path: root/kernel/fork.c
2011-08-11move RLIMIT_NPROC check from set_user() to do_execve_common()Vasiliy Kulikov
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC check in set_user() to check for NPROC exceeding via setuid() and similar functions. Before the check there was a possibility to greatly exceed the allowed number of processes by an unprivileged user if the program relied on rlimit only. But the check created new security threat: many poorly written programs simply don't check setuid() return code and believe it cannot fail if executed with root privileges. So, the check is removed in this patch because of too often privilege escalations related to buggy programs. The NPROC can still be enforced in the common code flow of daemons spawning user processes. Most of daemons do fork()+setuid()+execve(). The check introduced in execve() (1) enforces the same limit as in setuid() and (2) doesn't create similar security issues. Neil Brown suggested to track what specific process has exceeded the limit by setting PF_NPROC_EXCEEDED process flag. With the change only this process would fail on execve(), and other processes' execve() behaviour is not changed. Solar Designer suggested to re-check whether NPROC limit is still exceeded at the moment of execve(). If the process was sleeping for days between set*uid() and execve(), and the NPROC counter step down under the limit, the defered execve() failure because NPROC limit was exceeded days ago would be unexpected. If the limit is not exceeded anymore, we clear the flag on successful calls to execve() and fork(). The flag is also cleared on successful calls to set_user() as the limit was exceeded for the previous user, not the current one. Similar check was introduced in -ow patches (without the process flag). v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user(). Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26kernel/fork.c: fix a few coding style issuesDaniel Rebelo de Oliveira
Signed-off-by: Daniel Rebelo de Oliveira <psykon@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26cpusets: randomize node rotor used in cpuset_mem_spread_node()Michal Hocko
[ This patch has already been accepted as commit 0ac0c0d0f837 but later reverted (commit 35926ff5fba8) because it itroduced arch specific __node_random which was defined only for x86 code so it broke other archs. This is a followup without any arch specific code. Other than that there are no functional changes.] Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] [mhocko@suse.cz: Make it arch independent] [akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Paul Menage <menage@google.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-3.1/core' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits) block: strict rq_affinity backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu block: fix patch import error in max_discard_sectors check block: reorder request_queue to remove 64 bit alignment padding CFQ: add think time check for group CFQ: add think time check for service tree CFQ: move think time check variables to a separate struct fixlet: Remove fs_excl from struct task. cfq: Remove special treatment for metadata rqs. block: document blk_plug list access block: avoid building too big plug list compat_ioctl: fix make headers_check regression block: eliminate potential for infinite loop in blkdev_issue_discard compat_ioctl: fix warning caused by qemu block: flush MEDIA_CHANGE from drivers on close(2) blk-throttle: Make total_nr_queued unsigned block: Add __attribute__((format(printf...) and fix fallout fs/partitions/check.c: make local symbols static block:remove some spare spaces in genhd.c block:fix the comment error in blkdev.h ...
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-22Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: Fix lockdep_no_validate against IRQ states mutex: Make mutex_destroy() an inline function plist: Remove the need to supply locks to plist heads lockup detector: Fix reference to the non-existent CONFIG_DETECT_SOFTLOCKUP option
2011-07-20make sure that nsproxy_cache is initialized early enoughAl Viro
2011-07-17ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task()Oleg Nesterov
If the new child is traced, do_fork() adds the pending SIGSTOP. It assumes that either it is traced because of auto-attach or the tracer attached later, in both cases sigaddset/set_thread_flag is correct even if SIGSTOP is already pending. Now that we have PTRACE_SEIZE this is no longer right in the latter case. If the tracer does PTRACE_SEIZE after copy_process() makes the child visible the queued SIGSTOP is wrong. We could check PT_SEIZED bit and change ptrace_attach() to set both PT_PTRACED and PT_SEIZED bits simultaneously but see the next patch, we need to know whether this child was auto-attached or not anyway. So this patch simply moves this code to ptrace_init_task(), this way we can never race with ptrace_attach(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org>
2011-07-12fixlet: Remove fs_excl from struct task.Justin TerAvest
