path: root/kernel/cgroup.c
2010-05-04cgroup: Fix an RCU warning in alloc_css_id()Li Zefan
With CONFIG_PROVE_RCU=y, a warning can be triggered: # mount -t cgroup -o memory xxx /mnt # mkdir /mnt/0 ... kernel/cgroup.c:4442 invoked rcu_dereference_check() without protection! ... This is a false-positive. It's safe to directly access parent_css->id. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-04cgroup: Fix an RCU warning in cgroup_path()Li Zefan
with CONFIG_PROVE_RCU=y, a warning can be triggered: # mount -t cgroup -o debug xxx /mnt # cat /proc/$$/cgroup ... kernel/cgroup.c:1649 invoked rcu_dereference_check() without protection! ... This is a false-positive, because cgroup_path() can be called with either rcu_read_lock() held or cgroup_mutex held. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
2010-03-24cgroups: remove duplicate includeLi Zefan
commit e6a1105b ("cgroups: subsystem module loading interface") and commit c50cc752 ("sched, cgroups: Fix module export") result in duplicate including of module.h Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-16Fix typos in commentsThomas Weber
[Ss]ytem => [Ss]ystem udpate => update paramters => parameters orginal => original Signed-off-by: Thomas Weber <swirl@gmx.li> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-12cgroups: remove events before destroying subsystem state objectsKirill A. Shutemov
Events should be removed after rmdir of cgroup directory, but before destroying subsystem state objects. Let's take reference to cgroup directory dentry to do that. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hioryu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: fix race between userspace and kernelspaceKirill A. Shutemov
Notify userspace about cgroup removing only after rmdir of cgroup directory to avoid race between userspace and kernelspace. eventfd are used to notify about two types of event: - control file-specific, like crossing memory threshold; - cgroup removing. To understand what really happen, userspace can check if the cgroup still exists. To avoid race beetween userspace and kernelspace we have to notify userspace about cgroup removing only after rmdir of cgroup directory. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroup: implement eventfd-based generic API for notificationsKirill A. Shutemov
This patchset introduces eventfd-based API for notifications in cgroups and implements memory notifications on top of it. It uses statistics in memory controler to track memory usage. Output of time(1) on building kernel on tmpfs: Root cgroup before changes: make -j2 506.37 user 60.93s system 193% cpu 4:52.77 total Non-root cgroup before changes: make -j2 507.14 user 62.66s system 193% cpu 4:54.74 total Root cgroup after changes (0 thresholds): make -j2 507.13 user 62.20s system 193% cpu 4:53.55 total Non-root cgroup after changes (0 thresholds): make -j2 507.70 user 64.20s system 193% cpu 4:55.70 total Root cgroup after changes (1 thresholds, never crossed): make -j2 506.97 user 62.20s system 193% cpu 4:53.90 total Non-root cgroup after changes (1 thresholds, never crossed): make -j2 507.55 user 64.08s system 193% cpu 4:55.63 total This patch: Introduce the write-only file "cgroup.event_control" in every cgroup. To register new notification handler you need: - create an eventfd; - open a control file to be monitored. Callbacks register_event() and unregister_event() must be defined for the control file; - write "<event_fd> <control_fd> <args>" to cgroup.event_control. Interpretation of args is defined by control file implementation; eventfd will be woken up by control file implementation or when the cgroup is removed. To unregister notification handler just close eventfd. If you need notification functionality for a control file you have to implement callbacks register_event() and unregister_event() in the struct cftype. [kamezawa.hiroyu@jp.fujitsu.com: Kconfig fix] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Dan Malek <dan@embeddedalley.com> Cc: Vladislav Buzov <vbuzov@embeddedalley.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Alexander Shishkin <virtuoso@slind.org> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: clean up cgroup_pidlist_find() a bitLi Zefan
Don't call get_pid_ns() before we locate/alloc the ns. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Serge Hallyn <serue@us.ibm.com> Acked-by: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: blkio subsystem as moduleBen Blum
Modify the Block I/O cgroup subsystem to be able to be built as a module. As the CFQ disk scheduler optionally depends on blk-cgroup, config options in block/Kconfig, block/Kconfig.iosched, and block/blk-cgroup.h are enhanced to support the new module dependency. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: subsystem module unloadingBen Blum
