This patch adds a notifier which can be used by subsystems that may
be interested in when a task has completely died and is about to
have it's last resource freed.
The Android lowmemory killer uses this to determine when a task
it has killed has finally given up its goods.
Signed-off-by: San Mehat <san@google.com>
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC
check in set_user() to check for NPROC exceeding via setuid() and
similar functions.
Before the check there was a possibility to greatly exceed the allowed
number of processes by an unprivileged user if the program relied on
rlimit only. But the check created new security threat: many poorly
written programs simply don't check setuid() return code and believe it
cannot fail if executed with root privileges. So, the check is removed
in this patch because of too often privilege escalations related to
buggy programs.
The NPROC can still be enforced in the common code flow of daemons
spawning user processes. Most of daemons do fork()+setuid()+execve().
The check introduced in execve() (1) enforces the same limit as in
setuid() and (2) doesn't create similar security issues.
Neil Brown suggested to track what specific process has exceeded the
limit by setting PF_NPROC_EXCEEDED process flag. With the change only
this process would fail on execve(), and other processes' execve()
behaviour is not changed.
Solar Designer suggested to re-check whether NPROC limit is still
exceeded at the moment of execve(). If the process was sleeping for
days between set*uid() and execve(), and the NPROC counter step down
under the limit, the defered execve() failure because NPROC limit was
exceeded days ago would be unexpected. If the limit is not exceeded
anymore, we clear the flag on successful calls to execve() and fork().
The flag is also cleared on successful calls to set_user() as the limit
was exceeded for the previous user, not the current one.
Similar check was introduced in -ow patches (without the process flag).
v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user().
Reviewed-by: James Morris <jmorris@namei.org>
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Acked-by: NeilBrown <neilb@suse.de>
Signed-off-by: Daniel Rebelo de Oliveira <psykon@gmail.com>
[ This patch has already been accepted as commit 0ac0c0d0f837 but later
reverted (commit 35926ff5fba8) because it itroduced arch specific
__node_random which was defined only for x86 code so it broke other
archs. This is a followup without any arch specific code. Other than
that there are no functional changes.]
Some workloads that create a large number of small files tend to assign
too many pages to node 0 (multi-node systems). Part of the reason is
that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts
at node 0 for newly created tasks.
This patch changes the rotor to be initialized to a random node number
of the cpuset.
[akpm@linux-foundation.org: fix layout]
[Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration]
[mhocko@suse.cz: Make it arch independent]
[akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build]
Signed-off-by: Jack Steiner <steiner@sgi.com>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Paul Menage <menage@google.com>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits)
block: strict rq_affinity
backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu
block: fix patch import error in max_discard_sectors check
block: reorder request_queue to remove 64 bit alignment padding
CFQ: add think time check for group
CFQ: add think time check for service tree
CFQ: move think time check variables to a separate struct
fixlet: Remove fs_excl from struct task.
cfq: Remove special treatment for metadata rqs.
block: document blk_plug list access
block: avoid building too big plug list
compat_ioctl: fix make headers_check regression
block: eliminate potential for infinite loop in blkdev_issue_discard
compat_ioctl: fix warning caused by qemu
block: flush MEDIA_CHANGE from drivers on close(2)
blk-throttle: Make total_nr_queued unsigned
block: Add __attribute__((format(printf...) and fix fallout
fs/partitions/check.c: make local symbols static
block:remove some spare spaces in genhd.c
block:fix the comment error in blkdev.h
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits)
vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp
isofs: Remove global fs lock
jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory
fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.
mm/truncate.c: fix build for CONFIG_BLOCK not enabled
fs:update the NOTE of the file_operations structure
Remove dead code in dget_parent()
AFS: Fix silly characters in a comment
switch d_add_ci() to d_splice_alias() in "found negative" case as well
simplify gfs2_lookup()
jfs_lookup(): don't bother with . or ..
get rid of useless dget_parent() in btrfs rename() and link()
get rid of useless dget_parent() in fs/btrfs/ioctl.c
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
drivers: fix up various ->llseek() implementations
fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek
Ext4: handle SEEK_HOLE/SEEK_DATA generically
Btrfs: implement our own ->llseek
fs: add SEEK_HOLE and SEEK_DATA flags
reiserfs: make reiserfs default to barrier=flush
Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new
shrinker callout for the inode cache, that clashed with the xfs code to
start the periodic workers later.
