path: root/ipc
2017-07-15mqueue: fix a use-after-free in sys_mq_notify()Cong Wang
commit f991af3daabaecff34684fd51fac80319d1baad1 upstream. The retry logic for netlink_attachskb() inside sys_mq_notify() is nasty and vulnerable: 1) The sock refcnt is already released when retry is needed 2) The fd is controllable by user-space because we already release the file refcnt so we when retry but the fd has been just closed by user-space during this small window, we end up calling netlink_detachskb() on the error path which releases the sock again, later when the user-space closes this socket a use-after-free could be triggered. Setting 'sock' to NULL here should be sufficient to fix it. Reported-by: GeneBlue <geneblue.mail@gmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12ipc/shm: Fix shmat mmap nil-page protectionDavidlohr Bueso
commit 95e91b831f87ac8e1f8ed50c14d709089b4e01b8 upstream. The issue is described here, with a nice testcase: https://bugzilla.kernel.org/show_bug.cgi?id=192931 The problem is that shmat() calls do_mmap_pgoff() with MAP_FIXED, and the address rounded down to 0. For the regular mmap case, the protection mentioned above is that the kernel gets to generate the address -- arch_get_unmapped_area() will always check for MAP_FIXED and return that address. So by the time we do security_mmap_addr(0) things get funky for shmat(). The testcase itself shows that while a regular user crashes, root will not have a problem attaching a nil-page. There are two possible fixes to this. The first, and which this patch does, is to simply allow root to crash as well -- this is also regular mmap behavior, ie when hacking up the testcase and adding mmap(... |MAP_FIXED). While this approach is the safer option, the second alternative is to ignore SHM_RND if the rounded address is 0, thus only having MAP_SHARED flags. This makes the behavior of shmat() identical to the mmap() case. The downside of this is obviously user visible, but does make sense in that it maintains semantics after the round-down wrt 0 address and mmap. Passes shm related ltp tests. Link: http://lkml.kernel.org/r/1486050195-18629-1-git-send-email-dave@stgolabs.net Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Reported-by: Gareth Evans <gareth.evans@contextis.co.uk> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-27ipc: account for kmem usage on mqueue and msgAristeu Rozanski
When kmem accounting switched from account by default to only account if flagged by __GFP_ACCOUNT, IPC mqueue and messages was left out. The production use case at hand is that mqueues should be customizable via sysctls in Docker containers in a Kubernetes cluster. This can only be safely allowed to the users of the cluster (without the risk that they can cause resource shortage on a node, influencing other users' containers) if all resources they control are bounded, i.e. accounted for. Link: http://lkml.kernel.org/r/1476806075-1210-1-git-send-email-arozansk@redhat.com Signed-off-by: Aristeu Rozanski <arozansk@redhat.com> Reported-by: Stefan Schimanski <sttts@redhat.com> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Stefan Schimanski <sttts@redhat.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11ipc/sem.c: add cond_resched in exit_smeNikolay Borisov
In CONFIG_PREEMPT=n kernel a softlockup was observed while the for loop in exit_sem. Apparently it's possible for the loop to take quite a long time and it doesn't have a scheduling point in it. Since the codes is executing under an rcu read section this may also cause rcu stalls, which in turn block synchronize_rcu operations, which more or less de-stabilises the whole system. Fix this by introducing a cond_resched() at the beginning of the loop. So this patch fixes the following: NMI watchdog: BUG: soft lockup - CPU#10 stuck for 23s! [httpd:18119] CPU: 10 PID: 18119 Comm: httpd Tainted: G O 4.4.20-clouder2 #6 Hardware name: Supermicro X10DRi/X10DRi, BIOS 1.1 04/14/2015 task: ffff88348d695280 ti: ffff881c95550000 task.ti: ffff881c95550000 RIP: 0010:[<ffffffff81614bc7>] [<ffffffff81614bc7>] _raw_spin_lock+0x17/0x30 RSP: 0018:ffff881c95553e40 EFLAGS: 00000246 RAX: 0000000000000000 RBX: ffff883161b1eea8 RCX: 000000000000000d RDX: 0000000000000001 RSI: 000000000000000e RDI: ffff883161b1eea4 RBP: ffff881c95553ea0 R08: ffff881c95553e68 R09: ffff883fef376f88 R10: ffff881fffb58c20 R11: ffffea0072556600 R12: ffff883161b1eea0 R13: ffff88348d695280 R14: ffff883dec427000 R15: ffff8831621672a0 FS: 0000000000000000(0000) GS:ffff881fffb40000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f3b3723e020 CR3: 0000000001c0a000 CR4: 00000000001406e0 Call Trace: ? exit_sem+0x7c/0x280 do_exit+0x338/0xb40 do_group_exit+0x43/0xd0 SyS_exit_group+0x14/0x20 entry_SYSCALL_64_fastpath+0x16/0x6e Link: http://lkml.kernel.org/r/1475154992-6363-1-git-send-email-kernel@kyup.com Signed-off-by: Nikolay Borisov <kernel@kyup.com> Cc: Herton R. Krzesinski <herton@redhat.com> Cc: Fabian Frederick <fabf@skynet.be> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11ipc/msg: avoid waking sender upon full queueDavidlohr Bueso
Blocked tasks queued in q_senders waiting for their message to fit in the queue are blindly awoken every time we think there's a remote chance this might happen. This could cause numerous (and expensive -- thundering herd-ish) bogus wakeups if the queue is still really full. Adding to the scheduling cost/overhead, there's also the fact that we need to take the ipc object lock and requeue ourselves in the q_senders list. By keeping track of the blocked sender's message size, we can know previously if the wakeup ought to occur or not. Otherwise, to maintain the current wakeup order we just move it to the tail. This is exactly what occurs right now if the sender needs to go back to sleep. The case of EIDRM is left completely untouched, as we need to wakeup all the tasks, and shouldn't be playing games in the first place. This patch was seen to save on the 'msgctl10' ltp testcase ~15% in context switches (avg out of ten runs). Although these tests are really about functionality (as opposed to performance), is does show the direct benefits of the optimization. [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/1469748819-19484-6-git-send-email-dave@stgolabs.net Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11ipc/msg: make ss_wakeup() kill arg booleanDavidlohr Bueso
