[ Upstream commit f991af3daabaecff34684fd51fac80319d1baad1 ]
The retry logic for netlink_attachskb() inside sys_mq_notify()
is nasty and vulnerable:
1) The sock refcnt is already released when retry is needed
2) The fd is controllable by user-space because we already
release the file refcnt
so we when retry but the fd has been just closed by user-space
during this small window, we end up calling netlink_detachskb()
on the error path which releases the sock again, later when
the user-space closes this socket a use-after-free could be
triggered.
Setting 'sock' to NULL here should be sufficient to fix it.
Reported-by: GeneBlue <geneblue.mail@gmail.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: stable@kernel.org
[ Upstream commit 95e91b831f87ac8e1f8ed50c14d709089b4e01b8 ]
The issue is described here, with a nice testcase:
https://bugzilla.kernel.org/show_bug.cgi?id=192931
The problem is that shmat() calls do_mmap_pgoff() with MAP_FIXED, and
the address rounded down to 0. For the regular mmap case, the
protection mentioned above is that the kernel gets to generate the
address -- arch_get_unmapped_area() will always check for MAP_FIXED and
return that address. So by the time we do security_mmap_addr(0) things
get funky for shmat().
The testcase itself shows that while a regular user crashes, root will
not have a problem attaching a nil-page. There are two possible fixes
to this. The first, and which this patch does, is to simply allow root
to crash as well -- this is also regular mmap behavior, ie when hacking
up the testcase and adding mmap(... |MAP_FIXED). While this approach
is the safer option, the second alternative is to ignore SHM_RND if the
rounded address is 0, thus only having MAP_SHARED flags. This makes the
behavior of shmat() identical to the mmap() case. The downside of this
is obviously user visible, but does make sense in that it maintains
semantics after the round-down wrt 0 address and mmap.
Passes shm related ltp tests.
Link: http://lkml.kernel.org/r/1486050195-18629-1-git-send-email-dave@stgolabs.net
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reported-by: Gareth Evans <gareth.evans@contextis.co.uk>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: <stable@vger.kernel.org>
[ Upstream commit 9b24fef9f0410fb5364245d6cc2bd044cc064007 ]
Commit 53dad6d3a8e5 ("ipc: fix race with LSMs") updated ipc_rcu_putref()
to receive rcu freeing function but used generic ipc_rcu_free() instead
of msg_rcu_free() which does security cleaning.
Running LTP msgsnd06 with kmemleak gives the following:
cat /sys/kernel/debug/kmemleak
unreferenced object 0xffff88003c0a11f8 (size 8):
comm "msgsnd06", pid 1645, jiffies 4294672526 (age 6.549s)
hex dump (first 8 bytes):
1b 00 00 00 01 00 00 00 ........
backtrace:
kmemleak_alloc+0x23/0x40
kmem_cache_alloc_trace+0xe1/0x180
selinux_msg_queue_alloc_security+0x3f/0xd0
security_msg_queue_alloc+0x2e/0x40
newque+0x4e/0x150
ipcget+0x159/0x1b0
SyS_msgget+0x39/0x40
entry_SYSCALL_64_fastpath+0x13/0x8f
Manfred Spraul suggested to fix sem.c as well and Davidlohr Bueso to
only use ipc_rcu_free in case of security allocation failure in newary()
Fixes: 53dad6d3a8e ("ipc: fix race with LSMs")
Link: http://lkml.kernel.org/r/1470083552-22966-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: <stable@vger.kernel.org> [3.12+]
[ Upstream commit 15db15e2f10ae12d021c9a2e9edd8a03b9238551 ]
commit 1ac0b6dec656f3f78d1c3dd216fad84cb4d0a01e upstream.
remap_file_pages(2) emulation can reach file which represents removed
IPC ID as long as a memory segment is mapped. It breaks expectations of
IPC subsystem.
Test case (rewritten to be more human readable, originally autogenerated
by syzkaller[1]):
#define _GNU_SOURCE
#include <stdlib.h>
#include <sys/ipc.h>
#include <sys/mman.h>
#include <sys/shm.h>
#define PAGE_SIZE 4096
int main()
int id;
void *p;
id = shmget(IPC_PRIVATE, 3 * PAGE_SIZE, 0);
p = shmat(id, NULL, 0);
shmctl(id, IPC_RMID, NULL);
remap_file_pages(p, 3 * PAGE_SIZE, 0, 7, 0);
return 0;
The patch changes shm_mmap() and code around shm_lock() to propagate
locking error back to caller of shm_mmap().