Provides support for unloading modular subsystems. This patch adds a new function cgroup_unload_subsys which is to be used for removing a loaded subsystem during module deletion. Reference counting of the subsystems' modules is moved from once (at load time) to once per attached hierarchy (in parse_cgroupfs_options and rebind_subsystems) (i.e., 0 or 1). Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: subsystem module loading interfaceBen Blum
Add interface between cgroups subsystem management and module loading This patch implements rudimentary module-loading support for cgroups - namely, a cgroup_load_subsys (similar to cgroup_init_subsys) for use as a module initcall, and a struct module pointer in struct cgroup_subsys. Several functions that might be wanted by modules have had EXPORT_SYMBOL added to them, but it's unclear exactly which functions want it and which won't. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroups: revamp subsys arrayBen Blum
This patch series provides the ability for cgroup subsystems to be compiled as modules both within and outside the kernel tree. This is mainly useful for classifiers and subsystems that hook into components that are already modules. cls_cgroup and blkio-cgroup serve as the example use cases for this feature. It provides an interface cgroup_load_subsys() and cgroup_unload_subsys() which modular subsystems can use to register and depart during runtime. The net_cls classifier subsystem serves as the example for a subsystem which can be converted into a module using these changes. Patch #1 sets up the subsys[] array so its contents can be dynamic as modules appear and (eventually) disappear. Iterations over the array are modified to handle when subsystems are absent, and the dynamic section of the array is protected by cgroup_mutex. Patch #2 implements an interface for modules to load subsystems, called cgroup_load_subsys, similar to cgroup_init_subsys, and adds a module pointer in struct cgroup_subsys. Patch #3 adds a mechanism for unloading modular subsystems, which includes a more advanced rework of the rudimentary reference counting introduced in patch 2. Patch #4 modifies the net_cls subsystem, which already had some module declarations, to be configurable as a module, which also serves as a simple proof-of-concept. Part of implementing patches 2 and 4 involved updating css pointers in each css_set when the module appears or leaves. In doing this, it was discovered that css_sets always remain linked to the dummy cgroup, regardless of whether or not any subsystems are actually bound to it (i.e., not mounted on an actual hierarchy). The subsystem loading and unloading code therefore should keep in mind the special cases where the added subsystem is the only one in the dummy cgroup (and therefore all css_sets need to be linked back into it) and where the removed subsys was the only one in the dummy cgroup (and therefore all css_sets should be unlinked from it) - however, as all css_sets always stay attached to the dummy cgroup anyway, these cases are ignored. Any fix that addresses this issue should also make sure these cases are addressed in the subsystem loading and unloading code. This patch: Make subsys[] able to be dynamically populated to support modular subsystems This patch reworks the way the subsys[] array is used so that subsystems can register themselves after boot time, and enables the internals of cgroups to be able to handle when subsystems are not present or may appear/disappear. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroup: introduce coalesce css_get() and css_put()Daisuke Nishimura
Current css_get() and css_put() increment/decrement css->refcnt one by one. This patch add a new function __css_get(), which takes "count" as a arg and increment the css->refcnt by "count". And this patch also add a new arg("count") to __css_put() and change the function to decrement the css->refcnt by "count". These coalesce version of __css_get()/__css_put() will be used to improve performance of memcg's moving charge feature later, where instead of calling css_get()/css_put() repeatedly, these new functions will be used. No change is needed for current users of css_get()/css_put(). Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12cgroup: introduce cancel_attach()Daisuke Nishimura
Add cancel_attach() operation to struct cgroup_subsys. cancel_attach() can be used when can_attach() operation prepares something for the subsys, but we should rollback what can_attach() operation has prepared if attach task fails after we've succeeded in can_attach(). Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-25sched, cgroups: Fix module exportIngo Molnar
I have exported it in d11c563 - but cgroups.c did not have module.h included ... Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-6-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25sched: Use lockdep-based checking on rcu_dereference()Paul E. McKenney
Update the rcu_dereference() usages to take advantage of the new lockdep-based checking. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-6-git-send-email-paulmck@linux.vnet.ibm.com> [ -v2: fix allmodconfig missing symbol export build failure on x86 ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-02cgroups: fix to return errno in a failure pathLi Zefan
