[ Upstream commit 69924b89687a2923e88cc42144aea27868913d0e ]
if the child has been negative and just went positive
under us, we want coherent d_is_positive() and ->d_inode.
Don't unlock the parent until we'd done that work...
[ Upstream commit baa2a4fdd525c8c4b0f704d20457195b29437839 ]
audit_add_watch stores locally krule->watch without taking a reference
on watch. Then, it calls audit_add_to_parent, and uses the watch stored
locally.
Unfortunately, it is possible that audit_add_to_parent updates
krule->watch.
When it happens, it also drops a reference of watch which
could free the watch.
How to reproduce (with KASAN enabled):
auditctl -w /etc/passwd -F success=0 -k test_passwd
auditctl -w /etc/passwd -F success=1 -k test_passwd2
The second call to auditctl triggers the use-after-free, because
audit_to_parent updates krule->watch to use a previous existing watch
and drops the reference to the newly created watch.
To fix the issue, we grab a reference of watch and we release it at the
end of the function.
Signed-off-by: Ronny Chevalier <ronny.chevalier@hp.com>
Reviewed-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit
Pull audit fixes from Paul Moore:
"Two small fixes to the audit code, both explained well in the
respective patch descriptions, but the quick summary is one
use-after-free fix, and one silly fanotify notification flag fix"
* tag 'audit-pr-20170816' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit:
audit: Receive unmount event
audit: Fix use after free in audit_remove_watch_rule()
Although audit_watch_handle_event() can handle FS_UNMOUNT event, it is
not part of AUDIT_FS_WATCH mask and thus such event never gets to
audit_watch_handle_event(). Thus fsnotify marks are deleted by fsnotify
subsystem on unmount without audit being notified about that which leads
to a strange state of existing audit rules with dead fsnotify marks.
Add FS_UNMOUNT to the mask of events to be received so that audit can
clean up its state accordingly.
audit_remove_watch_rule() drops watch's reference to parent but then
continues to work with it. That is not safe as parent can get freed once
we drop our reference. The following is a trivial reproducer:
mount -o loop image /mnt
touch /mnt/file
auditctl -w /mnt/file -p wax
umount /mnt
auditctl -D
<crash in fsnotify_destroy_mark()>
Grab our own reference in audit_remove_watch_rule() earlier to make sure
mark does not get freed under us.
CC: stable@vger.kernel.org
Reported-by: Tony Jones <tonyj@suse.de>
Tested-by: Tony Jones <tonyj@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull fsnotify updates from Jan Kara:
"The branch contains mainly a rework of fsnotify infrastructure fixing
a shortcoming that we have waited for response to fanotify permission
events with SRCU read lock held and when the process consuming events
was slow to respond the kernel has stalled.
It also contains several cleanups of unnecessary indirections in
fsnotify framework and a bugfix from Amir fixing leakage of kernel
internal errno to userspace"
* 'fsnotify' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: (37 commits)
fanotify: don't expose EOPENSTALE to userspace
fsnotify: remove a stray unlock
fsnotify: Move ->free_mark callback to fsnotify_ops
fsnotify: Add group pointer in fsnotify_init_mark()
fsnotify: Drop inode_mark.c
fsnotify: Remove fsnotify_find_{inode|vfsmount}_mark()
fsnotify: Remove fsnotify_detach_group_marks()
fsnotify: Rename fsnotify_clear_marks_by_group_flags()
fsnotify: Inline fsnotify_clear_{inode|vfsmount}_mark_group()
fsnotify: Remove fsnotify_recalc_{inode|vfsmount}_mask()
fsnotify: Remove fsnotify_set_mark_{,ignored_}mask_locked()
fanotify: Release SRCU lock when waiting for userspace response
fsnotify: Pass fsnotify_iter_info into handle_event handler
fsnotify: Provide framework for dropping SRCU lock in ->handle_event
fsnotify: Remove special handling of mark destruction on group shutdown
fsnotify: Detach mark from object list when last reference is dropped
fsnotify: Move queueing of mark for destruction into fsnotify_put_mark()
inotify: Do not drop mark reference under idr_lock
fsnotify: Free fsnotify_mark_connector when there is no mark attached
fsnotify: Lock object list with connector lock
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
[PM: fix subject line, add #include]
The excess ; after the closing parenthesis is just code-noise it has no
and can be removed.