[1] http://github.com/google/syzkaller
Cc: Davidlohr Bueso <dave@stgolabs.net>
[ Upstream commit d0edd8528362c07216498340e928159510595e7b ]
Considering Linus' past rants about the (ab)use of BUG in the kernel, I
took a look at how we deal with such calls in ipc. Given that any errors
or corruption in ipc code are most likely contained within the set of
processes participating in the broken mechanisms, there aren't really many
strong fatal system failure scenarios that would require a BUG call.
Also, if something is seriously wrong, ipc might not be the place for such
a BUG either.
1. For example, recently, a customer hit one of these BUG_ONs in shm
after failing shm_lock(). A busted ID imho does not merit a BUG_ON,
and WARN would have been better.
2. MSG_COPY functionality of posix msgrcv(2) for checkpoint/restore.
I don't see how we can hit this anyway -- at least it should be IS_ERR.
The 'copy' arg from do_msgrcv is always set by calling prepare_copy()
first and foremost. We could also probably drop this check altogether.
Either way, it does not merit a BUG_ON.
3. No ->fault() callback for the fs getting the corresponding page --
seems selfish to make the system unusable.
[ Upstream commit c5c8975b2eb4eb7604e8ce4f762987f56d2a96a2 ]
Upon every shm_lock call, we BUG_ON if an error was returned, indicating
racing either in idr or in shm_destroy. Move this logic into the locking.
[akpm@linux-foundation.org: simplify code]
commit b9a532277938798b53178d5a66af6e2915cb27cf upstream.
As reported by Dmitry Vyukov, we really shouldn't do ipc_addid() before
having initialized the IPC object state. Yes, we initialize the IPC
object in a locked state, but with all the lockless RCU lookup work,
that IPC object lock no longer means that the state cannot be seen.
We already did this for the IPC semaphore code (see commit e8577d1f0329:
"ipc/sem.c: fully initialize sem_array before making it visible") but we
clearly forgot about msg and shm.
commit 3ed1f8a99d70ea1cd1508910eb107d0edcae5009 upstream.
sem_lock() did not properly pair memory barriers:
!spin_is_locked() and spin_unlock_wait() are both only control barriers.
The code needs an acquire barrier, otherwise the cpu might perform read
operations before the lock test.
As no primitive exists inside <include/spinlock.h> and since it seems
noone wants another primitive, the code creates a local primitive within
ipc/sem.c.
With regards to -stable:
The change of sem_wait_array() is a bugfix, the change to sem_lock() is a
nop (just a preprocessor redefinition to improve the readability). The
bugfix is necessary for all kernels that use sem_wait_array() (i.e.:
starting from 3.10).
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Kirill Tkhai <ktkhai@parallels.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
set exits
commit 602b8593d2b4138c10e922eeaafe306f6b51817b upstream.
The current semaphore code allows a potential use after free: in
exit_sem we may free the task's sem_undo_list while there is still
another task looping through the same semaphore set and cleaning the
sem_undo list at freeary function (the task called IPC_RMID for the same
semaphore set).
For example, with a test program [1] running which keeps forking a lot
of processes (which then do a semop call with SEM_UNDO flag), and with
the parent right after removing the semaphore set with IPC_RMID, and a
kernel built with CONFIG_SLAB, CONFIG_SLAB_DEBUG and
CONFIG_DEBUG_SPINLOCK, you can easily see something like the following
in the kernel log:
Slab corruption (Not tainted): kmalloc-64 start=ffff88003b45c1c0, len=64
000: 6b 6b 6b 6b 6b 6b 6b 6b 00 6b 6b 6b 6b 6b 6b 6b kkkkkkkk.kkkkkkk
010: ff ff ff ff 6b 6b 6b 6b ff ff ff ff ff ff ff ff ....kkkk........
Prev obj: start=ffff88003b45c180, len=64
000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ
010: ff ff ff ff ff ff ff ff c0 fb 01 37 00 88 ff ff ...........7....
Next obj: start=ffff88003b45c200, len=64
010: ff ff ff ff ff ff ff ff 68 29 a7 3c 00 88 ff ff ........h).<....
