path: root/kernel/Kconfig.hz
2005-06-23[PATCH] i386: Selectable Frequency of the Timer InterruptChristoph Lameter
Make the timer frequency selectable. The timer interrupt may cause bus and memory contention in large NUMA systems since the interrupt occurs on each processor HZ times per second. Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