Signed-off-by: Nicholas Mc Guire <der.herr@hofr.at>
[PM: tweaked subject line]
Pointer to ->free_mark callback unnecessarily occupies one long in each
fsnotify_mark although they are the same for all marks from one
notification group. Move the callback pointer to fsnotify_ops.
Reviewed-by: Miklos Szeredi <mszeredi@redhat.com>
Reviewed-by: Amir Goldstein <amir73il@gmail.com>
Currently we initialize mark->group only in fsnotify_add_mark_lock().
However we will need to access fsnotify_ops of corresponding group from
fsnotify_put_mark() so we need mark->group initialized earlier. Do that
in fsnotify_init_mark() which has a consequence that once
fsnotify_init_mark() is called on a mark, the mark has to be destroyed
by fsnotify_put_mark().
These are very thin wrappers, just remove them. Drop
fs/notify/vfsmount_mark.c as it is empty now.
Pass fsnotify_iter_info into ->handle_event() handler so that it can
release and reacquire SRCU lock via fsnotify_prepare_user_wait() and
fsnotify_finish_user_wait() functions. These functions also make sure
current marks are appropriately pinned so that iteration protected by
srcu in fsnotify() stays safe.
Pull more vfs updates from Al Viro:
"In this pile:
- autofs-namespace series
- dedupe stuff
- more struct path constification"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (40 commits)
ocfs2: implement the VFS clone_range, copy_range, and dedupe_range features
ocfs2: charge quota for reflinked blocks
ocfs2: fix bad pointer cast
ocfs2: always unlock when completing dio writes
ocfs2: don't eat io errors during _dio_end_io_write
ocfs2: budget for extent tree splits when adding refcount flag
ocfs2: prohibit refcounted swapfiles
ocfs2: add newlines to some error messages
ocfs2: convert inode refcount test to a helper
simple_write_end(): don't zero in short copy into uptodate
exofs: don't mess with simple_write_{begin,end}
9p: saner ->write_end() on failing copy into non-uptodate page
fix gfs2_stuffed_write_end() on short copies
fix ceph_write_end()
nfs_write_end(): fix handling of short copies
vfs: refactor clone/dedupe_file_range common functions
fs: try to clone files first in vfs_copy_file_range
vfs: misc struct path constification
namespace.c: constify struct path passed to a bunch of primitives
quota: constify struct path in quota_on
Pull vfs updates from Al Viro:
- more ->d_init() stuff (work.dcache)
- pathname resolution cleanups (work.namei)
- a few missing iov_iter primitives - copy_from_iter_full() and
friends. Either copy the full requested amount, advance the iterator
and return true, or fail, return false and do _not_ advance the
iterator. Quite a few open-coded callers converted (and became more
readable and harder to fuck up that way) (work.iov_iter)
- several assorted patches, the big one being logfs removal
logfs: remove from tree
vfs: fix put_compat_statfs64() does not handle errors
namei: fold should_follow_link() with the step into not-followed link
namei: pass both WALK_GET and WALK_MORE to should_follow_link()
namei: invert WALK_PUT logics
namei: shift interpretation of LOOKUP_FOLLOW inside should_follow_link()
namei: saner calling conventions for mountpoint_last()
namei.c: get rid of user_path_parent()
switch getfrag callbacks to ..._full() primitives
make skb_add_data,{_nocache}() and skb_copy_to_page_nocache() advance only on success
[iov_iter] new primitives - copy_from_iter_full() and friends
don't open-code file_inode()
ceph: switch to use of ->d_init()
ceph: unify dentry_operations instances
lustre: switch to use of ->d_init()
The AUDIT_CONFIG_CHANGE events sometimes use a op= field. The current
code logs the value of the field with quotes. This field is documented
to not be encoded, so it should not have quotes.
Signed-off-by: Steve Grubb <sgrubb@redhat.com>
[PM: reformatted commit description to make checkpatch.pl happy]
"Two small patches to fix some bugs with the audit-by-executable
functionality we introduced back in v4.3 (both patches are marked
for the stable folks)"
* 'stable-4.8' of git://git.infradead.org/users/pcmoore/audit:
audit: fix exe_file access in audit_exe_compare
mm: introduce get_task_exe_file
Prior to the change the function would blindly deference mm, exe_file
and exe_file->f_inode, each of which could have been NULL or freed.
