commit 3f05317d9889ab75c7190dcd39491d2a97921984 upstream.
syzbot reported a use-after-free of shm_file_data(file)->file->f_op in
shm_get_unmapped_area(), called via sys_remap_file_pages().
Unfortunately it couldn't generate a reproducer, but I found a bug which
I think caused it. When remap_file_pages() is passed a full System V
shared memory segment, the memory is first unmapped, then a new map is
created using the ->vm_file. Between these steps, the shm ID can be
removed and reused for a new shm segment. But, shm_mmap() only checks
whether the ID is currently valid before calling the underlying file's
->mmap(); it doesn't check whether it was reused. Thus it can use the
wrong underlying file, one that was already freed.
Fix this by making the "outer" shm file (the one that gets put in
->vm_file) hold a reference to the real shm file, and by making
__shm_open() require that the file associated with the shm ID matches
the one associated with the "outer" file.
Taking the reference to the real shm file is needed to fully solve the
problem, since otherwise sfd->file could point to a freed file, which
then could be reallocated for the reused shm ID, causing the wrong shm
segment to be mapped (and without the required permission checks).
Commit 1ac0b6dec656 ("ipc/shm: handle removed segments gracefully in
shm_mmap()") almost fixed this bug, but it didn't go far enough because
it didn't consider the case where the shm ID is reused.
The following program usually reproduces this bug:
#include <stdlib.h>
#include <sys/shm.h>
#include <sys/syscall.h>
#include <unistd.h>
int main()
int is_parent = (fork() != 0);
srand(getpid());
for (;;) {
int id = shmget(0xF00F, 4096, IPC_CREAT|0700);
if (is_parent) {
void *addr = shmat(id, NULL, 0);
usleep(rand() % 50);
while (!syscall(__NR_remap_file_pages, addr, 4096, 0, 0, 0));
} else {
shmctl(id, IPC_RMID, NULL);
It causes the following NULL pointer dereference due to a 'struct file'
being used while it's being freed. (I couldn't actually get a KASAN
use-after-free splat like in the syzbot report. But I think it's
possible with this bug; it would just take a more extraordinary race...)
BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
PGD 0 P4D 0
Oops: 0000 [#1] SMP NOPTI
CPU: 9 PID: 258 Comm: syz_ipc Not tainted 4.16.0-05140-gf8cf2f16a7c95 #189
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014
RIP: 0010:d_inode include/linux/dcache.h:519 [inline]
RIP: 0010:touch_atime+0x25/0xd0 fs/inode.c:1724
Call Trace:
file_accessed include/linux/fs.h:2063 [inline]
shmem_mmap+0x25/0x40 mm/shmem.c:2149
call_mmap include/linux/fs.h:1789 [inline]
shm_mmap+0x34/0x80 ipc/shm.c:465
mmap_region+0x309/0x5b0 mm/mmap.c:1712
do_mmap+0x294/0x4a0 mm/mmap.c:1483
do_mmap_pgoff include/linux/mm.h:2235 [inline]
SYSC_remap_file_pages mm/mmap.c:2853 [inline]
SyS_remap_file_pages+0x232/0x310 mm/mmap.c:2769
do_syscall_64+0x64/0x1a0 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x42/0xb7
[ebiggers@google.com: add comment]
Link: http://lkml.kernel.org/r/20180410192850.235835-1-ebiggers3@gmail.com
Link: http://lkml.kernel.org/r/20180409043039.28915-1-ebiggers3@gmail.com
Reported-by: syzbot+d11f321e7f1923157eac80aa990b446596f46439@syzkaller.appspotmail.com
Fixes: c8d78c1823f4 ("mm: replace remap_file_pages() syscall with emulation")
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Acked-by: Davidlohr Bueso <dbueso@suse.de>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: <stable@vger.kernel.org>
commit 3d942ee079b917b24e2a0c5f18d35ac8ec9fee48 upstream.
If System V shmget/shmat operations are used to create a hugetlbfs
backed mapping, it is possible to munmap part of the mapping and split
the underlying vma such that it is not huge page aligned. This will
untimately result in the following BUG:
kernel BUG at /build/linux-jWa1Fv/linux-4.15.0/mm/hugetlb.c:3310!
Oops: Exception in kernel mode, sig: 5 [#1]
LE SMP NR_CPUS=2048 NUMA PowerNV
Modules linked in: kcm nfc af_alg caif_socket caif phonet fcrypt
CPU: 18 PID: 43243 Comm: trinity-subchil Tainted: G C E 4.15.0-10-generic #11-Ubuntu
NIP: c00000000036e764 LR: c00000000036ee48 CTR: 0000000000000009
REGS: c000003fbcdcf810 TRAP: 0700 Tainted: G C E (4.15.0-10-generic)
MSR: 9000000000029033 <SF,HV,EE,ME,IR,DR,RI,LE> CR: 24002222 XER: 20040000
CFAR: c00000000036ee44 SOFTE: 1
NIP __unmap_hugepage_range+0xa4/0x760
LR __unmap_hugepage_range_final+0x28/0x50
Call Trace:
0x7115e4e00000 (unreliable)
unmap_single_vma+0x11c/0x190
unmap_vmas+0x94/0x140
exit_mmap+0x9c/0x1d0
mmput+0xa8/0x1d0
do_exit+0x360/0xc80
do_group_exit+0x60/0x100
SyS_exit_group+0x24/0x30
system_call+0x58/0x6c
---[ end trace ee88f958a1c62605 ]---
This bug was introduced by commit 31383c6865a5 ("mm, hugetlbfs:
introduce ->split() to vm_operations_struct"). A split function was
added to vm_operations_struct to determine if a mapping can be split.
This was mostly for device-dax and hugetlbfs mappings which have
specific alignment constraints.
Mappings initiated via shmget/shmat have their original vm_ops
overwritten with shm_vm_ops. shm_vm_ops functions will call back to the
original vm_ops if needed. Add such a split function to shm_vm_ops.
Link: http://lkml.kernel.org/r/20180321161314.7711-1-mike.kravetz@oracle.com
Fixes: 31383c6865a5 ("mm, hugetlbfs: introduce ->split() to vm_operations_struct")
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Reported-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Reviewed-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Tested-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
commit 999898355e08ae3b92dfd0a08db706e0c6703d30 upstream.