BUG: spinlock wrong CPU on CPU#2, test/18028
general protection fault: 0000 [#1] SMP
Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib]
CPU: 2 PID: 18028 Comm: test Not tainted 4.2.0-rc5+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014
RIP: spin_dump+0x53/0xc0
Call Trace:
spin_bug+0x30/0x40
do_raw_spin_unlock+0x71/0xa0
_raw_spin_unlock+0xe/0x10
freeary+0x82/0x2a0
? _raw_spin_lock+0xe/0x10
semctl_down.clone.0+0xce/0x160
? __do_page_fault+0x19a/0x430
? __audit_syscall_entry+0xa8/0x100
SyS_semctl+0x236/0x2c0
? syscall_trace_leave+0xde/0x130
entry_SYSCALL_64_fastpath+0x12/0x71
Code: 8b 80 88 03 00 00 48 8d 88 60 05 00 00 48 c7 c7 a0 2c a4 81 31 c0 65 8b 15 eb 40 f3 7e e8 08 31 68 00 4d 85 e4 44 8b 4b 08 74 5e <45> 8b 84 24 88 03 00 00 49 8d 8c 24 60 05 00 00 8b 53 04 48 89
RIP [<ffffffff810d6053>] spin_dump+0x53/0xc0
RSP <ffff88003750fd68>
---[ end trace 783ebb76612867a0 ]---
NMI watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [test:18053]
CPU: 3 PID: 18053 Comm: test Tainted: G D 4.2.0-rc5+ #1
RIP: native_read_tsc+0x0/0x20
Call Trace:
? delay_tsc+0x40/0x70
__delay+0xf/0x20
do_raw_spin_lock+0x96/0x140
sem_lock_and_putref+0x11/0x70
SYSC_semtimedop+0x7bf/0x960
? handle_mm_fault+0xbf6/0x1880
? dequeue_task_fair+0x79/0x4a0
? kfree_debugcheck+0x16/0x40
? do_audit_syscall_entry+0x66/0x70
? syscall_trace_enter_phase1+0x139/0x160
SyS_semtimedop+0xe/0x10
SyS_semop+0x10/0x20
Code: 47 10 83 e8 01 85 c0 89 47 10 75 08 65 48 89 3d 1f 74 ff 7e c9 c3 0f 1f 44 00 00 55 48 89 e5 e8 87 17 04 00 66 90 c9 c3 0f 1f 00 <55> 48 89 e5 0f 31 89 c1 48 89 d0 48 c1 e0 20 89 c9 48 09 c8 c9
Kernel panic - not syncing: softlockup: hung tasks
I wasn't able to trigger any badness on a recent kernel without the
proper config debugs enabled, however I have softlockup reports on some
kernel versions, in the semaphore code, which are similar as above (the
scenario is seen on some servers running IBM DB2 which uses semaphore
syscalls).
The patch here fixes the race against freeary, by acquiring or waiting
on the sem_undo_list lock as necessary (exit_sem can race with freeary,
while freeary sets un->semid to -1 and removes the same sem_undo from
list_proc or when it removes the last sem_undo).
After the patch I'm unable to reproduce the problem using the test case
[1].