Use get_task_exe_file to safely obtain stable exe_file.
Signed-off-by: Mateusz Guzik <mguzik@redhat.com>
Acked-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Acked-by: Richard Guy Briggs <rgb@redhat.com>
Cc: <stable@vger.kernel.org> # 4.3.x
... and neither can ever be NULL
Pull audit updates from Paul Moore:
"A small set of patches for audit this time; just three in total and
one is a spelling fix.
The two patches with actual content are designed to help prevent new
instances of auditd from displacing an existing, functioning auditd
and to generate a log of the attempt. Not to worry, dead/stuck auditd
instances can still be replaced by a new instance without problem.
Nothing controversial, and everything passes our regression suite"
* 'stable-4.6' of git://git.infradead.org/users/pcmoore/audit:
audit: Fix typo in comment
audit: log failed attempts to change audit_pid configuration
audit: stop an old auditd being starved out by a new auditd
Signed-off-by: Weiyuan <weiyuan.wei@huawei.com>
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Pull audit update from Paul Moore:
"This is one of the larger audit patchsets in recent history,
consisting of eight patches and almost 400 lines of changes.
The bulk of the patchset is the new "audit by executable"
functionality which allows admins to set an audit watch based on the
executable on disk. Prior to this, admins could only track an
application by PID, which has some obvious limitations.
Beyond the new functionality we also have some refcnt fixes and a few
minor cleanups"
* 'upstream' of git://git.infradead.org/users/pcmoore/audit:
fixup: audit: implement audit by executable
audit: clean simple fsnotify implementation
audit: use macros for unset inode and device values
audit: make audit_del_rule() more robust
audit: fix uninitialized variable in audit_add_rule()
audit: eliminate unnecessary extra layer of watch parent references
audit: eliminate unnecessary extra layer of watch references
The Intel build-bot detected a sparse warning with with a patch I posted a
couple of days ago that was accepted in the audit/next tree:
Subject: [linux-next:master 6689/6751] kernel/audit_watch.c:543:36: sparse: dereference of noderef expression
Date: Friday, August 07, 2015, 06:57:55 PM
tree: git://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git master
head: e6455bc5b91f41f842f30465c9193320f0568707
commit: 2e3a8aeb63e5335d4f837d453787c71bcb479796 [6689/6751] Merge remote- tracking branch 'audit/next'
sparse warnings: (new ones prefixed by >>)
kernel/audit_watch.c:544:28: sparse: dereference of noderef expression
34d99af5 Richard Guy Briggs 2015-08-05 541 int audit_exe_compare(struct task_struct *tsk, struct audit_fsnotify_mark *mark)
34d99af5 Richard Guy Briggs 2015-08-05 542 {
34d99af5 Richard Guy Briggs 2015-08-05 @543 unsigned long ino = tsk->mm- >exe_file->f_inode->i_ino;
34d99af5 Richard Guy Briggs 2015-08-05 544 dev_t dev = tsk->mm->exe_file- >f_inode->i_sb->s_dev;
:::::: The code at line 543 was first introduced by commit
:::::: 34d99af52ad40bd498ba66970579a5bc1fb1a3bc audit: implement audit by executable
tsk->mm->exe_file requires RCU access. The warning was reproduceable by adding
"C=1 CF=-D__CHECK_ENDIAN__" to the build command, and verified eliminated with
this patch.
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
This adds the ability audit the actions of a not-yet-running process.
This patch implements the ability to filter on the executable path. Instead of
just hard coding the ino and dev of the executable we care about at the moment
the rule is inserted into the kernel, use the new audit_fsnotify
infrastructure to manage this dynamically. This means that if the filename
does not yet exist but the containing directory does, or if the inode in
question is unlinked and creat'd (aka updated) the rule will just continue to
work. If the containing directory is moved or deleted or the filesystem is
unmounted, the rule is deleted automatically. A future enhancement would be to
have the rule survive across directory disruptions.
This is a heavily modified version of a patch originally submitted by Eric
Paris with some ideas from Peter Moody.