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep: Fix lockdep_no_validate against IRQ states
mutex: Make mutex_destroy() an inline function
plist: Remove the need to supply locks to plist heads
lockup detector: Fix reference to the non-existent CONFIG_DETECT_SOFTLOCKUP option
If the new child is traced, do_fork() adds the pending SIGSTOP.
It assumes that either it is traced because of auto-attach or the
tracer attached later, in both cases sigaddset/set_thread_flag is
correct even if SIGSTOP is already pending.
Now that we have PTRACE_SEIZE this is no longer right in the latter
case. If the tracer does PTRACE_SEIZE after copy_process() makes the
child visible the queued SIGSTOP is wrong.
We could check PT_SEIZED bit and change ptrace_attach() to set both
PT_PTRACED and PT_SEIZED bits simultaneously but see the next patch,
we need to know whether this child was auto-attached or not anyway.
So this patch simply moves this code to ptrace_init_task(), this
way we can never race with ptrace_attach().
Acked-by: Tejun Heo <tj@kernel.org>
fs_excl is a poor man's priority inheritance for filesystems to hint to
the block layer that an operation is important. It was never clearly
specified, not widely adopted, and will not prevent starvation in many
cases (like across cgroups).
fs_excl was introduced with the time sliced CFQ IO scheduler, to
indicate when a process held FS exclusive resources and thus needed
a boost.
It doesn't cover all file systems, and it was never fully complete.
Lets kill it.
Signed-off-by: Justin TerAvest <teravest@google.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
This was legacy code brought over from the RT tree and
is no longer necessary.
Signed-off-by: Dima Zavin <dima@android.com>
Cc: Daniel Walker <dwalker@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com
At this point, tracehooks aren't useful to mainline kernel and mostly
just add an extra layer of obfuscation. Although they have comments,
without actual in-kernel users, it is difficult to tell what are their
assumptions and they're actually trying to achieve. To mainline
kernel, they just aren't worth keeping around.
This patch kills the following clone and exec related tracehooks.
tracehook_prepare_clone()
tracehook_finish_clone()
tracehook_report_clone()
tracehook_report_clone_complete()
tracehook_unsafe_exec()
The changes are mostly trivial - logic is moved to the caller and
comments are merged and adjusted appropriately.
The only exception is in check_unsafe_exec() where LSM_UNSAFE_PTRACE*
are OR'd to bprm->unsafe instead of setting it, which produces the
same result as the field is always zero on entry. It also tests
p->ptrace instead of (p->ptrace & PT_PTRACED) for consistency, which
also gives the same result.
This doesn't introduce any behavior change.
This patch kills the following trivial tracehooks.
* Ones testing whether task is ptraced. Replace with ->ptrace test.
tracehook_expect_breakpoints()
tracehook_consider_ignored_signal()
tracehook_consider_fatal_signal()
* ptrace_event() wrappers. Call directly.
tracehook_report_exec()
tracehook_report_exit()
tracehook_report_vfork_done()
* ptrace_release_task() wrapper. Call directly.
tracehook_finish_release_task()
* noop
tracehook_prepare_release_task()
tracehook_report_death()
Thomas Gleixner reports that we now have a boot crash triggered by
CONFIG_CPUMASK_OFFSTACK=y:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<c11ae035>] find_next_bit+0x55/0xb0
Call Trace:
[<c11addda>] cpumask_any_but+0x2a/0x70
[<c102396b>] flush_tlb_mm+0x2b/0x80
[<c1022705>] pud_populate+0x35/0x50
[<c10227ba>] pgd_alloc+0x9a/0xf0
[<c103a3fc>] mm_init+0xec/0x120
[<c103a7a3>] mm_alloc+0x53/0xd0
which was introduced by commit de03c72cfce5 ("mm: convert
mm->cpu_vm_cpumask into cpumask_var_t"), and is due to wrong ordering of
mm_init() vs mm_init_cpumask
Thomas wrote a patch to just fix the ordering of initialization, but I
hate the new double allocation in the fork path, so I ended up instead
doing some more radical surgery to clean it all up.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Reported-by: Ingo Molnar <mingo@elte.hu>
Setup and cleanup of mm_struct->exe_file is currently done in fs/proc/.