[1] Test case used below:
#include <stdio.h>
#include <sys/types.h>
#include <sys/sem.h>
#include <sys/wait.h>
#include <stdlib.h>
#include <time.h>
#include <unistd.h>
#include <errno.h>
#define NSEM 1
#define NSET 5
int sid[NSET];
void thread()
struct sembuf op;
int s;
uid_t pid = getuid();
s = rand() % NSET;
op.sem_num = pid % NSEM;
op.sem_op = 1;
op.sem_flg = SEM_UNDO;
semop(sid[s], &op, 1);
exit(EXIT_SUCCESS);
void create_set()
int i, j;
pid_t p;
union {
int val;
struct semid_ds *buf;
unsigned short int *array;
struct seminfo *__buf;
} un;
/* Create and initialize semaphore set */
for (i = 0; i < NSET; i++) {
sid[i] = semget(IPC_PRIVATE , NSEM, 0644 | IPC_CREAT);
if (sid[i] < 0) {
perror("semget");
exit(EXIT_FAILURE);
un.val = 0;
for (j = 0; j < NSEM; j++) {
if (semctl(sid[i], j, SETVAL, un) < 0)
perror("semctl");
/* Launch threads that operate on semaphore set */
for (i = 0; i < NSEM * NSET * NSET; i++) {
p = fork();
if (p < 0)
perror("fork");
if (p == 0)
thread();
/* Free semaphore set */
if (semctl(sid[i], NSEM, IPC_RMID))
perror("IPC_RMID");
/* Wait for forked processes to exit */
while (wait(NULL)) {
if (errno == ECHILD)
break;
int main(int argc, char **argv)
pid_t p;
srand(time(NULL));
while (1) {
p = fork();
if (p < 0) {
perror("fork");
exit(EXIT_FAILURE);
if (p == 0) {
create_set();
goto end;
break;
end:
return 0;
[akpm@linux-foundation.org: use normal comment layout]
Signed-off-by: Herton R. Krzesinski <herton@redhat.com>
Acked-by: Manfred Spraul <manfred@colorfullife.com>
Cc: Rafael Aquini <aquini@redhat.com>
CC: Aristeu Rozanski <aris@redhat.com>
Cc: David Jeffery <djeffery@redhat.com>
account
commit de54b9ac253787c366bbfb28d901a31954eb3511 upstream.
A while back, the message queue implementation in the kernel was
improved to use btrees to speed up retrieval of messages, in commit
d6629859b36d ("ipc/mqueue: improve performance of send/recv").
That patch introducing the improved kernel handling of message queues
(using btrees) has, as a by-product, changed the meaning of the QSIZE
field in the pseudo-file created for the queue. Before, this field
reflected the size of the user-data in the queue. Since, it also takes
kernel data structures into account. For example, if 13 bytes of user
data are in the queue, on my machine the file reports a size of 61
bytes.
There was some discussion on this topic before (for example
https://lkml.org/lkml/2014/10/1/115). Commenting on a th lkml, Michael
Kerrisk gave the following background
(https://lkml.org/lkml/2015/6/16/74):
The pseudofiles in the mqueue filesystem (usually mounted at
/dev/mqueue) expose fields with metadata describing a message
queue. One of these fields, QSIZE, as originally implemented,
showed the total number of bytes of user data in all messages in
the message queue, and this feature was documented from the
beginning in the mq_overview(7) page. In 3.5, some other (useful)
work happened to break the user-space API in a couple of places,
including the value exposed via QSIZE, which now includes a measure
of kernel overhead bytes for the queue, a figure that renders QSIZE
useless for its original purpose, since there's no way to deduce
the number of overhead bytes consumed by the implementation.
(The other user-space breakage was subsequently fixed.)
This patch removes the accounting of kernel data structures in the
queue. Reporting the size of these data-structures in the QSIZE field
was a breaking change (see Michael's comment above). Without the QSIZE
field reporting the total size of user-data in the queue, there is no
way to deduce this number.
It should be noted that the resource limit RLIMIT_MSGQUEUE is counted
against the worst-case size of the queue (in both the old and the new
implementation). Therefore, the kernel overhead accounting in QSIZE is
not necessary to help the user understand the limitations RLIMIT imposes
on the processes.
Signed-off-by: Marcus Gelderie <redmnic@gmail.com>
Acked-by: Doug Ledford <dledford@redhat.com>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Davidlohr Bueso <dbueso@suse.de>
Cc: John Duffy <jb_duffy@btinternet.com>
Cc: Arto Bendiken <arto@bendiken.net>
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
The seq_printf return value, because it's frequently misused,
will eventually be converted to void.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
Call __set_current_state() instead of assigning the new state directly.
These interfaces also aid CONFIG_DEBUG_ATOMIC_SLEEP environments, keeping
track of who changed the state.
Pull vfs pile #2 from Al Viro:
"Next pile (and there'll be one or two more).
