path: root/ipc/util.h
2009-04-07namespaces: ipc namespaces: implement support for posix msqueuesSerge E. Hallyn
Implement multiple mounts of the mqueue file system, and link it to usage of CLONE_NEWIPC. Each ipc ns has a corresponding mqueuefs superblock. When a user does clone(CLONE_NEWIPC) or unshare(CLONE_NEWIPC), the unshare will cause an internal mount of a new mqueuefs sb linked to the new ipc ns. When a user does 'mount -t mqueue mqueue /dev/mqueue', he mounts the mqueuefs superblock. Posix message queues can be worked with both through the mq_* system calls (see mq_overview(7)), and through the VFS through the mqueue mount. Any usage of mq_open() and friends will work with the acting task's ipc namespace. Any actions through the VFS will work with the mqueuefs in which the file was created. So if a user doesn't remount mqueuefs after unshare(CLONE_NEWIPC), mq_open("/ab") will not be reflected in "ls /dev/mqueue". If task a mounts mqueue for ipc_ns:1, then clones task b with a new ipcns, ipcns:2, and then task a is the last task in ipc_ns:1 to exit, then (1) ipc_ns:1 will be freed, (2) it's superblock will live on until task b umounts the corresponding mqueuefs, and vfs actions will continue to succeed, but (3) sb->s_fs_info will be NULL for the sb corresponding to the deceased ipc_ns:1. To make this happen, we must protect the ipc reference count when a) a task exits and drops its ipcns->count, since it might be dropping it to 0 and freeing the ipcns b) a task accesses the ipcns through its mqueuefs interface, since it bumps the ipcns refcount and might race with the last task in the ipcns exiting. So the kref is changed to an atomic_t so we can use atomic_dec_and_lock(&ns->count,mq_lock), and every access to the ipcns through ns = mqueuefs_sb->s_fs_info is protected by the same lock. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: mqueue ns: move mqueue_mnt into struct ipc_namespaceSerge E. Hallyn
Move mqueue vfsmount plus a few tunables into the ipc_namespace struct. The CONFIG_IPC_NS boolean and the ipc_namespace struct will serve both the posix message queue namespaces and the SYSV ipc namespaces. The sysctl code will be fixed separately in patch 3. After just this patch, making a change to posix mqueue tunables always changes the values in the initial ipc namespace. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: get rid of ipc_lock_down()Nadia Derbey
Remove the ipc_lock_down() routines: they used to call idr_find() locklessly (given that the ipc ids lock was already held), so they are not needed anymore. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: add definitions of USHORT_MAX and othersZhang, Yanmin
Add definitions of USHORT_MAX and others into kernel. ipc uses it and slub implementation might also use it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Reviewed-by: Christoph Lameter <clameter@sgi.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: "Pierre Peiffer" <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: consolidate all xxxctl_down() functionsPierre Peiffer
semctl_down(), msgctl_down() and shmctl_down() are used to handle the same set of commands for each kind of IPC. They all start to do the same job (they retrieve the ipc and do some permission checks) before handling the commands on their own. This patch proposes to consolidate this by moving these same pieces of code into one common function called ipcctl_pre_down(). It simplifies a little these xxxctl_down() functions and increases a little the maintainability. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29IPC: introduce ipc_update_perm()Pierre Peiffer
The IPC_SET command performs the same permission setting for all IPCs. This patch introduces a common ipc_update_perm() function to update these permissions and makes use of it for all IPCs. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: recompute msgmni on memory add / removeNadia Derbey
Introduce the registration of a callback routine that recomputes msg_ctlmni upon memory add / remove. A single notifier block is registered in the hotplug memory chain for all the ipc namespaces. Since the ipc namespaces are not linked together, they have their own notification chain: one notifier_block is defined per ipc namespace. Each time an ipc namespace is created (removed) it registers (unregisters) its notifier block in (from) the ipcns chain. The callback routine registered in the memory chain invokes the ipcns notifier chain with the IPCNS_LOWMEM event. Each callback routine registered in the ipcns namespace, in turn, recomputes msgmni for the owning namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08IPC: make struct ipc_ids static in ipc_namespacePierre Peiffer
Each ipc_namespace contains a table of 3 pointers to struct ipc_ids (3 for msg, sem and shm, structure used to store all ipcs) These 'struct ipc_ids' are dynamically allocated for each icp_namespace as the ipc_namespace itself (for the init namespace, they are initialized with pointers to static variables instead) It is so for historical reason: in fact, before the use of idr to store the ipcs, the ipcs were stored in tables of variable length, depending of the maximum number of ipc allowed. Now, these 'struct ipc_ids' have a fixed size. As they are allocated in any cases for each new ipc_namespace, there is no gain of memory in having them allocated separately of the struct ipc_namespace. This patch proposes to make this table static in the struct ipc_namespace. Thus, we can allocate all in once and get rid of all the code needed to allocate and free these ipc_ids separately. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08ipc: uninline some code from util.hPavel Emelyanov
ipc_lock_check_down(), ipc_lock_check() and ipcget() seem too large to be inline. Besides, they give no optimization being inline as they perform calls inside in any case. Moving them into ipc/util.c saves 500 bytes of vmlinux and shortens IPC internal API. $ ./scripts/bloat-o-meter vmlinux-orig vmlinux add/remove: 3/2 grow/shrink: 0/10 up/down: 490/-989 (-499) function old new delta ipcget - 392 +392 ipc_lock_check_down - 49 +49 ipc_lock_check - 49 +49 sys_semget 119 105 -14 sys_shmget 108 86 -22 sys_msgget 100 78 -22 do_msgsnd 665 631 -34 do_msgrcv 680 644 -36 do_shmat 771 733 -38 sys_msgctl 1302 1229 -73 ipcget_new 80 - -80 sys_semtimedop 1534 1452 -82 sys_semctl 2034 1922 -112 sys_shmctl 1919 1765 -154 ipcget_public 322 - -322 The ipcget() growth is the result of gcc inlining of currently static ipcget_new/_public. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08namespaces: move the IPC namespace under IPC_NS optionPavel Emelyanov
