commit feae3203d711db0a9965300ee6d592257fdaae4f upstream.
Limit the number of per cpu calibration messages by only
printing out results for the first cpu to boot.
Also, don't print "CPUx is down" as this is expected, and we
don't need 4096 reminders... ;-)
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Tejun Heo <tj@kernel.org>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Jack Steiner <steiner@sgi.com>
LKML-Reference: <20091118002219.889552000@alcatraz.americas.sgi.com>
commit 6ad4c18884e864cf4c77f9074d3d1816063f99cd upstream.
Since (e761b77: cpu hotplug, sched: Introduce cpu_active_map and redo
sched domain managment) we have cpu_active_mask which is suppose to rule
scheduler migration and load-balancing, except it never (fully) did.
The particular problem being solved here is a crash in try_to_wake_up()
where select_task_rq() ends up selecting an offline cpu because
select_task_rq_fair() trusts the sched_domain tree to reflect the
current state of affairs, similarly select_task_rq_rt() trusts the
root_domain.
However, the sched_domains are updated from CPU_DEAD, which is after the
cpu is taken offline and after stop_machine is done. Therefore it can
race perfectly well with code assuming the domains are right.
Cure this by building the domains from cpu_active_mask on
CPU_DOWN_PREPARE.
LKML-Reference: <new-submission>
Cc: Holger Hoffstätte <holger.hoffstaette@googlemail.com>
* 'x86-pat-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, pat: Fix cacheflush address in change_page_attr_set_clr()
mm: remove !NUMA condition from PAGEFLAGS_EXTENDED condition set
x86: Fix earlyprintk=dbgp for machines without NX
x86, pat: Sanity check remap_pfn_range for RAM region
x86, pat: Lookup the protection from memtype list on vm_insert_pfn()
x86, pat: Add lookup_memtype to get the current memtype of a paddr
x86, pat: Use page flags to track memtypes of RAM pages
x86, pat: Generalize the use of page flag PG_uncached
x86, pat: Add rbtree to do quick lookup in memtype tracking
x86, pat: Add PAT reserve free to io_mapping* APIs
x86, pat: New i/f for driver to request memtype for IO regions
x86, pat: ioremap to follow same PAT restrictions as other PAT users
x86, pat: Keep identity maps consistent with mmaps even when pat_disabled
x86, mtrr: make mtrr_aps_delayed_init static bool
x86, pat/mtrr: Rendezvous all the cpus for MTRR/PAT init
generic-ipi: Allow cpus not yet online to call smp_call_function with irqs disabled
x86: Fix an incorrect argument of reserve_bootmem()
x86: Fix system crash when loading with "reservetop" parameter
Move tboot.h from asm to linux to fix the build errors of intel_txt
patch on non-X86 platforms. Remove the tboot code from generic code
init/main.c and kernel/cpu.c.
Signed-off-by: Shane Wang <shane.wang@intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
SDM Vol 3a section titled "MTRR considerations in MP systems" specifies
the need for synchronizing the logical cpu's while initializing/updating
MTRR.
Currently Linux kernel does the synchronization of all cpu's only when
a single MTRR register is programmed/updated. During an AP online
(during boot/cpu-online/resume) where we initialize all the MTRR/PAT registers,
we don't follow this synchronization algorithm.
This can lead to scenarios where during a dynamic cpu online, that logical cpu
is initializing MTRR/PAT with cache disabled (cr0.cd=1) etc while other logical
HT sibling continue to run (also with cache disabled because of cr0.cd=1
on its sibling).
Starting from Westmere, VMX transitions with cr0.cd=1 don't work properly
(because of some VMX performance optimizations) and the above scenario
(with one logical cpu doing VMX activity and another logical cpu coming online)
can result in system crash.
Fix the MTRR initialization by doing rendezvous of all the cpus. During
boot and resume, we delay the MTRR/PAT init for APs till all the
logical cpu's come online and the rendezvous process at the end of AP's bringup,
will initialize the MTRR/PAT for all AP's.
For dynamic single cpu online, we synchronize all the logical cpus and
do the MTRR/PAT init on the AP that is coming online.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Support for graceful handling of sleep states (S3/S4/S5) after an Intel(R) TXT launch.
Without this patch, attempting to place the system in one of the ACPI sleep
states (S3/S4/S5) will cause the TXT hardware to treat this as an attack and
will cause a system reset, with memory locked. Not only may the subsequent
memory scrub take some time, but the platform will be unable to enter the
requested power state.
