path: root/ipc/util.c
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] more kernel-doc cleanups, additionsRandy Dunlap
Various core kernel-doc cleanups: - add missing function parameters in ipc, irq/manage, kernel/sys, kernel/sysctl, and mm/slab; - move description to just above function for kernel_restart() Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] ipc: add generic struct ipc_ids seq_file iterationMike Waychison
The following two patches convert /proc/sysvipc/* to use seq_file. This gives us the following: - Self-consistent IPC records in proc. - O(n) reading of the files themselves. This patch: Add a generic method for ipc types to be displayed using seq_file. This patch abstracts out seq_file iterating over struct ipc_ids into ipc/util.c Signed-off-by: Mike Waychison <mikew@google.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
