The wake-up part of semtimedop() consists out of two steps:
- the right tasks must be identified.
- they must be woken up.
Right now, both steps run while the array spinlock is held. This patch
reorders the code and moves the actual wake_up_process() behind the point
where the spinlock is dropped.
The code also moves setting sem->sem_otime to one place: It does not make
sense to set the last modify time multiple times.
[akpm@linux-foundation.org: repair kerneldoc]
[akpm@linux-foundation.org: fix uninitialised retval]
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Zach Brown <zach.brown@oracle.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Nick Piggin <npiggin@suse.de>
The following series of patches tries to fix the spinlock contention
reported by Chris Mason - his benchmark exposes problems of the current
code:
- In the worst case, the algorithm used by update_queue() is O(N^2).
Bulk wake-up calls can enter this worst case. The patch series fix
that.
Note that the benchmark app doesn't expose the problem, it just should
be fixed: Real world apps might do the wake-ups in another order than
perfect FIFO.
- The part of the code that runs within the semaphore array spinlock is
significantly larger than necessary.
The patch series fixes that. This change is responsible for the main
improvement.
- The cacheline with the spinlock is also used for a variable that is
read in the hot path (sem_base) and for a variable that is unnecessarily
written to multiple times (sem_otime). The last step of the series
cacheline-aligns the spinlock.
This patch:
The SysV semaphore code allows to perform multiple operations on all
semaphores in the array as atomic operations. After a modification,
update_queue() checks which of the waiting tasks can complete.
The algorithm that is used to identify the tasks is O(N^2) in the worst
case. For some cases, it is simple to avoid the O(N^2).
The patch adds a detection logic for some cases, especially for the case
of an array where all sleeping tasks are single sembuf operations and a
multi-sembuf operation is used to wake up multiple tasks.
A big database application uses that approach.
The patch fixes wakeup due to semctl(,,SETALL,) - the initial version of
the patch breaks that.
[akpm@linux-foundation.org: make do_smart_update() static]
This line is unreachable, remove it.
[akpm@linux-foundation.org: remove unneeded initialisation of `err']
Signed-off-by: WANG Cong <amwang@redhat.com>
If multiple simple decrements on the same semaphore are pending, then the
current code scans all decrement operations, even if the semaphore value
is already 0.
The patch optimizes that: if the semaphore value is 0, then there is no
need to scan the q->alter entries.
Note that this is a common case: It happens if 100 decrements by one are
pending and now an increment by one increases the semaphore value from 0
to 1. Without this patch, all 100 entries are scanned. With the patch,
only one entry is scanned, then woken up. Then the new rule triggers and
the scanning is aborted, without looking at the remaining 99 tasks.
With this patch, single sop increment/decrement by 1 are now O(1).
(same as with Nick's patch)
Cc: Pierre Peiffer <peifferp@gmail.com>
sysv sem has the concept of semaphore arrays that consist out of multiple
semaphores. Atomic operations that affect multiple semaphores are
supported.
The patch optimizes single semaphore operation calls that affect only one
semaphore: It's not necessary to scan all pending operations, it is
sufficient to scan the per-semaphore list.
The idea is from Nick Piggin version of an ipc sem improvement, the
implementation is different: The code tries to keep as much common code as
possible.
As the result, the patch is simpler, but optimizes fewer cases.
Based on Nick's findings:
supported.
The patch is the first step for optimizing simple, single semaphore
operations: In addition to the global list of all pending operations, a
2nd, per-semaphore list with the simple operations is added.
Note: this patch does not make sense by itself, the new list is used
nowhere.
Reduce the amount of scanning of the list of pending semaphore operations:
If try_atomic_semop failed, then no changes were applied. Thus no need to
restart.
Additionally, this patch correct an incorrect comment: It's possible to
wait for arbitrary semaphore values (do a dec by <x>, wait-for-zero, inc
by <x> in one atomic operation)
Both changes are from Nick Piggin, the patch is the result of a different
split of the individual changes.
The strange sysv semaphore wakeup scheme has a kind of busy-wait lock
involved, which could deadlock if preemption is enabled during the "lock".
It is an implementation detail (due to a spinlock being held) that this is
actually the case. However if "spinlocks" are made preemptible, or if the
sem lock is changed to a sleeping lock for example, then the wakeup would
become buggy. So this might be a bugfix for -rt kernels.
Imagine waker being preempted by wakee and never clearing IN_WAKEUP -- if
wakee has higher RT priority then there is a priority inversion deadlock.
