path: root/kernel/auditsc.c
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-22Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fixes from Paul Moore: "Seven audit patches for v4.1, all bug fixes. The largest, and perhaps most significant commit helps resolve some memory pressure issues related to the inode cache and audit, there are also a few small commits which help resolve some timing issues with the audit log queue, and the rest fall into the always popular "code clean-up" category. In general, nothing really substantial, just a nice set of maintenance patches" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: Remove condition which always evaluates to false audit: reduce mmap_sem hold for mm->exe_file audit: consolidate handling of mm->exe_file audit: code clean up audit: don't reset working wait time accidentally with auditd audit: don't lose set wait time on first successful call to audit_log_start() audit: move the tree pruning to a dedicated thread
2015-04-15VFS: audit: d_backing_inode() annotationsDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-23audit: consolidate handling of mm->exe_fileDavidlohr Bueso
This patch adds a audit_log_d_path_exe() helper function to share how we handle auditing of the exe_file's path. Used by both audit and auditsc. No functionality is changed. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> [PM: tweaked subject line] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-17Merge branch 'getname2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull getname/putname updates from Al Viro: "Rework of getname/getname_kernel/etc., mostly from Paul Moore. Gets rid of quite a pile of kludges between namei and audit..." * 'getname2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: audit: replace getname()/putname() hacks with reference counters audit: fix filename matching in __audit_inode() and __audit_inode_child() audit: enable filename recording via getname_kernel() simpler calling conventions for filename_mountpoint() fs: create proper filename objects using getname_kernel() fs: rework getname_kernel to handle up to PATH_MAX sized filenames cut down the number of do_path_lookup() callers
2015-01-25file->f_path.dentry is pinned down for as long as the file is open...Al Viro
2015-01-23audit: replace getname()/putname() hacks with reference countersPaul Moore
In order to ensure that filenames are not released before the audit subsystem is done with the strings there are a number of hacks built into the fs and audit subsystems around getname() and putname(). To say these hacks are "ugly" would be kind. This patch removes the filename hackery in favor of a more conventional reference count based approach. The diffstat below tells most of the story; lots of audit/fs specific code is replaced with a traditional reference count based approach that is easily understood, even by those not familiar with the audit and/or fs subsystems. CC: viro@zeniv.linux.org.uk CC: linux-fsdevel@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-23audit: fix filename matching in __audit_inode() and __audit_inode_child()Paul Moore
In all likelihood there were some subtle, and perhaps not so subtle, bugs with filename matching in audit_inode() and audit_inode_child() for some time, however, recent changes to the audit filename code have definitely broken the filename matching code. The breakage could result in duplicate filenames in the audit log and other odd audit record entries. This patch fixes the filename matching code and restores some sanity to the filename audit records. CC: viro@zeniv.linux.org.uk CC: linux-fsdevel@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-23audit: enable filename recording via getname_kernel()Paul Moore
Enable recording of filenames in getname_kernel() and remove the kludgy workaround in __audit_inode() now that we have proper filename logging for kernel users. CC: viro@zeniv.linux.org.uk CC: linux-fsdevel@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com> Reviewed-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-31Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fix from Paul Moore: "One audit patch to resolve a panic/oops when recording filenames in the audit log, see the mail archive link below. The fix isn't as nice as I would like, as it involves an allocate/copy of the filename, but it solves the problem and the overhead should only affect users who have configured audit rules involving file names. We'll revisit this issue with future kernels in an attempt to make this suck less, but in the meantime I think this fix should go into the next release of v3.19-rcX. [ https://marc.info/?t=141986927600001&r=1&w=2 ]" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: create private file name copies when auditing inodes
2014-12-30audit: create private file name copies when auditing inodesPaul Moore