... 'tis annoying. Link: http://lkml.kernel.org/r/1469748819-19484-4-git-send-email-dave@stgolabs.net Signed-off-by: Davidlohr Bueso <dave@stgolabs.net> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11ipc/msg: batch queue sender wakeupsDavidlohr Bueso
Currently the use of wake_qs in sysv msg queues are only for the receiver tasks that are blocked on the queue. But blocked sender tasks (due to queue size constraints) still are awoken with the ipc object lock held, which can be a problem particularly for small sized queues and far from gracious for -rt (just like it was for the receiver side). The paths that actually wakeup a sender are obviously related to when we are either getting rid of the queue or after (some) space is freed-up after a receiver takes the msg (msgrcv). Furthermore, with the exception of msgrcv, we can always piggy-back on expunge_all that has its own tasks lined-up for waking. Finally, upon unlinking the message, it should be no problem delaying the wakeups a bit until after we've released the lock. Link: http://lkml.kernel.org/r/1469748819-19484-3-git-send-email-dave@stgolabs.net Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11ipc/msg: implement lockless pipelined wakeupsSebastian Andrzej Siewior
This patch moves the wakeup_process() invocation so it is not done under the ipc global lock by making use of a lockless wake_q. With this change, the waiter is woken up once the message has been assigned and it does not need to loop on SMP if the message points to NULL. In the signal case we still need to check the pointer under the lock to verify the state. This change should also avoid the introduction of preempt_disable() in -RT which avoids a busy-loop which pools for the NULL -> !NULL change if the waiter has a higher priority compared to the waker. By making use of wake_qs, the logic of sysv msg queues is greatly simplified (and very well suited as we can batch lockless wakeups), particularly around the lockless receive algorithm. This has been tested with Manred's pmsg-shared tool on a "AMD A10-7800 Radeon R7, 12 Compute Cores 4C+8G": test | before | after | diff -----------------|------------|------------|---------- pmsg-shared 8 60 | 19,347,422 | 30,442,191 | + ~57.34 % pmsg-shared 4 60 | 21,367,197 | 35,743,458 | + ~67.28 % pmsg-shared 2 60 | 22,884,224 | 24,278,200 | + ~6.09 % Link: http://lkml.kernel.org/r/1469748819-19484-2-git-send-email-dave@stgolabs.net Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11ipc/sem.c: fix complex_count vs. simple op raceManfred Spraul
Commit 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()") introduced a race: sem_lock has a fast path that allows parallel simple operations. There are two reasons why a simple operation cannot run in parallel: - a non-simple operations is ongoing (sma->sem_perm.lock held) - a complex operation is sleeping (sma->complex_count != 0) As both facts are stored independently, a thread can bypass the current checks by sleeping in the right positions. See below for more details (or kernel bugzilla 105651). The patch fixes that by creating one variable (complex_mode) that tracks both reasons why parallel operations are not possible. The patch also updates stale documentation regarding the locking. With regards to stable kernels: The patch is required for all kernels that include the commit 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()") (3.10?) The alternative is to revert the patch that introduced the race. The patch is safe for backporting, i.e. it makes no assumptions about memory barriers in spin_unlock_wait(). Background: Here is the race of the current implementation: Thread A: (simple op) - does the first "sma->complex_count == 0" test Thread B: (complex op) - does sem_lock(): This includes an array scan. But the scan can't find Thread A, because Thread A does not own sem->lock yet. - the thread does the operation, increases complex_count, drops sem_lock, sleeps Thread A: - spin_lock(&sem->lock), spin_is_locked(sma->sem_perm.lock) - sleeps before the complex_count test Thread C: (complex op) - does sem_lock (no array scan, complex_count==1) - wakes up Thread B. - decrements complex_count Thread A: - does the complex_count test Bug: Now both thread A and thread C operate on the same array, without any synchronization. Fixes: 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()") Link: http://lkml.kernel.org/r/1469123695-5661-1-git-send-email-manfred@colorfullife.com Reported-by: <felixh@informatik.uni-bremen.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: <1vier1@web.de> Cc: <stable@vger.kernel.org> [3.10+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-09-27fs: Replace CURRENT_TIME with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME macro is not appropriate for filesystems as it doesn't use the right granularity for filesystem timestamps. Use current_time() instead. CURRENT_TIME is also not y2038 safe. This is also in preparation for the patch that transitions vfs timestamps to use 64 bit time and hence make them y2038 safe. As part of the effort current_time() will be extended to do range checks. Hence, it is necessary for all file system timestamps to use current_time(). Also, current_time() will be transitioned along with vfs to be y2038 safe. Note that whenever a single call to current_time() is used to change timestamps in different inodes, it is because they share the same time granularity. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Felipe Balbi <balbi@kernel.org> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: David Sterba <dsterba@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-22Merge branch 'nsfs-ioctls' into HEADEric W. Biederman