In cgroup_create(), if alloc_css_id() returns failure, the errno is not propagated to userspace, so mkdir will fail silently. To trigger this bug, we mount blkio (or memory subsystem), and create more then 65534 cgroups. (The number of cgroups is limited to 65535 if a subsystem has use_id == 1) # mount -t cgroup -o blkio xxx /mnt # for ((i = 0; i < 65534; i++)); do mkdir /mnt/$i; done # mkdir /mnt/65534 (should return ENOSPC) # Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Paul Menage <menage@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11cgroups: fix 2.6.32 regression causing BUG_ON() in cgroup_diput()Dave Anderson
The LTP cgroup test suite generates a "kernel BUG at kernel/cgroup.c:790!" here in cgroup_diput(): /* * if we're getting rid of the cgroup, refcount should ensure * that there are no pidlists left. */ BUG_ON(!list_empty(&cgrp->pidlists)); The cgroup pidlist rework in 2.6.32 generates the BUG_ON, which is caused when pidlist_array_load() calls cgroup_pidlist_find(): (1) if a matching cgroup_pidlist is found, it down_write's the mutex of the pre-existing cgroup_pidlist, and increments its use_count. (2) if no matching cgroup_pidlist is found, then a new one is allocated, it down_write's its mutex, and the use_count is set to 0. (3) the matching, or new, cgroup_pidlist gets returned back to pidlist_array_load(), which increments its use_count -- regardless whether new or pre-existing -- and up_write's the mutex. So if a matching list is ever encountered by cgroup_pidlist_find() during the life of a cgroup directory, it results in an inflated use_count value, preventing it from ever getting released by cgroup_release_pid_array(). Then if the directory is subsequently removed, cgroup_diput() hits the BUG_ON() when it finds that the directory's cgroup is still populated with a pidlist. The patch simply removes the use_count increment when a matching pidlist is found by cgroup_pidlist_find(), because it gets bumped by the calling pidlist_array_load() function while still protected by the list's mutex. Signed-off-by: Dave Anderson <anderson@redhat.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Ben Blum <bblum@andrew.cmu.edu> Cc: Paul Menage <menage@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29cgroup: fix strstrip() misuseKOSAKI Motohiro
cgroup_write_X64() and cgroup_write_string() ignore the return value of strstrip(). it makes small inconsistent behavior. example: ========================= # cd /mnt/cgroup/hoge # cat memory.swappiness 60 # echo "59 " > memory.swappiness # cat memory.swappiness 59 # echo " 58" > memory.swappiness bash: echo: write error: Invalid argument This patch fixes it. Cc: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01cgroup: catch bad css refcnt at css_putKAMEZAWA Hiroyuki
__css_put() doesn't check a bug as refcnt goes to minus. I think it should be caught. This patch adds a check for it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: let ss->can_attach and ss->attach do whole threadgroups at a timeBen Blum
Alter the ss->can_attach and ss->attach functions to be able to deal with a whole threadgroup at a time, for use in cgroup_attach_proc. (This is a pre-patch to cgroup-procs-writable.patch.) Currently, new mode of the attach function can only tell the subsystem about the old cgroup of the threadgroup leader. No subsystem currently needs that information for each thread that's being moved, but if one were to be added (for example, one that counts tasks within a group) this bit would need to be reworked a bit to tell the subsystem the right information. [hidave.darkstar@gmail.com: fix build] Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: change css_set freeing mechanism to be under RCUBen Blum
Changes css_set freeing mechanism to be under RCU This is a prepatch for making the procs file writable. In order to free the old css_sets for each task to be moved as they're being moved, the freeing mechanism must be RCU-protected, or else we would have to have a call to synchronize_rcu() for each task before freeing its old css_set. Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: use vmalloc for large cgroups pidlist allocationsBen Blum
Separates all pidlist allocation requests to a separate function that judges based on the requested size whether or not the array needs to be vmalloced or can be gotten via kmalloc, and similar for kfree/vfree. Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: ensure correct concurrent opening/reading of pidlists across pid ↵Ben Blum
namespaces Previously there was the problem in which two processes from different pid namespaces reading the tasks or procs file could result in one process seeing results from the other's namespace. Rather than one pidlist for each file in a cgroup, we now keep a list of pidlists keyed by namespace and file type (tasks versus procs) in which entries are placed on demand. Each pidlist has its own lock, and that the pidlists themselves are passed around in the seq_file's private pointer means we don't have to touch the cgroup or its master list except when creating and destroying entries. Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: add a read-only "procs" file similar to "tasks" that shows only ↵Ben Blum