This patch calls back into the tboot so that it may properly and securely clean
up system state and clear the secrets-in-memory flag, after which it will place
the system into the requested sleep state using ACPI information passed by the kernel.
arch/x86/kernel/smpboot.c | 2 ++
drivers/acpi/acpica/hwsleep.c | 3 +++
kernel/cpu.c | 7 ++++++-
3 files changed, 11 insertions(+), 1 deletion(-)
Signed-off-by: Joseph Cihula <joseph.cihula@intel.com>
SLAB uses get/put_online_cpus() which use a mutex which is itself only
initialized when cpu_hotplug_init() is called. Currently we hang suring
boot in SLAB due to doing that too late.
Reported by James Bottomley and Sachin Sant (and possibly others).
Debugged by Benjamin Herrenschmidt.
This just removes the dynamic initialization of the data structures, and
replaces it with a static one, avoiding this dependency entirely, and
removing one unnecessary special initcall.
Tested-by: Sachin Sant <sachinp@in.ibm.com>
Tested-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
cpu_active_map is deprecated in favor of cpu_active_mask, which is
const for safety: we use accessors now (set_cpu_active) is we really
want to make a change.
disable_nonboot_cpus calls _cpu_down. But _cpu_down requires that the
caller already created the stop_machine workqueue (like cpu_down does).
Otherwise a call to stop_machine will lead to accesses to random memory
regions.
When introducing this new interface (9ea09af3bd3090e8349ca2899ca2011bd94cda85
"stop_machine: introduce stop_machine_create/destroy") I missed the second
call site of _cpu_down.
So add the missing stop_machine_create/destroy calls to disable_nonboot_cpus
as well.
Fixes suspend-to-ram/disk and also this bug:
[ 286.547348] BUG: unable to handle kernel paging request at 6b6b6b6b
[ 286.548940] IP: [<c0150ca4>] __stop_machine+0x88/0xe3
[ 286.550598] Oops: 0002 [#1] SMP
[ 286.560580] Pid: 3273, comm: halt Not tainted (2.6.28-06127-g238c6d5
[ 286.560580] EIP: is at __stop_machine+0x88/0xe3
[ 286.560580] Process halt (pid: 3273, ti=f1a28000 task=f4530f30
[ 286.560580] Call Trace:
[ 286.560580] [<c03d04e4>] ? _cpu_down+0x10f/0x234
[ 286.560580] [<c012a57e>] ? disable_nonboot_cpus+0x58/0xdc
[ 286.560580] [<c01360c0>] ? kernel_poweroff+0x22/0x39
[ 286.560580] [<c0136301>] ? sys_reboot+0xde/0x14c
[ 286.560580] [<c01331b2>] ? complete_signal+0x179/0x191
[ 286.560580] [<c0133396>] ? send_signal+0x1cc/0x1e1
[ 286.560580] [<c03de418>] ? _spin_unlock_irqrestore+0x2d/0x3c
[ 286.560580] [<c0133b65>] ? group_send_signal_info+0x58/0x61
[ 286.560580] [<c0133b9e>] ? kill_pid_info+0x30/0x3a
[ 286.560580] [<c0133d49>] ? sys_kill+0x75/0x13a
[ 286.560580] [<c01a06cb>] ? mntput_no_expire+ox1f/0x101
[ 286.560580] [<c019b3b3>] ? dput+0x1e/0x105
[ 286.560580] [<c018ef87>] ? __fput+0x150/0x158
[ 286.560580] [<c0157abf>] ? audit_syscall_entry+0x137/0x159
[ 286.560580] [<c010329f>] ? sysenter_do_call+0x12/0x34
Reported-and-tested-by: "Justin P. Mattock" <justinmattock@gmail.com>
Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi>
Tested-by: Ingo Molnar <mingo@elte.hu>
Introduce stop_machine_create/destroy. With this interface subsystems
that need a non-failing stop_machine environment can create the
stop_machine machine threads before actually calling stop_machine.
When the threads aren't needed anymore they can be killed with
stop_machine_destroy again.
When stop_machine gets called and the threads aren't present they
will be created and destroyed automatically. This restores the old
behaviour of stop_machine.
This patch also converts cpu hotplug to the new interface since it
is special: cpu_down calls __stop_machine instead of stop_machine.