From: Andrey Vagin <avagin@openvz.org> Each namespace has an owning user namespace and now there is not way to discover these relationships. Pid and user namepaces are hierarchical. There is no way to discover parent-child relationships too. Why we may want to know relationships between namespaces? One use would be visualization, in order to understand the running system. Another would be to answer the question: what capability does process X have to perform operations on a resource governed by namespace Y? One more use-case (which usually called abnormal) is checkpoint/restart. In CRIU we are going to dump and restore nested namespaces. There [1] was a discussion about which interface to choose to determing relationships between namespaces. Eric suggested to add two ioctl-s [2]: > Grumble, Grumble. I think this may actually a case for creating ioctls > for these two cases. Now that random nsfs file descriptors are bind > mountable the original reason for using proc files is not as pressing. > > One ioctl for the user namespace that owns a file descriptor. > One ioctl for the parent namespace of a namespace file descriptor. Here is an implementaions of these ioctl-s. $ man man7/namespaces.7 ... Since Linux 4.X, the following ioctl(2) calls are supported for namespace file descriptors. The correct syntax is: fd = ioctl(ns_fd, ioctl_type); where ioctl_type is one of the following: NS_GET_USERNS Returns a file descriptor that refers to an owning user names‐ pace. NS_GET_PARENT Returns a file descriptor that refers to a parent namespace. This ioctl(2) can be used for pid and user namespaces. For user namespaces, NS_GET_PARENT and NS_GET_USERNS have the same meaning. In addition to generic ioctl(2) errors, the following specific ones can occur: EINVAL NS_GET_PARENT was called for a nonhierarchical namespace. EPERM The requested namespace is outside of the current namespace scope. [1] https://lkml.org/lkml/2016/7/6/158 [2] https://lkml.org/lkml/2016/7/9/101 Changes for v2: * don't return ENOENT for init_user_ns and init_pid_ns. There is nothing outside of the init namespace, so we can return EPERM in this case too. > The fewer special cases the easier the code is to get > correct, and the easier it is to read. // Eric Changes for v3: * rename ns->get_owner() to ns->owner(). get_* usually means that it grabs a reference. Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com> Cc: "W. Trevor King" <wking@tremily.us> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Serge Hallyn <serge.hallyn@canonical.com>
2016-09-22kernel: add a helper to get an owning user namespace for a namespaceAndrey Vagin
Return -EPERM if an owning user namespace is outside of a process current user namespace. v2: In a first version ns_get_owner returned ENOENT for init_user_ns. This special cases was removed from this version. There is nothing outside of init_user_ns, so we can return EPERM. v3: rename ns->get_owner() to ns->owner(). get_* usually means that it grabs a reference. Acked-by: Serge Hallyn <serge@hallyn.com> Signed-off-by: Andrei Vagin <avagin@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2016-09-22userns: When the per user per user namespace limit is reached return ENOSPCEric W. Biederman
The current error codes returned when a the per user per user namespace limit are hit (EINVAL, EUSERS, and ENFILE) are wrong. I asked for advice on linux-api and it we made clear that those were the wrong error code, but a correct effor code was not suggested. The best general error code I have found for hitting a resource limit is ENOSPC. It is not perfect but as it is unambiguous it will serve until someone comes up with a better error code. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-08-08ipcns: Add a limit on the number of ipc namespacesEric W. Biederman
Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-08-02ipc: delete "nr_ipc_ns"Alexey Dobriyan
Write-only variable. Link: http://lkml.kernel.org/r/20160708214356.GA6785@p183.telecom.by Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02sysv, ipc: fix security-layer leakingFabian Frederick
Commit 53dad6d3a8e5 ("ipc: fix race with LSMs") updated ipc_rcu_putref() to receive rcu freeing function but used generic ipc_rcu_free() instead of msg_rcu_free() which does security cleaning. Running LTP msgsnd06 with kmemleak gives the following: cat /sys/kernel/debug/kmemleak unreferenced object 0xffff88003c0a11f8 (size 8): comm "msgsnd06", pid 1645, jiffies 4294672526 (age 6.549s) hex dump (first 8 bytes): 1b 00 00 00 01 00 00 00 ........ backtrace: kmemleak_alloc+0x23/0x40 kmem_cache_alloc_trace+0xe1/0x180 selinux_msg_queue_alloc_security+0x3f/0xd0 security_msg_queue_alloc+0x2e/0x40 newque+0x4e/0x150 ipcget+0x159/0x1b0 SyS_msgget+0x39/0x40 entry_SYSCALL_64_fastpath+0x13/0x8f Manfred Spraul suggested to fix sem.c as well and Davidlohr Bueso to only use ipc_rcu_free in case of security allocation failure in newary() Fixes: 53dad6d3a8e ("ipc: fix race with LSMs") Link: http://lkml.kernel.org/r/1470083552-22966-1-git-send-email-fabf@skynet.be Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: <stable@vger.kernel.org> [3.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull userns vfs updates from Eric Biederman: "This tree contains some very long awaited work on generalizing the user namespace support for mounting filesystems to include filesystems with a backing store. The real world target is fuse but the goal is to update the vfs to allow any filesystem to be supported. This patchset is based on a lot of code review and testing to approach that goal. While looking at what is needed to support the fuse filesystem it became clear that there were things like xattrs for security modules that needed special treatment. That the resolution of those concerns would not be fuse specific. That sorting out these general issues made most sense at the generic level, where the right people could be drawn into the conversation, and the issues could be solved for everyone. At a high level what this patchset does a couple of simple things: - Add a user namespace owner (s_user_ns) to struct super_block. - Teach the vfs to handle filesystem uids and gids not mapping into to kuids and kgids and being reported as INVALID_UID and INVALID_GID in vfs data structures. By assigning a user namespace owner filesystems that are mounted with only user namespace privilege can be detected. This allows security modules and the like to know which mounts may not be trusted. This also allows the set of uids and gids that are communicated to the filesystem to be capped at the set of kuids and kgids that are in the owning user namespace of the filesystem. One of the crazier corner casees this handles is the case of inodes whose i_uid or i_gid are not mapped into the vfs. Most of the code simply doesn't care but it is easy to confuse the inode writeback path so no operation that could cause an inode write-back is permitted for such inodes (aka only reads are allowed). This set of changes starts out by cleaning up the code paths involved in user namespace permirted mounts. Then when things are clean enough adds code that cleanly sets s_user_ns. Then additional restrictions are added that are possible