fs_excl is a poor man's priority inheritance for filesystems to hint to the block layer that an operation is important. It was never clearly specified, not widely adopted, and will not prevent starvation in many cases (like across cgroups). fs_excl was introduced with the time sliced CFQ IO scheduler, to indicate when a process held FS exclusive resources and thus needed a boost. It doesn't cover all file systems, and it was never fully complete. Lets kill it. Signed-off-by: Justin TerAvest <teravest@google.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-08plist: Remove the need to supply locks to plist headsDima Zavin
This was legacy code brought over from the RT tree and is no longer necessary. Signed-off-by: Dima Zavin <dima@android.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Daniel Walker <dwalker@codeaurora.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-22ptrace: kill clone/exec tracehooksTejun Heo
At this point, tracehooks aren't useful to mainline kernel and mostly just add an extra layer of obfuscation. Although they have comments, without actual in-kernel users, it is difficult to tell what are their assumptions and they're actually trying to achieve. To mainline kernel, they just aren't worth keeping around. This patch kills the following clone and exec related tracehooks. tracehook_prepare_clone() tracehook_finish_clone() tracehook_report_clone() tracehook_report_clone_complete() tracehook_unsafe_exec() The changes are mostly trivial - logic is moved to the caller and comments are merged and adjusted appropriately. The only exception is in check_unsafe_exec() where LSM_UNSAFE_PTRACE* are OR'd to bprm->unsafe instead of setting it, which produces the same result as the field is always zero on entry. It also tests p->ptrace instead of (p->ptrace & PT_PTRACED) for consistency, which also gives the same result. This doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-22ptrace: kill trivial tracehooksTejun Heo
At this point, tracehooks aren't useful to mainline kernel and mostly just add an extra layer of obfuscation. Although they have comments, without actual in-kernel users, it is difficult to tell what are their assumptions and they're actually trying to achieve. To mainline kernel, they just aren't worth keeping around. This patch kills the following trivial tracehooks. * Ones testing whether task is ptraced. Replace with ->ptrace test. tracehook_expect_breakpoints() tracehook_consider_ignored_signal() tracehook_consider_fatal_signal() * ptrace_event() wrappers. Call directly. tracehook_report_exec() tracehook_report_exit() tracehook_report_vfork_done() * ptrace_release_task() wrapper. Call directly. tracehook_finish_release_task() * noop tracehook_prepare_release_task() tracehook_report_death() This doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-05-29mm: Fix boot crash in mm_alloc()Linus Torvalds
Thomas Gleixner reports that we now have a boot crash triggered by CONFIG_CPUMASK_OFFSTACK=y: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<c11ae035>] find_next_bit+0x55/0xb0 Call Trace: [<c11addda>] cpumask_any_but+0x2a/0x70 [<c102396b>] flush_tlb_mm+0x2b/0x80 [<c1022705>] pud_populate+0x35/0x50 [<c10227ba>] pgd_alloc+0x9a/0xf0 [<c103a3fc>] mm_init+0xec/0x120 [<c103a7a3>] mm_alloc+0x53/0xd0 which was introduced by commit de03c72cfce5 ("mm: convert mm->cpu_vm_cpumask into cpumask_var_t"), and is due to wrong ordering of mm_init() vs mm_init_cpumask Thomas wrote a patch to just fix the ordering of initialization, but I hate the new double allocation in the fork path, so I ended up instead doing some more radical surgery to clean it all up. Reported-by: Thomas Gleixner <tglx@linutronix.de> Reported-by: Ingo Molnar <mingo@elte.hu> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm: extract exe_file handling from procfsJiri Slaby
Setup and cleanup of mm_struct->exe_file is currently done in fs/proc/. This was because exe_file was needed only for /proc/<pid>/exe. Since we will need the exe_file functionality also for core dumps (so core name can contain full binary path), built this functionality always into the kernel. To achieve that move that out of proc FS to the kernel/ where in fact it should belong. By doing that we can make dup_mm_exe_file static. Also we can drop linux/proc_fs.h inclusion in fs/exec.c and kernel/fork.c. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroup: remove the ns_cgroupDaniel Lezcano
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and leads to some problems: * cgroup creation is out-of-control * cgroup name can conflict when pids are looping * it is not possible to have a single process handling a lot of namespaces without falling in a exponential creation time * we may want to create a namespace without creating a cgroup The ns_cgroup was replaced by a compatibility flag 'clone_children', where a newly created cgroup will copy the parent cgroup values. The userspace has to manually create a cgroup and add a task to the 'tasks' file. This patch removes the ns_cgroup as suggested in the following thread: https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html The 'cgroup_clone' function is removed because it is no longer used. This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a printk warning users that the feature is planned for removal. Since that time we have heard from XXX users who were affected by this. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Jamal Hadi Salim <hadi@cyberus.ca> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: read-write lock CLONE_THREAD forking per threadgroupBen Blum