Cc: Peter Moody <peter@hda3.com>
Cc: Eric Paris <eparis@redhat.com>
[PM: minor whitespace clean to satisfy ./scripts/checkpatch]
Clean up a number of places were casted magic numbers are used to represent
unset inode and device numbers in preparation for the audit by executable path
patch set.
[PM: enclosed the _UNSET macros in parentheses for ./scripts/checkpatch]
The audit watch parent count was imbalanced, adding an unnecessary layer of
watch parent references. Decrement the additional parent reference when a
watch is reused, already having a reference to the parent.
audit_find_parent() gets a reference to the parent, if the parent is
already known. This additional parental reference is not needed if the
watch is subsequently found by audit_add_to_parent(), and consumed if
the watch does not already exist, so we need to put the parent if the
watch is found, and do nothing if this new watch is added to the parent.
If the parent wasn't already known, it is created with a refcount of 1
and added to the audit_watch_group, then incremented by one to be
subsequently consumed by the newly created watch in
audit_add_to_parent().
The rule points to the watch, not to the parent, so the rule's refcount
gets bumped, not the parent's.
See LKML, 2015-07-16
The audit watch count was imbalanced, adding an unnecessary layer of watch
references. Only add the second reference when it is added to a parent.
Various audit events dealing with adding, removing and updating rules result in
invalid values set for the op keys which result in embedded spaces in op=
values.
The invalid values are
op="add rule" set in kernel/auditfilter.c
op="remove rule" set in kernel/auditfilter.c
op="remove rule" set in kernel/audit_tree.c
op="updated rules" set in kernel/audit_watch.c
op="remove rule" set in kernel/audit_watch.c
Replace the space in the above values with an underscore character ('_').
Coded-by: Burn Alting <burn@swtf.dyndns.org>
My rework of handling of notification events (namely commit 7053aee26a35
"fsnotify: do not share events between notification groups") broke
sending of cookies with inotify events. We didn't propagate the value
passed to fsnotify() properly and passed 4 uninitialized bytes to
userspace instead (so it is also an information leak). Sadly I didn't
notice this during my testing because inotify cookies aren't used very
much and LTP inotify tests ignore them.
Fix the problem by passing the cookie value properly.
Fixes: 7053aee26a3548ebaba046ae2e52396ccf56ac6c
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
We usually rely on the fact that struct members not specified in the
initializer are set to NULL. So do that with fsnotify function pointers
as well.
Cc: Eric Paris <eparis@parisplace.org>
After removing event structure creation from the generic layer there is
no reason for separate .should_send_event and .handle_event callbacks.
So just remove the first one.
Currently fsnotify framework creates one event structure for each
notification event and links this event into all interested notification
groups. This is done so that we save memory when several notification
groups are interested in the event. However the need for event
structure shared between inotify & fanotify bloats the event structure
so the result is often higher memory consumption.
Another problem is that fsnotify framework keeps path references with
outstanding events so that fanotify can return open file descriptors
with its events. This has the undesirable effect that filesystem cannot
be unmounted while there are outstanding events - a regression for
inotify compared to a situation before it was converted to fsnotify
framework. For fanotify this problem is hard to avoid and users of
fanotify should kind of expect this behavior when they ask for file
descriptors from notified files.
This patch changes fsnotify and its users to create separate event
structure for each group. This allows for much simpler code (~400 lines
removed by this patch) and also smaller event structures. For example
on 64-bit system original struct fsnotify_event consumes 120 bytes, plus
additional space for file name, additional 24 bytes for second and each
subsequent group linking the event, and additional 32 bytes for each
inotify group for private data. After the conversion inotify event
consumes 48 bytes plus space for file name which is considerably less
memory unless file names are long and there are several groups
interested in the events (both of which are uncommon). Fanotify event
fits in 56 bytes after the conversion (fanotify doesn't care about file
names so its events don't have to have it allocated). A win unless
there are four or more fanotify groups interested in the event.
The conversion also solves the problem with unmount when only inotify is
used as we don't have to grab path references for inotify events.
[hughd@google.com: fanotify: fix corruption preventing startup]
It's possible for audit_log_start() to return NULL. Handle it in the
various callers.