now that the filesystem superblock contains owner information. These changes should not affect anyone in practice, but there are some parts of these restrictions that are changes in behavior. - Andy's restriction on suid executables that does not honor the suid bit when the path is from another mount namespace (think /proc/[pid]/fd/) or when the filesystem was mounted by a less privileged user. - The replacement of the user namespace implicit setting of MNT_NODEV with implicitly setting SB_I_NODEV on the filesystem superblock instead. Using SB_I_NODEV is a stronger form that happens to make this state user invisible. The user visibility can be managed but it caused problems when it was introduced from applications reasonably expecting mount flags to be what they were set to. There is a little bit of work remaining before it is safe to support mounting filesystems with backing store in user namespaces, beyond what is in this set of changes. - Verifying the mounter has permission to read/write the block device during mount. - Teaching the integrity modules IMA and EVM to handle filesystems mounted with only user namespace root and to reduce trust in their security xattrs accordingly. - Capturing the mounters credentials and using that for permission checks in d_automount and the like. (Given that overlayfs already does this, and we need the work in d_automount it make sense to generalize this case). Furthermore there are a few changes that are on the wishlist: - Get all filesystems supporting posix acls using the generic posix acls so that posix_acl_fix_xattr_from_user and posix_acl_fix_xattr_to_user may be removed. [Maintainability] - Reducing the permission checks in places such as remount to allow the superblock owner to perform them. - Allowing the superblock owner to chown files with unmapped uids and gids to something that is mapped so the files may be treated normally. I am not considering even obvious relaxations of permission checks until it is clear there are no more corner cases that need to be locked down and handled generically. Many thanks to Seth Forshee who kept this code alive, and putting up with me rewriting substantial portions of what he did to handle more corner cases, and for his diligent testing and reviewing of my changes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (30 commits) fs: Call d_automount with the filesystems creds fs: Update i_[ug]id_(read|write) to translate relative to s_user_ns evm: Translate user/group ids relative to s_user_ns when computing HMAC dquot: For now explicitly don't support filesystems outside of init_user_ns quota: Handle quota data stored in s_user_ns in quota_setxquota quota: Ensure qids map to the filesystem vfs: Don't create inodes with a uid or gid unknown to the vfs vfs: Don't modify inodes with a uid or gid unknown to the vfs cred: Reject inodes with invalid ids in set_create_file_as() fs: Check for invalid i_uid in may_follow_link() vfs: Verify acls are valid within superblock's s_user_ns. userns: Handle -1 in k[ug]id_has_mapping when !CONFIG_USER_NS fs: Refuse uid/gid changes which don't map into s_user_ns selinux: Add support for unprivileged mounts from user namespaces Smack: Handle labels consistently in untrusted mounts Smack: Add support for unprivileged mounts from user namespaces fs: Treat foreign mounts as nosuid fs: Limit file caps to the user namespace of the super block userns: Remove the now unnecessary FS_USERNS_DEV_MOUNT flag userns: Remove implicit MNT_NODEV fragility. ...
2016-07-26shmem: make shmem_inode_info::lock irq-safeKirill A. Shutemov
We are going to need to call shmem_charge() under tree_lock to get accoutning right on collapse of small tmpfs pages into a huge one. The problem is that tree_lock is irq-safe and lockdep is not happy, that we take irq-unsafe lock under irq-safe[1]. Let's convert the lock to irq-safe. [1] https://gist.github.com/kiryl/80c0149e03ed35dfaf26628b8e03cdbc Link: http://lkml.kernel.org/r/1466021202-61880-34-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26shmem: get_unmapped_area align huge pageHugh Dickins
Provide a shmem_get_unmapped_area method in file_operations, called at mmap time to decide the mapping address. It could be conditional on CONFIG_TRANSPARENT_HUGEPAGE, but save #ifdefs in other places by making it unconditional. shmem_get_unmapped_area() first calls the usual mm->get_unmapped_area (which we treat as a black box, highly dependent on architecture and config and executable layout). Lots of conditions, and in most cases it just goes with the address that chose; but when our huge stars are rightly aligned, yet that did not provide a suitable address, go back to ask for a larger arena, within which to align the mapping suitably. There have to be some direct calls to shmem_get_unmapped_area(), not via the file_operations: because of the way shmem_zero_setup() is called to create a shmem object late in the mmap sequence, when MAP_SHARED is requested with MAP_ANONYMOUS or /dev/zero. Though this only matters when /proc/sys/vm/shmem_huge has been set. Link: http://lkml.kernel.org/r/1466021202-61880-29-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-23vfs: Generalize filesystem nodev handling.Eric W. Biederman
Introduce a function may_open_dev that tests MNT_NODEV and a new superblock flab SB_I_NODEV. Use this new function in all of the places where MNT_NODEV was previously tested. Add the new SB_I_NODEV s_iflag to proc, sysfs, and mqueuefs as those filesystems should never support device nodes, and a simple superblock flags makes that very hard to get wrong. With SB_I_NODEV set if any device nodes somehow manage to show up on on a filesystem those device nodes will be unopenable. Acked-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-06-23ipc/mqueue: The mqueue filesystem should never contain executablesEric W. Biederman
Set SB_I_NOEXEC on mqueuefs to ensure small implementation mistakes do not result in executable on mqueuefs by accident. Acked-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-06-23vfs: Pass data, ns, and ns->userns to mount_nsEric W. Biederman
