commit 65ecc14a30ad21bed9aabdfd6a2ae1a1aaaa6a00 upstream, tweaked to get
it to apply to 2.6.27
For some unknown reason at Steven Rostedt added in disabling of the SPE
instruction generation for e500 based PPC cores in commit
6ec562328fda585be2d7f472cfac99d3b44d362a.
We are removing it because:
1. It generates e500 kernels that don't work
2. its not the correct set of flags to do this
3. we handle this in the arch/powerpc/Makefile already
4. its unknown in talking to Steven why he did this
Tested-and-Acked-by: Steven Rostedt <srostedt@redhat.com>
arch/x86/Kconfig
Build kernel/profile.o only if CONFIG_PROFILING is enabled.
This makes CONFIG_PROFILING=n kernels smaller.
As a bonus, some profile_tick() calls and one branch from schedule() are
now eliminated with CONFIG_PROFILING=n (but I doubt these are
measurable effects).
This patch changes the effects of CONFIG_PROFILING=n, but I don't think
having more than two choices would be the better choice.
This patch also adds the name of the first parameter to the prototypes
of profile_{hits,tick}() since I anyway had to add them for the dummy
functions.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
kernel/Makefile
the removal of -mno-spe in the !ftrace case was not intended.
do not trace scheduler functions - it's still a bit fragile
and can lock up with:
http://redhat.com/~mingo/misc/config-Thu_Jul_17_13_34_52_CEST_2008
arch/powerpc/Kconfig
arch/s390/kernel/time.c
arch/x86/kernel/apic_32.c
arch/x86/kernel/cpu/perfctr-watchdog.c
arch/x86/kernel/i8259_64.c
arch/x86/kernel/ldt.c
arch/x86/kernel/nmi_64.c
arch/x86/kernel/smpboot.c
arch/x86/xen/smp.c
include/asm-x86/hw_irq_32.h
include/asm-x86/hw_irq_64.h
include/asm-x86/mach-default/irq_vectors.h
include/asm-x86/mach-voyager/irq_vectors.h
include/asm-x86/smp.h
kernel/Makefile
arch/x86/kernel/entry_32.S
arch/x86/kernel/process_32.c
arch/x86/kernel/process_64.c
arch/x86/lib/Makefile
include/asm-x86/irqflags.h
kernel/Makefile
kernel/sched.c
After the sched_clock code has been removed from sched.c we can now trace
the scheduler. The scheduler has a lot of functions that would be worth
tracing.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Currently x86_32, sh and cris-v32 provide per-device coherent dma
memory allocator.
However their implementation is nearly identical. Refactor out
common code to be reused by them.
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
This adds kernel/smp.c which contains helpers for IPI function calls. In
addition to supporting the existing smp_call_function() in a more efficient
manner, it also adds a more scalable variant called smp_call_function_single()
for calling a given function on a single CPU only.
The core of this is based on the x86-64 patch from Nick Piggin, lots of
changes since then. "Alan D. Brunelle" <Alan.Brunelle@hp.com> has
contributed lots of fixes and suggestions as well. Also thanks to
Paul E. McKenney <paulmck@linux.vnet.ibm.com> for reviewing RCU usage
and getting rid of the data allocation fallback deadlock.
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
kernel/cpu.c seems a more logical place for those maps since they do not really
have much to do with the scheduler these days.
kernel/cpu.c is now built for the UP kernel too, but it does not affect the size
the kernel sections.
$ size vmlinux
before
3313797 307060 310352 3931209 3bfc49 vmlinux
after
Signed-off-by: Max Krasnyansky <maxk@qualcomm.com>
Cc: pj@sgi.com
Cc: menage@google.com
Cc: rostedt@goodmis.org
Cc: mingo@elte.hu
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
The current code use a linear algorithm which causes scaling issues
on larger SMP machines. This patch replaces that algorithm with a
2-dimensional bitmap to reduce latencies in the wake-up path.
Signed-off-by: Gregory Haskins <ghaskins@novell.com>
This patch removes the Makefile turd and uses the nice CFLAGS_REMOVE macro
in the kernel directory.