When LONG_MIN is passed to msgrcv, one would expect to recieve any
message. But convert_mode does *msgtyp = -*msgtyp and -LONG_MIN is
undefined. In particular, with my gcc -LONG_MIN produces -LONG_MIN
again.
So handle this case properly by assigning LONG_MAX to *msgtyp if
LONG_MIN was specified as msgtyp to msgrcv.
This code:
long msg[] = { 100, 200 };
int m = msgget(IPC_PRIVATE, IPC_CREAT | 0644);
msgsnd(m, &msg, sizeof(msg), 0);
msgrcv(m, &msg, sizeof(msg), LONG_MIN, 0);
produces currently nothing:
msgget(IPC_PRIVATE, IPC_CREAT|0644) = 65538
msgsnd(65538, {100, "\310\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"}, 16, 0) = 0
msgrcv(65538, ...
Except a UBSAN warning:
UBSAN: Undefined behaviour in ipc/msg.c:745:13
negation of -9223372036854775808 cannot be represented in type 'long int':
With the patch, I see what I expect:
msgget(IPC_PRIVATE, IPC_CREAT|0644) = 0
msgsnd(0, {100, "\310\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"}, 16, 0) = 0
msgrcv(0, {100, "\310\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"}, 16, -9223372036854775808, 0) = 16
Link: http://lkml.kernel.org/r/20161024082633.10148-1-jslaby@suse.cz
commit f991af3daabaecff34684fd51fac80319d1baad1 upstream.
The retry logic for netlink_attachskb() inside sys_mq_notify()
is nasty and vulnerable:
1) The sock refcnt is already released when retry is needed
2) The fd is controllable by user-space because we already
release the file refcnt
so we when retry but the fd has been just closed by user-space
during this small window, we end up calling netlink_detachskb()
on the error path which releases the sock again, later when
the user-space closes this socket a use-after-free could be
triggered.
Setting 'sock' to NULL here should be sufficient to fix it.
Reported-by: GeneBlue <geneblue.mail@gmail.com>
commit 95e91b831f87ac8e1f8ed50c14d709089b4e01b8 upstream.
The issue is described here, with a nice testcase:
https://bugzilla.kernel.org/show_bug.cgi?id=192931
The problem is that shmat() calls do_mmap_pgoff() with MAP_FIXED, and
the address rounded down to 0. For the regular mmap case, the
protection mentioned above is that the kernel gets to generate the
address -- arch_get_unmapped_area() will always check for MAP_FIXED and
return that address. So by the time we do security_mmap_addr(0) things
get funky for shmat().
The testcase itself shows that while a regular user crashes, root will
not have a problem attaching a nil-page. There are two possible fixes
to this. The first, and which this patch does, is to simply allow root
to crash as well -- this is also regular mmap behavior, ie when hacking
up the testcase and adding mmap(... |MAP_FIXED). While this approach
is the safer option, the second alternative is to ignore SHM_RND if the
rounded address is 0, thus only having MAP_SHARED flags. This makes the
behavior of shmat() identical to the mmap() case. The downside of this
is obviously user visible, but does make sense in that it maintains
semantics after the round-down wrt 0 address and mmap.
Passes shm related ltp tests.
Link: http://lkml.kernel.org/r/1486050195-18629-1-git-send-email-dave@stgolabs.net
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reported-by: Gareth Evans <gareth.evans@contextis.co.uk>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
When kmem accounting switched from account by default to only account if
flagged by __GFP_ACCOUNT, IPC mqueue and messages was left out.
The production use case at hand is that mqueues should be customizable
via sysctls in Docker containers in a Kubernetes cluster. This can only
be safely allowed to the users of the cluster (without the risk that
they can cause resource shortage on a node, influencing other users'
containers) if all resources they control are bounded, i.e. accounted
for.
Link: http://lkml.kernel.org/r/1476806075-1210-1-git-send-email-arozansk@redhat.com
Signed-off-by: Aristeu Rozanski <arozansk@redhat.com>
Reported-by: Stefan Schimanski <sttts@redhat.com>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Stefan Schimanski <sttts@redhat.com>
In CONFIG_PREEMPT=n kernel a softlockup was observed while the for loop in
exit_sem. Apparently it's possible for the loop to take quite a long time
and it doesn't have a scheduling point in it. Since the codes is
executing under an rcu read section this may also cause rcu stalls, which
in turn block synchronize_rcu operations, which more or less de-stabilises
the whole system.
Fix this by introducing a cond_resched() at the beginning of the loop.
So this patch fixes the following:
NMI watchdog: BUG: soft lockup - CPU#10 stuck for 23s! [httpd:18119]
CPU: 10 PID: 18119 Comm: httpd Tainted: G O 4.4.20-clouder2 #6
Hardware name: Supermicro X10DRi/X10DRi, BIOS 1.1 04/14/2015
task: ffff88348d695280 ti: ffff881c95550000 task.ti: ffff881c95550000
RIP: 0010:[<ffffffff81614bc7>] [<ffffffff81614bc7>] _raw_spin_lock+0x17/0x30
RSP: 0018:ffff881c95553e40 EFLAGS: 00000246
RAX: 0000000000000000 RBX: ffff883161b1eea8 RCX: 000000000000000d
RDX: 0000000000000001 RSI: 000000000000000e RDI: ffff883161b1eea4
RBP: ffff881c95553ea0 R08: ffff881c95553e68 R09: ffff883fef376f88
R10: ffff881fffb58c20 R11: ffffea0072556600 R12: ffff883161b1eea0
R13: ffff88348d695280 R14: ffff883dec427000 R15: ffff8831621672a0
FS: 0000000000000000(0000) GS:ffff881fffb40000(0000) knlGS:0000000000000000
CR2: 00007f3b3723e020 CR3: 0000000001c0a000 CR4: 00000000001406e0
Call Trace:
? exit_sem+0x7c/0x280
do_exit+0x338/0xb40
do_group_exit+0x43/0xd0
SyS_exit_group+0x14/0x20
entry_SYSCALL_64_fastpath+0x16/0x6e
Link: http://lkml.kernel.org/r/1475154992-6363-1-git-send-email-kernel@kyup.com
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
Cc: Herton R. Krzesinski <herton@redhat.com>
Cc: Fabian Frederick <fabf@skynet.be>
Blocked tasks queued in q_senders waiting for their message to fit in the
queue are blindly awoken every time we think there's a remote chance this
might happen. This could cause numerous (and expensive -- thundering
herd-ish) bogus wakeups if the queue is still really full. Adding to the
scheduling cost/overhead, there's also the fact that we need to take the
ipc object lock and requeue ourselves in the q_senders list.
