path: root/kernel/cgroup.c
2010-01-18cgroups: fix 2.6.32 regression causing BUG_ON() in cgroup_diput()Dave Anderson
commit bd4f490a079730aadfaf9a728303ea0135c01945 upstream. The LTP cgroup test suite generates a "kernel BUG at kernel/cgroup.c:790!" here in cgroup_diput(): /* * if we're getting rid of the cgroup, refcount should ensure * that there are no pidlists left. */ BUG_ON(!list_empty(&cgrp->pidlists)); The cgroup pidlist rework in 2.6.32 generates the BUG_ON, which is caused when pidlist_array_load() calls cgroup_pidlist_find(): (1) if a matching cgroup_pidlist is found, it down_write's the mutex of the pre-existing cgroup_pidlist, and increments its use_count. (2) if no matching cgroup_pidlist is found, then a new one is allocated, it down_write's its mutex, and the use_count is set to 0. (3) the matching, or new, cgroup_pidlist gets returned back to pidlist_array_load(), which increments its use_count -- regardless whether new or pre-existing -- and up_write's the mutex. So if a matching list is ever encountered by cgroup_pidlist_find() during the life of a cgroup directory, it results in an inflated use_count value, preventing it from ever getting released by cgroup_release_pid_array(). Then if the directory is subsequently removed, cgroup_diput() hits the BUG_ON() when it finds that the directory's cgroup is still populated with a pidlist. The patch simply removes the use_count increment when a matching pidlist is found by cgroup_pidlist_find(), because it gets bumped by the calling pidlist_array_load() function while still protected by the list's mutex. Signed-off-by: Dave Anderson <anderson@redhat.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Ben Blum <bblum@andrew.cmu.edu> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-29cgroup: fix strstrip() misuseKOSAKI Motohiro
cgroup_write_X64() and cgroup_write_string() ignore the return value of strstrip(). it makes small inconsistent behavior. example: ========================= # cd /mnt/cgroup/hoge # cat memory.swappiness 60 # echo "59 " > memory.swappiness # cat memory.swappiness 59 # echo " 58" > memory.swappiness bash: echo: write error: Invalid argument This patch fixes it. Cc: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01cgroup: catch bad css refcnt at css_putKAMEZAWA Hiroyuki
__css_put() doesn't check a bug as refcnt goes to minus. I think it should be caught. This patch adds a check for it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: let ss->can_attach and ss->attach do whole threadgroups at a timeBen Blum
Alter the ss->can_attach and ss->attach functions to be able to deal with a whole threadgroup at a time, for use in cgroup_attach_proc. (This is a pre-patch to cgroup-procs-writable.patch.) Currently, new mode of the attach function can only tell the subsystem about the old cgroup of the threadgroup leader. No subsystem currently needs that information for each thread that's being moved, but if one were to be added (for example, one that counts tasks within a group) this bit would need to be reworked a bit to tell the subsystem the right information. [hidave.darkstar@gmail.com: fix build] Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: change css_set freeing mechanism to be under RCUBen Blum
Changes css_set freeing mechanism to be under RCU This is a prepatch for making the procs file writable. In order to free the old css_sets for each task to be moved as they're being moved, the freeing mechanism must be RCU-protected, or else we would have to have a call to synchronize_rcu() for each task before freeing its old css_set. Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: use vmalloc for large cgroups pidlist allocationsBen Blum
Separates all pidlist allocation requests to a separate function that judges based on the requested size whether or not the array needs to be vmalloced or can be gotten via kmalloc, and similar for kfree/vfree. Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: ensure correct concurrent opening/reading of pidlists across pid ↵Ben Blum
namespaces Previously there was the problem in which two processes from different pid namespaces reading the tasks or procs file could result in one process seeing results from the other's namespace. Rather than one pidlist for each file in a cgroup, we now keep a list of pidlists keyed by namespace and file type (tasks versus procs) in which entries are placed on demand. Each pidlist has its own lock, and that the pidlists themselves are passed around in the seq_file's private pointer means we don't have to touch the cgroup or its master list except when creating and destroying entries. Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: add a read-only "procs" file similar to "tasks" that shows only ↵Ben Blum