Adds functionality to read/write lock CLONE_THREAD fork()ing per-threadgroup Add an rwsem that lives in a threadgroup's signal_struct that's taken for reading in the fork path, under CONFIG_CGROUPS. If another part of the kernel later wants to use such a locking mechanism, the CONFIG_CGROUPS ifdefs should be changed to a higher-up flag that CGROUPS and the other system would both depend on. This is a pre-patch for cgroup-procs-write.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: convert mm->cpu_vm_cpumask into cpumask_var_tKOSAKI Motohiro
cpumask_t is very big struct and cpu_vm_mask is placed wrong position. It might lead to reduce cache hit ratio. This patch has two change. 1) Move the place of cpumask into last of mm_struct. Because usually cpumask is accessed only front bits when the system has cpu-hotplug capability 2) Convert cpu_vm_mask into cpumask_var_t. It may help to reduce memory footprint if cpumask_size() will use nr_cpumask_bits properly in future. In addition, this patch change the name of cpu_vm_mask with cpu_vm_mask_var. It may help to detect out of tree cpu_vm_mask users. This patch has no functional change. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Hugh Dickins <hughd@google.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: Convert i_mmap_lock to a mutexPeter Zijlstra
Straightforward conversion of i_mmap_lock to a mutex. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: Remove i_mmap_lock lockbreakPeter Zijlstra
Hugh says: "The only significant loser, I think, would be page reclaim (when concurrent with truncation): could spin for a long time waiting for the i_mmap_mutex it expects would soon be dropped? " Counter points: - cpu contention makes the spin stop (need_resched()) - zap pages should be freeing pages at a higher rate than reclaim ever can I think the simplification of the truncate code is definitely worth it. Effectively reverts: 2aa15890f3c ("mm: prevent concurrent unmap_mapping_range() on the same inode") and takes out the code that caused its problem. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-12sched: Remove unused parameters from sched_fork() and wake_up_new_task()Samir Bellabes
sched_fork() and wake_up_new_task() are defined with a parameter 'unsigned long clone_flags', which is unused. This patch removes the parameters. Signed-off-by: Samir Bellabes <sam@synack.fr> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1305130685-1047-1-git-send-email-sam@synack.fr Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-24sched: Get rid of lock_depthJonathan Corbet
Neil Brown pointed out that lock_depth somehow escaped the BKL removal work. Let's get rid of it now. Note that the perf scripting utilities still have a bunch of code for dealing with common_lock_depth in tracepoints; I have left that in place in case anybody wants to use that code with older kernels. Suggested-by: Neil Brown <neilb@suse.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20110422111910.456c0e84@bike.lwn.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23pidns: call pid_ns_prepare_proc() from create_pid_namespace()Eric W. Biederman
Reorganize proc_get_sb() so it can be called before the struct pid of the first process is allocated. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23pid: remove the child_reaper special case in init/main.cEric W. Biederman
This patchset is a cleanup and a preparation to unshare the pid namespace. These prerequisites prepare for Eric's patchset to give a file descriptor to a namespace and join an existing namespace. This patch: It turns out that the existing assignment in copy_process of the child_reaper can handle the initial assignment of child_reaper we just need to generalize the test in kernel/fork.c Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22sys_unshare: remove the dead CLONE_THREAD/SIGHAND/VM codeOleg Nesterov
Cleanup: kill the dead code which does nothing but complicates the code and confuses the reader. sys_unshare(CLONE_THREAD/SIGHAND/VM) is not really implemented, and I doubt very much it will ever work. At least, nobody even tried since the original 99d1419d96d7df9cfa56 ("unshare system call -v5: system call handler function") was applied more than 4 years ago. And the code is not consistent. unshare_thread() always fails unconditionally, while unshare_sighand() and unshare_vm() pretend to work if there is nothing to unshare. Remove unshare_thread(), unshare_sighand(), unshare_vm() helpers and related variables and add a simple CLONE_THREAD | CLONE_SIGHAND| CLONE_VM check into check_unshare_flags(). Also, move the "CLONE_NEWNS needs CLONE_FS" check from check_unshare_flags() to sys_unshare(). This looks more consistent and matches the similar do_sysvsem check in sys_unshare(). Note: with or without this patch "atomic_read(mm->mm_users) > 1" can give a false positive due to get_task_mm(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Janak Desai <janak@us.ibm.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22kthread: NUMA aware kthread_create_on_node()Eric Dumazet