By keeping track of the blocked sender's message size, we can know
previously if the wakeup ought to occur or not. Otherwise, to maintain
the current wakeup order we just move it to the tail. This is exactly
what occurs right now if the sender needs to go back to sleep.
The case of EIDRM is left completely untouched, as we need to wakeup all
the tasks, and shouldn't be playing games in the first place.
This patch was seen to save on the 'msgctl10' ltp testcase ~15% in context
switches (avg out of ten runs). Although these tests are really about
functionality (as opposed to performance), is does show the direct
benefits of the optimization.
Link: http://lkml.kernel.org/r/1469748819-19484-6-git-send-email-dave@stgolabs.net
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
... 'tis annoying.
Link: http://lkml.kernel.org/r/1469748819-19484-4-git-send-email-dave@stgolabs.net
Signed-off-by: Davidlohr Bueso <dave@stgolabs.net>
Currently the use of wake_qs in sysv msg queues are only for the receiver
tasks that are blocked on the queue. But blocked sender tasks (due to
queue size constraints) still are awoken with the ipc object lock held,
which can be a problem particularly for small sized queues and far from
gracious for -rt (just like it was for the receiver side).
The paths that actually wakeup a sender are obviously related to when we
are either getting rid of the queue or after (some) space is freed-up
after a receiver takes the msg (msgrcv). Furthermore, with the exception
of msgrcv, we can always piggy-back on expunge_all that has its own tasks
lined-up for waking. Finally, upon unlinking the message, it should be no
problem delaying the wakeups a bit until after we've released the lock.
Link: http://lkml.kernel.org/r/1469748819-19484-3-git-send-email-dave@stgolabs.net
This patch moves the wakeup_process() invocation so it is not done under
the ipc global lock by making use of a lockless wake_q. With this change,
the waiter is woken up once the message has been assigned and it does not
need to loop on SMP if the message points to NULL. In the signal case we
still need to check the pointer under the lock to verify the state.
This change should also avoid the introduction of preempt_disable() in -RT
which avoids a busy-loop which pools for the NULL -> !NULL change if the
waiter has a higher priority compared to the waker.
By making use of wake_qs, the logic of sysv msg queues is greatly
simplified (and very well suited as we can batch lockless wakeups),
particularly around the lockless receive algorithm.
This has been tested with Manred's pmsg-shared tool on a "AMD A10-7800
Radeon R7, 12 Compute Cores 4C+8G":
test | before | after | diff
pmsg-shared 8 60 | 19,347,422 | 30,442,191 | + ~57.34 %
pmsg-shared 4 60 | 21,367,197 | 35,743,458 | + ~67.28 %
pmsg-shared 2 60 | 22,884,224 | 24,278,200 | + ~6.09 %
Link: http://lkml.kernel.org/r/1469748819-19484-2-git-send-email-dave@stgolabs.net
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Commit 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()") introduced a
race:
sem_lock has a fast path that allows parallel simple operations.
There are two reasons why a simple operation cannot run in parallel:
- a non-simple operations is ongoing (sma->sem_perm.lock held)
- a complex operation is sleeping (sma->complex_count != 0)
As both facts are stored independently, a thread can bypass the current
checks by sleeping in the right positions. See below for more details
(or kernel bugzilla 105651).
The patch fixes that by creating one variable (complex_mode)
that tracks both reasons why parallel operations are not possible.
The patch also updates stale documentation regarding the locking.
With regards to stable kernels:
The patch is required for all kernels that include the
commit 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()") (3.10?)
The alternative is to revert the patch that introduced the race.
The patch is safe for backporting, i.e. it makes no assumptions
about memory barriers in spin_unlock_wait().
Background:
Here is the race of the current implementation:
Thread A: (simple op)
- does the first "sma->complex_count == 0" test
Thread B: (complex op)
- does sem_lock(): This includes an array scan. But the scan can't
find Thread A, because Thread A does not own sem->lock yet.
- the thread does the operation, increases complex_count,
drops sem_lock, sleeps
Thread A:
- spin_lock(&sem->lock), spin_is_locked(sma->sem_perm.lock)
- sleeps before the complex_count test
Thread C: (complex op)
- does sem_lock (no array scan, complex_count==1)
- wakes up Thread B.
- decrements complex_count
Thread A:
- does the complex_count test
Bug:
Now both thread A and thread C operate on the same array, without
any synchronization.
Fixes: 6d07b68ce16a ("ipc/sem.c: optimize sem_lock()")
Link: http://lkml.kernel.org/r/1469123695-5661-1-git-send-email-manfred@colorfullife.com
Reported-by: <felixh@informatik.uni-bremen.de>
Cc: <1vier1@web.de>
Cc: <stable@vger.kernel.org> [3.10+]
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
Each namespace has an owning user namespace and now there is not way
to discover these relationships.
Pid and user namepaces are hierarchical. There is no way to discover
parent-child relationships too.
Why we may want to know relationships between namespaces?
One use would be visualization, in order to understand the running
system. Another would be to answer the question: what capability does
process X have to perform operations on a resource governed by namespace
Y?
One more use-case (which usually called abnormal) is checkpoint/restart.
In CRIU we are going to dump and restore nested namespaces.
There [1] was a discussion about which interface to choose to determing
relationships between namespaces.
Eric suggested to add two ioctl-s [2]:
> Grumble, Grumble. I think this may actually a case for creating ioctls
> for these two cases. Now that random nsfs file descriptors are bind
> mountable the original reason for using proc files is not as pressing.
> One ioctl for the user namespace that owns a file descriptor.
> One ioctl for the parent namespace of a namespace file descriptor.
Here is an implementaions of these ioctl-s.
