path: root/ipc/util.c
2013-01-04ipc: add sysctl to specify desired next object idStanislav Kinsbursky
Add 3 new variables and sysctls to tune them (by one "next_id" variable for messages, semaphores and shared memory respectively). This variable can be used to set desired id for next allocated IPC object. By default it's equal to -1 and old behaviour is preserved. If this variable is non-negative, then desired idr will be extracted from it and used as a start value to search for free IDR slot. Notes: 1) this patch doesn't guarantee that the new object will have desired id. So it's up to user space how to handle new object with wrong id. 2) After a sucessful id allocation attempt, "next_id" will be set back to -1 (if it was non-negative). [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-06userns: Convert ipc to use kuid and kgid where appropriateEric W. Biederman
- Store the ipc owner and creator with a kuid - Store the ipc group and the crators group with a kgid. - Add error handling to ipc_update_perms, allowing it to fail if the uids and gids can not be converted to kuids or kgids. - Modify the proc files to display the ipc creator and owner in the user namespace of the opener of the proc file. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-30ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSIONWill Deacon
Rather than #define the options manually in the architecture code, add Kconfig options for them and select them there instead. This also allows us to select the compat IPC version parsing automatically for platforms using the old compat IPC interface. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20ipc,rcu: Convert call_rcu(ipc_immediate_free) to kfree_rcu()Lai Jiangshan
The rcu callback ipc_immediate_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(ipc_immediate_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-03-27ipc: fix util.c kernel-doc warningsRandy Dunlap
Fix ipc/util.c kernel-doc warnings: Warning(ipc/util.c:336): No description found for parameter 'ns' Warning(ipc/util.c:620): No description found for parameter 'ns' Warning(ipc/util.c:790): No description found for parameter 'ns' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: user namespaces: convert several capable() callsSerge E. Hallyn
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(), because the resource comes from current's own ipc namespace. setuid/setgid are to uids in own namespace, so again checks can be against current_user_ns(). Changelog: Jan 11: Use task_ns_capable() in place of sched_capable(). Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Clarify (hopefully) some logic in futex and sched.c Feb 15: use ns_capable for ipc, not nsown_capable Feb 23: let copy_ipcs handle setting ipc_ns->user_ns Feb 23: pass ns down rather than taking it from current [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25kernel-wide: replace USHORT_MAX, SHORT_MAX and SHORT_MIN with USHRT_MAX, ↵Alexey Dobriyan
SHRT_MAX and SHRT_MIN - C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not USHORT_MAX/SHORT_MAX/SHORT_MIN. - Make SHRT_MIN of type s16, not int, for consistency. [akpm@linux-foundation.org: fix drivers/dma/timb_dma.c] [akpm@linux-foundation.org: fix security/keys/keyring.c] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: mqueue ns: move mqueue_mnt into struct ipc_namespaceSerge E. Hallyn
Move mqueue vfsmount plus a few tunables into the ipc_namespace struct. The CONFIG_IPC_NS boolean and the ipc_namespace struct will serve both the posix message queue namespaces and the SYSV ipc namespaces. The sysctl code will be fixed separately in patch 3. After just this patch, making a change to posix mqueue tunables always changes the values in the initial ipc namespace. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04sanitize audit_ipc_set_perm()Al Viro
* get rid of allocations * make it return void * simplify callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_ipc_obj()Al Viro
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-11-19sysvipc: fix the ipc structures initializationNadia Derbey
A problem was found while reviewing the code after Bugzilla bug http://bugzilla.kernel.org/show_bug.cgi?id=11796. In ipc_addid(), the newly allocated ipc structure is inserted into the ipcs tree (i.e made visible to readers) without locking it. This is not correct since its initialization continues after it has been inserted in the tree. This patch moves the ipc structure lock initialization + locking before the actual insertion. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Reported-by: Clement Calmels <cboulte@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Wrap task credential accesses in the SYSV IPC subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-07-25ipc: get rid of ipc_lock_down()Nadia Derbey