This patch removes the "notrace" annotation from lockdep and adds the debugging
files in the kernel director to those that should not be compiled with
"-pg" mcount tracing.
This patch adds the latency tracer infrastructure. This patch
does not add anything that will select and turn it on, but will
be used by later patches.
If it were to be compiled, it would add the following files
to the debugfs:
The root tracing directory:
/debugfs/tracing/
This patch also adds the following files:
available_tracers
list of available tracers. Currently no tracers are
available. Looking into this file only shows
"none" which is used to unregister all tracers.
current_tracer
The trace that is currently active. Empty on start up.
To switch to a tracer simply echo one of the tracers that
are listed in available_tracers:
example: (used with later patches)
echo function > /debugfs/tracing/current_tracer
To disable the tracer:
echo disable > /debugfs/tracing/current_tracer
tracing_enabled
echoing "1" into this file starts the ftrace function tracing
(if sysctl kernel.ftrace_enabled=1)
echoing "0" turns it off.
latency_trace
This file is readonly and holds the result of the trace.
trace
This file outputs a easier to read version of the trace.
iter_ctrl
Controls the way the output of traces look.
So far there's two controls:
echoing in "symonly" will only show the kallsyms variables
without the addresses (if kallsyms was configured)
echoing in "verbose" will change the output to show
a lot more data, but not very easy to understand by
humans.
echoing in "nosymonly" turns off symonly.
echoing in "noverbose" turns off verbose.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
If CONFIG_FTRACE is selected and /proc/sys/kernel/ftrace_enabled is
set to a non-zero value the ftrace routine will be called everytime
we enter a kernel function that is not marked with the "notrace"
attribute.
The ftrace routine will then call a registered function if a function
happens to be registered.
[ This code has been highly hacked by Steven Rostedt and Ingo Molnar,
so don't blame Arnaldo for all of this ;-) ]
Update:
It is now possible to register more than one ftrace function.
If only one ftrace function is registered, that will be the
function that ftrace calls directly. If more than one function
is registered, then ftrace will call a function that will loop
through the functions to call.
this replaces the rq->clock stuff (and possibly cpu_clock()).
- architectures that have an 'imperfect' hardware clock can set
CONFIG_HAVE_UNSTABLE_SCHED_CLOCK
- the 'jiffie' window might be superfulous when we update tick_gtod
before the __update_sched_clock() call in sched_clock_tick()
- cpu_clock() might be implemented as:
sched_clock_cpu(smp_processor_id())
if the accuracy proves good enough - how far can TSC drift in a
single jiffie when considering the filtering and idle hooks?
[ mingo@elte.hu: various fixes and cleanups ]
Disable sysctl_check.c for embedded targets. This saves about about 11 kB
in .text and another 11 kB in .data on a PXA255 embedded platform.
Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-kgdb:
kgdb: always use icache flush for sw breakpoints
kgdb: fix SMP NMI kgdb_handle_exception exit race
kgdb: documentation fixes
kgdb: allow static kgdbts boot configuration
kgdb: add documentation
kgdb: Kconfig fix
kgdb: add kgdb internal test suite
kgdb: fix several kgdb regressions
kgdb: kgdboc pl011 I/O module
kgdb: fix optional arch functions and probe_kernel_*
kgdb: add x86 HW breakpoints
kgdb: print breakpoint removed on exception
kgdb: clocksource watchdog
kgdb: fix NMI hangs
kgdb: fix kgdboc dynamic module configuration
kgdb: document parameters
x86: kgdb support
consoles: polling support, kgdboc
kgdb: core
uaccess: add probe_kernel_write()
kgdb core code. Handles the protocol and the arch details.
[ mingo@elte.hu: heavily modified, simplified and cleaned up. ]
[ xemul@openvz.org: use find_task_by_pid_ns ]
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Signed-off-by: Jan Kiszka <jan.kiszka@web.de>
Semaphores are no longer performance-critical, so a generic C
implementation is better for maintainability, debuggability and
extensibility. Thanks to Peter Zijlstra for fixing the lockdep
warning. Thanks to Harvey Harrison for pointing out that the
unlikely() was unnecessary.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
When the conversion factor between jiffies and milli- or microseconds is
not a single multiply or divide, as for the case of HZ == 300, we currently
do a multiply followed by a divide. The intervening result, however, is
subject to overflows, especially since the fraction is not simplified (for
HZ == 300, we multiply by 300 and divide by 1000).