However the kstop threads will only be created when stop_machine
gets called.
Changing the code so that the threads would be created automatically
on __stop_machine is currently not possible: when __stop_machine gets
called we hold cpu_add_remove_lock, which is the same lock that
create_rt_workqueue would take. So the workqueue needs to be created
before the cpu hotplug code locks cpu_add_remove_lock.
Impact: Reduce kernel stack and memory usage, use new cpumask API.
Use cpumask_var_t for take_cpu_down() stack var, and frozen_cpus.
Note that notify_cpu_starting() can be called before core_initcall
allocates frozen_cpus, but the NULL check is optimized out by gcc for
the CONFIG_CPUMASK_OFFSTACK=n case.
They're only for use in boot/cpu hotplug code anyway, and this avoids
the use of deprecated cpu_*_map.
Stephen Rothwell points out that gcc 4.2.4 (on powerpc at least)
didn't like the cast away of const anyway:
include/linux/cpumask.h: In function 'set_cpu_possible':
include/linux/cpumask.h:1052: warning: passing argument 2 of 'cpumask_set_cpu' discards qualifiers from pointer target type
So this kills two birds with one stone.
Impact: cleanup
This implements the obsolescent cpu_online_map in terms of
cpu_online_mask, rather than the other way around. Same for the other
maps.
The documentation comments are also updated to refer to _mask rather
than _map.
Impact: cleanup
Each SMP arch defines these themselves. Move them to a central
location.
Twists:
1) Some archs (m32, parisc, s390) set possible_map to all 1, so we add a
CONFIG_INIT_ALL_POSSIBLE for this rather than break them.
2) mips and sparc32 '#define cpu_possible_map phys_cpu_present_map'.
Those archs simply have phys_cpu_present_map replaced everywhere.
3) Alpha defined cpu_possible_map to cpu_present_map; this is tricky
so I just manipulate them both in sync.
4) IA64, cris and m32r have gratuitous 'extern cpumask_t cpu_possible_map'
declarations.
Reviewed-by: Grant Grundler <grundler@parisc-linux.org>
Tested-by: Tony Luck <tony.luck@intel.com>
Cc: Mike Travis <travis@sgi.com>
Cc: ink@jurassic.park.msu.ru
Cc: rmk@arm.linux.org.uk
Cc: starvik@axis.com
Cc: tony.luck@intel.com
Cc: takata@linux-m32r.org
Cc: ralf@linux-mips.org
Cc: grundler@parisc-linux.org
Cc: paulus@samba.org
Cc: schwidefsky@de.ibm.com
Cc: lethal@linux-sh.org
Cc: wli@holomorphy.com
Cc: davem@davemloft.net
Cc: jdike@addtoit.com
Cc: mingo@redhat.com
Impact: introduce new APIs
We want to deprecate cpumasks on the stack, as we are headed for
gynormous numbers of CPUs. Eventually, we want to head towards an
undefined 'struct cpumask' so they can never be declared on stack.
1) New cpumask functions which take pointers instead of copies.
(cpus_* -> cpumask_*)
2) Several new helpers to reduce requirements for temporary cpumasks
(cpumask_first_and, cpumask_next_and, cpumask_any_and)
3) Helpers for declaring cpumasks on or offstack for large NR_CPUS
(cpumask_var_t, alloc_cpumask_var and free_cpumask_var)
4) 'struct cpumask' for explicitness and to mark new-style code.
5) Make iterator functions stop at nr_cpu_ids (a runtime constant),
not NR_CPUS for time efficiency and for smaller dynamic allocations
in future.
6) cpumask_copy() so we can allocate less than a full cpumask eventually
(for alloc_cpumask_var), and so we can eliminate the 'struct cpumask'
definition eventually.
7) work_on_cpu() helper for doing task on a CPU, rather than saving old
cpumask for current thread and manipulating it.
8) smp_call_function_many() which is smp_call_function_mask() except
taking a cpumask pointer.
Note that this patch simply introduces the new functions and leaves
the obsolescent ones in place. This is to simplify the transition
patches.
'sched/urgent' into sched/core
Right now, there is no notifier that is called on a new cpu, before the new
cpu begins processing interrupts/softirqs.
Various kernel function would need that notification, e.g. kvm works around
by calling smp_call_function_single(), rcu polls cpu_online_map.
The patch adds a CPU_STARTING notification. It also adds a helper function
that sends the message to all cpu_chain handlers.
