path: root/ipc
2009-02-10Do not account for the address space used by hugetlbfs using VM_ACCOUNTMel Gorman
When overcommit is disabled, the core VM accounts for pages used by anonymous shared, private mappings and special mappings. It keeps track of VMAs that should be accounted for with VM_ACCOUNT and VMAs that never had a reserve with VM_NORESERVE. Overcommit for hugetlbfs is much riskier than overcommit for base pages due to contiguity requirements. It avoids overcommiting on both shared and private mappings using reservation counters that are checked and updated during mmap(). This ensures (within limits) that hugepages exist in the future when faults occurs or it is too easy to applications to be SIGKILLed. As hugetlbfs makes its own reservations of a different unit to the base page size, VM_ACCOUNT should never be set. Even if the units were correct, we would double account for the usage in the core VM and hugetlbfs. VM_NORESERVE may be set because an application can request no reserves be made for hugetlbfs at the risk of getting killed later. With commit fc8744adc870a8d4366908221508bb113d8b72ee, VM_NORESERVE and VM_ACCOUNT are getting unconditionally set for hugetlbfs-backed mappings. This breaks the accounting for both the core VM and hugetlbfs, can trigger an OOM storm when hugepage pools are too small lockups and corrupted counters otherwise are used. This patch brings hugetlbfs more in line with how the core VM treats VM_NORESERVE but prevents VM_ACCOUNT being set. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-05shm: fix shmctl(SHM_INFO) lockup with !CONFIG_SHMEMTony Battersby
shm_get_stat() assumes that the inode is a "struct shmem_inode_info", which is incorrect for !CONFIG_SHMEM (see fs/ramfs/inode.c: ramfs_get_inode() vs. mm/shmem.c: shmem_get_inode()). This bad assumption can cause shmctl(SHM_INFO) to lockup when shm_get_stat() tries to spin_lock(&info->lock). Users of !CONFIG_SHMEM may encounter this lockup simply by invoking the 'ipcs' command. Reported by Jiri Olsa back in February 2008: http://lkml.org/lkml/2008/2/29/74 Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Cc: Jiri Kosina <jkosina@suse.cz> Reported-by: Jiri Olsa <olsajiri@gmail.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: <stable@kernel.org> [2.6.everything] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-31Stop playing silly games with the VM_ACCOUNT flagLinus Torvalds
The mmap_region() code would temporarily set the VM_ACCOUNT flag for anonymous shared mappings just to inform shmem_zero_setup() that it should enable accounting for the resulting shm object. It would then clear the flag after calling ->mmap (for the /dev/zero case) or doing shmem_zero_setup() (for the MAP_ANON case). This just resulted in vma merge issues, but also made for just unnecessary confusion. Use the already-existing VM_NORESERVE flag for this instead, and let shmem_{zero|file}_setup() just figure it out from that. This also happens to make it obvious that the new DRI2 GEM layer uses a non-reserving backing store for its object allocation - which is quite possibly not intentional. But since I didn't want to change semantics in this patch, I left it alone, and just updated the caller to use the new flag semantics. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 26Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 25Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 24Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrapper special casesHeiko Carstens
System calls with an unsigned long long argument can't be converted with the standard wrappers since that would include a cast to long, which in turn means that we would lose the upper 32 bit on 32 bit architectures. Also semctl can't use the standard wrapper since it has a 'union' parameter. So we handle them as special case and add some extra wrappers instead. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14[CVE-2009-0029] Convert all system calls to return a longHeiko Carstens
Convert all system calls to return a long. This should be a NOP since all converted types should have the same size anyway. With the exception of sys_exit_group which returned void. But that doesn't matter since the system call doesn't return. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommuLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommu: NOMMU: Support XIP on initramfs NOMMU: Teach kobjsize() about VMA regions. FLAT: Don't attempt to expand the userspace stack to fill the space allocated FDPIC: Don't attempt to expand the userspace stack to fill the space allocated NOMMU: Improve procfs output using per-MM VMAs NOMMU: Make mmap allocation page trimming behaviour configurable. NOMMU: Make VMAs per MM as for MMU-mode linux NOMMU: Delete askedalloc and realalloc variables NOMMU: Rename ARM's struct vm_region NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()
2009-01-08mqueue: fix si_pid value in mqueue do_notify()Sukadev Bhattiprolu
If a process registers for asynchronous notification on a POSIX message queue, it gets a signal and a siginfo_t structure when a message arrives on the message queue. The si_pid in the siginfo_t structure is set to the PID of the process that sent the message to the message queue. The principle is the following: . when mq_notify(SIGEV_SIGNAL) is called, the caller registers for notification when a msg arrives. The associated pid structure is stroed into inode_info->notify_owner. Let's call this process P1. . when mq_send() is called by say P2, P2 sends a signal to P1 to notify him about msg arrival. The way .si_pid is set today is not correct, since it doesn't take into account the fact that the process that is sending the message might not be in the same namespace as the notified one. This patch proposes to set si_pid to the sender's pid into the notify_owner namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Bastian Blank <bastian@waldi.eu.org> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08NOMMU: Make VMAs per MM as for MMU-mode linuxDavid Howells
