/config: Revamp configuration for MID devices x86/sfi: Kill the IRQ as id hack
2012-01-11Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/numa: Add constraints check for nid parameters mm, x86: Remove debug_pagealloc_enabled x86/mm: Initialize high mem before free_all_bootmem() arch/x86/kernel/e820.c: quiet sparse noise about plain integer as NULL pointer arch/x86/kernel/e820.c: Eliminate bubble sort from sanitize_e820_map() x86: Fix mmap random address range x86, mm: Unify zone_sizes_init() x86, mm: Prepare zone_sizes_init() for unification x86, mm: Use max_low_pfn for ZONE_NORMAL on 64-bit x86, mm: Wrap ZONE_DMA32 with CONFIG_ZONE_DMA32 x86, mm: Use max_pfn instead of highend_pfn x86, mm: Move zone init from paging_init() on 64-bit x86, mm: Use MAX_DMA_PFN for ZONE_DMA on 32-bit
2012-01-10Merge branch 'nfs-for-3.3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'nfs-for-3.3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4: Change the default setting of the nfs4_disable_idmapping parameter NFSv4: Save the owner/group name string when doing open NFS: Remove pNFS bloat from the generic write path pnfs-obj: Must return layout on IO error pnfs-obj: pNFS errors are communicated on iodata->pnfs_error NFS: Cache state owners after files are closed NFS: Clean up nfs4_find_state_owners_locked() NFSv4: include bitmap in nfsv4 get acl data nfs: fix a minor do_div portability issue NFSv4.1: cleanup comment and debug printk NFSv4.1: change nfs4_free_slot parameters for dynamic slots NFSv4.1: cleanup init and reset of session slot tables NFSv4.1: fix backchannel slotid off-by-one bug nfs: fix regression in handling of context= option in NFSv4 NFS - fix recent breakage to NFS error handling. NFS: Retry mounting NFSROOT SUNRPC: Clean up the RPCSEC_GSS service ticket requests
2012-01-10sched: Fix CONFIG_CGROUP_SCHED dependencyFabio Estevam
The dependency bug was pointed out by this build warning: warning: (SCHED_AUTOGROUP) selects CGROUP_SCHED which has unmet direct dependencies (CGROUPS && EXPERIMENTAL) Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: a.p.zijlstra@chello.nl Cc: Fabio Estevam <festevam@gmail.com> Link: http://lkml.kernel.org/r/1326192383-5113-1-git-send-email-festevam@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-08Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (165 commits) reiserfs: Properly display mount options in /proc/mounts vfs: prevent remount read-only if pending removes vfs: count unlinked inodes vfs: protect remounting superblock read-only vfs: keep list of mounts for each superblock vfs: switch ->show_options() to struct dentry * vfs: switch ->show_path() to struct dentry * vfs: switch ->show_devname() to struct dentry * vfs: switch ->show_stats to struct dentry * switch security_path_chmod() to struct path * vfs: prefer ->dentry->d_sb to ->mnt->mnt_sb vfs: trim includes a bit switch mnt_namespace ->root to struct mount vfs: take /proc/*/mounts and friends to fs/proc_namespace.c vfs: opencode mntget() mnt_set_mountpoint() vfs: spread struct mount - remaining argument of next_mnt() vfs: move fsnotify junk to struct mount vfs: move mnt_devname vfs: move mnt_list to struct mount vfs: switch pnode.h macros to struct mount * ...
2012-01-06vfs: prefer ->dentry->d_sb to ->mnt->mnt_sbAl Viro
2012-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1958 commits) net: pack skb_shared_info more efficiently net_sched: red: split red_parms into parms and vars net_sched: sfq: extend limits cnic: Improve error recovery on bnx2x devices cnic: Re-init dev->stats_addr after chip reset net_sched: Bug in netem reordering bna: fix sparse warnings/errors bna: make ethtool_ops and strings const xgmac: cleanups net: make ethtool_ops const vmxnet3" make ethtool ops const xen-netback: make ops structs const virtio_net: Pass gfp flags when allocating rx buffers. ixgbe: FCoE: Add support for ndo_get_fcoe_hbainfo() call netdev: FCoE: Add new ndo_get_fcoe_hbainfo() call igb: reset PHY after recovering from PHY power down igb: add basic runtime PM support igb: Add support for byte queue limits. e1000: cleanup CE4100 MDIO registers access e1000: unmap ce4100_gbe_mdio_base_virt in e1000_remove ...