This was because exe_file was needed only for /proc/<pid>/exe. Since we
will need the exe_file functionality also for core dumps (so core name can
contain full binary path), built this functionality always into the
kernel.
To achieve that move that out of proc FS to the kernel/ where in fact it
should belong. By doing that we can make dup_mm_exe_file static. Also we
can drop linux/proc_fs.h inclusion in fs/exec.c and kernel/fork.c.
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and
leads to some problems:
* cgroup creation is out-of-control
* cgroup name can conflict when pids are looping
* it is not possible to have a single process handling a lot of
namespaces without falling in a exponential creation time
* we may want to create a namespace without creating a cgroup
The ns_cgroup was replaced by a compatibility flag 'clone_children',
where a newly created cgroup will copy the parent cgroup values.
The userspace has to manually create a cgroup and add a task to
the 'tasks' file.
This patch removes the ns_cgroup as suggested in the following thread:
https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html
The 'cgroup_clone' function is removed because it is no longer used.
This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify
ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a
printk warning users that the feature is planned for removal. Since that
time we have heard from XXX users who were affected by this.
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Jamal Hadi Salim <hadi@cyberus.ca>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
Acked-by: Matt Helsley <matthltc@us.ibm.com>
Adds functionality to read/write lock CLONE_THREAD fork()ing per-threadgroup
Add an rwsem that lives in a threadgroup's signal_struct that's taken for
reading in the fork path, under CONFIG_CGROUPS. If another part of the
kernel later wants to use such a locking mechanism, the CONFIG_CGROUPS
ifdefs should be changed to a higher-up flag that CGROUPS and the other
system would both depend on.
This is a pre-patch for cgroup-procs-write.patch.
Signed-off-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Matt Helsley <matthltc@us.ibm.com>
Reviewed-by: Paul Menage <menage@google.com>
Cc: Miao Xie <miaox@cn.fujitsu.com>
cpumask_t is very big struct and cpu_vm_mask is placed wrong position.
It might lead to reduce cache hit ratio.
This patch has two change.
1) Move the place of cpumask into last of mm_struct. Because usually cpumask
is accessed only front bits when the system has cpu-hotplug capability
2) Convert cpu_vm_mask into cpumask_var_t. It may help to reduce memory
footprint if cpumask_size() will use nr_cpumask_bits properly in future.
In addition, this patch change the name of cpu_vm_mask with cpu_vm_mask_var.
It may help to detect out of tree cpu_vm_mask users.
This patch has no functional change.
[akpm@linux-foundation.org: build fix]
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Straightforward conversion of i_mmap_lock to a mutex.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Hugh says:
"The only significant loser, I think, would be page reclaim (when
concurrent with truncation): could spin for a long time waiting for
the i_mmap_mutex it expects would soon be dropped? "
Counter points:
- cpu contention makes the spin stop (need_resched())
- zap pages should be freeing pages at a higher rate than reclaim
ever can
I think the simplification of the truncate code is definitely worth it.
Effectively reverts: 2aa15890f3c ("mm: prevent concurrent
unmap_mapping_range() on the same inode") and takes out the code that
caused its problem.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
sched_fork() and wake_up_new_task() are defined with a parameter
'unsigned long clone_flags', which is unused.
This patch removes the parameters.
Signed-off-by: Samir Bellabes <sam@synack.fr>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/r/1305130685-1047-1-git-send-email-sam@synack.fr
Neil Brown pointed out that lock_depth somehow escaped the BKL
removal work. Let's get rid of it now.
Note that the perf scripting utilities still have a bunch of
code for dealing with common_lock_depth in tracepoints; I have
left that in place in case anybody wants to use that code with
older kernels.
Suggested-by: Neil Brown <neilb@suse.de>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Link: http://lkml.kernel.org/r/20110422111910.456c0e84@bike.lwn.net
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
Reorganize proc_get_sb() so it can be called before the struct pid of the
first process is allocated.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Acked-by: Serge E. Hallyn <serge@hallyn.com>
This patchset is a cleanup and a preparation to unshare the pid namespace.