$ man man7/namespaces.7
Since Linux 4.X, the following ioctl(2) calls are supported for
namespace file descriptors. The correct syntax is:
fd = ioctl(ns_fd, ioctl_type);
where ioctl_type is one of the following:
NS_GET_USERNS
Returns a file descriptor that refers to an owning user names‐
pace.
NS_GET_PARENT
Returns a file descriptor that refers to a parent namespace.
This ioctl(2) can be used for pid and user namespaces. For
user namespaces, NS_GET_PARENT and NS_GET_USERNS have the same
meaning.
In addition to generic ioctl(2) errors, the following specific ones
can occur:
EINVAL NS_GET_PARENT was called for a nonhierarchical namespace.
EPERM The requested namespace is outside of the current namespace
scope.
[1] https://lkml.org/lkml/2016/7/6/158
[2] https://lkml.org/lkml/2016/7/9/101
Changes for v2:
* don't return ENOENT for init_user_ns and init_pid_ns. There is nothing
outside of the init namespace, so we can return EPERM in this case too.
> The fewer special cases the easier the code is to get
> correct, and the easier it is to read. // Eric
Changes for v3:
* rename ns->get_owner() to ns->owner(). get_* usually means that it
grabs a reference.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com>
Cc: "W. Trevor King" <wking@tremily.us>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Return -EPERM if an owning user namespace is outside of a process
current user namespace.
v2: In a first version ns_get_owner returned ENOENT for init_user_ns.
This special cases was removed from this version. There is nothing
outside of init_user_ns, so we can return EPERM.
v3: rename ns->get_owner() to ns->owner(). get_* usually means that it
grabs a reference.
Acked-by: Serge Hallyn <serge@hallyn.com>
Signed-off-by: Andrei Vagin <avagin@openvz.org>
The current error codes returned when a the per user per user
namespace limit are hit (EINVAL, EUSERS, and ENFILE) are wrong. I
asked for advice on linux-api and it we made clear that those were
the wrong error code, but a correct effor code was not suggested.
The best general error code I have found for hitting a resource limit
is ENOSPC. It is not perfect but as it is unambiguous it will serve
until someone comes up with a better error code.
Write-only variable.
Link: http://lkml.kernel.org/r/20160708214356.GA6785@p183.telecom.by
Commit 53dad6d3a8e5 ("ipc: fix race with LSMs") updated ipc_rcu_putref()
to receive rcu freeing function but used generic ipc_rcu_free() instead
of msg_rcu_free() which does security cleaning.
Running LTP msgsnd06 with kmemleak gives the following:
cat /sys/kernel/debug/kmemleak
unreferenced object 0xffff88003c0a11f8 (size 8):
comm "msgsnd06", pid 1645, jiffies 4294672526 (age 6.549s)
hex dump (first 8 bytes):
1b 00 00 00 01 00 00 00 ........
backtrace:
kmemleak_alloc+0x23/0x40
kmem_cache_alloc_trace+0xe1/0x180
selinux_msg_queue_alloc_security+0x3f/0xd0
security_msg_queue_alloc+0x2e/0x40
newque+0x4e/0x150
ipcget+0x159/0x1b0
SyS_msgget+0x39/0x40
entry_SYSCALL_64_fastpath+0x13/0x8f
Manfred Spraul suggested to fix sem.c as well and Davidlohr Bueso to
only use ipc_rcu_free in case of security allocation failure in newary()
Fixes: 53dad6d3a8e ("ipc: fix race with LSMs")
Link: http://lkml.kernel.org/r/1470083552-22966-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: <stable@vger.kernel.org> [3.12+]
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull userns vfs updates from Eric Biederman:
"This tree contains some very long awaited work on generalizing the
user namespace support for mounting filesystems to include filesystems
with a backing store. The real world target is fuse but the goal is
to update the vfs to allow any filesystem to be supported. This
patchset is based on a lot of code review and testing to approach that
goal.
While looking at what is needed to support the fuse filesystem it
became clear that there were things like xattrs for security modules
that needed special treatment. That the resolution of those concerns
would not be fuse specific. That sorting out these general issues
made most sense at the generic level, where the right people could be
drawn into the conversation, and the issues could be solved for
everyone.
At a high level what this patchset does a couple of simple things:
- Add a user namespace owner (s_user_ns) to struct super_block.
- Teach the vfs to handle filesystem uids and gids not mapping into
to kuids and kgids and being reported as INVALID_UID and
INVALID_GID in vfs data structures.
By assigning a user namespace owner filesystems that are mounted with
only user namespace privilege can be detected. This allows security
modules and the like to know which mounts may not be trusted. This
also allows the set of uids and gids that are communicated to the
filesystem to be capped at the set of kuids and kgids that are in the
owning user namespace of the filesystem.
One of the crazier corner casees this handles is the case of inodes
whose i_uid or i_gid are not mapped into the vfs. Most of the code
simply doesn't care but it is easy to confuse the inode writeback path
so no operation that could cause an inode write-back is permitted for
such inodes (aka only reads are allowed).
This set of changes starts out by cleaning up the code paths involved
in user namespace permirted mounts. Then when things are clean enough
adds code that cleanly sets s_user_ns. Then additional restrictions
are added that are possible now that the filesystem superblock
contains owner information.
These changes should not affect anyone in practice, but there are some
parts of these restrictions that are changes in behavior.
- Andy's restriction on suid executables that does not honor the
suid bit when the path is from another mount namespace (think
/proc/[pid]/fd/) or when the filesystem was mounted by a less
privileged user.
- The replacement of the user namespace implicit setting of MNT_NODEV
with implicitly setting SB_I_NODEV on the filesystem superblock
instead.
Using SB_I_NODEV is a stronger form that happens to make this state
user invisible. The user visibility can be managed but it caused
problems when it was introduced from applications reasonably
expecting mount flags to be what they were set to.
There is a little bit of work remaining before it is safe to support
mounting filesystems with backing store in user namespaces, beyond
what is in this set of changes.
- Verifying the mounter has permission to read/write the block device
during mount.
- Teaching the integrity modules IMA and EVM to handle filesystems
mounted with only user namespace root and to reduce trust in their
security xattrs accordingly.
- Capturing the mounters credentials and using that for permission
checks in d_automount and the like. (Given that overlayfs already
does this, and we need the work in d_automount it make sense to
generalize this case).