Tested on x86-64.
All other archs are untested. Especially on sparc, I'm not sure if I got
it right.
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
When a cpu is taken offline, the CPU_DYING notifiers are called on the
dying cpu. According to <linux/notifiers.h>, the cpu should be "not
running any task, not handling interrupts, soon dead".
For the current implementation, this is not true:
- __cpu_disable can fail. If it fails, then the cpu will remain alive
and happy.
- At least on x86, __cpu_disable() briefly enables the local interrupts
to handle any outstanding interrupts.
What about moving CPU_DYING down a few lines, behind the __cpu_disable()
line?
There are only two CPU_DYING handlers in the kernel right now: one in
kvm, one in the scheduler. Both should work with the patch applied
[and: I'm not sure if either one handles a failing __cpu_disable()]
The patch survives simple offlining a cpu. kvm untested due to lack
of a test setup.
Signed-off-By: Manfred Spraul <manfred@colorfullife.com>
s390 doesn't support the additional_cpus kernel parameter anymore since a
long time. So we better update the code and documentation to reflect
that.
Mark Langsdorf reported:
> One of my co-workers noticed that the powernow-k8
> driver no longer restarts when a CPU core is
> hot-disabled and then hot-enabled on AMD quad-core
> systems.
> The following comands work fine on 2.6.26 and fail
> on 2.6.27-rc1:
> echo 0 > /sys/devices/system/cpu/cpu3/online
> echo 1 > /sys/devices/system/cpu/cpu3/online
> find /sys -name cpufreq
> For 2.6.26, the find will return a cpufreq
> directory for each processor. In 2.6.27-rc1,
> the cpu3 directory is missing.
> After digging through the code, the following
> logic is failing when the core is hot-enabled
> at runtime. The code works during the boot
> sequence.
> cpumask_t = current->cpus_allowed;
> set_cpus_allowed_ptr(current, &cpumask_of_cpu(cpu));
> if (smp_processor_id() != cpu)
> return -ENODEV;
So set the CPU active before calling the CPU_ONLINE notifier chain,
there are a handful of notifiers that use set_cpus_allowed().
This fix also solves the problem with x86-microcode. I've sent
alternative patches for microcode, but as this "rely on
set_cpus_allowed_ptr() being workable in cpu-hotplug(CPU_ONLINE, ...)"
assumption seems to be more broad than what we thought, perhaps this fix
should be applied.
With this patch we define that by the moment CPU_ONLINE is being sent,
a 'cpu' is online and ready for tasks to be migrated onto it.
Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com>
Reported-by: Mark Langsdorf <mark.langsdorf@amd.com>
Tested-by: Mark Langsdorf <mark.langsdorf@amd.com>
kernel/stop_machine.c
Clean up and optimize cpumask_of_cpu(), by sharing all the zero words.
Instead of stupidly generating all possible i=0...NR_CPUS 2^i patterns
creating a huge array of constant bitmasks, realize that the zero words
can be shared.
In other words, on a 64-bit architecture, we only ever need 64 of these
arrays - with a different bit set in one single world (with enough zero
words around it so that we can create any bitmask by just offsetting in
that big array). And then we just put enough zeroes around it that we
can point every single cpumask to be one of those things.
So when we have 4k CPU's, instead of having 4k arrays (of 4k bits each,
with one bit set in each array - 2MB memory total), we have exactly 64
arrays instead, each 8k bits in size (64kB total).
And then we just point cpumask(n) to the right position (which we can
calculate dynamically). Once we have the right arrays, getting
"cpumask(n)" ends up being:
static inline const cpumask_t *get_cpu_mask(unsigned int cpu)
const unsigned long *p = cpu_bit_bitmap[1 + cpu % BITS_PER_LONG];
p -= cpu / BITS_PER_LONG;
return (const cpumask_t *)p;
This brings other advantages and simplifications as well:
- we are not wasting memory that is just filled with a single bit in
various different places
- we don't need all those games to re-create the arrays in some dense
format, because they're already going to be dense enough.
if we compile a kernel for up to 4k CPU's, "wasting" that 64kB of memory
is a non-issue (especially since by doing this "overlapping" trick we
probably get better cache behaviour anyway).
