path: root/kernel/crash_dump.c
2011-03-23crash_dump: export is_kdump_kernel to modules, consolidate elfcorehdr_addr, ↵Olaf Hering
setup_elfcorehdr and saved_max_pfn The Xen PV drivers in a crashed HVM guest can not connect to the dom0 backend drivers because both frontend and backend drivers are still in connected state. To run the connection reset function only in case of a crashdump, the is_kdump_kernel() function needs to be available for the PV driver modules. Consolidate elfcorehdr_addr, setup_elfcorehdr and saved_max_pfn into kernel/crash_dump.c Also export elfcorehdr_addr to make is_kdump_kernel() usable for modules. Leave 'elfcorehdr' as early_param(). This changes powerpc from __setup() to early_param(). It adds an address range check from x86 also on ia64 and powerpc. [akpm@linux-foundation.org: additional #includes] [akpm@linux-foundation.org: remove elfcorehdr_addr export] [akpm@linux-foundation.org: fix for Tejun's mm/nobootmem.c changes] Signed-off-by: Olaf Hering <olaf@aepfle.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-10[PATCH] kdump: read previous kernel's memoryVivek Goyal
- Moving the crash_dump.c file to arch dependent part as kmap_atomic_pfn is specific to i386 and highmem may not exist in other archs. - Use ioremap for x86_64 to map the previous kernel memory. - In copy_oldmem_page(), we now directly copy to the user/kernel buffer and avoid the unneccesary copy to a kmalloc'd page. Signed-off-by: Rachita Kothiyal <rachita@in.ibm.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] powerpc: Add arch-dependent copy_oldmem_pageMichael Ellerman
Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-07-27[PATCH] kernel/crash_dump.c: add kerneldocRandy Dunlap
Add kerneldoc to kernel/crash_dump.c Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Access dump file in elf format (/proc/vmcore)Vivek Goyal
From: "Vivek Goyal" <vgoyal@in.ibm.com> o Support for /proc/vmcore interface. This interface exports elf core image either in ELF32 or ELF64 format, depending on the format in which elf headers have been stored by crashed kernel. o Added support for CONFIG_VMCORE config option. o Removed the dependency on /proc/kcore. From: "Eric W. Biederman" <ebiederm@xmission.com> This patch has been refactored to more closely match the prevailing style in the affected files. And to clearly indicate the dependency between /proc/kcore and proc/vmcore.c From: Hariprasad Nellitheertha <hari@in.ibm.com> This patch contains the code that provides an ELF format interface to the previous kernel's memory post kexec reboot. Signed off by Hariprasad Nellitheertha <hari@in.ibm.com> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Retrieve elfcorehdr address from command lineVivek Goyal
This patch adds support for retrieving the address of elf core header if one is passed in command line. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Routines for copying dump pagesVivek Goyal
This patch provides the interfaces necessary to read the dump contents, treating it as a high memory device. Signed off by Hariprasad Nellitheertha <hari@in.ibm.com> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