Furthermore there are a few changes that are on the wishlist:
- Get all filesystems supporting posix acls using the generic posix
acls so that posix_acl_fix_xattr_from_user and
posix_acl_fix_xattr_to_user may be removed. [Maintainability]
- Reducing the permission checks in places such as remount to allow
the superblock owner to perform them.
- Allowing the superblock owner to chown files with unmapped uids and
gids to something that is mapped so the files may be treated
normally.
I am not considering even obvious relaxations of permission checks
until it is clear there are no more corner cases that need to be
locked down and handled generically.
Many thanks to Seth Forshee who kept this code alive, and putting up
with me rewriting substantial portions of what he did to handle more
corner cases, and for his diligent testing and reviewing of my
changes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (30 commits)
fs: Call d_automount with the filesystems creds
fs: Update i_[ug]id_(read|write) to translate relative to s_user_ns
evm: Translate user/group ids relative to s_user_ns when computing HMAC
dquot: For now explicitly don't support filesystems outside of init_user_ns
quota: Handle quota data stored in s_user_ns in quota_setxquota
quota: Ensure qids map to the filesystem
vfs: Don't create inodes with a uid or gid unknown to the vfs
vfs: Don't modify inodes with a uid or gid unknown to the vfs
cred: Reject inodes with invalid ids in set_create_file_as()
fs: Check for invalid i_uid in may_follow_link()
vfs: Verify acls are valid within superblock's s_user_ns.
userns: Handle -1 in k[ug]id_has_mapping when !CONFIG_USER_NS
fs: Refuse uid/gid changes which don't map into s_user_ns
selinux: Add support for unprivileged mounts from user namespaces
Smack: Handle labels consistently in untrusted mounts
Smack: Add support for unprivileged mounts from user namespaces
fs: Treat foreign mounts as nosuid
fs: Limit file caps to the user namespace of the super block
userns: Remove the now unnecessary FS_USERNS_DEV_MOUNT flag
userns: Remove implicit MNT_NODEV fragility.
We are going to need to call shmem_charge() under tree_lock to get
accoutning right on collapse of small tmpfs pages into a huge one.
The problem is that tree_lock is irq-safe and lockdep is not happy, that
we take irq-unsafe lock under irq-safe[1].
Let's convert the lock to irq-safe.
[1] https://gist.github.com/kiryl/80c0149e03ed35dfaf26628b8e03cdbc
Link: http://lkml.kernel.org/r/1466021202-61880-34-git-send-email-kirill.shutemov@linux.intel.com
Provide a shmem_get_unmapped_area method in file_operations, called at
mmap time to decide the mapping address. It could be conditional on
CONFIG_TRANSPARENT_HUGEPAGE, but save #ifdefs in other places by making
it unconditional.
shmem_get_unmapped_area() first calls the usual mm->get_unmapped_area
(which we treat as a black box, highly dependent on architecture and
config and executable layout). Lots of conditions, and in most cases it
just goes with the address that chose; but when our huge stars are
rightly aligned, yet that did not provide a suitable address, go back to
ask for a larger arena, within which to align the mapping suitably.
There have to be some direct calls to shmem_get_unmapped_area(), not via
the file_operations: because of the way shmem_zero_setup() is called to
create a shmem object late in the mmap sequence, when MAP_SHARED is
requested with MAP_ANONYMOUS or /dev/zero. Though this only matters
when /proc/sys/vm/shmem_huge has been set.
Link: http://lkml.kernel.org/r/1466021202-61880-29-git-send-email-kirill.shutemov@linux.intel.com
Introduce a function may_open_dev that tests MNT_NODEV and a new
superblock flab SB_I_NODEV. Use this new function in all of the
places where MNT_NODEV was previously tested.
Add the new SB_I_NODEV s_iflag to proc, sysfs, and mqueuefs as those
filesystems should never support device nodes, and a simple superblock
flags makes that very hard to get wrong. With SB_I_NODEV set if any
device nodes somehow manage to show up on on a filesystem those
device nodes will be unopenable.
Acked-by: Seth Forshee <seth.forshee@canonical.com>
Set SB_I_NOEXEC on mqueuefs to ensure small implementation mistakes
do not result in executable on mqueuefs by accident.
Today what is normally called data (the mount options) is not passed
to fill_super through mount_ns.
Pass the mount options and the namespace separately to mount_ns so
that filesystems such as proc that have mount options, can use
mount_ns.
Pass the user namespace to mount_ns so that the standard permission
check that verifies the mounter has permissions over the namespace can
be performed in mount_ns instead of in each filesystems .mount method.
Thus removing the duplication between mqueuefs and proc in terms of
permission checks. The extra permission check does not currently
affect the rpc_pipefs filesystem and the nfsd filesystem as those
filesystems do not currently allow unprivileged mounts. Without
unpvileged mounts it is guaranteed that the caller has already passed
capable(CAP_SYS_ADMIN) which guarantees extra permission check will
pass.
Update rpc_pipefs and the nfsd filesystem to ensure that the network
namespace reference is always taken in fill_super and always put in kill_sb
so that the logic is simpler and so that errors originating inside of
fill_super do not cause a network namespace leak.
Allow the ipc namespace initialization code to depend on ns->user_ns
being set during initialization.
In particular this allows mq_init_ns to use ns->user_ns for permission
checks and initializating s_user_ns while the the mq filesystem is
being mounted.
Suggested-by: Seth Forshee <seth.forshee@canonical.com>
With the modified semantics of spin_unlock_wait() a number of
explicit barriers can be removed. Also update the comment for the
do_exit() usecase, as that was somewhat stale/obscure.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Introduce smp_acquire__after_ctrl_dep(), this construct is not
uncommon, but the lack of this barrier is.
Use it to better express smp_rmb() uses in WRITE_ONCE(), the IPC
semaphore code and the qspinlock code.
shmat and shmdt rely on mmap_sem for write. If the waiting task gets
killed by the oom killer it would block oom_reaper from asynchronous
address space reclaim and reduce the chances of timely OOM resolving.
Wait for the lock in the killable mode and return with EINTR if the task
got killed while waiting.
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
As indicated by bug#112271, Linux sets the sempid value upon semctl, and
not only for semop calls. However, within semctl we only do this for
SETVAL, leaving SETALL without updating the field, and therefore rather
inconsistent behavior when compared to other Unices.
