path: root/kernel/debug
2010-05-20kgdb: Add the ability to schedule a breakpoint via a taskletJason Wessel
Some kgdb I/O modules require the ability to create a breakpoint tasklet, such as kgdboc and external modules such as kgdboe. The breakpoint tasklet is used as an asynchronous entry point into the debugger which will have a different function scope than the current execution path where it might not be safe to have an inline breakpoint. This is true of some of the kgdb I/O drivers which share code with kgdb and rest of the kernel users. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-05-20x86,kgdb: Add low level debug hookJason Wessel
The only way the debugger can handle a trap in inside rcu_lock, notify_die, or atomic_notifier_call_chain without a triple fault is to have a low level "first opportunity handler" in the int3 exception handler. Generally this will be something the vast majority of folks will not need, but for those who need it, it is added as a kernel .config option called KGDB_LOW_LEVEL_TRAP. CC: Ingo Molnar <mingo@elte.hu> CC: Thomas Gleixner <tglx@linutronix.de> CC: H. Peter Anvin <hpa@zytor.com> CC: x86@kernel.org Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-05-20kgdb: remove post_primary_code referencesJason Wessel
Remove all the references to the kgdb_post_primary_code. This function serves no useful purpose because you can obtain the same information from the "struct kgdb_state *ks" from with in the debugger, if for some reason you want the data. Also remove the unintentional duplicate assignment for ks->ex_vector. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-05-20kgdboc,keyboard: Keyboard driver for kdb with kgdbJason Wessel
This patch adds in the kdb PS/2 keyboard driver. This was mostly a direct port from the original kdb where I cleaned up the code against checkpatch.pl and added the glue to stitch it into kgdb. This patch also enables early kdb debug via kgdbwait and the keyboard. All the access to configure kdb using either a serial console or the keyboard is done via kgdboc. If you want to use only the keyboard and want to break in early you would add to your kernel command arguments: kgdboc=kbd kgdbwait If you wanted serial and or the keyboard access you could use: kgdboc=kbd,ttyS0 You can also configure kgdboc as a kernel module or at run time with the sysfs where you can activate and deactivate kgdb. Turn it on: echo kbd,ttyS0 > /sys/module/kgdboc/parameters/kgdboc Turn it off: echo "" > /sys/module/kgdboc/parameters/kgdboc Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2010-05-20kgdb: gdb "monitor" -> kdb passthroughJason Wessel
One of the driving forces behind integrating another front end (kdb) to the debug core is to allow front end commands to be accessible via gdb's monitor command. It is true that you could write gdb macros to get certain data, but you may want to just use gdb to access the commands that are available in the kdb front end. This patch implements the Rcmd gdb stub packet. In gdb you access this with the "monitor" command. For instance you could type "monitor help", "monitor lsmod" or "monitor ps A" etc... There is no error checking or command restrictions on what you can and cannot access at this point. Doing something like trying to set breakpoints with the monitor command is going to cause nothing but problems. Perhaps in the future only the commands that are actually known to work with the gdb monitor command will be available. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-05-20kgdb,8250,pl011: Return immediately from console pollJason Wessel
The design of the kdb shell requires that every device that can provide input to kdb have a polling routine that exits immediately if there is no character available. This is required in order to get the page scrolling mechanism working. Changing the kernel debugger I/O API to require all polling character routines to exit immediately if there is no data allows the kernel debugger to process multiple input channels. NO_POLL_CHAR will be the return code to the polling routine when ever there is no character available. CC: linux-serial@vger.kernel.org Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-05-20kgdb: core changes to support kdbJason Wessel
These are the minimum changes to the kgdb core in order to enable an API to connect a new front end (kdb) to the debug core. This patch introduces the dbg_kdb_mode variable controls where the user level I/O is routed. It will be routed to the gdbstub (kgdb) or to the kdb front end which is a simple shell available over the kgdboc connection. You can switch back and forth between kdb or the gdb stub mode of operation dynamically. From gdb stub mode you can blindly type "$3#33", or from the kdb mode you can enter "kgdb" to switch to the gdb stub. The logic in the debug core depends on kdb to look for the typical gdb connection sequences and return immediately with KGDB_PASS_EVENT if a gdb serial command sequence is detected. That should allow a reasonably seamless transition between kdb -> gdb without leaving the kernel exception state. The two gdb serial queries that kdb is responsible for detecting are the "?" and "qSupported" packets. CC: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Martin Hicks <mort@sgi.com>
2010-05-20kdb: core for kgdb back end (1 of 2)Jason Wessel
This patch contains only the kdb core. Because the change set was large, it was split. The next patch in the series includes the instrumentation into the core kernel which are mainly helper functions for kdb. This work is directly derived from kdb v4.4 found at: ftp://oss.sgi.com/projects/kdb/download/v4.4/ The kdb internals have been re-organized to make them mostly platform independent and to connect everything to the debug core which is used by gdbstub (which has long been known as kgdb). The original version of kdb was 58,000 lines worth of changes to support x86. From that implementation only the kdb shell, and basic commands for memory access, runcontrol, lsmod, and dmesg where carried forward. This is a generic implementation which aims to cover all the current architectures using the kgdb core: ppc, arm, x86, mips, sparc, sh and blackfin. More archictectures can be added by implementing the architecture specific kgdb functions. [mort@sgi.com: Compile fix with hugepages enabled] [mort@sgi.com: Clean breakpoint code renaming kdba_ -> kdb_] [mort@sgi.com: fix new line after printing registers] [mort@sgi.com: Remove the concept of global vs. local breakpoints] [mort@sgi.com: Rework kdb_si_swapinfo to use more generic name] [mort@sgi.com: fix the information dump macros, remove 'arch' from the names] [sfr@canb.auug.org.au: include fixup to include linux/slab.h] CC: linux-arch@vger.kernel.org Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Martin Hicks <mort@sgi.com>
2010-05-20Separate the gdbstub from the debug coreJason Wessel
Split the former kernel/kgdb.c into debug_core.c which contains the kernel debugger exception logic and to the gdbstub.c which contains the logic for allowing gdb to talk to the debug core. This also created a private include file called debug_core.h which contains all the definitions to glue the debug_core to any other debugger connections. CC: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-05-20Move kernel/kgdb.c to kernel/debug/debug_core.cJason Wessel
Move kgdb.c in preparation to separate the gdbstub from the debug core and exception handling. CC: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