unique tgids struct cgroup used to have a bunch of fields for keeping track of the pidlist for the tasks file. Those are now separated into a new struct cgroup_pidlist, of which two are had, one for procs and one for tasks. The way the seq_file operations are set up is changed so that just the pidlist struct gets passed around as the private data. Interface example: Suppose a multithreaded process has pid 1000 and other threads with ids 1001, 1002, 1003: $ cat tasks 1000 1001 1002 1003 $ cat cgroup.procs 1000 $ Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: revert "cgroups: fix pid namespace bug"Paul Menage
The following series adds a "cgroup.procs" file to each cgroup that reports unique tgids rather than pids, and allows all threads in a threadgroup to be atomically moved to a new cgroup. The subsystem "attach" interface is modified to support attaching whole threadgroups at a time, which could introduce potential problems if any subsystem were to need to access the old cgroup of every thread being moved. The attach interface may need to be revised if this becomes the case. Also added is functionality for read/write locking all CLONE_THREAD fork()ing within a threadgroup, by means of an rwsem that lives in the sighand_struct, for per-threadgroup-ness and also for sharing a cacheline with the sighand's atomic count. This scheme should introduce no extra overhead in the fork path when there's no contention. The final patch reveals potential for a race when forking before a subsystem's attach function is called - one potential solution in case any subsystem has this problem is to hang on to the group's fork mutex through the attach() calls, though no subsystem yet demonstrates need for an extended critical section. This patch: Revert commit 096b7fe012d66ed55e98bc8022405ede0cc80e96 Author: Li Zefan <lizf@cn.fujitsu.com> AuthorDate: Wed Jul 29 15:04:04 2009 -0700 Commit: Linus Torvalds <torvalds@linux-foundation.org> CommitDate: Wed Jul 29 19:10:35 2009 -0700 cgroups: fix pid namespace bug This is in preparation for some clashing cgroups changes that subsume the original commit's functionaliy. The original commit fixed a pid namespace bug which Ben Blum fixed independently (in the same way, but with different code) as part of a series of patches. I played around with trying to reconcile Ben's patch series with Li's patch, but concluded that it was simpler to just revert Li's, given that Ben's patch series contained essentially the same fix. Signed-off-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: allow cgroup hierarchies to be created with no bound subsystemsPaul Menage
This patch removes the restriction that a cgroup hierarchy must have at least one bound subsystem. The mount option "none" is treated as an explicit request for no bound subsystems. A hierarchy with no subsystems can be useful for plain task tracking, and is also a step towards the support for multiply-bindable subsystems. As part of this change, the hierarchy id is no longer calculated from the bitmask of subsystems in the hierarchy (since this is not guaranteed to be unique) but is allocated via an ida. Reference counts on cgroups from css_set objects are now taken explicitly one per hierarchy, rather than one per subsystem. Example usage: mount -t cgroup -o none,name=foo cgroup /mnt/cgroup Based on the "no-op"/"none" subsystem concept proposed by kamezawa.hiroyu@jp.fujitsu.com Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: add a back-pointer from struct cg_cgroup_link to struct cgroupPaul Menage
Currently the cgroups code makes the assumption that the subsystem pointers in a struct css_set uniquely identify the hierarchy->cgroup mappings associated with the css_set; and there's no way to directly identify the associated set of cgroups other than by indirecting through the appropriate subsystem state pointers. This patch removes the need for that assumption by adding a back-pointer from struct cg_cgroup_link object to its associated cgroup; this allows the set of cgroups to be determined by traversing the cg_links list in the struct css_set. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: move the cgroup debug subsys into cgroup.c to access internal statePaul Menage
While it's architecturally clean to have the cgroup debug subsystem be completely independent of the cgroups framework, it limits its usefulness for debugging the contents of internal data structures. Move the debug subsystem code into the scope of all the cgroups data structures to make more detailed debugging possible. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: support named cgroups hierarchiesPaul Menage