These prerequisites prepare for Eric's patchset to give a file descriptor
to a namespace and join an existing namespace.
This patch:
It turns out that the existing assignment in copy_process of the
child_reaper can handle the initial assignment of child_reaper we just
need to generalize the test in kernel/fork.c
Cleanup: kill the dead code which does nothing but complicates the code
and confuses the reader.
sys_unshare(CLONE_THREAD/SIGHAND/VM) is not really implemented, and I
doubt very much it will ever work. At least, nobody even tried since the
original 99d1419d96d7df9cfa56 ("unshare system call -v5: system call
handler function") was applied more than 4 years ago.
And the code is not consistent. unshare_thread() always fails
unconditionally, while unshare_sighand() and unshare_vm() pretend to work
if there is nothing to unshare.
Remove unshare_thread(), unshare_sighand(), unshare_vm() helpers and
related variables and add a simple CLONE_THREAD | CLONE_SIGHAND| CLONE_VM
check into check_unshare_flags().
Also, move the "CLONE_NEWNS needs CLONE_FS" check from
check_unshare_flags() to sys_unshare(). This looks more consistent and
matches the similar do_sysvsem check in sys_unshare().
Note: with or without this patch "atomic_read(mm->mm_users) > 1" can give
a false positive due to get_task_mm().
Acked-by: Roland McGrath <roland@redhat.com>
Cc: Janak Desai <janak@us.ibm.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
All kthreads being created from a single helper task, they all use memory
from a single node for their kernel stack and task struct.
This patch suite creates kthread_create_on_node(), adding a 'cpu' parameter
to parameters already used by kthread_create().
This parameter serves in allocating memory for the new kthread on its
memory node if possible.
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Tejun Heo <tj@kernel.org>
Cc: <linux-arch@vger.kernel.org>
Add a node parameter to alloc_thread_info(), and change its name to
alloc_thread_info_node()
This change is needed to allow NUMA aware kthread_create_on_cpu()
This patch suite creates kthread_create_on_cpu(), adding a 'cpu' parameter
memory node if available.
Users of this new function are : ksoftirqd, kworker, migration, pktgend...
This patch:
Add a node parameter to alloc_task_struct(), and change its name to
alloc_task_struct_node()
Export the symbols required for a race-free kvm_vcpu_on_spin.
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
This patch adds support for creating a queuing context outside
of the queue itself. This enables us to batch up pieces of IO
before grabbing the block device queue lock and submitting them to
the IO scheduler.
The context is created on the stack of the process and assigned in
the task structure, so that we can auto-unplug it if we hit a schedule
event.
The current queue plugging happens implicitly if IO is submitted to
an empty device, yet callers have to remember to unplug that IO when
they are going to wait for it. This is an ugly API and has caused bugs
in the past. Additionally, it requires hacks in the vm (->sync_page()
callback) to handle that logic. By switching to an explicit plugging
scheme we make the API a lot nicer and can get rid of the ->sync_page()
hack in the vm.
Add khugepaged to relocate fragmented pages into hugepages if new
hugepages become available. (this is indipendent of the defrag logic that
will have to make new hugepages available)
The fundamental reason why khugepaged is unavoidable, is that some memory
can be fragmented and not everything can be relocated. So when a virtual
machine quits and releases gigabytes of hugepages, we want to use those
freely available hugepages to create huge-pmd in the other virtual
machines that may be running on fragmented memory, to maximize the CPU
efficiency at all times. The scan is slow, it takes nearly zero cpu time,
except when it copies data (in which case it means we definitely want to
pay for that cpu time) so it seems a good tradeoff.
In addition to the hugepages being released by other process releasing
memory, we have the strong suspicion that the performance impact of
potentially defragmenting hugepages during or before each page fault could
lead to more performance inconsistency than allocating small pages at
first and having them collapsed into large pages later... if they prove
themselfs to be long lived mappings (khugepaged scan is slow so short
lived mappings have low probability to run into khugepaged if compared to
long lived mappings).