The large piece in this one is getting rid of /proc/*/ns/* weirdness;
among other things, it allows to (finally) make nameidata completely
opaque outside of fs/namei.c, making for easier further cleanups in
there"
coda_venus_readdir(): use file_inode()
fs/namei.c: fold link_path_walk() call into path_init()
path_init(): don't bother with LOOKUP_PARENT in argument
fs/namei.c: new helper (path_cleanup())
path_init(): store the "base" pointer to file in nameidata itself
make default ->i_fop have ->open() fail with ENXIO
make nameidata completely opaque outside of fs/namei.c
kill proc_ns completely
take the targets of /proc/*/ns/* symlinks to separate fs
bury struct proc_ns in fs/proc
copy address of proc_ns_ops into ns_common
new helpers: ns_alloc_inum/ns_free_inum
make proc_ns_operations work with struct ns_common * instead of void *
switch the rest of proc_ns_operations to working with &...->ns
netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns
make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns
common object embedded into various struct ....ns
Andrew Morton noted
http://lkml.kernel.org/r/20141104142027.a7a0d010772d84560b445f59@linux-foundation.org
that the shmdt uses inode->i_size outside of i_mutex being held.
There is one more case in shm.c in shm_destroy(). This converts
both users over to use i_size_read().
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
This is a highly-contrived scenario. But, a single shmdt() call can be
induced in to unmapping memory from mulitple shm segments. Example code
is here:
http://www.sr71.net/~dave/intel/shmfun.c
The fix is pretty simple: Record the 'struct file' for the first VMA we
encounter and then stick to it. Decline to unmap anything not from the
same file and thus the same segment.
I found this by inspection and the odds of anyone hitting this in practice
are pretty darn small.
Lightly tested, but it's a pretty small patch.
Reviewed-by: Davidlohr Bueso <dave@stgolabs.net>
SysV can be abused to allocate locked kernel memory. For most systems, a
small limit doesn't make sense, see the discussion with regards to SHMMAX.
Therefore: increase MSGMNI to the maximum supported.
And: If we ignore the risk of locking too much memory, then an automatic
scaling of MSGMNI doesn't make sense. Therefore the logic can be removed.
The code preserves auto_msgmni to avoid breaking any user space applications
that expect that the value exists.
Notes:
1) If an administrator must limit the memory allocations, then he can set
MSGMNI as necessary.
Or he can disable sysv entirely (as e.g. done by Android).
2) MSGMAX and MSGMNB are intentionally not increased, as these values are used
to control latency vs. throughput:
If MSGMNB is large, then msgsnd() just returns and more messages can be queued
before a task switch to a task that calls msgrcv() is forced.
When I fixed bugs in the sem_lock() logic, I was more conservative than
necessary. Therefore it is safe to replace the smp_mb() with smp_rmb().
And: With smp_rmb(), semop() syscalls are up to 10% faster.
The race we must protect against is:
sem->lock is free
sma->complex_count = 0
sma->sem_perm.lock held by thread B
thread A:
A: spin_lock(&sem->lock)
B: sma->complex_count++; (now 1)
B: spin_unlock(&sma->sem_perm.lock);
A: spin_is_locked(&sma->sem_perm.lock);
A: XXXXX memory barrier
A: if (sma->complex_count == 0)
Thread A must read the increased complex_count value, i.e. the read must
not be reordered with the read of sem_perm.lock done by spin_is_locked().
Since it's about ordering of reads, smp_rmb() is sufficient.
[akpm@linux-foundation.org: update sem_lock() comment, from Davidlohr]
Acked-by: Rafael Aquini <aquini@redhat.com>
Pull VFS changes from Al Viro:
"First pile out of several (there _definitely_ will be more). Stuff in
this one:
- unification of d_splice_alias()/d_materialize_unique()
- iov_iter rewrite
- killing a bunch of ->f_path.dentry users (and f_dentry macro).
Getting that completed will make life much simpler for
unionmount/overlayfs, since then we'll be able to limit the places
sensitive to file _dentry_ to reasonably few. Which allows to have
file_inode(file) pointing to inode in a covered layer, with dentry
pointing to (negative) dentry in union one.
Still not complete, but much closer now.