Unfortunately, while commit 4a928436 ("audit: correctly record file names with different path name types") fixed a problem where we were not recording filenames, it created a new problem by attempting to use these file names after they had been freed. This patch resolves the issue by creating a copy of the filename which the audit subsystem frees after it is done with the string. At some point it would be nice to resolve this issue with refcounts, or something similar, instead of having to allocate/copy strings, but that is almost surely beyond the scope of a -rcX patch so we'll defer that for later. On the plus side, only audit users should be impacted by the string copying. Reported-by: Toralf Foerster <toralf.foerster@gmx.de> Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-12-23Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit fixes from Paul Moore: "Four patches to fix various problems with the audit subsystem, all are fairly small and straightforward. One patch fixes a problem where we weren't using the correct gfp allocation flags (GFP_KERNEL regardless of context, oops), one patch fixes a problem with old userspace tools (this was broken for a while), one patch fixes a problem where we weren't recording pathnames correctly, and one fixes a problem with PID based filters. In general I don't think there is anything controversial with this patchset, and it fixes some rather unfortunate bugs; the allocation flag one can be particularly scary looking for users" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: restore AUDIT_LOGINUID unset ABI audit: correctly record file names with different path name types audit: use supplied gfp_mask from audit_buffer in kauditd_send_multicast_skb audit: don't attempt to lookup PIDs when changing PID filtering audit rules
2014-12-22audit: correctly record file names with different path name typesPaul Moore
There is a problem with the audit system when multiple audit records are created for the same path, each with a different path name type. The root cause of the problem is in __audit_inode() when an exact match (both the path name and path name type) is not found for a path name record; the existing code creates a new path name record, but it never sets the path name in this record, leaving it NULL. This patch corrects this problem by assigning the path name to these newly created records. There are many ways to reproduce this problem, but one of the easiest is the following (assuming auditd is running): # mkdir /root/tmp/test # touch /root/tmp/test/567 # auditctl -a always,exit -F dir=/root/tmp/test # touch /root/tmp/test/567 Afterwards, or while the commands above are running, check the audit log and pay special attention to the PATH records. A faulty kernel will display something like the following for the file creation: type=SYSCALL msg=audit(1416957442.025:93): arch=c000003e syscall=2 success=yes exit=3 ... comm="touch" exe="/usr/bin/touch" type=CWD msg=audit(1416957442.025:93): cwd="/root/tmp" type=PATH msg=audit(1416957442.025:93): item=0 name="test/" inode=401409 ... nametype=PARENT type=PATH msg=audit(1416957442.025:93): item=1 name=(null) inode=393804 ... nametype=NORMAL type=PATH msg=audit(1416957442.025:93): item=2 name=(null) inode=393804 ... nametype=NORMAL While a patched kernel will show the following: type=SYSCALL msg=audit(1416955786.566:89): arch=c000003e syscall=2 success=yes exit=3 ... comm="touch" exe="/usr/bin/touch" type=CWD msg=audit(1416955786.566:89): cwd="/root/tmp" type=PATH msg=audit(1416955786.566:89): item=0 name="test/" inode=401409 ... nametype=PARENT type=PATH msg=audit(1416955786.566:89): item=1 name="test/567" inode=393804 ... nametype=NORMAL This issue was brought up by a number of people, but special credit should go to hujianyang@huawei.com for reporting the problem along with an explanation of the problem and a patch. While the original patch did have some problems (see the archive link below), it did demonstrate the problem and helped kickstart the fix presented here. * https://lkml.org/lkml/2014/9/5/66 Reported-by: hujianyang <hujianyang@huawei.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Richard Guy Briggs <rgb@redhat.com>
2014-11-19new helper: audit_file()Al Viro
... for situations when we don't have any candidate in pathnames - basically, in descriptor-based syscalls. [Folded the build fix for !CONFIG_AUDITSYSCALL configs from Chen Gang] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-19kill f_dentry usesAl Viro
2014-10-19Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris: "So this change across a whole bunch of arches really solves one basic problem. We want to audit when seccomp is killing a process. seccomp hooks in before the audit syscall entry code. audit_syscall_entry took as an argument the arch of the given syscall. Since the arch is part of what makes a syscall number meaningful it's an important part of the record, but it isn't available when seccomp shoots the syscall... For most arch's we have a better way to get the arch (syscall_get_arch) So the solution was two fold: Implement syscall_get_arch() everywhere there is audit which didn't have it. Use syscall_get_arch() in the seccomp audit code. Having syscall_get_arch() everywhere meant it was a useless flag on the stack and we could get rid of it for the typical syscall entry. The other changes inside the audit system aren't grand, fixed some records that had invalid spaces. Better locking around the task comm field. Removing some dead functions and structs. Make some things static. Really minor stuff" * git://git.infradead.org/users/eparis/audit: (31 commits) audit: rename audit_log_remove_rule to disambiguate for trees audit: cull redundancy in audit_rule_change audit: WARN if audit_rule_change called illegally audit: put rule