All kthreads being created from a single helper task, they all use memory from a single node for their kernel stack and task struct. This patch suite creates kthread_create_on_node(), adding a 'cpu' parameter to parameters already used by kthread_create(). This parameter serves in allocating memory for the new kthread on its memory node if possible. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: NUMA aware alloc_thread_info_node()Eric Dumazet
Add a node parameter to alloc_thread_info(), and change its name to alloc_thread_info_node() This change is needed to allow NUMA aware kthread_create_on_cpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: NUMA aware alloc_task_struct_node()Eric Dumazet
All kthreads being created from a single helper task, they all use memory from a single node for their kernel stack and task struct. This patch suite creates kthread_create_on_cpu(), adding a 'cpu' parameter to parameters already used by kthread_create(). This parameter serves in allocating memory for the new kthread on its memory node if available. Users of this new function are : ksoftirqd, kworker, migration, pktgend... This patch: Add a node parameter to alloc_task_struct(), and change its name to alloc_task_struct_node() This change is needed to allow NUMA aware kthread_create_on_cpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17export pid symbols needed for kvm_vcpu_on_spinRik van Riel
Export the symbols required for a race-free kvm_vcpu_on_spin. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-10block: initial patch for on-stack per-task pluggingJens Axboe
This patch adds support for creating a queuing context outside of the queue itself. This enables us to batch up pieces of IO before grabbing the block device queue lock and submitting them to the IO scheduler. The context is created on the stack of the process and assigned in the task structure, so that we can auto-unplug it if we hit a schedule event. The current queue plugging happens implicitly if IO is submitted to an empty device, yet callers have to remember to unplug that IO when they are going to wait for it. This is an ugly API and has caused bugs in the past. Additionally, it requires hacks in the vm (->sync_page() callback) to handle that logic. By switching to an explicit plugging scheme we make the API a lot nicer and can get rid of the ->sync_page() hack in the vm. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13thp: khugepagedAndrea Arcangeli
Add khugepaged to relocate fragmented pages into hugepages if new hugepages become available. (this is indipendent of the defrag logic that will have to make new hugepages available) The fundamental reason why khugepaged is unavoidable, is that some memory can be fragmented and not everything can be relocated. So when a virtual machine quits and releases gigabytes of hugepages, we want to use those freely available hugepages to create huge-pmd in the other virtual machines that may be running on fragmented memory, to maximize the CPU efficiency at all times. The scan is slow, it takes nearly zero cpu time, except when it copies data (in which case it means we definitely want to pay for that cpu time) so it seems a good tradeoff. In addition to the hugepages being released by other process releasing memory, we have the strong suspicion that the performance impact of potentially defragmenting hugepages during or before each page fault could lead to more performance inconsistency than allocating small pages at first and having them collapsed into large pages later... if they prove themselfs to be long lived mappings (khugepaged scan is slow so short lived mappings have low probability to run into khugepaged if compared to long lived mappings). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: add pmd_huge_pte to mm_structAndrea Arcangeli
This increase the size of the mm struct a bit but it is needed to preallocate one pte for each hugepage so that split_huge_page will not require a fail path. Guarantee of success is a fundamental property of split_huge_page to avoid decrasing swapping reliability and to avoid adding -ENOMEM fail paths that would otherwise force the hugepage-unaware VM code to learn rolling back in the middle of its pte mangling operations (if something we need it to learn handling pmd_trans_huge natively rather being capable of rollback). When split_huge_page runs a pte is needed to succeed the split, to map the newly splitted regular pages with a regular pte. This way all existing VM code remains backwards compatible by just adding a split_huge_page* one liner. The memory waste of those preallocated ptes is negligible and so it is worth it. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13oom: allow a non-CAP_SYS_RESOURCE proces to oom_score_adj downMandeep Singh Baines