This is exposed to the user when passing a large timeout to poll(), for
example.
This patch replaces the multiply-divide with a reciprocal multiplication on
32-bit platforms. When the input is an unsigned long, there is no portable
way to do this on 64-bit platforms there is no portable way to do this
since it requires a 128-bit intermediate result (which gcc does support on
64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but
since the output is a 32-bit integer in the cases affected, just simplify
the multiply-divide (*3/10 instead of *300/1000).
The reciprocal multiply used can have off-by-one errors in the upper half
of the valid output range. This could be avoided at the expense of having
to deal with a potential 65-bit intermediate result. Since the intent is
to avoid overflow problems and most of the other time conversions are only
semiexact, the off-by-one errors were considered an acceptable tradeoff.
At Ralf Baechle's suggestion, this version uses a Perl script to compute
the necessary constants. We already have dependencies on Perl for kernel
compiles. This does, however, require the Perl module Math::BigInt, which
is included in the standard Perl distribution starting with version 5.8.0.
In order to support older versions of Perl, include a table of canned
constants in the script itself, and structure the script so that
Math::BigInt isn't required if pulling values from said table.
Running the script requires that the HZ value is available from the
Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the
architectures which didn't already have it (alpha, cris, frv, h8300, m32r,
m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or
sh64 architectures, since Paul Mundt has dealt with those separately in the
sh tree.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Ralf Baechle <ralf@linux-mips.org>,
Cc: Sam Ravnborg <sam@ravnborg.org>,
Cc: Paul Mundt <lethal@linux-sh.org>,
Cc: Richard Henderson <rth@twiddle.net>,
Cc: Michael Starvik <starvik@axis.com>,
Cc: David Howells <dhowells@redhat.com>,
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>,
Cc: Hirokazu Takata <takata@linux-m32r.org>,
Cc: Geert Uytterhoeven <geert@linux-m68k.org>,
Cc: Roman Zippel <zippel@linux-m68k.org>,
Cc: William L. Irwin <sparclinux@vger.kernel.org>,
Cc: Chris Zankel <chris@zankel.net>,
Cc: H. Peter Anvin <hpa@zytor.com>,
Cc: Jan Engelhardt <jengelh@computergmbh.de>
Just like with the user namespaces, move the namespace management code into
the separate .c file and mark the (already existing) PID_NS option as "depend
on NAMESPACES"
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Make the user_namespace.o compilation depend on this option and move the
init_user_ns into user.c file to make the kernel compile and work without the
namespaces support. This make the user namespace code be organized similar to
other namespaces'.
Also mask the USER_NS option as "depend on NAMESPACES".
Currently all the namespace management code is in the kernel/utsname.c file,
so just compile it out and make stubs in the appropriate header.
The init namespace itself is in init/version.c and is in the kernel all the
time.
With fixes from David Rientjes <rientjes@google.com>
Introduce generic structures and routines for resource accounting.
Each resource accounting cgroup is supposed to aggregate it,
cgroup_subsystem_state and its resource-specific members within.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Paul Menage <menage@google.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Pavel Emelianov <xemul@openvz.org>
Replace latency.c use with pm_qos_params use.
Signed-off-by: mark gross <mgross@linux.intel.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Arjan van de Ven <arjan@infradead.org>
The following patch is a generalization of the latency.c implementation done
by Arjan last year. It provides infrastructure for more than one parameter,
and exposes a user mode interface for processes to register pm_qos
expectations of processes.
This interface provides a kernel and user mode interface for registering
performance expectations by drivers, subsystems and user space applications on
one of the parameters.
Currently we have {cpu_dma_latency, network_latency, network_throughput} as
the initial set of pm_qos parameters.