existence check in canonical order next: openrisc: Fix build audit: get comm using lock to avoid race in string printing audit: remove open_arg() function that is never used audit: correct AUDIT_GET_FEATURE return message type audit: set nlmsg_len for multicast messages. audit: use union for audit_field values since they are mutually exclusive audit: invalid op= values for rules audit: use atomic_t to simplify audit_serial() kernel/audit.c: use ARRAY_SIZE instead of sizeof/sizeof[0] audit: reduce scope of audit_log_fcaps audit: reduce scope of audit_net_id audit: arm64: Remove the audit arch argument to audit_syscall_entry arm64: audit: Add audit hook in syscall_trace_enter/exit() audit: x86: drop arch from __audit_syscall_entry() interface sparc: implement is_32bit_task sparc: properly conditionalize use of TIF_32BIT ...
2014-09-23audit: get comm using lock to avoid race in string printingRichard Guy Briggs
When task->comm is passed directly to audit_log_untrustedstring() without getting a copy or using the task_lock, there is a race that could happen that would output a NULL (\0) in the output string that would effectively truncate the rest of the report text after the comm= field in the audit, losing fields. Use get_task_comm() to get a copy while acquiring the task_lock to prevent this and to prevent the result from being a mixture of old and new values of comm. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-09-23audit: remove open_arg() function that is never usedRichard Guy Briggs
open_arg() was added in commit 55669bfa "audit: AUDIT_PERM support" and never used. Remove it. Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-09-23audit: x86: drop arch from __audit_syscall_entry() interfaceRichard Guy Briggs
Since the arch is found locally in __audit_syscall_entry(), there is no need to pass it in as a parameter. Delete it from the parameter list. x86* was the only arch to call __audit_syscall_entry() directly and did so from assembly code. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Cc: linux-kernel@vger.kernel.org Cc: linux-audit@redhat.com Signed-off-by: Eric Paris <eparis@redhat.com> --- As this patch relies on changes in the audit tree, I think it appropriate to send it through my tree rather than the x86 tree.
2014-09-23audit: add arch field to seccomp event logRichard Guy Briggs
The AUDIT_SECCOMP record looks something like this: type=SECCOMP msg=audit(1373478171.953:32775): auid=4325 uid=4325 gid=4325 ses=1 subj=unconfined_u:unconfined_r:unconfined_t:s0 pid=12381 comm="test" sig=31 syscall=231 compat=0 ip=0x39ea8bca89 code=0x0 In order to determine what syscall 231 maps to, we need to have the arch= field right before it. To see the event, compile this test.c program: ===== int main(void) { return seccomp_load(seccomp_init(SCMP_ACT_KILL)); } ===== gcc -g test.c -o test -lseccomp After running the program, find the record by: ausearch --start recent -m SECCOMP -i Signed-off-by: Richard Guy Briggs <rgb@redhat.com> signed-off-by: Eric Paris <eparis@redhat.com>
2014-09-23audit: __audit_syscall_entry: ignore arch arg and call syscall_get_arch() ↵Richard Guy Briggs
directly Since every arch should have syscall_get_arch() defined, stop using the function argument and just collect this ourselves. We do not drop the argument as fixing some code paths (in assembly) to not pass this first argument is non-trivial. The argument will be dropped when that is fixed. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-09-09Documentation: Docbook: Fix generated DocBook/kernel-api.xmlMasanari Iida
This patch fix spelling typo found in DocBook/kernel-api.xml. It is because the file is generated from the source comments, I have to fix the comments in source codes. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-06-10auditsc: audit_krule mask accesses need bounds checkingAndy Lutomirski
Fixes an easy DoS and possible information disclosure. This does nothing about the broken state of x32 auditing. eparis: If the admin has enabled auditd and has specifically loaded audit rules. This bug has been around since before git. Wow... Cc: stable@vger.kernel.org Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-12Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris. * git://git.infradead.org/users/eparis/audit: (28 commits) AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range audit: do not cast audit_rule_data pointers pointlesly AUDIT: Allow login in non-init namespaces audit: define audit_is_compat in kernel internal header kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c sched: declare pid_alive as inline audit: use uapi/linux/audit.h for AUDIT_ARCH declarations syscall_get_arch: remove useless function arguments audit: remove stray newline from audit_log_execve_info() audit_panic() call audit: remove stray newlines from audit_log_lost messages audit: include subject in login records audit: remove superfluous new- prefix in AUDIT_LOGIN messages audit: allow user processes to log from another PID namespace audit: anchor all pid references in the initial pid namespace audit: convert PPIDs to the inital PID namespace. pid: get pid_t ppid of task in init_pid_ns audit: rename the misleading audit_get_context() to audit_take_context() audit: Add generic compat syscall support audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL ...