Make VMAs per mm_struct as for MMU-mode linux. This solves two problems: (1) In SYSV SHM where nattch for a segment does not reflect the number of shmat's (and forks) done. (2) In mmap() where the VMA's vm_mm is set to point to the parent mm by an exec'ing process when VM_EXECUTABLE is specified, regardless of the fact that a VMA might be shared and already have its vm_mm assigned to another process or a dead process. A new struct (vm_region) is introduced to track a mapped region and to remember the circumstances under which it may be shared and the vm_list_struct structure is discarded as it's no longer required. This patch makes the following additional changes: (1) Regions are now allocated with alloc_pages() rather than kmalloc() and with no recourse to __GFP_COMP, so the pages are not composite. Instead, each page has a reference on it held by the region. Anything else that is interested in such a page will have to get a reference on it to retain it. When the pages are released due to unmapping, each page is passed to put_page() and will be freed when the page usage count reaches zero. (2) Excess pages are trimmed after an allocation as the allocation must be made as a power-of-2 quantity of pages. (3) VMAs are added to the parent MM's R/B tree and mmap lists. As an MM may end up with overlapping VMAs within the tree, the VMA struct address is appended to the sort key. (4) Non-anonymous VMAs are now added to the backing inode's prio list. (5) Holes may be punched in anonymous VMAs with munmap(), releasing parts of the backing region. The VMA and region structs will be split if necessary. (6) sys_shmdt() only releases one attachment to a SYSV IPC shared memory segment instead of all the attachments at that addresss. Multiple shmat()'s return the same address under NOMMU-mode instead of different virtual addresses as under MMU-mode. (7) Core dumping for ELF-FDPIC requires fewer exceptions for NOMMU-mode. (8) /proc/maps is now the global list of mapped regions, and may list bits that aren't actually mapped anywhere. (9) /proc/meminfo gains a line (tagged "MmapCopy") that indicates the amount of RAM currently allocated by mmap to hold mappable regions that can't be mapped directly. These are copies of the backing device or file if not anonymous. These changes make NOMMU mode more similar to MMU mode. The downside is that NOMMU mode requires some extra memory to track things over NOMMU without this patch (VMAs are no longer shared, and there are now region structs). Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2009-01-06ipc/ipc_sysctl.c: move the definition of ipc_auto_callback()akpm@linux-foundation.org
proc_ipcauto_dointvec_minmax() is the only user of ipc_auto_callback(), since the former function is protected by CONFIG_PROC_FS, so should be the latter one. Just move its definition down. Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: Eric Biederman <ebiederm@xmision.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06ipc: do not goto to the next lineDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Reviewed-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06ipc: clean up ipc/shm.cWANG Cong
Use the macro shm_ids(). Remove useless check for a userspace pointer, because copy_to_user() will check it. Some style cleanups. Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: inotify: fix type errors in interfaces fix breakage in reiserfs_new_inode() fix the treatment of jfs special inodes vfs: remove duplicate code in get_fs_type() add a vfs_fsync helper sys_execve and sys_uselib do not call into fsnotify zero i_uid/i_gid on inode allocation inode->i_op is never NULL ntfs: don't NULL i_op isofs check for NULL ->i_op in root directory is dead code affs: do not zero ->i_op kill suid bit only for regular files vfs: lseek(fd, 0, SEEK_CUR) race condition
2009-01-05mm: update my addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_mq_open()Al Viro
* don't bother with allocations * don't do double copy_from_user() * don't duplicate parts of check for audit_dummy_context() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize AUDIT_MQ_SENDRECVAl Viro
* logging the original value of *msg_prio in mq_timedreceive(2) is insane - the argument is write-only (i.e. syscall always ignores the original value and only overwrites it). * merge __audit_mq_timed{send,receive} * don't do copy_from_user() twice * don't mess with allocations in auditsc part * ... and don't bother checking !audit_enabled and !context in there - we'd already checked for audit_dummy_context(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_mq_notify()Al Viro
* don't copy_from_user() twice * don't bother with allocations * don't duplicate parts of audit_dummy_context() * make it return void Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_mq_getsetattr()Al Viro
* get rid of allocations * make it return void * don't duplicate parts of audit_dummy_context() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_ipc_set_perm()Al Viro