unique tgids struct cgroup used to have a bunch of fields for keeping track of the pidlist for the tasks file. Those are now separated into a new struct cgroup_pidlist, of which two are had, one for procs and one for tasks. The way the seq_file operations are set up is changed so that just the pidlist struct gets passed around as the private data. Interface example: Suppose a multithreaded process has pid 1000 and other threads with ids 1001, 1002, 1003: $ cat tasks 1000 1001 1002 1003 $ cat cgroup.procs 1000 $ Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: revert "cgroups: fix pid namespace bug"Paul Menage
The following series adds a "cgroup.procs" file to each cgroup that reports unique tgids rather than pids, and allows all threads in a threadgroup to be atomically moved to a new cgroup. The subsystem "attach" interface is modified to support attaching whole threadgroups at a time, which could introduce potential problems if any subsystem were to need to access the old cgroup of every thread being moved. The attach interface may need to be revised if this becomes the case. Also added is functionality for read/write locking all CLONE_THREAD fork()ing within a threadgroup, by means of an rwsem that lives in the sighand_struct, for per-threadgroup-ness and also for sharing a cacheline with the sighand's atomic count. This scheme should introduce no extra overhead in the fork path when there's no contention. The final patch reveals potential for a race when forking before a subsystem's attach function is called - one potential solution in case any subsystem has this problem is to hang on to the group's fork mutex through the attach() calls, though no subsystem yet demonstrates need for an extended critical section. This patch: Revert commit 096b7fe012d66ed55e98bc8022405ede0cc80e96 Author: Li Zefan <lizf@cn.fujitsu.com> AuthorDate: Wed Jul 29 15:04:04 2009 -0700 Commit: Linus Torvalds <torvalds@linux-foundation.org> CommitDate: Wed Jul 29 19:10:35 2009 -0700 cgroups: fix pid namespace bug This is in preparation for some clashing cgroups changes that subsume the original commit's functionaliy. The original commit fixed a pid namespace bug which Ben Blum fixed independently (in the same way, but with different code) as part of a series of patches. I played around with trying to reconcile Ben's patch series with Li's patch, but concluded that it was simpler to just revert Li's, given that Ben's patch series contained essentially the same fix. Signed-off-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: allow cgroup hierarchies to be created with no bound subsystemsPaul Menage
This patch removes the restriction that a cgroup hierarchy must have at least one bound subsystem. The mount option "none" is treated as an explicit request for no bound subsystems. A hierarchy with no subsystems can be useful for plain task tracking, and is also a step towards the support for multiply-bindable subsystems. As part of this change, the hierarchy id is no longer calculated from the bitmask of subsystems in the hierarchy (since this is not guaranteed to be unique) but is allocated via an ida. Reference counts on cgroups from css_set objects are now taken explicitly one per hierarchy, rather than one per subsystem. Example usage: mount -t cgroup -o none,name=foo cgroup /mnt/cgroup Based on the "no-op"/"none" subsystem concept proposed by kamezawa.hiroyu@jp.fujitsu.com Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: add a back-pointer from struct cg_cgroup_link to struct cgroupPaul Menage
Currently the cgroups code makes the assumption that the subsystem pointers in a struct css_set uniquely identify the hierarchy->cgroup mappings associated with the css_set; and there's no way to directly identify the associated set of cgroups other than by indirecting through the appropriate subsystem state pointers. This patch removes the need for that assumption by adding a back-pointer from struct cg_cgroup_link object to its associated cgroup; this allows the set of cgroups to be determined by traversing the cg_links list in the struct css_set. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: move the cgroup debug subsys into cgroup.c to access internal statePaul Menage
While it's architecturally clean to have the cgroup debug subsystem be completely independent of the cgroups framework, it limits its usefulness for debugging the contents of internal data structures. Move the debug subsystem code into the scope of all the cgroups data structures to make more detailed debugging possible. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: support named cgroups hierarchiesPaul Menage