2014-03-20audit: remove stray newline from audit_log_execve_info() audit_panic() callJoe Perches
There's an unnecessary use of a \n in audit_panic. Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-03-20audit: include subject in login recordsEric Paris
The login uid change record does not include the selinux context of the task logging in. Add that information. (Updated from 2011-01: RHBZ:670328 -- RGB) Reported-by: Steve Grubb <sgrubb@redhat.com> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Aristeu Rozanski <arozansk@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-03-20audit: remove superfluous new- prefix in AUDIT_LOGIN messagesRichard Guy Briggs
The new- prefix on ses and auid are un-necessary and break ausearch. Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-03-20audit: anchor all pid references in the initial pid namespaceRichard Guy Briggs
Store and log all PIDs with reference to the initial PID namespace and use the access functions task_pid_nr() and task_tgid_nr() for task->pid and task->tgid. Cc: "Eric W. Biederman" <ebiederm@xmission.com> (informed by ebiederman's c776b5d2) Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-03-20audit: convert PPIDs to the inital PID namespace.Richard Guy Briggs
sys_getppid() returns the parent pid of the current process in its own pid namespace. Since audit filters are based in the init pid namespace, a process could avoid a filter or trigger an unintended one by being in an alternate pid namespace or log meaningless information. Switch to task_ppid_nr() for PPIDs to anchor all audit filters in the init_pid_ns. (informed by ebiederman's 6c621b7e) Cc: stable@vger.kernel.org Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-03-20audit: rename the misleading audit_get_context() to audit_take_context()Richard Guy Briggs
"get" usually implies incrementing a refcount into a structure to indicate a reference being held by another part of code. Change this function name to indicate it is in fact being taken from it, returning the value while clearing it in the supplying structure. Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-03-20audit: Audit proc/<pid>/cmdline aka proctitleWilliam Roberts
During an audit event, cache and print the value of the process's proctitle value (proc/<pid>/cmdline). This is useful in situations where processes are started via fork'd virtual machines where the comm field is incorrect. Often times, setting the comm field still is insufficient as the comm width is not very wide and most virtual machine "package names" do not fit. Also, during execution, many threads have their comm field set as well. By tying it back to the global cmdline value for the process, audit records will be more complete in systems with these properties. An example of where this is useful and applicable is in the realm of Android. With Android, their is no fork/exec for VM instances. The bare, preloaded Dalvik VM listens for a fork and specialize request. When this request comes in, the VM forks, and the loads the specific application (specializing). This was done to take advantage of COW and to not require a load of basic packages by the VM on very app spawn. When this spawn occurs, the package name is set via setproctitle() and shows up in procfs. Many of these package names are longer then 16 bytes, the historical width of task->comm. Having the cmdline in the audit records will couple the application back to the record directly. Also, on my Debian development box, some audit records were more useful then what was printed under comm. The cached proctitle is tied to the life-cycle of the audit_context structure and is built on demand. Proctitle is controllable by userspace, and thus should not be trusted. It is meant as an aid to assist in debugging. The proctitle event is emitted during syscall audits, and can be filtered with auditctl. Example: type=AVC msg=audit(1391217013.924:386): avc: denied { getattr } for pid=1971 comm="mkdir" name="/" dev="selinuxfs" ino=1 scontext=system_u:system_r:consolekit_t:s0-s0:c0.c255 tcontext=system_u:object_r:security_t:s0 tclass=filesystem type=SYSCALL msg=audit(1391217013.924:386): arch=c000003e syscall=137 success=yes exit=0 a0=7f019dfc8bd7 a1=7fffa6aed2c0 a2=fffffffffff4bd25 a3=7fffa6aed050 items=0 ppid=1967 pid=1971 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="mkdir" exe="/bin/mkdir" subj=system_u:system_r:consolekit_t:s0-s0:c0.c255 key=(null) type=UNKNOWN[1327] msg=audit(1391217013.924:386): proctitle=6D6B646972002D70002F7661722F72756E2F636F6E736F6C65 Acked-by: Steve Grubb <sgrubb@redhat.com> (wrt record formating) Signed-off-by: William Roberts <wroberts@tresys.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-03-07audit: Use more current logging style againRichard Guy Briggs