Today what is normally called data (the mount options) is not passed to fill_super through mount_ns. Pass the mount options and the namespace separately to mount_ns so that filesystems such as proc that have mount options, can use mount_ns. Pass the user namespace to mount_ns so that the standard permission check that verifies the mounter has permissions over the namespace can be performed in mount_ns instead of in each filesystems .mount method. Thus removing the duplication between mqueuefs and proc in terms of permission checks. The extra permission check does not currently affect the rpc_pipefs filesystem and the nfsd filesystem as those filesystems do not currently allow unprivileged mounts. Without unpvileged mounts it is guaranteed that the caller has already passed capable(CAP_SYS_ADMIN) which guarantees extra permission check will pass. Update rpc_pipefs and the nfsd filesystem to ensure that the network namespace reference is always taken in fill_super and always put in kill_sb so that the logic is simpler and so that errors originating inside of fill_super do not cause a network namespace leak. Acked-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-06-23ipc: Initialize ipc_namespace->user_ns early.Eric W. Biederman
Allow the ipc namespace initialization code to depend on ns->user_ns being set during initialization. In particular this allows mq_init_ns to use ns->user_ns for permission checks and initializating s_user_ns while the the mq filesystem is being mounted. Acked-by: Seth Forshee <seth.forshee@canonical.com> Suggested-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-06-14locking/spinlock: Update spin_unlock_wait() usersPeter Zijlstra
With the modified semantics of spin_unlock_wait() a number of explicit barriers can be removed. Also update the comment for the do_exit() usecase, as that was somewhat stale/obscure. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-14locking/barriers: Introduce smp_acquire__after_ctrl_dep()Peter Zijlstra
Introduce smp_acquire__after_ctrl_dep(), this construct is not uncommon, but the lack of this barrier is. Use it to better express smp_rmb() uses in WRITE_ONCE(), the IPC semaphore code and the qspinlock code. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-05-23ipc, shm: make shmem attach/detach wait for mmap_sem killableMichal Hocko
shmat and shmdt rely on mmap_sem for write. If the waiting task gets killed by the oom killer it would block oom_reaper from asynchronous address space reclaim and reduce the chances of timely OOM resolving. Wait for the lock in the killable mode and return with EINTR if the task got killed while waiting. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-22ipc/sem: make semctl setting sempid consistentDavidlohr Bueso
As indicated by bug#112271, Linux sets the sempid value upon semctl, and not only for semop calls. However, within semctl we only do this for SETVAL, leaving SETALL without updating the field, and therefore rather inconsistent behavior when compared to other Unices. There is really no documentation regarding this and therefore users should not make assumptions. With this patch, along with updating semctl.2 manpages, this scenario should become less ambiguous As such, set sempid on SETALL cmd. Also update some in-code documentation, specifying where the sempid is set. Passes ltp and custom testcase where a child (fork) does SETALL to the set. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Reported-by: Philip Semanchuk <linux_kernel.20.ick@spamgourmet.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Herton R. Krzesinski <herton@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-18ipc/shm: handle removed segments gracefully in shm_mmap()Kirill A. Shutemov
remap_file_pages(2) emulation can reach file which represents removed IPC ID as long as a memory segment is mapped. It breaks expectations of IPC subsystem. Test case (rewritten to be more human readable, originally autogenerated by syzkaller[1]): #define _GNU_SOURCE #include <stdlib.h> #include <sys/ipc.h> #include <sys/mman.h> #include <sys/shm.h> #define PAGE_SIZE 4096 int main() { int id; void *p; id = shmget(IPC_PRIVATE, 3 * PAGE_SIZE, 0); p = shmat(id, NULL, 0); shmctl(id, IPC_RMID, NULL); remap_file_pages(p, 3 * PAGE_SIZE, 0, 7, 0); return 0; } The patch changes shm_mmap() and code around shm_lock() to propagate locking error back to caller of shm_mmap(). [1] http://github.com/google/syzkaller Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull final vfs updates from Al Viro: - The ->i_mutex wrappers (with small prereq in lustre) - a fix for too early freeing of symlink bodies on shmem (they need to be RCU-delayed) (-stable fodder) - followup to dedupe stuff merged this cycle * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: abort dedupe loop if fatal signals are pending make sure that freeing shmem fast symlinks is RCU-delayed wrappers for ->i_mutex access lustre: remove unused declaration
2016-01-22tree wide: use kvfree() than conditional kfree()/vfree()Tetsuo Handa
There are many locations that do if (memory_was_allocated_by_vmalloc) vfree(ptr); else kfree(ptr); but kvfree() can handle both kmalloc()ed memory and vmalloc()ed memory using is_vmalloc_addr(). Unless callers have special reasons, we can replace this branch with kvfree(). Please check and reply if you found problems. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Andreas Dilger <andreas.dilger@intel.com> Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> Acked-by: David Rientjes <rientjes@google.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Boris Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-20ipc/shm.c: is_file_shm_hugepages() can be booleanYaowei Bai
Make is_file_shm_hugepages() return bool to improve readability due to this particular function only using either one or zero as its return value. No functional change. Signed-off-by: Yaowei Bai <baiyaowei@cmss.chinamobile.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14kmemcg: account certain kmem allocations to memcgVladimir Davydov
Mark those kmem allocations that are known to be easily triggered from userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to memcg. For the list, see below: - threadinfo - task_struct - task_delay_info - pid - cred - mm_struct - vm_area_struct and vm_region (nommu) - anon_vma and anon_vma_chain - signal_struct - sighand_struct - fs_struct - files_struct - fdtable and fdtable->full_fds_bits - dentry and external_name - inode for all filesystems. This is the most tedious part, because most filesystems overwrite the alloc_inode method. The list is far from complete, so feel free to add more objects. Nevertheless, it should be close to "account everything" approach and keep most workloads within bounds. Malevolent users will be able to breach the limit, but this was possible even with the former "account everything" approach (simply because it did not account everything in fact). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06ipc,msg: drop dst nil validation in copy_msgDavidlohr Bueso
