path: root/kernel/exec_domain.c
2015-04-12Remove rest of exec domains.Richard Weinberger
It is gone from all archs, now we can remove the final bits. Signed-off-by: Richard Weinberger <richard@nod.at>
2015-04-12Remove execution domain supportRichard Weinberger
All users of exec_domain are gone, now we can get rid of that abandoned feature. To not break existing userspace we keep a dummy /proc/execdomains file which will always contain "0-0 Linux [kernel]". Signed-off-by: Richard Weinberger <richard@nod.at>
2014-06-04kernel/exec_domain.c: code clean-upFabian Frederick
Fix checkpatch warnings about EXPORT_SYMBOL and return() Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09sys_personality: remove the bogus checks in ↵Oleg Nesterov
sys_personality()->__set_personality() path Cleanup, no functional changes. - __set_personality() always changes ->exec_domain/personality, the special case when ->exec_domain remains the same buys nothing but complicates the code. Unify both cases to simplify the code. - The -EINVAL check in sys_personality() was never right. If we assume that set_personality() can fail we should check the value it returns instead of verifying that task->personality was actually changed. Remove it. Before the previous patch it was possible to hit this case due to overflow problems, but this -EINVAL just indicated the kernel bug. OTOH, probably it makes sense to change lookup_exec_domain() to return ERR_PTR() instead of default_exec_domain if the search in exec_domains list fails, and report this error to the user-space. But this means another user-space change, and we have in-kernel users which need fixes. For example, PER_OSF4 falls into PER_MASK for unkown reason and nobody cares to register this domain. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Wenming Zhang <wezhang@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04sys_personality: change sys_personality() to accept "unsigned int" instead ↵Oleg Nesterov
of u_long task_struct->pesonality is "unsigned int", but sys_personality() paths use "unsigned long pesonality". This means that every assignment or comparison is not right. In particular, if this argument does not fit into "unsigned int" __set_personality() changes the caller's personality and then sys_personality() returns -EINVAL. Turn this argument into "unsigned int" and avoid overflows. Obviously, this is the user-visible change, we just ignore the upper bits. But this can't break the sane application. There is another thing which can confuse the poorly written applications. User-space thinks that this syscall returns int, not long. This means that the returned value can be negative and look like the error code. But note that libc won't be confused and thus errno won't be set, and with this patch the user-space can never get -1 unless sys_personality() really fails. And, most importantly, the negative RET != -1 is only possible if that app previously called personality(RET). Pointed-out-by: Wenming Zhang <wezhang@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Get rid of indirect include of fs_struct.hAl Viro
Don't pull it in sched.h; very few files actually need it and those can include directly. sched.h itself only needs forward declaration of struct fs_struct; Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-31Kill unsharing fs_struct in __set_personality()Al Viro
That's a rudiment of altroot support. I.e. it should've been buried a long time ago. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-14[CVE-2009-0029] System call wrappers part 04Heiko Carstens
2008-10-23proc: move /proc/execdomains to kernel/exec_domain.cAlexey Dobriyan
2008-07-26[PATCH] kill altrootAl Viro
long overdue... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-22remove CONFIG_KMOD from core kernel codeJohannes Berg
Always compile request_module when the kernel allows modules. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-18whitespace fixes: execution domainsDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-24[PATCH] Fix module refcount leak in __set_personality()Sergey Vlasov
If the change of personality does not lead to change of exec domain, __set_personality() returned without releasing the module reference acquired by lookup_exec_domain(). Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