Add pr_fmt to prefix "audit: " to output Convert printk(KERN_<LEVEL> to pr_<level> Coalesce formats Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-02-05execve: use 'struct filename *' for executable name passingLinus Torvalds
This changes 'do_execve()' to get the executable name as a 'struct filename', and to free it when it is done. This is what the normal users want, and it simplifies and streamlines their error handling. The controlled lifetime of the executable name also fixes a use-after-free problem with the trace_sched_process_exec tracepoint: the lifetime of the passed-in string for kernel users was not at all obvious, and the user-mode helper code used UMH_WAIT_EXEC to serialize the pathname allocation lifetime with the execve() having finished, which in turn meant that the trace point that happened after mm_release() of the old process VM ended up using already free'd memory. To solve the kernel string lifetime issue, this simply introduces "getname_kernel()" that works like the normal user-space getname() function, except with the source coming from kernel memory. As Oleg points out, this also means that we could drop the tcomm[] array from 'struct linux_binprm', since the pathname lifetime now covers setup_new_exec(). That would be a separate cleanup. Reported-by: Igor Zhbanov <i.zhbanov@samsung.com> Tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-13audit: fix dangling keywords in audit_log_set_loginuid() outputRichard Guy Briggs
Remove spaces between "new", "old" label modifiers and "auid", "ses" labels in log output since userspace tools can't parse orphaned keywords. Make variable names more consistent and intuitive. Make audit_log_format() argument code easier to read. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-01-13audit: convert all sessionid declaration to unsigned intEric Paris
Right now the sessionid value in the kernel is a combination of u32, int, and unsigned int. Just use unsigned int throughout. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-01-13audit: Added exe field to audit core dump signal logPaul Davies C
Currently when the coredump signals are logged by the audit system, the actual path to the executable is not logged. Without details of exe, the system admin may not have an exact idea on what program failed. This patch changes the audit_log_task() so that the path to the exe is also logged. This was copied from audit_log_task_info() and the latter enhanced to avoid disappearing text fields. Signed-off-by: Paul Davies C <pauldaviesc@gmail.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-01-13audit: drop audit_log_abend()Paul Davies C
The audit_log_abend() is used only by the audit_core_dumps(). Thus there is no need of maintaining the audit_log_abend() as a separate function. This patch drops the audit_log_abend() and pushes its functionalities back to the audit_core_dumps(). Apart from that the "reason" field is also dropped from being logged since the reason can be deduced from the signal number. Signed-off-by: Paul Davies C <pauldaviesc@gmail.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-01-13audit: don't generate loginuid log when audit disabledGao feng
If audit is disabled, we shouldn't generate loginuid audit log. Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-01-13audit: Simplify and correct audit_log_capsetEric W. Biederman
- Always report the current process as capset now always only works on the current process. This prevents reporting 0 or a random pid in a random pid namespace. - Don't bother to pass the pid as is available. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> (cherry picked from commit bcc85f0af31af123e32858069eb2ad8f39f90e67) (cherry picked from commit f911cac4556a7a23e0b3ea850233d13b32328692) Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [eparis: fix build error when audit disabled] Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-06audit: fix type of sessionid in audit_set_loginuid()Eric Paris