To simplify referring to cgroup hierarchies in mount statements, and to allow disambiguation in the presence of empty hierarchies and multiply-bindable subsystems this patch adds support for naming a new cgroup hierarchy via the "name=" mount option A pre-existing hierarchy may be specified by either name or by subsystems; a hierarchy's name cannot be changed by a remount operation. Example usage: # To create a hierarchy called "foo" containing the "cpu" subsystem mount -t cgroup -oname=foo,cpu cgroup /mnt/cgroup1 # To mount the "foo" hierarchy on a second location mount -t cgroup -oname=foo cgroup /mnt/cgroup2 Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: make unlock sequence in cgroup_get_sb consistentXiaotian Feng
Make the last unlock sequence consistent with previous unlock sequeue. Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining inode_operations as constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining super_operations constAlexey Dobriyan
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-29cgroup avoid permanent sleep at rmdirKAMEZAWA Hiroyuki
After commit ec64f51545fffbc4cb968f0cea56341a4b07e85a ("cgroup: fix frequent -EBUSY at rmdir"), cgroup's rmdir (especially against memcg) doesn't return -EBUSY by temporary ref counts. That commit expects all refs after pre_destroy() is temporary but...it wasn't. Then, rmdir can wait permanently. This patch tries to fix that and change followings. - set CGRP_WAIT_ON_RMDIR flag before pre_destroy(). - clear CGRP_WAIT_ON_RMDIR flag when the subsys finds racy case. if there are sleeping ones, wakes them up. - rmdir() sleeps only when CGRP_WAIT_ON_RMDIR flag is set. Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Paul Menage <menage@google.com> Acked-by: Balbir Sigh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29cgroups: fix pid namespace bugLi Zefan
The bug was introduced by commit cc31edceee04a7b87f2be48f9489ebb72d264844 ("cgroups: convert tasks file to use a seq_file with shared pid array"). We cache a pid array for all threads that are opening the same "tasks" file, but the pids in the array are always from the namespace of the last process that opened the file, so all other threads will read pids from that namespace instead of their own namespaces. To fix it, we maintain a list of pid arrays, which is keyed by pid_ns. The list will be of length 1 at most time. Reported-by: Paul Menage <menage@google.com> Idea-by: Paul Menage <menage@google.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Serge Hallyn <serue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18cgroups: forbid noprefix if mounting more than just cpuset subsystemLi Zefan
The 'noprefix' option was introduced for backwards-compatibility of cpuset, but actually it can be used when mounting other subsystems. This results in possibility of name collision, and now the collision can really happen, because we have 'stat' file in both memory and cpuacct subsystem: # mount -t cgroup -o noprefix,memory,cpuacct xxx /mnt Cgroup will happily mount the 2 subsystems, but only 'stat' file of memory subsys can be seen. We don't want users to use nopreifx, and also want to avoid name collision, so we change to allow noprefix only if mounting just the cpuset subsystem. [akpm@linux-foundation.org: fix shift for cpuset_subsys_id >= 32] Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-04-02memcg: fix OOM killer under memcgKAMEZAWA Hiroyuki
This patch tries to fix OOM Killer problems caused by hierarchy. Now, memcg itself has OOM KILL function (in oom_kill.c) and tries to kill a task in memcg. But, when hierarchy is used, it's broken and correct task cannot be killed. For example, in following cgroup /groupA/ hierarchy=1, limit=1G, 01 nolimit 02 nolimit All tasks' memory usage under /groupA, /groupA/01, groupA/02 is limited to groupA's 1Gbytes but OOM Killer just kills tasks in groupA. This patch provides makes the bad process be selected from all tasks under hierarchy. BTW, currently, oom_jiffies is updated against groupA in above case. oom_jiffies of tree should be updated. To see how oom_jiffies is used, please check mem_cgroup_oom_called() callers. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: const fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: don't change release_agent when remount failedLi Zefan
Remount can fail in either case: - wrong mount options is specified, or option 'noprefix' is changed. - a to-be-added subsys is already mounted/active. When using remount to change 'release_agent', for the above former failure case, remount will return errno with release_agent unchanged, but for the latter case, remount will return EBUSY with relase_agent changed, which is unexpected I think: # mount -t cgroup -o cpu xxx /cgrp1 # mount -t cgroup -o cpuset,release_agent=agent1 yyy /cgrp2 # cat /cgrp2/release_agent agent1 # mount -t cgroup -o remount,cpuset,noprefix,release_agent=agent2 yyy /cgrp2 mount: /cgrp2 not mounted already, or bad option # cat /cgrp2/release_agent agent1 <-- ok # mount -t cgroup -o remount,cpu,cpuset,release_agent=agent2 yyy /cgrp2 mount: /cgrp2 is busy # cat /cgrp2/release_agent agent2 <-- unexpected! Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: show correct file modeLi Zefan