Even if there is not a priority inversion to cause a deadlock, then there
is still time wasted spinning.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Replace the handcoded list operations in update_queue() with the standard
list_for_each_entry macros.
list_for_each_entry_safe() must be used, because list entries can
disappear immediately uppon the wakeup event.
Around a month ago, there was some discussion about an improvement of the
sysv sem algorithm: Most (at least: some important) users only use simple
semaphore operations, therefore it's worthwile to optimize this use case.
This patch:
Move last looked up sem_undo struct to the head of the task's undo list.
Attempt to move common entries to the front of the list so search time is
reduced. This reduces lookup_undo on oprofile of problematic SAP workload
by 30% (see patch 4 for a description of SAP workload).
We have apparently had a memory leak since
7ca7e564e049d8b350ec9d958ff25eaa24226352 "ipc: store ipcs into IDRs" in
2007. The idr of which 3 exist for each ipc namespace is never freed.
This patch simply frees them when the ipcns is freed. I don't believe any
idr_remove() are done from rcu (and could therefore be delayed until after
this idr_destroy()), so the patch should be safe. Some quick testing
showed no harm, and the memory leak fixed.
Caught by kmemleak.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Use previously introduced list_entry_rcu instead of an open-coded
list_entry + rcu_dereference combination.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: dipankar@in.ibm.com
LKML-Reference: <20090414181715.GA3634@psychotron.englab.brq.redhat.com>
System calls with an unsigned long long argument can't be converted with
the standard wrappers since that would include a cast to long, which in
turn means that we would lose the upper 32 bit on 32 bit architectures.
Also semctl can't use the standard wrapper since it has a 'union'
parameter.
So we handle them as special case and add some extra wrappers instead.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Reviewed-by: WANG Cong <wangcong@zeuux.org>
Signed-off-by: Alan Cox <alan@redhat.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The attached patch:
- reverses the locking order of ulp->lock and sem_lock:
Previously, it was first ulp->lock, then inside sem_lock.
Now it's the other way around.
- converts the undo structure to rcu.
Benefits:
- With the old locking order, IPC_RMID could not kfree the undo structures.
The stale entries remained in the linked lists and were released later.
- The patch fixes a a race in semtimedop(): if both IPC_RMID and a semget() that
recreates exactly the same id happen between find_alloc_undo() and sem_lock,
then semtimedop() would access already kfree'd memory.
Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net>
sem_array.sem_pending is a double linked list, the attached patch converts
it to struct list_head.
sem_queue.sma and sem_queue.id were never used, the attached patch removes
them.
The undo structures contain two linked lists, the attached patch replaces
them with generic struct list_head lists.
Cc: Nadia Derbey <Nadia.Derbey@bull.net>
sys_unshare(CLONE_NEWIPC) doesn't handle the undo lists properly, this can
cause a kernel memory corruption. CLONE_NEWIPC must detach from the existing
undo lists.
Fix, part 1: add support for sys_unshare(CLONE_SYSVSEM)
The original reason to not support it was the potential (inevitable?)
confusion due to the fact that sys_unshare(CLONE_SYSVSEM) has the
inverse meaning of clone(CLONE_SYSVSEM).
Our two most reasonable options then appear to be (1) fully support
CLONE_SYSVSEM, or (2) continue to refuse explicit CLONE_SYSVSEM,
but always do it anyway on unshare(CLONE_SYSVSEM). This patch does
(1).
Changelog:
Apr 16: SEH: switch to Manfred's alternative patch which
removes the unshare_semundo() function which
always refused CLONE_SYSVSEM.
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
semctl_down(), msgctl_down() and shmctl_down() are used to handle the same set
of commands for each kind of IPC. They all start to do the same job (they
retrieve the ipc and do some permission checks) before handling the commands
on their own.
This patch proposes to consolidate this by moving these same pieces of code
into one common function called ipcctl_pre_down().
It simplifies a little these xxxctl_down() functions and increases a little
the maintainability.
Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net>
Acked-by: Serge Hallyn <serue@us.ibm.com>
The IPC_SET command performs the same permission setting for all IPCs. This
patch introduces a common ipc_update_perm() function to update these
permissions and makes use of it for all IPCs.
All IPCs make use of an intermetiate *_setbuf structure to handle the IPC_SET
command. This is not really needed and, moreover, it complicates a little bit
the code.
This patch gets rid of the use of it and uses directly the semid64_ds/
msgid64_ds/shmid64_ds structure.