The infrastructure exposes multiple misc device nodes one per implemented
parameter. The set of parameters implement is defined by pm_qos_power_init()
and pm_qos_params.h. This is done because having the available parameters
being runtime configurable or changeable from a driver was seen as too easy to
abuse.
For each parameter a list of performance requirements is maintained along with
an aggregated target value. The aggregated target value is updated with
changes to the requirement list or elements of the list. Typically the
aggregated target value is simply the max or min of the requirement values
held in the parameter list elements.
>From kernel mode the use of this interface is simple:
pm_qos_add_requirement(param_id, name, target_value):
Will insert a named element in the list for that identified PM_QOS
parameter with the target value. Upon change to this list the new target is
recomputed and any registered notifiers are called only if the target value
is now different.
pm_qos_update_requirement(param_id, name, new_target_value):
Will search the list identified by the param_id for the named list element
and then update its target value, calling the notification tree if the
aggregated target is changed. with that name is already registered.
pm_qos_remove_requirement(param_id, name):
Will search the identified list for the named element and remove it, after
removal it will update the aggregate target and call the notification tree
if the target was changed as a result of removing the named requirement.
>From user mode:
Only processes can register a pm_qos requirement. To provide for
automatic cleanup for process the interface requires the process to register
its parameter requirements in the following way:
To register the default pm_qos target for the specific parameter, the
process must open one of /dev/[cpu_dma_latency, network_latency,
network_throughput]
As long as the device node is held open that process has a registered
requirement on the parameter. The name of the requirement is
"process_<PID>" derived from the current->pid from within the open system
call.
To change the requested target value the process needs to write a s32
value to the open device node. This translates to a
pm_qos_update_requirement call.
To remove the user mode request for a target value simply close the device
node.
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix build again]
Cc: Venki Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Adam Belay <abelay@novell.com>
kernel/ksysfs.c seems to be a random dumping group for misc globals
that the rest of the tree depend on. This has caused problems with
exports in the past when sysfs is disabled, which can already be
observed in commit-id 51107301b629640f9ab76fe23bf385e187b9ac29.
The latest one is the kernel_kobj usage, which presently results in:
fs/built-in.o: In function `debugfs_init':
inode.c:(.init.text+0xc34): undefined reference to `kernel_kobj'
make: *** [.tmp_vmlinux1] Error 1
kernel/ksysfs.c itself at this point only contains globals and some
basic sysfs initialization, the sysfs initialization code is optimized
out when we build with sysfs disabled. Given that, it's easier to just
build in unconditionally, rather than trying to find some other random
place to dump and initialize the globals.
Additionally, the current trend seems to be decoupling of kobjects from
sysfs, in which case it still makes sense to perform the kernel_kobj
initialization that happens here even if sysfs is disabled, as
lib/kobject.o is built-in unconditionally.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
During the work on the x86 32 and 64 bit backtrace code I found it useful
to have a simple test module to test a process and irq context backtrace.
Since the existing backtrace code was buggy, I figure it might be useful
to have such a test module in the kernel so that maybe we can even
detect such bugs earlier..
[ mingo@elte.hu: build fix ]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Here is a quick and naive smoke test for kprobes. This is intended to
just verify if some unrelated change broke the *probes subsystem. It is
self contained, architecture agnostic and isn't of any great use by itself.
This needs to be built in the kernel and runs a basic set of tests to
verify if kprobes, jprobes and kretprobes run fine on the kernel. In case
of an error, it'll print out a message with a "BUG" prefix.
This is a start; we intend to add more tests to this bucket over time.
Thanks to Jim Keniston and Masami Hiramatsu for comments and suggestions.
Tested on x86 (32/64) and powerpc.
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
LatencyTOP kernel infrastructure; it measures latencies in the
scheduler and tracks it system wide and per process.
This patch implements a new version of RCU which allows its read-side
critical sections to be preempted. It uses a set of counter pairs
to keep track of the read-side critical sections and flips them
when all tasks exit read-side critical section. The details
of this implementation can be found in this paper -
http://www.rdrop.com/users/paulmck/RCU/OLSrtRCU.2006.08.11a.pdf
and the article-
http://lwn.net/Articles/253651/
This patch was developed as a part of the -rt kernel development and
meant to provide better latencies when read-side critical sections of
RCU don't disable preemption. As a consequence of keeping track of RCU
readers, the readers have a slight overhead (optimizations in the paper).