To simplify referring to cgroup hierarchies in mount statements, and to allow disambiguation in the presence of empty hierarchies and multiply-bindable subsystems this patch adds support for naming a new cgroup hierarchy via the "name=" mount option A pre-existing hierarchy may be specified by either name or by subsystems; a hierarchy's name cannot be changed by a remount operation. Example usage: # To create a hierarchy called "foo" containing the "cpu" subsystem mount -t cgroup -oname=foo,cpu cgroup /mnt/cgroup1 # To mount the "foo" hierarchy on a second location mount -t cgroup -oname=foo cgroup /mnt/cgroup2 Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: make unlock sequence in cgroup_get_sb consistentXiaotian Feng
Make the last unlock sequence consistent with previous unlock sequeue. Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining inode_operations as constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining super_operations constAlexey Dobriyan
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-29cgroup avoid permanent sleep at rmdirKAMEZAWA Hiroyuki
After commit ec64f51545fffbc4cb968f0cea56341a4b07e85a ("cgroup: fix frequent -EBUSY at rmdir"), cgroup's rmdir (especially against memcg) doesn't return -EBUSY by temporary ref counts. That commit expects all refs after pre_destroy() is temporary but...it wasn't. Then, rmdir can wait permanently. This patch tries to fix that and change followings. - set CGRP_WAIT_ON_RMDIR flag before pre_destroy(). - clear CGRP_WAIT_ON_RMDIR flag when the subsys finds racy case. if there are sleeping ones, wakes them up. - rmdir() sleeps only when CGRP_WAIT_ON_RMDIR flag is set. Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Paul Menage <menage@google.com> Acked-by: Balbir Sigh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29cgroups: fix pid namespace bugLi Zefan
The bug was introduced by commit cc31edceee04a7b87f2be48f9489ebb72d264844 ("cgroups: convert tasks file to use a seq_file with shared pid array"). We cache a pid array for all threads that are opening the same "tasks" file, but the pids in the array are always from the namespace of the last process that opened the file, so all other threads will read pids from that namespace instead of their own namespaces. To fix it, we maintain a list of pid arrays, which is keyed by pid_ns. The list will be of length 1 at most time. Reported-by: Paul Menage <menage@google.com> Idea-by: Paul Menage <menage@google.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Serge Hallyn <serue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18cgroups: forbid noprefix if mounting more than just cpuset subsystemLi Zefan
The 'noprefix' option was introduced for backwards-compatibility of cpuset, but actually it can be used when mounting other subsystems. This results in possibility of name collision, and now the collision can really happen, because we have 'stat' file in both memory and cpuacct subsystem: # mount -t cgroup -o noprefix,memory,cpuacct xxx /mnt Cgroup will happily mount the 2 subsystems, but only 'stat' file of memory subsys can be seen. We don't want users to use nopreifx, and also want to avoid name collision, so we change to allow noprefix only if mounting just the cpuset subsystem. [akpm@linux-foundation.org: fix shift for cpuset_subsys_id >= 32] Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-04-02memcg: fix OOM killer under memcgKAMEZAWA Hiroyuki
This patch tries to fix OOM Killer problems caused by hierarchy. Now, memcg itself has OOM KILL function (in oom_kill.c) and tries to kill a task in memcg. But, when hierarchy is used, it's broken and correct task cannot be killed. For example, in following cgroup /groupA/ hierarchy=1, limit=1G, 01 nolimit 02 nolimit All tasks' memory usage under /groupA, /groupA/01, groupA/02 is limited to groupA's 1Gbytes but OOM Killer just kills tasks in groupA. This patch provides makes the bad process be selected from all tasks under hierarchy. BTW, currently, oom_jiffies is updated against groupA in above case. oom_jiffies of tree should be updated. To see how oom_jiffies is used, please check mem_cgroup_oom_called() callers. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: const fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: don't change release_agent when remount failedLi Zefan
Remount can fail in either case: - wrong mount options is specified, or option 'noprefix' is changed. - a to-be-added subsys is already mounted/active. When using remount to change 'release_agent', for the above former failure case, remount will return errno with release_agent unchanged, but for the latter case, remount will return EBUSY with relase_agent changed, which is unexpected I think: # mount -t cgroup -o cpu xxx /cgrp1 # mount -t cgroup -o cpuset,release_agent=agent1 yyy /cgrp2 # cat /cgrp2/release_agent agent1 # mount -t cgroup -o remount,cpuset,noprefix,release_agent=agent2 yyy /cgrp2 mount: /cgrp2 not mounted already, or bad option # cat /cgrp2/release_agent agent1 <-- ok # mount -t cgroup -o remount,cpu,cpuset,release_agent=agent2 yyy /cgrp2 mount: /cgrp2 is busy # cat /cgrp2/release_agent agent2 <-- unexpected! Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: show correct file modeLi Zefan