We have some read-only files and write-only files, but currently they are all set to 0644, which is counter-intuitive and cause trouble for some cgroup tools like libcgroup. This patch adds 'mode' to struct cftype to allow cgroup subsys to set it's own files' file mode, and for the most cases cft->mode can be default to 0 and cgroup will figure out proper mode. Acked-by: Paul Menage <menage@google.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02kernel/cgroup.c: kfree(NULL) is legalJesper Juhl
Reduces object file size a bit: Before: $ size kernel/cgroup.o text data bss dec hex filename 21593 7804 4924 34321 8611 kernel/cgroup.o After: $ size kernel/cgroup.o text data bss dec hex filename 21537 7744 4924 34205 859d kernel/cgroup.o Signed-off-by: Jesper Juhl <jj@chaosbits.net> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroup: fix frequent -EBUSY at rmdirKAMEZAWA Hiroyuki
In following situation, with memory subsystem, /groupA use_hierarchy==1 /01 some tasks /02 some tasks /03 some tasks /04 empty When tasks under 01/02/03 hit limit on /groupA, hierarchical reclaim is triggered and the kernel walks tree under groupA. In this case, rmdir /groupA/04 fails with -EBUSY frequently because of temporal refcnt from the kernel. In general. cgroup can be rmdir'd if there are no children groups and no tasks. Frequent fails of rmdir() is not useful to users. (And the reason for -EBUSY is unknown to users.....in most cases) This patch tries to modify above behavior, by - retries if css_refcnt is got by someone. - add "return value" to pre_destroy() and allows subsystem to say "we're really busy!" Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroup: CSS ID supportKAMEZAWA Hiroyuki
Patch for Per-CSS(Cgroup Subsys State) ID and private hierarchy code. This patch attaches unique ID to each css and provides following. - css_lookup(subsys, id) returns pointer to struct cgroup_subysys_state of id. - css_get_next(subsys, id, rootid, depth, foundid) returns the next css under "root" by scanning When cgroup_subsys->use_id is set, an id for css is maintained. The cgroup framework only parepares - css_id of root css for subsys - id is automatically attached at creation of css. - id is *not* freed automatically. Because the cgroup framework don't know lifetime of cgroup_subsys_state. free_css_id() function is provided. This must be called by subsys. There are several reasons to develop this. - Saving space .... For example, memcg's swap_cgroup is array of pointers to cgroup. But it is not necessary to be very fast. By replacing pointers(8bytes per ent) to ID (2byes per ent), we can reduce much amount of memory usage. - Scanning without lock. CSS_ID provides "scan id under this ROOT" function. By this, scanning css under root can be written without locks. ex) do { rcu_read_lock(); next = cgroup_get_next(subsys, id, root, &found); /* check sanity of next here */ css_tryget(); rcu_read_unlock(); id = found + 1 } while(...) Characteristics: - Each css has unique ID under subsys. - Lifetime of ID is controlled by subsys. - css ID contains "ID" and "Depth in hierarchy" and stack of hierarchy - Allowed ID is 1-65535, ID 0 is UNUSED ID. Design Choices: - scan-by-ID v.s. scan-by-tree-walk. As /proc's pid scan does, scan-by-ID is robust when scanning is done by following kind of routine. scan -> rest a while(release a lock) -> conitunue from interrupted memcg's hierarchical reclaim does this. - When subsys->use_id is set, # of css in the system is limited to 65535. [bharata@linux.vnet.ibm.com: remove rcu_read_lock() from css_get_next()] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: relax ns_can_attach checks to allow attaching to grandchild cgroupsGrzegorz Nosek
The ns_proxy cgroup allows moving processes to child cgroups only one level deep at a time. This commit relaxes this restriction and makes it possible to attach tasks directly to grandchild cgroups, e.g.: ($pid is in the root cgroup) echo $pid > /cgroup/CG1/CG2/tasks Previously this operation would fail with -EPERM and would have to be performed as two steps: echo $pid > /cgroup/CG1/tasks echo $pid > /cgroup/CG1/CG2/tasks Also, the target cgroup no longer needs to be empty to move a task there. Signed-off-by: Grzegorz Nosek <root@localdomain.pl> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27vfs: simple_set_mnt() should return voidSukadev Bhattiprolu
simple_set_mnt() is defined as returning 'int' but always returns 0. Callers assume simple_set_mnt() never fails and don't properly cleanup if it were to _ever_ fail. For instance, get_sb_single() and get_sb_nodev() should: up_write(sb->s_unmount); deactivate_super(sb); if simple_set_mnt() fails. Since simple_set_mnt() never fails, would be cleaner if it did not return anything. [akpm@linux-foundation.org: fix build] Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27constify dentry_operations: restAl Viro