d0edd8528362 ("ipc: convert invalid scenarios to use WARN_ON") relaxed the nil dst parameter check, originally being a full BUG_ON. However, this check seems quite unnecessary when the only purpose is for ceckpoint/restore (MSG_COPY flag): o The copy variable is set initially to nil, apparently as a way of ensuring that prepare_copy is previously called. Which is in fact done, unconditionally at the beginning of do_msgrcv. o There is no concurrency with 'copy' (stack allocated in do_msgrcv). Furthermore, any errors in 'copy' (and thus prepare_copy/copy_msg) should always handled by IS_ERR() family. Therefore remove this check altogether as it can never occur with the current users. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-30Initialize msg/shm IPC objects before doing ipc_addid()Linus Torvalds
As reported by Dmitry Vyukov, we really shouldn't do ipc_addid() before having initialized the IPC object state. Yes, we initialize the IPC object in a locked state, but with all the lockless RCU lookup work, that IPC object lock no longer means that the state cannot be seen. We already did this for the IPC semaphore code (see commit e8577d1f0329: "ipc/sem.c: fully initialize sem_array before making it visible") but we clearly forgot about msg and shm. Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dbueso@suse.de> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10ipc: convert invalid scenarios to use WARN_ONDavidlohr Bueso
Considering Linus' past rants about the (ab)use of BUG in the kernel, I took a look at how we deal with such calls in ipc. Given that any errors or corruption in ipc code are most likely contained within the set of processes participating in the broken mechanisms, there aren't really many strong fatal system failure scenarios that would require a BUG call. Also, if something is seriously wrong, ipc might not be the place for such a BUG either. 1. For example, recently, a customer hit one of these BUG_ONs in shm after failing shm_lock(). A busted ID imho does not merit a BUG_ON, and WARN would have been better. 2. MSG_COPY functionality of posix msgrcv(2) for checkpoint/restore. I don't see how we can hit this anyway -- at least it should be IS_ERR. The 'copy' arg from do_msgrcv is always set by calling prepare_copy() first and foremost. We could also probably drop this check altogether. Either way, it does not merit a BUG_ON. 3. No ->fault() callback for the fs getting the corresponding page -- seems selfish to make the system unusable. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-14ipc/sem.c: update/correct memory barriersManfred Spraul
sem_lock() did not properly pair memory barriers: !spin_is_locked() and spin_unlock_wait() are both only control barriers. The code needs an acquire barrier, otherwise the cpu might perform read operations before the lock test. As no primitive exists inside <include/spinlock.h> and since it seems noone wants another primitive, the code creates a local primitive within ipc/sem.c. With regards to -stable: The change of sem_wait_array() is a bugfix, the change to sem_lock() is a nop (just a preprocessor redefinition to improve the readability). The bugfix is necessary for all kernels that use sem_wait_array() (i.e.: starting from 3.10). Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Kirill Tkhai <ktkhai@parallels.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: <stable@vger.kernel.org> [3.10+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-14ipc,sem: remove uneeded sem_undo_list lock usage in exit_sem()Herton R. Krzesinski
After we acquire the sma->sem_perm lock in exit_sem(), we are protected against a racing IPC_RMID operation. Also at that point, we are the last user of sem_undo_list. Therefore it isn't required that we acquire or use ulp->lock. Signed-off-by: Herton R. Krzesinski <herton@redhat.com> Acked-by: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Rafael Aquini <aquini@redhat.com> CC: Aristeu Rozanski <aris@redhat.com> Cc: David Jeffery <djeffery@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-14ipc,sem: fix use after free on IPC_RMID after a task using same semaphore ↵Herton R. Krzesinski
set exits The current semaphore code allows a potential use after free: in exit_sem we may free the task's sem_undo_list while there is still another task looping through the same semaphore set and cleaning the sem_undo list at freeary function (the task called IPC_RMID for the same semaphore set). For example, with a test program [1] running which keeps forking a lot of processes (which then do a semop call with SEM_UNDO flag), and with the parent right after removing the semaphore set with IPC_RMID, and a kernel built with CONFIG_SLAB, CONFIG_SLAB_DEBUG and CONFIG_DEBUG_SPINLOCK, you can easily see something like the following in the kernel log: Slab corruption (Not tainted): kmalloc-64 start=ffff88003b45c1c0, len=64 000: 6b 6b 6b 6b 6b 6b 6b 6b 00 6b 6b 6b 6b 6b 6b 6b kkkkkkkk.kkkkkkk 010: ff ff ff ff 6b 6b 6b 6b ff ff ff ff ff ff ff ff ....kkkk........ Prev obj: start=ffff88003b45c180, len=64 000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ 010: ff ff ff ff ff ff ff ff c0 fb 01 37 00 88 ff ff ...........7.... Next obj: start=ffff88003b45c200, len=64 000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ 010: ff ff ff ff ff ff ff ff 68 29 a7 3c 00 88 ff ff ........h).