This implementation co-exists with the "classic" RCU implementations
and can be switched to at compiler.
Also includes RCU tracing summarized in debugfs.
[ akpm@linux-foundation.org: build fixes on non-preempt architectures ]
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com>
Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com>
Reviewed-by: Steven Rostedt <srostedt@redhat.com>
This patch re-organizes the RCU code to enable multiple implementations
of RCU. Users of RCU continues to include rcupdate.h and the
RCU interfaces remain the same. This is in preparation for
subsequently merging the preemptible RCU implementation.
Revert 62d0df64065e7c135d0002f069444fbdfc64768f.
This was originally intended as a simple initial example of how to create a
control groups subsystem; it wasn't intended for mainline, but I didn't make
this clear enough to Andrew.
The CFS cgroup subsystem now has better functionality for the per-cgroup usage
accounting (based directly on CFS stats) than the "usage" status file in this
patch, and the "load" status file is rather simplistic - although having a
per-cgroup load average report would be a useful feature, I don't believe this
patch actually provides it. If it gets into the final 2.6.24 we'd probably
have to support this interface for ever.
New kind of audit rule predicates: "object is visible in given subtree".
The part that can be sanely implemented, that is. Limitations:
* if you have hardlink from outside of tree, you'd better watch
it too (or just watch the object itself, obviously)
* if you mount something under a watched tree, tell audit
that new chunk should be added to watched subtrees
* if you umount something in a watched tree and it's still mounted
elsewhere, you will get matches on events happening there. New command
tells audit to recalculate the trees, trimming such sources of false
positives.
Note that it's _not_ about path - if something mounted in several places
(multiple mount, bindings, different namespaces, etc.), the match does
_not_ depend on which one we are using for access.
Weird I thought I had written the makefile so this would be handled. Oh
well this should fix it.
Sorry about that.
Acked-and-tested-by: Randy Dunlap <randy.dunlap@oracle.com>
The marker activation functions sits in kernel/marker.c. A hash table is used
to keep track of the registered probes and armed markers, so the markers
within a newly loaded module that should be active can be activated at module
load time.
marker_query has been removed. marker_get_first, marker_get_next and
marker_release should be used as iterators on the markers.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Acked-by: "Frank Ch. Eigler" <fche@redhat.com>
Cc: Mike Mason <mmlnx@us.ibm.com>
When a task enters a new namespace via a clone() or unshare(), a new cgroup
is created and the task moves into it.
This version names cgroups which are automatically created using
cgroup_clone() as "node_<pid>" where pid is the pid of the unsharing or
cloned process. (Thanks Pavel for the idea) This is safe because if the
process unshares again, it will create
/cgroups/(...)/node_<pid>/node_<pid>
The only possibilities (AFAICT) for a -EEXIST on unshare are
1. pid wraparound
2. a process fails an unshare, then tries again.
Case 1 is unlikely enough that I ignore it (at least for now). In case 2, the
node_<pid> will be empty and can be rmdir'ed to make the subsequent unshare()
succeed.
Changelog:
Name cloned cgroups as "node_<pid>".
[clg@fr.ibm.com: fix order of cgroup subsystems in init/Kconfig]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
This example subsystem exports debugging information as an aid to diagnosing
refcount leaks, etc, in the cgroup framework.
Signed-off-by: Paul Menage <menage@google.com>
Cc: Serge E. Hallyn <serue@us.ibm.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Paul Jackson <pj@sgi.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com>
This example demonstrates how to use the generic cgroup subsystem for a
simple resource tracker that counts, for the processes in a cgroup, the
total CPU time used and the %CPU used in the last complete 10 second interval.