2009-02-18cgroups: fix possible use after freeLi Zefan
In cgroup_kill_sb(), root is freed before sb is detached from the list, so another sget() may find this sb and call cgroup_test_super(), which will access the root that has been freed. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11cgroups: fix lockdep subclasses overflowLi Zefan
I enabled all cgroup subsystems when compiling kernel, and then: # mount -t cgroup -o net_cls xxx /mnt # mkdir /mnt/0 This showed up immediately: BUG: MAX_LOCKDEP_SUBCLASSES too low! turning off the locking correctness validator. It's caused by the cgroup hierarchy lock: for (i = 0; i < CGROUP_SUBSYS_COUNT; i++) { struct cgroup_subsys *ss = subsys[i]; if (ss->root == root) mutex_lock_nested(&ss->hierarchy_mutex, i); } Now we have 9 cgroup subsystems, and the above 'i' for net_cls is 8, but MAX_LOCKDEP_SUBCLASSES is 8. This patch uses different lockdep keys for different subsystems. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29cgroup: fix root_count when mount fails due to busy subsystemPaul Menage
root_count was being incremented in cgroup_get_sb() after all error checking was complete, but decremented in cgroup_kill_sb(), which can be called on a superblock that we gave up on due to an error. This patch changes cgroup_kill_sb() to only decrement root_count if the root was previously linked into the list of roots. Signed-off-by: Paul Menage <menage@google.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29cgroups: add cpu_relax() calls in css_tryget() and cgroup_clear_css_refs()Paul Menage
css_tryget() and cgroup_clear_css_refs() contain polling loops; these loops should have cpu_relax calls in them to reduce cross-cache traffic. Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29cgroups: fix lock inconsistency in cgroup_clone()Li Zefan
I fixed a bug in cgroup_clone() in Linus' tree in commit 7b574b7 ("cgroups: fix a race between cgroup_clone and umount") without noticing there was a cleanup patch in -mm tree that should be rebased (now commit 104cbd5, "cgroups: use task_lock() for access tsk->cgroups safe in cgroup_clone()"), thus resulted in lock inconsistency. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29cgroups: use hierarchy mutex in creation failure pathKAMEZAWA Hiroyuki
Now, cgrp->sibling is handled under hierarchy mutex. error route should do so, too. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Acked-by Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: add css_tryget()Paul Menage
Add css_tryget(), that obtains a counted reference on a CSS. It is used in situations where the caller has a "weak" reference to the CSS, i.e. one that does not protect the cgroup from removal via a reference count, but would instead be cleaned up by a destroy() callback. css_tryget() will return true on success, or false if the cgroup is being removed. This is similar to Kamezawa Hiroyuki's patch from a week or two ago, but with the difference that in the event of css_tryget() racing with a cgroup_rmdir(), css_tryget() will only return false if the cgroup really does get removed. This implementation is done by biasing css->refcnt, so that a refcnt of 1 means "releasable" and 0 means "released or releasing". In the event of a race, css_tryget() distinguishes between "released" and "releasing" by checking for the CSS_REMOVED flag in css->flags. Signed-off-by: Paul Menage <menage@google.com> Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: add a per-subsystem hierarchy_mutexPaul Menage
These patches introduce new locking/refcount support for cgroups to reduce the need for subsystems to call cgroup_lock(). This will ultimately allow the atomicity of cgroup_rmdir() (which was removed recently) to be restored. These three patches give: 1/3 - introduce a per-subsystem hierarchy_mutex which a subsystem can use to prevent changes to its own cgroup tree 2/3 - use hierarchy_mutex in place of calling cgroup_lock() in the memory controller 3/3 - introduce a css_tryget() function similar to the one recently proposed by Kamezawa, but avoiding spurious refcount failures in the event of a race between a css_tryget() and an unsuccessful cgroup_rmdir() Future patches will likely involve: - using hierarchy mutex in place of cgroup_lock() in more subsystems where appropriate - restoring the atomicity of cgroup_rmdir() with respect to cgroup_create() This patch: Add a hierarchy_mutex to the cgroup_subsys object that protects changes to the hierarchy observed by that subsystem. It is taken by the cgroup subsystem (in addition to cgroup_mutex) for the following operations: - linking a cgroup into that subsystem's cgroup tree - unlinking a cgroup from that subsystem's cgroup tree - moving the subsystem to/from a hierarchy (including across the bind() callback) Thus if the subsystem holds its own hierarchy_mutex, it can safely traverse its own hierarchy. Signed-off-by: Paul Menage <menage@google.com> Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: make cgroup_path() RCU-safePaul Menage