In addition of removing one struture declaration, it also simplifies and
improves a little bit the common 64-bits path.
semctl_down() takes one unused parameter: semnum. This patch proposes to get
rid of it.
semctl_down is called with the rwmutex (the one which protects the list of
ipcs) taken in write mode.
This patch moves this rwmutex taken in write-mode inside semctl_down.
This has the advantages of reducing a little bit the window during which this
rwmutex is taken, clarifying sys_semctl, and finally of having a coherent
behaviour with [shm|msg]ctl_down
Trivial patch which adds some small locking functions and makes use of them to
factorize some part of the code and to make it cleaner.
By continuing to consolidate a little the IPC code, each id can be built
directly in ipc_addid() instead of having it built from each callers of
ipc_addid()
And I also remove shm_addid() in order to have, as much as possible, the
same code for shm/sem/msg.
sem_exit_ns(), msg_exit_ns() and shm_exit_ns() are all called when an
ipc_namespace is released to free all ipcs of each type. But in fact, they
do the same thing: they loop around all ipcs to free them individually by
calling a specific routine.
This patch proposes to consolidate this by introducing a common function,
free_ipcs(), that do the job. The specific routine to call on each
individual ipcs is passed as parameter. For this, these ipc-specific
'free' routines are reworked to take a generic 'struct ipc_perm' as
parameter.
Cc: Cedric Le Goater <clg@fr.ibm.com>
Each ipc_namespace contains a table of 3 pointers to struct ipc_ids (3 for
msg, sem and shm, structure used to store all ipcs) These 'struct ipc_ids'
are dynamically allocated for each icp_namespace as the ipc_namespace
itself (for the init namespace, they are initialized with pointers to
static variables instead)
It is so for historical reason: in fact, before the use of idr to store the
ipcs, the ipcs were stored in tables of variable length, depending of the
maximum number of ipc allowed. Now, these 'struct ipc_ids' have a fixed
size. As they are allocated in any cases for each new ipc_namespace, there
is no gain of memory in having them allocated separately of the struct
ipc_namespace.
This patch proposes to make this table static in the struct ipc_namespace.
Thus, we can allocate all in once and get rid of all the code needed to
allocate and free these ipc_ids separately.
Acked-by: Cedric Le Goater <clg@fr.ibm.com>
These commands (SEM_STAT and IPC_STAT) are rather doing the same things
(only the meaning of the id given as input and the return value differ).
However, for the semaphores, they are handled in two different places (two
different functions).
This patch consolidates this for clarification by handling these both
commands in the same place in semctl_nolock(). It also removes one unused
parameter for this function.
Currently the IPC namespace management code is spread over the ipc/*.c files.
I moved this code into ipc/namespace.c file which is compiled out when needed.
The linux/ipc_namespace.h file is used to store the prototypes of the
functions in namespace.c and the stubs for NAMESPACES=n case. This is done
so, because the stub for copy_ipc_namespace requires the knowledge of the
CLONE_NEWIPC flag, which is in sched.h. But the linux/ipc.h file itself in
included into many many .c files via the sys.h->sem.h sequence so adding the
sched.h into it will make all these .c depend on sched.h which is not that
good. On the other hand the knowledge about the namespaces stuff is required
in 4 .c files only.
Besides, this patch compiles out some auxiliary functions from ipc/sem.c,
msg.c and shm.c files. It turned out that moving these functions into
namespaces.c is not that easy because they use many other calls and macros
from the original file. Moving them would make this patch complicated. On
the other hand all these functions can be consolidated, so I will send a
separate patch doing this a bit later.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
In the new implementation of the [sem|shm|msg]_lock[_check]() routines, we
use the return value of ipc_lock() in container_of() without any check.
But ipc_lock may return a errcode. The use of this errcode in
container_of() may alter this errcode, and we don't want this.
And in xxx_exit_ns, the pointer return by idr_find is of type 'struct
kern_ipc_per'...
Today, the code will work as is because the member used in these
container_of() is the first member of its container (offset == 0), the
errcode isn't changed then. But in the general case, we can't count on
this assumption and this may lead later to a real bug if we don't correct
this.
Again, the proposed solution is simple and correct. But, as pointed by
Nadia, with this solution, the same check will be done several times (in
all sub-callers...), what is not very funny/optimal...
With the use of idr to store the ipc, the case where the idr cache is
empty, when idr_get_new is called (this may happen even if we call
idr_pre_get() before), is not well handled: it lets
semget()/shmget()/msgget() return ENOSPC when this cache is empty, what 1.
does not reflect the facts and 2. does not conform to the man(s).