<.... BUG: spinlock wrong CPU on CPU#2, test/18028 general protection fault: 0000 [#1] SMP Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib] CPU: 2 PID: 18028 Comm: test Not tainted 4.2.0-rc5+ #1 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 RIP: spin_dump+0x53/0xc0 Call Trace: spin_bug+0x30/0x40 do_raw_spin_unlock+0x71/0xa0 _raw_spin_unlock+0xe/0x10 freeary+0x82/0x2a0 ? _raw_spin_lock+0xe/0x10 semctl_down.clone.0+0xce/0x160 ? __do_page_fault+0x19a/0x430 ? __audit_syscall_entry+0xa8/0x100 SyS_semctl+0x236/0x2c0 ? syscall_trace_leave+0xde/0x130 entry_SYSCALL_64_fastpath+0x12/0x71 Code: 8b 80 88 03 00 00 48 8d 88 60 05 00 00 48 c7 c7 a0 2c a4 81 31 c0 65 8b 15 eb 40 f3 7e e8 08 31 68 00 4d 85 e4 44 8b 4b 08 74 5e <45> 8b 84 24 88 03 00 00 49 8d 8c 24 60 05 00 00 8b 53 04 48 89 RIP [<ffffffff810d6053>] spin_dump+0x53/0xc0 RSP <ffff88003750fd68> ---[ end trace 783ebb76612867a0 ]--- NMI watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [test:18053] Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib] CPU: 3 PID: 18053 Comm: test Tainted: G D 4.2.0-rc5+ #1 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 RIP: native_read_tsc+0x0/0x20 Call Trace: ? delay_tsc+0x40/0x70 __delay+0xf/0x20 do_raw_spin_lock+0x96/0x140 _raw_spin_lock+0xe/0x10 sem_lock_and_putref+0x11/0x70 SYSC_semtimedop+0x7bf/0x960 ? handle_mm_fault+0xbf6/0x1880 ? dequeue_task_fair+0x79/0x4a0 ? __do_page_fault+0x19a/0x430 ? kfree_debugcheck+0x16/0x40 ? __do_page_fault+0x19a/0x430 ? __audit_syscall_entry+0xa8/0x100 ? do_audit_syscall_entry+0x66/0x70 ? syscall_trace_enter_phase1+0x139/0x160 SyS_semtimedop+0xe/0x10 SyS_semop+0x10/0x20 entry_SYSCALL_64_fastpath+0x12/0x71 Code: 47 10 83 e8 01 85 c0 89 47 10 75 08 65 48 89 3d 1f 74 ff 7e c9 c3 0f 1f 44 00 00 55 48 89 e5 e8 87 17 04 00 66 90 c9 c3 0f 1f 00 <55> 48 89 e5 0f 31 89 c1 48 89 d0 48 c1 e0 20 89 c9 48 09 c8 c9 Kernel panic - not syncing: softlockup: hung tasks I wasn't able to trigger any badness on a recent kernel without the proper config debugs enabled, however I have softlockup reports on some kernel versions, in the semaphore code, which are similar as above (the scenario is seen on some servers running IBM DB2 which uses semaphore syscalls). The patch here fixes the race against freeary, by acquiring or waiting on the sem_undo_list lock as necessary (exit_sem can race with freeary, while freeary sets un->semid to -1 and removes the same sem_undo from list_proc or when it removes the last sem_undo). After the patch I'm unable to reproduce the problem using the test case [1]. [1] Test case used below: #include <stdio.h> #include <sys/types.h> #include <sys/ipc.h> #include <sys/sem.h> #include <sys/wait.h> #include <stdlib.h> #include <time.h> #include <unistd.h> #include <errno.h> #define NSEM 1 #define NSET 5 int sid[NSET]; void thread() { struct sembuf op; int s; uid_t pid = getuid(); s = rand() % NSET; op.sem_num = pid % NSEM; op.sem_op = 1; op.sem_flg = SEM_UNDO; semop(sid[s], &op, 1); exit(EXIT_SUCCESS); } void create_set() { int i, j; pid_t p; union { int val; struct semid_ds *buf; unsigned short int *array; struct seminfo *__buf; } un; /* Create and initialize semaphore set */ for (i = 0; i < NSET; i++) { sid[i] = semget(IPC_PRIVATE , NSEM, 0644 | IPC_CREAT); if (sid[i] < 0) { perror("semget"); exit(EXIT_FAILURE); } } un.val = 0; for (i = 0; i < NSET; i++) { for (j = 0; j < NSEM; j++) { if (semctl(sid[i], j, SETVAL, un) < 0) perror("semctl"); } } /* Launch threads that operate on semaphore set */ for (i = 0; i < NSEM * NSET * NSET; i++) { p = fork(); if (p < 0) perror("fork"); if (p == 0) thread(); } /* Free semaphore set */ for (i = 0; i < NSET; i++) { if (semctl(sid[i], NSEM, IPC_RMID)) perror("IPC_RMID"); } /* Wait for forked processes to exit */ while (wait(NULL)) { if (errno == ECHILD) break; }; } int main(int argc, char **argv) { pid_t p; srand(time(NULL)); while (1) { p = fork(); if (p < 0) { perror("fork"); exit(EXIT_FAILURE); } if (p == 0) { create_set(); goto end; } /* Wait for forked processes to exit */ while (wait(NULL)) { if (errno == ECHILD) break; }; } end: return 0; } [akpm@linux-foundation.org: use normal comment layout] Signed-off-by: Herton R. Krzesinski <herton@redhat.com> Acked-by: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Rafael Aquini <aquini@redhat.com> CC: Aristeu Rozanski <aris@redhat.com> Cc: David Jeffery <djeffery@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-07ipc: use private shmem or hugetlbfs inodes for shm segments.Stephen Smalley
The shm implementation internally uses shmem or hugetlbfs inodes for shm segments. As these inodes are never directly exposed to userspace and only accessed through the shm operations which are already hooked by security modules, mark the inodes with the S_PRIVATE flag so that inode security initialization and permission checking is skipped. This was motivated by the following lockdep warning: ====================================================== [ INFO: possible circular locking dependency detected ] 4.2.0-0.rc3.git0.1.fc24.x86_64+debug #1 Tainted: G W ------------------------------------------------------- httpd/1597 is trying to acquire lock: (&ids->rwsem){+++++.}, at: shm_close+0x34/0x130 but task is already holding lock: (&mm->mmap_sem){++++++}, at: SyS_shmdt+0x4b/0x180 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #3 (&mm->mmap_sem){++++++}: lock_acquire+0xc7/0x270 __might_fault+0x7a/0xa0 filldir+0x9e/0x130 xfs_dir2_block_getdents.isra.12+0x198/0x1c0 [xfs] xfs_readdir+0x1b4/0x330 [xfs] xfs_file_readdir+0x2b/0x30 [xfs] iterate_dir+0x97/0x130 SyS_getdents+0x91/0x120 entry_SYSCALL_64_fastpath+0x12/0x76 -> #2 (&xfs_dir_ilock_class){++++.+}: lock_acquire+0xc7/0x270 down_read_nested+0x57/0xa0 xfs_ilock+0x167/0x350 [xfs] xfs_ilock_attr_map_shared+0x38/0x50 [xfs] xfs_attr_get+0xbd/0x190 [xfs] xfs_xattr_get+0x3d/0x70 [xfs] generic_getxattr+0x4f/0x70 inode_doinit_with_dentry+0x162/0x670 sb_finish_set_opts+0xd9/0x230 selinux_set_mnt_opts+0x35c/0x660 superblock_doinit+0x77/0xf0 delayed_superblock_init+0x10/0x20 iterate_supers+0xb3/0x110 selinux_complete_init+0x2f/0x40 security_load_policy+0x103/0x600 sel_write_load+0xc1/0x750 __vfs_write+0x37/0x100 vfs_write+0xa9/0x1a0 SyS_write+0x58/0xd0 entry_SYSCALL_64_fastpath+0x12/0x76 ... Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Reported-by: Morten Stevens <mstevens@fedoraproject.org> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-07ipc: modify message queue accounting to not take kernel data structures into ↵Marcus Gelderie