Remove the ipc_lock_down() routines: they used to call idr_find() locklessly (given that the ipc ids lock was already held), so they are not needed anymore. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: call idr_find() without locking in ipc_lock()Nadia Derbey
Call idr_find() locklessly from ipc_lock(), since the idr tree is now RCU protected. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29sysvipc: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: add definitions of USHORT_MAX and othersZhang, Yanmin
Add definitions of USHORT_MAX and others into kernel. ipc uses it and slub implementation might also use it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Reviewed-by: Christoph Lameter <clameter@sgi.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: "Pierre Peiffer" <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: consolidate all xxxctl_down() functionsPierre Peiffer
semctl_down(), msgctl_down() and shmctl_down() are used to handle the same set of commands for each kind of IPC. They all start to do the same job (they retrieve the ipc and do some permission checks) before handling the commands on their own. This patch proposes to consolidate this by moving these same pieces of code into one common function called ipcctl_pre_down(). It simplifies a little these xxxctl_down() functions and increases a little the maintainability. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: introduce ipc_update_perm()Pierre Peiffer
The IPC_SET command performs the same permission setting for all IPCs. This patch introduces a common ipc_update_perm() function to update these permissions and makes use of it for all IPCs. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: invoke the ipcns notifier chain as a work itemNadia Derbey
Make the memory hotplug chain's mutex held for a shorter time: when memory is offlined or onlined a work item is added to the global workqueue. When the work item is run, it notifies the ipcns notifier chain with the IPCNS_MEMCHANGED event. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: recompute msgmni on memory add / removeNadia Derbey
Introduce the registration of a callback routine that recomputes msg_ctlmni upon memory add / remove. A single notifier block is registered in the hotplug memory chain for all the ipc namespaces. Since the ipc namespaces are not linked together, they have their own notification chain: one notifier_block is defined per ipc namespace. Each time an ipc namespace is created (removed) it registers (unregisters) its notifier block in (from) the ipcns chain. The callback routine registered in the memory chain invokes the ipcns notifier chain with the IPCNS_LOWMEM event. Each callback routine registered in the ipcns namespace, in turn, recomputes msgmni for the owning namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: scale msgmni to the number of ipc namespacesNadia Derbey
Since all the namespaces see the same amount of memory (the total one) this patch introduces a new variable that counts the ipc namespaces and divides msg_ctlmni by this counter. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: use ipc_buildid() directly from ipc_addid()Pierre Peiffer
By continuing to consolidate a little the IPC code, each id can be built directly in ipc_addid() instead of having it built from each callers of ipc_addid() And I also remove shm_addid() in order to have, as much as possible, the same code for shm/sem/msg. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08IPC: make struct ipc_ids static in ipc_namespacePierre Peiffer
Each ipc_namespace contains a table of 3 pointers to struct ipc_ids (3 for msg, sem and shm, structure used to store all ipcs) These 'struct ipc_ids' are dynamically allocated for each icp_namespace as the ipc_namespace itself (for the init namespace, they are initialized with pointers to static variables instead) It is so for historical reason: in fact, before the use of idr to store the ipcs, the ipcs were stored in tables of variable length, depending of the maximum number of ipc allowed. Now, these 'struct ipc_ids' have a fixed size. As they are allocated in any cases for each new ipc_namespace, there is no gain of memory in having them allocated separately of the struct ipc_namespace. This patch proposes to make this table static in the struct ipc_namespace. Thus, we can allocate all in once and get rid of all the code needed to allocate and free these ipc_ids separately. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08ipc: uninline some code from util.hPavel Emelyanov
ipc_lock_check_down(), ipc_lock_check() and ipcget() seem too large to be inline. Besides, they give no optimization being inline as they perform calls inside in any case. Moving them into ipc/util.c saves 500 bytes of vmlinux and shortens IPC internal API. $ ./scripts/bloat-o-meter vmlinux-orig vmlinux add/remove: 3/2 grow/shrink: 0/10 up/down: 490/-989 (-499) function old new delta ipcget - 392 +392 ipc_lock_check_down - 49 +49 ipc_lock_check - 49 +49 sys_semget 119 105 -14 sys_shmget 108 86 -22 sys_msgget 100 78 -22 do_msgsnd 665 631 -34 do_msgrcv 680 644 -36 do_shmat 771 733 -38 sys_msgctl 1302 1229 -73 ipcget_new 80 - -80 sys_semtimedop 1534 1452 -82 sys_semctl 2034 1922 -112 sys_shmctl 1919 1765 -154 ipcget_public 322 - -322 The ipcget() growth is the result of gcc inlining of currently static ipcget_new/_public. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08namespaces: move the IPC namespace under IPC_NS optionPavel Emelyanov