Fix races between /proc/sched_debug by freeing cgroup objects via an RCU callback. Thus any cgroup reference obtained from an RCU-safe source will remain valid during the RCU section. Since dentries are also RCU-safe, this allows us to traverse up the tree safely. Additionally, make cgroup_path() check for a NULL cgrp->dentry to avoid trying to report a path for a partially-created cgroup. [lizf@cn.fujitsu.com: call deactive_super() in cgroup_diput()] Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Tested-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: skip processes from other namespaces when listing a cgroupGowrishankar M
Once tasks are populated from system namespace inside cgroup, container replaces other namespace task with 0 while listing tasks, inside container. Though this is expected behaviour from container end, there is no use of showing unwanted 0s. In this patch, we check if a process is in same namespace before loading into pid array. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Gowrishankar M <gowrishankar.m@in.ibm.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: introduce link_css_set() to remove duplicate codeLi Zefan
Add a common function link_css_set() to link a css_set to a cgroup. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: add inactive subsystems to rootnode.subsys_listLi Zefan
Though for an inactive hierarchy, we have subsys->root == &rootnode, but rootnode's subsys_list is always empty. This conflicts with the code in find_css_set(): for (i = 0; i < CGROUP_SUBSYS_COUNT; i++) { ... if (ss->root->subsys_list.next == &ss->sibling) { ... } } if (list_empty(&rootnode.subsys_list)) { ... } The above code assumes rootnode.subsys_list links all inactive hierarchies. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: make root_list contains active hierarchies onlyLi Zefan
Don't link rootnode to the root list, so root_list contains active hierarchies only as the comment indicates. And rename for_each_root() to for_each_active_root(). Also remove redundant check in cgroup_kill_sb(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: remove rcu_read_lock() in cgroupstats_build()Lai Jiangshan
cgroup_iter_* do not need rcu_read_lock(). In cgroup_enable_task_cg_lists(), do_each_thread() and while_each_thread() are protected by RCU, it's OK, for write_lock(&css_set_lock) implies rcu_read_lock() in non-RT kernel. If we need explicit rcu_read_lock(), we should add rcu_read_lock() in cgroup_enable_task_cg_lists(), not cgroup_iter_*. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: call find_css_set() safely in cgroup_attach_task()Lai Jiangshan
In cgroup_attach_task(), tsk maybe exit when we call find_css_set(). and find_css_set() will access to invalid css_set. This patch increases the count before get_css_set(), and decreases it after find_css_set(). NOTE: css_set's refcount is also taskcount, after this patch applied, taskcount may be off-by-one WHEN cgroup_lock() is not held. but I reviewed other code which use taskcount, they are still correct. No regression found by reviewing and simply testing. So I do not use two counters in css_set. (one counter for taskcount, the other for refcount. like struct mm_struct) If this fix cause regression, we will use two counters in css_set. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: use task_lock() for access tsk->cgroups safe in cgroup_clone()Lai Jiangshan
Use task_lock() protect tsk->cgroups and get_css_set(tsk->cgroups). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: don't put struct cgroupfs_root protected by RCULai Jiangshan
We don't access struct cgroupfs_root in fast path, so we should not put struct cgroupfs_root protected by RCU But the comment in struct cgroup_subsys.root confuse us. struct cgroup_subsys.root is used in these places: 1 find_css_set(): if (ss->root->subsys_list.next == &ss->sibling) 2 rebind_subsystems(): if (ss->root != &rootnode) rcu_assign_pointer(ss->root, root); rcu_assign_pointer(subsys[i]->root, &rootnode); 3 cgroup_has_css_refs(): if (ss->root != cgrp->root) 4 cgroup_init_subsys(): ss->root = &rootnode; 5 proc_cgroupstats_show(): ss->name, ss->root->subsys_bits, ss->root->number_of_cgroups, !ss->disabled); 6 cgroup_clone(): root = subsys->root; if ((root != subsys->root) || All these place we have held cgroup_lock() or we don't dereference to struct cgroupfs_root. It's means wo don't need RCU when use struct cgroup_subsys.root, and we should not put struct cgroupfs_root protected by RCU. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Reviewed-by: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