* get rid of allocations * make it return void * simplify callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_ipc_obj()Al Viro
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-11-19sysvipc: fix the ipc structures initializationNadia Derbey
A problem was found while reviewing the code after Bugzilla bug http://bugzilla.kernel.org/show_bug.cgi?id=11796. In ipc_addid(), the newly allocated ipc structure is inserted into the ipcs tree (i.e made visible to readers) without locking it. This is not correct since its initialization continues after it has been inserted in the tree. This patch moves the ipc structure lock initialization + locking before the actual insertion. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Reported-by: Clement Calmels <cboulte@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Pass credentials through dentry_open()David Howells
Pass credentials through dentry_open() so that the COW creds patch can have SELinux's flush_unauthorized_files() pass the appropriate creds back to itself when it opens its null chardev. The security_dentry_open() call also now takes a creds pointer, as does the dentry_open hook in struct security_operations. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the SYSV IPC subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-10-20message queues: increase range limitsJoe Korty
Increase the range of various posix message queue limits. Posix gives the message queue user the ability to 'trade off' the maximum size of messages with the number of possible messages that can be 'in flight'. Linux currently makes this trade off more restrictive than it needs to be. In particular, the maximum message size today can be made no smaller than 8192. This greatly restricts those applications that would like to have the ability to post large numbers of very small messages. So this task lowers the limit that the maximum message size can be set to, from 8192 to 128. It also lowers the limit that the maximum #number of messages in flight can be set to, from 10 to 1. With these changes the message queue user can make better trade offs between #messages and message size, in order to get everything to fit within the setrlimit(RLIMIT_MSGQUEUE) limit for that particular user. This patch also applies the values in /proc/sys/fs/mqueue/msg_max /proc/sys/fs/mqueue/msgsize_max as the defaults for the max #messages allowed and the max message size allowed, respectively, for those applications that do not supply these. Previously, the defaults were hardwired to 10 and 8192, respectively. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joe Korty <joe.korty@ccur.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20SHM_LOCKED pages are unevictableLee Schermerhorn
Shmem segments locked into memory via shmctl(SHM_LOCKED) should not be kept on the normal LRU, since scanning them is a waste of time and might throw off kswapd's balancing algorithms. Place them on the unevictable LRU list instead. Use the AS_UNEVICTABLE flag to mark address_space of SHM_LOCKed shared memory regions as unevictable. Then these pages will be culled off the normal LRU lists during vmscan. Add new wrapper function to clear the mapping's unevictable state when/if shared memory segment is munlocked. Add 'scan_mapping_unevictable_page()' to mm/vmscan.c to scan all pages in the shmem segment's mapping [struct address_space] for evictability now that they're no longer locked. If so, move them to the appropriate zone lru list. Changes depend on [CONFIG_]UNEVICTABLE_LRU. [kosaki.motohiro@jp.fujitsu.com: revert shm change] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Kosaki Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16ipc/sem.c: make free_un() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16sysctl: simplify ->strategyAlexey Dobriyan
name and nlen parameters passed to ->strategy hook are unused, remove them. In general ->strategy hook should know what it's doing, and don't do something tricky for which, say, pointer to original userspace array may be needed (name). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[PATCH] kill nameidata passing to permission(), rename to inode_permission()Al Viro
Incidentally, the name that gives hundreds of false positives on grep is not a good idea... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: do not use a negative value to re-enable msgmni automatic recomputingNadia Derbey
This patch proposes an alternative to the "magical positive-versus-negative number trick" Andrew complained about last week in http://lkml.org/lkml/2008/6/24/418. This had been introduced with the patches that scale msgmni to the amount of lowmem. With these patches, msgmni has a registered notification routine that recomputes msgmni value upon memory add/remove or ipc namespace creation/ removal. When msgmni is changed from user space (i.e. value written to the proc file), that notification routine is unregistered, and the way to make it registered back is to write a negative value into the proc file. This is the "magical positive-versus-negative number trick". To fix this, a new proc file is introduced: /proc/sys/kernel/auto_msgmni. This file acts as ON/OFF for msgmni automatic recomputing. With this patch, the process is the following: 1) kernel boots in "automatic recomputing mode" /proc/sys/kernel/msgmni contains the value that has been computed (depends on lowmem) /proc/sys/kernel/automatic_msgmni contains "1" 2) echo <val> > /proc/sys/kernel/msgmni . sets msg_ctlmni to <val> . de-activates automatic recomputing (i.e. if, say, some memory is added msgmni won't be recomputed anymore) . /proc/sys/kernel/automatic_msgmni now contains "0" 3) echo "0" > /proc/sys/kernel/automatic_msgmni . de-activates msgmni automatic recomputing this has the same effect as 2) except that msg_ctlmni's value stays blocked at its current value) 3) echo "1" > /proc/sys/kernel/automatic_msgmni . recomputes msgmni's value based on the current available memory size and number of ipc namespaces . re-activates automatic recomputing for msgmni. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Solofo Ramangalahy <Solofo.Ramangalahy@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: use simple_read_from_buffer()Akinobu Mita