Currently the IPC namespace management code is spread over the ipc/*.c files. I moved this code into ipc/namespace.c file which is compiled out when needed. The linux/ipc_namespace.h file is used to store the prototypes of the functions in namespace.c and the stubs for NAMESPACES=n case. This is done so, because the stub for copy_ipc_namespace requires the knowledge of the CLONE_NEWIPC flag, which is in sched.h. But the linux/ipc.h file itself in included into many many .c files via the sys.h->sem.h sequence so adding the sched.h into it will make all these .c depend on sched.h which is not that good. On the other hand the knowledge about the namespaces stuff is required in 4 .c files only. Besides, this patch compiles out some auxiliary functions from ipc/sem.c, msg.c and shm.c files. It turned out that moving these functions into namespaces.c is not that easy because they use many other calls and macros from the original file. Moving them would make this patch complicated. On the other hand all these functions can be consolidated, so I will send a separate patch doing this a bit later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06make ipc/util.c:sysvipc_find_ipc() staticAdrian Bunk
sysvipc_find_ipc() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19IPC: fix error case when idr-cache is empty in ipcget()Pierre Peiffer
With the use of idr to store the ipc, the case where the idr cache is empty, when idr_get_new is called (this may happen even if we call idr_pre_get() before), is not well handled: it lets semget()/shmget()/msgget() return ENOSPC when this cache is empty, what 1. does not reflect the facts and 2. does not conform to the man(s). This patch fixes this by retrying the whole process of allocation in this case. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19fix idr_find() lockingNadia Derbey
This is a patch that fixes the way idr_find() used to be called in ipc_lock(): in all the paths that don't imply an update of the ipcs idr, it was called without the idr tree being locked. The changes are: . in ipc_ids, the mutex has been changed into a reader/writer semaphore. . ipc_lock() now takes the mutex as a reader during the idr_find(). . a new routine ipc_lock_down() has been defined: it doesn't take the mutex, assuming that it is being held by the caller. This is the routine that is now called in all the update paths. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: fix wrong commentsNadia Derbey
This patch fixes the wrong / obsolete comments in the ipc code. Also adds a missing lock around ipc_get_maxid() in shm_get_stat(). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: inline ipc_buildid()Nadia Derbey
This is a trivial patch that changes the ipc_buildid() routine into a static inline. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: introduce the ipcid_to_idx macroNadia Derbey
This is a trivial patch that changes all the (id % SEQ_MULTIPLIER) into a call to the ipcid_to_idx(id) macro. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: integrate ipc_checkid() into ipc_lock()Nadia Derbey
This patch introduces a new ipc_lock_check() routine interface: . each time ipc_checkid() is called, this is done after calling ipc_lock(). ipc_checkid() is now called from inside ipc_lock_check(). [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix RCU locking] Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: remove the ipc_get() routineNadia Derbey
This is a trivial patch that removes the ipc_get() routine: it is replaced by a call to idr_find(). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: unify the syscalls codeNadia Derbey
This patch introduces a change into the sys_msgget(), sys_semget() and sys_shmget() routines: they now share a common code, which is better for maintainability. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: store ipcs into IDRsNadia Derbey
This patch introduces ipcs storage into IDRs. The main changes are: . This ipc_ids structure is changed: the entries array is changed into a root idr structure. . The grow_ary() routine is removed: it is not needed anymore when adding an ipc structure, since we are now using the IDR facility. . The ipc_rmid() routine interface is changed: . there is no need for this routine to return the pointer passed in as argument: it is now declared as a void . since the id is now part of the kern_ipc_perm structure, no need to have it as an argument to the routine Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16remove CONFIG_UTS_NS and CONFIG_IPC_NSCedric Le Goater