- crapectomy in lustre (dead code removal, mostly)
- "let's make seq_printf return nothing" preparations
- assorted cleanups and fixes
There _definitely_ will be more piles"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
copy_from_iter_nocache()
new helper: iov_iter_kvec()
csum_and_copy_..._iter()
iov_iter.c: handle ITER_KVEC directly
iov_iter.c: convert copy_to_iter() to iterate_and_advance
iov_iter.c: convert copy_from_iter() to iterate_and_advance
iov_iter.c: get rid of bvec_copy_page_{to,from}_iter()
iov_iter.c: convert iov_iter_zero() to iterate_and_advance
iov_iter.c: convert iov_iter_get_pages_alloc() to iterate_all_kinds
iov_iter.c: convert iov_iter_get_pages() to iterate_all_kinds
iov_iter.c: convert iov_iter_npages() to iterate_all_kinds
iov_iter.c: iterate_and_advance
iov_iter.c: macros for iterating over iov_iter
kill f_dentry macro
dcache: fix kmemcheck warning in switch_names
new helper: audit_file()
nfsd_vfs_write(): use file_inode()
ncpfs: use file_inode()
kill f_dentry uses
lockd: get rid of ->f_path.dentry->d_sb
take struct ns_common *, for now simply wrappers around proc_{alloc,free}_inum()
We can do that now. And kill ->inum(), while we are at it - all instances
are identical.
for now - just move corresponding ->proc_inum instances over there
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
ipc_addid() makes a new ipc identifier visible to everyone. New objects
start as locked, so that the caller can complete the initialization
after the call. Within struct sem_array, at least sma->sem_base and
sma->sem_nsems are accessed without any locks, therefore this approach
doesn't work.
Thus: Move the ipc_addid() to the end of the initialization.
Reported-by: Rik van Riel <riel@redhat.com>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
... for situations when we don't have any candidate in pathnames - basically,
in descriptor-based syscalls.
[Folded the build fix for !CONFIG_AUDITSYSCALL configs from Chen Gang]
Resolve some shadow warnings produced in W=2 builds by changing the name
of some parameters and local variables. Change instances of "s64"
because that clashes with the well-known typedef. Also change a local
variable with the name "up" because that clashes with the name of of the
"up" function for semaphores. These are hazards so eliminate the
hazards by renaming them.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
Using __seq_open_private() removes boilerplate code from
sysvipc_proc_open().
The resultant code is shorter and easier to follow.
However, please note that __seq_open_private() call kzalloc() rather than
kmalloc() which may affect timing due to the memory initialisation
overhead.
Signed-off-by: Rob Jones <rob.jones@codethink.co.uk>
do_shmat() is the only user of ->start_stack (proc just reports its
value), and this check looks ugly and wrong.
The reason for this check is not clear at all, and it wrongly assumes that
the stack can only grow down.
But the main problem is that in general mm->start_stack has nothing to do
with stack_vma->vm_start. Not only the application can switch to another
stack and even unmap this area, setup_arg_pages() expands the stack
without updating mm->start_stack during exec(). This means that in the
likely case "addr > start_stack - size - PAGE_SIZE * 5" is simply
impossible after find_vma_intersection() == F, or the stack can't grow
anyway because of RLIMIT_STACK.
Many thanks to Hugh for his explanations.
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
proc_dointvec_minmax() returns zero if a new value has been set. So we
don't need to check all charecters have been handled.
Below you can find two examples. In the new value has not been handled
properly.
$ strace ./a.out
open("/proc/sys/kernel/auto_msgmni", O_WRONLY) = 3
write(3, "0\n\0", 3) = 2
close(3) = 0
exit_group(0)
$ cat /sys/kernel/debug/tracing/trace
$strace ./a.out
write(3, "0\n", 2) = 2
close(3) = 0
a.out-697 [000] .... 3280.998235: unregister_ipcns_notifier <-proc_ipcauto_dointvec_minmax
Fixes: 9eefe520c814 ("ipc: do not use a negative value to re-enable msgmni automatic recomputin")
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Cc: Mathias Krause <minipli@googlemail.com>
Cc: Joe Perches <joe@perches.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
This patch fix spelling typo found in DocBook/kernel-api.xml.
It is because the file is generated from the source comments,
I have to fix the comments in source codes.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"This is a bunch of small changes built against 3.16-rc6. The most
significant change for users is the first patch which makes setns
drmatically faster by removing unneded rcu handling.
The next chunk of changes are so that "mount -o remount,.." will not
allow the user namespace root to drop flags on a mount set by the
system wide root. Aks this forces read-only mounts to stay read-only,
no-dev mounts to stay no-dev, no-suid mounts to stay no-suid, no-exec
mounts to stay no exec and it prevents unprivileged users from messing
with a mounts atime settings. I have included my test case as the
last patch in this series so people performing backports can verify
this change works correctly.