There is really no documentation regarding this and therefore users
should not make assumptions. With this patch, along with updating
semctl.2 manpages, this scenario should become less ambiguous As such,
set sempid on SETALL cmd.
Also update some in-code documentation, specifying where the sempid is
set.
Passes ltp and custom testcase where a child (fork) does SETALL to the
set.
Reported-by: Philip Semanchuk <linux_kernel.20.ick@spamgourmet.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
remap_file_pages(2) emulation can reach file which represents removed
IPC ID as long as a memory segment is mapped. It breaks expectations of
IPC subsystem.
Test case (rewritten to be more human readable, originally autogenerated
by syzkaller[1]):
#define _GNU_SOURCE
#include <stdlib.h>
#include <sys/ipc.h>
#include <sys/mman.h>
#define PAGE_SIZE 4096
int main()
int id;
void *p;
id = shmget(IPC_PRIVATE, 3 * PAGE_SIZE, 0);
p = shmat(id, NULL, 0);
remap_file_pages(p, 3 * PAGE_SIZE, 0, 7, 0);
return 0;
The patch changes shm_mmap() and code around shm_lock() to propagate
locking error back to caller of shm_mmap().
[1] http://github.com/google/syzkaller
Pull final vfs updates from Al Viro:
- The ->i_mutex wrappers (with small prereq in lustre)
- a fix for too early freeing of symlink bodies on shmem (they need to
be RCU-delayed) (-stable fodder)
- followup to dedupe stuff merged this cycle
vfs: abort dedupe loop if fatal signals are pending
make sure that freeing shmem fast symlinks is RCU-delayed
wrappers for ->i_mutex access
lustre: remove unused declaration
There are many locations that do
if (memory_was_allocated_by_vmalloc)
vfree(ptr);
else
kfree(ptr);
but kvfree() can handle both kmalloc()ed memory and vmalloc()ed memory
using is_vmalloc_addr(). Unless callers have special reasons, we can
replace this branch with kvfree(). Please check and reply if you found
problems.
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: Boris Petkov <bp@suse.de>
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Make is_file_shm_hugepages() return bool to improve readability due to
this particular function only using either one or zero as its return
value.
No functional change.
Signed-off-by: Yaowei Bai <baiyaowei@cmss.chinamobile.com>
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
d0edd8528362 ("ipc: convert invalid scenarios to use WARN_ON") relaxed the
nil dst parameter check, originally being a full BUG_ON. However, this
check seems quite unnecessary when the only purpose is for
ceckpoint/restore (MSG_COPY flag):
o The copy variable is set initially to nil, apparently as a way of
ensuring that prepare_copy is previously called. Which is in fact done,
unconditionally at the beginning of do_msgrcv.
o There is no concurrency with 'copy' (stack allocated in do_msgrcv).
Furthermore, any errors in 'copy' (and thus prepare_copy/copy_msg) should
always handled by IS_ERR() family. Therefore remove this check altogether
as it can never occur with the current users.
Cc: Stanislav Kinsbursky <skinsbursky@parallels.com>
As reported by Dmitry Vyukov, we really shouldn't do ipc_addid() before
having initialized the IPC object state. Yes, we initialize the IPC
object in a locked state, but with all the lockless RCU lookup work,
that IPC object lock no longer means that the state cannot be seen.
We already did this for the IPC semaphore code (see commit e8577d1f0329:
"ipc/sem.c: fully initialize sem_array before making it visible") but we
clearly forgot about msg and shm.
Cc: stable@vger.kernel.org
Considering Linus' past rants about the (ab)use of BUG in the kernel, I
took a look at how we deal with such calls in ipc. Given that any errors
or corruption in ipc code are most likely contained within the set of
processes participating in the broken mechanisms, there aren't really many
strong fatal system failure scenarios that would require a BUG call.
Also, if something is seriously wrong, ipc might not be the place for such
a BUG either.
1. For example, recently, a customer hit one of these BUG_ONs in shm
after failing shm_lock(). A busted ID imho does not merit a BUG_ON,
and WARN would have been better.
2. MSG_COPY functionality of posix msgrcv(2) for checkpoint/restore.
I don't see how we can hit this anyway -- at least it should be IS_ERR.
The 'copy' arg from do_msgrcv is always set by calling prepare_copy()
first and foremost. We could also probably drop this check altogether.
Either way, it does not merit a BUG_ON.
3. No ->fault() callback for the fs getting the corresponding page --
seems selfish to make the system unusable.
sem_lock() did not properly pair memory barriers:
!spin_is_locked() and spin_unlock_wait() are both only control barriers.
The code needs an acquire barrier, otherwise the cpu might perform read
operations before the lock test.
As no primitive exists inside <include/spinlock.h> and since it seems
noone wants another primitive, the code creates a local primitive within
ipc/sem.c.
With regards to -stable:
The change of sem_wait_array() is a bugfix, the change to sem_lock() is a
nop (just a preprocessor redefinition to improve the readability). The
bugfix is necessary for all kernels that use sem_wait_array() (i.e.:
starting from 3.10).
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Kirill Tkhai <ktkhai@parallels.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
After we acquire the sma->sem_perm lock in exit_sem(), we are protected
against a racing IPC_RMID operation. Also at that point, we are the last
user of sem_undo_list. Therefore it isn't required that we acquire or use
ulp->lock.
Signed-off-by: Herton R. Krzesinski <herton@redhat.com>
Acked-by: Manfred Spraul <manfred@colorfullife.com>
Cc: Rafael Aquini <aquini@redhat.com>
CC: Aristeu Rozanski <aris@redhat.com>
Cc: David Jeffery <djeffery@redhat.com>
set exits
The current semaphore code allows a potential use after free: in
exit_sem we may free the task's sem_undo_list while there is still
another task looping through the same semaphore set and cleaning the
sem_undo list at freeary function (the task called IPC_RMID for the same
semaphore set).