CONFIG_UTS_NS and CONFIG_IPC_NS have very little value as they only deactivate the unshare of the uts and ipc namespaces and do not improve performance. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge sys_clone()/sys_unshare() nsproxy and namespace handlingBadari Pulavarty
sys_clone() and sys_unshare() both makes copies of nsproxy and its associated namespaces. But they have different code paths. This patch merges all the nsproxy and its associated namespace copy/clone handling (as much as possible). Posted on container list earlier for feedback. - Create a new nsproxy and its associated namespaces and pass it back to caller to attach it to right process. - Changed all copy_*_ns() routines to return a new copy of namespace instead of attaching it to task->nsproxy. - Moved the CAP_SYS_ADMIN checks out of copy_*_ns() routines. - Removed unnessary !ns checks from copy_*_ns() and added BUG_ON() just incase. - Get rid of all individual unshare_*_ns() routines and make use of copy_*_ns() instead. [akpm@osdl.org: cleanups, warning fix] [clg@fr.ibm.com: remove dup_namespaces() declaration] [serue@us.ibm.com: fix CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) retval] [akpm@linux-foundation.org: fix build with CONFIG_SYSVIPC=n] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <containers@lists.osdl.org> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27[PATCH] ipcns: fix !CONFIG_IPC_NS behaviorSerge E. Hallyn
When CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) claims success, but did not actually clone a new IPC namespace. Fix this to return -EINVAL so the caller knows his request was denied. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] ipc: save the ipc namespace while reading proc filesEric W. Biederman
The problem we were assuming that current->nsproxy->ipc_ns would never change while someone has our file in /proc/sysvipc/ file open. Given that this can change with both unshare and by passing the file descriptor to another process that assumption is occasionally wrong. Therefore this patch causes /proc/sysvipc/* to cache the namespace and increment it's count when we open the file and to decrement the count when we close the file, ensuring consistent operation with no surprises. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-03[PATCH] Fix ipc entries removalPavel Emelianov
Fix two issuses related to ipc_ids->entries freeing. 1. When freeing ipc namespace we need to free entries allocated with ipc_init_ids(). 2. When removing old entries in grow_ary() ipc_rcu_putref() may be called on entries set to &ids->nullentry earlier in ipc_init_ids(). This is almost impossible without namespaces, but with them this situation becomes possible. Found during OpenVZ testing after obvious leaks in beancounters. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace - utilsKirill Korotaev
This patch adds basic IPC namespace functionality to IPC utils: - init_ipc_ns - copy/clone/unshare/free IPC ns - /proc preparations Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] Rework of IPC auditingSteve Grubb
1) The audit_ipc_perms() function has been split into two different functions: - audit_ipc_obj() - audit_ipc_set_perm() There's a key shift here... The audit_ipc_obj() collects the uid, gid, mode, and SElinux context label of the current ipc object. This audit_ipc_obj() hook is now found in several places. Most notably, it is hooked in ipcperms(), which is called in various places around the ipc code permforming a MAC check. Additionally there are several places where *checkid() is used to validate that an operation is being performed on a valid object while not necessarily having a nearby ipcperms() call. In these locations, audit_ipc_obj() is called to ensure that the information is captured by the audit system. The audit_set_new_perm() function is called any time the permissions on the ipc object changes. In this case, the NEW permissions are recorded (and note that an audit_ipc_obj() call exists just a few lines before each instance). 2) Support for an AUDIT_IPC_SET_PERM audit message type. This allows for separate auxiliary audit records for normal operations on an IPC object and permissions changes. Note that the same struct audit_aux_data_ipcctl is used and populated, however there are separate audit_log_format statements based on the type of the message. Finally, the AUDIT_IPC block of code in audit_free_aux() was extended to handle aux messages of this new type. No more mem leaks I hope ;-) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-04-17[PATCH] IPC: access to unmapped vmalloc area in grow_ary()Alexey Kuznetsov
grow_ary() should not copy struct ipc_id_ary (it copies new->p, not new). Due to this, memcpy() src pointer could hit unmapped vmalloc page when near page boundary. Found during OpenVZ stress testing Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