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
This increase the size of the mm struct a bit but it is needed to
preallocate one pte for each hugepage so that split_huge_page will not
require a fail path. Guarantee of success is a fundamental property of
split_huge_page to avoid decrasing swapping reliability and to avoid
adding -ENOMEM fail paths that would otherwise force the hugepage-unaware
VM code to learn rolling back in the middle of its pte mangling operations
(if something we need it to learn handling pmd_trans_huge natively rather
being capable of rollback). When split_huge_page runs a pte is needed to
succeed the split, to map the newly splitted regular pages with a regular
pte. This way all existing VM code remains backwards compatible by just
adding a split_huge_page* one liner. The memory waste of those
preallocated ptes is negligible and so it is worth it.
Acked-by: Mel Gorman <mel@csn.ul.ie>
We'd like to be able to oom_score_adj a process up/down as it
enters/leaves the foreground. Currently, it is not possible to oom_adj
down without CAP_SYS_RESOURCE. This patch allows a task to decrease its
oom_score_adj back to the value that a CAP_SYS_RESOURCE thread set it to
or its inherited value at fork. Assuming the thread that has forked it
has oom_score_adj of 0, each process could decrease it back from 0 upon
activation unless a CAP_SYS_RESOURCE thread elevated it to something
higher.
Alternative considered:
* a setuid binary
* a daemon with CAP_SYS_RESOURCE
Since you don't wan't all processes to be able to reduce their oom_adj, a
setuid or daemon implementation would be complex. The alternatives also
have much higher overhead.
This patch updated from original patch based on feedback from David
Rientjes.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Ying Han <yinghan@google.com>
This warning was added in commit bdff746a3915 ("clone: prepare to recycle
CLONE_STOPPED") three years ago. 2.6.26 came and went. As far as I know,
no-one is actually using CLONE_STOPPED.
Signed-off-by: Dave Jones <davej@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits)
gameport: use this_cpu_read instead of lookup
x86: udelay: Use this_cpu_read to avoid address calculation
x86: Use this_cpu_inc_return for nmi counter
x86: Replace uses of current_cpu_data with this_cpu ops
x86: Use this_cpu_ops to optimize code
vmstat: User per cpu atomics to avoid interrupt disable / enable
irq_work: Use per cpu atomics instead of regular atomics
cpuops: Use cmpxchg for xchg to avoid lock semantics
x86: this_cpu_cmpxchg and this_cpu_xchg operations
percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support
percpu,x86: relocate this_cpu_add_return() and friends
connector: Use this_cpu operations
xen: Use this_cpu_inc_return
taskstats: Use this_cpu_ops
random: Use this_cpu_inc_return
fs: Use this_cpu_inc_return in buffer.c
highmem: Use this_cpu_xx_return() operations
vmstat: Use this_cpu_inc_return for vm statistics
x86: Support for this_cpu_add, sub, dec, inc_return
percpu: Generic support for this_cpu_add, sub, dec, inc_return
Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c}
as per Tejun.
Per Oleg's suggestion, undo fork failure free/put_signal_struct change,
and move sched_autogroup_exit() to free_signal_struct() instead.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
LKML-Reference: <1294222564.8369.6.camel@marge.simson.net>
Merge reason: Merge the final .37 tree.
The cgroup exit mess also uncovered a struct autogroup reference leak.
copy_process() was simply freeing vs putting the signal_struct,
stranding a reference.
LKML-Reference: <1293784350.6839.2.camel@marge.simson.net>
__get_cpu_var() can be replaced with this_cpu_read and will then use a
single read instruction with implied address calculation to access the
correct per cpu instance.
However, the address of a per cpu variable passed to __this_cpu_read()
cannot be determined (since it's an implied address conversion through
segment prefixes). Therefore apply this only to uses of __get_cpu_var
where the address of the variable is not used.
Acked-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
idle_balance() drops/retakes rq->lock, leaving the previous task
vulnerable to set_tsk_need_resched(). Clear it after we return
from balancing instead, and in setup_thread_stack() as well, so
no successfully descheduled or never scheduled task has it set.
Need resched confused the skip_clock_update logic, which assumes
that the next call to update_rq_clock() will come nearly immediately
after being set. Make the optimization robust against the waking
a sleeper before it sucessfully deschedules case by checking that
the current task has not been dequeued before setting the flag,
since it is that useless clock update we're trying to save, and
clear unconditionally in schedule() proper instead of conditionally
in put_prev_task().