For example, with a test program [1] running which keeps forking a lot
of processes (which then do a semop call with SEM_UNDO flag), and with
the parent right after removing the semaphore set with IPC_RMID, and a
kernel built with CONFIG_SLAB, CONFIG_SLAB_DEBUG and
CONFIG_DEBUG_SPINLOCK, you can easily see something like the following
in the kernel log:
Slab corruption (Not tainted): kmalloc-64 start=ffff88003b45c1c0, len=64
000: 6b 6b 6b 6b 6b 6b 6b 6b 00 6b 6b 6b 6b 6b 6b 6b kkkkkkkk.kkkkkkk
010: ff ff ff ff 6b 6b 6b 6b ff ff ff ff ff ff ff ff ....kkkk........
Prev obj: start=ffff88003b45c180, len=64
000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ
010: ff ff ff ff ff ff ff ff c0 fb 01 37 00 88 ff ff ...........7....
Next obj: start=ffff88003b45c200, len=64
010: ff ff ff ff ff ff ff ff 68 29 a7 3c 00 88 ff ff ........h).<....
BUG: spinlock wrong CPU on CPU#2, test/18028
general protection fault: 0000 [#1] SMP
Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib]
CPU: 2 PID: 18028 Comm: test Not tainted 4.2.0-rc5+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014
RIP: spin_dump+0x53/0xc0
Call Trace:
spin_bug+0x30/0x40
do_raw_spin_unlock+0x71/0xa0
_raw_spin_unlock+0xe/0x10
freeary+0x82/0x2a0
? _raw_spin_lock+0xe/0x10
semctl_down.clone.0+0xce/0x160
? __do_page_fault+0x19a/0x430
? __audit_syscall_entry+0xa8/0x100
SyS_semctl+0x236/0x2c0
? syscall_trace_leave+0xde/0x130
entry_SYSCALL_64_fastpath+0x12/0x71
Code: 8b 80 88 03 00 00 48 8d 88 60 05 00 00 48 c7 c7 a0 2c a4 81 31 c0 65 8b 15 eb 40 f3 7e e8 08 31 68 00 4d 85 e4 44 8b 4b 08 74 5e <45> 8b 84 24 88 03 00 00 49 8d 8c 24 60 05 00 00 8b 53 04 48 89
RIP [<ffffffff810d6053>] spin_dump+0x53/0xc0
RSP <ffff88003750fd68>
---[ end trace 783ebb76612867a0 ]---
NMI watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [test:18053]
CPU: 3 PID: 18053 Comm: test Tainted: G D 4.2.0-rc5+ #1
RIP: native_read_tsc+0x0/0x20
Call Trace:
? delay_tsc+0x40/0x70
__delay+0xf/0x20
do_raw_spin_lock+0x96/0x140
sem_lock_and_putref+0x11/0x70
SYSC_semtimedop+0x7bf/0x960
? handle_mm_fault+0xbf6/0x1880
? dequeue_task_fair+0x79/0x4a0
? kfree_debugcheck+0x16/0x40
? do_audit_syscall_entry+0x66/0x70
? syscall_trace_enter_phase1+0x139/0x160
SyS_semtimedop+0xe/0x10
SyS_semop+0x10/0x20
Code: 47 10 83 e8 01 85 c0 89 47 10 75 08 65 48 89 3d 1f 74 ff 7e c9 c3 0f 1f 44 00 00 55 48 89 e5 e8 87 17 04 00 66 90 c9 c3 0f 1f 00 <55> 48 89 e5 0f 31 89 c1 48 89 d0 48 c1 e0 20 89 c9 48 09 c8 c9
Kernel panic - not syncing: softlockup: hung tasks
I wasn't able to trigger any badness on a recent kernel without the
proper config debugs enabled, however I have softlockup reports on some
kernel versions, in the semaphore code, which are similar as above (the
scenario is seen on some servers running IBM DB2 which uses semaphore
syscalls).
The patch here fixes the race against freeary, by acquiring or waiting
on the sem_undo_list lock as necessary (exit_sem can race with freeary,
while freeary sets un->semid to -1 and removes the same sem_undo from
list_proc or when it removes the last sem_undo).
After the patch I'm unable to reproduce the problem using the test case
[1].
[1] Test case used below:
#include <stdio.h>
#include <sys/types.h>
#include <sys/sem.h>
#include <sys/wait.h>
#include <stdlib.h>
#include <time.h>
#include <unistd.h>
#include <errno.h>
#define NSEM 1
#define NSET 5
int sid[NSET];
void thread()
struct sembuf op;
int s;
uid_t pid = getuid();
s = rand() % NSET;
op.sem_num = pid % NSEM;
op.sem_op = 1;
op.sem_flg = SEM_UNDO;
semop(sid[s], &op, 1);
exit(EXIT_SUCCESS);
void create_set()
int i, j;
pid_t p;
union {
int val;
struct semid_ds *buf;
unsigned short int *array;
struct seminfo *__buf;
} un;
/* Create and initialize semaphore set */
for (i = 0; i < NSET; i++) {
sid[i] = semget(IPC_PRIVATE , NSEM, 0644 | IPC_CREAT);
if (sid[i] < 0) {
perror("semget");
exit(EXIT_FAILURE);
un.val = 0;
for (j = 0; j < NSEM; j++) {
if (semctl(sid[i], j, SETVAL, un) < 0)
perror("semctl");
/* Launch threads that operate on semaphore set */
for (i = 0; i < NSEM * NSET * NSET; i++) {
p = fork();
if (p < 0)
perror("fork");
if (p == 0)
thread();
/* Free semaphore set */
if (semctl(sid[i], NSEM, IPC_RMID))
perror("IPC_RMID");
/* Wait for forked processes to exit */
while (wait(NULL)) {
if (errno == ECHILD)
break;
int main(int argc, char **argv)
pid_t p;
srand(time(NULL));
while (1) {
p = fork();
if (p < 0) {
perror("fork");
exit(EXIT_FAILURE);
if (p == 0) {
create_set();
goto end;
break;
end:
return 0;
[akpm@linux-foundation.org: use normal comment layout]
The shm implementation internally uses shmem or hugetlbfs inodes for shm
segments. As these inodes are never directly exposed to userspace and
only accessed through the shm operations which are already hooked by
security modules, mark the inodes with the S_PRIVATE flag so that inode
security initialization and permission checking is skipped.