We'd like to be able to oom_score_adj a process up/down as it enters/leaves the foreground. Currently, it is not possible to oom_adj down without CAP_SYS_RESOURCE. This patch allows a task to decrease its oom_score_adj back to the value that a CAP_SYS_RESOURCE thread set it to or its inherited value at fork. Assuming the thread that has forked it has oom_score_adj of 0, each process could decrease it back from 0 upon activation unless a CAP_SYS_RESOURCE thread elevated it to something higher. Alternative considered: * a setuid binary * a daemon with CAP_SYS_RESOURCE Since you don't wan't all processes to be able to reduce their oom_adj, a setuid or daemon implementation would be complex. The alternatives also have much higher overhead. This patch updated from original patch based on feedback from David Rientjes. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Acked-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13sched: remove long deprecated CLONE_STOPPED flagDave Jones
This warning was added in commit bdff746a3915 ("clone: prepare to recycle CLONE_STOPPED") three years ago. 2.6.26 came and went. As far as I know, no-one is actually using CLONE_STOPPED. Signed-off-by: Dave Jones <davej@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07Merge branch 'for-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits) gameport: use this_cpu_read instead of lookup x86: udelay: Use this_cpu_read to avoid address calculation x86: Use this_cpu_inc_return for nmi counter x86: Replace uses of current_cpu_data with this_cpu ops x86: Use this_cpu_ops to optimize code vmstat: User per cpu atomics to avoid interrupt disable / enable irq_work: Use per cpu atomics instead of regular atomics cpuops: Use cmpxchg for xchg to avoid lock semantics x86: this_cpu_cmpxchg and this_cpu_xchg operations percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support percpu,x86: relocate this_cpu_add_return() and friends connector: Use this_cpu operations xen: Use this_cpu_inc_return taskstats: Use this_cpu_ops random: Use this_cpu_inc_return fs: Use this_cpu_inc_return in buffer.c highmem: Use this_cpu_xx_return() operations vmstat: Use this_cpu_inc_return for vm statistics x86: Support for this_cpu_add, sub, dec, inc_return percpu: Generic support for this_cpu_add, sub, dec, inc_return ... Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c} as per Tejun.
2011-01-07sched: Move sched_autogroup_exit() to free_signal_struct()Mike Galbraith
Per Oleg's suggestion, undo fork failure free/put_signal_struct change, and move sched_autogroup_exit() to free_signal_struct() instead. Signed-off-by: Mike Galbraith <efault@gmx.de> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1294222564.8369.6.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-05Merge commit 'v2.6.37' into sched/coreIngo Molnar
Merge reason: Merge the final .37 tree. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-04sched, autogroup: Fix reference leakMike Galbraith
The cgroup exit mess also uncovered a struct autogroup reference leak. copy_process() was simply freeing vs putting the signal_struct, stranding a reference. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Oleg Nesterov <oleg@redhat.com> LKML-Reference: <1293784350.6839.2.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-17core: Replace __get_cpu_var with __this_cpu_read if not used for an address.Christoph Lameter
__get_cpu_var() can be replaced with this_cpu_read and will then use a single read instruction with implied address calculation to access the correct per cpu instance. However, the address of a per cpu variable passed to __this_cpu_read() cannot be determined (since it's an implied address conversion through segment prefixes). Therefore apply this only to uses of __get_cpu_var where the address of the variable is not used. Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Hugh Dickins <hughd@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-08Sched: fix skip_clock_update optimizationMike Galbraith
idle_balance() drops/retakes rq->lock, leaving the previous task vulnerable to set_tsk_need_resched(). Clear it after we return from balancing instead, and in setup_thread_stack() as well, so no successfully descheduled or never scheduled task has it set. Need resched confused the skip_clock_update logic, which assumes that the next call to update_rq_clock() will come nearly immediately after being set. Make the optimization robust against the waking a sleeper before it sucessfully deschedules case by checking that the current task has not been dequeued before setting the flag, since it is that useless clock update we're trying to save, and clear unconditionally in schedule() proper instead of conditionally in put_prev_task(). Signed-off-by: Mike Galbraith <efault@gmx.de> Reported-by: Bjoern B. Brandenburg <bbb.lst@gmail.com> Tested-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@kernel.org LKML-Reference: <1291802742.1417.9.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-30sched: Add 'autogroup' scheduling feature: automated per session task groupsMike Galbraith
