path: root/kernel/exec_domain.c
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-12Remove rest of exec domains.Richard Weinberger
It is gone from all archs, now we can remove the final bits. Signed-off-by: Richard Weinberger <richard@nod.at>
2015-04-12Remove execution domain supportRichard Weinberger
All users of exec_domain are gone, now we can get rid of that abandoned feature. To not break existing userspace we keep a dummy /proc/execdomains file which will always contain "0-0 Linux [kernel]". Signed-off-by: Richard Weinberger <richard@nod.at>
2014-06-04kernel/exec_domain.c: code clean-upFabian Frederick
Fix checkpatch warnings about EXPORT_SYMBOL and return() Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09sys_personality: remove the bogus checks in ↵Oleg Nesterov
sys_personality()->__set_personality() path Cleanup, no functional changes. - __set_personality() always changes ->exec_domain/personality, the special case when ->exec_domain remains the same buys nothing but complicates the code. Unify both cases to simplify the code. - The -EINVAL check in sys_personality() was never right. If we assume that set_personality() can fail we should check the value it returns instead of verifying that task->personality was actually changed. Remove it. Before the previous patch it was possible to hit this case due to overflow problems, but this -EINVAL just indicated the kernel bug. OTOH, probably it makes sense to change lookup_exec_domain() to return ERR_PTR() instead of default_exec_domain if the search in exec_domains list fails, and report this error to the user-space. But this means another user-space change, and we have in-kernel users which need fixes. For example, PER_OSF4 falls into PER_MASK for unkown reason and nobody cares to register this domain. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Wenming Zhang <wezhang@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04sys_personality: change sys_personality() to accept "unsigned int" instead ↵Oleg Nesterov
of u_long task_struct->pesonality is "unsigned int", but sys_personality() paths use "unsigned long pesonality". This means that every assignment or comparison is not right. In particular, if this argument does not fit into "unsigned int" __set_personality() changes the caller's personality and then sys_personality() returns -EINVAL. Turn this argument into "unsigned int" and avoid overflows. Obviously, this is the user-visible change, we just ignore the upper bits. But this can't break the sane application. There is another thing which can confuse the poorly written applications. User-space thinks that this syscall returns int, not long. This means that the returned value can be negative and look like the error code. But note that libc won't be confused and thus errno won't be set, and with this patch the user-space can never get -1 unless sys_personality() really fails. And, most importantly, the negative RET != -1 is only possible if that app previously called personality(RET). Pointed-out-by: Wenming Zhang <wezhang@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Get rid of indirect include of fs_struct.hAl Viro
Don't pull it in sched.h; very few files actually need it and those can include directly. sched.h itself only needs forward declaration of struct fs_struct; Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-31Kill unsharing fs_struct in __set_personality()Al Viro
That's a rudiment of altroot support. I.e. it should've been buried a long time ago. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-14[CVE-2009-0029] System call wrappers part 04Heiko Carstens
2008-10-23proc: move /proc/execdomains to kernel/exec_domain.cAlexey Dobriyan
2008-07-26[PATCH] kill altrootAl Viro
long overdue... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-22remove CONFIG_KMOD from core kernel codeJohannes Berg
Always compile request_module when the kernel allows modules. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-18whitespace fixes: execution domainsDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-24[PATCH] Fix module refcount leak in __set_personality()Sergey Vlasov
If the change of personality does not lead to change of exec domain, __set_personality() returned without releasing the module reference acquired by lookup_exec_domain(). Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