The next change fixes a bug in NFS that was discovered while auditing
nsproxy users for the first optimization. Today you can oops the
kernel by reading /proc/fs/nfsfs/{servers,volumes} if you are clever
with pid namespaces. I rebased and fixed the build of the
!CONFIG_NFS_FS case yesterday when a build bot caught my typo. Given
that no one to my knowledge bases anything on my tree fixing the typo
in place seems more responsible that requiring a typo-fix to be
backported as well.
The last change is a small semantic cleanup introducing
/proc/thread-self and pointing /proc/mounts and /proc/net at it. This
prevents several kinds of problemantic corner cases. It is a
user-visible change so it has a minute chance of causing regressions
so the change to /proc/mounts and /proc/net are individual one line
commits that can be trivially reverted. Unfortunately I lost and
could not find the email of the original reporter so he is not
credited. From at least one perspective this change to /proc/net is a
refgression fix to allow pthread /proc/net uses that were broken by
the introduction of the network namespace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
proc: Point /proc/mounts at /proc/thread-self/mounts instead of /proc/self/mounts
proc: Point /proc/net at /proc/thread-self/net instead of /proc/self/net
proc: Implement /proc/thread-self to point at the directory of the current thread
proc: Have net show up under /proc/<tgid>/task/<tid>
NFS: Fix /proc/fs/nfsfs/servers and /proc/fs/nfsfs/volumes
mnt: Add tests for unprivileged remount cases that have found to be faulty
mnt: Change the default remount atime from relatime to the existing value
mnt: Correct permission checks in do_remount
mnt: Move the test for MNT_LOCK_READONLY from change_mount_flags into do_remount
mnt: Only change user settable mount flags in remount
namespaces: Use task_lock and not rcu to protect nsproxy
If shm_rmid_force (the default state) is not set then the shmids are only
marked as orphaned and does not require any add, delete, or locking of the
tree structure.
Seperate the sysctl on and off case, and only obtain the read lock. The
newly added list head can be deleted under the read lock because we are
only called with current and will only change the semids allocated by this
task and not manipulate the list.
This commit assumes that up_read includes a sufficient memory barrier for
the writes to be seen my others that later obtain a write lock.
Signed-off-by: Milton Miller <miltonm@bga.com>
Signed-off-by: Jack Miller <millerjo@us.ibm.com>
This is small set of patches our team has had kicking around for a few
versions internally that fixes tasks getting hung on shm_exit when there
are many threads hammering it at once.
Anton wrote a simple test to cause the issue:
http://ozlabs.org/~anton/junkcode/bust_shm_exit.c
Before applying this patchset, this test code will cause either hanging
tracebacks or pthread out of memory errors.
After this patchset, it will still produce output like:
root@somehost:~# ./bust_shm_exit 1024 160
INFO: rcu_sched detected stalls on CPUs/tasks: {} (detected by 116, t=2111 jiffies, g=241, c=240, q=7113)
INFO: Stall ended before state dump start
But the task will continue to run along happily, so we consider this an
improvement over hanging, even if it's a bit noisy.
This patch (of 3):
exit_shm obtains the ipc_ns shm rwsem for write and holds it while it
walks every shared memory segment in the namespace. Thus the amount of
work is related to the number of shm segments in the namespace not the
number of segments that might need to be cleaned.
In addition, this occurs after the task has been notified the thread has
exited, so the number of tasks waiting for the ns shm rwsem can grow
without bound until memory is exausted.
Add a list to the task struct of all shmids allocated by this task. Init
the list head in copy_process. Use the ns->rwsem for locking. Add
segments after id is added, remove before removing from id.
On unshare of NEW_IPCNS orphan any ids as if the task had exited, similar
to handling of semaphore undo.
I chose a define for the init sequence since its a simple list init,
otherwise it would require a function call to avoid include loops between
the semaphore code and the task struct. Converting the list_del to
list_del_init for the unshare cases would remove the exit followed by
init, but I left it blow up if not inited.
The synchronous syncrhonize_rcu in switch_task_namespaces makes setns
a sufficiently expensive system call that people have complained.
Upon inspect nsproxy no longer needs rcu protection for remote reads.
remote reads are rare. So optimize for same process reads and write
by switching using rask_lock instead.