[ mingo@elte.hu:
Converted Linus's mails into a commit. See:
http://lkml.org/lkml/2008/7/27/156
http://lkml.org/lkml/2008/7/28/320
Also applied a family filter - which also has the side-effect of leaving
out the bits where Linus calls me an idio... Oh, never mind ;-)
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Instead of a "cpu" arg with magic values NR_CPUS (any cpu) and ~0 (all
cpus), pass a cpumask_t. Allow NULL for the common case (where we
don't care which CPU the function is run on): temporary cpumask_t's
are usually considered bad for stack space.
This deprecates stop_machine_run, to be removed soon when all the
callers are dead.
Akinobu points out that if take_cpu_down() succeeds, the cpu must be offline.
Remove the cpu_online() check, and put a BUG_ON().
Quoting Akinobu Mita:
Actually the cpu_online() check was necessary before appling this
stop_machine: simplify patch.
With old __stop_machine_run(), __stop_machine_run() could succeed
(return !IS_ERR(p) value) even if take_cpu_down() returned non-zero value.
The return value of take_cpu_down() was obtained through kthread_stop()..
Cc: "Akinobu Mita" <akinobu.mita@gmail.com>
stop_machine creates a kthread which creates kernel threads. We can
create those threads directly and simplify things a little. Some care
must be taken with CPU hotunplug, which has special needs, but that code
seems more robust than it was in the past.
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
fix:
ERROR: "cpumask_of_cpu_map" [drivers/acpi/processor.ko] undefined!
ERROR: "cpumask_of_cpu_map" [arch/x86/kernel/microcode.ko] undefined!
ERROR: "cpumask_of_cpu_map" [arch/x86/kernel/cpu/cpufreq/speedstep-ich.ko] undefined!
ERROR: "cpumask_of_cpu_map" [arch/x86/kernel/cpu/cpufreq/acpi-cpufreq.ko] undefined!
* Create the cpumask_of_cpu_map statically in the init data section
using NR_CPUS but replace it during boot up with one sized by
nr_cpu_ids (num possible cpus).
If an arch doesn't define cpumask_of_cpu_map, create a generic
statically-initialized one for them. This allows removal of the buggy
cpumask_of_cpu() macro (&cpumask_of_cpu() gives address of
out-of-scope var).
An arch with NR_CPUS of 4096 probably wants to allocate this itself
based on the actual number of CPUs, since otherwise they're using 2MB
of rodata (1024 cpus means 128k). That's what
CONFIG_HAVE_CPUMASK_OF_CPU_MAP is for (only x86/64 does so at the
moment).
In future as we support more CPUs, we'll need to resort to a
get_cpu_map()/put_cpu_map() allocation scheme.
workqueue_cpu_callback(CPU_DEAD) flushes cwq->thread under
cpu_maps_update_begin(). This means that the multithreaded workqueues
can't use get_online_cpus() due to the possible deadlock, very bad and
very old problem.
Introduce the new state, CPU_POST_DEAD, which is called after
cpu_hotplug_done() but before cpu_maps_update_done().
Change workqueue_cpu_callback() to use CPU_POST_DEAD instead of CPU_DEAD.
This means that create/destroy functions can't rely on get_online_cpus()
any longer and should take cpu_add_remove_lock instead.
[akpm@linux-foundation.org: fix CONFIG_SMP=n]
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Acked-by: Gautham R Shenoy <ego@in.ibm.com>
Cc: Max Krasnyansky <maxk@qualcomm.com>
Cc: Paul Jackson <pj@sgi.com>
Cc: Paul Menage <menage@google.com>
Cc: Vegard Nossum <vegard.nossum@gmail.com>
* 'sched/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: hrtick_enabled() should use cpu_active()
sched, x86: clean up hrtick implementation
sched: fix build error, provide partition_sched_domains() unconditionally
sched: fix warning in inc_rt_tasks() to not declare variable 'rq' if it's not needed
cpu hotplug: Make cpu_active_map synchronization dependency clear
cpu hotplug, sched: Introduce cpu_active_map and redo sched domain managment (take 2)
sched: rework of "prioritize non-migratable tasks over migratable ones"
sched: reduce stack size in isolated_cpu_setup()
Revert parts of "ftrace: do not trace scheduler functions"
Fixed up conflicts in include/asm-x86/thread_info.h (due to the
TIF_SINGLESTEP unification vs TIF_HRTICK_RESCHED removal) and
kernel/sched_fair.c (due to cpu_active_map vs for_each_cpu_mask_nr()
introduction).
drivers/acpi/processor_throttling.c
This goes on top of the cpu_active_map (take 2) patch.