2012-01-06Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (64 commits) cpu: Export cpu_up() rcu: Apply ACCESS_ONCE() to rcu_boost() return value Revert "rcu: Permit rt_mutex_unlock() with irqs disabled" docs: Additional LWN links to RCU API rcu: Augment rcu_batch_end tracing for idle and callback state rcu: Add rcutorture tests for srcu_read_lock_raw() rcu: Make rcutorture test for hotpluggability before offlining CPUs driver-core/cpu: Expose hotpluggability to the rest of the kernel rcu: Remove redundant rcu_cpu_stall_suppress declaration rcu: Adaptive dyntick-idle preparation rcu: Keep invoking callbacks if CPU otherwise idle rcu: Irq nesting is always 0 on rcu_enter_idle_common rcu: Don't check irq nesting from rcu idle entry/exit rcu: Permit dyntick-idle with callbacks pending rcu: Document same-context read-side constraints rcu: Identify dyntick-idle CPUs on first force_quiescent_state() pass rcu: Remove dynticks false positives and RCU failures rcu: Reduce latency of rcu_prepare_for_idle() rcu: Eliminate RCU_FAST_NO_HZ grace-period hang rcu: Avoid needlessly IPIing CPUs at GP end ...
2012-01-05NFS: Retry mounting NFSROOTChuck Lever
Lukas Razik <linux@razik.name> reports that on his SPARC system, booting with an NFS root file system stopped working after commit 56463e50 "NFS: Use super.c for NFSROOT mount option parsing." We found that the network switch to which Lukas' client was attached was delaying access to the LAN after the client's NIC driver reported that its link was up. The delay was longer than the timeouts used in the NFS client during mounting. NFSROOT worked for Lukas before commit 56463e50 because in those kernels, the client's first operation was an rpcbind request to determine which port the NFS server was listening on. When that request failed after a long timeout, the client simply selected the default NFS port (2049). By that time the switch was allowing access to the LAN, and the mount succeeded. Neither of these client behaviors is desirable, so reverting 56463e50 is really not a choice. Instead, introduce a mechanism that retries the NFSROOT mount request several times. This is the same tactic that normal user space NFS mounts employ to overcome server and network delays. Signed-off-by: Lukas Razik <linux@razik.name> [ cel: match kernel coding style, add proper patch description ] [ cel: add exponential back-off ] Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: Lukas Razik <linux@razik.name> Cc: stable@kernel.org # > 2.6.38 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-03init/initramfs.c: should use umode_tAl Viro
2011-12-12Basic kernel memory functionality for the Memory ControllerGlauber Costa
This patch lays down the foundation for the kernel memory component of the Memory Controller. As of today, I am only laying down the following files: * memory.independent_kmem_limit * memory.kmem.limit_in_bytes (currently ignored) * memory.kmem.usage_in_bytes (always zero) Signed-off-by: Glauber Costa <glommer@parallels.com> CC: Kirill A. Shutemov <kirill@shutemov.name> CC: Paul Menage <paul@paulmenage.org> CC: Greg Thelen <gthelen@google.com> CC: Johannes Weiner <jweiner@redhat.com> CC: Michal Hocko <mhocko@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-11rcu: Permit RCU_FAST_NO_HZ to be used by TREE_PREEMPT_RCUPaul E. McKenney
The new implementation of RCU_FAST_NO_HZ is compatible with preemptible RCU, so this commit removes the Kconfig restriction that previously prohibited this. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-12-06mm, x86: Remove debug_pagealloc_enabledStanislaw Gruszka
When (no)bootmem finish operation, it pass pages to buddy allocator. Since debug_pagealloc_enabled is not set, we will do not protect pages, what is not what we want with CONFIG_DEBUG_PAGEALLOC=y. To fix remove debug_pagealloc_enabled. That variable was introduced by commit 12d6f21e "x86: do not PSE on CONFIG_DEBUG_PAGEALLOC=y" to get more CPA (change page attribude) code testing. But currently we have CONFIG_CPA_DEBUG, which test CPA. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/1322582711-14571-1-git-send-email-sgruszka@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-06init/main.c: Execute lockdep_init() as early as possibleMing Lei
This patch fixes a lockdep warning on ARM platforms: [ 0.000000] WARNING: lockdep init error! Arch code didn't call lockdep_init() early enough? [ 0.000000] Call stack leading to lockdep invocation was: [ 0.000000] [<c00164bc>] save_stack_trace_tsk+0x0/0x90 [ 0.000000] [<ffffffff>] 0xffffffff The warning is caused by printk inside smp_setup_processor_id(). It is safe to do this because lockdep_init() doesn't depend on smp_setup_processor_id(), so improve things that printk can be called as early as possible without lockdep complaint. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Reviewed-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1321508072-23853-1-git-send-email-tom.leiming@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86: Reduce clock calibration time during slave cpu startupJack Steiner