This yields a simpler to understand lock, and a faster setns system call.
In particular this fixes a performance regression observed
by Rafael David Tinoco <rafael.tinoco@canonical.com>.
This is effectively a revert of Pavel Emelyanov's commit
cf7b708c8d1d7a27736771bcf4c457b332b0f818 Make access to task's nsproxy lighter
from 2007. The race this originialy fixed no longer exists as
do_notify_parent uses task_active_pid_ns(parent) instead of
parent->nsproxy.
This typedef is unnecessary and should just be removed.
The actual Linux implementation for semctl(GETNCNT) and semctl(GETZCNT)
always (since 0.99.10) reported a thread as sleeping on all semaphores
that are listed in the semop() call.
The documented behavior (both in the Linux man page and in the Single
Unix Specification) is that a task should be reported on exactly one
semaphore: The semaphore that caused the thread to got to sleep.
This patch adds a pr_info_once() that is triggered if a thread hits the
relevant case.
The code triggers slightly too often, otherwise it would be necessary to
replicate the old code. As there are no known users of GETNCNT or
GETZCNT, this is done to prevent unnecessary bloat.
The task that triggered is reported with name (tsk->comm) and pid.
Acked-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
SUSv4 clearly defines how semncnt and semzcnt must be calculated: A task
waits on exactly one semaphore: The semaphore from the first operation
in the sop array that cannot proceed.
The Linux implementation never followed the standard, it tried to count
all semaphores that might be the reason why a task sleeps.
This patch fixes that.
Note:
a) The implementation assumes that GETNCNT and GETZCNT are rare operations,
therefore the code counts them only on demand.
(If they wouldn't be rare, then the non-compliance would have
been found earlier)
b) compared to the initial version of the patch, the BUG_ONs were removed
and it was clarified that the new behavior conforms to SUS.
Back-compatibility concerns:
Manfred:
: - there is no application in Fedora that uses GETNCNT or GETZCNT.
: - application that use only single-sop semop() are also safe, the
: difference only affects complex apps.
: - portable application are also safe, the new behavior is standard
: compliant.
: But that's it. The old behavior existed in Linux from 0.99.something
: until now.
Michael:
: * These operations seem to be very little used. Grepping the public
: source that is contained Fedora 20 source DVD, there appear to be no
: uses. Of course, this says nothing about uses in private /
: non-mainstream FOSS code, but it seems likely that the same pattern
: is followed there.
: * The existing behavior is hard enough to understand that I suspect
: that no one understood it well enough to rely on it anyway
: (especially as that behavior contradicted both man page and POSIX).
: So, there's a chance of breakage, but I estimate that it's minute.
Preparation for the next patch:
In the slow-path of perform_atomic_semop(), store a pointer to the
operation that caused the operation to block.
Right now, perform_atomic_semop gets the content of sem_queue as
individual fields. Changes that, instead pass a pointer to sem_queue.
This is a preparation for the next patch: it uses sem_queue to store the
reason why a task must sleep.
count_semzcnt and count_semncnt are more of less identical. The patch
creates a single function that either counts the number of tasks waiting
for zero or waiting due to a decrease operation.
Compared to the initial version, the BUG_ONs were removed.
GETZCNT is supposed to return the number of threads that wait until a
semaphore value becomes 0.
The current implementation overlooks complex operations that contain
both wait-for-zero operation and operations that alter at least one
semaphore.
The patch fixes that. It's intentionally copy&paste, this will be
cleaned up in the next patch.
The need for volatile is not obvious, document it.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Aswin Chandramouleeswaran <aswin@hp.com>
Nothing big and no logical changes, just get rid of some redundant
function declarations. Move msg_[init/exit]_ns down the end of the
file.
Signed-off-by: Manfred Spraul <manfred@colorfullif.com>
SHMMAX is the upper limit for the size of a shared memory segment, counted
in bytes. The actual allocation is that size, rounded up to the next full
page.
Add a check that prevents the creation of segments where the rounded up
size causes an integer overflow.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
shm_tot counts the total number of pages used by shm segments.
If SHMALL is ULONG_MAX (or nearly ULONG_MAX), then the number can
overflow. Subsequent calls to shmctl(,SHM_INFO,) would return wrong
values for shm_tot.
The patch adds a detection for overflows.
