path: root/kernel/cpu_pm.c
2012-05-31kernel/cpu_pm.c: fix various typosNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@linaro.org> Acked-by: Colin Cross <ccross@android.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-23cpu_pm: call notifiers during suspendColin Cross
Implements syscore_ops in cpu_pm to call the cpu and cpu cluster notifiers during suspend and resume, allowing drivers receiving the notifications to avoid implementing syscore_ops. Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Tested-and-Acked-by: Shawn Guo <shawn.guo@linaro.org> Tested-by: Vishwanath BS <vishwanath.bs@ti.com>
2011-09-23cpu_pm: Add cpu power management notifiersColin Cross
During some CPU power modes entered during idle, hotplug and suspend, peripherals located in the CPU power domain, such as the GIC, localtimers, and VFP, may be powered down. Add a notifier chain that allows drivers for those peripherals to be notified before and after they may be reset. Notified drivers can include VFP co-processor, interrupt controller and it's PM extensions, local CPU timers context save/restore which shouldn't be interrupted. Hence CPU PM event APIs must be called with interrupts disabled. Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Tested-and-Acked-by: Shawn Guo <shawn.guo@linaro.org> Tested-by: Kevin Hilman <khilman@ti.com> Tested-by: Vishwanath BS <vishwanath.bs@ti.com>