A recurring complaint from CFS users is that parallel kbuild has a negative impact on desktop interactivity. This patch implements an idea from Linus, to automatically create task groups. Currently, only per session autogroups are implemented, but the patch leaves the way open for enhancement. Implementation: each task's signal struct contains an inherited pointer to a refcounted autogroup struct containing a task group pointer, the default for all tasks pointing to the init_task_group. When a task calls setsid(), a new task group is created, the process is moved into the new task group, and a reference to the preveious task group is dropped. Child processes inherit this task group thereafter, and increase it's refcount. When the last thread of a process exits, the process's reference is dropped, such that when the last process referencing an autogroup exits, the autogroup is destroyed. At runqueue selection time, IFF a task has no cgroup assignment, its current autogroup is used. Autogroup bandwidth is controllable via setting it's nice level through the proc filesystem: cat /proc/<pid>/autogroup Displays the task's group and the group's nice level. echo <nice level> > /proc/<pid>/autogroup Sets the task group's shares to the weight of nice <level> task. Setting nice level is rate limited for !admin users due to the abuse risk of task group locking. The feature is enabled from boot by default if CONFIG_SCHED_AUTOGROUP=y is selected, but can be disabled via the boot option noautogroup, and can also be turned on/off on the fly via: echo [01] > /proc/sys/kernel/sched_autogroup_enabled ... which will automatically move tasks to/from the root task group. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Paul Turner <pjt@google.com> Cc: Oleg Nesterov <oleg@redhat.com> [ Removed the task_group_path() debug code, and fixed !EVENTFD build failure. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1290281700.28711.9.camel@maggy.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-27signals: move cred_guard_mutex from task_struct to signal_structKOSAKI Motohiro
Oleg Nesterov pointed out we have to prevent multiple-threads-inside-exec itself and we can reuse ->cred_guard_mutex for it. Yes, concurrent execve() has no worth. Let's move ->cred_guard_mutex from task_struct to signal_struct. It naturally prevent multiple-threads-inside-exec. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26oom: add per-mm oom disable countYing Han
It's pointless to kill a task if another thread sharing its mm cannot be killed to allow future memory freeing. A subsequent patch will prevent kills in such cases, but first it's necessary to have a way to flag a task that shares memory with an OOM_DISABLE task that doesn't incur an additional tasklist scan, which would make select_bad_process() an O(n^2) function. This patch adds an atomic counter to struct mm_struct that follows how many threads attached to it have an oom_score_adj of OOM_SCORE_ADJ_MIN. They cannot be killed by the kernel, so their memory cannot be freed in oom conditions. This only requires task_lock() on the task that we're operating on, it does not require mm->mmap_sem since task_lock() pins the mm and the operation is atomic. [rientjes@google.com: changelog and sys_unshare() code] [rientjes@google.com: protect oom_disable_count with task_lock in fork] [rientjes@google.com: use old_mm for oom_disable_count in exec] Signed-off-by: Ying Han <yinghan@google.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22rmap: fix walk during forkAndrea Arcangeli
The below bug in fork led to the rmap walk finding the parent huge-pmd twice instead of just once, because the anon_vma_chain objects of the child vma still point to the vma->vm_mm of the parent. The patch fixes it by making the rmap walk accurate during fork. It's not a big deal normally but it worth being accurate considering the cost is the same. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-21mm: make the vma list be doubly linkedLinus Torvalds
It's a really simple list, and several of the users want to go backwards in it to find the previous vma. So rather than have to look up the previous entry with 'find_vma_prev()' or something similar, just make it doubly linked instead. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-18fs: fs_struct rwlock to spinlockNick Piggin
fs: fs_struct rwlock to spinlock struct fs_struct.lock is an rwlock with the read-side used to protect root and pwd members while taking references to them. Taking a reference to a path typically requires just 2 atomic ops, so the critical section is very small. Parallel read-side operations would have cacheline contention on the lock, the dentry, and the vfsmount cachelines, so the rwlock is unlikely to ever give a real parallelism increase. Replace it with a spinlock to avoid one or two atomic operations in typical path lookup fastpath. Signed-off-by: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09oom: badness heuristic rewriteDavid Rientjes
