path: root/kernel/audit_watch.c
2010-08-12Revert "fsnotify: store struct file not struct path"Linus Torvalds
This reverts commit 3bcf3860a4ff9bbc522820b4b765e65e4deceb3e (and the accompanying commit c1e5c954020e "vfs/fsnotify: fsnotify_close can delay the final work in fput" that was a horribly ugly hack to make it work at all). The 'struct file' approach not only causes that disgusting hack, it somehow breaks pulseaudio, probably due to some other subtlety with f_count handling. Fix up various conflicts due to later fsnotify work. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-28fanotify: use both marks when possibleEric Paris
fanotify currently, when given a vfsmount_mark will look up (if it exists) the corresponding inode mark. This patch drops that lookup and uses the mark provided. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: pass both the vfsmount mark and inode markEric Paris
should_send_event() and handle_event() will both need to look up the inode event if they get a vfsmount event. Lets just pass both at the same time since we have them both after walking the lists in lockstep. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: remove group->maskEric Paris
group->mask is now useless. It was originally a shortcut for fsnotify to save on performance. These checks are now redundant, so we remove them. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: cleanup should_send_eventEric Paris
The change to use srcu and walk the object list rather than the global fsnotify_group list means that should_send_event is no longer needed for a number of groups and can be simplified for others. Do that. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28audit: use the mark in handler functionsEric Paris
audit now gets a mark in the should_send_event and handle_event functions. Rather than look up the mark themselves audit should just use the mark it was handed. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: send fsnotify_mark to groups in event handling functionsEric Paris
With the change of fsnotify to use srcu walking the marks list instead of walking the global groups list we now know the mark in question. The code can send the mark to the group's handling functions and the groups won't have to find those marks themselves. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: store struct file not struct pathEric Paris
Al explains that calling dentry_open() with a mnt/dentry pair is only garunteed to be safe if they are already used in an open struct file. To make sure this is the case don't store and use a struct path in fsnotify, always use a struct file. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: split generic and inode specific mark codeEric Paris
currently all marking is done by functions in inode-mark.c. Some of this is pretty generic and should be instead done in a generic function and we should only put the inode specific code in inode-mark.c Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: take inode->i_lock inside fsnotify_find_mark_entry()Andreas Gruenbacher
All callers to fsnotify_find_mark_entry() except one take and release inode->i_lock around the call. Take the lock inside fsnotify_find_mark_entry() instead. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: rename fsnotify_find_mark_entry to fsnotify_find_markEric Paris
the _entry portion of fsnotify functions is useless. Drop it. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: rename fsnotify_mark_entry to just fsnotify_markEric Paris
The name is long and it serves no real purpose. So rename fsnotify_mark_entry to just fsnotify_mark. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: include vfsmount in should_send_event when appropriateEric Paris
To ensure that a group will not duplicate events when it receives it based on the vfsmount and the inode should_send_event test we should distinguish those two cases. We pass a vfsmount to this function so groups can make their own determinations. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: drop mask argument from fsnotify_alloc_groupEric Paris
Nothing uses the mask argument to fsnotify_alloc_group. This patch drops that argument. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28Audit: only set group mask when something is being watchedEric Paris
Currently the audit watch group always sets a mask equal to all events it might care about. We instead should only set the group mask if we are actually watching inodes. This should be a perf win when audit watches are compiled in. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: fsnotify_obtain_group should be fsnotify_alloc_groupEric Paris
fsnotify_obtain_group was intended to be able to find an already existing group. Nothing uses that functionality. This just renames it to fsnotify_alloc_group so it is clear what it is doing. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: remove group_num altogetherEric Paris
The original fsnotify interface has a group-num which was intended to be able to find a group after it was added. I no longer think this is a necessary thing to do and so we remove the group_num. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: include data in should_send callsEric Paris