Portions contributed by Balbir Singh <balbir@in.ibm.com>
Generic Process Control Groups
There have recently been various proposals floating around for
resource management/accounting and other task grouping subsystems in
the kernel, including ResGroups, User BeanCounters, NSProxy
cgroups, and others. These all need the basic abstraction of being
able to group together multiple processes in an aggregate, in order to
track/limit the resources permitted to those processes, or control
other behaviour of the processes, and all implement this grouping in
different ways.
This patchset provides a framework for tracking and grouping processes
into arbitrary "cgroups" and assigning arbitrary state to those
groupings, in order to control the behaviour of the cgroup as an
aggregate.
The intention is that the various resource management and
virtualization/cgroup efforts can also become task cgroup
clients, with the result that:
- the userspace APIs are (somewhat) normalised
- it's easier to test e.g. the ResGroups CPU controller in
conjunction with the BeanCounters memory controller, or use either of
them as the resource-control portion of a virtual server system.
- the additional kernel footprint of any of the competing resource
management systems is substantially reduced, since it doesn't need
to provide process grouping/containment, hence improving their
chances of getting into the kernel
This patch:
Add the main task cgroups framework - the cgroup filesystem, and the
basic structures for tracking membership and associating subsystem state
objects to tasks.
There is separate notifier header, but no separate notifier .c file.
Extract notifier code out of kernel/sys.c which will remain for
misc syscalls I hope. Merge kernel/die_notifier.c into kernel/notifier.c.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
After going through the kernels sysctl tables several times it has become
clear that code review and testing is just not effective in prevent
problematic sysctl tables from being used in the stable kernel. I certainly
can't seem to fix the problems as fast as they are introduced.
Therefore this patch adds sysctl_check_table which is called when a sysctl
table is registered and checks to see if we have a problematic sysctl table.
The biggest part of the code is the table of valid binary sysctl entries, but
since we have frozen our set of binary sysctls this table should not need to
change, and it makes it much easier to detect when someone unintentionally
adds a new binary sysctl value.
As best as I can determine all of the several hundred errors spewed on boot up
now are legitimate.
[bunk@kernel.org: kernel/sysctl_check.c must #include <linux/string.h>]
Cc: Alexey Dobriyan <adobriyan@sw.ru>
Basically, it will allow a process to unshare its user_struct table,
resetting at the same time its own user_struct and all the associated
accounting.
A new root user (uid == 0) is added to the user namespace upon creation.
Such root users have full privileges and it seems that theses privileges
should be controlled through some means (process capabilities ?)
The unshare is not included in this patch.
Changes since [try #4]:
- Updated get_user_ns and put_user_ns to accept NULL, and
get_user_ns to return the namespace.
Changes since [try #3]:
- moved struct user_namespace to files user_namespace.{c,h}
Changes since [try #2]:
- removed struct user_namespace* argument from find_user()
Changes since [try #1]:
- added a root_user per user namespace
Acked-by: Pavel Emelianov <xemul@openvz.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Andrew Morgan <agm@google.com>
CONFIG_UTS_NS and CONFIG_IPC_NS have very little value as they only
deactivate the unshare of the uts and ipc namespaces and do not improve
performance.
Acked-by: "Serge E. Hallyn" <serue@us.ibm.com>
This patch moves the die notifier handling to common code. Previous
various architectures had exactly the same code for it. Note that the new
code is compiled unconditionally, this should be understood as an appel to
the other architecture maintainer to implement support for it aswell (aka
sprinkling a notify_die or two in the proper place)
arm had a notifiy_die that did something totally different, I renamed it to
arm_notify_die as part of the patch and made it static to the file it's
declared and used at. avr32 used to pass slightly less information through
this interface and I brought it into line with the other architectures.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: fix vmalloc_sync_all bustage]
[bryan.wu@analog.com: fix vmalloc_sync_all in nommu]
Cc: <linux-arch@vger.kernel.org>
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
This is just a simple cleanup to keep kernel/sysctl.c from getting to crowded
with special cases, and by keeping all of the utsname logic to together it
makes the code a little more readable.
It has caused more problems than it ever really solved, and is
apparently not getting cleaned up and fixed. We can put it back when
it's stable and isn't likely to make warning or bug events worse.
In the meantime, enable frame pointers for more readable stack traces.