This was motivated by the following lockdep warning:
[ INFO: possible circular locking dependency detected ]
4.2.0-0.rc3.git0.1.fc24.x86_64+debug #1 Tainted: G W
httpd/1597 is trying to acquire lock:
(&ids->rwsem){+++++.}, at: shm_close+0x34/0x130
but task is already holding lock:
(&mm->mmap_sem){++++++}, at: SyS_shmdt+0x4b/0x180
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #3 (&mm->mmap_sem){++++++}:
lock_acquire+0xc7/0x270
__might_fault+0x7a/0xa0
filldir+0x9e/0x130
xfs_dir2_block_getdents.isra.12+0x198/0x1c0 [xfs]
xfs_readdir+0x1b4/0x330 [xfs]
xfs_file_readdir+0x2b/0x30 [xfs]
iterate_dir+0x97/0x130
SyS_getdents+0x91/0x120
entry_SYSCALL_64_fastpath+0x12/0x76
-> #2 (&xfs_dir_ilock_class){++++.+}:
down_read_nested+0x57/0xa0
xfs_ilock+0x167/0x350 [xfs]
xfs_ilock_attr_map_shared+0x38/0x50 [xfs]
xfs_attr_get+0xbd/0x190 [xfs]
xfs_xattr_get+0x3d/0x70 [xfs]
generic_getxattr+0x4f/0x70
inode_doinit_with_dentry+0x162/0x670
sb_finish_set_opts+0xd9/0x230
selinux_set_mnt_opts+0x35c/0x660
superblock_doinit+0x77/0xf0
delayed_superblock_init+0x10/0x20
iterate_supers+0xb3/0x110
selinux_complete_init+0x2f/0x40
security_load_policy+0x103/0x600
sel_write_load+0xc1/0x750
__vfs_write+0x37/0x100
vfs_write+0xa9/0x1a0
SyS_write+0x58/0xd0
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Reported-by: Morten Stevens <mstevens@fedoraproject.org>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Eric Paris <eparis@redhat.com>
account
A while back, the message queue implementation in the kernel was
improved to use btrees to speed up retrieval of messages, in commit
d6629859b36d ("ipc/mqueue: improve performance of send/recv").
That patch introducing the improved kernel handling of message queues
(using btrees) has, as a by-product, changed the meaning of the QSIZE
field in the pseudo-file created for the queue. Before, this field
reflected the size of the user-data in the queue. Since, it also takes
kernel data structures into account. For example, if 13 bytes of user
data are in the queue, on my machine the file reports a size of 61
bytes.
There was some discussion on this topic before (for example
https://lkml.org/lkml/2014/10/1/115). Commenting on a th lkml, Michael
Kerrisk gave the following background
(https://lkml.org/lkml/2015/6/16/74):
The pseudofiles in the mqueue filesystem (usually mounted at
/dev/mqueue) expose fields with metadata describing a message
queue. One of these fields, QSIZE, as originally implemented,
showed the total number of bytes of user data in all messages in
the message queue, and this feature was documented from the
beginning in the mq_overview(7) page. In 3.5, some other (useful)
work happened to break the user-space API in a couple of places,
including the value exposed via QSIZE, which now includes a measure
of kernel overhead bytes for the queue, a figure that renders QSIZE
useless for its original purpose, since there's no way to deduce
the number of overhead bytes consumed by the implementation.
(The other user-space breakage was subsequently fixed.)
This patch removes the accounting of kernel data structures in the
queue. Reporting the size of these data-structures in the QSIZE field
was a breaking change (see Michael's comment above). Without the QSIZE
field reporting the total size of user-data in the queue, there is no
way to deduce this number.
It should be noted that the resource limit RLIMIT_MSGQUEUE is counted
against the worst-case size of the queue (in both the old and the new
implementation). Therefore, the kernel overhead accounting in QSIZE is
not necessary to help the user understand the limitations RLIMIT imposes
on the processes.
Signed-off-by: Marcus Gelderie <redmnic@gmail.com>
Acked-by: Doug Ledford <dledford@redhat.com>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: John Duffy <jb_duffy@btinternet.com>
Cc: Arto Bendiken <arto@bendiken.net>
In ipc_obtain_object_check we return -EIDRM when a bogus sequence number
is detected via ipc_checkid, while the ipc manpages state the following
return codes for such errors:
EIDRM <ID> points to a removed identifier.
EINVAL Invalid <ID> value, or unaligned, etc.
EIDRM should only be returned upon a RMID call (->deleted check), and thus
return EINVAL for wrong seq. This difference in semantics has also caused
real bugs, ie: https://bugzilla.redhat.com/show_bug.cgi?id=246509
The ipc_lock helper is used by all forms of sysv ipc to acquire the ipc
object's spinlock. Upon error (bogus identifier), we always return
-EINVAL, whether the problem be in the idr path or because we raced with a
task performing RMID. For the later, however, all ipc related manpages,
state the that for:
And return:
Which (EINVAL) should only return once the ipc resource is deleted. For
all types of ipc this is done immediately upon a RMID command. However,
shared memory behaves slightly different as it can merely mark a segment
for deletion, and delay the actual freeing until there are no more active
consumers. Per shmctl(IPC_RMID) manpage:
Mark the segment to be destroyed. The segment will only actually
be destroyed after the last process detaches it (i.e., when the
shm_nattch member of the associated structure shmid_ds is zero).
Unlike ipc_lock, paths that behave "correctly", at least per the manpage,
involve controlling the ipc resource via *ctl(), doing the exact same
validity check as ipc_lock after right acquiring the spinlock:
if (!ipc_valid_object()) {
err = -EIDRM;
goto out_unlock;
Thus make ipc_lock consistent with the rest of ipc code and return -EIDRM
in ipc_lock when !ipc_valid_object().
... to ipc_obtain_object_idr, which is more meaningful and makes the code
slightly easier to follow.
We currently use a full barrier on the sender side to to avoid receiver
tasks disappearing on us while still performing on the sender side wakeup.
We lack however, the proper CPU-CPU interactions pairing on the receiver
side which busy-waits for the message. Similarly, we do not need a full
smp_mb, and can relax the semantics for the writer and reader sides of the
message. This is safe as we are only ordering loads and stores to r_msg.
And in both smp_wmb and smp_rmb, there are no stores after the calls
_anyway_.
This obviously applies for pipelined_send and expunge_all, for EIRDM when
destroying a queue.