fanotify is going to need to look at file->private_data to know if an event should be sent or not. This passes the data (which might be a file, dentry, inode, or none) to the should_send function calls so fanotify can get that information when available Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: provide the data type to should_send_eventEric Paris
fanotify is only interested in event types which contain enough information to open the original file in the context of the fanotify listener. Since fanotify may not want to send events if that data isn't present we pass the data type to the should_send_event function call so fanotify can express its lack of interest. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28Audit: audit watch init should not be before fsnotify initEric Paris
Audit watch init and fsnotify init both use subsys_initcall() but since the audit watch code is linked in before the fsnotify code the audit watch code would be using the fsnotify srcu struct before it was initialized. This patch fixes that problem by moving audit watch init to device_initcall() so it happens after fsnotify is ready. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Eric Paris <eparis@redhat.com> Tested-by : Sachin Sant <sachinp@in.ibm.com>
2010-07-28fsnotify: allow addition of duplicate fsnotify marksEric Paris
This patch allows a task to add a second fsnotify mark to an inode for the same group. This mark will be added to the end of the inode's list and this will never be found by the stand fsnotify_find_mark() function. This is useful if a user wants to add a new mark before removing the old one. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28audit: do not get and put just to free a watchEric Paris
deleting audit watch rules is not currently done under audit_filter_mutex. It was done this way because we could not hold the mutex during inotify manipulation. Since we are using fsnotify we don't need to do the extra get/put pair nor do we need the private list on which to store the parents while they are about to be freed. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28audit: redo audit watch locking and refcnt in light of fsnotifyEric Paris
fsnotify can handle mutexes to be held across all fsnotify operations since it deals strickly in spinlocks. This can simplify and reduce some of the audit_filter_mutex taking and dropping. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28audit: convert audit watches to use fsnotify instead of inotifyEric Paris
Audit currently uses inotify to pin inodes in core and to detect when watched inodes are deleted or unmounted. This patch uses fsnotify instead of inotify. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28Audit: clean up the audit_watch splitEric Paris
No real changes, just cleanup to the audit_watch split patch which we done with minimal code changes for easy review. Now fix interfaces to make things work better. Signed-off-by: Eric Paris <eparis@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-24Audit: reorganize struct audit_watch to save 8 bytesEric Paris
pahole showed that struct audit_watch had two holes: struct audit_watch { atomic_t count; /* 0 4 */ /* XXX 4 bytes hole, try to pack */ char * path; /* 8 8 */ dev_t dev; /* 16 4 */ /* XXX 4 bytes hole, try to pack */ long unsigned int ino; /* 24 8 */ struct audit_parent * parent; /* 32 8 */ struct list_head wlist; /* 40 16 */ struct list_head rules; /* 56 16 */ /* --- cacheline 1 boundary (64 bytes) was 8 bytes ago --- */ /* size: 72, cachelines: 2, members: 7 */ /* sum members: 64, holes: 2, sum holes: 8 */ /* last cacheline: 8 bytes */ }; /* definitions: 1 */ by moving dev after count we save 8 bytes, actually improving cacheline usage. There are typically very few of these in the kernel so it won't be a large savings, but it's a good thing no matter what. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24Audit: clean up all op= output to include string quotingEric Paris
A number of places in the audit system we send an op= followed by a string that includes spaces. Somehow this works but it's just wrong. This patch moves all of those that I could find to be quoted. Example: Change From: type=CONFIG_CHANGE msg=audit(1244666690.117:31): auid=0 ses=1 subj=unconfined_u:unconfined_r:auditctl_t:s0-s0:c0.c1023 op=remove rule key="number2" list=4 res=0 Change To: type=CONFIG_CHANGE msg=audit(1244666690.117:31): auid=0 ses=1 subj=unconfined_u:unconfined_r:auditctl_t:s0-s0:c0.c1023 op="remove rule" key="number2" list=4 res=0 Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-23Audit: move audit_get_nd completely into audit_watchEric Paris
audit_get_nd() is only used by audit_watch and could be more cleanly implemented by having the audit watch functions call it when needed rather than making the generic audit rule parsing code deal with those objects. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-23audit: seperate audit inode watches into a subfileEric Paris
In preparation for converting audit to use fsnotify instead of inotify we seperate the inode watching code into it's own file. This is similar to how the audit tree watching code is already seperated into audit_tree.c Signed-off-by: Eric Paris <eparis@redhat.com>