Also this patch kills unneccesary trailing NULL character. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: rewrite undo list lockingManfred Spraul
The attached patch: - reverses the locking order of ulp->lock and sem_lock: Previously, it was first ulp->lock, then inside sem_lock. Now it's the other way around. - converts the undo structure to rcu. Benefits: - With the old locking order, IPC_RMID could not kfree the undo structures. The stale entries remained in the linked lists and were released later. - The patch fixes a a race in semtimedop(): if both IPC_RMID and a semget() that recreates exactly the same id happen between find_alloc_undo() and sem_lock, then semtimedop() would access already kfree'd memory. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: convert sem_array.sem_pending to struct list_headManfred Spraul
sem_array.sem_pending is a double linked list, the attached patch converts it to struct list_head. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: remove unused entries from struct sem_queueManfred Spraul
sem_queue.sma and sem_queue.id were never used, the attached patch removes them. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc/sem.c: convert undo structures to struct list_headManfred Spraul
The undo structures contain two linked lists, the attached patch replaces them with generic struct list_head lists. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: get rid of ipc_lock_down()Nadia Derbey
Remove the ipc_lock_down() routines: they used to call idr_find() locklessly (given that the ipc ids lock was already held), so they are not needed anymore. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ipc: call idr_find() without locking in ipc_lock()Nadia Derbey
Call idr_find() locklessly from ipc_lock(), since the idr tree is now RCU protected. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Jim Houston <jim.houston@comcast.net> Cc: Pierre Peiffer <peifferp@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: modular state for hugetlb page sizeAndi Kleen
The goal of this patchset is to support multiple hugetlb page sizes. This is achieved by introducing a new struct hstate structure, which encapsulates the important hugetlb state and constants (eg. huge page size, number of huge pages currently allocated, etc). The hstate structure is then passed around the code which requires these fields, they will do the right thing regardless of the exact hstate they are operating on. This patch adds the hstate structure, with a single global instance of it (default_hstate), and does the basic work of converting hugetlb to use the hstate. Future patches will add more hstate structures to allow for different hugetlbfs mounts to have different page sizes. [akpm@linux-foundation.org: coding-style fixes] Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-12/proc/sysvipc/shm: fix 32-bit truncation of segment sizesPaul Menage
sysvipc_shm_proc_show() picks between format strings (based on the expected maximum length of a SHM segment) in a way that prevents gcc from performing format checks on the seq_printf() parameters. This hid two format errors - shp->shm_segsz and shp->shm_nattach are both unsigned long, but were being printed as unsigned int and signed int respectively. This leads to 32-bit truncation of SHM segment sizes reported in /proc/sysvipc/shm. (And for nattach, but that's less of a problem for most users). This patch makes the format string directly visible to gcc's format specifier checker, and fixes the two broken format specifiers. Signed-off-by: Paul Menage <menage@google.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-10shm: Remove silly double assignmentNeil Horman
Found a silly double assignment of err is do_shmat. Silly, but good to clean up the useless code. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06ipc: only output msgmni value at boot timeNadia Derbey
When posting: [PATCH 1/8] Scaling msgmni to the amount of lowmem (see http://lkml.org/lkml/2008/2/11/171), I have added a KERN_INFO message that is output each time msgmni is recomputed. In http://lkml.org/lkml/2008/4/29/575 Tony Luck complained that this message references an ipc namespace address that is useless. I first thought of using an audit_log instead of a printk, as suggested by Serge Hallyn. But unfortunately, we do not have any other information than the namespace address to provide here too. So I chose to move the message and output it only at boot time, removing the reference to the namespace. Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Pierre Peiffer <peifferp@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Acked-by: Tony Luck <tony.luck@intel.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-05netlink: Remove nonblock parameter from netlink_attachskbDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