account A while back, the message queue implementation in the kernel was improved to use btrees to speed up retrieval of messages, in commit d6629859b36d ("ipc/mqueue: improve performance of send/recv"). That patch introducing the improved kernel handling of message queues (using btrees) has, as a by-product, changed the meaning of the QSIZE field in the pseudo-file created for the queue. Before, this field reflected the size of the user-data in the queue. Since, it also takes kernel data structures into account. For example, if 13 bytes of user data are in the queue, on my machine the file reports a size of 61 bytes. There was some discussion on this topic before (for example https://lkml.org/lkml/2014/10/1/115). Commenting on a th lkml, Michael Kerrisk gave the following background (https://lkml.org/lkml/2015/6/16/74): The pseudofiles in the mqueue filesystem (usually mounted at /dev/mqueue) expose fields with metadata describing a message queue. One of these fields, QSIZE, as originally implemented, showed the total number of bytes of user data in all messages in the message queue, and this feature was documented from the beginning in the mq_overview(7) page. In 3.5, some other (useful) work happened to break the user-space API in a couple of places, including the value exposed via QSIZE, which now includes a measure of kernel overhead bytes for the queue, a figure that renders QSIZE useless for its original purpose, since there's no way to deduce the number of overhead bytes consumed by the implementation. (The other user-space breakage was subsequently fixed.) This patch removes the accounting of kernel data structures in the queue. Reporting the size of these data-structures in the QSIZE field was a breaking change (see Michael's comment above). Without the QSIZE field reporting the total size of user-data in the queue, there is no way to deduce this number. It should be noted that the resource limit RLIMIT_MSGQUEUE is counted against the worst-case size of the queue (in both the old and the new implementation). Therefore, the kernel overhead accounting in QSIZE is not necessary to help the user understand the limitations RLIMIT imposes on the processes. Signed-off-by: Marcus Gelderie <redmnic@gmail.com> Acked-by: Doug Ledford <dledford@redhat.com> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Davidlohr Bueso <dbueso@suse.de> Cc: David Howells <dhowells@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: John Duffy <jb_duffy@btinternet.com> Cc: Arto Bendiken <arto@bendiken.net> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc,sysv: return -EINVAL upon incorrect id/seqnumDavidlohr Bueso
In ipc_obtain_object_check we return -EIDRM when a bogus sequence number is detected via ipc_checkid, while the ipc manpages state the following return codes for such errors: EIDRM <ID> points to a removed identifier. EINVAL Invalid <ID> value, or unaligned, etc. EIDRM should only be returned upon a RMID call (->deleted check), and thus return EINVAL for wrong seq. This difference in semantics has also caused real bugs, ie: https://bugzilla.redhat.com/show_bug.cgi?id=246509 Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc,sysv: make return -EIDRM when racing with RMID consistentDavidlohr Bueso
The ipc_lock helper is used by all forms of sysv ipc to acquire the ipc object's spinlock. Upon error (bogus identifier), we always return -EINVAL, whether the problem be in the idr path or because we raced with a task performing RMID. For the later, however, all ipc related manpages, state the that for: EIDRM <ID> points to a removed identifier. And return: EINVAL Invalid <ID> value, or unaligned, etc. Which (EINVAL) should only return once the ipc resource is deleted. For all types of ipc this is done immediately upon a RMID command. However, shared memory behaves slightly different as it can merely mark a segment for deletion, and delay the actual freeing until there are no more active consumers. Per shmctl(IPC_RMID) manpage: "" Mark the segment to be destroyed. The segment will only actually be destroyed after the last process detaches it (i.e., when the shm_nattch member of the associated structure shmid_ds is zero). "" Unlike ipc_lock, paths that behave "correctly", at least per the manpage, involve controlling the ipc resource via *ctl(), doing the exact same validity check as ipc_lock after right acquiring the spinlock: if (!ipc_valid_object()) { err = -EIDRM; goto out_unlock; } Thus make ipc_lock consistent with the rest of ipc code and return -EIDRM in ipc_lock when !ipc_valid_object(). Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc: rename ipc_obtain_objectDavidlohr Bueso
... to ipc_obtain_object_idr, which is more meaningful and makes the code slightly easier to follow. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc,msg: provide barrier pairings for lockless receiveDavidlohr Bueso
We currently use a full barrier on the sender side to to avoid receiver tasks disappearing on us while still performing on the sender side wakeup. We lack however, the proper CPU-CPU interactions pairing on the receiver side which busy-waits for the message. Similarly, we do not need a full smp_mb, and can relax the semantics for the writer and reader sides of the message. This is safe as we are only ordering loads and stores to r_msg. And in both smp_wmb and smp_rmb, there are no stores after the calls _anyway_. This obviously applies for pipelined_send and expunge_all, for EIRDM when destroying a queue. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc,shm: move BUG_ON check into shm_lockDavidlohr Bueso
Upon every shm_lock call, we BUG_ON if an error was returned, indicating racing either in idr or in shm_destroy. Move this logic into the locking. [akpm@linux-foundation.org: simplify code] Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30ipc/util.c: use kvfree() in ipc_rcu_free()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-08ipc/mqueue: Implement lockless pipelined wakeupsDavidlohr Bueso
This patch moves the wakeup_process() invocation so it is not done under the info->lock by making use of a lockless wake_q. With this change, the waiter is woken up once it is STATE_READY and it does not need to loop on SMP if it is still in STATE_PENDING. In the timeout case we still need to grab the info->lock to verify the state. This change should also avoid the introduction of preempt_disable() in -rt which avoids a busy-loop which pools for the STATE_PENDING -> STATE_READY change if the waiter has a higher priority compared to the waker. Additionally, this patch micro-optimizes wq_sleep by using the cheaper cousin of set_current_state(TASK_INTERRUPTABLE) as we will block no matter what, thus get rid of the implied barrier. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: George Spelvin <linux@horizon.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Chris Mason <clm@fb.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: dave@stgolabs.net Link: http://lkml.kernel.org/r/1430748166.1940.17.camel@stgolabs.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