Currently we depend on the stop_machine to provide nescessesary
synchronization for the cpu_active_map updates.
As Dmitry Adamushko pointed this is fragile and is not much clearer
than the previous scheme. In other words we do not want to depend on
the internal stop machine operation here.
So make the synchronization rules clear by doing synchronize_sched()
after clearing out cpu active bit.
Tested on quad-Core2 with:
while true; do
for i in 1 2 3; do
echo 0 > /sys/devices/system/cpu/cpu$i/online
done
for i in 1 2 3; do
echo 1 > /sys/devices/system/cpu/cpu$i/online
done
done
and
stress -c 200
No lockdep, preempt or other complaints.
Signed-off-by: Max Krasnyansky <maxk@qualcomm.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
(take 2)
This is based on Linus' idea of creating cpu_active_map that prevents
scheduler load balancer from migrating tasks to the cpu that is going
down.
It allows us to simplify domain management code and avoid unecessary
domain rebuilds during cpu hotplug event handling.
Please ignore the cpusets part for now. It needs some more work in order
to avoid crazy lock nesting. Although I did simplfy and unify domain
reinitialization logic. We now simply call partition_sched_domains() in
all the cases. This means that we're using exact same code paths as in
cpusets case and hence the test below cover cpusets too.
Cpuset changes to make rebuild_sched_domains() callable from various
contexts are in the separate patch (right next after this one).
This not only boots but also easily handles
while true; do make clean; make -j 8; done
and
while true; do on-off-cpu 1; done
at the same time.
(on-off-cpu 1 simple does echo 0/1 > /sys/.../cpu1/online thing).
Suprisingly the box (dual-core Core2) is quite usable. In fact I'm typing
this on right now in gnome-terminal and things are moving just fine.
Also this is running with most of the debug features enabled (lockdep,
mutex, etc) no BUG_ONs or lockdep complaints so far.
I believe I addressed all of the Dmitry's comments for original Linus'
version. I changed both fair and rt balancer to mask out non-active cpus.
And replaced cpu_is_offline() with !cpu_active() in the main scheduler
code where it made sense (to me).
Signed-off-by: Max Krasnyanskiy <maxk@qualcomm.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Gregory Haskins <ghaskins@novell.com>
Cc: dmitry.adamushko@gmail.com
Cc: pj@sgi.com
The ACPI device node for the cpu has already been unregistered
when acpi_processor_handle_eject is called.
Thus we should offline the cpu and continue, rather than a failure here.
http://bugzilla.kernel.org/show_bug.cgi?id=9772
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
arch/x86/xen/smp.c
kernel/sched_rt.c
net/iucv/iucv.c
kernel/cpu.c seems a more logical place for those maps since they do not really
have much to do with the scheduler these days.
kernel/cpu.c is now built for the UP kernel too, but it does not affect the size
the kernel sections.
$ size vmlinux
before
3313797 307060 310352 3931209 3bfc49 vmlinux
after
Cc: pj@sgi.com
Cc: menage@google.com
Cc: rostedt@goodmis.org
Cc: mingo@elte.hu
Change references from for_each_cpu_mask to for_each_cpu_mask_nr
where appropriate
Reviewed-by: Paul Jackson <pj@sgi.com>
Reviewed-by: Christoph Lameter <clameter@sgi.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
cpu_hotplug_begin() must be always called under cpu_add_remove_lock, this
means that only one process can be cpu_hotplug.active_writer. So we don't
need the cpu_hotplug.writer_queue, we can wake up the ->active_writer
directly.
Also, fix the comment.
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com>
Fix following warnings:
WARNING: vmlinux.o(.text+0xc60): Section mismatch in reference from the function kvm_init() to the function .cpuinit.text:register_cpu_notifier()
WARNING: vmlinux.o(.text+0x33869a): Section mismatch in reference from the function xfs_icsb_init_counters() to the function .cpuinit.text:register_cpu_notifier()
WARNING: vmlinux.o(.text+0x5556a1): Section mismatch in reference from the function acpi_processor_install_hotplug_notify() to the function .cpuinit.text:register_cpu_notifier()
WARNING: vmlinux.o(.text+0xfe6b28): Section mismatch in reference from the function cpufreq_register_driver() to the function .cpuinit.text:register_cpu_notifier()
register_cpu_notifier() are only really defined when HOTPLUG_CPU is enabled.