Reported-by: Bjoern B. Brandenburg <bbb.lst@gmail.com>
Tested-by: Yong Zhang <yong.zhang0@gmail.com>
Cc: stable@kernel.org
LKML-Reference: <1291802742.1417.9.camel@marge.simson.net>
A recurring complaint from CFS users is that parallel kbuild has
a negative impact on desktop interactivity. This patch
implements an idea from Linus, to automatically create task
groups. Currently, only per session autogroups are implemented,
but the patch leaves the way open for enhancement.
Implementation: each task's signal struct contains an inherited
pointer to a refcounted autogroup struct containing a task group
pointer, the default for all tasks pointing to the
init_task_group. When a task calls setsid(), a new task group
is created, the process is moved into the new task group, and a
reference to the preveious task group is dropped. Child
processes inherit this task group thereafter, and increase it's
refcount. When the last thread of a process exits, the
process's reference is dropped, such that when the last process
referencing an autogroup exits, the autogroup is destroyed.
At runqueue selection time, IFF a task has no cgroup assignment,
its current autogroup is used.
Autogroup bandwidth is controllable via setting it's nice level
through the proc filesystem:
cat /proc/<pid>/autogroup
Displays the task's group and the group's nice level.
echo <nice level> > /proc/<pid>/autogroup
Sets the task group's shares to the weight of nice <level> task.
Setting nice level is rate limited for !admin users due to the
abuse risk of task group locking.
The feature is enabled from boot by default if
CONFIG_SCHED_AUTOGROUP=y is selected, but can be disabled via
the boot option noautogroup, and can also be turned on/off on
the fly via:
echo [01] > /proc/sys/kernel/sched_autogroup_enabled
... which will automatically move tasks to/from the root task group.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Paul Turner <pjt@google.com>
[ Removed the task_group_path() debug code, and fixed !EVENTFD build failure. ]
LKML-Reference: <1290281700.28711.9.camel@maggy.simson.net>
Oleg Nesterov pointed out we have to prevent multiple-threads-inside-exec
itself and we can reuse ->cred_guard_mutex for it. Yes, concurrent
execve() has no worth.
Let's move ->cred_guard_mutex from task_struct to signal_struct. It
naturally prevent multiple-threads-inside-exec.
It's pointless to kill a task if another thread sharing its mm cannot be
killed to allow future memory freeing. A subsequent patch will prevent
kills in such cases, but first it's necessary to have a way to flag a task
that shares memory with an OOM_DISABLE task that doesn't incur an
additional tasklist scan, which would make select_bad_process() an O(n^2)
function.
This patch adds an atomic counter to struct mm_struct that follows how
many threads attached to it have an oom_score_adj of OOM_SCORE_ADJ_MIN.
They cannot be killed by the kernel, so their memory cannot be freed in
oom conditions.
This only requires task_lock() on the task that we're operating on, it
does not require mm->mmap_sem since task_lock() pins the mm and the
operation is atomic.
[rientjes@google.com: changelog and sys_unshare() code]
[rientjes@google.com: protect oom_disable_count with task_lock in fork]
[rientjes@google.com: use old_mm for oom_disable_count in exec]
Signed-off-by: Ying Han <yinghan@google.com>
Signed-off-by: David Rientjes <rientjes@google.com>
The below bug in fork led to the rmap walk finding the parent huge-pmd
twice instead of just once, because the anon_vma_chain objects of the
child vma still point to the vma->vm_mm of the parent.
The patch fixes it by making the rmap walk accurate during fork. It's not
a big deal normally but it worth being accurate considering the cost is
the same.
Acked-by: Johannes Weiner <jweiner@redhat.com>
It's a really simple list, and several of the users want to go backwards
in it to find the previous vma. So rather than have to look up the
previous entry with 'find_vma_prev()' or something similar, just make it
doubly linked instead.
Tested-by: Ian Campbell <ijc@hellion.org.uk>
fs: fs_struct rwlock to spinlock
struct fs_struct.lock is an rwlock with the read-side used to protect root and
pwd members while taking references to them. Taking a reference to a path
typically requires just 2 atomic ops, so the critical section is very small.