This patch fixes this by retrying the whole process of allocation in this case.
Some comments about sem_undo_list seem wrong.
About the comment above unlock_semundo:
"... If task2 now exits before task1 releases the lock (by calling
unlock_semundo()), then task1 will never call spin_unlock(). ..."
This is just wrong, I see no reason for which task1 will not call
spin_unlock... The rest of this comment is also wrong... Unless I
miss something (of course).
Finally, (un)lock_semundo functions are useless, so remove them
for simplification. (this avoids an useless if statement)
Remvoe the unneeded parameters from ipc_checkid() and ipc_buildid()
interfaces.
Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net>
This is a patch that fixes the way idr_find() used to be called in ipc_lock():
in all the paths that don't imply an update of the ipcs idr, it was called
without the idr tree being locked.
The changes are:
. in ipc_ids, the mutex has been changed into a reader/writer semaphore.
. ipc_lock() now takes the mutex as a reader during the idr_find().
. a new routine ipc_lock_down() has been defined: it doesn't take the
mutex, assuming that it is being held by the caller. This is the routine
that is now called in all the update paths.
Acked-by: Jarek Poplawski <jarkao2@o2.pl>
This patch fixes the wrong / obsolete comments in the ipc code. Also adds
a missing lock around ipc_get_maxid() in shm_get_stat().
This patch converts casts of struct kern_ipc_perm to
. struct msg_queue
. struct sem_array
. struct shmid_kernel
into the equivalent container_of() macro. It improves code maintenance
because the code need not change if kern_ipc_perm is no longer at the
beginning of the containing struct.
This patch introduces a new ipc_lock_check() routine interface:
. each time ipc_checkid() is called, this is done after calling ipc_lock().
ipc_checkid() is now called from inside ipc_lock_check().
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: fix RCU locking]
This patch introduces a change into the sys_msgget(), sys_semget() and
sys_shmget() routines: they now share a common code, which is better for
maintainability.
This patch introduces ipcs storage into IDRs. The main changes are:
. This ipc_ids structure is changed: the entries array is changed into a
root idr structure.
. The grow_ary() routine is removed: it is not needed anymore when adding
an ipc structure, since we are now using the IDR facility.
. The ipc_rmid() routine interface is changed:
. there is no need for this routine to return the pointer passed in as
argument: it is now declared as a void
. since the id is now part of the kern_ipc_perm structure, no need to
have it as an argument to the routine
This is the largest patch in the set. Make all (I hope) the places where
the pid is shown to or get from user operate on the virtual pids.
The idea is:
- all in-kernel data structures must store either struct pid itself
or the pid's global nr, obtained with pid_nr() call;
- when seeking the task from kernel code with the stored id one
should use find_task_by_pid() call that works with global pids;
- when showing pid's numerical value to the user the virtual one
should be used, but however when one shows task's pid outside this
task's namespace the global one is to be used;
- when getting the pid from userspace one need to consider this as
the virtual one and use appropriate task/pid-searching functions.
[akpm@linux-foundation.org: nuther build fix]
[akpm@linux-foundation.org: yet nuther build fix]
[akpm@linux-foundation.org: remove unneeded casts]
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Paul Menage <menage@google.com>
Mark variables with uninitialized_var() if such a warning appears,
and analysis proves that the var is initialized properly on all paths
it is used.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
CONFIG_UTS_NS and CONFIG_IPC_NS have very little value as they only
deactivate the unshare of the uts and ipc namespaces and do not improve
performance.
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Acked-by: "Serge E. Hallyn" <serue@us.ibm.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Pavel Emelianov <xemul@openvz.org>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Fix two issuses related to ipc_ids->entries freeing.
1. When freeing ipc namespace we need to free entries allocated
with ipc_init_ids().
2. When removing old entries in grow_ary() ipc_rcu_putref()
may be called on entries set to &ids->nullentry earlier in
ipc_init_ids().
This is almost impossible without namespaces, but with
them this situation becomes possible.
Found during OpenVZ testing after obvious leaks in beancounters.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Cc: Kirill Korotaev <dev@openvz.org>
Simplify get_undo_list() by dropping the unnecessary cast, removing the
size variable, and switching to kzalloc() instead of a kmalloc() followed
by a memset().
This cleanup was split then modified from Jes Sorenson's Task Notifiers
patches.
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Cc: Jes Sorensen <jes@sgi.com>