Cc: Jeff Layton <jlayton@redhat.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Julien Tinnes <jln@google.com>
Cc: Will Drewry <wad@google.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Pull filesystem notification updates from Eric Paris:
"This pull mostly is about locking changes in the fsnotify system. By
switching the group lock from a spin_lock() to a mutex() we can now
hold the lock across things like iput(). This fixes a problem
involving unmounting a fs and having inodes be busy, first pointed out
by FAT, but reproducible with tmpfs.
This also restores signal driven I/O for inotify, which has been
broken since about 2.6.32."
Ugh. I *hate* the timing of this. It was rebased after the merge
window opened, and then left to sit with the pull request coming the day
before the merge window closes. That's just crap. But apparently the
patches themselves have been around for over a year, just gathering
dust, so now it's suddenly critical.
Fixed up semantic conflict in fs/notify/fdinfo.c as per Stephen
Rothwell's fixes from -next.
* 'for-next' of git://git.infradead.org/users/eparis/notify:
inotify: automatically restart syscalls
inotify: dont skip removal of watch descriptor if creation of ignored event failed
fanotify: dont merge permission events
fsnotify: make fasync generic for both inotify and fanotify
fsnotify: change locking order
fsnotify: dont put marks on temporary list when clearing marks by group
fsnotify: introduce locked versions of fsnotify_add_mark() and fsnotify_remove_mark()
fsnotify: pass group to fsnotify_destroy_mark()
fsnotify: use a mutex instead of a spinlock to protect a groups mark list
fanotify: add an extra flag to mark_remove_from_mask that indicates wheather a mark should be destroyed
fsnotify: take groups mark_lock before mark lock
fsnotify: use reference counting for groups
fsnotify: introduce fsnotify_get_group()
inotify, fanotify: replace fsnotify_put_group() with fsnotify_destroy_group()
In fsnotify_destroy_mark() dont get the group from the passed mark anymore,
but pass the group itself as an additional parameter to the function.
Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
Signed-off-by: Eric Paris <eparis@redhat.com>
In the cases where we already know the length of the parent, pass it as
a parm so we don't need to recompute it. In the cases where we don't
know the length, pass in AUDIT_NAME_FULL (-1) to indicate that it should
be determined.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
All the callers set this to NULL now.
Always store audit loginuids in type kuid_t.
Print loginuids by converting them into uids in the appropriate user
namespace, and then printing the resulting uid.
Modify audit_get_loginuid to return a kuid_t.
Modify audit_set_loginuid to take a kuid_t.
Modify /proc/<pid>/loginuid on read to convert the loginuid into the
user namespace of the opener of the file.
Modify /proc/<pid>/loginud on write to convert the loginuid
rom the user namespace of the opener of the file.
Cc: Paul Moore <paul@paul-moore.com> ?
all callers want the same thing, actually - a kinda-sorta analog of
kern_path_create(). I.e. they want parent vfsmount/dentry (with
->i_mutex held, to make sure the child dentry is still their child)
+ the child dentry.
Signed-off-by Al Viro <viro@zeniv.linux.org.uk>
all remaining callers pass LOOKUP_PARENT to it, so
flags argument can die; renamed to kern_path_parent()
don't rely on pathname resolution ending up twice at the same point...
I was doing some namespace checks and found some simple stuff in
audit that could be cleaned up. Make some functions static, and
put const on make_reply payload arg.
This reverts commit 3bcf3860a4ff9bbc522820b4b765e65e4deceb3e (and the
accompanying commit c1e5c954020e "vfs/fsnotify: fsnotify_close can delay
the final work in fput" that was a horribly ugly hack to make it work at
all).
The 'struct file' approach not only causes that disgusting hack, it
somehow breaks pulseaudio, probably due to some other subtlety with
f_count handling.
Fix up various conflicts due to later fsnotify work.
fanotify currently, when given a vfsmount_mark will look up (if it exists)
the corresponding inode mark. This patch drops that lookup and uses the
mark provided.
should_send_event() and handle_event() will both need to look up the inode
event if they get a vfsmount event. Lets just pass both at the same time
since we have them both after walking the lists in lockstep.
group->mask is now useless. It was originally a shortcut for fsnotify to
save on performance. These checks are now redundant, so we remove them.
The change to use srcu and walk the object list rather than the global
fsnotify_group list means that should_send_event is no longer needed for a
number of groups and can be simplified for others. Do that.