sfr pointed out that with CONFIG_UIDGID_STRICT_TYPE_CHECKS set the audit tree would not build. This is because the oldsessionid in audit_set_loginuid() was accidentally being declared as a kuid_t. This patch fixes that declaration mistake. Example of problem: kernel/auditsc.c: In function 'audit_set_loginuid': kernel/auditsc.c:2003:15: error: incompatible types when assigning to type 'kuid_t' from type 'int' oldsessionid = audit_get_sessionid(current); Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05audit: call audit_bprm() only once to add AUDIT_EXECVE informationRichard Guy Briggs
Move the audit_bprm() call from search_binary_handler() to exec_binprm(). This allows us to get rid of the mm member of struct audit_aux_data_execve since bprm->mm will equal current->mm. This also mitigates the issue that ->argc could be modified by the load_binary() call in search_binary_handler(). audit_bprm() was being called to add an AUDIT_EXECVE record to the audit context every time search_binary_handler() was recursively called. Only one reference is necessary. Reported-by: Oleg Nesterov <onestero@redhat.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> --- This patch is against 3.11, but was developed on Oleg's post-3.11 patches that introduce exec_binprm().
2013-11-05audit: move audit_aux_data_execve contents into audit_context unionRichard Guy Briggs
audit_bprm() was being called to add an AUDIT_EXECVE record to the audit context every time search_binary_handler() was recursively called. Only one reference is necessary, so just update it. Move the the contents of audit_aux_data_execve into the union in audit_context, removing dependence on a kmalloc along the way. Reported-by: Oleg Nesterov <onestero@redhat.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05audit: remove unused envc member of audit_aux_data_execveRichard Guy Briggs
Get rid of write-only audit_aux_data_exeve structure member envc. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05audit: Kill the unused struct audit_aux_data_capsetEric W. Biederman
Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> (cherry picked from ebiederman commit 6904431d6b41190e42d6b94430b67cb4e7e6a4b7) Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05audit: update AUDIT_INODE filter rule to comparator functionRichard Guy Briggs
It appears this one comparison function got missed in f368c07d (and 9c937dcc). Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05audit: audit feature to set loginuid immutableEric Paris
This adds a new 'audit_feature' bit which allows userspace to set it such that the loginuid is absolutely immutable, even if you have CAP_AUDIT_CONTROL. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05audit: audit feature to only allow unsetting the loginuidEric Paris
This is a new audit feature which only grants processes with CAP_AUDIT_CONTROL the ability to unset their loginuid. They cannot directly set it from a valid uid to another valid uid. The ability to unset the loginuid is nice because a priviledged task, like that of container creation, can unset the loginuid and then priv is not needed inside the container when a login daemon needs to set the loginuid. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05audit: allow unsetting the loginuid (with priv)Eric Paris
If a task has CAP_AUDIT_CONTROL allow that task to unset their loginuid. This would allow a child of that task to set their loginuid without CAP_AUDIT_CONTROL. Thus when launching a new login daemon, a priviledged helper would be able to unset the loginuid and then the daemon, which may be malicious user facing, do not need priv to function correctly. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05audit: remove CONFIG_AUDIT_LOGINUID_IMMUTABLEEric Paris
After trying to use this feature in Fedora we found the hard coding policy like this into the kernel was a bad idea. Surprise surprise. We ran into these problems because it was impossible to launch a container as a logged in user and run a login daemon inside that container. This reverts back to the old behavior before this option was added. The option will be re-added in a userspace selectable manor such that userspace can choose when it is and when it is not appropriate. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05audit: loginuid functions coding styleEric Paris
This is just a code rework. It makes things more readable. It does not make any functional changes. It does change the log messages to include both the old session id as well the new and it includes a new res field, which means we get messages even when the user did not have permission to change the loginuid. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