This a complete rewrite of the oom killer's badness() heuristic which is used to determine which task to kill in oom conditions. The goal is to make it as simple and predictable as possible so the results are better understood and we end up killing the task which will lead to the most memory freeing while still respecting the fine-tuning from userspace. Instead of basing the heuristic on mm->total_vm for each task, the task's rss and swap space is used instead. This is a better indication of the amount of memory that will be freeable if the oom killed task is chosen and subsequently exits. This helps specifically in cases where KDE or GNOME is chosen for oom kill on desktop systems instead of a memory hogging task. The baseline for the heuristic is a proportion of memory that each task is currently using in memory plus swap compared to the amount of "allowable" memory. "Allowable," in this sense, means the system-wide resources for unconstrained oom conditions, the set of mempolicy nodes, the mems attached to current's cpuset, or a memory controller's limit. The proportion is given on a scale of 0 (never kill) to 1000 (always kill), roughly meaning that if a task has a badness() score of 500 that the task consumes approximately 50% of allowable memory resident in RAM or in swap space. The proportion is always relative to the amount of "allowable" memory and not the total amount of RAM systemwide so that mempolicies and cpusets may operate in isolation; they shall not need to know the true size of the machine on which they are running if they are bound to a specific set of nodes or mems, respectively. Root tasks are given 3% extra memory just like __vm_enough_memory() provides in LSMs. In the event of two tasks consuming similar amounts of memory, it is generally better to save root's task. Because of the change in the badness() heuristic's baseline, it is also necessary to introduce a new user interface to tune it. It's not possible to redefine the meaning of /proc/pid/oom_adj with a new scale since the ABI cannot be changed for backward compatability. Instead, a new tunable, /proc/pid/oom_score_adj, is added that ranges from -1000 to +1000. It may be used to polarize the heuristic such that certain tasks are never considered for oom kill while others may always be considered. The value is added directly into the badness() score so a value of -500, for example, means to discount 50% of its memory consumption in comparison to other tasks either on the system, bound to the mempolicy, in the cpuset, or sharing the same memory controller. /proc/pid/oom_adj is changed so that its meaning is rescaled into the units used by /proc/pid/oom_score_adj, and vice versa. Changing one of these per-task tunables will rescale the value of the other to an equivalent meaning. Although /proc/pid/oom_adj was originally defined as a bitshift on the badness score, it now shares the same linear growth as /proc/pid/oom_score_adj but with different granularity. This is required so the ABI is not broken with userspace applications and allows oom_adj to be deprecated for future removal. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-08sched: add hooks for workqueueTejun Heo
Concurrency managed workqueue needs to know when workers are going to sleep and waking up. Using these two hooks, cmwq keeps track of the current concurrency level and throttles execution of new works if it's too high and wakes up another worker from the sleep hook if it becomes too low. This patch introduces PF_WQ_WORKER to identify workqueue workers and adds the following two hooks. * wq_worker_waking_up(): called when a worker is woken up. * wq_worker_sleeping(): called when a worker is going to sleep and may return a pointer to a local task which should be woken up. The returned task is woken up using try_to_wake_up_local() which is simplified ttwu which is called under rq lock and can only wake up local tasks. Both hooks are currently defined as noop in kernel/workqueue_sched.h. Later cmwq implementation will replace them with proper implementation. These hooks are hard coded as they'll always be enabled. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Ingo Molnar <mingo@elte.hu>
2010-05-30Revert "cpusets: randomize node rotor used in cpuset_mem_spread_node()"Linus Torvalds
This reverts commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b, which caused cross-architecture build problems for all the wrong reasons. IA64 already added its own version of __node_random(), but the fact is, there is nothing architectural about the function, and the original commit was just badly done. Revert it, since no fix is forthcoming. Requested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27pids: fix fork_idle() to setup ->pids correctlyOleg Nesterov
copy_process(pid => &init_struct_pid) doesn't do attach_pid/etc. It shouldn't, but this means that the idle threads run with the wrong pids copied from the caller's task_struct. In x86 case the caller is either kernel_init() thread or keventd. In particular, this means that after the series of cpu_up/cpu_down an idle thread (which never exits) can run with .pid pointing to nowhere. Change fork_idle() to initialize idle->pids[] correctly. We only set .pid = &init_struct_pid but do not add .node to list, INIT_TASK() does the same for the boot-cpu idle thread (swapper). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Mathias Krause <Mathias.Krause@secunet.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
