path: root/ipc
2005-12-24Fix silly typo ("smb" vs "smp")Linus Torvalds
Introduced by commit 6003a93e7bf6c02f33c02976ff364785d4273295
2005-12-24[PATCH] add missing memory barriers to ipc/sem.cManfred Spraul
Two smp_wmb() statements are missing in the sysv sem code: This could cause stack corruptions. The attached patch adds them. Signed-Off-By: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2005-11-07[PATCH] more kernel-doc cleanups, additionsRandy Dunlap
Various core kernel-doc cleanups: - add missing function parameters in ipc, irq/manage, kernel/sys, kernel/sysctl, and mm/slab; - move description to just above function for kernel_restart() Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] SHM_NORESERVE flags for shmget()Badari Pulavarty
Add SHM_NORESERVE functionality similar to MAP_NORESERVE for shared memory segments. This is mainly to avoid abuse of OVERCOMMIT_ALWAYS and this flag is ignored for OVERCOMMIT_NEVER. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-06Update Michal Wronski contact infoMichal Wronski
2005-10-29[PATCH] hugetlb: remove repeated codeKrishnakumar R
Clean up some repeated code related to HugeTLB. hugetlb_zero_setup would have already allocated the file->f_op. Signed-off-by: Krishnakumar. R <rkrishnakumar@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-27[PATCH] Make POSIX message queue sys_mq_open() honor umaskKrzysztof Benedyczak
We ignored umask when creating new queues via mq_open (when creating with open() on mqueue fs it is ok of course). According to the specification this a bug. This trivial patch fixes this. Signed-off-by: Krzysztof Benedyczak <golbi@mat.uni.torun.pl> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] merge some from Rusty's trivial patchesAdrian Bunk
This patch contains the most trivial from Rusty's trivial patches: - spelling fixes - remove duplicate includes Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] ipc: convert /proc/sysvipc/* to generic seq_file interfaceMike Waychison
Change the /proc/sysvipc/shm|sem|msg files to use the generic seq_file implementation for struct ipc_ids. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] ipc: add generic struct ipc_ids seq_file iterationMike Waychison
The following two patches convert /proc/sysvipc/* to use seq_file. This gives us the following: - Self-consistent IPC records in proc. - O(n) reading of the files themselves. This patch: Add a generic method for ipc types to be displayed using seq_file. This patch abstracts out seq_file iterating over struct ipc_ids into ipc/util.c Signed-off-by: Mike Waychison <mikew@google.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] compat: be more consistent about [ug]id_tStephen Rothwell
When I first wrote the compat layer patches, I was somewhat cavalier about the definition of compat_uid_t and compat_gid_t (or maybe I just misunderstood :-)). This patch makes the compat types much more consistent with the types we are being compatible with and hopefully will fix a few bugs along the way. compat type type in compat arch __compat_[ug]id_t __kernel_[ug]id_t __compat_[ug]id32_t __kernel_[ug]id32_t compat_[ug]id_t [ug]id_t The difference is that compat_uid_t is always 32 bits (for the archs we care about) but __compat_uid_t may be 16 bits on some. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-05[PATCH] Fix semundo lock leakageIngo Molnar
semundo->lock can leak if semundo->refcount goes from 2 to 1 while another thread has it locked. This causes major problems for PREEMPT kernels. The simplest fix for now is to undo the single-thread optimization. This bug was found via relentless testing by Dominik Karall. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] shm: CONFIG_SHMEM=n build fixAndrew Morton
Fix bug found by Grant Coady <lkml@dodo.com.au>'s autobuild setup. shmem_set_policy() and shmem_get_policy() are macros if !CONFIG_SHMEM, so this doesn't work. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] xtensa: remove old syscallsChris Zankel
This patch fixes some minor bugs introduced by the previous patch (remove old syscalls). Both patches remove the obsolete syscalls. The changes in this patch were suggested by Arnd Bergmann. The vmlinux.lds.S changes are required for the latest gcc/binutils. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] put_compat_shminfo() warning fixJesse Millan
GCC 4 complains because the function put_compat_shminfo() can't get to its return statement if there is no error... If the function does not return -EFAULT, it doesn't return anything at all. Looks like a typo. Signed-off-by: Jesse Millan <jessem@cs.pdx.edu> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] ipcsem: remove superflous decrease variable from sys_semtimedopManfred Spraul
Patrick noticed that the initial scan of the semaphore operations logs decrease and increase operations seperately, but then both cases are or'ed together and decrease is never used. The attached patch removes the decrease parameter - it shrinks sys_semtimedop() by 56 bytes. Signed-Of-By: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] consolidate sys_shmatStephen Rothwell
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