Parallel read-side operations would have cacheline contention on the lock, the
dentry, and the vfsmount cachelines, so the rwlock is unlikely to ever give a
real parallelism increase.
Replace it with a spinlock to avoid one or two atomic operations in typical
path lookup fastpath.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
This a complete rewrite of the oom killer's badness() heuristic which is
used to determine which task to kill in oom conditions. The goal is to
make it as simple and predictable as possible so the results are better
understood and we end up killing the task which will lead to the most
memory freeing while still respecting the fine-tuning from userspace.
Instead of basing the heuristic on mm->total_vm for each task, the task's
rss and swap space is used instead. This is a better indication of the
amount of memory that will be freeable if the oom killed task is chosen
and subsequently exits. This helps specifically in cases where KDE or
GNOME is chosen for oom kill on desktop systems instead of a memory
hogging task.
The baseline for the heuristic is a proportion of memory that each task is
currently using in memory plus swap compared to the amount of "allowable"
memory. "Allowable," in this sense, means the system-wide resources for
unconstrained oom conditions, the set of mempolicy nodes, the mems
attached to current's cpuset, or a memory controller's limit. The
proportion is given on a scale of 0 (never kill) to 1000 (always kill),
roughly meaning that if a task has a badness() score of 500 that the task
consumes approximately 50% of allowable memory resident in RAM or in swap
space.
The proportion is always relative to the amount of "allowable" memory and
not the total amount of RAM systemwide so that mempolicies and cpusets may
operate in isolation; they shall not need to know the true size of the
machine on which they are running if they are bound to a specific set of
nodes or mems, respectively.
Root tasks are given 3% extra memory just like __vm_enough_memory()
provides in LSMs. In the event of two tasks consuming similar amounts of
memory, it is generally better to save root's task.
Because of the change in the badness() heuristic's baseline, it is also
necessary to introduce a new user interface to tune it. It's not possible
to redefine the meaning of /proc/pid/oom_adj with a new scale since the
ABI cannot be changed for backward compatability. Instead, a new tunable,
/proc/pid/oom_score_adj, is added that ranges from -1000 to +1000. It may
be used to polarize the heuristic such that certain tasks are never
considered for oom kill while others may always be considered. The value
is added directly into the badness() score so a value of -500, for
example, means to discount 50% of its memory consumption in comparison to
other tasks either on the system, bound to the mempolicy, in the cpuset,
or sharing the same memory controller.
/proc/pid/oom_adj is changed so that its meaning is rescaled into the
units used by /proc/pid/oom_score_adj, and vice versa. Changing one of
these per-task tunables will rescale the value of the other to an
equivalent meaning. Although /proc/pid/oom_adj was originally defined as
a bitshift on the badness score, it now shares the same linear growth as
/proc/pid/oom_score_adj but with different granularity. This is required
so the ABI is not broken with userspace applications and allows oom_adj to
be deprecated for future removal.
Cc: Nick Piggin <npiggin@suse.de>
Cc: Balbir Singh <balbir@in.ibm.com>
Concurrency managed workqueue needs to know when workers are going to
sleep and waking up. Using these two hooks, cmwq keeps track of the
current concurrency level and throttles execution of new works if it's
too high and wakes up another worker from the sleep hook if it becomes
too low.
This patch introduces PF_WQ_WORKER to identify workqueue workers and
adds the following two hooks.
* wq_worker_waking_up(): called when a worker is woken up.
* wq_worker_sleeping(): called when a worker is going to sleep and may
return a pointer to a local task which should be woken up. The
returned task is woken up using try_to_wake_up_local() which is
simplified ttwu which is called under rq lock and can only wake up
local tasks.
Both hooks are currently defined as noop in kernel/workqueue_sched.h.
Later cmwq implementation will replace them with proper
implementation.
These hooks are hard coded as they'll always be enabled.
Acked-by: Peter Zijlstra <peterz@infradead.org>
This reverts commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b, which
caused cross-architecture build problems for all the wrong reasons.
IA64 already added its own version of __node_random(), but the fact is,
there is nothing architectural about the function, and the original
commit was just badly done. Revert it, since no fix is forthcoming.
Requested-by: Stephen Rothwell <sfr@canb.auug.org.au>