Currently the IPC namespace management code is spread over the ipc/*.c files. I moved this code into ipc/namespace.c file which is compiled out when needed. The linux/ipc_namespace.h file is used to store the prototypes of the functions in namespace.c and the stubs for NAMESPACES=n case. This is done so, because the stub for copy_ipc_namespace requires the knowledge of the CLONE_NEWIPC flag, which is in sched.h. But the linux/ipc.h file itself in included into many many .c files via the sys.h->sem.h sequence so adding the sched.h into it will make all these .c depend on sched.h which is not that good. On the other hand the knowledge about the namespaces stuff is required in 4 .c files only. Besides, this patch compiles out some auxiliary functions from ipc/sem.c, msg.c and shm.c files. It turned out that moving these functions into namespaces.c is not that easy because they use many other calls and macros from the original file. Moving them would make this patch complicated. On the other hand all these functions can be consolidated, so I will send a separate patch doing this a bit later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: remove unneeded parametersNadia Derbey
Remvoe the unneeded parameters from ipc_checkid() and ipc_buildid() interfaces. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19fix idr_find() lockingNadia Derbey
This is a patch that fixes the way idr_find() used to be called in ipc_lock(): in all the paths that don't imply an update of the ipcs idr, it was called without the idr tree being locked. The changes are: . in ipc_ids, the mutex has been changed into a reader/writer semaphore. . ipc_lock() now takes the mutex as a reader during the idr_find(). . a new routine ipc_lock_down() has been defined: it doesn't take the mutex, assuming that it is being held by the caller. This is the routine that is now called in all the update paths. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: fix wrong commentsNadia Derbey
This patch fixes the wrong / obsolete comments in the ipc code. Also adds a missing lock around ipc_get_maxid() in shm_get_stat(). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: inline ipc_buildid()Nadia Derbey
This is a trivial patch that changes the ipc_buildid() routine into a static inline. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: introduce the ipcid_to_idx macroNadia Derbey
This is a trivial patch that changes all the (id % SEQ_MULTIPLIER) into a call to the ipcid_to_idx(id) macro. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Storing ipcs into IDRsNadia Derbey
This patch converts casts of struct kern_ipc_perm to . struct msg_queue . struct sem_array . struct shmid_kernel into the equivalent container_of() macro. It improves code maintenance because the code need not change if kern_ipc_perm is no longer at the beginning of the containing struct. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: integrate ipc_checkid() into ipc_lock()Nadia Derbey
This patch introduces a new ipc_lock_check() routine interface: . each time ipc_checkid() is called, this is done after calling ipc_lock(). ipc_checkid() is now called from inside ipc_lock_check(). [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix RCU locking] Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: remove the ipc_get() routineNadia Derbey
This is a trivial patch that removes the ipc_get() routine: it is replaced by a call to idr_find(). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: unify the syscalls codeNadia Derbey
This patch introduces a change into the sys_msgget(), sys_semget() and sys_shmget() routines: they now share a common code, which is better for maintainability. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ipc: store ipcs into IDRsNadia Derbey
This patch introduces ipcs storage into IDRs. The main changes are: . This ipc_ids structure is changed: the entries array is changed into a root idr structure. . The grow_ary() routine is removed: it is not needed anymore when adding an ipc structure, since we are now using the IDR facility. . The ipc_rmid() routine interface is changed: . there is no need for this routine to return the pointer passed in as argument: it is now declared as a void . since the id is now part of the kern_ipc_perm structure, no need to have it as an argument to the routine Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16remove CONFIG_UTS_NS and CONFIG_IPC_NSCedric Le Goater
CONFIG_UTS_NS and CONFIG_IPC_NS have very little value as they only deactivate the unshare of the uts and ipc namespaces and do not improve performance. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-03[PATCH] Fix ipc entries removalPavel Emelianov
Fix two issuses related to ipc_ids->entries freeing. 1. When freeing ipc namespace we need to free entries allocated with ipc_init_ids(). 2. When removing old entries in grow_ary() ipc_rcu_putref() may be called on entries set to &ids->nullentry earlier in ipc_init_ids(). This is almost impossible without namespaces, but with them this situation becomes possible. Found during OpenVZ testing after obvious leaks in beancounters. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace - utilsKirill Korotaev
This patch adds basic IPC namespace functionality to IPC utils: - init_ipc_ns - copy/clone/unshare/free IPC ns - /proc preparations Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: ipc, id.semIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-15correct email address of Manfred SpraulChristian Kujau
I tried to send the forcedeth maintainer an email, but it came back with: "The mail address manfreds@colorfullife.com is not read anymore. Please resent your mail to manfred@ instead of manfreds@." This patch fixes this. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-09-07[PATCH] ipc: add generic struct ipc_ids seq_file iterationMike Waychison
The following two patches convert /proc/sysvipc/* to use seq_file. This gives us the following: - Self-consistent IPC records in proc. - O(n) reading of the files themselves. This patch: Add a generic method for ipc types to be displayed using seq_file. This patch abstracts out seq_file iterating over struct ipc_ids into ipc/util.c Signed-off-by: Mike Waychison <mikew@google.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] xtensa: remove old syscallsChris Zankel
This patch fixes some minor bugs introduced by the previous patch (remove old syscalls). Both patches remove the obsolete syscalls. The changes in this patch were suggested by Arnd Bergmann. The vmlinux.lds.S changes are required for the latest gcc/binutils. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