So references to the function are OK.
Annotate it with __ref so we do not get warnings from callers and do not get
warnings for the functions/data used by register_cpu_notifier().
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Gautham R Shenoy <ego@in.ibm.com>
WARNING: vmlinux.o(.text+0x75c8d): Section mismatch in reference from the function take_cpu_down() to the variable .cpuinit.data:cpu_chain
WARNING: vmlinux.o(.text+0x75d2a): Section mismatch in reference from the function _cpu_down() to the variable .cpuinit.data:cpu_chain
WARNING: vmlinux.o(.text+0x75d4d): Section mismatch in reference from the function _cpu_down() to the variable .cpuinit.data:cpu_chain
WARNING: vmlinux.o(.text+0x75de4): Section mismatch in reference from the function _cpu_down() to the variable .cpuinit.data:cpu_chain
WARNING: vmlinux.o(.text+0x75e33): Section mismatch in reference from the function _cpu_down() to the variable .cpuinit.data:cpu_chain
cpu_down is only used from code surrounded by HOTPLUG_CPU so any references to
__cpuinit is OK.
Add a few __ref to tech modpost to ignore the references.
This is just papering over the fact that the cpu hotplug code is fragile with
respect to use of HOTPLUG_CPU and in many cases rely on __cpuinit to get rid
of code when HOTPLUG_CPU is not enabled. For now this is the least invasive
change.
Fix following warning:
WARNING: vmlinux.o(.text+0x75f4e): Section mismatch in reference from the function unregister_cpu_notifier() to the variable .cpuinit.data:cpu_chain
We know that unregister_cpu_notifier is using HOTPLUG_CPU
stuff - so ignore these references.
Annotating unregister_cpu_notifier had been another option
but this caused far more warnings since not all callers were
annotated __cpuinit.
* Use new set_cpus_allowed_ptr() function added by previous patch,
which instead of passing the "newly allowed cpus" cpumask_t arg
by value, pass it by pointer:
-int set_cpus_allowed(struct task_struct *p, cpumask_t new_mask)
+int set_cpus_allowed_ptr(struct task_struct *p, const cpumask_t *new_mask)
* Modify CPU_MASK_ALL
Depends on:
[sched-devel]: sched: add new set_cpus_allowed_ptr function
WARNING: o-x86_64/kernel/built-in.o(.text+0x36d8b): Section mismatch in reference from the function enable_nonboot_cpus() to the function .cpuinit.text:_cpu_up()
enable_nonboot_cpus() are used solely from CONFIG_CONFIG_PM_SLEEP_SMP=y
and PM_SLEEP_SMP imply HOTPLUG_CPU therefore the reference
to _cpu_up() is valid.
Annotate enable_nonboot_cpus() with __ref to silence modpost.
This patch converts the known per-subsystem mutexes to get_online_cpus
put_online_cpus. It also eliminates the CPU_LOCK_ACQUIRE and
CPU_LOCK_RELEASE hotplug notification events.
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use
get_online_cpus and put_online_cpus instead as it highlights the
refcount semantics in these operations.
The new API guarantees protection against the cpu-hotplug operation, but
it doesn't guarantee serialized access to any of the local data
structures. Hence the changes needs to be reviewed.
In case of pseries_add_processor/pseries_remove_processor, use
cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the
cpu_present_map there.
This patch implements a Refcount + Waitqueue based model for
cpu-hotplug.
Now, a thread which wants to prevent cpu-hotplug, will bump up a global
refcount and the thread which wants to perform a cpu-hotplug operation
will block till the global refcount goes to zero.
The readers, if any, during an ongoing cpu-hotplug operation are blocked
until the cpu-hotplug operation is over.
Signed-off-by: Paul Jackson <pj@sgi.com> [For !CONFIG_HOTPLUG_CPU ]
cpu-hot-add should be fail if cpu is not set in cpu_possible_map. If go
ahead, the system will panic soon.
Especially, arch which requires additional_cpus= parameter should handle
this. Tested on ia64.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
The task_struct->pid member is going to be deprecated, so start
using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in
the kernel.
The first thing to start with is the pid, printed to dmesg - in
this case we may safely use task_pid_nr(). Besides, printks produce
more (much more) than a half of all the explicit pid usage.
[akpm@linux-foundation.org: git-drm went and changed lots of stuff]
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Airlie <airlied@linux.ie>