We have some read-only files and write-only files, but currently they are all set to 0644, which is counter-intuitive and cause trouble for some cgroup tools like libcgroup. This patch adds 'mode' to struct cftype to allow cgroup subsys to set it's own files' file mode, and for the most cases cft->mode can be default to 0 and cgroup will figure out proper mode. Acked-by: Paul Menage <menage@google.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02kernel/cgroup.c: kfree(NULL) is legalJesper Juhl
Reduces object file size a bit: Before: $ size kernel/cgroup.o text data bss dec hex filename 21593 7804 4924 34321 8611 kernel/cgroup.o After: $ size kernel/cgroup.o text data bss dec hex filename 21537 7744 4924 34205 859d kernel/cgroup.o Signed-off-by: Jesper Juhl <jj@chaosbits.net> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroup: fix frequent -EBUSY at rmdirKAMEZAWA Hiroyuki
In following situation, with memory subsystem, /groupA use_hierarchy==1 /01 some tasks /02 some tasks /03 some tasks /04 empty When tasks under 01/02/03 hit limit on /groupA, hierarchical reclaim is triggered and the kernel walks tree under groupA. In this case, rmdir /groupA/04 fails with -EBUSY frequently because of temporal refcnt from the kernel. In general. cgroup can be rmdir'd if there are no children groups and no tasks. Frequent fails of rmdir() is not useful to users. (And the reason for -EBUSY is unknown to users.....in most cases) This patch tries to modify above behavior, by - retries if css_refcnt is got by someone. - add "return value" to pre_destroy() and allows subsystem to say "we're really busy!" Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroup: CSS ID supportKAMEZAWA Hiroyuki
Patch for Per-CSS(Cgroup Subsys State) ID and private hierarchy code. This patch attaches unique ID to each css and provides following. - css_lookup(subsys, id) returns pointer to struct cgroup_subysys_state of id. - css_get_next(subsys, id, rootid, depth, foundid) returns the next css under "root" by scanning When cgroup_subsys->use_id is set, an id for css is maintained. The cgroup framework only parepares - css_id of root css for subsys - id is automatically attached at creation of css. - id is *not* freed automatically. Because the cgroup framework don't know lifetime of cgroup_subsys_state. free_css_id() function is provided. This must be called by subsys. There are several reasons to develop this. - Saving space .... For example, memcg's swap_cgroup is array of pointers to cgroup. But it is not necessary to be very fast. By replacing pointers(8bytes per ent) to ID (2byes per ent), we can reduce much amount of memory usage. - Scanning without lock. CSS_ID provides "scan id under this ROOT" function. By this, scanning css under root can be written without locks. ex) do { rcu_read_lock(); next = cgroup_get_next(subsys, id, root, &found); /* check sanity of next here */ css_tryget(); rcu_read_unlock(); id = found + 1 } while(...) Characteristics: - Each css has unique ID under subsys. - Lifetime of ID is controlled by subsys. - css ID contains "ID" and "Depth in hierarchy" and stack of hierarchy - Allowed ID is 1-65535, ID 0 is UNUSED ID. Design Choices: - scan-by-ID v.s. scan-by-tree-walk. As /proc's pid scan does, scan-by-ID is robust when scanning is done by following kind of routine. scan -> rest a while(release a lock) -> conitunue from interrupted memcg's hierarchical reclaim does this. - When subsys->use_id is set, # of css in the system is limited to 65535. [bharata@linux.vnet.ibm.com: remove rcu_read_lock() from css_get_next()] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: relax ns_can_attach checks to allow attaching to grandchild cgroupsGrzegorz Nosek
The ns_proxy cgroup allows moving processes to child cgroups only one level deep at a time. This commit relaxes this restriction and makes it possible to attach tasks directly to grandchild cgroups, e.g.: ($pid is in the root cgroup) echo $pid > /cgroup/CG1/CG2/tasks Previously this operation would fail with -EPERM and would have to be performed as two steps: echo $pid > /cgroup/CG1/tasks echo $pid > /cgroup/CG1/CG2/tasks Also, the target cgroup no longer needs to be empty to move a task there. Signed-off-by: Grzegorz Nosek <root@localdomain.pl> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27vfs: simple_set_mnt() should return voidSukadev Bhattiprolu
simple_set_mnt() is defined as returning 'int' but always returns 0. Callers assume simple_set_mnt() never fails and don't properly cleanup if it were to _ever_ fail. For instance, get_sb_single() and get_sb_nodev() should: up_write(sb->s_unmount); deactivate_super(sb); if simple_set_mnt() fails. Since simple_set_mnt() never fails, would be cleaner if it did not return anything. [akpm@linux-foundation.org: fix build] Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