Reduce the startup time for slave cpus. Adds hooks for an arch-specific function for clock calibration. These hooks are used on x86. If a newly started cpu has the same phys_proc_id as a core already active, uses the TSC for the delay loop and has a CONSTANT_TSC, use the already-calculated value of loops_per_jiffy. This patch reduces the time required to start slave cpus on a 4096 cpu system from: 465 sec OLD 62 sec NEW This reduces boot time on a 4096p system by almost 7 minutes. Nice... Signed-off-by: Jack Steiner <steiner@sgi.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: John Stultz <john.stultz@linaro.org> [fix CONFIG_SMP=n build] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-06Merge branch 'upstream/jump-label-noearly' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/jump-label-noearly' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: jump-label: initialize jump-label subsystem much earlier x86/jump_label: add arch_jump_label_transform_static() s390/jump-label: add arch_jump_label_transform_static() jump_label: add arch_jump_label_transform_static() to optimise non-live code updates sparc/jump_label: drop arch_jump_label_text_poke_early() x86/jump_label: drop arch_jump_label_text_poke_early() jump_label: if a key has already been initialized, don't nop it out stop_machine: make stop_machine safe and efficient to call early jump_label: use proper atomic_t initializer Conflicts: - arch/x86/kernel/jump_label.c Added __init_or_module to arch_jump_label_text_poke_early vs removal of that function entirely - kernel/stop_machine.c same patch ("stop_machine: make stop_machine safe and efficient to call early") merged twice, with whitespace fix in one version
2011-11-02sysctl: make CONFIG_SYSCTL_SYSCALL default to nWANG Cong
When I tried to send a patch to remove it, Andi told me we still need to keep compabitlies for old libc, so we can't remove this completely. Then just make it default to n and remove the doc from feature-removal-schedule.txt. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02init: add root=PARTUUID=UUID/PARTNROFF=%d supportWill Drewry
Expand root=PARTUUID=UUID syntax to support selecting a root partition by integer offset from a known, unique partition. This approach provides similar properties to specifying a device and partition number, but using the UUID as the unique path prior to evaluating the offset. For example, root=PARTUUID=99DE9194-FC15-4223-9192-FC243948F88B/PARTNROFF=1 selects the partition with UUID 99DE.. then select the next partition. This change is motivated by a particular usecase in Chromium OS where the bootloader can easily determine what partition it is on (by UUID) but doesn't perform general partition table walking. That said, support for this model provides a direct mechanism for the user to modify the root partition to boot without specifically needing to extract each UUID or update the bootloader explicitly when the root partition UUID is changed (if it is recreated to be larger, for instance). Pinning to a /boot-style partition UUID allows the arbitrary root partition reconfiguration/modifications with slightly less ambiguity than just [dev][partition] and less stringency than the specific root partition UUID. [sfr@canb.auug.org.au: fix init sections warning] Signed-off-by: Will Drewry <wad@chromium.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02init/do_mounts_rd.c: fix ramdisk identification for padded cramfsNeil Armstrong
When a cramfs ramdisk padded with 512 bytes is given to the kernel, the current identify_ramdisk_image function fails to identify it. Tested with a padded cramfs image on an ARM based board. Signed-off-by: Neil Armstrong <narmstrong@neotion.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Davidlohr Bueso <dave@gnu.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-26Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) llist: Add back llist_add_batch() and llist_del_first() prototypes sched: Don't use tasklist_lock for debug prints sched: Warn on rt throttling sched: Unify the ->cpus_allowed mask copy sched: Wrap scheduler p->cpus_allowed access sched: Request for idle balance during nohz idle load balance sched: Use resched IPI to kick off the nohz idle balance sched: Fix idle_cpu() llist: Remove cpu_relax() usage in cmpxchg loops sched: Convert to struct llist llist: Add llist_next() irq_work: Use llist in the struct irq_work logic llist: Return whether list is empty before adding in llist_add() llist: Move cpu_relax() to after the cmpxchg() llist: Remove the platform-dependent NMI checks llist: Make some llist functions inline sched, tracing: Show PREEMPT_ACTIVE state in trace_sched_switch sched: Remove redundant test in check_preempt_tick() sched: Add documentation for bandwidth control sched: Return unused runtime on group dequeue ...
2011-10-26Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits) rcu: Move propagation of ->completed from rcu_start_gp() to rcu_report_qs_rsp() rcu: Remove rcu_needs_cpu_flush() to avoid false quiescent states rcu: Wire up RCU_BOOST_PRIO for rcutree rcu: Make rcu_torture_boost() exit loops at end of test rcu: Make rcu_torture_fqs() exit loops at end of test rcu: Permit rt_mutex_unlock() with irqs disabled rcu: Avoid having just-onlined CPU resched itself when RCU is idle rcu: Suppress NMI backtraces when stall ends before dump rcu: Prohibit grace periods during early boot rcu: Simplify unboosting checks rcu: Prevent early boot set_need_resched() from __rcu_pending() rcu: Dump local stack if cannot dump all CPUs' stacks rcu: Move __rcu_read_unlock()'s barrier() within if-statement rcu: Improve rcu_assign_pointer() and RCU_INIT_POINTER() documentation rcu: Make rcu_assign_pointer() unconditionally insert a memory barrier rcu: Make rcu_implicit_dynticks_qs() locals be correct size rcu: Eliminate in_irq() checks in rcu_enter_nohz() nohz: Remove nohz_cpu_mask rcu: Document interpretation of RCU-lockdep splats rcu: Allow rcutorture's stat_interval parameter to be changed at runtime ...
